  4. Ecovacs Adapter NPM Warn Meldung
    1.0k
npmnodeecovacs-deebot adapteradapater
13 Beiträge 3 Kommentatoren 1.7k Aufrufe 2 Beobachtet
  • R rebel85
    hallo,
    kann mir bitte wer sagen was ich mit dieser warn meldung mache bzw. wie cih diese wegbekomme?
    	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 72. This version of Node.js requiresNODE_MODULE_VERSION 83. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    Stable normal Adapter mit Debot T8
    mfg
    mrbungle64M Offline
    mrbungle64M Offline
    mrbungle64
    @rebel85
    https://github.com/mrbungle64/ioBroker.ecovacs-deebot/wiki/FAQ#nodejs-upgrade
    • R Offline
      rebel85
      top gemacht wie beschrieben und mal abwarten
      • mrbungle64M mrbungle64
        @rebel85
        anno171986
        schrieb am zuletzt editiert von anno171986
        @mrbungle64 Hallo, ich habe ein ähnliches Problem. Bei mir ist es nur eine andere Modul Version und ich versuche es über den eChart Adapter.
        Cannot find required modules: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 72. This version of Node.js requires NODE_MODULE_VERSION 93. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
        Habe alles probiert, was du in dem link geschrieben hast.
        pi@raspberrypi:~$ cd /opt/iobroker/node_modules
        pi@raspberrypi:/opt/iobroker/node_modules$ npm rebuild canvas --update-binary
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/canvas
        npm ERR! command failed
        npm ERR! command sh /tmp/install-94cc17b4.sh
        npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
        npm ERR! node-pre-gyp info it worked if it ends with ok
        npm ERR! node-pre-gyp info using node-pre-gyp@1.0.10
        npm ERR! node-pre-gyp info using node@16.17.1 | linux | arm
        npm ERR! node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
        npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
        npm ERR! node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.3 and node@16.17.1 (node-v93 ABI, glibc) (falling back to source compile with node-gyp)
        npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.3/canvas-v2.9.3-node-v93-linux-glibc-arm.tar.gz
        npm ERR! node:internal/modules/cjs/loader:959
        npm ERR!   throw err;
        npm ERR!   ^
        npm ERR!
        npm ERR! Error: Cannot find module 'object-assign'
        npm ERR! Require stack:
        npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js
        npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js
        npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js
        npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js
        npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
        npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
        npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
        npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
        npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
        npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)
        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)
        npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
        npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32)
        npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:839:12)
        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19) {
        npm ERR!   code: 'MODULE_NOT_FOUND',
        npm ERR!   requireStack: [
        npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',
        npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',
        npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',
        npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',
        npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
        npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
        npm ERR!   ]
        npm ERR! }
        npm ERR! node-pre-gyp ERR! build error
        npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
        npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
        npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
        npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1093:16)
        npm ERR! node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
        npm ERR! node-pre-gyp ERR! System Linux 5.10.103-v7l+
        npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
        npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        npm ERR! node-pre-gyp ERR! node -v v16.17.1
        npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.10
        npm ERR! node-pre-gyp ERR! not ok
        npm ERR!     /home/pi/.npm/_logs/2022-11-17T20_54_17_320Z-debug-0.log
        pi@raspberrypi:/opt/iobroker/node_modules$ cd
        pi@raspberrypi:~$ sudo npm uninstall canvas
        up to date, audited 2253 packages in 15s
        9 packages are looking for funding
          run `npm fund` for details
        7 vulnerabilities (6 high, 1 critical)
        To address all issues, run:
          npm audit fix
        Run `npm audit` for details.
        npm notice
        npm notice New major version of npm available! 8.15.0 -> 9.1.2
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v9.1.2
        npm notice Run npm install -g npm@9.1.2 to update!
        npm notice
        pi@raspberrypi:/opt/iobroker/node_modules$ npm uninstall canvas
        removed 98 packages, and changed 1 package in 11s
        79 packages are looking for funding
        pi@raspberrypi:/opt/iobroker/node_modules$ npm install canvas
        npm ERR! code 1
        npm ERR! command sh /tmp/install-bd4fad1a.sh
        npm ERR! node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v93-linux-glibc-arm.tar.gz
        npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v93-linux-glibc-arm.tar.gz
        npm ERR! node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@16.17.1 (node-v93 ABI, glibc) (falling back to source compile with node-gyp)
        npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v93-linux-glibc-arm.tar.gz
        npm ERR!   throw err;
        npm ERR!   ^
        npm ERR!
        npm ERR!   ]
        npm ERR! }
        npm ERR!     /home/pi/.npm/_logs/2022-11-17T20_56_02_687Z-debug-0.log
        Fehler bleibt der gleiche. Hast du noch einen Tipp?
        mrbungle64M 1 Antwort Letzte Antwort
        • A anno171986
          npm ERR! code 1
          npm ERR!   throw err;
          npm ERR!   ^
          npm ERR!
          npm ERR!   ]
          npm ERR! }
            npm audit fix
          npm notice
          npm notice
          npm ERR! code 1
          npm ERR!   throw err;
          npm ERR!   ^
          npm ERR!
          npm ERR!   ]
          npm ERR! }
          mrbungle64M Offline
          mrbungle64M Offline
          mrbungle64
          schrieb am zuletzt editiert von mrbungle64
          @anno171986
          Probier mal
          npm install object-assign --save-dev
            @anno171986
            Probier mal
            anno171986
            @mrbungle64 leider auch nicht
            pi@raspberrypi:/opt/iobroker/node_modules$ cd /opt/iobroker/node_modules
            pi@raspberrypi:/opt/iobroker/node_modules$ npm install object-assign --save-dev
            changed 1 package in 10s
            npm ERR! code 1
            npm ERR! command sh /tmp/install-caf3c17e.sh
            npm ERR!   throw err;
            npm ERR!   ^
            npm ERR!
            npm ERR!   ]
            npm ERR! }
            npm ERR!     /home/pi/.npm/_logs/2022-11-17T21_16_35_572Z-debug-0.log
            • A anno171986
              npm ERR! code 1
              npm ERR!   throw err;
              npm ERR!   ^
              npm ERR!
              npm ERR!   ]
              npm ERR! }
              mrbungle64M Offline
              mrbungle64M Offline
              mrbungle64
              @anno171986
              Das hier ist leider nicht mehr aufgeklärt worden, ob es funktioniert hat - aber probier dann mal
              npm install canvas --build-from-source
              A 3 Antworten Letzte Antwort
                @anno171986
                anno171986
                pi@raspberrypi:/opt/iobroker$ cd /opt/iobroker/node_modules
                pi@raspberrypi:/opt/iobroker/node_modules$ npm install canvas --build-from-source
                npm ERR! code 1
                npm ERR! command sh /tmp/install-ab819b46.sh
                npm ERR! node-pre-gyp info build requesting source compile
                npm ERR!   throw err;
                npm ERR!   ^
                npm ERR!
                npm ERR!   ]
                npm ERR! }
                npm ERR!     /home/pi/.npm/_logs/2022-11-17T21_24_58_078Z-debug-0.log
                  @anno171986
                  anno171986
                  @mrbungle64 in anderen Foren sind Einträge bezüglich des löschens des node_module ordners
                  • Remove/delete node_modules directory
                  • Re-install: npm install
                  • Rebuild canvas npm rebuild --build-from-source canvas
                  Würde das was bringen und wenn ja, wie mache ich das?
                  • A anno171986
                    mrbungle64M Offline
                    mrbungle64M Offline
                    mrbungle64
                    @anno171986 sagte in Ecovacs Adapter NPM Warn Meldung:
                    Das kann schon was bringen, aber dann müssten alle Adapter inkl. Abhängigkeiten wieder installiert werden.
                    Ich habe aber gerade auch keinen anderen Lösungsansatz parat. Da scheint was quer zu hängen was nichts mit dem Ecovacs Deebot Adapter und evtl. auch nichts mit canvas zu tun hat
                      @anno171986
                      anno171986
                      @mrbungle64 Wenn ich das hier mache:
                      pi@raspberrypi:/opt/iobroker/node_modules$ npm ls canvas
                      iobroker.core@1.0.0 /opt/iobroker
                      ├─┬ iobroker.echarts@1.0.12
                      │ ├── canvas@2.9.3
                      │ └─┬ jsdom@19.0.0
                      │   └── canvas@2.9.3 deduped
                      ├─┬ iobroker.iot@1.11.9
                      └─┬ iobroker.mihome-vacuum@3.4.2
                      sieht man dass bei mir "iobroker.core" steht, in dem von dir verlinkten Beitrag steht "iobroker.inst"
                        anno171986
                        @mrbungle64 Ok. Alle Adapter neu zu installieren ist ja schon ein enormer Aufwand, da ja wahrscheinlich auch alle Daten weg wären, oder?
                        • A anno171986
                          mrbungle64M Offline
                          mrbungle64M Offline
                          mrbungle64
                          Ich denke, dass die nicht direkt weg sind - aber es kann natürlich Seiteneffekte geben.
                          Von daher würde ich dir davon erst mal abraten.
