  4. Kann nichts mehr im Dateimanager löschen
    1.0k
    6.1k
vis
16 Beiträge 7 Kommentatoren 1.5k Aufrufe 7 Beobachtet
  • sigi234S sigi234
    @helfi9999
    Leider nein
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @sigi234 Der Einfachheit halber: Rechner mal neu gestartet ?
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
      sigi234S Online
      sigi234S Online
      @djmarc75 sagte in Kann nichts mehr im Dateimanager löschen:
      Jupp,
      host.Medion
      2022-10-29 12:50:35.560	error	instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.Medion
      2022-10-29 12:50:31.534	error	instance system.adapter.hs100.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.Medion
      2022-10-29 12:50:27.477	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.Medion
      2022-10-29 12:50:23.911	error	instance system.adapter.echarts.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.Medion
      2022-10-29 12:50:11.666	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.Medion
      2022-10-29 12:50:07.762	error	instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.Medion
      2022-10-29 12:50:03.318	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      backitup.0
      7816	2022-10-29 12:50:02.745	error	backitup.0 already running
      host.Medion
      2022-10-29 12:50:00.480	error	instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      info.0
      8316	2022-10-29 12:49:59.914	error	info.0 already running
      host.Medion
      2022-10-29 12:49:56.374	error	instance system.adapter.musiccast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      musiccast.0
      12480	2022-10-29 12:49:55.796	error	musiccast.0 already running
      host.Medion
      2022-10-29 12:49:48.187	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      web.0
      13500	2022-10-29 12:49:47.575	error	web.0 already running
      host.Medion
      2022-10-29 12:49:43.762	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      discovery.0
      9224	2022-10-29 12:49:43.203	error	discovery.0 already running
      host.Medion
      2022-10-29 12:49:42.536	error	instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      meross.0
      14272	2022-10-29 12:49:41.955	error	meross.0 already running
      host.Medion
      2022-10-29 12:49:41.416	error	instance system.adapter.p
      Diese Fehler kommen nach jedem Neustart, gehen aber nach 5 Minuten weg.
      • sigi234S sigi234
        Jupp,
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        host.Medion
        backitup.0
        host.Medion
        info.0
        host.Medion
        musiccast.0
        host.Medion
        web.0
        host.Medion
        discovery.0
        host.Medion
        meross.0
        host.Medion
        HomoranH Offline
        HomoranH Offline
        @sigi234 sagte in Kann nichts mehr im Dateimanager löschen:
        da laufen die Prozesse noch. Da ist beim Neustart anscheinend nicht korrekt beendet worden.
        welche admin Version?
          sigi234S Online
          sigi234S Online
          @homoran sagte in Kann nichts mehr im Dateimanager löschen:
          6.2.23
          • sigi234S sigi234
            6.2.23
            HomoranH Offline
            HomoranH Offline
            @sigi234 hätte mich bei dir auch gewundert wenn das noch 6.2,22 gewesen wäre. War aber mein letzter Strohhalm.
              sigi234S Online
              sigi234S Online
              Bernd1967B 1 Antwort Letzte Antwort
              • sigi234S sigi234
                Bernd1967B Offline
                Bernd1967B Offline
                Bernd1967
                @sigi234
                Ich weiß, ist schon lange her, aber konntest Du das Problem damals irgendwie lösen ?
                Hab das Problem auchmit vis-2.
                • Bernd1967B Bernd1967
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  @bernd1967 sagte in Kann nichts mehr im Dateimanager löschen:
                  @sigi234
                  Selbe Fehlermeldungen?
                  • sigi234S sigi234
                    @sigi234
                    MartinPM Offline
                    MartinPM Offline
                    MartinP
                    Selbes Betriebssystem wäre meine erste Frage gewesen....
                    iobroker unter Windows zu installieren, würde mir nicht einfallen ;-)
                    • MartinPM MartinP
                      Bernd1967B Offline
                      Bernd1967B Offline
                      Bernd1967
                      @martinp
                      Unter Windows läuft sonst alles super.
                        @martinp
                        MartinPM Offline
                        MartinPM Offline
                        MartinP
                        @bernd1967 Naja, ich vermute schon dass nur ein verschwindend geringer Prozentsatz der iobroker Installationen unter Windows läuft...
                        Falls das ein Windows-Spezifisches Problem ist, ist die Wahrscheinlichkeit eben recht gering, dass jemand über die gleiche Sache gestolpert ist, und deshalb Hilfestellung leisten kann ...
                        Zur Meldung:
                        error Caught by controller[0]: ReplyError: Error ERROR readDir id=vis: ENOTDIR: not a directory, scandir 'C:\ioBroker\iobroker-data\files\vis\cache.manifest'
                        cache.manifest ist bei mir unter Linux auch kein Directory ...
                        • GaspodeG Offline
                          GaspodeG Offline
                          Gaspode
                          @Bernd1967
                          Welche ioBroker Version nutzt du denn? Welchen Controller? Wie hast du installiert?
                          Beschreibe mal bitte die Schritte, mit denen du das Problem reproduzieren kannst und poste ein Log mit den Fehler-Ausgaben.
                          Ein "Hab das gleiche Problem" auf einen über zwei Jahre alten Beitrag ohne weitere Infos ist ein wenig Info, zumal das Problem der scheinbar noch laufenden Prozesse nach Neustart inzwischen behoben wurde. Ob das zusammen hängt ist natürlich eine andere Frage.
                          Also: Bitte mehr Details, dann würde ich das auch testweise mal hier bei mir nachstellen.
                          • GaspodeG Gaspode
                            @Bernd1967
                            Bernd1967B Offline
                            Bernd1967B Offline
                            Bernd1967
                            schrieb am zuletzt editiert von Bernd1967
                            @gaspode
                            Hier hatte ich nur nachgefragt weil der Fehler bei bestimmten Punkten ähnlich ist.
                            Hier hatte ich die Daten gepostet.
