  3. Einsteigerfragen
  4. JS-Controller update, was jetzt
    5.6k
47 Beiträge 2 Kommentatoren 8.4k Aufrufe 2 Beobachtet
  • S silbroker
    pi@raspberrypi:~ $ curl -sL https:deb.nodesource.com/setup_16.x | sudo -E bash -                             pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    pi@raspberrypi:~ $ apt policy nodejs
    nodejs:
      Installed: 12.22.12-deb-1nodesource1
      Candidate: 12.22.12-deb-1nodesource1
      Version table:
     *** 12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    pi@raspberrypi:~ $
    jetzt habe ich 12.22.12
    @silbroker
    sudo apt update
    apt policy nodejs
    • S silbroker
      nodejs:
        Version table:
      pi@raspberrypi:~ $
      @silbroker
      Und mal in die
      cat /etc/apt/sources.list.d/nodesource.list
      schauen.
        @silbroker
        Und mal in die
        schauen.
        silbroker
        pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/nodesource.list
        deb https://deb.nodesource.com/node_12.x buster main
        deb-src https://deb.nodesource.com/node_12.x buster main
        so?
        • S silbroker
          so?
          @silbroker
          Nach dem Installationsskript für nodejs16 sollte die eigentlich so aussehen:
          deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
          Was sagt denn:
          curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
          so?
            @silbroker
            Was sagt denn:
            so?
            silbroker
            pi@raspberrypi:~ $ sudo apt install -y nodejs
            The following packages will be upgraded:
              nodejs
            1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Need to get 24.2 MB of archives.
            After this operation, 2,727 kB of additional disk space will be used.
            Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.18.0-deb-1nodesource1 [24.2 MB]
            Fetched 24.2 MB in 2s (10.3 MB/s)
            apt-listchanges: Reading changelogs...
            (Reading database ... 57436 files and directories currently installed.)
            Preparing to unpack .../nodejs_16.18.0-deb-1nodesource1_armhf.deb ...
            Unpacking nodejs (16.18.0-deb-1nodesource1) over (14.20.1-deb-1nodesource1) ...
            Setting up nodejs (16.18.0-deb-1nodesource1) ...
            Processing triggers for man-db (2.8.5-2) ...
            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
            deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
            pi@raspberrypi:~ $
            jetzt ist gegangen.
            • S silbroker
                nodejs
              pi@raspberrypi:~ $
              jetzt ist gegangen.
              @silbroker sagte in JS-Controller update, was jetzt:
              Wo kam denn die 14.20.1 nun her?
                silbroker
                habe zuerst die 14er kopiert und ausgeführt
                und dann gemerkt das es geht.
                Danach noch die 16er
                • S silbroker
                    nodejs
                  pi@raspberrypi:~ $
                  jetzt ist gegangen.
                  @silbroker
                  Und was kommt bei
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  jetzt um's Eck?
                  • S silbroker
                    Mach bitte nicht irgendwas nebenher von dem ich nichts weiß. Das macht es nicht leichter dir zu helfen! Im Gegenteil...
                      @silbroker
                      Und was kommt bei
                      jetzt um's Eck?
                      silbroker
                      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.18.0
                      v16.18.0
                      8.19.2
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      /home/pi
                      Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                      nodejs:
                        Installed: 16.18.0-deb-1nodesource1
                        Candidate: 16.18.0-deb-1nodesource1
                        Version table:
                       *** 16.18.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                      • S silbroker
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.18.0
                        v16.18.0
                        8.19.2
                        pi
                        /home/pi
                        nodejs:
                          Version table:
                        @silbroker
                        iobroker restart
                        iobroker status
                          @silbroker
                          iobroker restart
                          iobroker status
                          silbroker
                          pi@raspberrypi:~ $ iobroker restart
                          pi@raspberrypi:~ $ iobroker status
                          node:internal/modules/cjs/loader:988
                            throw err;
                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                              at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                              at node:internal/main/run_main_module:22:47 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          pi@raspberrypi:~ $
                          • S silbroker
                              throw err;
                              requireStack: []
                            pi@raspberrypi:~ $
                            @silbroker
                            iobroker stop
                            cd /opt/iobroker
                            sudo -H -u iobroker npm install iobroker.js-controller
                            iobroker start
                              @silbroker
                              iobroker stop
                              cd /opt/iobroker
                              iobroker start
                              silbroker
                              @thomas-braun sagte in JS-Controller update, was jetzt:
                              iobroker start
                              pi@raspberrypi:~ $ cd /opt/iobroker
                              pi@raspberrypi:/opt/iobroker $
                              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                              npm WARN old lockfile
                              npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                              npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                              npm WARN old lockfile This is a one-time fix-up, please be patient...
                              npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
                              added 682 packages, removed 21 packages, and changed 29 packages in 2m
                              101 packages are looking for funding
                                run `npm fund` for details
                              pi@raspberrypi:/opt/iobroker $ iobroker start
                              jetzt ist sie wieder online. Muss ich sonst noch etwas machen / beachten?
                              • S silbroker
                                iobroker start
                                @silbroker
                                iobroker update -i
                                iobroker status
                                  @silbroker
                                  iobroker update -i
                                  iobroker status
                                  silbroker
                                  pi@raspberrypi:/opt/iobroker $ iobroker update -i
                                  Used repository: beta
                                  Adapter    "admin"        : 6.2.23   , installed 4.1.12 [Updatable]
                                  Adapter    "deconz"       : 1.3.21   , installed 2.0.5
                                  Adapter    "info"         : 1.9.21   , installed 1.9.21
                                  Adapter    "jarvis"       : 3.0.15   , installed 2.2.5  [Updatable]
                                  Adapter    "javascript"   : 6.0.3    , installed 4.10.8 [Updatable]
                                  Controller "js-controller": 4.0.23   , installed 4.0.23
                                  Adapter    "loxone"       : 3.0.0    , installed 2.2.3  [Updatable]
                                  Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                                  Adapter    "shelly"       : 6.2.4    , installed 4.1.2  [Updatable]
                                  Adapter    "socketio"     : 6.1.10   , installed 3.1.5  [Updatable]
                                  Adapter    "sonos"        : 2.2.3    , installed 2.1.1  [Updatable]
                                  Adapter    "web"          : 5.2.10   , installed 3.1.0  [Updatable]
                                  pi@raspberrypi:/opt/iobroker $ iobroker status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  • S silbroker
                                    Objects type: jsonl
                                    States  type: jsonl
                                    @silbroker Was willste denn mit dem alten Kram beta-testen?
                                    Stell das Repo auf stable und dann zieh das alles auf den stabilen Stand.
                                    • S silbroker
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Und was ist das für eine Version?
                                      deconz
                                      github:	1.3.21
                                      latest:	1.3.21 for 5 months
                                      stable:	1.3.21 for 5 months
                                        deconz
                                        github:	1.3.21
                                        silbroker
                                        Das konnte ich nicht updaten weil der JS-Controller zu alt war. 🤔
                                        • S silbroker
                                          Und nicht nur der...
                                          iob repo list
