  4. [Problem]Fehler nach Update. Nichts geht mehr
cb.apply is not a function
68 Beiträge 4 Kommentatoren 4.9k Aufrufe 3 Beobachtet
    @nevs84
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    N Offline
    N Offline
    nevs84
    @thomas-braun said in [Problem]Fehler nach Update. Nichts geht mehr:
    pi@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 24
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh /tmp/install-51355609.sh
    npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    npm ERR!     /home/iobroker/.npm/_logs/2022-10-04T13_00_00_679Z-debug-0.log
    • N nevs84
      npm ERR! code 24
      @nevs84
      Zumindest die npm-Meldungen sind weg...
      sudo install lsof
      lsof /opt/iobroker/iobroker-data/objects.jsonl
      N Thomas BraunT 2 Antworten Letzte Antwort
        @nevs84
        sudo install lsof
        N Offline
        N Offline
        nevs84
        sudo install lsof
        pi@iobroker:/opt/iobroker $ sudo install lsof
        install: Fehlender Zieldatei‐Operand hinter 'lsof'
        „install --help“ liefert weitere Informationen.
          @nevs84
          sudo install lsof
          sudo apt install lsof
          sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
          N 1 Antwort Letzte Antwort
          • N nevs84
            sudo install lsof
            @nevs84
            Übrigens ist hier erklärt, warum es zur ursprünglichen Meldung kommt:
            https://help.heroku.com/ZV7S7D6T/why-is-my-node-build-is-suddenly-displaying-npm-err-cb-apply-is-not-a-function
            Und genau aus diesem Grund raten wir immer davon ab npm separat in die Hand zu nehmen.
              N Offline
              N Offline
              nevs84
              pi@iobroker:/opt/iobroker $ sudo apt install lsof
              Die folgenden NEUEN Pakete werden installiert:
                lsof
              0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
              Es müssen 307 kB an Archiven heruntergeladen werden.
              Nach dieser Operation werden 447 kB Plattenplatz zusätzlich benutzt.
              Holen:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf lsof armhf 4.91+dfsg-1 [307 kB]
              Es wurden 307 kB in 1 s geholt (455 kB/s).
              Vormals nicht ausgewähltes Paket lsof wird gewählt.
              (Lese Datenbank ... 127192 Dateien und Verzeichnisse sind derzeit installiert.)
              Vorbereitung zum Entpacken von .../lsof_4.91+dfsg-1_armhf.deb ...
              Entpacken von lsof (4.91+dfsg-1) ...
              lsof (4.91+dfsg-1) wird eingerichtet ...
              Trigger für man-db (2.8.5-2) werden verarbeitet ...
              pi@iobroker:/opt/iobroker $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
              • N nevs84
                  lsof
                @nevs84 sagte in [Problem]Fehler nach Update. Nichts geht mehr:
                ls -l /opt/iobroker/iobroker-data/objects.jsonl
                  @nevs84
                  N Offline
                  N Offline
                  nevs84
                  @thomas-braun Danke! This is a conflict between npm <= 5 and newer versions of Node 12 and 14. The solution is to upgrade npm to >= 6, which is installed with Node 12 and Node 14 by default.! Verstanden
                    N Offline
                    N Offline
                    nevs84
                    pi@iobroker:/opt/iobroker $ ls -l /opt/iobroker/iobroker-data/objects.jsonl
                    -rwxrwxrwx+ 1 iobroker iobroker 583059237 Okt  4 06:59 /opt/iobroker/iobroker-data/objects.jsonl
                    • N nevs84
                      @nevs84
                      Irgendwo muss man das timeout hochsetzen.
                      Ich weiß gerade aber nicht wo.
                      Das sind ja 583MByte da bei dir...
                      Das ist natürlich für einen RPi3 mit seinen 1GB Ram nicht zu schlucken.
                      • N Offline
                        N Offline
                        nevs84
                        @thomas-braun Ich suche und lese gerade...werde aber gerade noch nicht so richtig schlau draus!
                          @nevs84
                          N Offline
                          N Offline
                          nevs84
                          free -m -t
                          Mem:            923         128         510          16         284         727
                          Swap:            99          52          47
                          Total:         1023         180         558
                          • N nevs84
                            free -m -t
                            Swap:            99          52          47
                            Total:         1023         180         558
                            @nevs84
                            Ja. Und? 583MByte sind trotzdem ein zu großer Happen. Das bekommt der kleine PI nicht schnell genug verputzt.
                            • N Offline
                              N Offline
                              nevs84
                              @thomas-braun Vielen Dank für deine Mühen und deine Zeit bis hierhin. Ich habe jetzt gerade noch eine Stunde bzgl. des TimeOuts gelesen aber komme hier an diesem Punkt nicht weiter. Ich habe versucht den ioBroker (wie oben auch schon von @Homoran erwähnt) neu zu installieren, was ebenfalls fehl schlägt. Hat jemand noch eine Idee bzgl. des Timeouts? Oder eine anderen schlauen Tipp bzgl. der Neuinstallation? Möchte gerne das Formatieren vermeiden! Grüße
                                  Installing ioBroker (3/4)
                              npm ERR! code 24
                              npm ERR! command sh /tmp/install-8412f0be.sh
                              npm ERR!     /home/pi/.npm/_logs/2022-10-05T19_24_32_093Z-debug-0.log
                              • Thomas BraunT Online
                                @nevs84
                                Frag mal @Glasfaser , der hat den Befehl glaube ich parat.
                                • N nevs84
                                  npm ERR! code 24
                                  https://forum.iobroker.net/topic/53378/server-cannot-start-inmem-objects-on-port-9001/173
                                    N Offline
                                    N Offline
                                    nevs84
                                    schrieb am zuletzt editiert von nevs84
                                    @thomas-braun Hab den Thread durchgelesen und den Timeout wie beschrieben hochgesetzt...keine Änderung. Der Fehler bleibt leider immer derselbe....wie kann ich nun am besten mein Backup einspielen (Was ja aktuell auch nicht geht aufgrund des nicht laufenden IOBrokers)? Bin dankbar für jeden Input.
                                    • N nevs84
                                      #66
                                      @nevs84
                                      Ich würde es von Null auf neuinstallieren.
                                        @nevs84
                                        N Offline
                                        N Offline
                                        nevs84
                                        #67
                                        @thomas-braun Das heisst formatieren und neu imagen? Oder gibt es da noch andere Möglichkeiten?
                                        • N nevs84
                                          #68
                                          @nevs84
                                          Ich würde es halt flugs neu draufwerfen. Wo ist die Hürde?
                                          Bullseye /64bit /kein GUI
                                          Edit: piVCCU läuft da auch noch mit?
                                          Da musst du Mal schauen was da die Empfehlung ist.
                                          Was 'Buster' angeht dürfte das in Kürze EOL werden. Du musst eh da was machen.
