  4. Ecovacs Adapter NPM Warn Meldung
npmnodeecovacs-deebot adapteradapater
13 Beiträge 3 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • R
    R
    rebel85
    top gemacht wie beschrieben und mal abwarten
    • mrbungle64M mrbungle64
      @rebel85
      https://github.com/mrbungle64/ioBroker.ecovacs-deebot/wiki/FAQ#nodejs-upgrade
      A
      A
      anno171986
      schrieb am zuletzt editiert von anno171986
      @mrbungle64 Hallo, ich habe ein ähnliches Problem. Bei mir ist es nur eine andere Modul Version und ich versuche es über den eChart Adapter.
      Cannot find required modules: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 72. This version of Node.js requires NODE_MODULE_VERSION 93. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
      Habe alles probiert, was du in dem link geschrieben hast.
      pi@raspberrypi:~$ cd /opt/iobroker/node_modules
      pi@raspberrypi:/opt/iobroker/node_modules$ npm rebuild canvas --update-binary
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/canvas
      npm ERR! command failed
      npm ERR! command sh /tmp/install-94cc17b4.sh
      npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
      npm ERR! node-pre-gyp info it worked if it ends with ok
      npm ERR! node-pre-gyp info using node-pre-gyp@1.0.10
      npm ERR! node-pre-gyp info using node@16.17.1 | linux | arm
      npm ERR! node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
      npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
      npm ERR! node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.3 and node@16.17.1 (node-v93 ABI, glibc) (falling back to source compile with node-gyp)
      npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
      npm ERR! node:internal/modules/cjs/loader:959
      npm ERR!   throw err;
      npm ERR!   ^
      npm ERR!
      npm ERR! Error: Cannot find module 'object-assign'
      npm ERR! Require stack:
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
      npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
      npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
      npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
      npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)
      npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32)
      npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:839:12)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19) {
      npm ERR!   code: 'MODULE_NOT_FOUND',
      npm ERR!   requireStack: [
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
      npm ERR!   ]
      npm ERR! }
      npm ERR! node-pre-gyp ERR! build error
      npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
      npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
      npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
      npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1093:16)
      npm ERR! node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
      npm ERR! node-pre-gyp ERR! System Linux 5.10.103-v7l+
      npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
      npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      npm ERR! node-pre-gyp ERR! node -v v16.17.1
      npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.10
      npm ERR! node-pre-gyp ERR! not ok
      npm ERR!     /home/pi/.npm/_logs/2022-11-17T20_54_17_320Z-debug-0.log
      pi@raspberrypi:/opt/iobroker/node_modules$ cd
      pi@raspberrypi:~$ sudo npm uninstall canvas
      up to date, audited 2253 packages in 15s
      9 packages are looking for funding
        run `npm fund` for details
      7 vulnerabilities (6 high, 1 critical)
      To address all issues, run:
        npm audit fix
      Run `npm audit` for details.
      npm notice
      npm notice New major version of npm available! 8.15.0 -> 9.1.2
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v9.1.2
      npm notice Run npm install -g npm@9.1.2 to update!
      npm notice
      pi@raspberrypi:/opt/iobroker/node_modules$ npm uninstall canvas
      removed 98 packages, and changed 1 package in 11s
      79 packages are looking for funding
      pi@raspberrypi:/opt/iobroker/node_modules$ npm install canvas
      npm ERR! code 1
      npm ERR! command sh /tmp/install-bd4fad1a.sh
      npm ERR! node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v93-linux-glibc-arm.tar.gz
      npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v93-linux-glibc-arm.tar.gz
      npm ERR! node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@16.17.1 (node-v93 ABI, glibc) (falling back to source compile with node-gyp)
      npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v93-linux-glibc-arm.tar.gz
      npm ERR!   throw err;
      npm ERR!   ^
      npm ERR!
      npm ERR!   ]
      npm ERR! }
      npm ERR!     /home/pi/.npm/_logs/2022-11-17T20_56_02_687Z-debug-0.log
      Fehler bleibt der gleiche. Hast du noch einen Tipp?
      mrbungle64M 1 Antwort Letzte Antwort
      • A anno171986
        npm ERR! code 1
        npm ERR!   throw err;
        npm ERR!   ^
        npm ERR!
        npm ERR!   ]
        npm ERR! }
          npm audit fix
        npm notice
        npm notice
        npm ERR! code 1
        npm ERR!   throw err;
        npm ERR!   ^
        npm ERR!
        npm ERR!   ]
        npm ERR! }
        mrbungle64M
        mrbungle64M
        mrbungle64
        schrieb am zuletzt editiert von mrbungle64
        @anno171986
        Probier mal
        npm install object-assign --save-dev
          @anno171986
          Probier mal
          A
          A
          anno171986
          @mrbungle64 leider auch nicht
          pi@raspberrypi:/opt/iobroker/node_modules$ cd /opt/iobroker/node_modules
          pi@raspberrypi:/opt/iobroker/node_modules$ npm install object-assign --save-dev
          changed 1 package in 10s
          npm ERR! code 1
          npm ERR! command sh /tmp/install-caf3c17e.sh
          npm ERR!   throw err;
          npm ERR!   ^
          npm ERR!
          npm ERR!   ]
          npm ERR! }
          npm ERR!     /home/pi/.npm/_logs/2022-11-17T21_16_35_572Z-debug-0.log
          • A anno171986
            npm ERR! code 1
            npm ERR!   throw err;
            npm ERR!   ^
            npm ERR!
            npm ERR!   ]
            npm ERR! }
            mrbungle64M
            mrbungle64M
            mrbungle64
            @anno171986
            Das hier ist leider nicht mehr aufgeklärt worden, ob es funktioniert hat - aber probier dann mal
            npm install canvas --build-from-source
            A 3 Antworten Letzte Antwort
              @anno171986
              A
              A
              anno171986
              pi@raspberrypi:/opt/iobroker$ cd /opt/iobroker/node_modules
              pi@raspberrypi:/opt/iobroker/node_modules$ npm install canvas --build-from-source
              npm ERR! code 1
              npm ERR! command sh /tmp/install-ab819b46.sh
              npm ERR! node-pre-gyp info build requesting source compile
              npm ERR!   throw err;
              npm ERR!   ^
              npm ERR!
              npm ERR!   ]
              npm ERR! }
              npm ERR!     /home/pi/.npm/_logs/2022-11-17T21_24_58_078Z-debug-0.log
                @anno171986
                A
                A
                anno171986
                @mrbungle64 in anderen Foren sind Einträge bezüglich des löschens des node_module ordners
                • Remove/delete node_modules directory
                • Re-install: npm install
                • Rebuild canvas npm rebuild --build-from-source canvas
                Würde das was bringen und wenn ja, wie mache ich das?
                • A anno171986
                  mrbungle64M
                  mrbungle64M
                  mrbungle64
                  @anno171986 sagte in Ecovacs Adapter NPM Warn Meldung:
                  Das kann schon was bringen, aber dann müssten alle Adapter inkl. Abhängigkeiten wieder installiert werden.
                  Ich habe aber gerade auch keinen anderen Lösungsansatz parat. Da scheint was quer zu hängen was nichts mit dem Ecovacs Deebot Adapter und evtl. auch nichts mit canvas zu tun hat
                    @anno171986
                    A
                    A
                    anno171986
                    @mrbungle64 Wenn ich das hier mache:
                    pi@raspberrypi:/opt/iobroker/node_modules$ npm ls canvas
                    iobroker.core@1.0.0 /opt/iobroker
                    ├─┬ iobroker.echarts@1.0.12
                    │ ├── canvas@2.9.3
                    │ └─┬ jsdom@19.0.0
                    │   └── canvas@2.9.3 deduped
                    ├─┬ iobroker.iot@1.11.9
                    └─┬ iobroker.mihome-vacuum@3.4.2
                    sieht man dass bei mir "iobroker.core" steht, in dem von dir verlinkten Beitrag steht "iobroker.inst"
                      A
                      A
                      anno171986
                      @mrbungle64 Ok. Alle Adapter neu zu installieren ist ja schon ein enormer Aufwand, da ja wahrscheinlich auch alle Daten weg wären, oder?
                      • A anno171986
                        mrbungle64M
                        mrbungle64M
                        mrbungle64
                        Ich denke, dass die nicht direkt weg sind - aber es kann natürlich Seiteneffekte geben.
                        Von daher würde ich dir davon erst mal abraten.
                        84.1k
