  4. Osram Lightify Adapter - Probleme nach Update
    2.2k
    4.1k
4 Beiträge 2 Kommentatoren 836 Aufrufe
    mariohbs
    Hi Leute,
    habe grad das Update vom Osram Lightify Adapter auf 0.2.10 versucht. Alte Version war 0.0.28. Leider scheint das gründlich daneben zu gehen.
    Die Installation an sich scheint gut zu klappen - keine Fehler. Aber dann startet der Adapter nicht mehr und generiert jede Menge Fehlermeldungen im Log. Hier ein Beispiel, welches sich ständig wiederholt:
    host.MyBroker-PI 2017-07-22 19:05:29.410 error instance system.adapter.lightify.0 terminated with code 0 (OK)
    lightify.0 2017-07-22 19:05:29.391 info terminating
    lightify.0 2017-07-22 19:05:29.380 error at Socket.Readable.push (_stream_readable.js:134:10)
    lightify.0 2017-07-22 19:05:29.380 error at readableAddChunk (_stream_readable.js:176:18)
    lightify.0 2017-07-22 19:05:29.380 error at Socket.emit (events.js:188:7)
    lightify.0 2017-07-22 19:05:29.380 error at emitOne (events.js:96:13)
    lightify.0 2017-07-22 19:05:29.380 error at Socket. (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:151:18)
    lightify.0 2017-07-22 19:05:29.380 error at lightify.onData (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:173:18)
    lightify.0 2017-07-22 19:05:29.380 error at lightify.processData (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:116:32)
    lightify.0 2017-07-22 19:05:29.380 error at Object.cb (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:460:28)
    lightify.0 2017-07-22 19:05:29.380 error at Buffer.readUInt8 (buffer.js:855:5)
    lightify.0 2017-07-22 19:05:29.380 error at checkOffset (buffer.js:817:11)
    lightify.0 2017-07-22 19:05:29.380 error RangeError: Index out of range
    lightify.0 2017-07-22 19:05:29.379 error uncaught exception: Index out of range
    lightify.0 2017-07-22 19:05:28.274 info starting. Version 0.2.10 in /opt/iobroker/node_modules/iobroker.lightify, node: v6.9.4
    lightify.0 2017-07-22 19:05:28.201 info States connected to redis 127.0.0.1:6379
    host.MyBroker-PI 2017-07-22 19:05:26.536 info instance system.adapter.lightify.0 started with pid 11428
    host.MyBroker-PI 2017-07-22 19:05:25.523 info Restart adapter system.adapter.lightify.0 because enabled
    host.MyBroker-PI 2017-07-22 19:05:25.522 error instance system.adapter.lightify.0 terminated with code 0 (OK)
    Alle Adapter sind auf aktuellen Stand und laufen ohne Probleme. Bin jetzt erst einmal auf die Version 0.0.28 zurück und da funktioniert wieder alles.
    Hat vielleicht jemand ne Idee für mich, was da Schief geht?
    Danke und viele Grüße
    Mario
      mariohbs
      Keiner ne Idee? Würde ja gerne nochmal testen aber wenn das Licht nicht mehr geht wird die Frau sauer ;)
      • BluefoxB Offline
        BluefoxB Offline
        Habe jetzt genau diesen Fall gefixt, aber das heißt, dass du keine Geräte hast.
          mariohbs
          Hi Bluefox,
          ich verstehe nicht ganz was du mit "keine Geräte hast" meinst. Nach der Installation alle Geräte weg oder…. ?
          Also aktuell habe ich so einige - also 13 Geräte aus dem Lightify System um genau zu sein.
          Danke und lieben Gruß
          Mario
