  4. Ring Doorbell Adapter
ringdoorbellring adapter
160 Beiträge 31 Kommentatoren 45.5k Aufrufe 26 Beobachtet
  • planetkeaneP Offline
    planetkeane
    Klappt bei mir auch nicht. Nach Update des Adapters keine Verbindungh zum Host mehr möglich
    host.ioBroker2
    	2022-11-20 12:55:53.622	info	Restart adapter system.adapter.ring.0 because enabled
    host.ioBroker2
    	2022-11-20 12:55:53.622	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker2
    	2022-11-20 12:55:53.622	error	Caught by controller[0]: }
    host.ioBroker2
    	2022-11-20 12:55:53.622	error	Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
    host.ioBroker2
    	2022-11-20 12:55:53.622	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ring/build/lib/ringApiClient.js:4:15) {
    host.ioBroker2
    	2022-11-20 12:55:53.622	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:533:31)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:493:36)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:748:3)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:464:9)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/api/api' is not defined by "exports" in /opt/iobroker/node_modules/ring-client-api/package.json
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: ^
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: throw e;
    host.ioBroker2
    	2022-11-20 12:55:53.621	error	Caught by controller[0]: node:internal/modules/cjs/loader:499
    host.ioBroker2
    	2022-11-20 12:55:53.201	info	instance system.adapter.ring.0 started with pid 310683
    • D denjo
      Moin, mich würde mal interessieren ob irgendwer die neuste Version vom Ring Adapter zum laufen gebracht hat?
      So wie ich weiß nutzen alle die alte 3.0.1 Version, weil das die einzige ist die läuft.
      Ich verstehe den Entwickler leider deswegen nicht, wieso macht er immer neue Versionen aber die meines Wissens nicht laufen.
      Ich bekomme die neuesten Versionen leider nur einmal zum Laufen.
      Vielleicht kann mir das ja mal jemand erklären?
      XceccX Offline
      XceccX Offline
      Xcecc
      @denjo bei mir läuft die Version gar nicht. Im issue von github haben wir auch verschiedene Versionen getestet und es scheint das ab Version 3.0.0 beta 4 die Fehler angefangen haben
      • XceccX Xcecc
        denjo
        @xcecc die 3.0.1 läuft tadellos
        • Daniel ZinglerD Offline
          Daniel Zingler
          Bin noch komplett neu in dem Thema aber habe den 3.1.3 bei mir laufen.
          Die Verbindung mit Host und lebenszeichen haben aber eine ganze Weile gebraucht bis sie auf Grün umgesprungen sind
          • Daniel ZinglerD Daniel Zingler
            denjo
            @daniel-zingler die 3.1.3 funktioniert nur 1 mal beim klingeln. Danach nicht mehr
              Daniel Zingler
              Stimmt gerade getestet
                denjo
                @daniel-zingler deswegen ja die 3.0.1 das die einzige die funktioniert. Ich verstehe auch den Entwickler nicht, weil es genug Issus dazu gibt
                  Daniel Zingler
                  wie kriege ich denn ne andere version da mit rein?
                  Habe den github adapter hinzugefügt und die Version 3.0.4 installiert aber die wird mir unter Instanzen nicht angezeigt.
                  D planetkeaneP 2 Antworten Letzte Antwort
                    denjo
                    schrieb am zuletzt editiert von denjo
                    @daniel-zingler
                    iobroker upgrade ring@3.0.1
                      planetkeane
                      @daniel-zingler
                      Gehe auf https://github.com/iobroker-community-adapters/ioBroker.ring
                      Dort steht auf der rechten Seite "Releases". Klicke auf "+36 Releases".
                      Suche deine Version die du haben möchtest
                      Links auf v3.0.1 klicken und auf der Seite die URL kopieren und in ioBroker eintragen.
                      Schritt für Schritt:
                      • Du hast dein Release v3.0.1 gefunden und bist nun auf der Seite mit dem Quellcode. Kopiere die URL
                      • In ioBroker auf "Adapter" gehen und den Kopf anklicken:
                      • Jetzt bist du im erweiterten Menü und kannst auf die Katze klicken (unten rechts im Bild)
                      • Dann unter "Benutzerdefiniert" die URL eingeben und installieren
                      Ist nicht die "sauberste" Art, aber die einfachste
                      • planetkeaneP planetkeane
                        @daniel-zingler
                        denjo
                        @planetkeane hab doch gesagt was er machen muss
                        planetkeaneP 1 Antwort Letzte Antwort
                          planetkeane
                          btw würde ich die Finger von dem Adapter lassen. Bei mir klappt nur Release v2.0.0-beta.3 und dann bekomme ich ständige errors im log. 3.0.1 verbindet sich ebenfalls nicht.
                          • D denjo
                            planetkeane
                            @denjo Das schon, aber nicht jeder arbeitet in der Kommandozeile bei ioBroker :) Dachte dieser Weg wäre eventuell einfacher
                              denjo
                              @planetkeane richtigen js-controller usw 3.0.1 läuft tadellos und das schon seit monaten
                                Daniel Zingler
                                welcher ist denn der Richtige?
                                  denjo
                                  @daniel-zingler steht in der Beschreibung ich hab eh immer den neuesten drauf
                                    Daniel Zingler
                                    Das Spuckt er mir jetzt aus
                                    host.debian
                                    	2022-11-20 20:40:21.751	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.debian
                                    	2022-11-20 20:40:21.751	error	Caught by controller[0]: }
                                    host.debian
                                    	2022-11-20 20:40:21.751	error	Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
                                    host.debian
                                    	2022-11-20 20:40:21.750	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ring/build/lib/ringApiClient.js:7:15) {
                                    host.debian
                                    	2022-11-20 20:40:21.750	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                                    host.debian
                                    	2022-11-20 20:40:21.750	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
                                    host.debian
                                    	2022-11-20 20:40:21.750	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                                    host.debian
                                    	2022-11-20 20:40:21.749	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:971:27)
                                    host.debian
                                    	2022-11-20 20:40:21.749	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:562:31)
                                    host.debian
                                    	2022-11-20 20:40:21.749	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:522:36)
                                    host.debian
                                    	2022-11-20 20:40:21.748	error	Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:649:3)
                                    host.debian
                                    	2022-11-20 20:40:21.748	error	Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:365:9)
                                    host.debian
                                    	2022-11-20 20:40:21.748	error	Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
                                    host.debian
                                    	2022-11-20 20:40:21.747	error	Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/api/api' is not defined by "exports" in /opt/iobroker/node_modules/ring-client-api/package.json
                                    host.debian
                                    	2022-11-20 20:40:21.747	error	Caught by controller[0]: ^
                                    host.debian
                                    	2022-11-20 20:40:21.747	error	Caught by controller[0]: throw e;
                                    host.debian
                                    	2022-11-20 20:40:21.746	error	Caught by controller[0]: node:internal/modules/cjs/loader:528
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      host.debian
                                      denjo
                                      @daniel-zingler welchen js hast denn jetzt drauf
                                      node 16.x muss man mindestens haben
                                        Daniel Zingler
                                        16.18.1 ist drauf
                                          planetkeane
                                          Hab den 16.17.1 und funktioniert nicht
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: }
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ring/build/lib/ringApiClient.js:7:15) {
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:533:31)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.841	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:493:36)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.840	error	Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:748:3)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.840	error	Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:464:9)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.840	error	Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.840	error	Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/api/api' is not defined by "exports" in /opt/iobroker/node_modules/ring-client-api/package.json
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.840	error	Caught by controller[0]: ^
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.840	error	Caught by controller[0]: throw e;
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.840	error	Caught by controller[0]: node:internal/modules/cjs/loader:499
                                          host.ioBroker2
                                          	2022-11-21 16:18:38.395	info	instance system.adapter.ring.0 started with pid 390107
