    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • ArmilarA Armilar
    @wuschl
    Poste nochmal die Config, bitte
    und die aktuellen Logs.
    W Offline
    W Offline
    Wuschl
    #794
    @armilar
    export const config: Config = {
        panelRecvTopic: 'mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT',       // anpassen
        panelSendTopic: 'mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend',   // anpassen
        firstScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Hourly.h0.PrecipitationProbability', ScreensaverEntityIcon: 'weather-pouring', ScreensaverEntityText: 'Regen', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100} },
        secondScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.WindSpeed', ScreensaverEntityIcon: 'weather-windy', ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'km/h', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
        thirdScreensaverEntity: { ScreensaverEntity: "shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3", ScreensaverEntityIcon: "pool-thermometer", ScreensaverEntityText: "Pool", ScreensaverEntityUnitText: "°C", ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 40} },
        fourthScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity', ScreensaverEntityIcon: 'water-percent', ScreensaverEntityText: 'Luft', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
        alternativeScreensaverLayout: false,
        autoWeatherColorScreensaverLayout: true,
        mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
        mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
        timeoutScreensaver: 20,
        dimmode: 20,
        active: 100, //Standard-Brightness TFT
        screenSaverDoubleClick: true,
        locale: 'de-DE',                                // en-US, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.
        timeFormat: '%H:%M',                            // currently not used
        dateFormat: '%A, %d. %B %Y',                    // currently not used
        weatherEntity: 'alias.0.Wetter.Gerät_1',                // Dieser Alias muss erstellt werden, damit die 4 kleineren Icons (Wetter oder DP) angezeigt werden können --> oder autoCreateAlias auf true
        defaultOffColor: Off,
        defaultOnColor: On,
        defaultColor: Off,
        defaultBackgroundColor: Black,    //New Parameter
        temperatureUnit: '°C',
        pages: [
                Garagen,
                WLAN,
                Service             //Auto-Alias Service Page
        subPages: [
                    NSPanel_Infos,              //Auto-Alias Service Page
                    NSPanel_Einstellungen,      //Auto-Alias Service Page
                    NSPanel_Firmware_Info       //Auto-Alias Service Page
        button1Page: null,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
        button2Page: null    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
    16.11.2022, 22:14:57.478	[info ]: javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
    16.11.2022, 22:15:01.129	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
    16.11.2022, 22:15:01.900	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
    16.11.2022, 22:15:01.983	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
    16.11.2022, 22:15:02.043	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
    16.11.2022, 22:15:03.460	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
    16.11.2022, 22:15:03.460	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
    16.11.2022, 22:15:03.461	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
    16.11.2022, 22:15:03.461	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)```
    code_text
    • ArmilarA Armilar
      @armilar
      on({id: [].concat(['0_userdata.0.NSPanel.1.Relay.1']).concat(['0_userdata.0.NSPanel.1.Relay.2']), change: "ne"}, async function (obj) {
          console.log(obj.id);
          console.log((obj.common ? obj.common.name : ""));
          console.log((obj.common ? obj.common.desc : ""));
          console.log(obj.channelId);
          console.log(obj.channelName);
          console.log(obj.deviceName);
          console.log((obj.state ? obj.state.val : ""));
          console.log((obj.state ? obj.state.ts : ""));
          console.log((obj.state ? obj.state.q : ""));
          console.log((obj.state ? obj.state.from : ""));
      Pass mal die beiden Datenpunkte im Trigger an deine an. Dann Trigger mal beide Datenpunkte (true/false) und sende das Log zurück.
      --> Als neues Test-Script anlegen
      Ich denke wir werden mit einem Spit über die obj.id gehen. Die ist eindeutig
      PeoplesP Offline
      PeoplesP Offline
      Peoples
      schrieb am zuletzt editiert von Peoples
      #795
      @armilar
      bitteschön
      2022-11-16 22:26:07.923 - info: javascript.0 (400696) script.js.test: 0_userdata.0.NSPanel.Fitness.Relay.1
      2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: 0_userdata.0.NSPanel.Fitness.Relay.1
      2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: undefined
      2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: Relay
      2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: Fitness
      2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: true
      2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: 1668633967917
      2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: 0
      • PeoplesP Peoples
        @armilar
        bitteschön
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        Most Active Forum Testing
        #796
        @peoples
        Okay, hatte ich mir schon gedacht.
        Nimm mal den Code aus diesen Post (vor ein paar Minuten):
        https://forum.iobroker.net/post/893216
        Ich habe die obj.id zerlegt und nehme den Teil nach dem Punkt. Dann sollte es passen.
        • ArmilarA Offline
          ArmilarA Offline
          Armilar
          #797
          @wuschl
          hmm, dachte ich hätte eben geantwortet. Aber dann sah ich meine Frage nicht mehr 😵
          Ich kann keine Fehler finden in der Config. Sende mal den kompletten oberen Teil (Code in einem Spoiler)
          erst
          dann außen noch
          Muss ich mir komplett ansehen. Irgendwo ist noch ein Fehlerchen in dem Teil. Kann aber bis morgen dauern.
          W 1 Antwort Letzte Antwort
          • ArmilarA Armilar
            @peoples
            Habe es auf die obj.id umgeschrieben. Tausche mal die Zeilen im TS-Script aus...
            //switch Relays 1 + 2 with DP's
            async function Init_Relays() {
                if (existsState(NSPanel_Path + 'Relay.1') == false ||
                    existsState(NSPanel_Path + 'Relay.2') == false) {
                    await createStateAsync(NSPanel_Path + 'Relay.1', true, { type: 'boolean' });
                    await createStateAsync(NSPanel_Path + 'Relay.2', true, { type: 'boolean' });
            Init_Relays();
            on({id: [].concat(String(NSPanel_Path) + 'Relay.1').concat(String(NSPanel_Path) + 'Relay.2'), change: "ne"}, async function (obj) {
                try {
                    let Button = obj.id.split('.');
                    console.log(((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))));
                    require("request")((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))).on("error", function (err) {console.error(err.message);});
                } catch (err) {
                    console.warn(err.message);
            on({id: [].concat(config.mrIcon1ScreensaverEntity.ScreensaverEntity).concat(config.mrIcon2ScreensaverEntity.ScreensaverEntity), change: "ne"}, async function (obj) {
                if (obj.id.substring(0,4) == 'mqtt') {
                    if (getState(NSPanel_Path + 'Relay.' + Button[Button.length - 1].substring(5,6)).val != obj.state.val) {
                        await setStateAsync(NSPanel_Path + 'Relay.' + Button[Button.length - 1].substring(5,6), obj.state.val == 'ON' ? true : false);
            PeoplesP Offline
            PeoplesP Offline
            Peoples
            #798
            @armilar
            Ja mit der Änderung funktioniert es
            • PeoplesP Peoples
              @armilar
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #799
              @peoples 👍
              • ArmilarA Armilar
                @wuschl
                erst
                dann außen noch
                W Offline
                W Offline
                Wuschl
                #800
                @armilar
                let vwIconColor = [];
                //-- Anfang der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ----------------
                var Garagen: PageEntities =
                    "type": "cardEntities",
                    "heading": "Garagen",
                    "useColor": true,
                    "subPage": false,
                    "parent": undefined,
                    "items": [
                        <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Audi", offColor: MSGreen, onColor: MSRed, name: "Garage Audi", icon: "garage-variant", icon2: "garage-open-variant"},
                        <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Polo", offColor: MSGreen, onColor: MSRed, name: "Garage Polo", icon: "garage-variant", icon2: "garage-open-variant"},
                        <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Fahrräder", offColor: MSGreen, onColor: MSRed, name: "Garage Fahrräder", icon: "garage-variant", icon2: "garage-open-variant"},
                var WLAN: PageQR =
                    "type": "cardQR",
                    "heading": "Gäste WLAN",
                    "useColor": true,
                    "subPage": true,
                    "items": [<PageItem>{ id: "alias.0.NsPanelGarage.WLAN" }]
                //-- ENDE der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ------------------
                //Service Pages mit Auto-Alias (Nachfolgende Seiten werden mit Alias automatisch angelegt)
                let Service: PageEntities =
                    "heading": "NSPanel Service",
                    "useColor": true,
                    "subPage": false,
                    "items": [
                        <PageItem>{ id: AliasPath + 'autoUpdate', name: "Auto-Updates" ,icon: "update", offColor: MSRed, onColor: MSGreen},
                        <PageItem>{ navigate: true, id: "NSPanel_Infos", icon: "information-outline", onColor: White, name: "NSPanel Infos"},
                        <PageItem>{ navigate: true, id: "NSPanel_Firmware_Info", icon: "update", onColor: White, name: "Firmware Infos"},
                        <PageItem>{ navigate: true, id: "NSPanel_Einstellungen", icon: "wrench-outline", onColor: White, name: "Screensaver"}
                        //Subpage 1 von Subpages_2
                        let NSPanel_Infos: PageEntities =
                            "heading": "NSPanel Infos",
                            "useColor": true,
                            "subPage": true,
                            "parent": Service,
                            "items": [
                                <PageItem>{ id: AliasPath + 'Tasmota.Hardware', name: 'Hardware', icon: 'memory', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                <PageItem>{ id: AliasPath + 'Sensor.ESP32.Temperature', name: "ESP Temperatur", icon: "thermometer", unit: "°C", offColor: MSYellow, onColor: MSYellow, useColor: true},
                                <PageItem>{ id: AliasPath + 'Tasmota.Uptime', name: "Uptime", icon: "timeline-clock-outline", offColor: MSYellow, onColor: MSYellow, useColor: true},
                                <PageItem>{ id: AliasPath + 'Tasmota.Wifi.RSSI', name: "Wifi-Signal", icon: "signal-distance-variant", unit: "dBm", offColor: MSYellow, onColor: MSYellow, useColor: true}
                        //Subpage 2 von Subpages_2
                        let NSPanel_Einstellungen: PageEntities =
                            'type': 'cardEntities',
                            'heading': 'Screensaver',
                            'useColor': true,
                            'subPage': true,
                            'parent': Service,
                            'items': [
                                <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                                <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                                <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                                <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
                        //Subpage 3 von Subpages_2
                        let NSPanel_Firmware_Info: PageEntities =
                            'heading': 'Firmware-Updates',
                            'useColor': true,
                            'subPage': true,
                            'parent': Service,
                            'items': [
                                <PageItem>{ id: AliasPath + 'Tasmota.Version', name: 'Tasmota Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                <PageItem>{ id: AliasPath + 'Display.TFTVersion', name: 'TFT-Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                <PageItem>{ id: AliasPath + 'Display.BerryDriver', name: 'Berry-Treiber', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                <PageItem>{ id: AliasPath + 'Display.Model', name: 'NSPanel Version', offColor: MSYellow, onColor: MSYellow, useColor: true}
                    dimmode: 20,
                    defaultOnColor: On,
                    defaultColor: Off,
                    pages: [
                            Garagen,
                            WLAN,
                    subPages: [
                [s=]
                [/s]
                ArmilarA T 2 Antworten Letzte Antwort
                • W Wuschl
                  @armilar
                      "useColor": true,
                      "subPage": false,
                      "items": [
                  var WLAN: PageQR =
                      "type": "cardQR",
                      "useColor": true,
                      "subPage": true,
                      "useColor": true,
                      "subPage": false,
                      "items": [
                              "useColor": true,
                              "subPage": true,
                              "parent": Service,
                              "items": [
                              'useColor': true,
                              'subPage': true,
                              'parent': Service,
                              'items': [
                              'useColor': true,
                              'subPage': true,
                              'parent': Service,
                              'items': [
                      dimmode: 20,
                      defaultOnColor: On,
                      defaultColor: Off,
                      pages: [
                              Garagen,
                              WLAN,
                      subPages: [
                  [s=]
                  [/s]
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #801
                  @wuschl sagte in SONOFF NSPanel mit Lovelace UI:
                  var WLAN: PageQR =
                  "type": "cardQR",
                  "useColor": true,
                  "subPage": true,
                  Du hast eine SubPage unter die Pages gehängt
                  Setze mal subPage auf false.
                  var WLAN: PageQR =
                      "type": "cardQR",
                      "useColor": true,
                      "subPage": false,
                  • ArmilarA Armilar
                    var WLAN: PageQR =
                    "type": "cardQR",
                    "useColor": true,
                    "subPage": true,
                    var WLAN: PageQR =
                        "type": "cardQR",
                        "useColor": true,
                        "subPage": false,
                    W Offline
                    W Offline
                    Wuschl
                    #802
                    @armilar das wars auch nicht
                    17.11.2022, 14:43:01.211	[info ]: javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                    17.11.2022, 14:43:05.999	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                    17.11.2022, 14:43:06.786	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                    17.11.2022, 14:43:06.843	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                    17.11.2022, 14:43:06.869	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                    17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                    17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                    17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                    17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)
                    • W Wuschl
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #803
                      @wuschl
                      Dann schalten wir mal etwas mehr Logging ein (oben rechts vom Script):
                      Dann Speichern und das Log senden in dem die Warnungen auftauchen.
                      Danach den Haken wieder raus und erneut speichern.
                      • ArmilarA Armilar
                        @wuschl
                        W Offline
                        W Offline
                        Wuschl
                        #804
                        @armilar wie kann ich dir das senden? Der Text ist zu lange.
                        • W Wuschl
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #805
                          @wuschl
                          nicht alles, sondern nur die Zeilen ab ca. 10 vor den Warnungen und 10 nach den Warnungen. Sollte direkt nach dem Start des Scriptes kommen. Also max. 30 - 100 Zeilen.
                          Es geht mir nur um die Funktionen die zuvor aufgerufen werden und danach um die Position zu lokalisieren. Die Zeilen-Nummerierung gibt das nicht her. Sonst könnte man ja mit den Daten von dir arbeiten ;-)
                          W 2 Antworten Letzte Antwort
                          • ArmilarA Armilar
                            @wuschl
                            W Offline
                            W Offline
                            Wuschl
                            #806
                            @armilar
                            18:50:59.370	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                            18:51:00.731	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                            18:51:00.819	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                            18:51:00.821	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.PageNavi","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.824	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_hourDay, timerId=undefined) => {"val":7,"ack":true,"ts":1668327325121,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325121}
                            18:51:00.824	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_hourNight, timerId=undefined) => {"val":22,"ack":true,"ts":1668327325607,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325607}
                            18:51:00.824	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_brightnessDay, timerId=undefined) => {"val":8,"ack":true,"ts":1668327324911,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327324911}
                            18:51:00.825	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_brightnessNight, timerId=undefined) => {"val":1,"ack":true,"ts":1668327325318,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325318}
                            18:51:00.825	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_hourDay, timerId=undefined) => {"val":7,"ack":true,"ts":1668327325121,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325121}
                            18:51:00.829	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=[object Object])
                            18:51:00.829	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_hourNight, timerId=undefined) => {"val":22,"ack":true,"ts":1668327325607,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325607}
                            18:51:00.830	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=[object Object])
                            18:51:00.831	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"dimmode~8~100~0","ack":false,"ts":1668707460831,"q":0,"from":"system.adapter.javascript.0","lc":1668707460831,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:00.837	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=* * * * *)
                            18:51:00.838	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.ScreensaverInfo.entityChangeTime, timerId=undefined) => {"val":60,"ack":true,"ts":1668327325175,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325175}
                            18:51:00.841	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=*/60 * * * * *)
                            18:51:00.842	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.843	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.843	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.ScreensaverInfo.weatherForecast","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.844	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=0 * * * *)
                            18:51:00.847	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=[object Object])
                            18:51:00.847	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(wizard={"time":{"start":"00:00","end":"23:59","mode":"hours","interval":12},"period":{"days":1}})
                            18:51:00.851	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"pageType~pageStartup","ack":false,"ts":1668707460851,"q":0,"from":"system.adapter.javascript.0","lc":1668707460851,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:00.852	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.tele.NS-Panel-Paps_0BED20.INFO2, timerId=undefined) => {"val":"{\"Info2\":{\"WebServerMode\":\"Admin\",\"Hostname\":\"NS-Panel-Paps-0BED20-3360\",\"IPAddress\":\"192.168.178.244\"}}","ack":true,"ts":1668692778130,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668270172355}
                            18:51:00.855	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.Tasmota_Firmware.currentVersion, timerId=undefined) => {"val":"12.2.0","ack":true,"ts":1668702873969,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327326108}
                            18:51:00.856	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.Tasmota_Firmware.onlineVersion, timerId=undefined) => {"val":"12.2.0","ack":true,"ts":1668702874500,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325585}
                            18:51:00.856	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.Berry_Driver.currentVersion, timerId=undefined) => {"val":"4","ack":true,"ts":1668702874147,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325585}
                            18:51:00.856	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.Display_Firmware.currentVersion, timerId=undefined) => {"val":"43","ack":true,"ts":1668702874596,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325214}
                            18:51:00.858	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.popupNotify.popupNotifyAction","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.858	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.858	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"accuweather.0.Hourly.h0.PrecipitationProbability","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.859	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"accuweather.0.Current.WindSpeed","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.859	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.859	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"accuweather.0.Current.RelativeHumidity","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.859	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.860	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Alarm.AlarmState","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.860	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.tele.NS-Panel-Paps_0BED20.SENSOR","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:00.860	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                            18:51:00.909	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.autoUpdate, obj={"type":"channel","common":{"role":"socket","name":"AutoUpdate"},"native":{}})
                            18:51:01.088	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.tele.NS-Panel-Paps_0BED20.INFO2, timerId=undefined) => {"val":"{\"Info2\":{\"WebServerMode\":\"Admin\",\"Hostname\":\"NS-Panel-Paps-0BED20-3360\",\"IPAddress\":\"192.168.178.244\"}}","ack":true,"ts":1668692778130,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668270172355}
                            18:51:01.089	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.NSPanel_ipAddress, state={"val":"192.168.178.244","ack":true,"ts":1668707461089,"q":0,"from":"system.adapter.javascript.0","lc":1668327325124,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:01.091	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.ScreensaverInfo.popupNotifyHeading","change":"ne","ack":false,"q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:01.093	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.ScreensaverInfo.popupNotifyText","change":"ne","ack":false,"q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:01.094	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.popupNotify.popupNotifyInternalName","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:01.146	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota_Firmware.currentVersion, state={"val":"12.2.0","ack":true,"ts":1668707461145,"q":0,"from":"system.adapter.javascript.0","lc":1668327326108,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:01.165	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.NSPanel_locales_json, state={"val":"{\n \"lights\": {\n \"Brightness\": {\n \"en-US\": \"Brightness\",\n \"de-DE\": \"Helligkeit\",\n \"nl-NL\": \"Helderheid\",\n \"da-DK\": \"Lysstyrke\",\n \"es-ES\": \"Brillo\",\n \"fr-FR\": \"Luminosité\",\n \"it-IT\": \"Luminosità\",\n \"ru-RU\": \"Яркость\",\n \"nb-NO\": \"Lysstyrke\",\n \"nn-NO\": \"Lysstyrke\",\n \"pl-PL\": \"Jasność\",\n \"pt-PT\": \"Brilho\",\n \"af-ZA\": \"Helderheid\",\n \"ar-SY\": \"السطوع\",\n \"bg-BG\": \"Яркост\",\n \"ca-ES\": \"Brillantor\",\n \"cs-CZ\": \"Jas\",\n \"el-GR\": \"Φωτεινότητα\",\n \"et-EE\": \"Heledus\",\n \"fa-IR\": \"روشنایی\",\n \"fi-FI\": \"Kirkkaus\",\n \"he-IL\": \"בהירות\",\n \"hr-xx\": \"Svjetlina\",\n \"hu-HU\": \"Fényerő\",\n \"hy-AM\": \"Պայծառություն\",\n \"id-ID\": \"Kecerahan\",\n \"is-IS\": \"Birtustig\",\n \"lb-xx\": \"Hellegkeet\",\n \"lt-LT\": \"Ryškumas\",\n \"ro-RO\": \"Luminozitate\",\n \"sk-SK\": \"Jas\",\n \"sl-SI\": \"Svetlost\",\n \"sv-SE\": \"Ljusstyrka\",\n \"th-TH\": \"ความสว่าง\",\n \"tr-TR\": \"Parlaklık\",\n \"uk-UA\": \"Яскравість\",\n \"vi-VN\": \"Độ sáng\",\n \"zh-CN\": \"亮度\",\n \"zh-TW\": \"亮度\"\n },\n \"Temperature\": {\n \"en-US\": \"Color temperature\",\n \"de-DE\": \"Farbtemperatur\",\n \"nl-NL\": \"Kleurtemperatuur\",\n \"da-DK\": \"Farvetemperatur\",\n \"es-ES\": \"Temperatura del color\",\n \"fr-FR\": \"Température de couleur\",\n \"it-IT\": \"Temperatura colore\",\n \"ru-RU\": \"Цветовая температура\",\n \"nb-NO\": \"Fargetemperatur\",\n \"nn-NO\": \"Fargetemperatur\",\n \"pl-PL\": \"Temperatura barwy\",\n \"pt-PT\": \"Temperatura de cor\",\n \"af-ZA\": \"Kleur temperatuur\",\n \"ar-SY\": \"درجة حرارة اللون\",\n \"bg-BG\": \"Цветова температура\",\n \"ca-ES\": \"Temperatura de color\",\n \"cs-CZ\": \"Teplota barvy\",\n \"el-GR\": \"Θερμοκρασία χρώματος\",\n \"et-EE\": \"Värvustemperatuur\",\n \"fa-IR\": \"دمای رنگ\",\n \"fi-FI\": \"Värilämpötila\",\n \"he-IL\": \"טמפרטורת הצבע\",\n \"hr-xx\": \"Temperatura boje\",\n \"hu-HU\": \"Színhőmérséklet\",\n \"hy-AM\": \"Գունային ջերմաստիճան\",\n \"id-ID\": \"Temperatur warna\",\n \"is-IS\": \"Litastig\",\n \"lb-xx\": \"Faarf Temperatur\",\n \"lt-LT\": \"Spalvos temperatūra\",\n \"ro-RO\": \"Temperatură de culoare\",\n \"sk-SK\": \"Teplota farby\",\n \"sl-SI\": \"Temperatura barve\",\n \"sv-SE\": \"Färgtemperatur\",\n \"th-TH\": \"อุณหภูมิสี\",\n \"tr-TR\": \"Renk sıcaklığı\",\n \"uk-UA\": \"Кольорова температура\",\n \"vi-VN\": \"Nhiệt độ màu\",\n \"zh-CN\": \"色温\",\n \"zh-TW\": \"色溫\"\n }\n },\n \"window\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыто\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворен\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστό\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגור\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Loka\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängt\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинене\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыто\",\n \"nb-NO\": \"Åpent\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворен\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτό\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוח\",\n \"hr-xx\": \"Otvoreno\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opna\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppet\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинене\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"開啟\"\n }\n },\n \"door\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыта\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворена\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστή\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגורה\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Lokuð\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängd\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинені\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"已關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыта\",\n \"nb-NO\": \"Åpen\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворена\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτή\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוחה\",\n \"hr-xx\": \"Otvori\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opin\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppen\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинені\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"已開啟\"\n }\n },\n \"lock\": {\n \"LOCK\": {\n \"en-US\": \"Lock\",\n \"de-DE\": \"Verriegeln\",\n \"nl-NL\": \"Vergrendelen\",\n \"da-DK\": \"Lås\",\n \"es-ES\": \"Bloquear\",\n \"fr-FR\": \"Verrouiller\",\n \"it-IT\": \"Blocca\",\n \"ru-RU\": \"Закрыть\",\n \"nb-NO\": \"Lås\",\n \"nn-NO\": \"Lås\",\n \"pl-PL\": \"Zablokuj\",\n \"pt-PT\": \"Bloquear\",\n \"af-ZA\": \"Sluit toe\",\n \"ar-SY\": \"قفل\",\n \"bg-BG\": \"Заключване\",\n \"ca-ES\": \"Bloquejar\",\n \"cs-CZ\": \"Zamknout\",\n \"el-GR\": \"Κλείδωμα\",\n \"et-EE\": \"Lukusta\",\n \"fa-IR\": \"قفل\",\n \"fi-FI\": \"Lukitse\",\n \"he-IL\": \"נעילה\",\n \"hr-xx\": \"zaključati\",\n \"hu-HU\": \"Bezár\",\n \"hy-AM\": \"Կողպեք\",\n \"id-ID\": \"Kunci\",\n \"is-IS\": \"Læsa\",\n \"lb-xx\": \"Spären\",\n \"lt-LT\": \"Užrakinti\",\n \"ro-RO\": \"Blocat\",\n \"sk-SK\": \"Zamknúť\",\n \"sl-SI\": \"Zakleni\",\n \"sv-SE\": \"Lås\",\n \"th-TH\": \"ล็อค\",\n \"tr-TR\": \"Kilitle\",\n \"uk-UA\": \"Блокувати\",\n \"vi-VN\": \"Khóa\",\n \"zh-CN\": \"锁定\",\n \"zh-TW\": \"上鎖\"\n },\n \"UNLOCK\": {\n \"en-US\": \"Unlock\",\n \"de-DE\": \"Entriegeln\",\n \"nl-NL\": \"Ontgrendelen\",\n \"da-DK\": \"Lås op\",\n \"es-ES\": \"Desbloquear\",\n \"fr-FR\": \"Déverrouiller\",\n \"it-IT\": \"Sblocca\",\n \"ru-RU\": \"Открыть\",\n \"nb-NO\": \"Lås opp\",\n \"nn-NO\": \"Lås opp\",\n \"pl-PL\": \"Odblokuj\",\n \"pt-PT\": \"Desbloquear\",\n \"af-ZA\": \"Sluit oop\",\n \"ar-SY\": \"فتح\",\n \"bg-BG\": \"Отключване\",\n \"ca-ES\": \"Desbloquejar\",\n \"cs-CZ\": \"Odemknout\",\n \"el-GR\": \"Ξεκλείδωμα\",\n \"et-EE\": \"Ava\",\n \"fa-IR\": \"باز کردن\",\n \"fi-FI\": \"Avaa lukitus\",\n \"he-IL\": \"ביטול נעילה\",\n \"hr-xx\": \"Otključati\",\n \"hu-HU\": \"Kinyit\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Buka\",\n \"is-IS\": \"Aflæsa\",\n \"lb-xx\": \"Entspären\",\n \"lt-LT\": \"Atrakinti\",\n \"ro-RO\": \"Deblocare\",\n \"sk-SK\": \"Odomknúť\",\n \"sl-SI\": \"Odkleni\",\n \"sv-SE\": \"Lås upp\",\n \"th-TH\": \"ปลดล็อค\",\n \"tr-TR\": \"Kilidi aç\",\n \"uk-UA\": \"Розблокувати\",\n \"vi-VN\": \"Mở khóa\",\n \"zh-CN\": \"解锁\",\n \"zh-TW\": \"解鎖\"\n }\n },\n \"blinds\": {\n \"Position\": {\n \"en-US\": \"Position\",\n \"de-DE\": \"Position\",\n \"nl-NL\": \"Positie\",\n \"da-DK\": \"Position\",\n \"es-ES\": \"Posición\",\n \"fr-FR\": \"Position\",\n \"it-IT\": \"Apertura\",\n \"ru-RU\": \"Положение\",\n \"nb-NO\": \"Posisjon\",\n \"nn-NO\": \"Posisjon\",\n \"pl-PL\": \"Pozycja\",\n \"pt-PT\": \"Posição\",\n \"af-ZA\": \"Posisie\",\n \"ar-SY\": \"موضع\",\n \"bg-BG\": \"Позиция\",\n \"ca-ES\": \"Posició\",\n \"cs-CZ\": \"Pozice\",\n \"el-GR\": \"Θέση\",\n \"et-EE\": \"Asend\",\n \"fa-IR\": \"موقعیت\",\n \"fi-FI\": \"Sijainti\",\n \"he-IL\": \"מיקום\",\n \"hr-xx\": \"Pozicija\",\n \"hu-HU\": \"Pozíció\",\n \"hy-AM\": \"Դիրք\",\n \"id-ID\": \"Posisi\",\n \"is-IS\": \"Staðsetning\",\n \"lb-xx\": \"Positioun\",\n \"lt-LT\": \"Padėtis\",\n \"ro-RO\": \"Poziţie\",\n \"sk-SK\": \"Poloha\",\n \"sl-SI\": \"Položaj\",\n \"sv-SE\": \"Position\",\n \"th-TH\": \"ตำแหน่ง\",\n \"tr-TR\": \"Pozisyon\",\n \"uk-UA\": \"Положення\",\n \"vi-VN\": \"Vị trí\",\n \"zh-CN\": \"位置\",\n \"zh-TW\": \"位置\"\n }\n },\n \"thermostat\": {\n \"Currently\": {\n \"en-US\": \"Currently\",\n \"de-DE\": \"Aktuell\",\n \"nl-NL\": \"Momenteel\",\n \"da-DK\": \"Aktuelt\",\n \"es-ES\": \"Actualmente\",\n \"fr-FR\": \"Actuellement\",\n \"it-IT\": \"Attualmente\",\n \"ru-RU\": \"Сейчас\",\n \"nb-NO\": \"Er nå\",\n \"nn-NO\": \"Akkurat no\",\n \"pl-PL\": \"Obecnie\",\n \"pt-PT\": \"Atualmente\",\n \"af-ZA\": \"Tans\",\n \"ar-SY\": \"حاليا\",\n \"bg-BG\": \"В момента\",\n \"ca-ES\": \"Actual\",\n \"cs-CZ\": \"Aktuálně\",\n \"el-GR\": \"Αυτή τη στιγμή\",\n \"et-EE\": \"Hetkel\",\n \"fa-IR\": \"در حال حاضر\",\n \"fi-FI\": \"Tällä hetkellä\",\n \"he-IL\": \"כעת\",\n \"hr-xx\": \"Trenutno\",\n \"hu-HU\": \"Jelenleg\",\n \"hy-AM\": \"Ներկայումս\",\n \"id-ID\": \"Saat ini\",\n \"is-IS\": \"Er núna\",\n \"lb-xx\": \"Momentan\",\n \"lt-LT\": \"Šiuo metu\",\n \"ro-RO\": \"În prezent\",\n \"sk-SK\": \"Aktuálne\",\n \"sl-SI\": \"Trenutno\",\n \"sv-SE\": \"Nuvarande\",\n \"th-TH\": \"ในขณะนี้\",\n \"tr-TR\": \"Şu an\",\n \"uk-UA\": \"В даний час\",\n \"vi-VN\": \"Hiện tại\",\n \"zh-CN\": \"当前\",\n \"zh-TW\": \"目前狀態\"\n },\n \"State\": {\n \"en-US\": \"State\",\n \"de-DE\": \"Zustand\",\n \"nl-NL\": \"Toestand\",\n \"da-DK\": \"Tilstand\",\n \"es-ES\": \"Estado\",\n \"fr-FR\": \"État\",\n \"it-IT\": \"Stato\",\n \"ru-RU\": \"Состояние\",\n \"nb-NO\": \"Tilstand\",\n \"nn-NO\": \"Tilstand\",\n \"pl-PL\": \"Stan\",\n \"pt-PT\": \"Estado\",\n \"af-ZA\": {\n \"add_entities_lovelace\": \"Voeg by Lovelace\",\n \"entities\": \"Entiteite\",\n \"none\": \"Hierdie toestel het geen entiteite nie\"\n },\n \"ar-SY\": {\n \"add_entities_lovelace\": \"أضف إلى Lovelace\",\n \"disabled_entities\": \"{count} {count, plural,\\n one {كيان}\\n other {كيانات}\\n}\",\n \"entities\": \"الكيانات\",\n \"hide_disabled\": \"إخفاء معطل\",\n \"none\": \"هذا الجهاز ليس له كيانات\"\n },\n \"bg-BG\": {\n \"add_entities_lovelace\": \"Добавете към Lovelace\",\n \"config\": \"Конфиг.\",\n \"control\": \"Контроли\",\n \"diagnostic\": \"Диагностика\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {деактивиран обект}\\n other {деактивирани обекта}\\n}\",\n \"entities\": \"Обекти\",\n \"hide_disabled\": \"Скриване на деактивираните\",\n \"none\": \"Това устройство няма обекти\",\n \"sensor\": \"Сензори\"\n },\n \"ca-ES\": \"Estat\",\n \"cs-CZ\": \"Stav\",\n \"el-GR\": \"Κατάσταση\",\n \"et-EE\": \"Olek\",\n \"fa-IR\": {\n \"add_entities_lovelace\": \"Adauga la Lovelace\",\n \"entities\": \"Entitati\",\n \"none\": \"Acest dispozitiv nu are nicio entitate\"\n },\n \"fi-FI\": \"Tila\",\n \"he-IL\": \"מצב\",\n \"hr-xx\": {\n \"automation\": {\n \"actions\": {\n \"caption\": \"Kada se nešto pokrene…\"\n },\n \"automations\": \"Automatizacije\",\n \"conditions\": {\n \"caption\": \"Učini nešto samo ako…\"\n },\n \"create\": \"Stvorite automatizaciju s uređajem\",\n \"no_automations\": \"Nema automatizacije\",\n \"no_device_automations\": \"Nema dostupnih automatizacija za ovaj uređaj.\",\n \"triggers\": {\n \"caption\": \"Učini nešto kad...\"\n }\n },\n \"cant_edit\": \"Možete uređivati samo stavke stvorene u korisničkom sučelju (UI).\",\n \"caption\": \"Uređaji\",\n \"confirm_rename_entity_ids\": \"Želite li također preimenovati ID entiteta svojih entiteta?\",\n \"data_table\": {\n \"area\": \"Područje\",\n \"battery\": \"Baterija\",\n \"device\": \"Uređaj\",\n \"integration\": \"Integracija\",\n \"manufacturer\": \"Proizvođač\",\n \"model\": \"Model\"\n },\n \"description\": \"Upravljanje povezanim uređajima\",\n \"device_not_found\": \"Uređaj nije pronađen.\",\n \"name\": \"Naziv\",\n \"scene\": {\n \"create\": \"Stvorite scenu s uređajem\",\n \"no_scenes\": \"Nema scena\",\n \"scenes\": \"Scene\"\n },\n \"scenes\": \"Scene\",\n \"script\": {\n \"create\": \"Stvorite skriptu s uređajem\",\n \"no_scripts\": \"Nema skripte\",\n \"scripts\": \"Skripte\"\n },\n \"scripts\": \"Skripte\",\n \"unknown_error\": \"Nepoznata pogreška\",\n \"unnamed_device\": \"Neimenovani uređaj\",\n \"update\": \"Ažuriraj\"\n },\n \"hu-HU\": \"Állapot\",\n \"hy-AM\": {\n \"automation\": {\n \"create_disable\": \"Հնարավոր չէ ստեղծել ավտոմատացում անջատված սարքով\"\n },\n \"disabled\": \"Անջատված\",\n \"disabled_by\": {\n \"config_entry\": \"Կարգավորման կետ\",\n \"integration\": \"Ինտեգրում\",\n \"user\": \"Օգտատեր\"\n },\n \"enabled_cause\": \"Անջատված է {cause}-ի կողմից\",\n \"enabled_label\": \"Միացնել սարքը\",\n \"picker\": {\n \"filter\": {\n \"filter\": \"Ֆիլտր\",\n \"show_all\": \"Ցույց տալ ամբողջը\",\n \"show_disabled\": \"Ցուցադրել ապաակտիվացված սարքերը\"\n },\n \"search\": \"Որոնել սարքեր\"\n },\n \"scene\": {\n \"create_disable\": \"Հնարավոր չէ սցենար ստեղծել անջատված սարքով\"\n },\n \"script\": {\n \"create_disable\": \"Անջատված սարքով հնարավոր չէ ստեղծել սկրիպտ\"\n }\n },\n \"id-ID\": \"Status\",\n \"is-IS\": \"Staða\",\n \"lb-xx\": {\n \"add_entities_lovelace\": \"Zu Lovelace bäisetzen\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {Déaktivéiert Entitéit}\\n other {Déaktivéiert Entitéiten}\\n}\",\n \"entities\": \"Entitéiten\",\n \"hide_disabled\": \"Deaktivéiert net uweisen\",\n \"none\": \"Dësen Appart huet keng Entitéiten.\"\n },\n \"lt-LT\": {\n \"add_entities_lovelace\": \"Pridėti į Lovelace\",\n \"config\": \"Konfigūracija\",\n \"control\": \"Valdikliai\",\n \"diagnostic\": \"Diagnostika\",\n \"entities\": \"Subjektai\",\n \"sensor\": \"Jutikliai\"\n },\n \"ro-RO\": {\n \"add_entities_lovelace\": \"Adăugați la Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {entitate dezactivată}\\n other {entități dezactivate}\\n}\",\n \"entities\": \"Entități\",\n \"hide_disabled\": \"Ascundeți dezactivate\",\n \"none\": \"Acest dispozitiv nu are entități\",\n \"sensor\": \"Senzori\"\n },\n \"sk-SK\": \"Stav\",\n \"sl-SI\": \"Stanje\",\n \"sv-SE\": \"Tillstånd\",\n \"th-TH\": \"สถานะ\",\n \"tr-TR\": \"Durum\",\n \"uk-UA\": \"Стан\",\n \"vi-VN\": {\n \"add_entities_lovelace\": \"Thêm vào Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {thực thể bị vô hiệu hoá}\\n other {các thực thể bị vô hiệu hoá}\\n}\",\n \"entities\": \"Các thực thể\",\n \"hide_disabled\": \"Ẩn các thiết bị bị vô hiệu hoá\",\n \"none\": \"Thiết bị này không có thực thể nào\"\n },\n \"zh-CN\": \"状态\",\n \"zh-TW\": \"狀態\"\n },\n \"Action\": {\n \"en-US\": \"Operation\",\n \"de-DE\": \"Aktion\",\n \"nl-NL\": \"Werking\",\n \"da-DK\": \"Drifttype\",\n \"es-ES\": \"Modo\",\n \"fr-FR\": \"Opération\",\n \"it-IT\": \"Operazione\",\n \"ru-RU\": \"Режим работы\",\n \"nb-NO\": \"Operasjon\",\n \"nn-NO\": \"Operasjon\",\n \"pl-PL\": \"Tryb pracy\",\n \"pt-PT\": \"Operação\",\n \"af-ZA\": \"Operasie\",\n \"ar-SY\": \"الوضع\",\n \"bg-BG\": \"Режим\",\n \"ca-ES\": \"Funcionament\",\n \"cs-CZ\": \"Provoz\",\n \"el-GR\": \"Λειτουργία\",\n \"et-EE\": \"Töörežiim\",\n \"fa-IR\": \"عملیات\",\n \"fi-FI\": \"Toiminto\",\n \"he-IL\": \"פעולה\",\n \"hr-xx\": \"operacija\",\n \"hu-HU\": \"Működés\",\n \"hy-AM\": \"Գործողություն\",\n \"id-ID\": \"Operasi\",\n \"is-IS\": \"Aðgerð\",\n \"lb-xx\": \"Aktioun\",\n \"lt-LT\": \"Operacija\",\n \"ro-RO\": \"Operație\",\n \"sk-SK\": \"Prevádzka\",\n \"sl-SI\": \"Delovanje\",\n \"sv-SE\": \"Driftläge\",\n \"th-TH\": \"การทำงาน\",\n \"tr-TR\": \"İşlem\",\n \"uk-UA\": \"Режим\",\n \"vi-VN\": \"Chế độ hoạt động\",\n \"zh-CN\": \"运行模式\",\n \"zh-TW\": \"運轉模式\"\n }\n }\n}","ack":true,"ts":1668707461164,"q":0,"from":"system.adapter.javascript.0","lc":1668327324911,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:01.171	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.ipAddress, obj={"type":"channel","common":{"role":"info","name":"ipAddress"},"native":{}})
                            18:51:01.182	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Uptime, state={"val":"0T04:04:50","ack":true,"ts":1668707461182,"q":0,"from":"system.adapter.javascript.0","lc":1668707461182,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:01.277	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Version, state={"val":"12.2.0(tasmota)","ack":true,"ts":1668707461277,"q":0,"from":"system.adapter.javascript.0","lc":1668327326125,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:01.318	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"date~Donnerstag, 17. November 2022","ack":false,"ts":1668707461318,"q":0,"from":"system.adapter.javascript.0","lc":1668707461318,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:01.319	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"time~18:51","ack":false,"ts":1668707461319,"q":0,"from":"system.adapter.javascript.0","lc":1668707461319,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:01.319	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"timeout~20","ack":false,"ts":1668707461319,"q":0,"from":"system.adapter.javascript.0","lc":1668707461319,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                            18:51:01.320	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Version, timerId=undefined) => {"val":"eu","ack":true,"ts":1668702874935,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325303}
                            18:51:01.323	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getObject(id=alias.0.Garagen-Papa.Garage-Audi, enumName=undefined) => {"_id":"alias.0.Garagen-Papa.Garage-Audi","common":{"name":{"de":"Garage-Audi"},"role":"gate","icon":"","color":null},"native":{},"type":"channel","from":"system.adapter.admin.0","user":"system.user.admin","ts":1668611449973,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                            18:51:01.324	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Garagen-Papa.Garage-Audi.SET, timerId=undefined) => {"val":false,"ack":true,"ts":1668621847691,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1668620862733}
                            18:51:01.324	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"alias.0.Garagen-Papa.Garage-Audi.SET","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                            18:51:01.325	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Garagen-Papa.Garage-Audi.ACTUAL, timerId=undefined) => {"val":false,"ack":false,"ts":1668700336224,"q":0,"c":"script.js.Papa-Garagen.Garage_Audi","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668700336224}
                            18:51:01.326	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_locales_json, timerId=undefined) => {"val":"{\n \"lights\": {\n \"Brightness\": {\n \"en-US\": \"Brightness\",\n \"de-DE\": \"Helligkeit\",\n \"nl-NL\": \"Helderheid\",\n \"da-DK\": \"Lysstyrke\",\n \"es-ES\": \"Brillo\",\n \"fr-FR\": \"Luminosité\",\n \"it-IT\": \"Luminosità\",\n \"ru-RU\": \"Яркость\",\n \"nb-NO\": \"Lysstyrke\",\n \"nn-NO\": \"Lysstyrke\",\n \"pl-PL\": \"Jasność\",\n \"pt-PT\": \"Brilho\",\n \"af-ZA\": \"Helderheid\",\n \"ar-SY\": \"السطوع\",\n \"bg-BG\": \"Яркост\",\n \"ca-ES\": \"Brillantor\",\n \"cs-CZ\": \"Jas\",\n \"el-GR\": \"Φωτεινότητα\",\n \"et-EE\": \"Heledus\",\n \"fa-IR\": \"روشنایی\",\n \"fi-FI\": \"Kirkkaus\",\n \"he-IL\": \"בהירות\",\n \"hr-xx\": \"Svjetlina\",\n \"hu-HU\": \"Fényerő\",\n \"hy-AM\": \"Պայծառություն\",\n \"id-ID\": \"Kecerahan\",\n \"is-IS\": \"Birtustig\",\n \"lb-xx\": \"Hellegkeet\",\n \"lt-LT\": \"Ryškumas\",\n \"ro-RO\": \"Luminozitate\",\n \"sk-SK\": \"Jas\",\n \"sl-SI\": \"Svetlost\",\n \"sv-SE\": \"Ljusstyrka\",\n \"th-TH\": \"ความสว่าง\",\n \"tr-TR\": \"Parlaklık\",\n \"uk-UA\": \"Яскравість\",\n \"vi-VN\": \"Độ sáng\",\n \"zh-CN\": \"亮度\",\n \"zh-TW\": \"亮度\"\n },\n \"Temperature\": {\n \"en-US\": \"Color temperature\",\n \"de-DE\": \"Farbtemperatur\",\n \"nl-NL\": \"Kleurtemperatuur\",\n \"da-DK\": \"Farvetemperatur\",\n \"es-ES\": \"Temperatura del color\",\n \"fr-FR\": \"Température de couleur\",\n \"it-IT\": \"Temperatura colore\",\n \"ru-RU\": \"Цветовая температура\",\n \"nb-NO\": \"Fargetemperatur\",\n \"nn-NO\": \"Fargetemperatur\",\n \"pl-PL\": \"Temperatura barwy\",\n \"pt-PT\": \"Temperatura de cor\",\n \"af-ZA\": \"Kleur temperatuur\",\n \"ar-SY\": \"درجة حرارة اللون\",\n \"bg-BG\": \"Цветова температура\",\n \"ca-ES\": \"Temperatura de color\",\n \"cs-CZ\": \"Teplota barvy\",\n \"el-GR\": \"Θερμοκρασία χρώματος\",\n \"et-EE\": \"Värvustemperatuur\",\n \"fa-IR\": \"دمای رنگ\",\n \"fi-FI\": \"Värilämpötila\",\n \"he-IL\": \"טמפרטורת הצבע\",\n \"hr-xx\": \"Temperatura boje\",\n \"hu-HU\": \"Színhőmérséklet\",\n \"hy-AM\": \"Գունային ջերմաստիճան\",\n \"id-ID\": \"Temperatur warna\",\n \"is-IS\": \"Litastig\",\n \"lb-xx\": \"Faarf Temperatur\",\n \"lt-LT\": \"Spalvos temperatūra\",\n \"ro-RO\": \"Temperatură de culoare\",\n \"sk-SK\": \"Teplota farby\",\n \"sl-SI\": \"Temperatura barve\",\n \"sv-SE\": \"Färgtemperatur\",\n \"th-TH\": \"อุณหภูมิสี\",\n \"tr-TR\": \"Renk sıcaklığı\",\n \"uk-UA\": \"Кольорова температура\",\n \"vi-VN\": \"Nhiệt độ màu\",\n \"zh-CN\": \"色温\",\n \"zh-TW\": \"色溫\"\n }\n },\n \"window\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыто\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворен\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστό\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגור\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Loka\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängt\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинене\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыто\",\n \"nb-NO\": \"Åpent\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворен\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτό\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוח\",\n \"hr-xx\": \"Otvoreno\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opna\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppet\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинене\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"開啟\"\n }\n },\n \"door\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыта\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворена\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστή\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגורה\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Lokuð\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängd\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинені\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"已關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыта\",\n \"nb-NO\": \"Åpen\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворена\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτή\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוחה\",\n \"hr-xx\": \"Otvori\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opin\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppen\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинені\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"已開啟\"\n }\n },\n \"lock\": {\n \"LOCK\": {\n \"en-US\": \"Lock\",\n \"de-DE\": \"Verriegeln\",\n \"nl-NL\": \"Vergrendelen\",\n \"da-DK\": \"Lås\",\n \"es-ES\": \"Bloquear\",\n \"fr-FR\": \"Verrouiller\",\n \"it-IT\": \"Blocca\",\n \"ru-RU\": \"Закрыть\",\n \"nb-NO\": \"Lås\",\n \"nn-NO\": \"Lås\",\n \"pl-PL\": \"Zablokuj\",\n \"pt-PT\": \"Bloquear\",\n \"af-ZA\": \"Sluit toe\",\n \"ar-SY\": \"قفل\",\n \"bg-BG\": \"Заключване\",\n \"ca-ES\": \"Bloquejar\",\n \"cs-CZ\": \"Zamknout\",\n \"el-GR\": \"Κλείδωμα\",\n \"et-EE\": \"Lukusta\",\n \"fa-IR\": \"قفل\",\n \"fi-FI\": \"Lukitse\",\n \"he-IL\": \"נעילה\",\n \"hr-xx\": \"zaključati\",\n \"hu-HU\": \"Bezár\",\n \"hy-AM\": \"Կողպեք\",\n \"id-ID\": \"Kunci\",\n \"is-IS\": \"Læsa\",\n \"lb-xx\": \"Spären\",\n \"lt-LT\": \"Užrakinti\",\n \"ro-RO\": \"Blocat\",\n \"sk-SK\": \"Zamknúť\",\n \"sl-SI\": \"Zakleni\",\n \"sv-SE\": \"Lås\",\n \"th-TH\": \"ล็อค\",\n \"tr-TR\": \"Kilitle\",\n \"uk-UA\": \"Блокувати\",\n \"vi-VN\": \"Khóa\",\n \"zh-CN\": \"锁定\",\n \"zh-TW\": \"上鎖\"\n },\n \"UNLOCK\": {\n \"en-US\": \"Unlock\",\n \"de-DE\": \"Entriegeln\",\n \"nl-NL\": \"Ontgrendelen\",\n \"da-DK\": \"Lås op\",\n \"es-ES\": \"Desbloquear\",\n \"fr-FR\": \"Déverrouiller\",\n \"it-IT\": \"Sblocca\",\n \"ru-RU\": \"Открыть\",\n \"nb-NO\": \"Lås opp\",\n \"nn-NO\": \"Lås opp\",\n \"pl-PL\": \"Odblokuj\",\n \"pt-PT\": \"Desbloquear\",\n \"af-ZA\": \"Sluit oop\",\n \"ar-SY\": \"فتح\",\n \"bg-BG\": \"Отключване\",\n \"ca-ES\": \"Desbloquejar\",\n \"cs-CZ\": \"Odemknout\",\n \"el-GR\": \"Ξεκλείδωμα\",\n \"et-EE\": \"Ava\",\n \"fa-IR\": \"باز کردن\",\n \"fi-FI\": \"Avaa lukitus\",\n \"he-IL\": \"ביטול נעילה\",\n \"hr-xx\": \"Otključati\",\n \"hu-HU\": \"Kinyit\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Buka\",\n \"is-IS\": \"Aflæsa\",\n \"lb-xx\": \"Entspären\",\n \"lt-LT\": \"Atrakinti\",\n \"ro-RO\": \"Deblocare\",\n \"sk-SK\": \"Odomknúť\",\n \"sl-SI\": \"Odkleni\",\n \"sv-SE\": \"Lås upp\",\n \"th-TH\": \"ปลดล็อค\",\n \"tr-TR\": \"Kilidi aç\",\n \"uk-UA\": \"Розблокувати\",\n \"vi-VN\": \"Mở khóa\",\n \"zh-CN\": \"解锁\",\n \"zh-TW\": \"解鎖\"\n }\n },\n \"blinds\": {\n \"Position\": {\n \"en-US\": \"Position\",\n \"de-DE\": \"Position\",\n \"nl-NL\": \"Positie\",\n \"da-DK\": \"Position\",\n \"es-ES\": \"Posición\",\n \"fr-FR\": \"Position\",\n \"it-IT\": \"Apertura\",\n \"ru-RU\": \"Положение\",\n \"nb-NO\": \"Posisjon\",\n \"nn-NO\": \"Posisjon\",\n \"pl-PL\": \"Pozycja\",\n \"pt-PT\": \"Posição\",\n \"af-ZA\": \"Posisie\",\n \"ar-SY\": \"موضع\",\n \"bg-BG\": \"Позиция\",\n \"ca-ES\": \"Posició\",\n \"cs-CZ\": \"Pozice\",\n \"el-GR\": \"Θέση\",\n \"et-EE\": \"Asend\",\n \"fa-IR\": \"موقعیت\",\n \"fi-FI\": \"Sijainti\",\n \"he-IL\": \"מיקום\",\n \"hr-xx\": \"Pozicija\",\n \"hu-HU\": \"Pozíció\",\n \"hy-AM\": \"Դիրք\",\n \"id-ID\": \"Posisi\",\n \"is-IS\": \"Staðsetning\",\n \"lb-xx\": \"Positioun\",\n \"lt-LT\": \"Padėtis\",\n \"ro-RO\": \"Poziţie\",\n \"sk-SK\": \"Poloha\",\n \"sl-SI\": \"Položaj\",\n \"sv-SE\": \"Position\",\n \"th-TH\": \"ตำแหน่ง\",\n \"tr-TR\": \"Pozisyon\",\n \"uk-UA\": \"Положення\",\n \"vi-VN\": \"Vị trí\",\n \"zh-CN\": \"位置\",\n \"zh-TW\": \"位置\"\n }\n },\n \"thermostat\": {\n \"Currently\": {\n \"en-US\": \"Currently\",\n \"de-DE\": \"Aktuell\",\n \"nl-NL\": \"Momenteel\",\n \"da-DK\": \"Aktuelt\",\n \"es-ES\": \"Actualmente\",\n \"fr-FR\": \"Actuellement\",\n \"it-IT\": \"Attualmente\",\n \"ru-RU\": \"Сейчас\",\n \"nb-NO\": \"Er nå\",\n \"nn-NO\": \"Akkurat no\",\n \"pl-PL\": \"Obecnie\",\n \"pt-PT\": \"Atualmente\",\n \"af-ZA\": \"Tans\",\n \"ar-SY\": \"حاليا\",\n \"bg-BG\": \"В момента\",\n \"ca-ES\": \"Actual\",\n \"cs-CZ\": \"Aktuálně\",\n \"el-GR\": \"Αυτή τη στιγμή\",\n \"et-EE\": \"Hetkel\",\n \"fa-IR\": \"در حال حاضر\",\n \"fi-FI\": \"Tällä hetkellä\",\n \"he-IL\": \"כעת\",\n \"hr-xx\": \"Trenutno\",\n \"hu-HU\": \"Jelenleg\",\n \"hy-AM\": \"Ներկայումս\",\n \"id-ID\": \"Saat ini\",\n \"is-IS\": \"Er núna\",\n \"lb-xx\": \"Momentan\",\n \"lt-LT\": \"Šiuo metu\",\n \"ro-RO\": \"În prezent\",\n \"sk-SK\": \"Aktuálne\",\n \"sl-SI\": \"Trenutno\",\n \"sv-SE\": \"Nuvarande\",\n \"th-TH\": \"ในขณะนี้\",\n \"tr-TR\": \"Şu an\",\n \"uk-UA\": \"В даний час\",\n \"vi-VN\": \"Hiện tại\",\n \"zh-CN\": \"当前\",\n \"zh-TW\": \"目前狀態\"\n },\n \"State\": {\n \"en-US\": \"State\",\n \"de-DE\": \"Zustand\",\n \"nl-NL\": \"Toestand\",\n \"da-DK\": \"Tilstand\",\n \"es-ES\": \"Estado\",\n \"fr-FR\": \"État\",\n \"it-IT\": \"Stato\",\n \"ru-RU\": \"Состояние\",\n \"nb-NO\": \"Tilstand\",\n \"nn-NO\": \"Tilstand\",\n \"pl-PL\": \"Stan\",\n \"pt-PT\": \"Estado\",\n \"af-ZA\": {\n \"add_entities_lovelace\": \"Voeg by Lovelace\",\n \"entities\": \"Entiteite\",\n \"none\": \"Hierdie toestel het geen entiteite nie\"\n },\n \"ar-SY\": {\n \"add_entities_lovelace\": \"أضف إلى Lovelace\",\n \"disabled_entities\": \"{count} {count, plural,\\n one {كيان}\\n other {كيانات}\\n}\",\n \"entities\": \"الكيانات\",\n \"hide_disabled\": \"إخفاء معطل\",\n \"none\": \"هذا الجهاز ليس له كيانات\"\n },\n \"bg-BG\": {\n \"add_entities_lovelace\": \"Добавете към Lovelace\",\n \"config\": \"Конфиг.\",\n \"control\": \"Контроли\",\n \"diagnostic\": \"Диагностика\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {деактивиран обект}\\n other {деактивирани обекта}\\n}\",\n \"entities\": \"Обекти\",\n \"hide_disabled\": \"Скриване на деактивираните\",\n \"none\": \"Това устройство няма обекти\",\n \"sensor\": \"Сензори\"\n },\n \"ca-ES\": \"Estat\",\n \"cs-CZ\": \"Stav\",\n \"el-GR\": \"Κατάσταση\",\n \"et-EE\": \"Olek\",\n \"fa-IR\": {\n \"add_entities_lovelace\": \"Adauga la Lovelace\",\n \"entities\": \"Entitati\",\n \"none\": \"Acest dispozitiv nu are nicio entitate\"\n },\n \"fi-FI\": \"Tila\",\n \"he-IL\": \"מצב\",\n \"hr-xx\": {\n \"automation\": {\n \"actions\": {\n \"caption\": \"Kada se nešto pokrene…\"\n },\n \"automations\": \"Automatizacije\",\n \"conditions\": {\n \"caption\": \"Učini nešto samo ako…\"\n },\n \"create\": \"Stvorite automatizaciju s uređajem\",\n \"no_automations\": \"Nema automatizacije\",\n \"no_device_automations\": \"Nema dostupnih automatizacija za ovaj uređaj.\",\n \"triggers\": {\n \"caption\": \"Učini nešto kad...\"\n }\n },\n \"cant_edit\": \"Možete uređivati samo stavke stvorene u korisničkom sučelju (UI).\",\n \"caption\": \"Uređaji\",\n \"confirm_rename_entity_ids\": \"Želite li također preimenovati ID entiteta svojih entiteta?\",\n \"data_table\": {\n \"area\": \"Područje\",\n \"battery\": \"Baterija\",\n \"device\": \"Uređaj\",\n \"integration\": \"Integracija\",\n \"manufacturer\": \"Proizvođač\",\n \"model\": \"Model\"\n },\n \"description\": \"Upravljanje povezanim uređajima\",\n \"device_not_found\": \"Uređaj nije pronađen.\",\n \"name\": \"Naziv\",\n \"scene\": {\n \"create\": \"Stvorite scenu s uređajem\",\n \"no_scenes\": \"Nema scena\",\n \"scenes\": \"Scene\"\n },\n \"scenes\": \"Scene\",\n \"script\": {\n \"create\": \"Stvorite skriptu s uređajem\",\n \"no_scripts\": \"Nema skripte\",\n \"scripts\": \"Skripte\"\n },\n \"scripts\": \"Skripte\",\n \"unknown_error\": \"Nepoznata pogreška\",\n \"unnamed_device\": \"Neimenovani uređaj\",\n \"update\": \"Ažuriraj\"\n },\n \"hu-HU\": \"Állapot\",\n \"hy-AM\": {\n \"automation\": {\n \"create_disable\": \"Հնարավոր չէ ստեղծել ավտոմատացում անջատված սարքով\"\n },\n \"disabled\": \"Անջատված\",\n \"disabled_by\": {\n \"config_entry\": \"Կարգավորման կետ\",\n \"integration\": \"Ինտեգրում\",\n \"user\": \"Օգտատեր\"\n },\n \"enabled_cause\": \"Անջատված է {cause}-ի կողմից\",\n \"enabled_label\": \"Միացնել սարքը\",\n \"picker\": {\n \"filter\": {\n \"filter\": \"Ֆիլտր\",\n \"show_all\": \"Ցույց տալ ամբողջը\",\n \"show_disabled\": \"Ցուցադրել ապաակտիվացված սարքերը\"\n },\n \"search\": \"Որոնել սարքեր\"\n },\n \"scene\": {\n \"create_disable\": \"Հնարավոր չէ սցենար ստեղծել անջատված սարքով\"\n },\n \"script\": {\n \"create_disable\": \"Անջատված սարքով հնարավոր չէ ստեղծել սկրիպտ\"\n }\n },\n \"id-ID\": \"Status\",\n \"is-IS\": \"Staða\",\n \"lb-xx\": {\n \"add_entities_lovelace\": \"Zu Lovelace bäisetzen\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {Déaktivéiert Entitéit}\\n other {Déaktivéiert Entitéiten}\\n}\",\n \"entities\": \"Entitéiten\",\n \"hide_disabled\": \"Deaktivéiert net uweisen\",\n \"none\": \"Dësen Appart huet keng Entitéiten.\"\n },\n \"lt-LT\": {\n \"add_entities_lovelace\": \"Pridėti į Lovelace\",\n \"config\": \"Konfigūracija\",\n \"control\": \"Valdikliai\",\n \"diagnostic\": \"Diagnostika\",\n \"entities\": \"Subjektai\",\n \"sensor\": \"Jutikliai\"\n },\n \"ro-RO\": {\n \"add_entities_lovelace\": \"Adăugați la Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {entitate dezactivată}\\n other {entități dezactivate}\\n}\",\n \"entities\": \"Entități\",\n \"hide_disabled\": \"Ascundeți dezactivate\",\n \"none\": \"Acest dispozitiv nu are entități\",\n \"sensor\": \"Senzori\"\n },\n \"sk-SK\": \"Stav\",\n \"sl-SI\": \"Stanje\",\n \"sv-SE\": \"Tillstånd\",\n \"th-TH\": \"สถานะ\",\n \"tr-TR\": \"Durum\",\n \"uk-UA\": \"Стан\",\n \"vi-VN\": {\n \"add_entities_lovelace\": \"Thêm vào Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {thực thể bị vô hiệu hoá}\\n other {các thực thể bị vô hiệu hoá}\\n}\",\n \"entities\": \"Các thực thể\",\n \"hide_disabled\": \"Ẩn các thiết bị bị vô hiệu hoá\",\n \"none\": \"Thiết bị này không có thực thể nào\"\n },\n \"zh-CN\": \"状态\",\n \"zh-TW\": \"狀態\"\n },\n \"Action\": {\n \"en-US\": \"Operation\",\n \"de-DE\": \"Aktion\",\n \"nl-NL\": \"Werking\",\n \"da-DK\": \"Drifttype\",\n \"es-ES\": \"Modo\",\n \"fr-FR\": \"Opération\",\n \"it-IT\": \"Operazione\",\n \"ru-RU\": \"Режим работы\",\n \"nb-NO\": \"Operasjon\",\n \"nn-NO\": \"Operasjon\",\n \"pl-PL\": \"Tryb pracy\",\n \"pt-PT\": \"Operação\",\n \"af-ZA\": \"Operasie\",\n \"ar-SY\": \"الوضع\",\n \"bg-BG\": \"Режим\",\n \"ca-ES\": \"Funcionament\",\n \"cs-CZ\": \"Provoz\",\n \"el-GR\": \"Λειτουργία\",\n \"et-EE\": \"Töörežiim\",\n \"fa-IR\": \"عملیات\",\n \"fi-FI\": \"Toiminto\",\n \"he-IL\": \"פעולה\",\n \"hr-xx\": \"operacija\",\n \"hu-HU\": \"Működés\",\n \"hy-AM\": \"Գործողություն\",\n \"id-ID\": \"Operasi\",\n \"is-IS\": \"Aðgerð\",\n \"lb-xx\": \"Aktioun\",\n \"lt-LT\": \"Operacija\",\n \"ro-RO\": \"Operație\",\n \"sk-SK\": \"Prevádzka\",\n \"sl-SI\": \"Delovanje\",\n \"sv-SE\": \"Driftläge\",\n \"th-TH\": \"การทำงาน\",\n \"tr-TR\": \"İşlem\",\n \"uk-UA\": \"Режим\",\n \"vi-VN\": \"Chế độ hoạt động\",\n \"zh-CN\": \"运行模式\",\n \"zh-TW\": \"運轉模式\"\n }\n }\n}","ack":true,"ts":1668707461164,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327324911}
                            • ArmilarA Armilar
                              @wuschl
                              W Offline
                              W Offline
                              Wuschl
                              #807
                              @armilar
                              18:51:01.330	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"alias.0.Garagen-Papa.Garage-Audi.ACTUAL","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                              18:51:01.331	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getObject(id=alias.0.Garagen-Papa.Garage-Polo, enumName=undefined) => {"_id":"alias.0.Garagen-Papa.Garage-Polo","common":{"name":{"de":"Garage-Polo"},"role":"gate","icon":"","color":null},"native":{},"type":"channel","from":"system.adapter.admin.0","user":"system.user.admin","ts":1668611696389,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                              18:51:01.332	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_locales_json, timerId=undefined) => {"val":"{\n \"lights\": {\n \"Brightness\": {\n \"en-US\": \"Brightness\",\n \"de-DE\": \"Helligkeit\",\n \"nl-NL\": \"Helderheid\",\n \"da-DK\": \"Lysstyrke\",\n \"es-ES\": \"Brillo\",\n \"fr-FR\": \"Luminosité\",\n \"it-IT\": \"Luminosità\",\n \"ru-RU\": \"Яркость\",\n \"nb-NO\": \"Lysstyrke\",\n \"nn-NO\": \"Lysstyrke\",\n \"pl-PL\": \"Jasność\",\n \"pt-PT\": \"Brilho\",\n \"af-ZA\": \"Helderheid\",\n \"ar-SY\": \"السطوع\",\n \"bg-BG\": \"Яркост\",\n \"ca-ES\": \"Brillantor\",\n \"cs-CZ\": \"Jas\",\n \"el-GR\": \"Φωτεινότητα\",\n \"et-EE\": \"Heledus\",\n \"fa-IR\": \"روشنایی\",\n \"fi-FI\": \"Kirkkaus\",\n \"he-IL\": \"בהירות\",\n \"hr-xx\": \"Svjetlina\",\n \"hu-HU\": \"Fényerő\",\n \"hy-AM\": \"Պայծառություն\",\n \"id-ID\": \"Kecerahan\",\n \"is-IS\": \"Birtustig\",\n \"lb-xx\": \"Hellegkeet\",\n \"lt-LT\": \"Ryškumas\",\n \"ro-RO\": \"Luminozitate\",\n \"sk-SK\": \"Jas\",\n \"sl-SI\": \"Svetlost\",\n \"sv-SE\": \"Ljusstyrka\",\n \"th-TH\": \"ความสว่าง\",\n \"tr-TR\": \"Parlaklık\",\n \"uk-UA\": \"Яскравість\",\n \"vi-VN\": \"Độ sáng\",\n \"zh-CN\": \"亮度\",\n \"zh-TW\": \"亮度\"\n },\n \"Temperature\": {\n \"en-US\": \"Color temperature\",\n \"de-DE\": \"Farbtemperatur\",\n \"nl-NL\": \"Kleurtemperatuur\",\n \"da-DK\": \"Farvetemperatur\",\n \"es-ES\": \"Temperatura del color\",\n \"fr-FR\": \"Température de couleur\",\n \"it-IT\": \"Temperatura colore\",\n \"ru-RU\": \"Цветовая температура\",\n \"nb-NO\": \"Fargetemperatur\",\n \"nn-NO\": \"Fargetemperatur\",\n \"pl-PL\": \"Temperatura barwy\",\n \"pt-PT\": \"Temperatura de cor\",\n \"af-ZA\": \"Kleur temperatuur\",\n \"ar-SY\": \"درجة حرارة اللون\",\n \"bg-BG\": \"Цветова температура\",\n \"ca-ES\": \"Temperatura de color\",\n \"cs-CZ\": \"Teplota barvy\",\n \"el-GR\": \"Θερμοκρασία χρώματος\",\n \"et-EE\": \"Värvustemperatuur\",\n \"fa-IR\": \"دمای رنگ\",\n \"fi-FI\": \"Värilämpötila\",\n \"he-IL\": \"טמפרטורת הצבע\",\n \"hr-xx\": \"Temperatura boje\",\n \"hu-HU\": \"Színhőmérséklet\",\n \"hy-AM\": \"Գունային ջերմաստիճան\",\n \"id-ID\": \"Temperatur warna\",\n \"is-IS\": \"Litastig\",\n \"lb-xx\": \"Faarf Temperatur\",\n \"lt-LT\": \"Spalvos temperatūra\",\n \"ro-RO\": \"Temperatură de culoare\",\n \"sk-SK\": \"Teplota farby\",\n \"sl-SI\": \"Temperatura barve\",\n \"sv-SE\": \"Färgtemperatur\",\n \"th-TH\": \"อุณหภูมิสี\",\n \"tr-TR\": \"Renk sıcaklığı\",\n \"uk-UA\": \"Кольорова температура\",\n \"vi-VN\": \"Nhiệt độ màu\",\n \"zh-CN\": \"色温\",\n \"zh-TW\": \"色溫\"\n }\n },\n \"window\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыто\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворен\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστό\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגור\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Loka\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängt\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинене\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыто\",\n \"nb-NO\": \"Åpent\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворен\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτό\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוח\",\n \"hr-xx\": \"Otvoreno\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opna\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppet\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинене\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"開啟\"\n }\n },\n \"door\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыта\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворена\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστή\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגורה\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Lokuð\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängd\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинені\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"已關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыта\",\n \"nb-NO\": \"Åpen\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворена\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτή\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוחה\",\n \"hr-xx\": \"Otvori\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opin\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppen\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинені\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"已開啟\"\n }\n },\n \"lock\": {\n \"LOCK\": {\n \"en-US\": \"Lock\",\n \"de-DE\": \"Verriegeln\",\n \"nl-NL\": \"Vergrendelen\",\n \"da-DK\": \"Lås\",\n \"es-ES\": \"Bloquear\",\n \"fr-FR\": \"Verrouiller\",\n \"it-IT\": \"Blocca\",\n \"ru-RU\": \"Закрыть\",\n \"nb-NO\": \"Lås\",\n \"nn-NO\": \"Lås\",\n \"pl-PL\": \"Zablokuj\",\n \"pt-PT\": \"Bloquear\",\n \"af-ZA\": \"Sluit toe\",\n \"ar-SY\": \"قفل\",\n \"bg-BG\": \"Заключване\",\n \"ca-ES\": \"Bloquejar\",\n \"cs-CZ\": \"Zamknout\",\n \"el-GR\": \"Κλείδωμα\",\n \"et-EE\": \"Lukusta\",\n \"fa-IR\": \"قفل\",\n \"fi-FI\": \"Lukitse\",\n \"he-IL\": \"נעילה\",\n \"hr-xx\": \"zaključati\",\n \"hu-HU\": \"Bezár\",\n \"hy-AM\": \"Կողպեք\",\n \"id-ID\": \"Kunci\",\n \"is-IS\": \"Læsa\",\n \"lb-xx\": \"Spären\",\n \"lt-LT\": \"Užrakinti\",\n \"ro-RO\": \"Blocat\",\n \"sk-SK\": \"Zamknúť\",\n \"sl-SI\": \"Zakleni\",\n \"sv-SE\": \"Lås\",\n \"th-TH\": \"ล็อค\",\n \"tr-TR\": \"Kilitle\",\n \"uk-UA\": \"Блокувати\",\n \"vi-VN\": \"Khóa\",\n \"zh-CN\": \"锁定\",\n \"zh-TW\": \"上鎖\"\n },\n \"UNLOCK\": {\n \"en-US\": \"Unlock\",\n \"de-DE\": \"Entriegeln\",\n \"nl-NL\": \"Ontgrendelen\",\n \"da-DK\": \"Lås op\",\n \"es-ES\": \"Desbloquear\",\n \"fr-FR\": \"Déverrouiller\",\n \"it-IT\": \"Sblocca\",\n \"ru-RU\": \"Открыть\",\n \"nb-NO\": \"Lås opp\",\n \"nn-NO\": \"Lås opp\",\n \"pl-PL\": \"Odblokuj\",\n \"pt-PT\": \"Desbloquear\",\n \"af-ZA\": \"Sluit oop\",\n \"ar-SY\": \"فتح\",\n \"bg-BG\": \"Отключване\",\n \"ca-ES\": \"Desbloquejar\",\n \"cs-CZ\": \"Odemknout\",\n \"el-GR\": \"Ξεκλείδωμα\",\n \"et-EE\": \"Ava\",\n \"fa-IR\": \"باز کردن\",\n \"fi-FI\": \"Avaa lukitus\",\n \"he-IL\": \"ביטול נעילה\",\n \"hr-xx\": \"Otključati\",\n \"hu-HU\": \"Kinyit\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Buka\",\n \"is-IS\": \"Aflæsa\",\n \"lb-xx\": \"Entspären\",\n \"lt-LT\": \"Atrakinti\",\n \"ro-RO\": \"Deblocare\",\n \"sk-SK\": \"Odomknúť\",\n \"sl-SI\": \"Odkleni\",\n \"sv-SE\": \"Lås upp\",\n \"th-TH\": \"ปลดล็อค\",\n \"tr-TR\": \"Kilidi aç\",\n \"uk-UA\": \"Розблокувати\",\n \"vi-VN\": \"Mở khóa\",\n \"zh-CN\": \"解锁\",\n \"zh-TW\": \"解鎖\"\n }\n },\n \"blinds\": {\n \"Position\": {\n \"en-US\": \"Position\",\n \"de-DE\": \"Position\",\n \"nl-NL\": \"Positie\",\n \"da-DK\": \"Position\",\n \"es-ES\": \"Posición\",\n \"fr-FR\": \"Position\",\n \"it-IT\": \"Apertura\",\n \"ru-RU\": \"Положение\",\n \"nb-NO\": \"Posisjon\",\n \"nn-NO\": \"Posisjon\",\n \"pl-PL\": \"Pozycja\",\n \"pt-PT\": \"Posição\",\n \"af-ZA\": \"Posisie\",\n \"ar-SY\": \"موضع\",\n \"bg-BG\": \"Позиция\",\n \"ca-ES\": \"Posició\",\n \"cs-CZ\": \"Pozice\",\n \"el-GR\": \"Θέση\",\n \"et-EE\": \"Asend\",\n \"fa-IR\": \"موقعیت\",\n \"fi-FI\": \"Sijainti\",\n \"he-IL\": \"מיקום\",\n \"hr-xx\": \"Pozicija\",\n \"hu-HU\": \"Pozíció\",\n \"hy-AM\": \"Դիրք\",\n \"id-ID\": \"Posisi\",\n \"is-IS\": \"Staðsetning\",\n \"lb-xx\": \"Positioun\",\n \"lt-LT\": \"Padėtis\",\n \"ro-RO\": \"Poziţie\",\n \"sk-SK\": \"Poloha\",\n \"sl-SI\": \"Položaj\",\n \"sv-SE\": \"Position\",\n \"th-TH\": \"ตำแหน่ง\",\n \"tr-TR\": \"Pozisyon\",\n \"uk-UA\": \"Положення\",\n \"vi-VN\": \"Vị trí\",\n \"zh-CN\": \"位置\",\n \"zh-TW\": \"位置\"\n }\n },\n \"thermostat\": {\n \"Currently\": {\n \"en-US\": \"Currently\",\n \"de-DE\": \"Aktuell\",\n \"nl-NL\": \"Momenteel\",\n \"da-DK\": \"Aktuelt\",\n \"es-ES\": \"Actualmente\",\n \"fr-FR\": \"Actuellement\",\n \"it-IT\": \"Attualmente\",\n \"ru-RU\": \"Сейчас\",\n \"nb-NO\": \"Er nå\",\n \"nn-NO\": \"Akkurat no\",\n \"pl-PL\": \"Obecnie\",\n \"pt-PT\": \"Atualmente\",\n \"af-ZA\": \"Tans\",\n \"ar-SY\": \"حاليا\",\n \"bg-BG\": \"В момента\",\n \"ca-ES\": \"Actual\",\n \"cs-CZ\": \"Aktuálně\",\n \"el-GR\": \"Αυτή τη στιγμή\",\n \"et-EE\": \"Hetkel\",\n \"fa-IR\": \"در حال حاضر\",\n \"fi-FI\": \"Tällä hetkellä\",\n \"he-IL\": \"כעת\",\n \"hr-xx\": \"Trenutno\",\n \"hu-HU\": \"Jelenleg\",\n \"hy-AM\": \"Ներկայումս\",\n \"id-ID\": \"Saat ini\",\n \"is-IS\": \"Er núna\",\n \"lb-xx\": \"Momentan\",\n \"lt-LT\": \"Šiuo metu\",\n \"ro-RO\": \"În prezent\",\n \"sk-SK\": \"Aktuálne\",\n \"sl-SI\": \"Trenutno\",\n \"sv-SE\": \"Nuvarande\",\n \"th-TH\": \"ในขณะนี้\",\n \"tr-TR\": \"Şu an\",\n \"uk-UA\": \"В даний час\",\n \"vi-VN\": \"Hiện tại\",\n \"zh-CN\": \"当前\",\n \"zh-TW\": \"目前狀態\"\n },\n \"State\": {\n \"en-US\": \"State\",\n \"de-DE\": \"Zustand\",\n \"nl-NL\": \"Toestand\",\n \"da-DK\": \"Tilstand\",\n \"es-ES\": \"Estado\",\n \"fr-FR\": \"État\",\n \"it-IT\": \"Stato\",\n \"ru-RU\": \"Состояние\",\n \"nb-NO\": \"Tilstand\",\n \"nn-NO\": \"Tilstand\",\n \"pl-PL\": \"Stan\",\n \"pt-PT\": \"Estado\",\n \"af-ZA\": {\n \"add_entities_lovelace\": \"Voeg by Lovelace\",\n \"entities\": \"Entiteite\",\n \"none\": \"Hierdie toestel het geen entiteite nie\"\n },\n \"ar-SY\": {\n \"add_entities_lovelace\": \"أضف إلى Lovelace\",\n \"disabled_entities\": \"{count} {count, plural,\\n one {كيان}\\n other {كيانات}\\n}\",\n \"entities\": \"الكيانات\",\n \"hide_disabled\": \"إخفاء معطل\",\n \"none\": \"هذا الجهاز ليس له كيانات\"\n },\n \"bg-BG\": {\n \"add_entities_lovelace\": \"Добавете към Lovelace\",\n \"config\": \"Конфиг.\",\n \"control\": \"Контроли\",\n \"diagnostic\": \"Диагностика\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {деактивиран обект}\\n other {деактивирани обекта}\\n}\",\n \"entities\": \"Обекти\",\n \"hide_disabled\": \"Скриване на деактивираните\",\n \"none\": \"Това устройство няма обекти\",\n \"sensor\": \"Сензори\"\n },\n \"ca-ES\": \"Estat\",\n \"cs-CZ\": \"Stav\",\n \"el-GR\": \"Κατάσταση\",\n \"et-EE\": \"Olek\",\n \"fa-IR\": {\n \"add_entities_lovelace\": \"Adauga la Lovelace\",\n \"entities\": \"Entitati\",\n \"none\": \"Acest dispozitiv nu are nicio entitate\"\n },\n \"fi-FI\": \"Tila\",\n \"he-IL\": \"מצב\",\n \"hr-xx\": {\n \"automation\": {\n \"actions\": {\n \"caption\": \"Kada se nešto pokrene…\"\n },\n \"automations\": \"Automatizacije\",\n \"conditions\": {\n \"caption\": \"Učini nešto samo ako…\"\n },\n \"create\": \"Stvorite automatizaciju s uređajem\",\n \"no_automations\": \"Nema automatizacije\",\n \"no_device_automations\": \"Nema dostupnih automatizacija za ovaj uređaj.\",\n \"triggers\": {\n \"caption\": \"Učini nešto kad...\"\n }\n },\n \"cant_edit\": \"Možete uređivati samo stavke stvorene u korisničkom sučelju (UI).\",\n \"caption\": \"Uređaji\",\n \"confirm_rename_entity_ids\": \"Želite li također preimenovati ID entiteta svojih entiteta?\",\n \"data_table\": {\n \"area\": \"Područje\",\n \"battery\": \"Baterija\",\n \"device\": \"Uređaj\",\n \"integration\": \"Integracija\",\n \"manufacturer\": \"Proizvođač\",\n \"model\": \"Model\"\n },\n \"description\": \"Upravljanje povezanim uređajima\",\n \"device_not_found\": \"Uređaj nije pronađen.\",\n \"name\": \"Naziv\",\n \"scene\": {\n \"create\": \"Stvorite scenu s uređajem\",\n \"no_scenes\": \"Nema scena\",\n \"scenes\": \"Scene\"\n },\n \"scenes\": \"Scene\",\n \"script\": {\n \"create\": \"Stvorite skriptu s uređajem\",\n \"no_scripts\": \"Nema skripte\",\n \"scripts\": \"Skripte\"\n },\n \"scripts\": \"Skripte\",\n \"unknown_error\": \"Nepoznata pogreška\",\n \"unnamed_device\": \"Neimenovani uređaj\",\n \"update\": \"Ažuriraj\"\n },\n \"hu-HU\": \"Állapot\",\n \"hy-AM\": {\n \"automation\": {\n \"create_disable\": \"Հնարավոր չէ ստեղծել ավտոմատացում անջատված սարքով\"\n },\n \"disabled\": \"Անջատված\",\n \"disabled_by\": {\n \"config_entry\": \"Կարգավորման կետ\",\n \"integration\": \"Ինտեգրում\",\n \"user\": \"Օգտատեր\"\n },\n \"enabled_cause\": \"Անջատված է {cause}-ի կողմից\",\n \"enabled_label\": \"Միացնել սարքը\",\n \"picker\": {\n \"filter\": {\n \"filter\": \"Ֆիլտր\",\n \"show_all\": \"Ցույց տալ ամբողջը\",\n \"show_disabled\": \"Ցուցադրել ապաակտիվացված սարքերը\"\n },\n \"search\": \"Որոնել սարքեր\"\n },\n \"scene\": {\n \"create_disable\": \"Հնարավոր չէ սցենար ստեղծել անջատված սարքով\"\n },\n \"script\": {\n \"create_disable\": \"Անջատված սարքով հնարավոր չէ ստեղծել սկրիպտ\"\n }\n },\n \"id-ID\": \"Status\",\n \"is-IS\": \"Staða\",\n \"lb-xx\": {\n \"add_entities_lovelace\": \"Zu Lovelace bäisetzen\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {Déaktivéiert Entitéit}\\n other {Déaktivéiert Entitéiten}\\n}\",\n \"entities\": \"Entitéiten\",\n \"hide_disabled\": \"Deaktivéiert net uweisen\",\n \"none\": \"Dësen Appart huet keng Entitéiten.\"\n },\n \"lt-LT\": {\n \"add_entities_lovelace\": \"Pridėti į Lovelace\",\n \"config\": \"Konfigūracija\",\n \"control\": \"Valdikliai\",\n \"diagnostic\": \"Diagnostika\",\n \"entities\": \"Subjektai\",\n \"sensor\": \"Jutikliai\"\n },\n \"ro-RO\": {\n \"add_entities_lovelace\": \"Adăugați la Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {entitate dezactivată}\\n other {entități dezactivate}\\n}\",\n \"entities\": \"Entități\",\n \"hide_disabled\": \"Ascundeți dezactivate\",\n \"none\": \"Acest dispozitiv nu are entități\",\n \"sensor\": \"Senzori\"\n },\n \"sk-SK\": \"Stav\",\n \"sl-SI\": \"Stanje\",\n \"sv-SE\": \"Tillstånd\",\n \"th-TH\": \"สถานะ\",\n \"tr-TR\": \"Durum\",\n \"uk-UA\": \"Стан\",\n \"vi-VN\": {\n \"add_entities_lovelace\": \"Thêm vào Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {thực thể bị vô hiệu hoá}\\n other {các thực thể bị vô hiệu hoá}\\n}\",\n \"entities\": \"Các thực thể\",\n \"hide_disabled\": \"Ẩn các thiết bị bị vô hiệu hoá\",\n \"none\": \"Thiết bị này không có thực thể nào\"\n },\n \"zh-CN\": \"状态\",\n \"zh-TW\": \"狀態\"\n },\n \"Action\": {\n \"en-US\": \"Operation\",\n \"de-DE\": \"Aktion\",\n \"nl-NL\": \"Werking\",\n \"da-DK\": \"Drifttype\",\n \"es-ES\": \"Modo\",\n \"fr-FR\": \"Opération\",\n \"it-IT\": \"Operazione\",\n \"ru-RU\": \"Режим работы\",\n \"nb-NO\": \"Operasjon\",\n \"nn-NO\": \"Operasjon\",\n \"pl-PL\": \"Tryb pracy\",\n \"pt-PT\": \"Operação\",\n \"af-ZA\": \"Operasie\",\n \"ar-SY\": \"الوضع\",\n \"bg-BG\": \"Режим\",\n \"ca-ES\": \"Funcionament\",\n \"cs-CZ\": \"Provoz\",\n \"el-GR\": \"Λειτουργία\",\n \"et-EE\": \"Töörežiim\",\n \"fa-IR\": \"عملیات\",\n \"fi-FI\": \"Toiminto\",\n \"he-IL\": \"פעולה\",\n \"hr-xx\": \"operacija\",\n \"hu-HU\": \"Működés\",\n \"hy-AM\": \"Գործողություն\",\n \"id-ID\": \"Operasi\",\n \"is-IS\": \"Aðgerð\",\n \"lb-xx\": \"Aktioun\",\n \"lt-LT\": \"Operacija\",\n \"ro-RO\": \"Operație\",\n \"sk-SK\": \"Prevádzka\",\n \"sl-SI\": \"Delovanje\",\n \"sv-SE\": \"Driftläge\",\n \"th-TH\": \"การทำงาน\",\n \"tr-TR\": \"İşlem\",\n \"uk-UA\": \"Режим\",\n \"vi-VN\": \"Chế độ hoạt động\",\n \"zh-CN\": \"运行模式\",\n \"zh-TW\": \"運轉模式\"\n }\n }\n}","ack":true,"ts":1668707461164,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327324911}
                              18:51:01.335	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"alias.0.Garagen-Papa.Garage-Polo.ACTUAL","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                              18:51:01.335	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getObject(id=alias.0.Garagen-Papa.Garage-Fahrräder, enumName=undefined) => {"_id":"alias.0.Garagen-Papa.Garage-Fahrräder","common":{"name":{"de":"Garage-Fahrräder"},"role":"gate","icon":"","color":null},"native":{},"type":"channel","from":"system.adapter.admin.0","user":"system.user.admin","ts":1668612233532,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                              18:51:01.335	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Garagen-Papa.Garage-Fahrräder.ACTUAL, timerId=undefined) => {"val":false,"ack":false,"ts":1668636385319,"q":0,"c":"script.js.Papa-Garagen.Garage_Fahrräder","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668636385319}
                              18:51:01.336	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_locales_json, timerId=undefined) => {"val":"{\n \"lights\": {\n \"Brightness\": {\n \"en-US\": \"Brightness\",\n \"de-DE\": \"Helligkeit\",\n \"nl-NL\": \"Helderheid\",\n \"da-DK\": \"Lysstyrke\",\n \"es-ES\": \"Brillo\",\n \"fr-FR\": \"Luminosité\",\n \"it-IT\": \"Luminosità\",\n \"ru-RU\": \"Яркость\",\n \"nb-NO\": \"Lysstyrke\",\n \"nn-NO\": \"Lysstyrke\",\n \"pl-PL\": \"Jasność\",\n \"pt-PT\": \"Brilho\",\n \"af-ZA\": \"Helderheid\",\n \"ar-SY\": \"السطوع\",\n \"bg-BG\": \"Яркост\",\n \"ca-ES\": \"Brillantor\",\n \"cs-CZ\": \"Jas\",\n \"el-GR\": \"Φωτεινότητα\",\n \"et-EE\": \"Heledus\",\n \"fa-IR\": \"روشنایی\",\n \"fi-FI\": \"Kirkkaus\",\n \"he-IL\": \"בהירות\",\n \"hr-xx\": \"Svjetlina\",\n \"hu-HU\": \"Fényerő\",\n \"hy-AM\": \"Պայծառություն\",\n \"id-ID\": \"Kecerahan\",\n \"is-IS\": \"Birtustig\",\n \"lb-xx\": \"Hellegkeet\",\n \"lt-LT\": \"Ryškumas\",\n \"ro-RO\": \"Luminozitate\",\n \"sk-SK\": \"Jas\",\n \"sl-SI\": \"Svetlost\",\n \"sv-SE\": \"Ljusstyrka\",\n \"th-TH\": \"ความสว่าง\",\n \"tr-TR\": \"Parlaklık\",\n \"uk-UA\": \"Яскравість\",\n \"vi-VN\": \"Độ sáng\",\n \"zh-CN\": \"亮度\",\n \"zh-TW\": \"亮度\"\n },\n \"Temperature\": {\n \"en-US\": \"Color temperature\",\n \"de-DE\": \"Farbtemperatur\",\n \"nl-NL\": \"Kleurtemperatuur\",\n \"da-DK\": \"Farvetemperatur\",\n \"es-ES\": \"Temperatura del color\",\n \"fr-FR\": \"Température de couleur\",\n \"it-IT\": \"Temperatura colore\",\n \"ru-RU\": \"Цветовая температура\",\n \"nb-NO\": \"Fargetemperatur\",\n \"nn-NO\": \"Fargetemperatur\",\n \"pl-PL\": \"Temperatura barwy\",\n \"pt-PT\": \"Temperatura de cor\",\n \"af-ZA\": \"Kleur temperatuur\",\n \"ar-SY\": \"درجة حرارة اللون\",\n \"bg-BG\": \"Цветова температура\",\n \"ca-ES\": \"Temperatura de color\",\n \"cs-CZ\": \"Teplota barvy\",\n \"el-GR\": \"Θερμοκρασία χρώματος\",\n \"et-EE\": \"Värvustemperatuur\",\n \"fa-IR\": \"دمای رنگ\",\n \"fi-FI\": \"Värilämpötila\",\n \"he-IL\": \"טמפרטורת הצבע\",\n \"hr-xx\": \"Temperatura boje\",\n \"hu-HU\": \"Színhőmérséklet\",\n \"hy-AM\": \"Գունային ջերմաստիճան\",\n \"id-ID\": \"Temperatur warna\",\n \"is-IS\": \"Litastig\",\n \"lb-xx\": \"Faarf Temperatur\",\n \"lt-LT\": \"Spalvos temperatūra\",\n \"ro-RO\": \"Temperatură de culoare\",\n \"sk-SK\": \"Teplota farby\",\n \"sl-SI\": \"Temperatura barve\",\n \"sv-SE\": \"Färgtemperatur\",\n \"th-TH\": \"อุณหภูมิสี\",\n \"tr-TR\": \"Renk sıcaklığı\",\n \"uk-UA\": \"Кольорова температура\",\n \"vi-VN\": \"Nhiệt độ màu\",\n \"zh-CN\": \"色温\",\n \"zh-TW\": \"色溫\"\n }\n },\n \"window\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыто\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворен\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστό\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגור\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Loka\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängt\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинене\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыто\",\n \"nb-NO\": \"Åpent\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворен\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτό\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוח\",\n \"hr-xx\": \"Otvoreno\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opna\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppet\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинене\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"開啟\"\n }\n },\n \"door\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыта\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворена\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστή\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגורה\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Lokuð\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängd\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинені\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"已關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыта\",\n \"nb-NO\": \"Åpen\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворена\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτή\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוחה\",\n \"hr-xx\": \"Otvori\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opin\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppen\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинені\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"已開啟\"\n }\n },\n \"lock\": {\n \"LOCK\": {\n \"en-US\": \"Lock\",\n \"de-DE\": \"Verriegeln\",\n \"nl-NL\": \"Vergrendelen\",\n \"da-DK\": \"Lås\",\n \"es-ES\": \"Bloquear\",\n \"fr-FR\": \"Verrouiller\",\n \"it-IT\": \"Blocca\",\n \"ru-RU\": \"Закрыть\",\n \"nb-NO\": \"Lås\",\n \"nn-NO\": \"Lås\",\n \"pl-PL\": \"Zablokuj\",\n \"pt-PT\": \"Bloquear\",\n \"af-ZA\": \"Sluit toe\",\n \"ar-SY\": \"قفل\",\n \"bg-BG\": \"Заключване\",\n \"ca-ES\": \"Bloquejar\",\n \"cs-CZ\": \"Zamknout\",\n \"el-GR\": \"Κλείδωμα\",\n \"et-EE\": \"Lukusta\",\n \"fa-IR\": \"قفل\",\n \"fi-FI\": \"Lukitse\",\n \"he-IL\": \"נעילה\",\n \"hr-xx\": \"zaključati\",\n \"hu-HU\": \"Bezár\",\n \"hy-AM\": \"Կողպեք\",\n \"id-ID\": \"Kunci\",\n \"is-IS\": \"Læsa\",\n \"lb-xx\": \"Spären\",\n \"lt-LT\": \"Užrakinti\",\n \"ro-RO\": \"Blocat\",\n \"sk-SK\": \"Zamknúť\",\n \"sl-SI\": \"Zakleni\",\n \"sv-SE\": \"Lås\",\n \"th-TH\": \"ล็อค\",\n \"tr-TR\": \"Kilitle\",\n \"uk-UA\": \"Блокувати\",\n \"vi-VN\": \"Khóa\",\n \"zh-CN\": \"锁定\",\n \"zh-TW\": \"上鎖\"\n },\n \"UNLOCK\": {\n \"en-US\": \"Unlock\",\n \"de-DE\": \"Entriegeln\",\n \"nl-NL\": \"Ontgrendelen\",\n \"da-DK\": \"Lås op\",\n \"es-ES\": \"Desbloquear\",\n \"fr-FR\": \"Déverrouiller\",\n \"it-IT\": \"Sblocca\",\n \"ru-RU\": \"Открыть\",\n \"nb-NO\": \"Lås opp\",\n \"nn-NO\": \"Lås opp\",\n \"pl-PL\": \"Odblokuj\",\n \"pt-PT\": \"Desbloquear\",\n \"af-ZA\": \"Sluit oop\",\n \"ar-SY\": \"فتح\",\n \"bg-BG\": \"Отключване\",\n \"ca-ES\": \"Desbloquejar\",\n \"cs-CZ\": \"Odemknout\",\n \"el-GR\": \"Ξεκλείδωμα\",\n \"et-EE\": \"Ava\",\n \"fa-IR\": \"باز کردن\",\n \"fi-FI\": \"Avaa lukitus\",\n \"he-IL\": \"ביטול נעילה\",\n \"hr-xx\": \"Otključati\",\n \"hu-HU\": \"Kinyit\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Buka\",\n \"is-IS\": \"Aflæsa\",\n \"lb-xx\": \"Entspären\",\n \"lt-LT\": \"Atrakinti\",\n \"ro-RO\": \"Deblocare\",\n \"sk-SK\": \"Odomknúť\",\n \"sl-SI\": \"Odkleni\",\n \"sv-SE\": \"Lås upp\",\n \"th-TH\": \"ปลดล็อค\",\n \"tr-TR\": \"Kilidi aç\",\n \"uk-UA\": \"Розблокувати\",\n \"vi-VN\": \"Mở khóa\",\n \"zh-CN\": \"解锁\",\n \"zh-TW\": \"解鎖\"\n }\n },\n \"blinds\": {\n \"Position\": {\n \"en-US\": \"Position\",\n \"de-DE\": \"Position\",\n \"nl-NL\": \"Positie\",\n \"da-DK\": \"Position\",\n \"es-ES\": \"Posición\",\n \"fr-FR\": \"Position\",\n \"it-IT\": \"Apertura\",\n \"ru-RU\": \"Положение\",\n \"nb-NO\": \"Posisjon\",\n \"nn-NO\": \"Posisjon\",\n \"pl-PL\": \"Pozycja\",\n \"pt-PT\": \"Posição\",\n \"af-ZA\": \"Posisie\",\n \"ar-SY\": \"موضع\",\n \"bg-BG\": \"Позиция\",\n \"ca-ES\": \"Posició\",\n \"cs-CZ\": \"Pozice\",\n \"el-GR\": \"Θέση\",\n \"et-EE\": \"Asend\",\n \"fa-IR\": \"موقعیت\",\n \"fi-FI\": \"Sijainti\",\n \"he-IL\": \"מיקום\",\n \"hr-xx\": \"Pozicija\",\n \"hu-HU\": \"Pozíció\",\n \"hy-AM\": \"Դիրք\",\n \"id-ID\": \"Posisi\",\n \"is-IS\": \"Staðsetning\",\n \"lb-xx\": \"Positioun\",\n \"lt-LT\": \"Padėtis\",\n \"ro-RO\": \"Poziţie\",\n \"sk-SK\": \"Poloha\",\n \"sl-SI\": \"Položaj\",\n \"sv-SE\": \"Position\",\n \"th-TH\": \"ตำแหน่ง\",\n \"tr-TR\": \"Pozisyon\",\n \"uk-UA\": \"Положення\",\n \"vi-VN\": \"Vị trí\",\n \"zh-CN\": \"位置\",\n \"zh-TW\": \"位置\"\n }\n },\n \"thermostat\": {\n \"Currently\": {\n \"en-US\": \"Currently\",\n \"de-DE\": \"Aktuell\",\n \"nl-NL\": \"Momenteel\",\n \"da-DK\": \"Aktuelt\",\n \"es-ES\": \"Actualmente\",\n \"fr-FR\": \"Actuellement\",\n \"it-IT\": \"Attualmente\",\n \"ru-RU\": \"Сейчас\",\n \"nb-NO\": \"Er nå\",\n \"nn-NO\": \"Akkurat no\",\n \"pl-PL\": \"Obecnie\",\n \"pt-PT\": \"Atualmente\",\n \"af-ZA\": \"Tans\",\n \"ar-SY\": \"حاليا\",\n \"bg-BG\": \"В момента\",\n \"ca-ES\": \"Actual\",\n \"cs-CZ\": \"Aktuálně\",\n \"el-GR\": \"Αυτή τη στιγμή\",\n \"et-EE\": \"Hetkel\",\n \"fa-IR\": \"در حال حاضر\",\n \"fi-FI\": \"Tällä hetkellä\",\n \"he-IL\": \"כעת\",\n \"hr-xx\": \"Trenutno\",\n \"hu-HU\": \"Jelenleg\",\n \"hy-AM\": \"Ներկայումս\",\n \"id-ID\": \"Saat ini\",\n \"is-IS\": \"Er núna\",\n \"lb-xx\": \"Momentan\",\n \"lt-LT\": \"Šiuo metu\",\n \"ro-RO\": \"În prezent\",\n \"sk-SK\": \"Aktuálne\",\n \"sl-SI\": \"Trenutno\",\n \"sv-SE\": \"Nuvarande\",\n \"th-TH\": \"ในขณะนี้\",\n \"tr-TR\": \"Şu an\",\n \"uk-UA\": \"В даний час\",\n \"vi-VN\": \"Hiện tại\",\n \"zh-CN\": \"当前\",\n \"zh-TW\": \"目前狀態\"\n },\n \"State\": {\n \"en-US\": \"State\",\n \"de-DE\": \"Zustand\",\n \"nl-NL\": \"Toestand\",\n \"da-DK\": \"Tilstand\",\n \"es-ES\": \"Estado\",\n \"fr-FR\": \"État\",\n \"it-IT\": \"Stato\",\n \"ru-RU\": \"Состояние\",\n \"nb-NO\": \"Tilstand\",\n \"nn-NO\": \"Tilstand\",\n \"pl-PL\": \"Stan\",\n \"pt-PT\": \"Estado\",\n \"af-ZA\": {\n \"add_entities_lovelace\": \"Voeg by Lovelace\",\n \"entities\": \"Entiteite\",\n \"none\": \"Hierdie toestel het geen entiteite nie\"\n },\n \"ar-SY\": {\n \"add_entities_lovelace\": \"أضف إلى Lovelace\",\n \"disabled_entities\": \"{count} {count, plural,\\n one {كيان}\\n other {كيانات}\\n}\",\n \"entities\": \"الكيانات\",\n \"hide_disabled\": \"إخفاء معطل\",\n \"none\": \"هذا الجهاز ليس له كيانات\"\n },\n \"bg-BG\": {\n \"add_entities_lovelace\": \"Добавете към Lovelace\",\n \"config\": \"Конфиг.\",\n \"control\": \"Контроли\",\n \"diagnostic\": \"Диагностика\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {деактивиран обект}\\n other {деактивирани обекта}\\n}\",\n \"entities\": \"Обекти\",\n \"hide_disabled\": \"Скриване на деактивираните\",\n \"none\": \"Това устройство няма обекти\",\n \"sensor\": \"Сензори\"\n },\n \"ca-ES\": \"Estat\",\n \"cs-CZ\": \"Stav\",\n \"el-GR\": \"Κατάσταση\",\n \"et-EE\": \"Olek\",\n \"fa-IR\": {\n \"add_entities_lovelace\": \"Adauga la Lovelace\",\n \"entities\": \"Entitati\",\n \"none\": \"Acest dispozitiv nu are nicio entitate\"\n },\n \"fi-FI\": \"Tila\",\n \"he-IL\": \"מצב\",\n \"hr-xx\": {\n \"automation\": {\n \"actions\": {\n \"caption\": \"Kada se nešto pokrene…\"\n },\n \"automations\": \"Automatizacije\",\n \"conditions\": {\n \"caption\": \"Učini nešto samo ako…\"\n },\n \"create\": \"Stvorite automatizaciju s uređajem\",\n \"no_automations\": \"Nema automatizacije\",\n \"no_device_automations\": \"Nema dostupnih automatizacija za ovaj uređaj.\",\n \"triggers\": {\n \"caption\": \"Učini nešto kad...\"\n }\n },\n \"cant_edit\": \"Možete uređivati samo stavke stvorene u korisničkom sučelju (UI).\",\n \"caption\": \"Uređaji\",\n \"confirm_rename_entity_ids\": \"Želite li također preimenovati ID entiteta svojih entiteta?\",\n \"data_table\": {\n \"area\": \"Područje\",\n \"battery\": \"Baterija\",\n \"device\": \"Uređaj\",\n \"integration\": \"Integracija\",\n \"manufacturer\": \"Proizvođač\",\n \"model\": \"Model\"\n },\n \"description\": \"Upravljanje povezanim uređajima\",\n \"device_not_found\": \"Uređaj nije pronađen.\",\n \"name\": \"Naziv\",\n \"scene\": {\n \"create\": \"Stvorite scenu s uređajem\",\n \"no_scenes\": \"Nema scena\",\n \"scenes\": \"Scene\"\n },\n \"scenes\": \"Scene\",\n \"script\": {\n \"create\": \"Stvorite skriptu s uređajem\",\n \"no_scripts\": \"Nema skripte\",\n \"scripts\": \"Skripte\"\n },\n \"scripts\": \"Skripte\",\n \"unknown_error\": \"Nepoznata pogreška\",\n \"unnamed_device\": \"Neimenovani uređaj\",\n \"update\": \"Ažuriraj\"\n },\n \"hu-HU\": \"Állapot\",\n \"hy-AM\": {\n \"automation\": {\n \"create_disable\": \"Հնարավոր չէ ստեղծել ավտոմատացում անջատված սարքով\"\n },\n \"disabled\": \"Անջատված\",\n \"disabled_by\": {\n \"config_entry\": \"Կարգավորման կետ\",\n \"integration\": \"Ինտեգրում\",\n \"user\": \"Օգտատեր\"\n },\n \"enabled_cause\": \"Անջատված է {cause}-ի կողմից\",\n \"enabled_label\": \"Միացնել սարքը\",\n \"picker\": {\n \"filter\": {\n \"filter\": \"Ֆիլտր\",\n \"show_all\": \"Ցույց տալ ամբողջը\",\n \"show_disabled\": \"Ցուցադրել ապաակտիվացված սարքերը\"\n },\n \"search\": \"Որոնել սարքեր\"\n },\n \"scene\": {\n \"create_disable\": \"Հնարավոր չէ սցենար ստեղծել անջատված սարքով\"\n },\n \"script\": {\n \"create_disable\": \"Անջատված սարքով հնարավոր չէ ստեղծել սկրիպտ\"\n }\n },\n \"id-ID\": \"Status\",\n \"is-IS\": \"Staða\",\n \"lb-xx\": {\n \"add_entities_lovelace\": \"Zu Lovelace bäisetzen\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {Déaktivéiert Entitéit}\\n other {Déaktivéiert Entitéiten}\\n}\",\n \"entities\": \"Entitéiten\",\n \"hide_disabled\": \"Deaktivéiert net uweisen\",\n \"none\": \"Dësen Appart huet keng Entitéiten.\"\n },\n \"lt-LT\": {\n \"add_entities_lovelace\": \"Pridėti į Lovelace\",\n \"config\": \"Konfigūracija\",\n \"control\": \"Valdikliai\",\n \"diagnostic\": \"Diagnostika\",\n \"entities\": \"Subjektai\",\n \"sensor\": \"Jutikliai\"\n },\n \"ro-RO\": {\n \"add_entities_lovelace\": \"Adăugați la Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {entitate dezactivată}\\n other {entități dezactivate}\\n}\",\n \"entities\": \"Entități\",\n \"hide_disabled\": \"Ascundeți dezactivate\",\n \"none\": \"Acest dispozitiv nu are entități\",\n \"sensor\": \"Senzori\"\n },\n \"sk-SK\": \"Stav\",\n \"sl-SI\": \"Stanje\",\n \"sv-SE\": \"Tillstånd\",\n \"th-TH\": \"สถานะ\",\n \"tr-TR\": \"Durum\",\n \"uk-UA\": \"Стан\",\n \"vi-VN\": {\n \"add_entities_lovelace\": \"Thêm vào Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {thực thể bị vô hiệu hoá}\\n other {các thực thể bị vô hiệu hoá}\\n}\",\n \"entities\": \"Các thực thể\",\n \"hide_disabled\": \"Ẩn các thiết bị bị vô hiệu hoá\",\n \"none\": \"Thiết bị này không có thực thể nào\"\n },\n \"zh-CN\": \"状态\",\n \"zh-TW\": \"狀態\"\n },\n \"Action\": {\n \"en-US\": \"Operation\",\n \"de-DE\": \"Aktion\",\n \"nl-NL\": \"Werking\",\n \"da-DK\": \"Drifttype\",\n \"es-ES\": \"Modo\",\n \"fr-FR\": \"Opération\",\n \"it-IT\": \"Operazione\",\n \"ru-RU\": \"Режим работы\",\n \"nb-NO\": \"Operasjon\",\n \"nn-NO\": \"Operasjon\",\n \"pl-PL\": \"Tryb pracy\",\n \"pt-PT\": \"Operação\",\n \"af-ZA\": \"Operasie\",\n \"ar-SY\": \"الوضع\",\n \"bg-BG\": \"Режим\",\n \"ca-ES\": \"Funcionament\",\n \"cs-CZ\": \"Provoz\",\n \"el-GR\": \"Λειτουργία\",\n \"et-EE\": \"Töörežiim\",\n \"fa-IR\": \"عملیات\",\n \"fi-FI\": \"Toiminto\",\n \"he-IL\": \"פעולה\",\n \"hr-xx\": \"operacija\",\n \"hu-HU\": \"Működés\",\n \"hy-AM\": \"Գործողություն\",\n \"id-ID\": \"Operasi\",\n \"is-IS\": \"Aðgerð\",\n \"lb-xx\": \"Aktioun\",\n \"lt-LT\": \"Operacija\",\n \"ro-RO\": \"Operație\",\n \"sk-SK\": \"Prevádzka\",\n \"sl-SI\": \"Delovanje\",\n \"sv-SE\": \"Driftläge\",\n \"th-TH\": \"การทำงาน\",\n \"tr-TR\": \"İşlem\",\n \"uk-UA\": \"Режим\",\n \"vi-VN\": \"Chế độ hoạt động\",\n \"zh-CN\": \"运行模式\",\n \"zh-TW\": \"運轉模式\"\n }\n }\n}","ack":true,"ts":1668707461164,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327324911}
                              18:51:01.339	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"alias.0.Garagen-Papa.Garage-Fahrräder.ACTUAL","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                              18:51:01.339	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"pageType~cardEntities","ack":false,"ts":1668707461339,"q":0,"from":"system.adapter.javascript.0","lc":1668707461339,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                              18:51:01.339	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"entityUpd~Garagen~1|1~text~alias.0.Garagen-Papa.Garage-Audi~~32495~Garage Audi~Geschlossen~text~alias.0.Garagen-Papa.Garage-Polo~~64332~Garage Polo~Offen~text~alias.0.Garagen-Papa.Garage-Fahrräder~~32495~Garage Fahrräder~Geschlossen","ack":false,"ts":1668707461339,"q":0,"from":"system.adapter.javascript.0","lc":1668707461339,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                              18:51:01.348	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Hardware, state={"val":"ESP32-D0WD-V3 rev.3","ack":true,"ts":1668707461348,"q":0,"from":"system.adapter.javascript.0","lc":1668327326137,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                              18:51:01.410	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Display_Firmware.currentVersion, state={"val":"43","ack":true,"ts":1668707461410,"q":0,"from":"system.adapter.javascript.0","lc":1668327325214,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                              18:51:01.416	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.tele.NS-Panel-Paps_0BED20.INFO2, timerId=undefined) => {"val":"{\"Info2\":{\"WebServerMode\":\"Admin\",\"Hostname\":\"NS-Panel-Paps-0BED20-3360\",\"IPAddress\":\"192.168.178.244\"}}","ack":true,"ts":1668692778130,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668270172355}
                              18:51:01.440	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.AP, state={"val":1,"ack":true,"ts":1668707461440,"q":0,"from":"system.adapter.javascript.0","lc":1668327326143,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                              18:51:01.442	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.NSPanel_Version, state={"val":"eu","ack":true,"ts":1668707461442,"q":0,"from":"system.adapter.javascript.0","lc":1668327325303,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                              18:51:01.451	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.SSId, state={"val":"Siggi&Bernd_2.4","ack":true,"ts":1668707461451,"q":0,"from":"system.adapter.javascript.0","lc":1668327326154,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                              18:51:01.454	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Display.TFTVersion, obj={"type":"channel","common":{"role":"info","name":"Display.TFTVersion"},"native":{}})
                              18:51:01.454	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Display.Model, obj={"type":"channel","common":{"role":"info","name":"Display.Model"},"native":{}})
                              18:51:01.522	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.BSSId, state={"val":"2C:3A:FD:09:0B:6F","ack":true,"ts":1668707461522,"q":0,"from":"system.adapter.javascript.0","lc":1668327326162,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                              • W Wuschl
                                @armilar
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                Most Active Forum Testing
                                #808
                                @wuschl
                                Wäre schon gut, wenn die Warnungen dazwischen wären ;-)
                                W 1 Antwort Letzte Antwort
                                • ArmilarA Armilar
                                  @wuschl
                                  W Offline
                                  W Offline
                                  Wuschl
                                  #809
                                  @armilar
                                  18:56:05.906	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.Mode, state={"val":"11n","ack":true,"ts":1668707765906,"q":0,"from":"system.adapter.javascript.0","lc":1668327326178,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:05.908	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Display_Firmware.onlineVersion, state={"val":"43","ack":true,"ts":1668707765908,"q":0,"from":"system.adapter.javascript.0","lc":1668327325591,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:05.957	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.RSSI, state={"val":64,"ack":true,"ts":1668707765957,"q":0,"from":"system.adapter.javascript.0","lc":1668707765957,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:06.006	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.Signal, state={"val":-68,"ack":true,"ts":1668707766006,"q":0,"from":"system.adapter.javascript.0","lc":1668707766006,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:06.058	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Uptime, obj={"type":"channel","common":{"role":"info","name":"Uptime"},"native":{}})
                                  18:56:06.058	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Version, obj={"type":"channel","common":{"role":"info","name":"Version"},"native":{}})
                                  18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Hardware, obj={"type":"channel","common":{"role":"info","name":"Hardware"},"native":{}})
                                  18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.AP, obj={"type":"channel","common":{"role":"info","name":"AP"},"native":{}})
                                  18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.SSId, obj={"type":"channel","common":{"role":"info","name":"SSId"},"native":{}})
                                  18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.BSSId, obj={"type":"channel","common":{"role":"info","name":"BSSId"},"native":{}})
                                  18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.Channel, obj={"type":"channel","common":{"role":"info","name":"Channel"},"native":{}})
                                  18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.Mode, obj={"type":"channel","common":{"role":"info","name":"Mode"},"native":{}})
                                  18:56:06.060	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.RSSI, obj={"type":"channel","common":{"role":"info","name":"RSSI"},"native":{}})
                                  18:56:06.060	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.Signal, obj={"type":"channel","common":{"role":"info","name":"Signal"},"native":{}})
                                  18:56:06.213	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.TFT_Firmware.onlineVersion, state={"val":"3.5.0","ack":true,"ts":1668707766213,"q":0,"from":"system.adapter.javascript.0","lc":1668327325426,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:06.269	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota_Firmware.onlineVersion, state={"val":"12.2.0","ack":true,"ts":1668707766269,"q":0,"from":"system.adapter.javascript.0","lc":1668327325585,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:06.286	warn	javascript.0 (806) at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                                  18:56:06.287	warn	javascript.0 (806) at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                                  18:56:06.287	warn	javascript.0 (806) at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                                  18:56:06.287	warn	javascript.0 (806) at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)
                                  18:56:06.287	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Berry_Driver.currentVersion, state={"val":"4","ack":true,"ts":1668707766287,"q":0,"from":"system.adapter.javascript.0","lc":1668327325585,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:06.364	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Display.BerryDriver, obj={"type":"channel","common":{"role":"info","name":"Berry Driver"},"native":{}})
                                  18:56:22.397	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Sensor.Time, state={"val":"2022-11-17T18:56:22","ack":true,"ts":1668707782397,"q":0,"from":"system.adapter.javascript.0","lc":1668707782397,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:22.406	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Sensor.TempUnit, state={"val":"°C","ack":true,"ts":1668707782406,"q":0,"from":"system.adapter.javascript.0","lc":1668327395067,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:22.415	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Sensor.ANALOG.Temperature, state={"val":28.7,"ack":true,"ts":1668707782415,"q":0,"from":"system.adapter.javascript.0","lc":1668707782415,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:22.424	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Sensor.ESP32.Temperature, state={"val":40,"ack":true,"ts":1668707782424,"q":0,"from":"system.adapter.javascript.0","lc":1668707782424,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:22.437	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Sensor.ANALOG.Temperature, obj={"type":"channel","common":{"role":"info","name":""},"native":{}})
                                  18:56:22.438	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Sensor.ESP32.Temperature, obj={"type":"channel","common":{"role":"info","name":""},"native":{}})
                                  18:56:26.024	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"pageType~screensaver","ack":false,"ts":1668707786023,"q":0,"from":"system.adapter.javascript.0","lc":1668707786023,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:26.025	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: adapterUnsubscribe(id=[object Object])
                                  18:56:26.026	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: adapterUnsubscribe(id=[object Object])
                                  18:56:26.028	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Wetter.Gerät_1.ICON, timerId=undefined) => {"val":"7","ack":true,"ts":1668704678761,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678761}
                                  18:56:26.029	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Wetter.Gerät_1.TEMP, timerId=undefined) => {"val":7.4,"ack":true,"ts":1668707775192,"q":0,"from":"system.adapter.shelly.1","user":"system.user.admin","lc":1668707775192}
                                  18:56:26.030	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Hourly.h0.PrecipitationProbability, timerId=undefined) => {"val":11,"ack":true,"ts":1668704677777,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668683082200}
                                  18:56:26.030	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.WindSpeed, timerId=undefined) => {"val":3.7,"ack":true,"ts":1668704678763,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678763}
                                  18:56:26.030	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3, timerId=undefined) => {"val":6.4,"ack":true,"ts":1668706145132,"q":0,"from":"system.adapter.shelly.1","user":"system.user.admin","lc":1668706145132}
                                  18:56:26.031	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.RelativeHumidity, timerId=undefined) => {"val":93,"ack":true,"ts":1668704678762,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678762}
                                  18:56:26.031	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Hourly.h0.PrecipitationProbability, timerId=undefined) => {"val":11,"ack":true,"ts":1668704677777,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668683082200}
                                  18:56:26.031	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.WindSpeed, timerId=undefined) => {"val":3.7,"ack":true,"ts":1668704678763,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678763}
                                  18:56:26.032	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.WindSpeed, timerId=undefined) => {"val":3.7,"ack":true,"ts":1668704678763,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678763}
                                  18:56:26.032	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3, timerId=undefined) => {"val":6.4,"ack":true,"ts":1668706145132,"q":0,"from":"system.adapter.shelly.1","user":"system.user.admin","lc":1668706145132}
                                  18:56:26.032	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.RelativeHumidity, timerId=undefined) => {"val":93,"ack":true,"ts":1668704678762,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678762}
                                  18:56:26.033	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1, timerId=undefined) => {"val":"OFF","ack":true,"ts":1668693148871,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668693148871}
                                  18:56:26.033	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2, timerId=undefined) => {"val":"OFF","ack":true,"ts":1668693152067,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668693152067}
                                  18:56:26.034	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"color~0~65535~65535~65535~19017~65535~65535~65535~65535~65535~34351~26095~42639~64750~65535~65535~65535~65535~65535~65535~65535~65535","ack":false,"ts":1668707786034,"q":0,"from":"system.adapter.javascript.0","lc":1668707786034,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:26.034	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"weatherUpdate~~7.4 °C~Regen~~11 %~Wind~~3.7 km/h~Pool~艹~6.4 °C~Luft~~93 %~~~~17299~~17299~","ack":false,"ts":1668707786034,"q":0,"from":"system.adapter.javascript.0","lc":1668707786034,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:26.035	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"color~0~65535~65535~65535~19017~65535~65535~65535~65535~65535~34351~26095~42639~64750~65535~65535~65535~65535~65535~65535~65535~65535","ack":false,"ts":1668707786035,"q":0,"from":"system.adapter.javascript.0","lc":1668707786035,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:56:26.667	info	javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                                  18:56:26.726	info	javascript.1 (821) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                                  18:56:26.903	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                                  18:56:27.906	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                                  18:56:27.972	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                                  18:56:28.014	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  • W Wuschl
                                    @armilar
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #810
                                    @wuschl
                                    Auf was steht der Datenpunkt?:
                                    0_userdata.0.NSPanel.1.NSPanel_autoUpdate
                                    Und zeige mal kurz die Datenpunkte wie in der Abb.
                                    Die Warnung dürfte in der mit den Updates laufen...
                                    • ArmilarA Armilar
                                      @wuschl
                                      W Offline
                                      W Offline
                                      Wuschl
                                      schrieb am zuletzt editiert von Wuschl
                                      #811
                                      @armilar wo finde ich den Datenpunkt?
                                      ArmilarA 2 Antworten Letzte Antwort
                                      • W Wuschl
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #812
                                        @wuschl
                                        Der ist fast unten im Hauptverzeichnis.
                                        Mich interessiert Vorrangig das Berry-Verzeichnis und das Tasmota-Verzeichnis. Daher auch als Vergleich mein Screenshot mit den aufgeklappten Verzeichnissen.
                                        • ArmilarA Armilar
                                          @wuschl
                                          W Offline
                                          W Offline
                                          Wuschl
                                          #813
                                          @armilar sorry, aber den finde ich nicht.
