  4. Raspi4 2GB / ioBroker startet jeden Tag neu ?
    5.6k
41 Beiträge 9 Kommentatoren 1.6k Aufrufe 6 Beobachtet
  • HumidorH Offline
    HumidorH Offline
    Humidor
    schrieb am zuletzt editiert von Humidor
    Hallo Gemeinde,
    könnt ihr aus dem Log da was erkennen?
    es fängt an mit ECONNRESET und dann sind die DB closed, irgendwann gibt er auf und startet neu.
    2022-11-05 22:58:11.742 - error: go-e.0 (144279) Objects database error: write ECONNRESET
    2022-11-05 22:58:11.748 - error: life360.0 (155077) States database error: write ECONNRESET
    2022-11-05 22:58:11.848 - error: backitup.0 (144084) States database error: read ECONNRESET
    2022-11-05 22:58:11.767 - error: go-e.0 (144279) States database error: write ECONNRESET
    2022-11-05 22:58:11.950 - error: fronius.0 (153864) States database error: write ECONNRESET
    2022-11-05 22:58:12.021 - info: life360.0 (155077) cleaned everything up...
    2022-11-05 22:58:12.017 - info: backitup.0 (144084) cleaned everything up...
    2022-11-05 22:58:12.090 - error: renault.0 (144298) States database error: read ECONNRESET
    2022-11-05 22:58:11.729 - error: echarts.0 (144348) States database error: write ECONNRESET
    2022-11-05 22:58:11.731 - error: vis-inventwo.0 (144253) States database error: write ECONNRESET
    2022-11-05 22:58:11.730 - error: time-switch.0 (144359) States database error: write ECONNRESET
    2022-11-05 22:58:12.308 - error: modbus.1 (143976) States database error: write ECONNRESET
    2022-11-05 22:58:12.324 - error: kecontact.0 (144333) Objects database error: write ECONNRESET
    2022-11-05 22:58:12.326 - error: javascript.0 (143862) Objects database error: write ECONNRESET
    2022-11-05 22:58:11.928 - error: fritzdect.0 (144317) Objects database error: write ECONNRESET
    2022-11-05 22:58:12.251 - error: fritzdect.0 (144317) States database error: write ECONNRESET
    2022-11-05 22:58:12.339 - info: vis-inventwo.0 (144253) cleaned everything up...
    2022-11-05 22:58:12.213 - error: modbus.0 (164056) States database error: write ECONNRESET
    2022-11-05 22:12:46.131 - info: cloud.0 (143910) Connection changed: disconnect
    2022-11-05 22:58:12.376 - error: cloud.0 (143910) States database error: write ECONNRESET
    2022-11-05 22:58:12.374 - error: vis-inventwo.0 (144253) uncaught exception: write EPIPE
    2022-11-05 22:58:12.377 - error: vis-inventwo.0 (144253) Error: write EPIPE
    at afterWriteDispatched (node:internal/stream_base_commons:160:15)
    at writeGeneric (node:internal/stream_base_commons:151:3)
    at Socket._writeGeneric (node:net:874:11)
    at Socket._write (node:net:886:8)
    at writeOrBuffer (node:internal/streams/writable:391:12)
    at _write (node:internal/streams/writable:332:10)
    at Socket.Writable.write (node:internal/streams/writable:336:10)
    at console.value (node:internal/console/constructor:299:16)
    at console.warn (node:internal/console/constructor:381:26)
    at /opt/iobroker/node_modules/pidusage/lib/helpers/cpu.js:45:17
    2022-11-05 22:58:12.392 - error: vis-inventwo.0 (144253) Exception-Code: EPIPE: write EPIPE
    2022-11-05 22:58:12.319 - error: shelly.0 (144069) Objects database error: write EPIPE
    2022-11-05 22:58:12.469 - error: modbus.1 (143976) Objects database error: read ECONNRESET
    2022-11-05 22:58:12.333 - error: iot.0 (154615) States database error: write ECONNRESET
    2022-11-05 22:58:12.513 - info: iot.0 (154615) Connection changed: disconnect
    2022-11-05 22:58:12.515 - info: iot.0 (154615) Connection lost
    2022-11-05 22:58:12.254 - error: s7.0 (144032) States database error: write ECONNRESET
    2022-11-05 22:58:12.527 - error: s7.0 (144032) Objects database error: write ECONNRESET
    2022-11-05 22:58:12.366 - error: modbus.0 (164056) Objects database error: read ECONNRESET
    2022-11-05 22:58:12.454 - info: fritzdect.0 (144317) cleaned everything up...
    2022-11-05 22:58:12.461 - info: time-switch.0 (144359) cleaning everything up...
    2022-11-05 22:58:12.618 - error: modbus.1 (143976) Socket Error
    2022-11-05 22:58:12.610 - error: kecontact.0 (144333) States database error: write ECONNRESET
    2022-11-05 22:58:12.228 - error: web.0 (144106) States database error: write ECONNRESET
    2022-11-05 22:58:12.619 - error: modbus.1 (143976) Client in error state.
    2022-11-05 22:58:12.524 - error: admin.0 (143804) States database error: write ECONNRESET
    2022-11-05 22:58:12.624 - error: ws.0 (144379) States database error: write ECONNRESET
    2022-11-05 22:58:12.758 - info: renault.0 (144298) battery-status receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:12.479 - error: shelly.0 (144069) States database error: write ECONNRESET
    2022-11-05 22:58:12.846 - error: mqtt.0 (144006) Objects database error: write ECONNRESET
    2022-11-05 22:58:12.905 - error: mqtt.0 (144006) States database error: write ECONNRESET
    2022-11-05 22:58:13.011 - info: renault.0 (144298) battery-inhibition-status receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:13.137 - error: telegram.0 (143890) States database error: write ECONNRESET
    2022-11-05 22:58:13.261 - info: renault.0 (144298) cockpit receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:13.520 - info: renault.0 (144298) cockpitv2 receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:13.541 - info: fronius.0 (153864) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.524 - info: go-e.0 (144279) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.537 - info: backitup.0 (144084) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.541 - info: life360.0 (155077) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.627 - error: javascript.0 (143862) States database error: write ECONNRESET
    2022-11-05 22:58:13.658 - info: javascript.0 (143862) Stop script script.js.common.AMIS_Fronius
    2022-11-05 22:58:13.660 - info: javascript.0 (143862) Stop script script.js.common.AMIS_Home
    2022-11-05 22:58:13.661 - info: javascript.0 (143862) Stop script script.js.common.C35
    2022-11-05 22:58:13.662 - info: javascript.0 (143862) Stop script script.js.common.SE_Power
    2022-11-05 22:58:13.663 - info: javascript.0 (143862) Stop script script.js.common.ZOE_Ladung_Ziel
    2022-11-05 22:58:13.666 - info: javascript.0 (143862) Stop script script.js.common.ZOE_MIN_Ladung
    2022-11-05 22:58:13.667 - info: javascript.0 (143862) Stop script script.js.common.go-E_Error
    2022-11-05 22:58:13.668 - info: javascript.0 (143862) Stop script script.js.common.go-E_Limits
    2022-11-05 22:58:13.668 - info: javascript.0 (143862) Stop script script.js.common.go-E_Verriegelung
    2022-11-05 22:58:13.669 - info: javascript.0 (143862) Stop script script.js.common.ZOE_GridOffset
    2022-11-05 22:58:13.669 - info: javascript.0 (143862) Stop script script.js.common.ZOE_MinMax
    2022-11-05 22:58:13.670 - info: javascript.0 (143862) Stop script script.js.common.go-E_Control
    2022-11-05 22:58:13.671 - info: javascript.0 (143862) Stop script script.js.common.go-E_GridOffset
    2022-11-05 22:58:13.672 - info: javascript.0 (143862) Stop script script.js.common.Pool_Steuerung
    2022-11-05 22:58:13.672 - info: javascript.0 (143862) Stop script script.js.common.ZOE_Phasen
    2022-11-05 22:58:13.673 - info: javascript.0 (143862) Stop script script.js.common.go-E_Init
    2022-11-05 22:58:13.673 - info: javascript.0 (143862) Stop script script.js.common.go-E_Überschuss
    2022-11-05 22:58:13.674 - info: javascript.0 (143862) Stop script script.js.common.go-E_Überwachung
    2022-11-05 22:58:13.674 - info: javascript.0 (143862) Stop script script.js.common.Grid-PV
    2022-11-05 22:58:13.676 - info: javascript.0 (143862) Stop script script.js.common.Grid-PVFronius
    2022-11-05 22:58:13.677 - info: javascript.0 (143862) Stop script script.js.common.ZOE_Debug
    2022-11-05 22:58:13.678 - info: javascript.0 (143862) Stop script script.js.common.go-E_Phasen
    2022-11-05 22:58:13.679 - info: javascript.0 (143862) Stop script script.js.common.ZOE_Regelung
    2022-11-05 22:58:13.679 - info: javascript.0 (143862) Stop script script.js.common.Pool
    2022-11-05 22:58:13.680 - info: javascript.0 (143862) Stop script script.js.common.ZOE_Steuerung
    2022-11-05 22:58:13.680 - info: javascript.0 (143862) Stop script script.js.common.go-E_Charger
    2022-11-05 22:58:13.681 - info: javascript.0 (143862) Stop script script.js.common.Garage
    2022-11-05 22:58:13.682 - info: javascript.0 (143862) Stop script script.js.common.ZOE_Init
    2022-11-05 22:58:13.682 - info: javascript.0 (143862) Stop script script.js.common.Adapter_Blockly
    2022-11-05 22:58:13.712 - info: echarts.0 (144348) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.772 - info: renault.0 (144298) charge-mode receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:13.817 - info: renault.0 (144298) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.843 - info: vis-inventwo.0 (144253) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.919 - info: cloud.0 (143910) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.966 - info: time-switch.0 (144359) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.973 - info: daswetter.0 (164348) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:13.989 - info: fritzdect.0 (144317) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:14.007 - info: iot.0 (154615) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:14.008 - info: renault.0 (144298) hvac-status receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:14.075 - info: s7.0 (144032) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:14.182 - info: kecontact.0 (144333) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:14.244 - info: renault.0 (144298) hvac-settings receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:14.492 - info: shelly.0 (144069) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:14.518 - info: renault.0 (144298) charging-settings receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:14.756 - info: renault.0 (144298) charges receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:14.996 - info: renault.0 (144298) location receive 401 error. Refresh Token in 60 seconds
    2022-11-05 22:58:15.162 - info: javascript.0 (143862) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:16.770 - error: go-e.0 (144279) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:16.796 - error: life360.0 (155077) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:16.804 - warn: life360.0 (155077) get state error: Connection is closed.
    2022-11-05 22:58:16.806 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.807 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.808 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.809 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.810 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.811 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.812 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.813 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.814 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.815 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.816 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.817 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.818 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.819 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.820 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.821 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.822 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.823 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.824 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.825 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.826 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.827 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.828 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.829 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.830 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.831 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.832 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.833 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.834 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.835 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.840 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.841 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.842 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.843 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.844 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.845 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.846 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.847 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.848 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.849 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.850 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.851 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.852 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.853 - warn: life360.0 (155077) get state error: DB closed
    2022-11-05 22:58:16.882 - warn: backitup.0 (144084) get state error: DB closed
    2022-11-05 22:58:16.888 - warn: go-e.0 (144279) get state error: Connection is closed.
    2022-11-05 22:58:16.889 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.890 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.891 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.892 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.898 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.902 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.903 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.904 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.905 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.906 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.907 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.909 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.910 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.911 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.912 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:16.913 - warn: go-e.0 (144279) get state error: DB closed
    2022-11-05 22:58:17.010 - error: fronius.0 (153864) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.218 - error: fritzdect.0 (144317) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.225 - error: echarts.0 (144348) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.347 - error: javascript.0 (143862) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.365 - error: vis-inventwo.0 (144253) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.403 - warn: renault.0 (144298) get state error: Connection is closed.
    2022-11-05 22:58:17.413 - warn: cloud.0 (143910) get state error: Connection is closed.
    2022-11-05 22:58:17.404 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.405 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.406 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.407 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.408 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.409 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.413 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.414 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.415 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.416 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.417 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.418 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.419 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.420 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.421 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.422 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.423 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.424 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.425 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.426 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.427 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.428 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.429 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.430 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.431 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.432 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.433 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.434 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.435 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.436 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.437 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.438 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.439 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.440 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.441 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.442 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.443 - warn: renault.0 (144298) get state error: DB closed
    2022-11-05 22:58:17.448 - error: kecontact.0 (144333) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.482 - error: shelly.0 (144069) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.526 - error: modbus.0 (164056) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.554 - error: modbus.1 (143976) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.560 - error: s7.0 (144032) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.563 - warn: iot.0 (154615) get state error: Connection is closed.
    2022-11-05 22:58:17.582 - warn: time-switch.0 (144359) get state error: Connection is closed.
    2022-11-05 22:58:17.566 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.568 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.569 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.570 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.572 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.573 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.574 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.578 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.581 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.582 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.584 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.585 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.586 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.587 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.589 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.590 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.591 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.592 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.593 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.595 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.596 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.597 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.598 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.599 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.600 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.601 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.602 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.603 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.604 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.605 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.606 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.607 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.608 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.609 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.610 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.611 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.612 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.618 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.619 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.620 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.621 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.622 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.623 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.624 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.625 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.626 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.627 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.628 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.629 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.630 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.631 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.632 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.633 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.634 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.635 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.636 - warn: iot.0 (154615) get state error: DB closed
    2022-11-05 22:58:17.673 - warn: fritzdect.0 (144317) get state error: Connection is closed.
    2022-11-05 22:58:17.695 - warn: kecontact.0 (144333) get state error: Connection is closed.
    2022-11-05 22:58:17.690 - warn: daswetter.0 (164348) get state error: Connection is closed.
    2022-11-05 22:58:17.781 - error: ws.0 (144379) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2022-11-05 22:58:17.790 - error: ws.0 (144379) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:17.700 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.701 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.702 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.703 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.705 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.706 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.707 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.708 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.709 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.710 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.734 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.735 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.736 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.741 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.742 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.771 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.772 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.773 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.774 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.775 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.776 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.777 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.778 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.793 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.794 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.795 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.796 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.797 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.798 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.799 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.800 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.803 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.804 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.805 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.806 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.807 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.808 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.809 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.810 - warn: kecontact.0 (144333) get state error: DB closed
    2022-11-05 22:58:17.910 - error: mqtt.0 (144006) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:18.001 - warn: shelly.0 (144069) get state error: Connection is closed.
    2022-11-05 22:58:18.003 - warn: shelly.0 (144069) get state error: DB closed
    2022-11-05 22:58:18.004 - warn: shelly.0 (144069) get state error: DB closed
    2022-11-05 22:58:18.005 - warn: shelly.0 (144069) get state error: DB closed
    2022-11-05 22:58:18.006 - warn: shelly.0 (144069) get state error: DB closed
    2022-11-05 22:58:18.008 - warn: shelly.0 (144069) redis get shelly.0.SHPLG-S#8044C6#1.firmware, error - DB closed
    2022-11-05 22:58:18.009 - warn: shelly.0 (144069) redis get shelly.0.SHPLG-S#EED8F9#1.firmware, error - DB closed
    2022-11-05 22:58:18.010 - warn: shelly.0 (144069) redis get shelly.0.SHPLG-S#BC6DEB#1.firmware, error - DB closed
    2022-11-05 22:58:18.010 - warn: shelly.0 (144069) redis get shelly.0.SHPLG-S#DCCD03#1.firmware, error - DB closed
    2022-11-05 22:58:18.011 - warn: shelly.0 (144069) redis get shelly.0.SHSW-25#483FDA8241A8#1.firmware, error - DB closed
    2022-11-05 22:58:18.011 - warn: shelly.0 (144069) get state error: DB closed
    2022-11-05 22:58:18.011 - warn: shelly.0 (144069) redis get shelly.0.SHPLG-S#DCCD03#1.Relay0.Timer, error - DB closed
    2022-11-05 22:58:18.011 - warn: shelly.0 (144069) redis get shelly.0.SHSW-25#483FDA8241A8#1.Relay0.Timer, error - DB closed
    2022-11-05 22:58:18.012 - warn: shelly.0 (144069) redis get shelly.0.SHPLG-S#8044C6#1.Relay0.Timer, error - DB closed
    2022-11-05 22:58:18.012 - warn: shelly.0 (144069) get state error: DB closed
    2022-11-05 22:58:18.013 - warn: shelly.0 (144069) get state error: DB closed
    2022-11-05 22:58:18.016 - warn: shelly.0 (144069) get state error: DB closed
    2022-11-05 22:58:18.030 - warn: shelly.0 (144069) redis get shelly.0.SHSW-25#483FDA8241A8#1.Relay1.Timer, error - Connection is closed.
    2022-11-05 22:58:18.037 - warn: shelly.0 (144069) redis get shelly.0.SHSW-25#483FDA8241A8#1.Shutter.Duration, error - Connection is closed.
    2022-11-05 22:58:12.374 - error: history.0 (143831) States database error: write EPIPE
    2022-11-05 22:58:18.695 - warn: javascript.0 (143862) get state error: Connection is closed.
    2022-11-05 22:58:18.696 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.697 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.698 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.699 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.700 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.701 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.705 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.706 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.707 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.708 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.709 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.710 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.715 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.716 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.717 - warn: javascript.0 (143862) redis get javascript.0.variables.isDayTime, error - DB closed
    2022-11-05 22:58:18.717 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.718 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.719 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.720 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.721 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.722 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.723 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.724 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.725 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.726 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:18.727 - warn: javascript.0 (143862) get state error: DB closed
    2022-11-05 22:58:22.496 - error: shelly.0 (144069) Cannot find view "system" for search "device" : DB closed
    2022-11-05 22:58:22.810 - error: ws.0 (144379) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:29.223 - error: history.0 (143831) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2022-11-05 22:58:29.273 - error: history.0 (143831) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:34.231 - error: history.0 (143831) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2022-11-05 22:58:34.296 - error: history.0 (143831) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-11-05 22:58:35.193 - info: history.0 (143831) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-05 22:58:39.251 - warn: history.0 (143831) get state error: Connection is closed.
    2022-11-05 22:58:44.929 - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2022-11-05 22:58:44.936 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-11-05 22:58:44.937 - info: host.raspberrypi hostname: raspberrypi, node: v16.17.1
    2022-11-05 22:58:44.938 - info: host.raspberrypi ip addresses: 192.168.0.92 fe80::8511:91de:53a6:d2db 192.168.0.93 fe80::4e06:c2e7:21eb:13ec
    2022-11-05 22:58:46.521 - info: host.raspberrypi connected to Objects and States
    2022-11-05 22:58:46.590 - info: host.raspberrypi added notifications configuration of host
    2022-11-05 22:58:47.359 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
    2022-11-05 22:58:47.361 - info: host.raspberrypi 35 instances found
    2022-11-05 22:58:47.437 - info: host.raspberrypi starting 28 instances
    2022-11-05 22:58:47.623 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
    2022-11-05 22:58:47.694 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 164478
    2022-11-05 22:58:47.711 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
    2022-11-05 22:58:47.768 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
    2022-11-05 22:58:47.827 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
    2022-11-05 22:58:47.888 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
    2022-11-05 22:58:47.949 - info: host.raspberrypi Some obsolete host states deleted.
    2022-11-05 22:58:49.727 - error: admin.0 (164478) admin.0 already running
    2022-11-05 22:58:50.321 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:58:50.322 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2022-11-05 22:58:51.505 - info: host.raspberrypi instance system.adapter.history.0 started with pid 164489
    2022-11-05 22:58:52.937 - error: history.0 (164489) history.0 already running
    2022-11-05 22:58:52.942 - warn: history.0 (164489) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-11-05 22:58:53.577 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:58:53.578 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
    2022-11-05 22:58:55.508 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 164500
    2022-11-05 22:58:58.813 - error: javascript.0 (164500) javascript.0 already running
    2022-11-05 22:58:58.817 - warn: javascript.0 (164500) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-11-05 22:58:59.412 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:58:59.413 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2022-11-05 22:58:59.513 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 164511
    2022-11-05 22:59:01.967 - error: telegram.0 (164511) telegram.0 already running
    2022-11-05 22:59:02.549 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:59:02.549 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2022-11-05 22:59:03.501 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 164522
    2022-11-05 22:59:05.084 - error: cloud.0 (164522) cloud.0 already running
    2022-11-05 22:59:05.089 - warn: cloud.0 (164522) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-11-05 22:59:05.664 - error: host.raspberrypi instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:59:05.665 - info: host.raspberrypi Restart adapter system.adapter.cloud.0 because enabled
    2022-11-05 22:59:07.528 - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 164533
    2022-11-05 22:59:09.032 - error: modbus.0 (164533) modbus.0 already running
    2022-11-05 22:59:09.609 - error: host.raspberrypi instance system.adapter.modbus.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:59:09.609 - info: host.raspberrypi Restart adapter system.adapter.modbus.0 because enabled
    2022-11-05 22:59:11.517 - info: host.raspberrypi instance system.adapter.modbus.1 started with pid 164544
    2022-11-05 22:59:12.945 - error: modbus.1 (164544) modbus.1 already running
    2022-11-05 22:59:13.528 - error: host.raspberrypi instance system.adapter.modbus.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:59:13.528 - info: host.raspberrypi Restart adapter system.adapter.modbus.1 because enabled
    2022-11-05 22:59:15.573 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 164555
    2022-11-05 22:59:16.977 - error: mqtt.0 (164555) mqtt.0 already running
    2022-11-05 22:59:17.555 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:59:17.556 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
    2022-11-05 22:59:19.522 - info: host.raspberrypi instance system.adapter.s7.0 started with pid 164566
    2022-11-05 22:59:20.392 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 164573
    2022-11-05 22:59:21.118 - error: s7.0 (164566) s7.0 already running
    2022-11-05 22:59:21.124 - warn: s7.0 (164566) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-11-05 22:59:21.704 - error: host.raspberrypi instance system.adapter.s7.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-05 22:59:21.705 - info: host.raspberrypi Restart adapter system.adapter.s7.0 because enabled
    2022-11-05 22:59:23.871 - info: host.raspberrypi instance system.adapter.history.0 started with pid 164600
    2022-11-05 22:59:23.933 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 164606
    2022-11-05 22:59:25.807 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-11-05 22:59:26.825 - info: history.0 (164600) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.history, node: v16.17.1, js-controller: 4.0.23
    2022-11-05 22:59:27.079 - info: history.0 (164600) enabled logging of fronius.0.inverter.1.PAC (Count=1), Alias=false
    2022-11-05 22:59:27.081 - info: history.0 (164600) enabled logging of go-e.0.amperePV (Count=2), Alias=false
    2022-11-05 22:59:27.083 - info: history.0 (164600) enabled logging of go-e.0.allow_charging (Count=3), Alias=false
    BG
    arteckA CodierknechtC 2 Antworten Letzte Antwort
    • HumidorH Humidor
      Hallo Gemeinde,
      arteckA Offline
      arteckA Offline
      arteck
      @humidor ich tippe auf speicher platz ..
      zeigmal
      df -h
      HumidorH 1 Antwort Letzte Antwort
      • arteckA arteck
        zeigmal
        df -h
        HumidorH Offline
        HumidorH Offline
        Humidor
        @arteck morgen!
        pi@raspberrypi:~ $ df -h
        Filesystem      Size  Used Avail Use% Mounted on
        /dev/root        29G  5.7G   22G  21% /
        devtmpfs        763M     0  763M   0% /dev
        tmpfs           925M     0  925M   0% /dev/shm
        tmpfs           370M  1.1M  369M   1% /run
        tmpfs           5.0M  4.0K  5.0M   1% /run/lock
        /dev/mmcblk0p1  255M   31M  225M  12% /boot
        tmpfs           185M     0  185M   0% /run/user/1000
        pi@raspberrypi:~ $
        BG
        • HumidorH Humidor
          Hallo Gemeinde,
          CodierknechtC Offline
          Codierknecht
          @humidor
          Hmmmm, ich betreibe den Broker zwar nicht auf 'nem Raspi, aber bei 2GB würde ich eher die RAM-Ausstattung als den Plattenplatz im Verdacht haben. Insbesondere bei der Anzahl der Adapter die im Log zu sehen sind.
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • CodierknechtC Codierknecht
            @humidor
            crunchipC Offline
            crunchipC Offline
            @codierknecht allerdings
            @humidor sagte in Raspi4 2GB / ioBroker startet jeden Tag neu ?:
              HumidorH Offline
              HumidorH Offline
              Humidor
              @crunchip der RAM ist durchaus ein Kandidat, aber was füllt ihn auf ?
              BG
              • HumidorH Humidor
                Codierknecht
                @humidor
                Die 24 laufenden Prozesse?
                Jeder Prozess braucht Speicher ... und irgendwann ist einfach Ende Gelände ;-)
                  @humidor
                  HumidorH Offline
                  HumidorH Offline
                  Humidor
                  @codierknecht schon klar, aber der Ram verbraucht sich nach Zeit, dh. mind. ein Adapter müllt den zu
                  BG
                  • HumidorH Humidor
                    Codierknecht
                    @humidor
                    https://www.howtoforge.de/anleitung/wie-man-laufende-prozesse-unter-linux-anzeigt/
                    iobroker@iobroker:/opt/iobroker# top
                    Da müsste sich dann nach Deiner Annahme ein Prozess mit massivem Speicherverbrauch finden lassen ...
                      @humidor
                      HumidorH Offline
                      HumidorH Offline
                      Humidor
                      @codierknecht danke, dh wer da unter %Mem wächst, der ist ein Kandidat
                      BG
                      • HumidorH Humidor
                        Codierknecht
                        @humidor
                        Ich glaube kaum, dass damit ein einzelner Prozess als Übeltäter auszumachen ist.
                        Die brauchen ja alle nicht wirklich übermäßig viel von dem beschränkt verfügbaren Speicher.
                        Rechne mal zusammen ... da bleibt nicht viel übrig.
                        So sieht das bei mir aus:
                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                          428 iobroker  20   0 1143060 194184  10500 S   5,0   2,4   2897:30 iobroker.js-con
                        26204 iobroker  20   0  952836  87472  10272 R   4,7   1,1   2630:18 io.lupusec.1
                        23996 iobroker  20   0   10,9g  58036  10392 S   1,7   0,7 688:48.62 io.synology.0
                          512 iobroker  20   0  794024  56916   9780 S   1,0   0,7 397:39.29 io.sql.0
                        10544 iobroker  20   0  690032  51988  12240 S   1,0   0,6 107:09.94 io.tr-064.0
                          470 iobroker  20   0 1042160 100412  10580 S   0,7   1,3 492:16.04 io.javascript.0
                        20017 iobroker  20   0  696652  28880  12280 S   0,7   0,4  86:54.05 io.mqtt.0
                        32356 iobroker  20   0  688316  49128  10404 S   0,7   0,6  89:13.86 io.hue.0
                          742 iobroker  20   0  669376  25020   8272 S   0,3   0,3 182:53.43 io.denon.0
                          804 iobroker  20   0  970812  63944  10452 S   0,3   0,8  49:58.56 io.web.0
                        31324 iobroker  20   0  955932  46816  14984 S   0,3   0,6   3:04.95 io.backitup.0
                            1 root      20   0    7292    276    276 S   0,0   0,0   0:00.05 iobroker_startu
                          497 iobroker  20   0  674128  36300   8760 S   0,0   0,5  22:37.28 io.scenes.0
                          569 iobroker  20   0  687240  45776   8328 S   0,0   0,6  32:30.00 io.hm-rega.0
                          702 iobroker  20   0  666092  37144   8580 S   0,0   0,5  32:37.74 io.fritzdect.0
                          789 iobroker  20   0  652328  30376   7968 S   0,0   0,4  20:23.24 io.discovery.0
                          876 iobroker  20   0  681208  36336   9272 S   0,0   0,5  66:10.17 io.lgtv.0
                         6996 iobroker  20   0  679736  40840  12128 S   0,0   0,5  18:37.62 io.device-watch
                         8549 iobroker  20   0 1022408 105700  14904 S   0,0   1,3  17:09.28 io.admin.1
                        16843 iobroker  20   0  671308  36264  11100 S   0,0   0,5  10:14.03 io.snmp.0
                        18582 root      20   0    7424   2276   1752 S   0,0   0,0   0:00.01 bash
                        19878 iobroker  20   0  954592  52120  14228 S   0,0   0,6  23:36.28 io.tapo.0
                        20056 iobroker  20   0  763180  59196  13144 S   0,0   0,7  12:07.57 io.yahka.0
                        20150 iobroker  20   0  693836  53480  12720 S   0,0   0,7 158:22.58 io.unifi.0
                        20951 iobroker  20   0  665796  49520  18884 S   0,0   0,6   0:01.77 io.trashschedul
                        21061 iobroker  20   0  962476  74528  13044 S   0,0   0,9   7:47.59 io.sourceanalyt
                        21157 iobroker  20   0  686920  46008  11120 S   0,0   0,6  26:06.42 io.hm-rpc.0
                        21498 root      20   0   10256   1924   1416 R   0,0   0,0   0:00.00 top
                        22130 iobroker  20   0  960560  65460  14420 S   0,0   0,8  45:01.08 io.meross.0
                        Das sind insgesamt knapp 20% oder 1,6 GB.
                        HumidorH HomoranH 2 Antworten Letzte Antwort
                          @humidor
                          HumidorH Offline
                          HumidorH Offline
                          Humidor
                          @codierknecht 1,6GB sind ja auch bei mir benutzt, 126MB frei
                          wenn man was macht, wie ein Blockly erstellen, dann gehts auf 0
                          wenn man ihn völlig in Ruhe lässt, scheint er durchzulaufen
                          dh wenn man etwas tut, verbraucht es Ram, ist ja auch klar, aber da ist dann ein Raspi4 mit 2GB schon an der Grenze, überhaupt sinnvoll eingesetzt zu werden
                          ev. sollte hier die Doku darauf hinweisen, wenn sie das nicht schon tut.
                          BG
                          Thomas BraunT CodierknechtC crunchipC 3 Antworten Letzte Antwort
                          • HumidorH Humidor
                            @humidor
                            free -ht --mega
                            sagt?
                              @humidor
                              free -ht --mega
                              sagt?
                              HumidorH Offline
                              HumidorH Offline
                              Humidor
                              @thomas-braun sagte in Raspi4 2GB / ioBroker startet jeden Tag neu ?:
                              free -ht --mega
                              Mem:            1.8G        1.6G        113M        0.0K        134M        169M
                              Swap:            99M         99M          0B
                              Total:          1.9G        1.7G        113M
                              BG
                              • HumidorH Humidor
                                free -ht --mega
                                Swap:            99M         99M          0B
                                @humidor
                                Das Ding läuft im Roten Bereich.
                                  @humidor
                                  HumidorH Offline
                                  HumidorH Offline
                                  Humidor
                                  @thomas-braun dh für 24 Prozesse sind 2GB zu wenig
                                  BG
                                  • HumidorH Humidor
                                    @humidor
                                    Das hängt (auch) damit zusammen was das für Instanzen (du meinst nicht Prozesse, da laufen wesentlich mehr auf deiner Kiste) sind.
                                      @humidor
                                      HumidorH Offline
                                      HumidorH Offline
                                      Humidor
                                      @thomas-braun richtig, Prozesse, ist aber nicht wirklich viel was ich mache, die grundlegende ioBroker Struktur benötigt ja auch schon ein paar Prozesse....
                                      BG
                                      • HumidorH Humidor
                                        @humidor
                                        ps -e | wc -l
                                        Da siehst du wieviele Prozesse laufen.
                                        Bzw. genauer:
                                        ps -e --no-headers | wc -l
                                        Aber grundsätzlich finde ich das 2GB RAM die unterste Grenze ist, wenn da ein 'Standard'-Iobroker laufen soll.
                                          @humidor
                                          ps -e | wc -l
                                          Bzw. genauer:
                                          HumidorH Offline
                                          HumidorH Offline
                                          Humidor
                                          173 😬
                                          BG
