  4. Kann nichts mehr im Dateimanager löschen
    1.0k
    6.1k
vis
16 Beiträge 7 Kommentatoren 1.5k Aufrufe 7 Beobachtet
  • sigi234S Online
    sigi234S Online
    Hallo, beim löschen im Dateimanager bekomme ich folgende Fehler:
    web.0
    2022-10-29 11:59:36.270	info	socket.io server listening on port 8082
    web.0
    2022-10-29 11:59:35.841	info	starting. Version 5.2.10 in C:/ioBroker/node_modules/iobroker.web, node: v16.18.0, js-controller: 4.0.23
    host.Medion
    2022-10-29 11:59:33.905	info	instance system.adapter.web.0 started with pid 9080
    host.Medion
    2022-10-29 11:59:03.766	info	Restart adapter system.adapter.web.0 because enabled
    host.Medion
    2022-10-29 11:59:03.766	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.Medion
    2022-10-29 11:59:03.766	error	Caught by controller[0]: at parseType (C:\ioBroker\node_modules\redis-parser\lib\parser.js:302:14)
    host.Medion
    2022-10-29 11:59:03.766	error	Caught by controller[0]: at parseError (C:\ioBroker\node_modules\redis-parser\lib\parser.js:179:12)
    host.Medion
    2022-10-29 11:59:03.765	error	Caught by controller[0]: ReplyError: Error ERROR readDir id=vis: ENOTDIR: not a directory, scandir 'C:\ioBroker\iobroker-data\files\vis\cache.manifest\'
    web.0
    2022-10-29 11:59:03.670	error	Error ERROR readDir id=vis: ENOTDIR: not a directory, scandir 'C:\ioBroker\iobroker-data\files\vis\cache.manifest\'
    web.0
    2022-10-29 11:59:03.670	error	ReplyError: Error ERROR readDir id=vis: ENOTDIR: not a directory, scandir 'C:\ioBroker\iobroker-data\files\vis\cache.manifest\' at parseError (C:\ioBroker\node_modules\redis-parser\lib\parser.js:179:12) at parseType (C:\ioBroker\node_modules\redis-parser\lib\parser.js:302:14)
    web.0
    2022-10-29 11:59:03.668	error	uncaught exception: Error ERROR readDir id=vis: ENOTDIR: not a directory, scandir 'C:\ioBroker\iobroker-data\files\vis\cache.manifest\'
    host.Medion-Server
    2022-10-29 11:59:03.659	warn	Objects 127.0.0.1:1913 Error from InMemDB: Error: ERROR readDir id=vis: ENOTDIR: not a directory, scandir 'C:\ioBroker\iobroker-data\files\vis\cache.manifest\'
    Plattform: Windows
    RAM: 16 GB
    NODE.JS: V16.18.0
    NPM: 8.19.2
    JS Controller: 4.0.23
    Admin: 6.2.23
    WS: 2.1.3
    WEB: 5.2.10
    Socket.io: 6.1.8
    Script Engine: 6.0.3
    IOT: 1.12.2
    VIS: 1.4.15
    H 1 Antwort Letzte Antwort
    • sigi234S sigi234
      web.0
      web.0
      host.Medion
      host.Medion
      host.Medion
      host.Medion
      host.Medion
      host.Medion
      web.0
      web.0
      web.0
      host.Medion-Server
      Plattform: Windows
      RAM: 16 GB
      NODE.JS: V16.18.0
      NPM: 8.19.2
      Admin: 6.2.23
      WS: 2.1.3
      WEB: 5.2.10
      Socket.io: 6.1.8
      IOT: 1.12.2
      VIS: 1.4.15
      helfi9999
      @sigi234 versuche mal diese Einstellung:
      und den Adapter ws
      Intel NUC mit Iobroker
      • H helfi9999
        und den Adapter ws
        sigi234S Online
        sigi234S Online
        @helfi9999
        Leider nein
        • sigi234S sigi234
          @helfi9999
          Leider nein
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @sigi234 Der Einfachheit halber: Rechner mal neu gestartet ?
          Lehrling seit 1975 !!!
          • DJMarc75D DJMarc75
            sigi234S Online
            sigi234S Online
            @djmarc75 sagte in Kann nichts mehr im Dateimanager löschen:
            Jupp,
            host.Medion
            2022-10-29 12:50:35.560	error	instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:31.534	error	instance system.adapter.hs100.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:27.477	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:23.911	error	instance system.adapter.echarts.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:11.666	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:07.762	error	instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.Medion
            2022-10-29 12:50:03.318	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            backitup.0
            7816	2022-10-29 12:50:02.745	error	backitup.0 already running
            host.Medion
            2022-10-29 12:50:00.480	error	instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            info.0
            8316	2022-10-29 12:49:59.914	error	info.0 already running
            host.Medion
            2022-10-29 12:49:56.374	error	instance system.adapter.musiccast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            musiccast.0
            12480	2022-10-29 12:49:55.796	error	musiccast.0 already running
            host.Medion
            2022-10-29 12:49:48.187	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            web.0
            13500	2022-10-29 12:49:47.575	error	web.0 already running
            host.Medion
            2022-10-29 12:49:43.762	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            discovery.0
            9224	2022-10-29 12:49:43.203	error	discovery.0 already running
            host.Medion
            2022-10-29 12:49:42.536	error	instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            meross.0
            14272	2022-10-29 12:49:41.955	error	meross.0 already running
            host.Medion
            2022-10-29 12:49:41.416	error	instance system.adapter.p
            Diese Fehler kommen nach jedem Neustart, gehen aber nach 5 Minuten weg.
            • sigi234S sigi234
              Jupp,
              host.Medion
              host.Medion
              host.Medion
              host.Medion
              host.Medion
              host.Medion
              host.Medion
              backitup.0
              host.Medion
              info.0
              host.Medion
              musiccast.0
              host.Medion
              web.0
              host.Medion
              discovery.0
              host.Medion
              meross.0
              host.Medion
              HomoranH Offline
              HomoranH Offline
              @sigi234 sagte in Kann nichts mehr im Dateimanager löschen:
              da laufen die Prozesse noch. Da ist beim Neustart anscheinend nicht korrekt beendet worden.
              welche admin Version?
                sigi234S Online
                sigi234S Online
                @homoran sagte in Kann nichts mehr im Dateimanager löschen:
                6.2.23
                • sigi234S sigi234
                  6.2.23
                  HomoranH Offline
                  HomoranH Offline
                  @sigi234 hätte mich bei dir auch gewundert wenn das noch 6.2,22 gewesen wäre. War aber mein letzter Strohhalm.
                    sigi234S Online
                    sigi234S Online
                    Bernd1967B 1 Antwort Letzte Antwort
                    • sigi234S sigi234
                      Bernd1967B Offline
                      Bernd1967B Offline
                      Bernd1967
                      @sigi234
                      Ich weiß, ist schon lange her, aber konntest Du das Problem damals irgendwie lösen ?
                      Hab das Problem auchmit vis-2.
                      • Bernd1967B Bernd1967
                        @sigi234
                        sigi234S Online
                        sigi234S Online
                        @bernd1967 sagte in Kann nichts mehr im Dateimanager löschen:
                        @sigi234
                        Selbe Fehlermeldungen?
                        • sigi234S sigi234
                          @sigi234
                          MartinPM Online
                          MartinPM Online
                          MartinP
                          Selbes Betriebssystem wäre meine erste Frage gewesen....
                          iobroker unter Windows zu installieren, würde mir nicht einfallen ;-)
                          • MartinPM MartinP
                            Bernd1967B Offline
                            Bernd1967B Offline
                            Bernd1967
                            @martinp
                            Unter Windows läuft sonst alles super.
                              @martinp
                              MartinPM Online
                              MartinPM Online
                              MartinP
                              @bernd1967 Naja, ich vermute schon dass nur ein verschwindend geringer Prozentsatz der iobroker Installationen unter Windows läuft...
                              Falls das ein Windows-Spezifisches Problem ist, ist die Wahrscheinlichkeit eben recht gering, dass jemand über die gleiche Sache gestolpert ist, und deshalb Hilfestellung leisten kann ...
                              Zur Meldung:
                              error Caught by controller[0]: ReplyError: Error ERROR readDir id=vis: ENOTDIR: not a directory, scandir 'C:\ioBroker\iobroker-data\files\vis\cache.manifest'
                              cache.manifest ist bei mir unter Linux auch kein Directory ...
                              • GaspodeG Offline
                                GaspodeG Offline
                                Gaspode
                                @Bernd1967
                                Welche ioBroker Version nutzt du denn? Welchen Controller? Wie hast du installiert?
                                Beschreibe mal bitte die Schritte, mit denen du das Problem reproduzieren kannst und poste ein Log mit den Fehler-Ausgaben.
                                Ein "Hab das gleiche Problem" auf einen über zwei Jahre alten Beitrag ohne weitere Infos ist ein wenig Info, zumal das Problem der scheinbar noch laufenden Prozesse nach Neustart inzwischen behoben wurde. Ob das zusammen hängt ist natürlich eine andere Frage.
                                Also: Bitte mehr Details, dann würde ich das auch testweise mal hier bei mir nachstellen.
                                • GaspodeG Gaspode
                                  @Bernd1967
                                  Bernd1967B Offline
                                  Bernd1967B Offline
                                  Bernd1967
                                  schrieb am zuletzt editiert von Bernd1967
                                  @gaspode
                                  Hier hatte ich nur nachgefragt weil der Fehler bei bestimmten Punkten ähnlich ist.
                                  Hier hatte ich die Daten gepostet.
