  4. Nach restore Adapter in der Konsole aber nicht ...
    5.6k
57 Beiträge 6 Kommentatoren 5.1k Aufrufe 4 Beobachtet
  • H HiHo
    @crunchip
    sieht schon anders aus:
    pi@iobroker:~ $ iobroker repo unset live
    Repository "live" deactivated.
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    live          : http://iobroker.live/repo/sources-dist-latest.json
    pi@iobroker:~ $ iobroker update
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
    Adapter    "cloud"        : 4.2.2    , installed 4.3.0
    Adapter    "discovery"    : 3.0.5    , installed 3.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.2.0    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.43
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.15
    Adapter    "info"         : 1.9.19   , installed 1.9.21
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
    Adapter    "javascript"   : 6.0.3    , installed 6.1.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "openweathermap": 0.3.0   , installed 0.3.3
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
    Adapter    "socketio"     : 4.2.0    , installed 6.1.10
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "terminal"     : 0.2.6    , installed 1.0.0
    Adapter    "text2command" : 2.2.2    , installed 2.3.0
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 4.3.0    , installed 5.2.10
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.3
    Adapter    "ws"           : 1.3.0    , installed 2.1.5
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    aber wieso verweist es dann auf Beta?
    Das Backuptool ist das "raspiBackup", ist doch kein Problem oder?
    @hiho sagte in Nach restore Adapter in der Konsole aber nicht ...:
    nicht auszuschließen. Wo kommt das denn her?
    H 1 Antwort Letzte Antwort
      HiHo
      schrieb am zuletzt editiert von HiHo
      habe ich hier gefunden
      https://raspibackup.linux-tips-and-tricks.de/de/home-deutsch/
      an sich funktioniert es ganz gut... frage mich aber gerade ab das auch über Backitup geht...
      das habe ich aber erst nach der ganzen Geschichte installiert...
      • H HiHo
        @hiho
        Das tool von @framp kenne ich zwar nicht genau, aber das hatte in der Vergangenheit Probleme mit ACL Dateirechten. Ob die in der aktuellsten Version behoben sind weiß ich nicht, framp wollte sich das aber anschauen.
        H frampF 2 Antworten Letzte Antwort
          @hiho
          HiHo
          also im Moment sieht alles gut aus. Es scheint dann an der Repo gelegen zu haben?
          Jedenfalls vielen Dank für eure Hilfe und eure Geduld, ihr seid ein Spitzenteam! 👏 😊
            @hiho
            frampF Offline
            frampF Offline
            framp
            schrieb am zuletzt editiert von framp
            @thomas-braun said in Nach restore Adapter in der Konsole aber nicht ...:
            Es ist nicht raspiBackup sondern rsync. Das kann keine ACLs per nfs sichern. Hier steht beschrieben was man bei IOBroker tun muss um mit ACLs und rsync/raspiBackup zurecht zu kommen :-)
            H Thomas BraunT 2 Antworten Letzte Antwort
            • frampF framp
              HiHo
              @framp
              nun, eigentlich wollte ich ja nur ein Systembackup vom Raspi haben, über Backitup habe ich ja quasi nur ioBroker gesichert, oder? Also kann ich das raspiBackup besser wieder runterschmeissen...
              frampF 1 Antwort Letzte Antwort
              • frampF framp
                @framp
                Ich bitte um Entschuldigung. Wusste nicht mehr genau was der Punkt war.
                  @framp
                  HiHo
                  in raspiBackup gibt es eine Einstellung, welche Services man zunächst stoppen möcvhte, da habe ich iobroker natürlich ausgewählt. Weiss nicht, ob das genügt ? Ich hatte jedenfalls keine Fehlermeldung beim letzten Backup.
                    @framp
                    frampF Offline
                    frampF Offline
                    framp
                    @thomas-braun Kein Problem. ich habe es ja richtig gestellt 😁
                    • H HiHo
                      @framp
                      frampF Offline
                      frampF Offline
                      framp
                      @hiho said in Nach restore Adapter in der Konsole aber nicht ...:
                      Das verstehe ich nicht warum Du es runterschmeissen willst 🙄 . Mit raspiBackup kannst Du ein Systembackup erstellen was Du ja willst - oder verstehe ich Dich falsch?.
                      • frampF framp
                        HiHo
                        @framp
                        nein, alles richtig. War mir nur gerade nicht mehr sicher, was noch gut ist und was nicht...😖
                        Aber ich lasse es jetzt mal so laufen. Das nächste Projekt ist alles auf eine SSD zu schaufeln und das ganze von dort aus zu betreiben 😬. Hoffe, dass ich mir nicht wieder das nächste Grab schaufle...😇 .
                        Euch auf jeden Fall nochmal herzlichen Dank 😘
