  4. Nach restore Adapter in der Konsole aber nicht ...
    5.6k
57 Beiträge 6 Kommentatoren 5.1k Aufrufe 4 Beobachtet
  • H HiHo
    @crunchip
    sieht schon anders aus:
    pi@iobroker:~ $ iobroker repo unset live
    Repository "live" deactivated.
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    live          : http://iobroker.live/repo/sources-dist-latest.json
    pi@iobroker:~ $ iobroker update
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
    Adapter    "cloud"        : 4.2.2    , installed 4.3.0
    Adapter    "discovery"    : 3.0.5    , installed 3.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.2.0    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.43
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.15
    Adapter    "info"         : 1.9.19   , installed 1.9.21
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
    Adapter    "javascript"   : 6.0.3    , installed 6.1.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "openweathermap": 0.3.0   , installed 0.3.3
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
    Adapter    "socketio"     : 4.2.0    , installed 6.1.10
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "terminal"     : 0.2.6    , installed 1.0.0
    Adapter    "text2command" : 2.2.2    , installed 2.3.0
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 4.3.0    , installed 5.2.10
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.3
    Adapter    "ws"           : 1.3.0    , installed 2.1.5
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    aber wieso verweist es dann auf Beta?
    Das Backuptool ist das "raspiBackup", ist doch kein Problem oder?
    @hiho sagte in Nach restore Adapter in der Konsole aber nicht ...:
    Kenn ich nicht.
    • H HiHo
      @crunchip
      Weil du es so eingestellt hast.
      Das Repo ist soweit ich weiß nicht im Standard drin.
      • H HiHo
        @crunchip
        nicht auszuschließen. Wo kommt das denn her?
        H 1 Antwort Letzte Antwort
          HiHo
          schrieb am zuletzt editiert von HiHo
          habe ich hier gefunden
          https://raspibackup.linux-tips-and-tricks.de/de/home-deutsch/
          an sich funktioniert es ganz gut... frage mich aber gerade ab das auch über Backitup geht...
          das habe ich aber erst nach der ganzen Geschichte installiert...
          • H HiHo
            @hiho
            Das tool von @framp kenne ich zwar nicht genau, aber das hatte in der Vergangenheit Probleme mit ACL Dateirechten. Ob die in der aktuellsten Version behoben sind weiß ich nicht, framp wollte sich das aber anschauen.
            H frampF 2 Antworten Letzte Antwort
              @hiho
              HiHo
              also im Moment sieht alles gut aus. Es scheint dann an der Repo gelegen zu haben?
              Jedenfalls vielen Dank für eure Hilfe und eure Geduld, ihr seid ein Spitzenteam! 👏 😊
                @hiho
                frampF Offline
                frampF Offline
                framp
                schrieb am zuletzt editiert von framp
                @thomas-braun said in Nach restore Adapter in der Konsole aber nicht ...:
                Es ist nicht raspiBackup sondern rsync. Das kann keine ACLs per nfs sichern. Hier steht beschrieben was man bei IOBroker tun muss um mit ACLs und rsync/raspiBackup zurecht zu kommen :-)
                H Thomas BraunT 2 Antworten Letzte Antwort
                • frampF framp
                  HiHo
                  @framp
                  nun, eigentlich wollte ich ja nur ein Systembackup vom Raspi haben, über Backitup habe ich ja quasi nur ioBroker gesichert, oder? Also kann ich das raspiBackup besser wieder runterschmeissen...
                  frampF 1 Antwort Letzte Antwort
                  • frampF framp
                    @framp
                    Ich bitte um Entschuldigung. Wusste nicht mehr genau was der Punkt war.
                      @framp
                      HiHo
                      in raspiBackup gibt es eine Einstellung, welche Services man zunächst stoppen möcvhte, da habe ich iobroker natürlich ausgewählt. Weiss nicht, ob das genügt ? Ich hatte jedenfalls keine Fehlermeldung beim letzten Backup.
                        @framp
                        frampF Offline
                        frampF Offline
                        framp
                        @thomas-braun Kein Problem. ich habe es ja richtig gestellt 😁
                        • H HiHo
                          @framp
                          frampF Offline
                          frampF Offline
                          framp
                          @hiho said in Nach restore Adapter in der Konsole aber nicht ...:
                          Das verstehe ich nicht warum Du es runterschmeissen willst 🙄 . Mit raspiBackup kannst Du ein Systembackup erstellen was Du ja willst - oder verstehe ich Dich falsch?.
                          • frampF framp
                            HiHo
                            @framp
                            nein, alles richtig. War mir nur gerade nicht mehr sicher, was noch gut ist und was nicht...😖
                            Aber ich lasse es jetzt mal so laufen. Das nächste Projekt ist alles auf eine SSD zu schaufeln und das ganze von dort aus zu betreiben 😬. Hoffe, dass ich mir nicht wieder das nächste Grab schaufle...😇 .
                            Euch auf jeden Fall nochmal herzlichen Dank 😘
