  4. iobroker kaputt nach NodeJS Update
75 Beiträge 3 Kommentatoren 6.0k Aufrufe 4 Beobachtet
    @michaelheiml
    Unabhängig voneinander eingeben, nicht in einem Rutsch...
    Btw:
    echad@chet:/opt/iobroker $ ls -la /opt/iobroker/node_modules/iobroker.js-controller/
    total 392
    drwxrwxr-x+   7 iobroker iobroker   4096 Oct  9 11:54 .
    drwxrwxr-x+ 704 iobroker iobroker  36864 Oct 10 17:13 ..
    drwxrwxr-x+   2 iobroker iobroker   4096 Jul 30 03:42 backups
    -rw-rwxr--+   1 iobroker iobroker    420 Jul 29 20:20 compactgroupController.js
    drwxrwxr-x+   2 iobroker iobroker   4096 Jul 29 20:20 conf
    -rw-rwxr--+   1 iobroker iobroker    158 Jul 29 20:20 controller.js
    -rwxrwxr-x+   1 iobroker iobroker     34 Jul 29 20:20 iobroker.js
    -rw-rwxr--+   1 iobroker iobroker  54395 Jul 29 20:20 io-package.json
    drwxrwxr-x+   9 iobroker iobroker   4096 Jul 29 20:20 lib
    -rw-rwxr--+   1 iobroker iobroker   1135 Jul 29 20:20 LICENSE
    -rw-rwxr--+   1 iobroker iobroker 249293 Jul 29 20:20 main.js
    drwxrwxr-x+   5 iobroker iobroker   4096 Jul 29 20:20 node_modules
    -rw-rwxr--+   1 iobroker iobroker   3277 Jul 29 20:20 package.json
    -rw-rw-r--+   1 iobroker iobroker    177 Oct 10 17:14 pids.txt
    -rw-rwxr--+   1 iobroker iobroker    193 Jul 29 20:20 README.md
    drwxrwxr-x+   2 iobroker iobroker   4096 Oct 10 03:42 tmp
    michaelheiml
    pi@raspberrypi:/opt/iobroker $ iob status
    node:internal/modules/cjs/loader:959
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
        at Function.Module._load (node:internal/modules/cjs/loader:804:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    pi@raspberrypi:/opt/iobroker $ iob setup first
      throw err;
      requireStack: []
      @michaelheiml
      Btw:
      total 392
      michaelheiml
      Der Ordner sieht bei mir gänzlich anders aus. Keine .js Dateien. Kann es sein, dass durch irgendeinen Fehler von mir ich die Windows Version von iobroker installiert habe?
      • M michaelheiml
        @michaelheiml sagte in iobroker kaputt nach NodeJS Update:
        Kann ich dir nicht sagen. Ich weiß ja nicht was du da veranstaltet hast.
        • M michaelheiml
          Wie sieht der denn aus?
            michaelheiml
            Offenbar einen Quark ;)
            Na jedenfalls.. das ist mein Ordner Inhalt:
            iob.bat
            iobroker.bat
            lib
            LICENSE
            node_modules
            _service_iobroker.bat
            Mehr nicht.
            Thomas BraunT M 2 Antworten Letzte Antwort
            • M michaelheiml
              iob.bat
              iobroker.bat
              lib
              LICENSE
              node_modules
              Mehr nicht.
              @michaelheiml
              Kopier dir doch den Befehl den ich auch verwendet habe. Dann reden wir über das gleiche.
              • M michaelheiml
                iob.bat
                iobroker.bat
                lib
                LICENSE
                node_modules
                Mehr nicht.
                michaelheiml
                @michaelheiml
                Zum Installieren habe ich jedenfalls den Befehl aus der Anleitung verwendet.
                curl -sLf https://iobroker.net/install.sh | bash -
                pi@raspberrypi:/opt/iobroker/node_modules/iobroker.js-controller $ ls -la /opt/iobroker/node_modules/iobroker.js-controller/
                insgesamt 96
                drwxrwxrwx+   4 iobroker iobroker  4096 Okt 10 18:14 .
                drwxrwxrwx+ 394 iobroker iobroker 69632 Okt 10 21:37 ..
                -rw-rwxrw-+   1 iobroker iobroker    41 Okt 10 18:14 iob.bat
                -rw-rwxrw-+   1 iobroker iobroker     0 Okt 10 18:14 iobroker.bat
                drwxrwxrwx+   2 iobroker iobroker  4096 Okt 10 18:14 lib
                -rw-rwxrw-+   1 iobroker iobroker  1135 Okt 10 18:14 LICENSE
                drwxrwxrwx+   5 iobroker iobroker  4096 Okt 10 18:14 node_modules
                -rw-rwxrw-+   1 iobroker iobroker   144 Okt 10 18:14 _service_iobroker.bat
                • M michaelheiml
                  @michaelheiml
                  insgesamt 96
                  Und wie läuft der Installer?
                    michaelheiml
                    Hab die Command History durchgesehen.. deutet nichts in Richtung Windows iobroker Installation.
                    Output Install.sh:
                    pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                    library: loaded
                    Library version=2022-06-15
                        Welcome to the ioBroker installer!
                        Installer version: 2022-06-03
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/4)
                    OK:1 http://archive.raspberrypi.org/debian buster InRelease
                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    OK:3 https://downloads.plex.tv/repo/deb public InRelease
                    OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                    OK:5 https://linux.teamviewer.com/deb stable InRelease
                    Changing npm registry to https://registry.npmjs.org
                    Installed gcc-c++
                        Creating ioBroker user and directory (2/4)
                    Directory /opt/iobroker created
                        Installing ioBroker (3/4)
                    npm ERR! code 1
                    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                    npm ERR! command failed
                    npm ERR! command sh /tmp/install-f3ce3c9e.sh
                    npm ERR! node:internal/modules/cjs/loader:372
                    npm ERR!       throw err;
                    npm ERR!       ^
                    npm ERR!
                    npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/jsonwebtoken/index.js'. Please verify that the package.json has a valid "main" entry
                    npm ERR!     at tryPackage (node:internal/modules/cjs/loader:364:19)
                    npm ERR!     at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
                    npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
                    npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
                    npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
                    npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:10:13)
                    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)
                    npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                    npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32) {
                    npm ERR!   code: 'MODULE_NOT_FOUND',
                    npm ERR!   path: '/opt/iobroker/node_modules/jsonwebtoken/package.json',
                    npm ERR!   requestPath: 'jsonwebtoken'
                    npm ERR! }
                    npm ERR!     /home/pi/.npm/_logs/2022-10-10T20_14_34_985Z-debug-0.log
                        Finalizing installation (4/4)
                    Enabling autostart...
                    Autostart enabled!
                        ioBroker was installed successfully
                        Open http://192.168.1.254:8081 in a browser and start configuring!
                    You need to re-login before doing anything else on the console!
                    • M michaelheiml
                      Output Install.sh:
                      library: loaded
                      Installed gcc-c++
                      npm ERR! code 1
                      npm ERR!       throw err;
                      npm ERR!       ^
                      npm ERR!
                      npm ERR! }
                      Autostart enabled!
                      @michaelheiml
                      ls -lA / | grep tmp
                        @michaelheiml
                        ls -lA / | grep tmp
                        michaelheiml
                        @thomas-braun said in iobroker kaputt nach NodeJS Update:
                        ls -lA / | grep tmp
                        pi@raspberrypi:~ $ ls -lA / | grep tmp
                        drwxrwxrwt  19 root root  4096 Okt 10 22:17 tmp
                        • M michaelheiml
                          ls -lA / | grep tmp
                          ls -lA /tmp/
                            ls -lA /tmp/
                            michaelheiml
                            pi@raspberrypi:~ $ ls -lA /tmp/
                            insgesamt 72
                            drwx------ 2 pi   pi   4096 Okt 10 18:21 dhcpcd-pi
                            drwxrwxrwt 2 root root 4096 Okt 10 18:20 .font-unix
                            srw------- 1 pi   pi      0 Okt 10 22:03 geany_socket.c2929e62
                            drwxrwxrwt 2 root root 4096 Okt 10 18:20 .ICE-unix
                            drwxr-xr-x 2 plex plex 4096 Okt 10 18:21 pms-783b7fb9-1920-49f3-b817-a0f35a1c9c16
                            drwx------ 2 root root 4096 Okt 10 18:20 pulse-PKdhtXMmr18n
                            drwx------ 2 pi   pi   4096 Okt 10 18:21 ssh-KmHKgJxQRO9T
                            drwx------ 2 pi   pi   4096 Okt 10 18:21 ssh-q5LDIGBGNjQc
                            drwx------ 3 root root 4096 Okt 10 18:20 systemd-private-d0c16273df82407fb538677a9af079b6-colord.service-GtnKyq
                            drwx------ 3 root root 4096 Okt 10 18:21 systemd-private-d0c16273df82407fb538677a9af079b6-rtkit-daemon.service-5ugbb2
                            drwx------ 3 root root 4096 Okt 10 18:20 systemd-private-d0c16273df82407fb538677a9af079b6-systemd-timesyncd.service-u0sQmX
                            drwxrwxrwt 2 root root 4096 Okt 10 18:20 .Test-unix
                            drwx------ 3 root root 4096 Okt 10 21:17 .vnc-0
                            drwx------ 3 pi   pi   4096 Okt 10 18:21 .vnc-1000
                            drwxrwxrwt 2 root root 4096 Okt 10 18:20 .vncserver-license
                            drwx------ 2 root root 4096 Okt 10 18:20 .vnc-vncservice
                            -r--r--r-- 1 root root   11 Okt 10 18:20 .X0-lock
                            drwxrwxrwt 2 root root 4096 Okt 10 18:20 .X11-unix
                            drwxrwxrwt 2 root root 4096 Okt 10 18:20 .XIM-unix
                            • M michaelheiml
                              insgesamt 72
                              @michaelheiml
                              Keine Ahnung. Sind mir auch zu viele Dateien mit X drin.
                                @michaelheiml
                                michaelheiml
                                Was müsste ich denn löschen, um die aktuelle Installation los zu werden? /opt/iobroker /* ?
                                Und wenn ich iobroker_data gesichert habe und zurückspiele nach einer Neuinstallation, würde ich dann meine vorherige Konfiguration wieder haben? Oder ist das zu kurz gegriffen?
                                • M michaelheiml
                                  @michaelheiml
                                  Ich würde mal
                                  rm -rf /opt/iobroker/
                                  versuchen.
                                  Möglich. Besser ist aber ein Backup via Backitup.
                                  • JLegJ Offline
                                    JLegJ Offline
                                    JLeg
                                    @michaelheiml
                                    bevor du alles löschst, würde ich nochmal die „Rosskur“ versuchen - hat bei mir prima funktioniert:
                                    cd /opt/iobroker
                                    mv node_modules node_modules.old
                                    mv package-lock.json package-lock.json.old
                                    npm cache clean --force
                                    npm install
                                    npm list
                                      @michaelheiml
                                      Ich würde mal
                                      versuchen.
                                      michaelheiml
                                      An diesem Thread hast du mitgeschrieben:
                                      https://forum.iobroker.net/topic/55683/kein-update-mehr-möglich-mit-node-js-16/303
                                      Ich bin gerade per Google darauf gestoßen, weil mir
                                      npm ls
                                      ausspuckt:
                                      ├── iobroker.backitup@ invalid: "stable" from the root project
                                      Vielleicht ein Hinweis, wo es hakt?
                                      • M michaelheiml
                                        npm ls
                                        ausspuckt:
                                        @michaelheiml
                                        Das bezieht sich auf die package.json
                                        cat /opt/iobroker/package.json | jq
                                        Da steht allerdings gemeinhin nicht stable sondern eine Versionsnummer für die Module drin.
                                          @michaelheiml
                                          michaelheiml
                                          "name": "iobroker.inst",
                                          "version": "3.0.0",
                                          "private": true,
                                          "description": "Automate your Life",
                                          "engines": {
                                          "node": ">=10.0.0"
                                          "dependencies": {
                                          "iobroker.js-controller": "stable",
                                          "iobroker.admin": "stable",
                                          "iobroker.discovery": "stable",
                                          "iobroker.backitup": "stable"
