  4. iobroker kaputt nach NodeJS Update
75 Beiträge 3 Kommentatoren 6.0k Aufrufe 4 Beobachtet
  • M michaelheiml
    Auf beide dieselbe Ausgabe:
    iob status
    iob setup first
    node:internal/modules/cjs/loader:959
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
        at Function.Module._load (node:internal/modules/cjs/loader:804:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    @michaelheiml
    Unabhängig voneinander eingeben, nicht in einem Rutsch...
    Btw:
    echad@chet:/opt/iobroker $ ls -la /opt/iobroker/node_modules/iobroker.js-controller/
    total 392
    drwxrwxr-x+   7 iobroker iobroker   4096 Oct  9 11:54 .
    drwxrwxr-x+ 704 iobroker iobroker  36864 Oct 10 17:13 ..
    drwxrwxr-x+   2 iobroker iobroker   4096 Jul 30 03:42 backups
    -rw-rwxr--+   1 iobroker iobroker    420 Jul 29 20:20 compactgroupController.js
    drwxrwxr-x+   2 iobroker iobroker   4096 Jul 29 20:20 conf
    -rw-rwxr--+   1 iobroker iobroker    158 Jul 29 20:20 controller.js
    -rwxrwxr-x+   1 iobroker iobroker     34 Jul 29 20:20 iobroker.js
    -rw-rwxr--+   1 iobroker iobroker  54395 Jul 29 20:20 io-package.json
    drwxrwxr-x+   9 iobroker iobroker   4096 Jul 29 20:20 lib
    -rw-rwxr--+   1 iobroker iobroker   1135 Jul 29 20:20 LICENSE
    -rw-rwxr--+   1 iobroker iobroker 249293 Jul 29 20:20 main.js
    drwxrwxr-x+   5 iobroker iobroker   4096 Jul 29 20:20 node_modules
    -rw-rwxr--+   1 iobroker iobroker   3277 Jul 29 20:20 package.json
    -rw-rw-r--+   1 iobroker iobroker    177 Oct 10 17:14 pids.txt
    -rw-rwxr--+   1 iobroker iobroker    193 Jul 29 20:20 README.md
    drwxrwxr-x+   2 iobroker iobroker   4096 Oct 10 03:42 tmp
    M 2 Antworten Letzte Antwort
      @michaelheiml
      Btw:
      total 392
      michaelheiml
      pi@raspberrypi:/opt/iobroker $ iob status
        throw err;
        requireStack: []
      pi@raspberrypi:/opt/iobroker $ iob setup first
        throw err;
        requireStack: []
        @michaelheiml
        Btw:
        total 392
        michaelheiml
        Der Ordner sieht bei mir gänzlich anders aus. Keine .js Dateien. Kann es sein, dass durch irgendeinen Fehler von mir ich die Windows Version von iobroker installiert habe?
        • M michaelheiml
          @michaelheiml sagte in iobroker kaputt nach NodeJS Update:
          Kann ich dir nicht sagen. Ich weiß ja nicht was du da veranstaltet hast.
          • M michaelheiml
            Wie sieht der denn aus?
              michaelheiml
              Offenbar einen Quark ;)
              Na jedenfalls.. das ist mein Ordner Inhalt:
              iob.bat
              iobroker.bat
              lib
              LICENSE
              node_modules
              _service_iobroker.bat
              Mehr nicht.
              Thomas BraunT M 2 Antworten Letzte Antwort
              • M michaelheiml
                iob.bat
                iobroker.bat
                lib
                LICENSE
                node_modules
                Mehr nicht.
                @michaelheiml
                Kopier dir doch den Befehl den ich auch verwendet habe. Dann reden wir über das gleiche.
                • M michaelheiml
                  iob.bat
                  iobroker.bat
                  lib
                  LICENSE
                  node_modules
                  Mehr nicht.
                  michaelheiml
                  @michaelheiml
                  Zum Installieren habe ich jedenfalls den Befehl aus der Anleitung verwendet.
                  curl -sLf https://iobroker.net/install.sh | bash -
                  pi@raspberrypi:/opt/iobroker/node_modules/iobroker.js-controller $ ls -la /opt/iobroker/node_modules/iobroker.js-controller/
                  insgesamt 96
                  drwxrwxrwx+   4 iobroker iobroker  4096 Okt 10 18:14 .
                  drwxrwxrwx+ 394 iobroker iobroker 69632 Okt 10 21:37 ..
                  -rw-rwxrw-+   1 iobroker iobroker    41 Okt 10 18:14 iob.bat
                  -rw-rwxrw-+   1 iobroker iobroker     0 Okt 10 18:14 iobroker.bat
                  drwxrwxrwx+   2 iobroker iobroker  4096 Okt 10 18:14 lib
                  -rw-rwxrw-+   1 iobroker iobroker  1135 Okt 10 18:14 LICENSE
                  drwxrwxrwx+   5 iobroker iobroker  4096 Okt 10 18:14 node_modules
                  -rw-rwxrw-+   1 iobroker iobroker   144 Okt 10 18:14 _service_iobroker.bat
                  • M michaelheiml
                    @michaelheiml
                    insgesamt 96
                    Und wie läuft der Installer?
                      michaelheiml
                      Hab die Command History durchgesehen.. deutet nichts in Richtung Windows iobroker Installation.
                      Output Install.sh:
                      pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                      library: loaded
                      Library version=2022-06-15
                          Welcome to the ioBroker installer!
                          Installer version: 2022-06-03
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/4)
                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:3 https://downloads.plex.tv/repo/deb public InRelease
                      OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                      OK:5 https://linux.teamviewer.com/deb stable InRelease
                      Changing npm registry to https://registry.npmjs.org
                      Installed gcc-c++
                          Creating ioBroker user and directory (2/4)
                      Directory /opt/iobroker created
                          Installing ioBroker (3/4)
                      npm ERR! code 1
                      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                      npm ERR! command failed
                      npm ERR! command sh /tmp/install-f3ce3c9e.sh
                      npm ERR! node:internal/modules/cjs/loader:372
                      npm ERR!       throw err;
                      npm ERR!       ^
                      npm ERR!
                      npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/jsonwebtoken/index.js'. Please verify that the package.json has a valid "main" entry
                      npm ERR!     at tryPackage (node:internal/modules/cjs/loader:364:19)
                      npm ERR!     at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
                      npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
                      npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
                      npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
                      npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:10:13)
                      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)
                      npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32) {
                      npm ERR!   code: 'MODULE_NOT_FOUND',
                      npm ERR!   path: '/opt/iobroker/node_modules/jsonwebtoken/package.json',
                      npm ERR!   requestPath: 'jsonwebtoken'
                      npm ERR! }
                      npm ERR!     /home/pi/.npm/_logs/2022-10-10T20_14_34_985Z-debug-0.log
                          Finalizing installation (4/4)
                      Enabling autostart...
                      Autostart enabled!
                          ioBroker was installed successfully
                          Open http://192.168.1.254:8081 in a browser and start configuring!
                      You need to re-login before doing anything else on the console!
                      • M michaelheiml
                        Output Install.sh:
                        library: loaded
                        Installed gcc-c++
                        npm ERR! code 1
                        npm ERR!       throw err;
                        npm ERR!       ^
                        npm ERR!
                        npm ERR! }
                        Autostart enabled!
                        @michaelheiml
                        ls -lA / | grep tmp
                          @michaelheiml
                          ls -lA / | grep tmp
                          michaelheiml
                          @thomas-braun said in iobroker kaputt nach NodeJS Update:
                          ls -lA / | grep tmp
                          pi@raspberrypi:~ $ ls -lA / | grep tmp
                          drwxrwxrwt  19 root root  4096 Okt 10 22:17 tmp
                          • M michaelheiml
                            ls -lA / | grep tmp
                            ls -lA /tmp/
                              ls -lA /tmp/
                              michaelheiml
                              pi@raspberrypi:~ $ ls -lA /tmp/
                              insgesamt 72
                              drwx------ 2 pi   pi   4096 Okt 10 18:21 dhcpcd-pi
                              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .font-unix
                              srw------- 1 pi   pi      0 Okt 10 22:03 geany_socket.c2929e62
                              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .ICE-unix
                              drwxr-xr-x 2 plex plex 4096 Okt 10 18:21 pms-783b7fb9-1920-49f3-b817-a0f35a1c9c16
                              drwx------ 2 root root 4096 Okt 10 18:20 pulse-PKdhtXMmr18n
                              drwx------ 2 pi   pi   4096 Okt 10 18:21 ssh-KmHKgJxQRO9T
                              drwx------ 2 pi   pi   4096 Okt 10 18:21 ssh-q5LDIGBGNjQc
                              drwx------ 3 root root 4096 Okt 10 18:20 systemd-private-d0c16273df82407fb538677a9af079b6-colord.service-GtnKyq
                              drwx------ 3 root root 4096 Okt 10 18:21 systemd-private-d0c16273df82407fb538677a9af079b6-rtkit-daemon.service-5ugbb2
                              drwx------ 3 root root 4096 Okt 10 18:20 systemd-private-d0c16273df82407fb538677a9af079b6-systemd-timesyncd.service-u0sQmX
                              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .Test-unix
                              drwx------ 3 root root 4096 Okt 10 21:17 .vnc-0
                              drwx------ 3 pi   pi   4096 Okt 10 18:21 .vnc-1000
                              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .vncserver-license
                              drwx------ 2 root root 4096 Okt 10 18:20 .vnc-vncservice
                              -r--r--r-- 1 root root   11 Okt 10 18:20 .X0-lock
                              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .X11-unix
                              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .XIM-unix
                              • M michaelheiml
                                insgesamt 72
                                @michaelheiml
                                Keine Ahnung. Sind mir auch zu viele Dateien mit X drin.
                                  @michaelheiml
                                  michaelheiml
                                  Was müsste ich denn löschen, um die aktuelle Installation los zu werden? /opt/iobroker /* ?
                                  Und wenn ich iobroker_data gesichert habe und zurückspiele nach einer Neuinstallation, würde ich dann meine vorherige Konfiguration wieder haben? Oder ist das zu kurz gegriffen?
                                  • M michaelheiml
                                    @michaelheiml
                                    Ich würde mal
                                    rm -rf /opt/iobroker/
                                    versuchen.
                                    Möglich. Besser ist aber ein Backup via Backitup.
                                    • JLegJ Offline
                                      JLegJ Offline
                                      JLeg
                                      @michaelheiml
                                      bevor du alles löschst, würde ich nochmal die „Rosskur“ versuchen - hat bei mir prima funktioniert:
                                      cd /opt/iobroker
                                      mv node_modules node_modules.old
                                      mv package-lock.json package-lock.json.old
                                      npm cache clean --force
                                      npm install
                                      npm list
                                        @michaelheiml
                                        Ich würde mal
                                        versuchen.
                                        michaelheiml
                                        An diesem Thread hast du mitgeschrieben:
                                        https://forum.iobroker.net/topic/55683/kein-update-mehr-möglich-mit-node-js-16/303
                                        Ich bin gerade per Google darauf gestoßen, weil mir
                                        npm ls
                                        ausspuckt:
                                        ├── iobroker.backitup@ invalid: "stable" from the root project
                                        Vielleicht ein Hinweis, wo es hakt?
                                        • M michaelheiml
                                          npm ls
                                          ausspuckt:
                                          @michaelheiml
                                          Das bezieht sich auf die package.json
                                          cat /opt/iobroker/package.json | jq
                                          Da steht allerdings gemeinhin nicht stable sondern eine Versionsnummer für die Module drin.
