  4. Test Adapter mihome-vacuum 3.8.x
    6.6k
129 Beiträge 19 Kommentatoren 25.6k Aufrufe 20 Beobachtet
    @da_woody sagte in Test für mihome-vacuum:
    startet das ding nicht mehr.
    Und was steht im Log?
    da_WoodyD Offline
    da_WoodyD Offline
    v6.2.23
    38
    Log-Größe: 58.2 KB
    mihome-vacuum.0
    Zeit
    debug
    Nachricht
    mihome-vacuum.0
    2022-11-01 14:14:39.756	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":174}
    mihome-vacuum.0
    2022-11-01 14:14:39.747	debug	Message= {"id":174,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:14:39.746	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:14:39.746	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":173}
    mihome-vacuum.0
    2022-11-01 14:14:39.742	debug	Message= {"id":173,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:14:39.742	debug	MIIO RECIVE: {"result":[90],"id":172}
    mihome-vacuum.0
    2022-11-01 14:14:39.732	debug	Message= {"id":172,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:14:39.615	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":171}
    mihome-vacuum.0
    2022-11-01 14:14:39.593	debug	Message= {"id":171,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:14:39.592	debug	setGetStatus {"msg_ver":2,"msg_seq":1784,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:14:39.592	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1784,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":170}
    mihome-vacuum.0
    2022-11-01 14:14:39.586	debug	Message= {"id":170,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:14:39.585	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:14:34.810	debug	Receive <<< Helo <<< 21310020000000001329b53563611bbaffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:14:24.807	debug	Receive <<< Helo <<< 21310020000000001329b53563611bb0ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:14:19.490	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":169}
    mihome-vacuum.0
    2022-11-01 14:14:19.479	debug	Message= {"id":169,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:14:19.479	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:14:19.479	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F17"],"id":168}
    mihome-vacuum.0
    2022-11-01 14:14:19.473	debug	Message= {"id":168,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:14:19.473	debug	MIIO RECIVE: {"result":[90],"id":167}
    mihome-vacuum.0
    2022-11-01 14:14:19.464	debug	Message= {"id":167,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:14:19.346	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":166}
    mihome-vacuum.0
    2022-11-01 14:14:19.324	debug	Message= {"id":166,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:14:19.324	debug	setGetStatus {"msg_ver":2,"msg_seq":1783,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:14:19.323	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1783,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":165}
    mihome-vacuum.0
    2022-11-01 14:14:19.317	debug	Message= {"id":165,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:14:19.317	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:14:14.803	debug	Receive <<< Helo <<< 21310020000000001329b53563611ba6ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:14:04.800	debug	Receive <<< Helo <<< 21310020000000001329b53563611b9cffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:13:59.198	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":164}
    mihome-vacuum.0
    2022-11-01 14:13:59.186	debug	Message= {"id":164,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:13:59.185	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:13:59.184	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F16"],"id":163}
    mihome-vacuum.0
    2022-11-01 14:13:59.177	debug	Message= {"id":163,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:13:59.177	debug	MIIO RECIVE: {"result":[90],"id":162}
    mihome-vacuum.0
    2022-11-01 14:13:59.172	debug	Message= {"id":162,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:13:59.070	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":161}
    mihome-vacuum.0
    2022-11-01 14:13:59.049	debug	Message= {"id":161,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:13:59.048	debug	setGetStatus {"msg_ver":2,"msg_seq":1782,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:13:59.048	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1782,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":160}
    mihome-vacuum.0
    2022-11-01 14:13:59.042	debug	Message= {"id":160,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:13:59.042	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:13:54.792	debug	Receive <<< Helo <<< 21310020000000001329b53563611b92ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:13:44.789	debug	Receive <<< Helo <<< 21310020000000001329b53563611b88ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:13:38.948	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":159}
    mihome-vacuum.0
    2022-11-01 14:13:38.938	debug	Message= {"id":159,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:13:38.938	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:13:38.937	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F15"],"id":158}
    mihome-vacuum.0
    2022-11-01 14:13:38.933	debug	Message= {"id":158,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:13:38.933	debug	MIIO RECIVE: {"result":[90],"id":157}
    mihome-vacuum.0
    2022-11-01 14:13:38.928	debug	Message= {"id":157,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:13:38.833	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":156}
    mihome-vacuum.0
    2022-11-01 14:13:38.812	debug	Message= {"id":156,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:13:38.812	debug	setGetStatus {"msg_ver":2,"msg_seq":1781,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:13:38.811	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1781,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":155}
    mihome-vacuum.0
    2022-11-01 14:13:38.805	debug	Message= {"id":155,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:13:38.805	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:13:34.786	debug	Receive <<< Helo <<< 21310020000000001329b53563611b7effffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:13:24.782	debug	Receive <<< Helo <<< 21310020000000001329b53563611b74ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:13:18.608	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":154}
    mihome-vacuum.0
    2022-11-01 14:13:18.598	debug	Message= {"id":154,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:13:18.598	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:13:18.598	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F14"],"id":153}
    mihome-vacuum.0
    2022-11-01 14:13:18.593	debug	Message= {"id":153,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:13:18.592	debug	MIIO RECIVE: {"result":[90],"id":152}
    mihome-vacuum.0
    2022-11-01 14:13:18.587	debug	Message= {"id":152,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:13:18.477	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":151}
    mihome-vacuum.0
    2022-11-01 14:13:18.455	debug	Message= {"id":151,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:13:18.455	debug	setGetStatus {"msg_ver":2,"msg_seq":1780,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:13:18.455	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1780,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":150}
    mihome-vacuum.0
    2022-11-01 14:13:18.449	debug	Message= {"id":150,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:13:18.448	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:13:14.779	debug	Receive <<< Helo <<< 21310020000000001329b53563611b6affffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:13:04.776	debug	Receive <<< Helo <<< 21310020000000001329b53563611b60ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:12:58.345	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":149}
    mihome-vacuum.0
    2022-11-01 14:12:58.334	debug	Message= {"id":149,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:12:58.334	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:12:58.334	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F13"],"id":148}
    mihome-vacuum.0
    2022-11-01 14:12:58.328	debug	Message= {"id":148,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:12:58.328	debug	MIIO RECIVE: {"result":[90],"id":147}
    mihome-vacuum.0
    2022-11-01 14:12:58.323	debug	Message= {"id":147,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:12:58.227	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":146}
    mihome-vacuum.0
    2022-11-01 14:12:58.205	debug	Message= {"id":146,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:12:58.205	debug	setGetStatus {"msg_ver":2,"msg_seq":1779,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:12:58.205	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1779,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":145}
    mihome-vacuum.0
    2022-11-01 14:12:58.196	debug	Message= {"id":145,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:12:58.196	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:12:54.773	debug	Receive <<< Helo <<< 21310020000000001329b53563611b56ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:12:44.768	debug	Receive <<< Helo <<< 21310020000000001329b53563611b4cffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:12:37.758	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":144}
    mihome-vacuum.0
    2022-11-01 14:12:37.749	debug	Message= {"id":144,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:12:37.749	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:12:37.749	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F12"],"id":143}
    mihome-vacuum.0
    2022-11-01 14:12:37.745	debug	Message= {"id":143,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:12:37.744	debug	MIIO RECIVE: {"result":[90],"id":142}
    mihome-vacuum.0
    2022-11-01 14:12:37.739	debug	Message= {"id":142,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:12:35.361	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":141}
    mihome-vacuum.0
    2022-11-01 14:12:35.337	debug	Message= {"id":141,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:12:35.337	debug	setGetStatus {"msg_ver":2,"msg_seq":1778,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:12:35.336	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1778,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":140}
    mihome-vacuum.0
    2022-11-01 14:12:35.329	debug	Message= {"id":140,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:12:35.329	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:12:34.765	debug	Receive <<< Helo <<< 21310020000000001329b53563611b42ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:12:24.754	debug	Receive <<< Helo <<< 21310020000000001329b53563611b38ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:12:15.197	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":139}
    mihome-vacuum.0
    2022-11-01 14:12:15.185	debug	Message= {"id":139,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:12:15.184	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:12:15.183	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F11"],"id":138}
    mihome-vacuum.0
    2022-11-01 14:12:15.178	debug	Message= {"id":138,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:12:15.178	debug	MIIO RECIVE: {"result":[90],"id":137}
    mihome-vacuum.0
    2022-11-01 14:12:15.173	debug	Message= {"id":137,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:12:15.080	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":136}
    mihome-vacuum.0
    2022-11-01 14:12:15.059	debug	Message= {"id":136,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:12:15.058	debug	setGetStatus {"msg_ver":2,"msg_seq":1777,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:12:15.058	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1777,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":135}
    mihome-vacuum.0
    2022-11-01 14:12:15.052	debug	Message= {"id":135,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:12:15.052	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:12:14.751	debug	Receive <<< Helo <<< 21310020000000001329b53563611b2effffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:12:04.744	debug	Receive <<< Helo <<< 21310020000000001329b53563611b24ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:11:54.945	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":134}
    mihome-vacuum.0
    2022-11-01 14:11:54.937	debug	Message= {"id":134,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:11:54.937	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:11:54.936	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F10"],"id":133}
    mihome-vacuum.0
    2022-11-01 14:11:54.931	debug	Message= {"id":133,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:11:54.931	debug	MIIO RECIVE: {"result":[90],"id":132}
    mihome-vacuum.0
    2022-11-01 14:11:54.923	debug	Message= {"id":132,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:11:54.765	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":131}
    mihome-vacuum.0
    2022-11-01 14:11:54.744	debug	Message= {"id":131,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:11:54.743	debug	setGetStatus {"msg_ver":2,"msg_seq":1776,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:11:54.743	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1776,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":130}
    mihome-vacuum.0
    2022-11-01 14:11:54.741	debug	Receive <<< Helo <<< 21310020000000001329b53563611b1affffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:11:54.737	debug	Message= {"id":130,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:11:54.737	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:11:44.737	debug	Receive <<< Helo <<< 21310020000000001329b53563611b10ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:11:34.734	debug	Receive <<< Helo <<< 21310020000000001329b53563611b06ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:11:34.643	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":129}
    mihome-vacuum.0
    2022-11-01 14:11:34.635	debug	Message= {"id":129,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:11:34.635	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:11:34.634	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F9"],"id":128}
    mihome-vacuum.0
    2022-11-01 14:11:34.630	debug	Message= {"id":128,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:11:34.630	debug	MIIO RECIVE: {"result":[90],"id":127}
    mihome-vacuum.0
    2022-11-01 14:11:34.624	debug	Message= {"id":127,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:11:34.513	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":126}
    mihome-vacuum.0
    2022-11-01 14:11:34.492	debug	Message= {"id":126,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:11:34.492	debug	setGetStatus {"msg_ver":2,"msg_seq":1775,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:11:34.492	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1775,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":125}
    mihome-vacuum.0
    2022-11-01 14:11:34.481	debug	Message= {"id":125,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:11:34.481	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:11:24.732	debug	Receive <<< Helo <<< 21310020000000001329b53563611afcffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:11:14.729	debug	Receive <<< Helo <<< 21310020000000001329b53563611af2ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:11:14.422	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":124}
    mihome-vacuum.0
    2022-11-01 14:11:14.415	debug	Message= {"id":124,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:11:14.414	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:11:14.414	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F8"],"id":123}
    mihome-vacuum.0
    2022-11-01 14:11:14.410	debug	Message= {"id":123,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:11:14.410	debug	MIIO RECIVE: {"result":[90],"id":122}
    mihome-vacuum.0
    2022-11-01 14:11:14.404	debug	Message= {"id":122,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:11:14.316	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":121}
    mihome-vacuum.0
    2022-11-01 14:11:14.293	debug	Message= {"id":121,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:11:14.293	debug	setGetStatus {"msg_ver":2,"msg_seq":1774,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:11:14.293	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1774,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":120}
    mihome-vacuum.0
    2022-11-01 14:11:14.281	debug	Message= {"id":120,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:11:14.281	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:11:04.724	debug	Receive <<< Helo <<< 21310020000000001329b53563611ae8ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:10:54.720	debug	Receive <<< Helo <<< 21310020000000001329b53563611adeffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:10:54.187	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":119}
    mihome-vacuum.0
    2022-11-01 14:10:54.177	debug	Message= {"id":119,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:10:54.177	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:10:54.176	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F7"],"id":118}
    mihome-vacuum.0
    2022-11-01 14:10:54.172	debug	Message= {"id":118,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:10:54.172	debug	MIIO RECIVE: {"result":[90],"id":117}
    mihome-vacuum.0
    2022-11-01 14:10:54.167	debug	Message= {"id":117,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:10:54.053	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":116}
    mihome-vacuum.0
    2022-11-01 14:10:54.028	debug	Message= {"id":116,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:10:54.028	debug	setGetStatus {"msg_ver":2,"msg_seq":1773,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:10:54.027	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1773,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":115}
    mihome-vacuum.0
    2022-11-01 14:10:54.021	debug	Message= {"id":115,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:10:54.021	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:10:44.714	debug	Receive <<< Helo <<< 21310020000000001329b53563611ad4ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:10:34.706	debug	Receive <<< Helo <<< 21310020000000001329b53563611acaffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:10:33.868	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":114}
    mihome-vacuum.0
    2022-11-01 14:10:33.861	debug	Message= {"id":114,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:10:33.861	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:10:33.861	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F6"],"id":113}
    mihome-vacuum.0
    2022-11-01 14:10:33.855	debug	Message= {"id":113,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:10:33.854	debug	MIIO RECIVE: {"result":[90],"id":112}
    mihome-vacuum.0
    2022-11-01 14:10:33.848	debug	Message= {"id":112,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:10:33.683	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":111}
    mihome-vacuum.0
    2022-11-01 14:10:33.661	debug	Message= {"id":111,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:10:33.661	debug	setGetStatus {"msg_ver":2,"msg_seq":1772,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:10:33.660	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1772,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":110}
    mihome-vacuum.0
    2022-11-01 14:10:33.654	debug	Message= {"id":110,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:10:33.654	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:10:24.702	debug	Receive <<< Helo <<< 21310020000000001329b53563611ac0ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:10:14.697	debug	Receive <<< Helo <<< 21310020000000001329b53563611ab6ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:10:13.551	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":109}
    mihome-vacuum.0
    2022-11-01 14:10:13.545	debug	Message= {"id":109,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:10:13.543	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:10:13.542	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F5"],"id":108}
    mihome-vacuum.0
    2022-11-01 14:10:13.537	debug	Message= {"id":108,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:10:13.537	debug	MIIO RECIVE: {"result":[90],"id":107}
    mihome-vacuum.0
    2022-11-01 14:10:13.532	debug	Message= {"id":107,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:10:13.418	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":106}
    mihome-vacuum.0
    2022-11-01 14:10:13.396	debug	Message= {"id":106,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:10:13.395	debug	setGetStatus {"msg_ver":2,"msg_seq":1771,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:10:13.395	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1771,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":105}
    mihome-vacuum.0
    2022-11-01 14:10:13.384	debug	Message= {"id":105,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:10:13.384	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:10:04.693	debug	Receive <<< Helo <<< 21310020000000001329b53563611aacffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:09:54.690	debug	Receive <<< Helo <<< 21310020000000001329b53563611aa2ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:09:53.241	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":104}
    mihome-vacuum.0
    2022-11-01 14:09:53.234	debug	Message= {"id":104,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:09:53.234	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:09:53.234	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F4"],"id":103}
    mihome-vacuum.0
    2022-11-01 14:09:53.229	debug	Message= {"id":103,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:09:53.229	debug	MIIO RECIVE: {"result":[90],"id":102}
    mihome-vacuum.0
    2022-11-01 14:09:53.220	debug	Message= {"id":102,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:09:53.114	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":101}
    mihome-vacuum.0
    2022-11-01 14:09:53.093	debug	Message= {"id":101,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:09:53.093	debug	setGetStatus {"msg_ver":2,"msg_seq":1770,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:09:53.092	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1770,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":100}
    mihome-vacuum.0
    2022-11-01 14:09:53.082	debug	Message= {"id":100,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:09:53.082	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:09:44.686	debug	Receive <<< Helo <<< 21310020000000001329b53563611a98ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:09:34.684	debug	Receive <<< Helo <<< 21310020000000001329b53563611a8effffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:09:32.973	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":99}
    mihome-vacuum.0
    2022-11-01 14:09:32.964	debug	Message= {"id":99,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:09:32.964	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:09:32.963	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F3"],"id":98}
    mihome-vacuum.0
    2022-11-01 14:09:32.958	debug	Message= {"id":98,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:09:32.957	debug	MIIO RECIVE: {"result":[90],"id":97}
    mihome-vacuum.0
    2022-11-01 14:09:32.951	debug	Message= {"id":97,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:09:32.854	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":96}
    mihome-vacuum.0
    2022-11-01 14:09:32.831	debug	Message= {"id":96,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:09:32.831	debug	setGetStatus {"msg_ver":2,"msg_seq":1769,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:09:32.831	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1769,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":95}
    mihome-vacuum.0
    2022-11-01 14:09:32.824	debug	Message= {"id":95,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:09:32.824	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:09:24.678	debug	Receive <<< Helo <<< 21310020000000001329b53563611a84ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:09:14.675	debug	Receive <<< Helo <<< 21310020000000001329b53563611a7affffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:09:12.653	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":94}
    mihome-vacuum.0
    2022-11-01 14:09:12.633	debug	Message= {"id":94,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:09:12.632	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:09:12.631	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F2"],"id":93}
    mihome-vacuum.0
    2022-11-01 14:09:12.624	debug	Message= {"id":93,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:09:12.622	debug	MIIO RECIVE: {"result":[90],"id":92}
    mihome-vacuum.0
    2022-11-01 14:09:12.613	debug	Message= {"id":92,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:09:12.514	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":91}
    mihome-vacuum.0
    2022-11-01 14:09:12.491	debug	Message= {"id":91,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:09:12.491	debug	setGetStatus {"msg_ver":2,"msg_seq":1768,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:09:12.491	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1768,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":90}
    mihome-vacuum.0
    2022-11-01 14:09:12.485	debug	Message= {"id":90,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:09:12.484	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:09:04.672	debug	Receive <<< Helo <<< 21310020000000001329b53563611a70ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:08:54.669	debug	Receive <<< Helo <<< 21310020000000001329b53563611a66ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:08:52.432	debug	finish logs all [{"Datum":"28.10","Start":"19:57","Saugzeit":"32 min","Fläche":"22.35 m²","Error":0,"Ende":true},{"Datum":"28.10","Start":"15:18","Saugzeit":"6 min","Fläche":"5.87 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:16","Saugzeit":"2 min","Fläche":"0 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:10","Saugzeit":"5 min","Fläche":"2.22 m²","Error":0,"Ende":false},{"Datum":"13.9","Start":"19:42","Saugzeit":"30 min","Fläche":"24.64 m²","Error":0,"Ende":true},{"Datum":"6.9","Start":"15:18","Saugzeit":"6 min","Fläche":"2 m²","Error":8,"Ende":false},{"Datum":"30.7","Start":"20:43","Saugzeit":"41 min","Fläche":"24.05 m²","Error":0,"Ende":true},{"Datum":"1.7","Start":"16:20","Saugzeit":"22 min","Fläche":"22.3 m²","Error":0,"Ende":true},{"Datum":"9.6","Start":"19:18","Saugzeit":"24 min","Fläche":"24.63 m²","Error":0,"Ende":true},{"Datum":"30.5","Start":"19:26","Saugzeit":"28 min","Fläche":"24.72 m²","Error":0,"Ende":true},{"Datum":"10.5","Start":"15:09","Saugzeit":"25 min","Fläche":"24.65 m²","Error":0,"Ende":true},{"Datum":"6.5","Start":"19:24","Saugzeit":"26 min","Fläche":"24.11 m²","Error":0,"Ende":true},{"Datum":"29.4","Start":"19:33","Saugzeit":"36 min","Fläche":"23.96 m²","Error":0,"Ende":true},{"Datum":"19.2","Start":"19:32","Saugzeit":"1 min","Fläche":"0.51 m²","Error":0,"Ende":false},{"Datum":"23.1","Start":"19:44","Saugzeit":"29 min","Fläche":"25.02 m²","Error":0,"Ende":true},{"Datum":"22.1","Start":"20:13","Saugzeit":"10 min","Fläche":"12.37 m²","Error":0,"Ende":false},{"Datum":"21.1","Start":"10:22","Saugzeit":"1 min","Fläche":"1.29 m²","Error":0,"Ende":false},{"Datum":"18.1","Start":"20:20","Saugzeit":"27 min","Fläche":"24.17 m²","Error":0,"Ende":true},{"Datum":"6.1","Start":"19:10","Saugzeit":"12 min","Fläche":"14.82 m²","Error":0,"Ende":false},{"Datum":"6.1","Start":"15:36","Saugzeit":"32 min","Fläche":"24.57 m²","Error":0,"Ende":true}]
    mihome-vacuum.0
    2022-11-01 14:08:52.432	debug	MIIO RECIVE: {"result":[[1641479793,1641486963,1910,24567500,0,1,2,1,52]],"id":89}
    mihome-vacuum.0
    2022-11-01 14:08:52.423	debug	Message= {"id":89,"method":"get_clean_record","params":[1641479793]}
    mihome-vacuum.0
    2022-11-01 14:08:52.422	debug	MIIO RECIVE: {"result":[[1641492626,1641493350,696,14817500,0,0,2,1,60]],"id":88}
    mihome-vacuum.0
    2022-11-01 14:08:52.413	debug	Message= {"id":88,"method":"get_clean_record","params":[1641492626]}
    mihome-vacuum.0
    2022-11-01 14:08:52.412	debug	MIIO RECIVE: {"result":[[1642533653,1642535288,1625,24167500,0,1,2,1,52]],"id":87}
    mihome-vacuum.0
    2022-11-01 14:08:52.403	debug	Message= {"id":87,"method":"get_clean_record","params":[1642533653]}
    mihome-vacuum.0
    2022-11-01 14:08:52.402	debug	MIIO RECIVE: {"result":[[1642756938,1642756995,57,1292500,0,0,2,1,60]],"id":86}
    mihome-vacuum.0
    2022-11-01 14:08:52.396	debug	Message= {"id":86,"method":"get_clean_record","params":[1642756938]}
    mihome-vacuum.0
    2022-11-01 14:08:52.396	debug	MIIO RECIVE: {"result":[[1642878816,1642879423,607,12367500,0,0,2,1,60]],"id":85}
    mihome-vacuum.0
    2022-11-01 14:08:52.389	debug	Message= {"id":85,"method":"get_clean_record","params":[1642878816]}
    mihome-vacuum.0
    2022-11-01 14:08:52.387	debug	MIIO RECIVE: {"result":[[1642963476,1642965232,1756,25020000,0,1,2,1,52]],"id":84}
    mihome-vacuum.0
    2022-11-01 14:08:52.373	debug	Message= {"id":84,"method":"get_clean_record","params":[1642963476]}
    mihome-vacuum.0
    2022-11-01 14:08:52.372	debug	MIIO RECIVE: {"result":[[1645295524,1645295556,32,512500,0,0,2,1,60]],"id":83}
    mihome-vacuum.0
    2022-11-01 14:08:52.366	debug	Message= {"id":83,"method":"get_clean_record","params":[1645295524]}
    mihome-vacuum.0
    2022-11-01 14:08:52.364	debug	MIIO RECIVE: {"result":[[1651253588,1651255767,2179,23957500,0,1,2,1,52]],"id":82}
    mihome-vacuum.0
    2022-11-01 14:08:52.358	debug	Message= {"id":82,"method":"get_clean_record","params":[1651253588]}
    mihome-vacuum.0
    2022-11-01 14:08:52.358	debug	MIIO RECIVE: {"result":[[1651857884,1651859471,1587,24110000,0,1,2,1,52]],"id":81}
    mihome-vacuum.0
    2022-11-01 14:08:52.353	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":80}
    mihome-vacuum.0
    2022-11-01 14:08:52.352	debug	Message= {"id":81,"method":"get_clean_record","params":[1651857884]}
    mihome-vacuum.0
    2022-11-01 14:08:52.352	debug	MIIO RECIVE: {"result":[[1652188174,1652189692,1518,24647500,0,1,2,1,52]],"id":79}
    mihome-vacuum.0
    2022-11-01 14:08:52.336	debug	Message= {"id":80,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:08:52.335	info	create state for carpet_mode
    mihome-vacuum.0
    2022-11-01 14:08:52.335	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":78}
    mihome-vacuum.0
    2022-11-01 14:08:52.334	debug	Message= {"id":79,"method":"get_clean_record","params":[1652188174]}
    mihome-vacuum.0
    2022-11-01 14:08:52.332	debug	MIIO RECIVE: {"result":[[1653931567,1653933520,1684,24717500,0,1,2,1,52]],"id":77}
    mihome-vacuum.0
    2022-11-01 14:08:52.327	debug	Message= {"id":78,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2022-11-01 14:08:52.326	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:08:52.326	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":76}
    mihome-vacuum.0
    2022-11-01 14:08:52.325	debug	Message= {"id":77,"method":"get_clean_record","params":[1653931567]}
    mihome-vacuum.0
    2022-11-01 14:08:52.324	debug	MIIO RECIVE: {"result":[[1654795117,1654796567,1450,24625000,0,1,2,1,52]],"id":75}
    mihome-vacuum.0
    2022-11-01 14:08:52.319	debug	Message= {"id":76,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:08:52.319	debug	Startup: Delete setGetConsumable
    mihome-vacuum.0
    2022-11-01 14:08:52.319	debug	Startup: setGetConsumable Answer: true
    mihome-vacuum.0
    2022-11-01 14:08:52.318	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":41889,"side_brush_work_time":41889,"filter_work_time":41889,"filter_element_work_time":0,"sensor_dirty_time":71089}],"id":74}
    mihome-vacuum.0
    2022-11-01 14:08:52.317	debug	Message= {"id":75,"method":"get_clean_record","params":[1654795117]}
    mihome-vacuum.0
    2022-11-01 14:08:52.310	debug	MIIO RECIVE: {"result":[[1656685244,1656686572,1328,22302500,0,1,2,1,52]],"id":73}
    mihome-vacuum.0
    2022-11-01 14:08:52.305	debug	Message= {"id":74,"method":"get_consumable"}
    mihome-vacuum.0
    2022-11-01 14:08:52.305	debug	Startup: Delete setGetCleanSummary
    mihome-vacuum.0
    2022-11-01 14:08:52.305	debug	Startup: setGetCleanSummary Answer: true
    mihome-vacuum.0
    2022-11-01 14:08:52.304	debug	MIIO RECIVE: {"result":[76749,992120000,76,[1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816,1642756938,1642533653,1641492626,1641479793]],"id":72}
    mihome-vacuum.0
    2022-11-01 14:08:52.303	debug	Message= {"id":73,"method":"get_clean_record","params":[1656685244]}
    mihome-vacuum.0
    2022-11-01 14:08:52.302	debug	MIIO RECIVE: {"result":[[1659206624,1659209105,2481,24045000,0,1,2,1,52]],"id":71}
    mihome-vacuum.0
    2022-11-01 14:08:52.297	debug	Message= {"id":72,"method":"get_clean_summary"}
    mihome-vacuum.0
    2022-11-01 14:08:52.297	debug	MIIO RECIVE: {"result":[90],"id":70}
    mihome-vacuum.0
    2022-11-01 14:08:52.296	debug	Message= {"id":71,"method":"get_clean_record","params":[1659206624]}
    mihome-vacuum.0
    2022-11-01 14:08:52.296	debug	MIIO RECIVE: {"result":[[1662470282,1662514759,383,2000000,8,0,2,1,34]],"id":69}
    mihome-vacuum.0
    2022-11-01 14:08:52.291	debug	Message= {"id":70,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:08:52.289	debug	Message= {"id":69,"method":"get_clean_record","params":[1662470282]}
    mihome-vacuum.0
    2022-11-01 14:08:52.289	debug	MIIO RECIVE: {"result":[[1663090972,1663093345,1773,24642500,0,1,2,1,52]],"id":68}
    mihome-vacuum.0
    2022-11-01 14:08:52.276	debug	Message= {"id":68,"method":"get_clean_record","params":[1663090972]}
    mihome-vacuum.0
    2022-11-01 14:08:52.276	debug	MIIO RECIVE: {"result":[[1666865404,1666865708,302,2215000,0,0,2,1,60]],"id":67}
    mihome-vacuum.0
    2022-11-01 14:08:52.254	debug	Message= {"id":67,"method":"get_clean_record","params":[1666865404]}
    mihome-vacuum.0
    2022-11-01 14:08:52.254	debug	MIIO RECIVE: {"result":[[1666865760,1666909702,141,0,8,0,2,1,34]],"id":66}
    mihome-vacuum.0
    2022-11-01 14:08:52.246	debug	Message= {"id":66,"method":"get_clean_record","params":[1666865760]}
    mihome-vacuum.0
    2022-11-01 14:08:52.244	debug	MIIO RECIVE: {"result":[[1666963083,1666979819,385,5867500,8,0,2,1,29]],"id":65}
    mihome-vacuum.0
    2022-11-01 14:08:52.237	debug	Message= {"id":65,"method":"get_clean_record","params":[1666963083]}
    mihome-vacuum.0
    2022-11-01 14:08:52.236	debug	MIIO RECIVE: {"result":[[1666979871,1666981820,1949,22352500,0,1,2,1,52]],"id":64}
    mihome-vacuum.0
    2022-11-01 14:08:52.229	debug	Message= {"id":64,"method":"get_clean_record","params":[1666979871]}
    mihome-vacuum.0
    2022-11-01 14:08:52.226	debug	MIIO RECIVE: {"result":[76749,992120000,76,[1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816,1642756938,1642533653,1641492626,1641479793]],"id":63}
    mihome-vacuum.0
    2022-11-01 14:08:52.223	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":62}
    mihome-vacuum.0
    2022-11-01 14:08:52.206	debug	Message= {"id":63,"method":"get_clean_summary"}
    mihome-vacuum.0
    2022-11-01 14:08:52.205	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":41889,"side_brush_work_time":41889,"filter_work_time":41889,"filter_element_work_time":0,"sensor_dirty_time":71089}],"id":61}
    mihome-vacuum.0
    2022-11-01 14:08:52.199	debug	Message= {"id":62,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:08:52.199	debug	Message= {"id":61,"method":"get_consumable"}
    mihome-vacuum.0
    2022-11-01 14:08:52.199	debug	MIIO RECIVE: {"result":[],"id":60}
    mihome-vacuum.0
    2022-11-01 14:08:52.190	debug	Message= {"id":60,"method":"get_room_mapping"}
    mihome-vacuum.0
    2022-11-01 14:08:52.190	debug	Mappointer_updated
    mihome-vacuum.0
    2022-11-01 14:08:52.189	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":59}
    mihome-vacuum.0
    2022-11-01 14:08:52.180	debug	Message= {"id":59,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:08:51.879	debug	MIIO RECIVE: {"result":["retry"],"id":58}
    mihome-vacuum.0
    2022-11-01 14:08:51.873	debug	Message= {"id":58,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:08:51.572	debug	MIIO RECIVE: {"result":["retry"],"id":57}
    mihome-vacuum.0
    2022-11-01 14:08:51.566	debug	Message= {"id":57,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:08:51.266	debug	MIIO RECIVE: {"result":["retry"],"id":56}
    mihome-vacuum.0
    2022-11-01 14:08:51.260	debug	Message= {"id":56,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:08:51.117	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    mihome-vacuum.0
    2022-11-01 14:08:51.109	info	create states for water box
    mihome-vacuum.0
    2022-11-01 14:08:51.109	info	change states from State control.fan_power
    mihome-vacuum.0
    2022-11-01 14:08:51.107	debug	setGetStatus {"msg_ver":2,"msg_seq":1767,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2022-11-01 14:08:51.107	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1767,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":55}
    mihome-vacuum.0
    2022-11-01 14:08:51.099	debug	Message= {"id":55,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:08:51.099	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:08:44.660	debug	Receive <<< Helo <<< 21310020000000001329b53563611a5cffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:08:34.656	debug	Receive <<< Helo <<< 21310020000000001329b53563611a52ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:08:31.098	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:08:31.097	debug	MIIO Receive Timeout for "get_map_v1" <<<
    mihome-vacuum.0
    2022-11-01 14:08:29.096	debug	Message= {"id":54,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:08:29.096	debug	Startup: setGetConsumable Answer: false
    mihome-vacuum.0
    2022-11-01 14:08:29.096	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:08:29.096	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:08:29.095	debug	MIIO Receive Timeout for "get_consumable" <<<
    mihome-vacuum.0
    2022-11-01 14:08:27.095	debug	Message= {"id":53,"method":"get_consumable"}
    mihome-vacuum.0
    2022-11-01 14:08:27.095	debug	Startup: setGetCleanSummary Answer: false
    mihome-vacuum.0
    2022-11-01 14:08:27.095	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:08:27.094	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:08:27.094	debug	MIIO Receive Timeout for "get_clean_summary" <<<
    mihome-vacuum.0
    2022-11-01 14:08:25.094	debug	Message= {"id":52,"method":"get_clean_summary"}
    mihome-vacuum.0
    2022-11-01 14:08:25.094	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:08:25.094	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:08:25.093	debug	MIIO Receive Timeout for "get_sound_volume" <<<
    mihome-vacuum.0
    2022-11-01 14:08:24.653	debug	Receive <<< Helo <<< 21310020000000001329b53563611a48ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:08:23.092	debug	Message= {"id":51,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:08:23.092	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:08:23.092	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:08:23.092	debug	MIIO Receive Timeout for "get_network_info" <<<
    mihome-vacuum.0
    2022-11-01 14:08:21.090	debug	Message= {"id":50,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:08:21.090	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:08:21.090	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:08:21.090	debug	MIIO Receive Timeout for "get_status" <<<
    mihome-vacuum.0
    2022-11-01 14:08:19.089	debug	Message= {"id":49,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:08:19.089	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:08:14.649	debug	Receive <<< Helo <<< 21310020000000001329b53563611a3effffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:08:04.646	debug	Receive <<< Helo <<< 21310020000000001329b53563611a34ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:07:59.088	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:59.087	debug	MIIO Receive Timeout for "get_map_v1" <<<
    mihome-vacuum.0
    2022-11-01 14:07:57.086	debug	Message= {"id":48,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:07:57.086	debug	Startup: setGetConsumable Answer: false
    mihome-vacuum.0
    2022-11-01 14:07:57.086	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:57.086	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:57.085	debug	MIIO Receive Timeout for "get_consumable" <<<
    mihome-vacuum.0
    2022-11-01 14:07:55.083	debug	Message= {"id":47,"method":"get_consumable"}
    mihome-vacuum.0
    2022-11-01 14:07:55.083	debug	Startup: setGetCleanSummary Answer: false
    mihome-vacuum.0
    2022-11-01 14:07:55.083	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:55.083	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:55.082	debug	MIIO Receive Timeout for "get_clean_summary" <<<
    mihome-vacuum.0
    2022-11-01 14:07:54.643	debug	Receive <<< Helo <<< 21310020000000001329b53563611a2affffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:07:53.082	debug	Message= {"id":46,"method":"get_clean_summary"}
    mihome-vacuum.0
    2022-11-01 14:07:53.081	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:53.081	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:53.080	debug	MIIO Receive Timeout for "get_sound_volume" <<<
    mihome-vacuum.0
    2022-11-01 14:07:51.079	debug	Message= {"id":45,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:07:51.079	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:51.079	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:51.078	debug	MIIO Receive Timeout for "get_network_info" <<<
    mihome-vacuum.0
    2022-11-01 14:07:49.078	debug	Message= {"id":44,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:07:49.078	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:49.078	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:49.077	debug	MIIO Receive Timeout for "get_status" <<<
    mihome-vacuum.0
    2022-11-01 14:07:47.077	debug	Message= {"id":43,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:07:47.076	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:07:44.635	debug	Receive <<< Helo <<< 21310020000000001329b53563611a20ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:07:34.632	debug	Receive <<< Helo <<< 21310020000000001329b53563611a16ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:07:27.076	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:27.076	debug	MIIO Receive Timeout for "get_map_v1" <<<
    mihome-vacuum.0
    2022-11-01 14:07:25.074	debug	Message= {"id":42,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:07:25.074	debug	Startup: setGetConsumable Answer: false
    mihome-vacuum.0
    2022-11-01 14:07:25.074	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:25.073	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:25.073	debug	MIIO Receive Timeout for "get_consumable" <<<
    mihome-vacuum.0
    2022-11-01 14:07:24.628	debug	Receive <<< Helo <<< 21310020000000001329b53563611a0cffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:07:23.072	debug	Message= {"id":41,"method":"get_consumable"}
    mihome-vacuum.0
    2022-11-01 14:07:23.071	debug	Startup: setGetCleanSummary Answer: false
    mihome-vacuum.0
    2022-11-01 14:07:23.071	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:23.071	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:23.071	debug	MIIO Receive Timeout for "get_clean_summary" <<<
    mihome-vacuum.0
    2022-11-01 14:07:21.070	debug	Message= {"id":40,"method":"get_clean_summary"}
    mihome-vacuum.0
    2022-11-01 14:07:21.070	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:21.070	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:21.069	debug	MIIO Receive Timeout for "get_sound_volume" <<<
    mihome-vacuum.0
    2022-11-01 14:07:19.069	debug	Message= {"id":39,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:07:19.069	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:19.061	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:19.061	debug	MIIO Receive Timeout for "get_network_info" <<<
    mihome-vacuum.0
    2022-11-01 14:07:17.060	debug	Message= {"id":38,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:07:17.060	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:07:17.059	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:07:17.059	debug	MIIO Receive Timeout for "get_status" <<<
    mihome-vacuum.0
    2022-11-01 14:07:15.059	debug	Message= {"id":37,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:07:15.058	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:07:14.625	debug	Receive <<< Helo <<< 21310020000000001329b53563611a02ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:07:04.622	debug	Receive <<< Helo <<< 21310020000000001329b535636119f8ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:06:55.058	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:55.057	debug	MIIO Receive Timeout for "get_map_v1" <<<
    mihome-vacuum.0
    2022-11-01 14:06:54.609	debug	Helo message Timeout
    mihome-vacuum.0
    2022-11-01 14:06:53.056	debug	Message= {"id":36,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:06:53.056	debug	Startup: setGetConsumable Answer: false
    mihome-vacuum.0
    2022-11-01 14:06:53.056	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:53.056	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:53.056	debug	MIIO Receive Timeout for "get_consumable" <<<
    mihome-vacuum.0
    2022-11-01 14:06:51.054	debug	Message= {"id":35,"method":"get_consumable"}
    mihome-vacuum.0
    2022-11-01 14:06:51.054	debug	Startup: setGetCleanSummary Answer: false
    mihome-vacuum.0
    2022-11-01 14:06:51.054	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:51.054	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:51.054	debug	MIIO Receive Timeout for "get_clean_summary" <<<
    mihome-vacuum.0
    2022-11-01 14:06:49.052	debug	Message= {"id":34,"method":"get_clean_summary"}
    mihome-vacuum.0
    2022-11-01 14:06:49.052	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:49.049	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:49.049	debug	MIIO Receive Timeout for "get_sound_volume" <<<
    mihome-vacuum.0
    2022-11-01 14:06:47.045	debug	Message= {"id":33,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:06:47.045	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:47.045	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:47.044	debug	MIIO Receive Timeout for "get_network_info" <<<
    mihome-vacuum.0
    2022-11-01 14:06:45.044	debug	Message= {"id":32,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:06:45.044	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:45.044	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:45.043	debug	MIIO Receive Timeout for "get_status" <<<
    mihome-vacuum.0
    2022-11-01 14:06:43.043	debug	Message= {"id":31,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:06:43.042	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:06:42.607	debug	Receive <<< Helo <<< 21310020000000001329b535636119e2ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:06:32.604	debug	Receive <<< Helo <<< 21310020000000001329b535636119d8ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:06:23.041	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:23.041	debug	MIIO Receive Timeout for "get_map_v1" <<<
    mihome-vacuum.0
    2022-11-01 14:06:22.600	debug	Receive <<< Helo <<< 21310020000000001329b535636119ceffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:06:21.040	debug	Message= {"id":30,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:06:21.039	debug	Startup: setGetConsumable Answer: false
    mihome-vacuum.0
    2022-11-01 14:06:21.039	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:21.039	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:21.038	debug	MIIO Receive Timeout for "get_consumable" <<<
    mihome-vacuum.0
    2022-11-01 14:06:19.038	debug	Message= {"id":29,"method":"get_consumable"}
    mihome-vacuum.0
    2022-11-01 14:06:19.038	debug	Startup: setGetCleanSummary Answer: false
    mihome-vacuum.0
    2022-11-01 14:06:19.037	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:19.037	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:19.037	debug	MIIO Receive Timeout for "get_clean_summary" <<<
    mihome-vacuum.0
    2022-11-01 14:06:17.036	debug	Message= {"id":28,"method":"get_clean_summary"}
    mihome-vacuum.0
    2022-11-01 14:06:17.036	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:17.036	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:17.035	debug	MIIO Receive Timeout for "get_sound_volume" <<<
    mihome-vacuum.0
    2022-11-01 14:06:15.035	debug	Message= {"id":27,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:06:15.035	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:15.035	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:15.034	debug	MIIO Receive Timeout for "get_network_info" <<<
    mihome-vacuum.0
    2022-11-01 14:06:13.033	debug	Message= {"id":26,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:06:13.033	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:06:13.033	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:06:13.033	debug	MIIO Receive Timeout for "get_status" <<<
    mihome-vacuum.0
    2022-11-01 14:06:12.596	debug	Receive <<< Helo <<< 21310020000000001329b535636119c4ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:06:11.032	debug	Message= {"id":25,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:06:11.031	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:06:02.588	debug	Receive <<< Helo <<< 21310020000000001329b535636119baffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:05:52.585	debug	Receive <<< Helo <<< 21310020000000001329b535636119b0ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:05:51.031	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:05:51.030	debug	MIIO Receive Timeout for "get_map_v1" <<<
    mihome-vacuum.0
    2022-11-01 14:05:49.029	debug	Message= {"id":24,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:05:49.029	debug	Startup: setGetConsumable Answer: false
    mihome-vacuum.0
    2022-11-01 14:05:49.029	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:05:49.029	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:05:49.028	debug	MIIO Receive Timeout for "get_consumable" <<<
    mihome-vacuum.0
    2022-11-01 14:05:47.028	debug	Message= {"id":23,"method":"get_consumable"}
    mihome-vacuum.0
    2022-11-01 14:05:47.027	debug	Startup: setGetCleanSummary Answer: false
    mihome-vacuum.0
    2022-11-01 14:05:47.027	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:05:47.026	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:05:47.026	debug	MIIO Receive Timeout for "get_clean_summary" <<<
    mihome-vacuum.0
    2022-11-01 14:05:45.025	debug	Message= {"id":22,"method":"get_clean_summary"}
    mihome-vacuum.0
    2022-11-01 14:05:45.025	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:05:45.025	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:05:45.024	debug	MIIO Receive Timeout for "get_sound_volume" <<<
    mihome-vacuum.0
    2022-11-01 14:05:43.024	debug	Message= {"id":21,"method":"get_sound_volume"}
    mihome-vacuum.0
    2022-11-01 14:05:43.024	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:05:43.024	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:05:43.023	debug	MIIO Receive Timeout for "get_network_info" <<<
    mihome-vacuum.0
    2022-11-01 14:05:42.582	debug	Receive <<< Helo <<< 21310020000000001329b535636119a6ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:05:41.022	debug	Message= {"id":20,"method":"get_network_info"}
    mihome-vacuum.0
    2022-11-01 14:05:41.022	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:05:41.022	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:05:41.021	debug	MIIO Receive Timeout for "get_status" <<<
    mihome-vacuum.0
    2022-11-01 14:05:39.020	debug	Message= {"id":19,"method":"get_status"}
    mihome-vacuum.0
    2022-11-01 14:05:39.020	debug	get params for stock Vacuum
    mihome-vacuum.0
    2022-11-01 14:05:38.399	info	discover Login failed
    mihome-vacuum.0
    2022-11-01 14:05:38.399	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"","pwd":0,"child":0,"desc":"登录验证失败"}
    mihome-vacuum.0
    2022-11-01 14:05:38.202	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"child":0,"desc":"登录验证失败"}
    mihome-vacuum.0
    2022-11-01 14:05:38.072	debug	Xiaomi Cloud: Logging in
    mihome-vacuum.0
    2022-11-01 14:05:32.579	debug	Receive <<< Helo <<< 21310020000000001329b5356361199cffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:05:22.576	debug	Receive <<< Helo <<< 21310020000000001329b53563611992ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2022-11-01 14:05:19.019	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:05:19.018	debug	MIIO Receive Timeout for "get_map_v1" <<<
    mihome-vacuum.0
    2022-11-01 14:05:17.018	debug	Message= {"id":18,"method":"get_map_v1"}
    mihome-vacuum.0
    2022-11-01 14:05:17.018	debug	Startup: setGetConsumable Answer: false
    mihome-vacuum.0
    2022-11-01 14:05:17.017	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
    mihome-vacuum.0
    2022-11-01 14:05:17.017	error	sendMessage throws error ==>MESSAGE TIMEOUT
    mihome-vacuum.0
    2022-11-01 14:05:17.017	debug	MIIO Receive Timeout for "get_consumable" <<<
    da knallts nur so rein...
    • da_WoodyD da_Woody
      v6.2.23
      38
      Log-Größe: 58.2 KB
      mihome-vacuum.0
      Zeit
      debug
      Nachricht
      mihome-vacuum.0
      2022-11-01 14:14:39.756	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":174}
      mihome-vacuum.0
      2022-11-01 14:14:39.747	debug	Message= {"id":174,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:14:39.746	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:14:39.746	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":173}
      mihome-vacuum.0
      2022-11-01 14:14:39.742	debug	Message= {"id":173,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:14:39.742	debug	MIIO RECIVE: {"result":[90],"id":172}
      mihome-vacuum.0
      2022-11-01 14:14:39.732	debug	Message= {"id":172,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:14:39.615	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":171}
      mihome-vacuum.0
      2022-11-01 14:14:39.593	debug	Message= {"id":171,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:14:39.592	debug	setGetStatus {"msg_ver":2,"msg_seq":1784,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:14:39.592	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1784,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":170}
      mihome-vacuum.0
      2022-11-01 14:14:39.586	debug	Message= {"id":170,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:14:39.585	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:14:34.810	debug	Receive <<< Helo <<< 21310020000000001329b53563611bbaffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:14:24.807	debug	Receive <<< Helo <<< 21310020000000001329b53563611bb0ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:14:19.490	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":169}
      mihome-vacuum.0
      2022-11-01 14:14:19.479	debug	Message= {"id":169,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:14:19.479	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:14:19.479	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F17"],"id":168}
      mihome-vacuum.0
      2022-11-01 14:14:19.473	debug	Message= {"id":168,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:14:19.473	debug	MIIO RECIVE: {"result":[90],"id":167}
      mihome-vacuum.0
      2022-11-01 14:14:19.464	debug	Message= {"id":167,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:14:19.346	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":166}
      mihome-vacuum.0
      2022-11-01 14:14:19.324	debug	Message= {"id":166,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:14:19.324	debug	setGetStatus {"msg_ver":2,"msg_seq":1783,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:14:19.323	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1783,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":165}
      mihome-vacuum.0
      2022-11-01 14:14:19.317	debug	Message= {"id":165,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:14:19.317	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:14:14.803	debug	Receive <<< Helo <<< 21310020000000001329b53563611ba6ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:14:04.800	debug	Receive <<< Helo <<< 21310020000000001329b53563611b9cffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:13:59.198	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":164}
      mihome-vacuum.0
      2022-11-01 14:13:59.186	debug	Message= {"id":164,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:13:59.185	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:13:59.184	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F16"],"id":163}
      mihome-vacuum.0
      2022-11-01 14:13:59.177	debug	Message= {"id":163,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:13:59.177	debug	MIIO RECIVE: {"result":[90],"id":162}
      mihome-vacuum.0
      2022-11-01 14:13:59.172	debug	Message= {"id":162,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:13:59.070	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":161}
      mihome-vacuum.0
      2022-11-01 14:13:59.049	debug	Message= {"id":161,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:13:59.048	debug	setGetStatus {"msg_ver":2,"msg_seq":1782,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:13:59.048	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1782,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":160}
      mihome-vacuum.0
      2022-11-01 14:13:59.042	debug	Message= {"id":160,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:13:59.042	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:13:54.792	debug	Receive <<< Helo <<< 21310020000000001329b53563611b92ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:13:44.789	debug	Receive <<< Helo <<< 21310020000000001329b53563611b88ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:13:38.948	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":159}
      mihome-vacuum.0
      2022-11-01 14:13:38.938	debug	Message= {"id":159,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:13:38.938	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:13:38.937	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F15"],"id":158}
      mihome-vacuum.0
      2022-11-01 14:13:38.933	debug	Message= {"id":158,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:13:38.933	debug	MIIO RECIVE: {"result":[90],"id":157}
      mihome-vacuum.0
      2022-11-01 14:13:38.928	debug	Message= {"id":157,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:13:38.833	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":156}
      mihome-vacuum.0
      2022-11-01 14:13:38.812	debug	Message= {"id":156,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:13:38.812	debug	setGetStatus {"msg_ver":2,"msg_seq":1781,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:13:38.811	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1781,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":155}
      mihome-vacuum.0
      2022-11-01 14:13:38.805	debug	Message= {"id":155,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:13:38.805	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:13:34.786	debug	Receive <<< Helo <<< 21310020000000001329b53563611b7effffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:13:24.782	debug	Receive <<< Helo <<< 21310020000000001329b53563611b74ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:13:18.608	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":154}
      mihome-vacuum.0
      2022-11-01 14:13:18.598	debug	Message= {"id":154,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:13:18.598	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:13:18.598	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F14"],"id":153}
      mihome-vacuum.0
      2022-11-01 14:13:18.593	debug	Message= {"id":153,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:13:18.592	debug	MIIO RECIVE: {"result":[90],"id":152}
      mihome-vacuum.0
      2022-11-01 14:13:18.587	debug	Message= {"id":152,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:13:18.477	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":151}
      mihome-vacuum.0
      2022-11-01 14:13:18.455	debug	Message= {"id":151,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:13:18.455	debug	setGetStatus {"msg_ver":2,"msg_seq":1780,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:13:18.455	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1780,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":150}
      mihome-vacuum.0
      2022-11-01 14:13:18.449	debug	Message= {"id":150,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:13:18.448	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:13:14.779	debug	Receive <<< Helo <<< 21310020000000001329b53563611b6affffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:13:04.776	debug	Receive <<< Helo <<< 21310020000000001329b53563611b60ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:12:58.345	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":149}
      mihome-vacuum.0
      2022-11-01 14:12:58.334	debug	Message= {"id":149,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:12:58.334	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:12:58.334	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F13"],"id":148}
      mihome-vacuum.0
      2022-11-01 14:12:58.328	debug	Message= {"id":148,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:12:58.328	debug	MIIO RECIVE: {"result":[90],"id":147}
      mihome-vacuum.0
      2022-11-01 14:12:58.323	debug	Message= {"id":147,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:12:58.227	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":146}
      mihome-vacuum.0
      2022-11-01 14:12:58.205	debug	Message= {"id":146,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:12:58.205	debug	setGetStatus {"msg_ver":2,"msg_seq":1779,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:12:58.205	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1779,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":145}
      mihome-vacuum.0
      2022-11-01 14:12:58.196	debug	Message= {"id":145,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:12:58.196	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:12:54.773	debug	Receive <<< Helo <<< 21310020000000001329b53563611b56ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:12:44.768	debug	Receive <<< Helo <<< 21310020000000001329b53563611b4cffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:12:37.758	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":144}
      mihome-vacuum.0
      2022-11-01 14:12:37.749	debug	Message= {"id":144,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:12:37.749	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:12:37.749	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F12"],"id":143}
      mihome-vacuum.0
      2022-11-01 14:12:37.745	debug	Message= {"id":143,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:12:37.744	debug	MIIO RECIVE: {"result":[90],"id":142}
      mihome-vacuum.0
      2022-11-01 14:12:37.739	debug	Message= {"id":142,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:12:35.361	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":141}
      mihome-vacuum.0
      2022-11-01 14:12:35.337	debug	Message= {"id":141,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:12:35.337	debug	setGetStatus {"msg_ver":2,"msg_seq":1778,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:12:35.336	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1778,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":140}
      mihome-vacuum.0
      2022-11-01 14:12:35.329	debug	Message= {"id":140,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:12:35.329	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:12:34.765	debug	Receive <<< Helo <<< 21310020000000001329b53563611b42ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:12:24.754	debug	Receive <<< Helo <<< 21310020000000001329b53563611b38ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:12:15.197	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":139}
      mihome-vacuum.0
      2022-11-01 14:12:15.185	debug	Message= {"id":139,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:12:15.184	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:12:15.183	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F11"],"id":138}
      mihome-vacuum.0
      2022-11-01 14:12:15.178	debug	Message= {"id":138,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:12:15.178	debug	MIIO RECIVE: {"result":[90],"id":137}
      mihome-vacuum.0
      2022-11-01 14:12:15.173	debug	Message= {"id":137,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:12:15.080	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":136}
      mihome-vacuum.0
      2022-11-01 14:12:15.059	debug	Message= {"id":136,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:12:15.058	debug	setGetStatus {"msg_ver":2,"msg_seq":1777,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:12:15.058	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1777,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":135}
      mihome-vacuum.0
      2022-11-01 14:12:15.052	debug	Message= {"id":135,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:12:15.052	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:12:14.751	debug	Receive <<< Helo <<< 21310020000000001329b53563611b2effffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:12:04.744	debug	Receive <<< Helo <<< 21310020000000001329b53563611b24ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:11:54.945	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":134}
      mihome-vacuum.0
      2022-11-01 14:11:54.937	debug	Message= {"id":134,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:11:54.937	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:11:54.936	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F10"],"id":133}
      mihome-vacuum.0
      2022-11-01 14:11:54.931	debug	Message= {"id":133,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:11:54.931	debug	MIIO RECIVE: {"result":[90],"id":132}
      mihome-vacuum.0
      2022-11-01 14:11:54.923	debug	Message= {"id":132,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:11:54.765	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":131}
      mihome-vacuum.0
      2022-11-01 14:11:54.744	debug	Message= {"id":131,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:11:54.743	debug	setGetStatus {"msg_ver":2,"msg_seq":1776,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:11:54.743	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1776,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":130}
      mihome-vacuum.0
      2022-11-01 14:11:54.741	debug	Receive <<< Helo <<< 21310020000000001329b53563611b1affffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:11:54.737	debug	Message= {"id":130,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:11:54.737	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:11:44.737	debug	Receive <<< Helo <<< 21310020000000001329b53563611b10ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:11:34.734	debug	Receive <<< Helo <<< 21310020000000001329b53563611b06ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:11:34.643	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":129}
      mihome-vacuum.0
      2022-11-01 14:11:34.635	debug	Message= {"id":129,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:11:34.635	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:11:34.634	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F9"],"id":128}
      mihome-vacuum.0
      2022-11-01 14:11:34.630	debug	Message= {"id":128,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:11:34.630	debug	MIIO RECIVE: {"result":[90],"id":127}
      mihome-vacuum.0
      2022-11-01 14:11:34.624	debug	Message= {"id":127,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:11:34.513	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":126}
      mihome-vacuum.0
      2022-11-01 14:11:34.492	debug	Message= {"id":126,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:11:34.492	debug	setGetStatus {"msg_ver":2,"msg_seq":1775,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:11:34.492	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1775,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":125}
      mihome-vacuum.0
      2022-11-01 14:11:34.481	debug	Message= {"id":125,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:11:34.481	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:11:24.732	debug	Receive <<< Helo <<< 21310020000000001329b53563611afcffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:11:14.729	debug	Receive <<< Helo <<< 21310020000000001329b53563611af2ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:11:14.422	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":124}
      mihome-vacuum.0
      2022-11-01 14:11:14.415	debug	Message= {"id":124,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:11:14.414	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:11:14.414	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F8"],"id":123}
      mihome-vacuum.0
      2022-11-01 14:11:14.410	debug	Message= {"id":123,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:11:14.410	debug	MIIO RECIVE: {"result":[90],"id":122}
      mihome-vacuum.0
      2022-11-01 14:11:14.404	debug	Message= {"id":122,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:11:14.316	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":121}
      mihome-vacuum.0
      2022-11-01 14:11:14.293	debug	Message= {"id":121,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:11:14.293	debug	setGetStatus {"msg_ver":2,"msg_seq":1774,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:11:14.293	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1774,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":120}
      mihome-vacuum.0
      2022-11-01 14:11:14.281	debug	Message= {"id":120,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:11:14.281	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:11:04.724	debug	Receive <<< Helo <<< 21310020000000001329b53563611ae8ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:10:54.720	debug	Receive <<< Helo <<< 21310020000000001329b53563611adeffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:10:54.187	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":119}
      mihome-vacuum.0
      2022-11-01 14:10:54.177	debug	Message= {"id":119,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:10:54.177	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:10:54.176	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F7"],"id":118}
      mihome-vacuum.0
      2022-11-01 14:10:54.172	debug	Message= {"id":118,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:10:54.172	debug	MIIO RECIVE: {"result":[90],"id":117}
      mihome-vacuum.0
      2022-11-01 14:10:54.167	debug	Message= {"id":117,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:10:54.053	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":116}
      mihome-vacuum.0
      2022-11-01 14:10:54.028	debug	Message= {"id":116,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:10:54.028	debug	setGetStatus {"msg_ver":2,"msg_seq":1773,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:10:54.027	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1773,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":115}
      mihome-vacuum.0
      2022-11-01 14:10:54.021	debug	Message= {"id":115,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:10:54.021	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:10:44.714	debug	Receive <<< Helo <<< 21310020000000001329b53563611ad4ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:10:34.706	debug	Receive <<< Helo <<< 21310020000000001329b53563611acaffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:10:33.868	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":114}
      mihome-vacuum.0
      2022-11-01 14:10:33.861	debug	Message= {"id":114,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:10:33.861	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:10:33.861	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F6"],"id":113}
      mihome-vacuum.0
      2022-11-01 14:10:33.855	debug	Message= {"id":113,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:10:33.854	debug	MIIO RECIVE: {"result":[90],"id":112}
      mihome-vacuum.0
      2022-11-01 14:10:33.848	debug	Message= {"id":112,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:10:33.683	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":111}
      mihome-vacuum.0
      2022-11-01 14:10:33.661	debug	Message= {"id":111,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:10:33.661	debug	setGetStatus {"msg_ver":2,"msg_seq":1772,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:10:33.660	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1772,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":110}
      mihome-vacuum.0
      2022-11-01 14:10:33.654	debug	Message= {"id":110,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:10:33.654	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:10:24.702	debug	Receive <<< Helo <<< 21310020000000001329b53563611ac0ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:10:14.697	debug	Receive <<< Helo <<< 21310020000000001329b53563611ab6ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:10:13.551	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":109}
      mihome-vacuum.0
      2022-11-01 14:10:13.545	debug	Message= {"id":109,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:10:13.543	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:10:13.542	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F5"],"id":108}
      mihome-vacuum.0
      2022-11-01 14:10:13.537	debug	Message= {"id":108,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:10:13.537	debug	MIIO RECIVE: {"result":[90],"id":107}
      mihome-vacuum.0
      2022-11-01 14:10:13.532	debug	Message= {"id":107,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:10:13.418	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":106}
      mihome-vacuum.0
      2022-11-01 14:10:13.396	debug	Message= {"id":106,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:10:13.395	debug	setGetStatus {"msg_ver":2,"msg_seq":1771,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:10:13.395	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1771,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":105}
      mihome-vacuum.0
      2022-11-01 14:10:13.384	debug	Message= {"id":105,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:10:13.384	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:10:04.693	debug	Receive <<< Helo <<< 21310020000000001329b53563611aacffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:09:54.690	debug	Receive <<< Helo <<< 21310020000000001329b53563611aa2ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:09:53.241	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":104}
      mihome-vacuum.0
      2022-11-01 14:09:53.234	debug	Message= {"id":104,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:09:53.234	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:09:53.234	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F4"],"id":103}
      mihome-vacuum.0
      2022-11-01 14:09:53.229	debug	Message= {"id":103,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:09:53.229	debug	MIIO RECIVE: {"result":[90],"id":102}
      mihome-vacuum.0
      2022-11-01 14:09:53.220	debug	Message= {"id":102,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:09:53.114	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":101}
      mihome-vacuum.0
      2022-11-01 14:09:53.093	debug	Message= {"id":101,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:09:53.093	debug	setGetStatus {"msg_ver":2,"msg_seq":1770,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:09:53.092	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1770,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":100}
      mihome-vacuum.0
      2022-11-01 14:09:53.082	debug	Message= {"id":100,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:09:53.082	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:09:44.686	debug	Receive <<< Helo <<< 21310020000000001329b53563611a98ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:09:34.684	debug	Receive <<< Helo <<< 21310020000000001329b53563611a8effffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:09:32.973	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":99}
      mihome-vacuum.0
      2022-11-01 14:09:32.964	debug	Message= {"id":99,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:09:32.964	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:09:32.963	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F3"],"id":98}
      mihome-vacuum.0
      2022-11-01 14:09:32.958	debug	Message= {"id":98,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:09:32.957	debug	MIIO RECIVE: {"result":[90],"id":97}
      mihome-vacuum.0
      2022-11-01 14:09:32.951	debug	Message= {"id":97,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:09:32.854	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":96}
      mihome-vacuum.0
      2022-11-01 14:09:32.831	debug	Message= {"id":96,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:09:32.831	debug	setGetStatus {"msg_ver":2,"msg_seq":1769,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:09:32.831	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1769,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":95}
      mihome-vacuum.0
      2022-11-01 14:09:32.824	debug	Message= {"id":95,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:09:32.824	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:09:24.678	debug	Receive <<< Helo <<< 21310020000000001329b53563611a84ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:09:14.675	debug	Receive <<< Helo <<< 21310020000000001329b53563611a7affffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:09:12.653	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":94}
      mihome-vacuum.0
      2022-11-01 14:09:12.633	debug	Message= {"id":94,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:09:12.632	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:09:12.631	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F2"],"id":93}
      mihome-vacuum.0
      2022-11-01 14:09:12.624	debug	Message= {"id":93,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:09:12.622	debug	MIIO RECIVE: {"result":[90],"id":92}
      mihome-vacuum.0
      2022-11-01 14:09:12.613	debug	Message= {"id":92,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:09:12.514	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":91}
      mihome-vacuum.0
      2022-11-01 14:09:12.491	debug	Message= {"id":91,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:09:12.491	debug	setGetStatus {"msg_ver":2,"msg_seq":1768,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:09:12.491	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1768,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":90}
      mihome-vacuum.0
      2022-11-01 14:09:12.485	debug	Message= {"id":90,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:09:12.484	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:09:04.672	debug	Receive <<< Helo <<< 21310020000000001329b53563611a70ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:08:54.669	debug	Receive <<< Helo <<< 21310020000000001329b53563611a66ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:08:52.432	debug	finish logs all [{"Datum":"28.10","Start":"19:57","Saugzeit":"32 min","Fläche":"22.35 m²","Error":0,"Ende":true},{"Datum":"28.10","Start":"15:18","Saugzeit":"6 min","Fläche":"5.87 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:16","Saugzeit":"2 min","Fläche":"0 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:10","Saugzeit":"5 min","Fläche":"2.22 m²","Error":0,"Ende":false},{"Datum":"13.9","Start":"19:42","Saugzeit":"30 min","Fläche":"24.64 m²","Error":0,"Ende":true},{"Datum":"6.9","Start":"15:18","Saugzeit":"6 min","Fläche":"2 m²","Error":8,"Ende":false},{"Datum":"30.7","Start":"20:43","Saugzeit":"41 min","Fläche":"24.05 m²","Error":0,"Ende":true},{"Datum":"1.7","Start":"16:20","Saugzeit":"22 min","Fläche":"22.3 m²","Error":0,"Ende":true},{"Datum":"9.6","Start":"19:18","Saugzeit":"24 min","Fläche":"24.63 m²","Error":0,"Ende":true},{"Datum":"30.5","Start":"19:26","Saugzeit":"28 min","Fläche":"24.72 m²","Error":0,"Ende":true},{"Datum":"10.5","Start":"15:09","Saugzeit":"25 min","Fläche":"24.65 m²","Error":0,"Ende":true},{"Datum":"6.5","Start":"19:24","Saugzeit":"26 min","Fläche":"24.11 m²","Error":0,"Ende":true},{"Datum":"29.4","Start":"19:33","Saugzeit":"36 min","Fläche":"23.96 m²","Error":0,"Ende":true},{"Datum":"19.2","Start":"19:32","Saugzeit":"1 min","Fläche":"0.51 m²","Error":0,"Ende":false},{"Datum":"23.1","Start":"19:44","Saugzeit":"29 min","Fläche":"25.02 m²","Error":0,"Ende":true},{"Datum":"22.1","Start":"20:13","Saugzeit":"10 min","Fläche":"12.37 m²","Error":0,"Ende":false},{"Datum":"21.1","Start":"10:22","Saugzeit":"1 min","Fläche":"1.29 m²","Error":0,"Ende":false},{"Datum":"18.1","Start":"20:20","Saugzeit":"27 min","Fläche":"24.17 m²","Error":0,"Ende":true},{"Datum":"6.1","Start":"19:10","Saugzeit":"12 min","Fläche":"14.82 m²","Error":0,"Ende":false},{"Datum":"6.1","Start":"15:36","Saugzeit":"32 min","Fläche":"24.57 m²","Error":0,"Ende":true}]
      mihome-vacuum.0
      2022-11-01 14:08:52.432	debug	MIIO RECIVE: {"result":[[1641479793,1641486963,1910,24567500,0,1,2,1,52]],"id":89}
      mihome-vacuum.0
      2022-11-01 14:08:52.423	debug	Message= {"id":89,"method":"get_clean_record","params":[1641479793]}
      mihome-vacuum.0
      2022-11-01 14:08:52.422	debug	MIIO RECIVE: {"result":[[1641492626,1641493350,696,14817500,0,0,2,1,60]],"id":88}
      mihome-vacuum.0
      2022-11-01 14:08:52.413	debug	Message= {"id":88,"method":"get_clean_record","params":[1641492626]}
      mihome-vacuum.0
      2022-11-01 14:08:52.412	debug	MIIO RECIVE: {"result":[[1642533653,1642535288,1625,24167500,0,1,2,1,52]],"id":87}
      mihome-vacuum.0
      2022-11-01 14:08:52.403	debug	Message= {"id":87,"method":"get_clean_record","params":[1642533653]}
      mihome-vacuum.0
      2022-11-01 14:08:52.402	debug	MIIO RECIVE: {"result":[[1642756938,1642756995,57,1292500,0,0,2,1,60]],"id":86}
      mihome-vacuum.0
      2022-11-01 14:08:52.396	debug	Message= {"id":86,"method":"get_clean_record","params":[1642756938]}
      mihome-vacuum.0
      2022-11-01 14:08:52.396	debug	MIIO RECIVE: {"result":[[1642878816,1642879423,607,12367500,0,0,2,1,60]],"id":85}
      mihome-vacuum.0
      2022-11-01 14:08:52.389	debug	Message= {"id":85,"method":"get_clean_record","params":[1642878816]}
      mihome-vacuum.0
      2022-11-01 14:08:52.387	debug	MIIO RECIVE: {"result":[[1642963476,1642965232,1756,25020000,0,1,2,1,52]],"id":84}
      mihome-vacuum.0
      2022-11-01 14:08:52.373	debug	Message= {"id":84,"method":"get_clean_record","params":[1642963476]}
      mihome-vacuum.0
      2022-11-01 14:08:52.372	debug	MIIO RECIVE: {"result":[[1645295524,1645295556,32,512500,0,0,2,1,60]],"id":83}
      mihome-vacuum.0
      2022-11-01 14:08:52.366	debug	Message= {"id":83,"method":"get_clean_record","params":[1645295524]}
      mihome-vacuum.0
      2022-11-01 14:08:52.364	debug	MIIO RECIVE: {"result":[[1651253588,1651255767,2179,23957500,0,1,2,1,52]],"id":82}
      mihome-vacuum.0
      2022-11-01 14:08:52.358	debug	Message= {"id":82,"method":"get_clean_record","params":[1651253588]}
      mihome-vacuum.0
      2022-11-01 14:08:52.358	debug	MIIO RECIVE: {"result":[[1651857884,1651859471,1587,24110000,0,1,2,1,52]],"id":81}
      mihome-vacuum.0
      2022-11-01 14:08:52.353	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":80}
      mihome-vacuum.0
      2022-11-01 14:08:52.352	debug	Message= {"id":81,"method":"get_clean_record","params":[1651857884]}
      mihome-vacuum.0
      2022-11-01 14:08:52.352	debug	MIIO RECIVE: {"result":[[1652188174,1652189692,1518,24647500,0,1,2,1,52]],"id":79}
      mihome-vacuum.0
      2022-11-01 14:08:52.336	debug	Message= {"id":80,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:08:52.335	info	create state for carpet_mode
      mihome-vacuum.0
      2022-11-01 14:08:52.335	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":78}
      mihome-vacuum.0
      2022-11-01 14:08:52.334	debug	Message= {"id":79,"method":"get_clean_record","params":[1652188174]}
      mihome-vacuum.0
      2022-11-01 14:08:52.332	debug	MIIO RECIVE: {"result":[[1653931567,1653933520,1684,24717500,0,1,2,1,52]],"id":77}
      mihome-vacuum.0
      2022-11-01 14:08:52.327	debug	Message= {"id":78,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-11-01 14:08:52.326	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:08:52.326	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":76}
      mihome-vacuum.0
      2022-11-01 14:08:52.325	debug	Message= {"id":77,"method":"get_clean_record","params":[1653931567]}
      mihome-vacuum.0
      2022-11-01 14:08:52.324	debug	MIIO RECIVE: {"result":[[1654795117,1654796567,1450,24625000,0,1,2,1,52]],"id":75}
      mihome-vacuum.0
      2022-11-01 14:08:52.319	debug	Message= {"id":76,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:08:52.319	debug	Startup: Delete setGetConsumable
      mihome-vacuum.0
      2022-11-01 14:08:52.319	debug	Startup: setGetConsumable Answer: true
      mihome-vacuum.0
      2022-11-01 14:08:52.318	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":41889,"side_brush_work_time":41889,"filter_work_time":41889,"filter_element_work_time":0,"sensor_dirty_time":71089}],"id":74}
      mihome-vacuum.0
      2022-11-01 14:08:52.317	debug	Message= {"id":75,"method":"get_clean_record","params":[1654795117]}
      mihome-vacuum.0
      2022-11-01 14:08:52.310	debug	MIIO RECIVE: {"result":[[1656685244,1656686572,1328,22302500,0,1,2,1,52]],"id":73}
      mihome-vacuum.0
      2022-11-01 14:08:52.305	debug	Message= {"id":74,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:08:52.305	debug	Startup: Delete setGetCleanSummary
      mihome-vacuum.0
      2022-11-01 14:08:52.305	debug	Startup: setGetCleanSummary Answer: true
      mihome-vacuum.0
      2022-11-01 14:08:52.304	debug	MIIO RECIVE: {"result":[76749,992120000,76,[1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816,1642756938,1642533653,1641492626,1641479793]],"id":72}
      mihome-vacuum.0
      2022-11-01 14:08:52.303	debug	Message= {"id":73,"method":"get_clean_record","params":[1656685244]}
      mihome-vacuum.0
      2022-11-01 14:08:52.302	debug	MIIO RECIVE: {"result":[[1659206624,1659209105,2481,24045000,0,1,2,1,52]],"id":71}
      mihome-vacuum.0
      2022-11-01 14:08:52.297	debug	Message= {"id":72,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:08:52.297	debug	MIIO RECIVE: {"result":[90],"id":70}
      mihome-vacuum.0
      2022-11-01 14:08:52.296	debug	Message= {"id":71,"method":"get_clean_record","params":[1659206624]}
      mihome-vacuum.0
      2022-11-01 14:08:52.296	debug	MIIO RECIVE: {"result":[[1662470282,1662514759,383,2000000,8,0,2,1,34]],"id":69}
      mihome-vacuum.0
      2022-11-01 14:08:52.291	debug	Message= {"id":70,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:08:52.289	debug	Message= {"id":69,"method":"get_clean_record","params":[1662470282]}
      mihome-vacuum.0
      2022-11-01 14:08:52.289	debug	MIIO RECIVE: {"result":[[1663090972,1663093345,1773,24642500,0,1,2,1,52]],"id":68}
      mihome-vacuum.0
      2022-11-01 14:08:52.276	debug	Message= {"id":68,"method":"get_clean_record","params":[1663090972]}
      mihome-vacuum.0
      2022-11-01 14:08:52.276	debug	MIIO RECIVE: {"result":[[1666865404,1666865708,302,2215000,0,0,2,1,60]],"id":67}
      mihome-vacuum.0
      2022-11-01 14:08:52.254	debug	Message= {"id":67,"method":"get_clean_record","params":[1666865404]}
      mihome-vacuum.0
      2022-11-01 14:08:52.254	debug	MIIO RECIVE: {"result":[[1666865760,1666909702,141,0,8,0,2,1,34]],"id":66}
      mihome-vacuum.0
      2022-11-01 14:08:52.246	debug	Message= {"id":66,"method":"get_clean_record","params":[1666865760]}
      mihome-vacuum.0
      2022-11-01 14:08:52.244	debug	MIIO RECIVE: {"result":[[1666963083,1666979819,385,5867500,8,0,2,1,29]],"id":65}
      mihome-vacuum.0
      2022-11-01 14:08:52.237	debug	Message= {"id":65,"method":"get_clean_record","params":[1666963083]}
      mihome-vacuum.0
      2022-11-01 14:08:52.236	debug	MIIO RECIVE: {"result":[[1666979871,1666981820,1949,22352500,0,1,2,1,52]],"id":64}
      mihome-vacuum.0
      2022-11-01 14:08:52.229	debug	Message= {"id":64,"method":"get_clean_record","params":[1666979871]}
      mihome-vacuum.0
      2022-11-01 14:08:52.226	debug	MIIO RECIVE: {"result":[76749,992120000,76,[1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816,1642756938,1642533653,1641492626,1641479793]],"id":63}
      mihome-vacuum.0
      2022-11-01 14:08:52.223	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":62}
      mihome-vacuum.0
      2022-11-01 14:08:52.206	debug	Message= {"id":63,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:08:52.205	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":41889,"side_brush_work_time":41889,"filter_work_time":41889,"filter_element_work_time":0,"sensor_dirty_time":71089}],"id":61}
      mihome-vacuum.0
      2022-11-01 14:08:52.199	debug	Message= {"id":62,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:08:52.199	debug	Message= {"id":61,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:08:52.199	debug	MIIO RECIVE: {"result":[],"id":60}
      mihome-vacuum.0
      2022-11-01 14:08:52.190	debug	Message= {"id":60,"method":"get_room_mapping"}
      mihome-vacuum.0
      2022-11-01 14:08:52.190	debug	Mappointer_updated
      mihome-vacuum.0
      2022-11-01 14:08:52.189	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":59}
      mihome-vacuum.0
      2022-11-01 14:08:52.180	debug	Message= {"id":59,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:08:51.879	debug	MIIO RECIVE: {"result":["retry"],"id":58}
      mihome-vacuum.0
      2022-11-01 14:08:51.873	debug	Message= {"id":58,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:08:51.572	debug	MIIO RECIVE: {"result":["retry"],"id":57}
      mihome-vacuum.0
      2022-11-01 14:08:51.566	debug	Message= {"id":57,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:08:51.266	debug	MIIO RECIVE: {"result":["retry"],"id":56}
      mihome-vacuum.0
      2022-11-01 14:08:51.260	debug	Message= {"id":56,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:08:51.117	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      mihome-vacuum.0
      2022-11-01 14:08:51.109	info	create states for water box
      mihome-vacuum.0
      2022-11-01 14:08:51.109	info	change states from State control.fan_power
      mihome-vacuum.0
      2022-11-01 14:08:51.107	debug	setGetStatus {"msg_ver":2,"msg_seq":1767,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-11-01 14:08:51.107	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1767,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":55}
      mihome-vacuum.0
      2022-11-01 14:08:51.099	debug	Message= {"id":55,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:08:51.099	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:08:44.660	debug	Receive <<< Helo <<< 21310020000000001329b53563611a5cffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:08:34.656	debug	Receive <<< Helo <<< 21310020000000001329b53563611a52ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:08:31.098	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:08:31.097	debug	MIIO Receive Timeout for "get_map_v1" <<<
      mihome-vacuum.0
      2022-11-01 14:08:29.096	debug	Message= {"id":54,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:08:29.096	debug	Startup: setGetConsumable Answer: false
      mihome-vacuum.0
      2022-11-01 14:08:29.096	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:08:29.096	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:08:29.095	debug	MIIO Receive Timeout for "get_consumable" <<<
      mihome-vacuum.0
      2022-11-01 14:08:27.095	debug	Message= {"id":53,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:08:27.095	debug	Startup: setGetCleanSummary Answer: false
      mihome-vacuum.0
      2022-11-01 14:08:27.095	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:08:27.094	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:08:27.094	debug	MIIO Receive Timeout for "get_clean_summary" <<<
      mihome-vacuum.0
      2022-11-01 14:08:25.094	debug	Message= {"id":52,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:08:25.094	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:08:25.094	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:08:25.093	debug	MIIO Receive Timeout for "get_sound_volume" <<<
      mihome-vacuum.0
      2022-11-01 14:08:24.653	debug	Receive <<< Helo <<< 21310020000000001329b53563611a48ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:08:23.092	debug	Message= {"id":51,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:08:23.092	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:08:23.092	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:08:23.092	debug	MIIO Receive Timeout for "get_network_info" <<<
      mihome-vacuum.0
      2022-11-01 14:08:21.090	debug	Message= {"id":50,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:08:21.090	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:08:21.090	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:08:21.090	debug	MIIO Receive Timeout for "get_status" <<<
      mihome-vacuum.0
      2022-11-01 14:08:19.089	debug	Message= {"id":49,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:08:19.089	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:08:14.649	debug	Receive <<< Helo <<< 21310020000000001329b53563611a3effffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:08:04.646	debug	Receive <<< Helo <<< 21310020000000001329b53563611a34ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:07:59.088	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:59.087	debug	MIIO Receive Timeout for "get_map_v1" <<<
      mihome-vacuum.0
      2022-11-01 14:07:57.086	debug	Message= {"id":48,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:07:57.086	debug	Startup: setGetConsumable Answer: false
      mihome-vacuum.0
      2022-11-01 14:07:57.086	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:57.086	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:57.085	debug	MIIO Receive Timeout for "get_consumable" <<<
      mihome-vacuum.0
      2022-11-01 14:07:55.083	debug	Message= {"id":47,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:07:55.083	debug	Startup: setGetCleanSummary Answer: false
      mihome-vacuum.0
      2022-11-01 14:07:55.083	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:55.083	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:55.082	debug	MIIO Receive Timeout for "get_clean_summary" <<<
      mihome-vacuum.0
      2022-11-01 14:07:54.643	debug	Receive <<< Helo <<< 21310020000000001329b53563611a2affffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:07:53.082	debug	Message= {"id":46,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:07:53.081	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:53.081	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:53.080	debug	MIIO Receive Timeout for "get_sound_volume" <<<
      mihome-vacuum.0
      2022-11-01 14:07:51.079	debug	Message= {"id":45,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:07:51.079	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:51.079	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:51.078	debug	MIIO Receive Timeout for "get_network_info" <<<
      mihome-vacuum.0
      2022-11-01 14:07:49.078	debug	Message= {"id":44,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:07:49.078	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:49.078	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:49.077	debug	MIIO Receive Timeout for "get_status" <<<
      mihome-vacuum.0
      2022-11-01 14:07:47.077	debug	Message= {"id":43,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:07:47.076	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:07:44.635	debug	Receive <<< Helo <<< 21310020000000001329b53563611a20ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:07:34.632	debug	Receive <<< Helo <<< 21310020000000001329b53563611a16ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:07:27.076	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:27.076	debug	MIIO Receive Timeout for "get_map_v1" <<<
      mihome-vacuum.0
      2022-11-01 14:07:25.074	debug	Message= {"id":42,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:07:25.074	debug	Startup: setGetConsumable Answer: false
      mihome-vacuum.0
      2022-11-01 14:07:25.074	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:25.073	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:25.073	debug	MIIO Receive Timeout for "get_consumable" <<<
      mihome-vacuum.0
      2022-11-01 14:07:24.628	debug	Receive <<< Helo <<< 21310020000000001329b53563611a0cffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:07:23.072	debug	Message= {"id":41,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:07:23.071	debug	Startup: setGetCleanSummary Answer: false
      mihome-vacuum.0
      2022-11-01 14:07:23.071	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:23.071	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:23.071	debug	MIIO Receive Timeout for "get_clean_summary" <<<
      mihome-vacuum.0
      2022-11-01 14:07:21.070	debug	Message= {"id":40,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:07:21.070	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:21.070	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:21.069	debug	MIIO Receive Timeout for "get_sound_volume" <<<
      mihome-vacuum.0
      2022-11-01 14:07:19.069	debug	Message= {"id":39,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:07:19.069	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:19.061	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:19.061	debug	MIIO Receive Timeout for "get_network_info" <<<
      mihome-vacuum.0
      2022-11-01 14:07:17.060	debug	Message= {"id":38,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:07:17.060	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:07:17.059	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:07:17.059	debug	MIIO Receive Timeout for "get_status" <<<
      mihome-vacuum.0
      2022-11-01 14:07:15.059	debug	Message= {"id":37,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:07:15.058	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:07:14.625	debug	Receive <<< Helo <<< 21310020000000001329b53563611a02ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:07:04.622	debug	Receive <<< Helo <<< 21310020000000001329b535636119f8ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:06:55.058	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:55.057	debug	MIIO Receive Timeout for "get_map_v1" <<<
      mihome-vacuum.0
      2022-11-01 14:06:54.609	debug	Helo message Timeout
      mihome-vacuum.0
      2022-11-01 14:06:53.056	debug	Message= {"id":36,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:06:53.056	debug	Startup: setGetConsumable Answer: false
      mihome-vacuum.0
      2022-11-01 14:06:53.056	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:53.056	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:53.056	debug	MIIO Receive Timeout for "get_consumable" <<<
      mihome-vacuum.0
      2022-11-01 14:06:51.054	debug	Message= {"id":35,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:06:51.054	debug	Startup: setGetCleanSummary Answer: false
      mihome-vacuum.0
      2022-11-01 14:06:51.054	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:51.054	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:51.054	debug	MIIO Receive Timeout for "get_clean_summary" <<<
      mihome-vacuum.0
      2022-11-01 14:06:49.052	debug	Message= {"id":34,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:06:49.052	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:49.049	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:49.049	debug	MIIO Receive Timeout for "get_sound_volume" <<<
      mihome-vacuum.0
      2022-11-01 14:06:47.045	debug	Message= {"id":33,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:06:47.045	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:47.045	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:47.044	debug	MIIO Receive Timeout for "get_network_info" <<<
      mihome-vacuum.0
      2022-11-01 14:06:45.044	debug	Message= {"id":32,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:06:45.044	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:45.044	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:45.043	debug	MIIO Receive Timeout for "get_status" <<<
      mihome-vacuum.0
      2022-11-01 14:06:43.043	debug	Message= {"id":31,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:06:43.042	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:06:42.607	debug	Receive <<< Helo <<< 21310020000000001329b535636119e2ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:06:32.604	debug	Receive <<< Helo <<< 21310020000000001329b535636119d8ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:06:23.041	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:23.041	debug	MIIO Receive Timeout for "get_map_v1" <<<
      mihome-vacuum.0
      2022-11-01 14:06:22.600	debug	Receive <<< Helo <<< 21310020000000001329b535636119ceffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:06:21.040	debug	Message= {"id":30,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:06:21.039	debug	Startup: setGetConsumable Answer: false
      mihome-vacuum.0
      2022-11-01 14:06:21.039	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:21.039	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:21.038	debug	MIIO Receive Timeout for "get_consumable" <<<
      mihome-vacuum.0
      2022-11-01 14:06:19.038	debug	Message= {"id":29,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:06:19.038	debug	Startup: setGetCleanSummary Answer: false
      mihome-vacuum.0
      2022-11-01 14:06:19.037	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:19.037	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:19.037	debug	MIIO Receive Timeout for "get_clean_summary" <<<
      mihome-vacuum.0
      2022-11-01 14:06:17.036	debug	Message= {"id":28,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:06:17.036	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:17.036	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:17.035	debug	MIIO Receive Timeout for "get_sound_volume" <<<
      mihome-vacuum.0
      2022-11-01 14:06:15.035	debug	Message= {"id":27,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:06:15.035	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:15.035	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:15.034	debug	MIIO Receive Timeout for "get_network_info" <<<
      mihome-vacuum.0
      2022-11-01 14:06:13.033	debug	Message= {"id":26,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:06:13.033	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:06:13.033	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:06:13.033	debug	MIIO Receive Timeout for "get_status" <<<
      mihome-vacuum.0
      2022-11-01 14:06:12.596	debug	Receive <<< Helo <<< 21310020000000001329b535636119c4ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:06:11.032	debug	Message= {"id":25,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:06:11.031	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:06:02.588	debug	Receive <<< Helo <<< 21310020000000001329b535636119baffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:05:52.585	debug	Receive <<< Helo <<< 21310020000000001329b535636119b0ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:05:51.031	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:05:51.030	debug	MIIO Receive Timeout for "get_map_v1" <<<
      mihome-vacuum.0
      2022-11-01 14:05:49.029	debug	Message= {"id":24,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:05:49.029	debug	Startup: setGetConsumable Answer: false
      mihome-vacuum.0
      2022-11-01 14:05:49.029	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:05:49.029	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:05:49.028	debug	MIIO Receive Timeout for "get_consumable" <<<
      mihome-vacuum.0
      2022-11-01 14:05:47.028	debug	Message= {"id":23,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:05:47.027	debug	Startup: setGetCleanSummary Answer: false
      mihome-vacuum.0
      2022-11-01 14:05:47.027	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:05:47.026	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:05:47.026	debug	MIIO Receive Timeout for "get_clean_summary" <<<
      mihome-vacuum.0
      2022-11-01 14:05:45.025	debug	Message= {"id":22,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:05:45.025	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:05:45.025	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:05:45.024	debug	MIIO Receive Timeout for "get_sound_volume" <<<
      mihome-vacuum.0
      2022-11-01 14:05:43.024	debug	Message= {"id":21,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:05:43.024	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:05:43.024	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:05:43.023	debug	MIIO Receive Timeout for "get_network_info" <<<
      mihome-vacuum.0
      2022-11-01 14:05:42.582	debug	Receive <<< Helo <<< 21310020000000001329b535636119a6ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:05:41.022	debug	Message= {"id":20,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:05:41.022	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:05:41.022	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:05:41.021	debug	MIIO Receive Timeout for "get_status" <<<
      mihome-vacuum.0
      2022-11-01 14:05:39.020	debug	Message= {"id":19,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:05:39.020	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:05:38.399	info	discover Login failed
      mihome-vacuum.0
      2022-11-01 14:05:38.399	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"","pwd":0,"child":0,"desc":"登录验证失败"}
      mihome-vacuum.0
      2022-11-01 14:05:38.202	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"child":0,"desc":"登录验证失败"}
      mihome-vacuum.0
      2022-11-01 14:05:38.072	debug	Xiaomi Cloud: Logging in
      mihome-vacuum.0
      2022-11-01 14:05:32.579	debug	Receive <<< Helo <<< 21310020000000001329b5356361199cffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:05:22.576	debug	Receive <<< Helo <<< 21310020000000001329b53563611992ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:05:19.019	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:05:19.018	debug	MIIO Receive Timeout for "get_map_v1" <<<
      mihome-vacuum.0
      2022-11-01 14:05:17.018	debug	Message= {"id":18,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:05:17.018	debug	Startup: setGetConsumable Answer: false
      mihome-vacuum.0
      2022-11-01 14:05:17.017	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
      mihome-vacuum.0
      2022-11-01 14:05:17.017	error	sendMessage throws error ==>MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-11-01 14:05:17.017	debug	MIIO Receive Timeout for "get_consumable" <<<
      da knallts nur so rein...
      @da_woody sagte in Test für mihome-vacuum:
      Receive <<< Helo <<< 21310020000000001329b53563611bbaffffffffffffffffffffffffffffffff
      Du bist doch verbunden. Sonst gäbe es das Helo nicht.
        startet das ding nicht mehr.
        Und was steht im Log?
        dirkhe
        So, das mit dem timeout Fehlermeldungen kann ich nun aufklären.
        Das Verhalten hat sich nicht geändert, es wurde nur seit der Version > 3.6.0 das Timeout per error geloggt.
        Dass der Robbi manchal keine Lust hat zu antwortern ist ja schon seit Ewigkeiten so, das dauert dann halt manchmal ein paar Minuten.
        Ich habe bei mir aktuell das Verhalten angepasst (werde ich nach ein paar Test nachher online stellen):
        Wenn ein Timeout kommt, gebe ich folgende Meldungen aus:
        Das bedeutet, es kommt jetzt beim Start das mit den 10 Minuten einmal als Fehler und sonst nur noch als Warnungen
          da_WoodyD Offline
          da_WoodyD Offline
          @thomas-braun das ding macht mich krank. jetzt ist das teil wieder grün.
          das kartenproblem ist aber immer noch vorhanden...
          in der APP kann ich zuschauen am handy, in iQontrol seh ich nur eine alte karte.
          Thomas BraunT D 2 Antworten Letzte Antwort
          • da_WoodyD da_Woody
            Der braucht halt was länger. Siehe oben.
            • D dirkhe
              haselchenH Offline
              haselchenH Offline
              haselchen
              @dirkhe
              Aber das bedeutet doch eigentlich nur , dass du dem Kind einen anderen Namen gegeben hast oder?
              Von Error auf Warn?
              Bei der 3.6.0 kam der Warnhinweis nur 1mal. Wenn ich dein Log sehe, kommt das vermutlich unendlich.
                dirkhe
                @da_woody interessant ist der Start der App, da steht ggf, dass canvas nicht geladen wurde. Wenn das alles richtig geladen wurde, sollte die Karte auch gezeichnet werden
                  da_WoodyD Offline
                  da_WoodyD Offline
                  @thomas-braun jau, die 10min... ;)
                  im endeffekt gehts ja um die canvas geschichte.
                  hab das teil gerade gestartet, hat sich wo verklemmt. seh ich in der mihomeAPP, bekomm auch die fehlermeldung in iQontrol
                  die map:
                  von irgendwann...
                  • haselchenH haselchen
                    @dirkhe
                    Von Error auf Warn?
                    dirkhe
                    schrieb am zuletzt editiert von dirkhe
                    @haselchen Wenn du auf debug hattest, kam das auch schon unendlich oft in etwas andere Form.
                    Also der Adapter versucht halt ständig mit dem robby zu quatschen. Wenn es dann halt ein timeout gibt, schreibt er das per debug immer ins log, du hast bei nur "error" halt nur einmal die Meldung gesehen.
                    Ich weiß auch nicht wann er timeout probleme hat und wann nicht. wenn mann als entwickler den adpter halt immer wieder neu startet, kann es sein, dass es 5 mal gut geht und er fängt sofort ohne ein einziges timout an, dann kann es ahlt wieder dauern. Damit müssen wir halt leben.
                    3.8.3 ist auf github
                    haselchenH da_WoodyD 2 Antworten Letzte Antwort
                    • D dirkhe
                      da_WoodyD Offline
                      da_WoodyD Offline
                      @dirkhe k, gestoppt.
                      mihome-vacuum.0
                      2022-11-01 14:31:49.512	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      mihome-vacuum.0
                      2022-11-01 14:31:49.512	debug	Plugin sentry destroyed
                      mihome-vacuum.0
                      2022-11-01 14:31:49.511	info	terminating
                      mihome-vacuum.0
                      2022-11-01 14:31:49.511	error	Socket Close
                      mihome-vacuum.0
                      2022-11-01 14:31:49.510	info	Got terminate signal TERMINATE_YOURSELF
                      mihome-vacuum.0
                      2022-11-01 14:31:46.225	debug	Receive <<< Helo <<< 21310020000000001329b53563611fc2ffffffffffffffffffffffffffffffff
                      start:
                      mihome-vacuum.0
                      2022-11-01 14:33:45.680	debug	Receive <<< Helo <<< 21310020000000001329b53563612039ffffffffffffffffffffffffffffffff
                      mihome-vacuum.0
                      2022-11-01 14:33:37.677	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":39}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.669	debug	Message= {"id":39,"method":"get_carpet_mode"}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.669	debug	Mappointer_updated
                      mihome-vacuum.0
                      2022-11-01 14:33:37.669	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F16"],"id":38}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.661	debug	Message= {"id":38,"method":"get_map_v1"}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.661	debug	MIIO RECIVE: {"result":[90],"id":37}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.656	debug	Message= {"id":37,"method":"get_sound_volume"}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.551	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":36}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.517	debug	Message= {"id":36,"method":"get_network_info"}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.517	debug	setGetStatus {"msg_ver":2,"msg_seq":1987,"state":12,"battery":99,"clean_time":210,"clean_area":2332500,"error_code":8,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"Device stuck, clean area"}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.517	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1987,"state":12,"battery":99,"clean_time":210,"clean_area":2332500,"error_code":8,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":35}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.511	debug	Message= {"id":35,"method":"get_status"}
                      mihome-vacuum.0
                      2022-11-01 14:33:37.510	debug	get params for stock Vacuum
                      mihome-vacuum.0
                      2022-11-01 14:33:35.678	debug	Receive <<< Helo <<< 21310020000000001329b5356361202fffffffffffffffffffffffffffffffff
                      mihome-vacuum.0
                      2022-11-01 14:33:25.674	debug	Receive <<< Helo <<< 21310020000000001329b53563612025ffffffffffffffffffffffffffffffff
                      mihome-vacuum.0
                      2022-11-01 14:33:17.375	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":34}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.367	debug	Message= {"id":34,"method":"get_carpet_mode"}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.366	info	create state for carpet_mode
                      mihome-vacuum.0
                      2022-11-01 14:33:17.366	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.358	debug	Message= {"id":33,"method":"get_carpet_mode"}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.358	debug	Mappointer_updated
                      mihome-vacuum.0
                      2022-11-01 14:33:17.358	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F15"],"id":32}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.352	debug	Message= {"id":32,"method":"get_map_v1"}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.352	debug	Startup: Delete setGetConsumable
                      mihome-vacuum.0
                      2022-11-01 14:33:17.351	debug	Startup: setGetConsumable Answer: true
                      mihome-vacuum.0
                      2022-11-01 14:33:17.351	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":41889,"side_brush_work_time":41889,"filter_work_time":41889,"filter_element_work_time":0,"sensor_dirty_time":71089}],"id":31}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.339	debug	Message= {"id":31,"method":"get_consumable"}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.338	debug	Startup: Delete setGetCleanSummary
                      mihome-vacuum.0
                      2022-11-01 14:33:17.338	debug	Startup: setGetCleanSummary Answer: true
                      mihome-vacuum.0
                      2022-11-01 14:33:17.337	debug	finish logs all [{"Datum":"28.10","Start":"19:57","Saugzeit":"32 min","Fläche":"22.35 m²","Error":0,"Ende":true},{"Datum":"28.10","Start":"15:18","Saugzeit":"6 min","Fläche":"5.87 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:16","Saugzeit":"2 min","Fläche":"0 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:10","Saugzeit":"5 min","Fläche":"2.22 m²","Error":0,"Ende":false},{"Datum":"13.9","Start":"19:42","Saugzeit":"30 min","Fläche":"24.64 m²","Error":0,"Ende":true},{"Datum":"6.9","Start":"15:18","Saugzeit":"6 min","Fläche":"2 m²","Error":8,"Ende":false},{"Datum":"30.7","Start":"20:43","Saugzeit":"41 min","Fläche":"24.05 m²","Error":0,"Ende":true},{"Datum":"1.7","Start":"16:20","Saugzeit":"22 min","Fläche":"22.3 m²","Error":0,"Ende":true},{"Datum":"9.6","Start":"19:18","Saugzeit":"24 min","Fläche":"24.63 m²","Error":0,"Ende":true},{"Datum":"30.5","Start":"19:26","Saugzeit":"28 min","Fläche":"24.72 m²","Error":0,"Ende":true},{"Datum":"10.5","Start":"15:09","Saugzeit":"25 min","Fläche":"24.65 m²","Error":0,"Ende":true},{"Datum":"6.5","Start":"19:24","Saugzeit":"26 min","Fläche":"24.11 m²","Error":0,"Ende":true},{"Datum":"29.4","Start":"19:33","Saugzeit":"36 min","Fläche":"23.96 m²","Error":0,"Ende":true},{"Datum":"19.2","Start":"19:32","Saugzeit":"1 min","Fläche":"0.51 m²","Error":0,"Ende":false},{"Datum":"23.1","Start":"19:44","Saugzeit":"29 min","Fläche":"25.02 m²","Error":0,"Ende":true},{"Datum":"22.1","Start":"20:13","Saugzeit":"10 min","Fläche":"12.37 m²","Error":0,"Ende":false},{"Datum":"21.1","Start":"10:22","Saugzeit":"1 min","Fläche":"1.29 m²","Error":0,"Ende":false},{"Datum":"18.1","Start":"20:20","Saugzeit":"27 min","Fläche":"24.17 m²","Error":0,"Ende":true},{"Datum":"6.1","Start":"19:10","Saugzeit":"12 min","Fläche":"14.82 m²","Error":0,"Ende":false},{"Datum":"6.1","Start":"15:36","Saugzeit":"32 min","Fläche":"24.57 m²","Error":0,"Ende":true}]
                      mihome-vacuum.0
                      2022-11-01 14:33:17.337	debug	MIIO RECIVE: {"result":[[1641479793,1641486963,1910,24567500,0,1,2,1,52]],"id":30}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.323	debug	Message= {"id":30,"method":"get_clean_record","params":[1641479793]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.322	debug	MIIO RECIVE: {"result":[[1641492626,1641493350,696,14817500,0,0,2,1,60]],"id":29}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.313	debug	Message= {"id":29,"method":"get_clean_record","params":[1641492626]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.313	debug	MIIO RECIVE: {"result":[[1642533653,1642535288,1625,24167500,0,1,2,1,52]],"id":28}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.304	debug	Message= {"id":28,"method":"get_clean_record","params":[1642533653]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.303	debug	MIIO RECIVE: {"result":[[1642756938,1642756995,57,1292500,0,0,2,1,60]],"id":27}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.297	debug	Message= {"id":27,"method":"get_clean_record","params":[1642756938]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.297	debug	MIIO RECIVE: {"result":[[1642878816,1642879423,607,12367500,0,0,2,1,60]],"id":26}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.279	debug	Message= {"id":26,"method":"get_clean_record","params":[1642878816]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.278	debug	MIIO RECIVE: {"result":[[1642963476,1642965232,1756,25020000,0,1,2,1,52]],"id":25}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.266	debug	Message= {"id":25,"method":"get_clean_record","params":[1642963476]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.266	debug	MIIO RECIVE: {"result":[[1645295524,1645295556,32,512500,0,0,2,1,60]],"id":24}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.262	debug	Message= {"id":24,"method":"get_clean_record","params":[1645295524]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.261	debug	MIIO RECIVE: {"result":[[1651253588,1651255767,2179,23957500,0,1,2,1,52]],"id":23}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.256	debug	Message= {"id":23,"method":"get_clean_record","params":[1651253588]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.256	debug	MIIO RECIVE: {"result":[[1651857884,1651859471,1587,24110000,0,1,2,1,52]],"id":22}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.251	debug	Message= {"id":22,"method":"get_clean_record","params":[1651857884]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.251	debug	MIIO RECIVE: {"result":[[1652188174,1652189692,1518,24647500,0,1,2,1,52]],"id":21}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.240	debug	Message= {"id":21,"method":"get_clean_record","params":[1652188174]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.239	debug	MIIO RECIVE: {"result":[[1653931567,1653933520,1684,24717500,0,1,2,1,52]],"id":20}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.231	debug	Message= {"id":20,"method":"get_clean_record","params":[1653931567]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.224	debug	MIIO RECIVE: {"result":[[1654795117,1654796567,1450,24625000,0,1,2,1,52]],"id":19}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.218	debug	Message= {"id":19,"method":"get_clean_record","params":[1654795117]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.218	debug	MIIO RECIVE: {"result":[[1656685244,1656686572,1328,22302500,0,1,2,1,52]],"id":18}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.199	debug	Message= {"id":18,"method":"get_clean_record","params":[1656685244]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.197	debug	MIIO RECIVE: {"result":[[1659206624,1659209105,2481,24045000,0,1,2,1,52]],"id":17}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.184	debug	Message= {"id":17,"method":"get_clean_record","params":[1659206624]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.184	debug	MIIO RECIVE: {"result":[[1662470282,1662514759,383,2000000,8,0,2,1,34]],"id":16}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.175	debug	Message= {"id":16,"method":"get_clean_record","params":[1662470282]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.175	debug	MIIO RECIVE: {"result":[[1663090972,1663093345,1773,24642500,0,1,2,1,52]],"id":15}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.165	debug	Message= {"id":15,"method":"get_clean_record","params":[1663090972]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.165	debug	MIIO RECIVE: {"result":[[1666865404,1666865708,302,2215000,0,0,2,1,60]],"id":14}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.152	debug	Message= {"id":14,"method":"get_clean_record","params":[1666865404]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.151	debug	MIIO RECIVE: {"result":[[1666865760,1666909702,141,0,8,0,2,1,34]],"id":13}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.142	debug	Message= {"id":13,"method":"get_clean_record","params":[1666865760]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.142	debug	MIIO RECIVE: {"result":[[1666963083,1666979819,385,5867500,8,0,2,1,29]],"id":12}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.128	debug	Message= {"id":12,"method":"get_clean_record","params":[1666963083]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.126	debug	MIIO RECIVE: {"result":[[1666979871,1666981820,1949,22352500,0,1,2,1,52]],"id":11}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.113	debug	Message= {"id":11,"method":"get_clean_record","params":[1666979871]}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.110	debug	MIIO RECIVE: {"result":[76749,992120000,76,[1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816,1642756938,1642533653,1641492626,1641479793]],"id":10}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.097	debug	Message= {"id":10,"method":"get_clean_summary"}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.097	debug	Startup: Delete getMultiMapsList
                      mihome-vacuum.0
                      2022-11-01 14:33:17.096	debug	Startup: getMultiMapsList Answer: true
                      mihome-vacuum.0
                      2022-11-01 14:33:17.096	debug	States for Map: {"0":"0"}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.095	debug	States for 1 Map: [{"mapFlag":0,"add_time":1666981861,"length":0,"name":"","bak_maps":[]}]
                      mihome-vacuum.0
                      2022-11-01 14:33:17.095	debug	MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1666981861,"length":0,"name":"","bak_maps":[]}]}],"id":9}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.089	debug	Message= {"id":9,"method":"get_multi_maps_list"}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.089	debug	MIIO RECIVE: {"result":[90],"id":8}
                      mihome-vacuum.0
                      2022-11-01 14:33:17.076	debug	Message= {"id":8,"method":"get_sound_volume"}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.966	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":7}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.942	debug	Message= {"id":7,"method":"get_network_info"}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.941	debug	MIIO RECIVE: {"result":[],"id":6}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.932	debug	Message= {"id":6,"method":"get_room_mapping"}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.932	debug	Mappointer_updated
                      mihome-vacuum.0
                      2022-11-01 14:33:16.931	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F14"],"id":5}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.919	debug	Message= {"id":5,"method":"get_map_v1"}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.618	debug	MIIO RECIVE: {"result":["retry"],"id":4}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.612	debug	Message= {"id":4,"method":"get_map_v1"}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.400	info	settest next timer: not available
                      mihome-vacuum.0
                      2022-11-01 14:33:16.311	debug	MIIO RECIVE: {"result":["retry"],"id":3}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.303	debug	Message= {"id":3,"method":"get_map_v1"}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.180	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      mihome-vacuum.0
                      2022-11-01 14:33:16.128	info	create states for water box
                      mihome-vacuum.0
                      2022-11-01 14:33:16.128	info	change states from State control.fan_power
                      mihome-vacuum.0
                      2022-11-01 14:33:16.124	debug	setGetStatus {"msg_ver":2,"msg_seq":1986,"state":12,"battery":99,"clean_time":210,"clean_area":2332500,"error_code":8,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"Device stuck, clean area"}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.115	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1986,"state":12,"battery":99,"clean_time":210,"clean_area":2332500,"error_code":8,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":2}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.105	debug	Message= {"id":2,"method":"get_status"}
                      mihome-vacuum.0
                      2022-11-01 14:33:16.105	debug	get params for stock Vacuum
                      mihome-vacuum.0
                      2022-11-01 14:33:16.105	debug	Create State done!
                      mihome-vacuum.0
                      2022-11-01 14:33:16.105	debug	Create State for map: loadMap
                      mihome-vacuum.0
                      2022-11-01 14:33:16.105	debug	Create State for map: mapURL
                      mihome-vacuum.0
                      2022-11-01 14:33:16.104	debug	Create State for map: mapStatus
                      mihome-vacuum.0
                      2022-11-01 14:33:16.104	debug	Create State for map: actualMap
                      mihome-vacuum.0
                      2022-11-01 14:33:16.104	debug	Create State for map: map64
                      mihome-vacuum.0
                      2022-11-01 14:33:16.063	debug	Create State for map:
                      mihome-vacuum.0
                      2022-11-01 14:33:16.060	info	Map selected create states...
                      mihome-vacuum.0
                      2022-11-01 14:33:16.016	debug	Create State for Queue: clearQueue
                      mihome-vacuum.0
                      2022-11-01 14:33:15.973	debug	Create State for Queue: queue
                      mihome-vacuum.0
                      2022-11-01 14:33:15.803	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      mihome-vacuum.0
                      2022-11-01 14:33:15.789	info	select standard vacuum protocol....
                      mihome-vacuum.0
                      2022-11-01 14:33:15.788	debug	DeviceModel selected to: roborock.vacuum.a08
                      mihome-vacuum.0
                      2022-11-01 14:33:15.681	debug	Get Device data from robot.. {"hw_ver":"Linux","fw_ver":"3.5.8_1368","ap":{"ssid":"Headquarter","bssid":"80:3f:5d:ae:a7:13","rssi":-62},"netif":{"localIp":"192.168.1.15","mask":"255.255.248.0","gw":"192.168.0.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.a08","mac":"64:90:C1:13:B1:18","token":"544f6b574e4e5868504d335933373635","life":38123}
                      mihome-vacuum.0
                      2022-11-01 14:33:15.681	debug	Get Device data..0
                      mihome-vacuum.0
                      2022-11-01 14:33:15.681	debug	GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1368","ap":{"ssid":"Headquarter","bssid":"80:3f:5d:ae:a7:13","rssi":-62},"netif":{"localIp":"192.168.1.15","mask":"255.255.248.0","gw":"192.168.0.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.a08","mac":"64:90:C1:13:B1:18","token":"544f6b574e4e5868504d335933373635","life":38123}}
                      mihome-vacuum.0
                      2022-11-01 14:33:15.681	debug	MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1368","ap":{"ssid":"Headquarter","bssid":"80:3f:5d:ae:a7:13","rssi":-62},"netif":{"localIp":"192.168.1.15","mask":"255.255.248.0","gw":"192.168.0.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.a08","mac":"64:90:C1:13:B1:18","token":"544f6b574e4e5868504d335933373635","life":38123}}
                      mihome-vacuum.0
                      2022-11-01 14:33:15.676	debug	Message= {"id":1,"method":"miIO.info"}
                      mihome-vacuum.0
                      2022-11-01 14:33:15.674	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.a08","ack":true,"ts":1667308751970,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1640205614333}
                      mihome-vacuum.0
                      2022-11-01 14:33:15.669	debug	MAIN: Connected to device, try to get model..
                      mihome-vacuum.0
                      2022-11-01 14:33:15.669	debug	Receive <<< Helo <<< 21310020000000001329b5356361201bffffffffffffffffffffffffffffffff
                      mihome-vacuum.0
                      2022-11-01 14:33:15.661	debug	server started on 0.0.0.0:53421
                      mihome-vacuum.0
                      2022-11-01 14:33:15.659	info	IOT enabled, create state
                      mihome-vacuum.0
                      2022-11-01 14:33:15.658	debug	MIIO: Config: ip:192.168.1.15 token: 544f6b574e4e5868504d335933373635
                      mihome-vacuum.0
                      2022-11-01 14:33:15.657	debug	Create State for deviceInfowifi_signal
                      mihome-vacuum.0
                      2022-11-01 14:33:15.657	debug	Create State for deviceInfofw_ver
                      mihome-vacuum.0
                      2022-11-01 14:33:15.657	debug	Create State for deviceInfomodel
                      mihome-vacuum.0
                      2022-11-01 14:33:15.657	debug	Create State for deviceInfomac
                      mihome-vacuum.0
                      2022-11-01 14:33:15.656	debug	Create State for deviceInfo
                      mihome-vacuum.0
                      2022-11-01 14:33:15.549	info	starting. Version 3.8.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.17.0, js-controller: 4.0.23
                      mihome-vacuum.0
                      2022-11-01 14:33:15.314	debug	Plugin sentry Initialize Plugin (enabled=true)
                      und so raschelts weiter...
                      • D dirkhe
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @dirkhe
                        Hab das Log auf Info stehen. Damit habe ich alles soweit im Blick.
                        Mit WARN kann ich leben. Habe ich so gut wie keine.
                        ERROR fällt durch die rote Schrift natürlich auf.
                        Hab ich ebenfalls täglich so gut wie nix , bis gar nix.
                        Nur bei der 3.8.2 lief das Log durch das Timeout aus dem Ruder.
                        Da mit der 3.6.0 alles läuft, bleibe auch jetzt auch dabei.
                        Hab natürlich immer ein Auge auf neue Versionen ;)
                        • D dirkhe
                          da_WoodyD Offline
                          da_WoodyD Offline
                          @dirkhe oopsdate auf 3.8.3 gemacht. vorher gestoppt, nach start...
                          mihome-vacuum.0
                          2022-11-01 14:40:02.340	debug	Receive <<< Helo <<< 21310020000000001329b535636121b2ffffffffffffffffffffffffffffffff
                          mihome-vacuum.0
                          2022-11-01 14:39:55.864	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:53.862	debug	Message= {"id":16,"method":"get_map_v1"}
                          mihome-vacuum.0
                          2022-11-01 14:39:53.561	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:52.338	debug	Receive <<< Helo <<< 21310020000000001329b535636121a8ffffffffffffffffffffffffffffffff
                          mihome-vacuum.0
                          2022-11-01 14:39:51.560	debug	Message= {"id":15,"method":"get_map_v1"}
                          mihome-vacuum.0
                          2022-11-01 14:39:51.259	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:49.257	debug	Message= {"id":14,"method":"get_map_v1"}
                          mihome-vacuum.0
                          2022-11-01 14:39:48.955	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:46.953	debug	Message= {"id":13,"method":"get_map_v1"}
                          mihome-vacuum.0
                          2022-11-01 14:39:46.652	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:44.652	debug	Message= {"id":12,"method":"get_map_v1"}
                          mihome-vacuum.0
                          2022-11-01 14:39:44.652	debug	Startup: setGetConsumable Answer: false
                          mihome-vacuum.0
                          2022-11-01 14:39:44.651	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:42.650	debug	Message= {"id":11,"method":"get_consumable"}
                          mihome-vacuum.0
                          2022-11-01 14:39:42.650	debug	Startup: setGetCleanSummary Answer: false
                          mihome-vacuum.0
                          2022-11-01 14:39:42.650	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:42.335	debug	Receive <<< Helo <<< 21310020000000001329b5356361219effffffffffffffffffffffffffffffff
                          mihome-vacuum.0
                          2022-11-01 14:39:40.648	debug	Message= {"id":10,"method":"get_clean_summary"}
                          mihome-vacuum.0
                          2022-11-01 14:39:40.648	debug	Startup: Delete getMultiMapsList
                          mihome-vacuum.0
                          2022-11-01 14:39:40.648	debug	Startup: getMultiMapsList Answer: true
                          mihome-vacuum.0
                          2022-11-01 14:39:40.647	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:38.646	debug	Message= {"id":9,"method":"get_multi_maps_list"}
                          mihome-vacuum.0
                          2022-11-01 14:39:38.645	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:36.644	debug	Message= {"id":8,"method":"get_sound_volume"}
                          mihome-vacuum.0
                          2022-11-01 14:39:36.643	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:34.643	debug	Message= {"id":7,"method":"get_network_info"}
                          mihome-vacuum.0
                          2022-11-01 14:39:34.642	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:32.973	info	settest next timer: not available
                          mihome-vacuum.0
                          2022-11-01 14:39:32.642	debug	Message= {"id":6,"method":"get_status"}
                          mihome-vacuum.0
                          2022-11-01 14:39:32.641	debug	get params for stock Vacuum
                          mihome-vacuum.0
                          2022-11-01 14:39:32.641	debug	Create State done!
                          mihome-vacuum.0
                          2022-11-01 14:39:32.641	debug	Create State for map: loadMap
                          mihome-vacuum.0
                          2022-11-01 14:39:32.641	debug	Create State for map: mapURL
                          mihome-vacuum.0
                          2022-11-01 14:39:32.641	debug	Create State for map: mapStatus
                          mihome-vacuum.0
                          2022-11-01 14:39:32.640	debug	Create State for map: actualMap
                          mihome-vacuum.0
                          2022-11-01 14:39:32.640	debug	Create State for map: map64
                          mihome-vacuum.0
                          2022-11-01 14:39:32.600	debug	Create State for map:
                          mihome-vacuum.0
                          2022-11-01 14:39:32.552	debug	Create State for Queue: clearQueue
                          mihome-vacuum.0
                          2022-11-01 14:39:32.513	debug	Create State for Queue: queue
                          mihome-vacuum.0
                          2022-11-01 14:39:32.416	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                          mihome-vacuum.0
                          2022-11-01 14:39:32.408	info	select standard vacuum protocol....
                          mihome-vacuum.0
                          2022-11-01 14:39:32.407	debug	DeviceModel selected to: roborock.vacuum.a08
                          mihome-vacuum.0
                          2022-11-01 14:39:32.342	warn	No Answer for DeviceModel use model from Config
                          mihome-vacuum.0
                          2022-11-01 14:39:32.342	warn	No Answer for DeviceModel use old one
                          mihome-vacuum.0
                          2022-11-01 14:39:32.342	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                          mihome-vacuum.0
                          2022-11-01 14:39:32.342	debug	Get Device data..4
                          mihome-vacuum.0
                          2022-11-01 14:39:32.342	debug	GETMODELFROMAPI:Data: {}
                          mihome-vacuum.0
                          2022-11-01 14:39:32.341	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:32.332	debug	Receive <<< Helo <<< 21310020000000001329b53563612194ffffffffffffffffffffffffffffffff
                          mihome-vacuum.0
                          2022-11-01 14:39:30.341	debug	Message= {"id":5,"method":"miIO.info"}
                          mihome-vacuum.0
                          2022-11-01 14:39:30.340	debug	Get Device data..3
                          mihome-vacuum.0
                          2022-11-01 14:39:30.340	debug	GETMODELFROMAPI:Data: {}
                          mihome-vacuum.0
                          2022-11-01 14:39:30.340	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:28.340	debug	Message= {"id":4,"method":"miIO.info"}
                          mihome-vacuum.0
                          2022-11-01 14:39:28.340	debug	Get Device data..2
                          mihome-vacuum.0
                          2022-11-01 14:39:28.340	debug	GETMODELFROMAPI:Data: {}
                          mihome-vacuum.0
                          2022-11-01 14:39:28.337	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:26.336	debug	Message= {"id":3,"method":"miIO.info"}
                          mihome-vacuum.0
                          2022-11-01 14:39:26.336	debug	Get Device data..1
                          mihome-vacuum.0
                          2022-11-01 14:39:26.336	debug	GETMODELFROMAPI:Data: {}
                          mihome-vacuum.0
                          2022-11-01 14:39:26.335	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:24.334	debug	Message= {"id":2,"method":"miIO.info"}
                          mihome-vacuum.0
                          2022-11-01 14:39:24.334	debug	Get Device data..0
                          mihome-vacuum.0
                          2022-11-01 14:39:24.334	debug	GETMODELFROMAPI:Data: {}
                          mihome-vacuum.0
                          2022-11-01 14:39:24.334	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                          mihome-vacuum.0
                          2022-11-01 14:39:22.332	debug	Message= {"id":1,"method":"miIO.info"}
                          mihome-vacuum.0
                          2022-11-01 14:39:22.331	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.a08","ack":true,"ts":1667309865791,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1640205614333}
                          mihome-vacuum.0
                          2022-11-01 14:39:22.328	debug	MAIN: Connected to device, try to get model..
                          mihome-vacuum.0
                          2022-11-01 14:39:22.328	debug	Receive <<< Helo <<< 21310020000000001329b5356361218affffffffffffffffffffffffffffffff
                          mihome-vacuum.0
                          2022-11-01 14:39:22.311	debug	server started on 0.0.0.0:53421
                          mihome-vacuum.0
                          2022-11-01 14:39:22.308	info	IOT enabled, create state
                          mihome-vacuum.0
                          2022-11-01 14:39:22.302	debug	MIIO: Config: ip:192.168.1.15 token: 544f6b574eXXXXXXXXX
                          mihome-vacuum.0
                          2022-11-01 14:39:22.301	debug	Create State for deviceInfowifi_signal
                          mihome-vacuum.0
                          2022-11-01 14:39:22.301	debug	Create State for deviceInfofw_ver
                          mihome-vacuum.0
                          2022-11-01 14:39:22.301	debug	Create State for deviceInfomodel
                          mihome-vacuum.0
                          2022-11-01 14:39:22.300	debug	Create State for deviceInfomac
                          mihome-vacuum.0
                          mihome-vacuum.0
                          2022-11-01 14:39:22.213	info	starting. Version 3.8.3 (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.17.0, js-controller: 4.0.23
                          mihome-vacuum.0
                          2022-11-01 14:39:21.834	debug	Plugin sentry Initialize Plugin (enabled=true)
                          nach umstellen auf warn ist wieder ruhe. aber tögal, mir gings ja eigentlich nur um die map wegen canvas. da liegt ja das prob mit der map...
                          https://forum.iobroker.net/topic/59480/test-für-mihome-vacuum/31
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            mihome-vacuum.0
                            @da_woody
                            Setz canvas nochmal in das Verzeichnis.
                            cd /opt/iobroker/node_modules/iobroker.mihome-vacuum/
                            sudo -H -u iobroker npm install canvas --omit=dev
                              @da_woody
                              da_WoodyD Offline
                              da_WoodyD Offline
                              @thomas-braun ok...
                              woody@ioBroker:/opt/iobroker/node_modules/iobroker.mihome-vacuum$ npm ls canvas
                              iobroker.mihome-vacuum@3.8.3 /opt/iobroker/node_modules/iobroker.mihome-vacuum
                              └── canvas@2.10.2
                              sieht IMHO schon besser aus.
                              den saubartel neu gestartet, adapter neu, grün, start einer reinigung, keine kartenaktualisierung.
                              ich verwende in iQontrol mihome-vacuum.0.cleanmap.map64 für die map. hat ja auch einige zeit funktioniert.
                                @thomas-braun ok...
                                └── canvas@2.10.2
                                @da_woody
                                cd /opt/iobroker
                                npm ls canvas
                                  @da_woody
                                  cd /opt/iobroker
                                  npm ls canvas
                                  da_WoodyD Offline
                                  da_WoodyD Offline
                                  @thomas-braun sagte in Test für mihome-vacuum:
                                  npm ls canvas
                                  woody@ioBroker:/opt/iobroker$ npm ls canvas
                                  [sudo] Passwort für woody:
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├── canvas@2.10.2
                                  ├─┬ iobroker.energiefluss@1.3.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#410151c990ec5f34351dbe28f14355cbc956be2d)
                                  │ └── canvas@2.10.2 deduped
                                  ├─┬ iobroker.iot@1.12.2
                                  │ ├── canvas@2.10.2 deduped
                                  │ └─┬ jsdom@20.0.0
                                  └─┬ iobroker.mihome-vacuum@3.8.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.mihome-vacuum.git#e388a842078214f55aaade2fdb3a91f8b2009035)
                                    └── canvas@2.10.2
                                    npm ls canvas
                                    ├── canvas@2.10.2
                                    │ └─┬ jsdom@20.0.0
                                      └── canvas@2.10.2
                                    @da_woody
                                    Bei mir funktionierts es damit.
                                    Du hast aber auch mal canvas eine Verzeichnis-Ebene zu hoch reingehauen.
                                    Das sollte imho nicht direkt unter iobroker.inst hängen.
                                    Bei mir jedenfalls nicht.
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      dirkhe
                                      @da_woody Also wenn ich mir das log so ansehe, kommt da "Mappointer_updated" danach müsste im debug eigentlich ein 'update_Map Mimap enabled' kommen, tut es aber nicht. Kann es sein, dass der Haken bei der Karte nicht mehr aktiv ist?
                                      @haselchen Es hat sich generell nichts an der Logik getan, also die 3.8.x is, was die timeouts angeht genauso wie die 3.6.0, nur das Logging ist anders. Egal welche Version des Adapters du nimmst, kann es sein, dass du bis zu 10 minuten nach dem Start warten mußt, bis alles funktioniert oder halt sofort.
                                        @da_woody
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        tja, als tux.png kennst du dich aus.
                                        hast du nen tip, wie ich das wieder hinbiegen kann? offensichtlich wird das zeuch ja für einiges verwendet.
                                        warum wird das ding dann immer wieder installiert und dann als "deduped" gekennzeichnet?
                                          Es wird ja eben NICHT x-fach installiert, sondern 'deduped' bedeutet, dass die Doubletten entfernt wurden und da nur Links zur eigentlichen Installation liegen. Ich vermute allerdings, dass der mihome-vaccuum mit diesen Links nicht parat kommt und nur auf eine richtige Installation zurückgreifen kann.
