  4. ioBroker startet nach Stromausfall nicht
    5.6k
21 Beiträge 3 Kommentatoren 2.3k Aufrufe 2 Beobachtet
    @schandy sagte in ioBroker startet nach Stromausfall nicht:
    Karte voll warum auch immer... bisschen aufgeräumt
    Was soll das genau heißen?
    Wo waren die dicken Hunde und warum?
    Was hast du da gelöscht?
    SchAndy
    nach dem eintragen und reboot kommt nur noch das im journal:
    Nov 04 11:16:04 ioBrokerRaspi systemd[3433]: iobroker.service: Failed at step EXEC spawning /usr/bin/bash: No such file or directory
    Nov 04 11:16:04 ioBrokerRaspi systemd[3433]: iobroker.service: Failed to execute command: No such file or directory
    Nov 04 11:16:04 ioBrokerRaspi systemd[1]: Started ioBroker Server.
    Nov 04 11:16:04 ioBrokerRaspi systemd[1]: Stopped ioBroker Server.
    Nov 04 11:16:04 ioBrokerRaspi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 42.
    Nov 04 11:16:04 ioBrokerRaspi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
    Nov 04 11:16:01 ioBrokerRaspi systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Nov 04 11:16:01 ioBrokerRaspi systemd[1]: iobroker.service: Main process exited, code=exited, status=203/EXEC
    Nov 04 11:16:01 ioBrokerRaspi systemd[3388]: iobroker.service: Failed at step EXEC spawning /usr/bin/bash: No such file or directory
    Nov 04 11:16:01 ioBrokerRaspi systemd[3388]: iobroker.service: Failed to execute command: No such file or directory
    Nov 04 11:16:01 ioBrokerRaspi systemd[1]: Started ioBroker Server.
    Nov 04 11:16:01 ioBrokerRaspi systemd[1]: Stopped ioBroker Server.
    Nov 04 11:16:01 ioBrokerRaspi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 41.
    Nov 04 11:16:01 ioBrokerRaspi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
    Nov 04 11:15:58 ioBrokerRaspi systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Nov 04 11:15:58 ioBrokerRaspi systemd[1]: iobroker.service: Main process exited, code=exited, status=203/EXEC
    Nov 04 11:15:58 ioBrokerRaspi systemd[3373]: iobroker.service: Failed at step EXEC spawning /usr/bin/bash: No such file or directory
    Nov 04 11:15:58 ioBrokerRaspi systemd[3373]: iobroker.service: Failed to execute command: No such file or directory
    gelöscht habe ich Ordner im Download Verzeichnis, was ich irgendwann mal als temp. Verzeichnis dahin kopiert habe. Also nichts aus dem System selber.
    • S SchAndy
      /usr/bin/bash
      Schlecht wenn es die nicht geben sollte...
      ls -la /usr/bin/bash
      sagt?
        /usr/bin/bash
        sagt?
        SchAndy
        pi@ioBrokerRaspi:~ $ ls -la /usr/bin/bash
        ls: Zugriff auf '/usr/bin/bash' nicht möglich: Datei oder Verzeichnis nicht gefunden
        Aber warum ist das plötzlich so...?
        • S SchAndy
          Das weiß ich nicht. Hab ja dein System nicht 'aufgeräumt' oder hart vom Strom genommen...
          Mach es neu, da wirst du vermutlich vom Hölzchen aufs Stöckchen kommen, wenn du das restaurieren willst. Wer weiß wo es da überall Baustellen gibt.
          Neues Installationsmedium würde ich auch empfehlen, falles es eine SD-Karte sein sollte.
          • S SchAndy
            @schandy
            dmesg -T | grep -i ext4
            sagt?
              @schandy
              sagt?
              SchAndy
              @thomas-braun sagte in ioBroker startet nach Stromausfall nicht:
              pi@ioBrokerRaspi:/opt/iobroker $ dmesg -T | grep -i ext4
              [Fr Nov  4 11:13:40 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:7F:2C:98 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Fr Nov  4 11:13:41 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Fr Nov  4 11:13:41 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Fr Nov  4 11:13:43 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              • S SchAndy
                @schandy
                Das ist okay. Hatte vermutet da stünde anderes drin.
                Aber offenbar ist da doch irgendwas kaputt.
                  @schandy
                  SchAndy
                  schrieb am zuletzt editiert von SchAndy
                  @thomas-braun mh..
                  Komisch halt, dass es erst so ist, nachdem ich iobroker fix ausgeführt habe.. vorher lief der iobroker noch... Und jetzt ist er kaputt.
                  Neues System aufsetzen wird warten müssen. Dafür brauche ich Zeit, weil dann muss ich auch mein Homematic im docker neu aufsetzen..
                  • S SchAndy
                    @thomas-braun mh..
                    Der fixer macht aber den ioBroker nicht kaputt. Im Gegenteil.
                      SchAndy
                      Mag sein, ich kann nur sagen wie es war. Ich habe sonst keine System Daten gelöscht. Evtl konnte der fixer ja irgendwas nicht auf die Karte schreiben weiß der Geier..
                      • S SchAndy
                        möglich, wenn
                        nach Stromausfall
                        das Dateisystem zerschossen war
                          möglich, wenn
                          nach Stromausfall
                          SchAndy
                          ich habe jetzt mal iobroker neu installiert nochmal einfach so. Alte daten umbenannt in iobroker_
                          dann installiert. Restore, läuft.. warum auch immer
                          • S SchAndy
                            SchAndy
                            Kann ich dann wohl den alten Ordner mit dem namen iobroker_ löschen?
