  4. Can not start inMem-objects on port 9001
    5.4k
55 Beiträge 5 Kommentatoren 6.2k Aufrufe 5 Beobachtet
    @nftvirus
    systemctl status iobroker.service
    N Offline
    N Offline
    NFTVirus
    pi@raspberrypi:/opt/iobroker $ systemctl status iobroker.service
    ● iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
         Active: inactive (dead) (Result: exit-code) since Tue 2022-11-01 13:25:46 GMT; 6min ago
           Docs: http://iobroker.net
        Process: 30534 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
       Main PID: 30534 (code=exited, status=1/FAILURE)
            CPU: 41.915s
    Nov 01 13:25:44 raspberrypi systemd[1]: iobroker.service: Consumed 41.915s CPU time.
    Nov 01 13:25:46 raspberrypi systemd[1]: Stopped ioBroker Server.
    Nov 01 13:25:46 raspberrypi systemd[1]: iobroker.service: Consumed 41.915s CPU time.
    • N NFTVirus
              CPU: 41.915s
      @nftvirus
      sudo systemctl mask iobroker.service
      sudo apt update
      N 1 Antwort Letzte Antwort
        @nftvirus
        sudo apt update
        N Offline
        N Offline
        NFTVirus
        pi@raspberrypi:/opt/iobroker $ sudo systemctl mask iobroker.service
        Created symlink /etc/systemd/system/iobroker.service → /dev/null.
        pi@raspberrypi:/opt/iobroker $ sudo apt update
        Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists... Done
        90 packages can be upgraded. Run 'apt list --upgradable' to see them.
        • N NFTVirus
          @nftvirus sagte in Can not start inMem-objects on port 9001:
          Neben dem Backup auch regelmäßiger das System auf Stand halten!!
          sudo apt full-upgrade
          sudo reboot
          Wenn das System wieder auf die Beine gekommen ist dürfte der
          iobroker status
          'nicht laufend' ausgeben.
          Dann mit
          iobroker start
          nachhelfen.
          Wenn das funktionieren sollte die Maske wieder abnehmen:
          sudo systemctl unmask iobroker.service
          N 2 Antworten Letzte Antwort
            sudo reboot
            iobroker status
            Dann mit
            iobroker start
            nachhelfen.
            N Offline
            N Offline
            NFTVirus
            @thomas-braun Vielen Dank für die ganze Unterstützung!!! Ich update jetzt noch alles und gebe dann nochmal kurz Rückmeldung ob wieder alles läuft.
              sudo reboot
              iobroker status
              Dann mit
              iobroker start
              nachhelfen.
              N Offline
              N Offline
              NFTVirus
              @thomas-braun Leider scheint es nicht geholfen zu haben:
              pi@raspberrypi:~ $ iob status
              No connection to databases possible ...
              pi@raspberrypi:~ $ iobroker start
              Failed to start iobroker.service: Unit iobroker.service is masked.
              pi@raspberrypi:~ $ iobroker status
              pi@raspberrypi:~ $ sudo systemctl unmask iobroker.service
              Removed /etc/systemd/system/iobroker.service.
              Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iob                                                 roker/iobroker-data/objects.jsonl"!
              pi@raspberrypi:~ $
              • N Offline
                N Offline
                NFTVirus
                Leider konnte ich es bisher nicht reparieren. Nun wollte ich ein älteres Backup nutzen und bekomme leider wieder nur no connection to databases possible..... Hat jemand noch eine Idee wie ich um ein komplettes Neuaufsetzen herum komme?
                pi@raspberrypi:~ $ iobroker stop
                pi@raspberrypi:~ $ iobroker restore 0
                pi@raspberrypi:~ $
                • N NFTVirus
                  ja den backitup sollte ich jetzt mal konfigurieren oder speichert er standartmäßig zumindest ein backup auf dem RPI?
                  pi@raspberrypi:/opt/iobroker $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                  COMMAND     PID     USER   FD   TYPE DEVICE  SIZE/OFF   NODE NAME
                  iobroker. 26626 iobroker   19u   REG  179,2 501587560 136879 /opt/iobroker/iobroker-data/objects.jsonl
                  GlasfaserG Offline
                  GlasfaserG Offline
                  kannst du mal bitte es aktuell zeigen , denn so sieht deine Datei riesig aus
                  du -sh  /opt/iobroker/iobroker-data/objects.jsonl
                  und
                  du -sh  /opt/iobroker/iobroker-data/backup-objects/*objects*
                  • GlasfaserG Glasfaser
                    und
                    N Offline
                    N Offline
                    NFTVirus
                    @glasfaser
                    pi@raspberrypi:/opt/iobroker/iobroker-data $ du -sh  /opt/iobroker/iobroker-data/objects.jsonl
                    479M    /opt/iobroker/iobroker-data/objects.jsonl
                    pi@raspberrypi:/opt/iobroker/iobroker-data $ du -sh  /opt/iobroker/iobroker-data/backup-objects/*objects*
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-27_21-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-27_23-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_01-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_03-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_05-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_07-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_09-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_11-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_13-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_15-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_17-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_19-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_21-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-28_23-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_01-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_03-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_05-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_07-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_09-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_11-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_13-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_15-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_17-47_objects.jsonl.gz
                    1.7M    /opt/iobroker/iobroker-data/backup-objects/2022-10-29_19-47_objects.jsonl.gz
                    • N NFTVirus
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @nftvirus
                      Du kannst mal ein Backup versuchen
                      iobroker stop
                      cd /opt/iobroker/iobroker-data/
                      mv objects.jsonl objects.jsonl.old
                      cd backup-objects/
                      gunzip -ck 2022-10-29_19-47_objects.jsonl.gz > /opt/iobroker/iobroker-data/objects.jsonl
                      iobroker start
                      EDIT
                        @nftvirus
                        iobroker stop
                        cd backup-objects/
                        iobroker start
                        EDIT
                        N Offline
                        N Offline
                        NFTVirus
                        @glasfaser da bekomme ich wieder einen Fehler:
                        pi@raspberrypi:/opt/iobroker/iobroker-data $ iobroker stop
                        pi@raspberrypi:/opt/iobroker/iobroker-data $ cd /opt/iobroker/iobroker-data/
                        pi@raspberrypi:/opt/iobroker/iobroker-data $ mv objects.json objects.jsonl.old
                        mv: cannot stat 'objects.json': No such file or directory
                        • N NFTVirus
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @nftvirus
                          ja habe EDIT gemacht .... siehe oben
                            @nftvirus
                            N Offline
                            N Offline
                            NFTVirus
                            @glasfaser Hey super VIELEN DANK!!! Es läuft wieder hat mir wirklich super geholfen.
                            • N NFTVirus
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @nftvirus
                              Kein Thema ...
                              dann setze den Thread auf [gelöst]
                                @nftvirus
                                Kein Thema ...
                                maxpd
                                schrieb am zuletzt editiert von maxpd
                                @glasfaser Ich halte das Thema mal am Leben.
                                Ich bekomme auch die gleiche Fehlermeldung. Mit iobroker start wechselt die Meldung dann zu
                                sudo iobroker start
                                sudo iobroker status
                                Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                Wenn ich die Objects Backup Datei nutzen will kommt diese Meldung
                                sudo iobroker stop
                                /opt/iobroker/iobroker-data $ mv objects.jsonl objects.jsonl.old
                                /opt/iobroker/iobroker-data $ cd backup-objects/
                                /opt/iobroker/iobroker-data/backup-objects $ gunzip -ck 2023-05-28_07-41_objects.jsonl.gz > /opt/iobroker/iobroker-data/objects.jsonl
                                gzip: stdout: No space left on device
                                Dabei liegt iobroker auf einer 120gb SSD
                                Wenn ich die Files über WinSCP ersetzen will:
                                mit filezilla:
                                Fehler: error while writing: received failure with description 'Failure'
                                Fehler: Dateiübertragung fehlgeschlagen
                                maxpd
                                Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                • M maxpd
                                  sudo iobroker start
                                  sudo iobroker stop
                                  mit filezilla:
                                  @maxpd sagte in Can not start inMem-objects on port 9001:
                                  sudo iobroker stop
                                  iobroker wird nie mit sudo angepackt. Nie.
                                  iob stop
                                  iob fix
                                  iob start
                                  iob diag
                                  sagt nach der Aktion?
                                  • M maxpd
                                    sudo iobroker start
                                    sudo iobroker stop
                                    mit filezilla:
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @maxpd
                                    Bitte nicht den Beitrag editieren !!
                                    Mach bitte das was @Thomas-Braun schreibt ...
                                      sudo iobroker stop
                                      iob stop
                                      iob fix
                                      iob start
                                      iob diag
                                      maxpd
                                      Das Ergebnis während iob fix
                                      pi@iobroker:~ $ iob fix
                                      library: loaded
                                      Library version=2022-12-09
                                          Welcome to the ioBroker installation fixer!
                                          Script version: 2023-04-02
                                          You might need to enter your password a couple of times.
                                          Installing prerequisites (1/5)
                                      Holen:1 http://archive.raspberrypi.org/debian bullseye InRelease [23,6 kB]
                                      Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                                      Fehl:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Fehler beim Schreiben in Datei - write (28: Auf dem Gerät ist kein Speicherplatz mehr verfügbar) [IP: 93.93.135.141 80]
                                      Fehl:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        Fehler beim Schreiben in Datei - write (28: Auf dem Gerät ist kein Speicherplatz mehr verfügbar) [IP: 93.93.128.193 80]
                                      OK:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                                      Fehl:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                                        Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
                                      OK:4 https://www.pivccu.de/piVCCU stable InRelease
                                      Fehl:4 https://www.pivccu.de/piVCCU stable InRelease
                                        Splitting up /var/lib/apt/lists/www.pivccu.de_piVCCU_dists_stable_InRelease into data and signature failed
                                      W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://deb.nodesource.com/node_18.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
                                      W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://www.pivccu.de/piVCCU stable InRelease: Splitting up /var/lib/apt/lists/www.pivccu.de_piVCCU_dists_stable_InRelease into data and signature failed
                                      W: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/dists/bullseye/InRelease Fehler beim Schreiben in Datei - write (28: Auf dem Gerät ist kein Speicherplatz mehr verfügbar) [IP: 93.93.128.193 80]
                                      W: Fehlschlag beim Holen von https://deb.nodesource.com/node_18.x/dists/bullseye/InRelease Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease into data and signature failed
                                      W: Fehlschlag beim Holen von https://www.pivccu.de/piVCCU/dists/stable/InRelease Splitting up /var/lib/apt/lists/www.pivccu.de_piVCCU_dists_stable_InRelease into data and signature failed
                                      W: Fehlschlag beim Holen von http://archive.raspberrypi.org/debian/dists/bullseye/InRelease Fehler beim Schreiben in Datei - write (28: Auf dem Gerät ist kein Speicherplatz mehr verfügbar) [IP: 93.93.135.141 80]
                                      W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                      Installed gcc-c++
                                          Checking ioBroker user and directory permissions (2/5)
                                      main: Zeile 697: echo: Schreibfehler: Auf dem Gerät ist kein Speicherplatz mehr verfügbar.
                                          Check and cleanup npm temporary directories (3/5)
                                      Done.
                                          Database maintenance (4/5)
                                      Checking for uncompressed JSONL databases... This might take a while!
                                      npm ERR! code ENOSPC
                                      npm ERR! syscall write
                                      npm ERR! errno -28
                                      npm ERR! nospc ENOSPC: no space left on device, write
                                      npm ERR! nospc There appears to be insufficient space on your system to finish.
                                      npm ERR! nospc Clear up some disk space and try again.
                                      npm ERR!     /home/iobroker/.npm/_logs/2023-05-28T19_43_04_574Z-debug-0.log
                                      main: Zeile 12: [: -lt: Einstelliger (unärer) Operator erwartet.
                                      npm ERR! errno -28
                                      npm ERR!     /home/iobroker/.npm/_logs/2023-05-28T19_43_06_239Z-debug-0.log
                                          Checking autostart (5/5)
                                      Enabling autostart...
                                      Autostart enabled!
                                          Your installation was fixed successfully
                                          Run iobroker start to start ioBroker again!
                                      und
                                      pi@iobroker:~ $ iob diag
                                      pi@iobroker:~ $
                                      maxpd
                                        @maxpd
                                        maxpd
                                        @glasfaser hat sich überschnitten
                                        maxpd
                                        • M maxpd
                                          @maxpd
                                          Das Dateisystem ist entweder rappeldicht oder wegen Fehlern nur lesend eingehängt.
                                          df -h
                                          dmesg -T | grep -i EXT4
                                          sagt?
