  4. HS100-Adapter stürzt immer wieder ab
    5.4k
hs100 adapter
17 Beiträge 6 Kommentatoren 816 Aufrufe 6 Beobachtet
  • arteckA arteck
    @gregors sagte in HS100-Adapter stürzt immer wieder ab:
    0000ms
    welche Adapter Version ?? nimm die aus GIT
    zeigmal die Aktualisierungswerte
    GregorSG Offline
    GregorSG Offline
    GregorS
    @arteck
    Hatte den 2.06 installiert, bin jetzt testweise zurück auf den 2.05.
    hs100.0	2022-01-17 17:57:54.240	error	(9862) Connection is closed.
    hs100.0	2022-01-17 17:57:54.239	error	at processImmediate (internal/timers.js:463:21)
    hs100.0	2022-01-17 17:57:54.239	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2332:33)
    hs100.0	2022-01-17 17:57:54.239	error	at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2286:37)
    hs100.0	2022-01-17 17:57:54.239	error	at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
    hs100.0	2022-01-17 17:57:54.239	error	at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
    hs100.0	2022-01-17 17:57:54.239	error	(9862) Error: Connection is closed.
    hs100.0	2022-01-17 17:57:54.235	error	(9862) unhandled promise rejection: Connection is closed.
    hs100.0	2022-01-17 17:57:54.234	error	(9862) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-17 17:57:54.232	error	(9862) Connection is closed.
    		debug	at processImmediate (internal/timers.js:463:21)
    		debug	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2332:33)
    		debug	at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2286:37)
    		debug	at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
    		debug	at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      @arteck
      arteckA Offline
      arteckA Offline
      arteck
      @gregors das kmmt zwar auf dem hs100 Adapter aber hat damit nix zu tun..
      ist die platte/SD-Karte voll ??
      da kann was nicht geschrieben werden
      GregorSG 1 Antwort Letzte Antwort
      • arteckA arteck
        GregorSG Offline
        GregorSG Offline
        GregorS
        @arteck
        Seit dem Downgrade gibt es bis heute keine Abstürze mehr.
        Plattenplatz verfügbar 55,7%, RAM frei 24%.
        Alles im grünen Bereich
          skokarl
          Hallo @arteck
          machst Du noch was an dem HS Adapter ?
          Hab aktuell 2.07 installiert, und unten stehende Meldung kommt immer mal wieder.
          Kommt wahrscheinlich auch öfter, weil manche Steckdosen die WLAN Verbindung verlieren, wobei ich nicht
          glaube dass das an Dir liegt ( Waschmaschinenraum )
          Aber der type ist eben falsch definiert.
          2022-03-02 08:22:03.736	warn	This object will not be created in future versions. Please report this to the developer.
          hs100.0
          	2022-03-02 08:22:03.736	warn	Object 192_168_178_40.last_update is invalid: Default value has to be type "string" but received type "number"
          hs100.0
          	2022-03-02 08:22:03.645	info	Start with IP : 192.168.178.40
          • S skokarl
            Hallo @arteck
            hs100.0
            hs100.0
            arteckA Offline
            arteckA Offline
            arteck
            @skokarl sagte in HS100-Adapter stürzt immer wieder ab:
            was soll ich da machen deinermeinung nach ?? gibts offene issues ??
            die problematik mit dem invalid value ist schon 100000 besprochen worden(lösche das object und starte den adapter neu)
            • arteckA arteck
              skokarl
              @arteck
              ok,
              dann muss ich mal nen issue machen .... vermutlich kannst Du gar nix dafür, glaube die HS100 Dosen sind wohl nicht so
              gut, blöd nur wenn man davon viele hat. Nix für ungut.
              Objekte gelöscht, Adapter neu gestartet.
              • S skokarl
                @arteck
                ok,
                arteckA Offline
                arteckA Offline
                arteck
                @skokarl hast du den adapter von GIT ?
                die HS Dosen verlangen eine bestehende WLAN Verbindung.. ja die meckern wenn das nicht der fall ist
                wie ist das timeout eingestellt ? in Einstellungen
                • arteckA arteck
                  skokarl
                  @arteck
                  eben nochmal alles gelöscht, und von github neu installiert.
                  Abfrage steht auf 30 sek.
                  Wenns nicht besser wird, müssen eben andere Steckdosen her, mal gucken.
                  Danke Dir.
                  • GregorSG GregorS
                    @arteck
                    Spidermike
                    schrieb am zuletzt editiert von Spidermike
                    @gregors
                    habt ihr jetzt eine gute Lösung für das Problem gefunden?
                    ich bekomme auch immer viele Fehlermeldungen
                    host.raspberrypi4-iobroker
                    	2022-10-01 18:10:11.133	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    	2022-10-01 18:10:11.133	error	Caught by controller[15]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.132	error	Caught by controller[15]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.132	error	Caught by controller[15]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.132	error	Caught by controller[15]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                    	2022-10-01 18:10:11.132	error	Caught by controller[15]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.132	error	Caught by controller[14]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.132	error	Caught by controller[14]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.132	error	Caught by controller[14]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.132	error	Caught by controller[14]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                    	2022-10-01 18:10:11.131	error	Caught by controller[14]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.131	error	Caught by controller[13]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.131	error	Caught by controller[13]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.131	error	Caught by controller[13]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.131	error	Caught by controller[13]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.131	error	Caught by controller[13]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.131	error	Caught by controller[12]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.130	error	Caught by controller[12]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.130	error	Caught by controller[12]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.130	error	Caught by controller[12]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.130	error	Caught by controller[12]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.130	error	Caught by controller[11]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.130	error	Caught by controller[11]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.130	error	Caught by controller[11]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.129	error	Caught by controller[11]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.129	error	Caught by controller[11]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.129	error	Caught by controller[10]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.129	error	Caught by controller[10]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.129	error	Caught by controller[10]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.129	error	Caught by controller[10]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.129	error	Caught by controller[10]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.129	error	Caught by controller[9]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.128	error	Caught by controller[9]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.128	error	Caught by controller[9]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.128	error	Caught by controller[9]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.128	error	Caught by controller[9]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.128	error	Caught by controller[8]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.128	error	Caught by controller[8]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.128	error	Caught by controller[8]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.127	error	Caught by controller[8]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.127	error	Caught by controller[8]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.127	error	Caught by controller[7]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.127	error	Caught by controller[7]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.127	error	Caught by controller[7]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.127	error	Caught by controller[7]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.127	error	Caught by controller[7]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.126	error	Caught by controller[6]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.126	error	Caught by controller[6]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.126	error	Caught by controller[6]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.126	error	Caught by controller[6]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.126	error	Caught by controller[6]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.126	error	Caught by controller[5]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.126	error	Caught by controller[5]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.125	error	Caught by controller[5]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.125	error	Caught by controller[5]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.125	error	Caught by controller[5]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.125	error	Caught by controller[4]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.125	error	Caught by controller[4]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.125	error	Caught by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.125	error	Caught by controller[4]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.124	error	Caught by controller[4]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.124	error	Caught by controller[3]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.124	error	Caught by controller[3]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.124	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.124	error	Caught by controller[3]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.123	error	Caught by controller[3]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.123	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.123	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.123	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.123	error	Caught by controller[2]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.123	error	Caught by controller[2]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:10:11.123	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:10:11.122	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:10:11.122	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:10:11.122	error	Caught by controller[1]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:10:11.122	error	Caught by controller[1]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                    hs100.0
                    	2022-10-01 18:10:10.485	error	TCP Timeout after 10000ms 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                    hs100.0
                    	2022-10-01 18:10:10.484	error	Error: TCP Timeout after 10000ms 192.168.178.94:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                    hs100.0
                    	2022-10-01 18:10:10.483	error	unhandled promise rejection: TCP Timeout after 10000ms 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                    hs100.0
                    	2022-10-01 18:10:10.482	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    	2022-10-01 18:08:38.854	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    	2022-10-01 18:08:38.854	error	Caught by controller[7]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.854	error	Caught by controller[7]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:08:38.853	error	Caught by controller[7]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.853	error	Caught by controller[7]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:08:38.853	error	Caught by controller[7]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:08:38.853	error	Caught by controller[6]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.853	error	Caught by controller[6]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:08:38.852	error	Caught by controller[6]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.852	error	Caught by controller[6]: 192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                    	2022-10-01 18:08:38.852	error	Caught by controller[6]: [Geschirrspüler Steckdose] device.send() Error: TCP Timeout after 10000ms
                    	2022-10-01 18:08:38.852	error	Caught by controller[5]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.852	error	Caught by controller[5]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:08:38.852	error	Caught by controller[5]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.851	error	Caught by controller[5]: 192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                    	2022-10-01 18:08:38.851	error	Caught by controller[5]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:08:38.851	error	Caught by controller[4]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.851	error	Caught by controller[4]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:08:38.851	error	Caught by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.851	error	Caught by controller[4]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:08:38.851	error	Caught by controller[4]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:08:38.850	error	Caught by controller[4]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.850	error	Caught by controller[4]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:08:38.850	error	Caught by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.850	error	Caught by controller[4]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:08:38.850	error	Caught by controller[4]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:08:38.850	error	Caught by controller[3]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.849	error	Caught by controller[3]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:08:38.849	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.849	error	Caught by controller[3]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:08:38.849	error	Caught by controller[3]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:08:38.849	error	Caught by controller[3]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.848	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.848	error	Caught by controller[3]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:08:38.848	error	Caught by controller[3]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:08:38.848	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.848	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:08:38.848	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.847	error	Caught by controller[2]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:08:38.847	error	Caught by controller[2]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 18:08:38.847	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 18:08:38.847	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 18:08:38.847	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 18:08:38.847	error	Caught by controller[1]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 18:08:38.845	error	Caught by controller[1]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                    hs100.0
                    	2022-10-01 18:08:38.247	error	TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                    hs100.0
                    	2022-10-01 18:08:38.247	error	Error: TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                    hs100.0
                    	2022-10-01 18:08:38.247	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                    hs100.0
                    	2022-10-01 18:08:38.246	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    	2022-10-01 13:09:14.462	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    	2022-10-01 13:09:14.461	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 13:09:14.461	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 13:09:14.461	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 13:09:14.461	error	Caught by controller[2]: 192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                    	2022-10-01 13:09:14.461	error	Caught by controller[2]: [Geschirrspüler Steckdose] device.send() Error: TCP Timeout after 10000ms
                    	2022-10-01 13:09:14.460	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 13:09:14.460	error	Caught by controller[2]: 192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                    	2022-10-01 13:09:14.460	error	Caught by controller[2]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 13:09:14.460	error	Caught by controller[1]: }
                    	2022-10-01 13:09:14.460	error	Caught by controller[1]: port: 9999
                    	2022-10-01 13:09:14.460	error	Caught by controller[1]: address: '192.168.178.95',
                    	2022-10-01 13:09:14.460	error	Caught by controller[1]: syscall: 'connect',
                    	2022-10-01 13:09:14.459	error	Caught by controller[1]: code: 'ECONNREFUSED',
                    	2022-10-01 13:09:14.459	error	Caught by controller[1]: errno: -111,
                    	2022-10-01 13:09:14.459	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1247:16) {
                    	2022-10-01 13:09:14.457	error	Caught by controller[1]: TCP 192.168.178.95:9999 Error: connect ECONNREFUSED 192.168.178.95:9999
                    hs100.0
                    	2022-10-01 13:09:13.859	error	TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                    hs100.0
                    	2022-10-01 13:09:13.857	error	Error: TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                    hs100.0
                    	2022-10-01 13:09:13.856	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                    hs100.0
                    	2022-10-01 13:09:13.855	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    	2022-10-01 08:58:05.593	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    	2022-10-01 08:58:05.593	error	Caught by controller[3]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 08:58:05.593	error	Caught by controller[3]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 08:58:05.592	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 08:58:05.592	error	Caught by controller[3]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                    	2022-10-01 08:58:05.592	error	Caught by controller[3]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    	2022-10-01 08:58:05.592	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 08:58:05.592	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 08:58:05.592	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 08:58:05.592	error	Caught by controller[2]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                    	2022-10-01 08:58:05.591	error	Caught by controller[2]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
                    	2022-10-01 08:58:05.591	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
                    	2022-10-01 08:58:05.591	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
                    	2022-10-01 08:58:05.591	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                    	2022-10-01 08:58:05.591	error	Caught by controller[1]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                    	2022-10-01 08:58:05.589	error	Caught by controller[1]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                    hs100.0
                    	2022-10-01 08:58:04.962	error	TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                    hs100.0
                    	2022-10-01 08:58:04.961	error	Error: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    	2022-10-01 08:58:04.961	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                    hs100.0
                    	2022-10-01 08:58:04.960	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    hs100.0
                    	2022-10-01 18:08:38.247	error	TCP Timeout after 10000ms 192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                    hs100.0
                    	2022-10-01 18:08:38.247	error	Error: TCP Timeout after 10000ms 192.168.178.95:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                    hs100.0
                    	2022-10-01 18:08:38.247	error	unhandled promise rejection: TCP Timeout after 10000ms 192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    hs100.0
                    iot.0
                    	2022-10-01 03:40:30.676	error	Error by device connection: "read ECONNRESET"
                    ich hoffe mir kann jemand helfen?
                    • S Spidermike
                      @gregors
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      hs100.0
                      iot.0
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @spidermike sagte in HS100-Adapter stürzt immer wieder ab:
                      immer noch das selbe.. die Dose läuft auf Timeout
                      installier mal von GIT .. und check nochmal
                      • arteckA arteck
                        Spidermike
                        ich habe immernoch manchmal fehlermeldungen
                        Habe alles gemacht was mir vorgeschlagen wurde,
                        Heute bei guten Bedingungen und ich am Rechner war und habe es überwacht, da hat alles funktioniert aber später wo eigentlich keine Sonne mehr da war kamen die Fehlermeldungen.
                        		2022-10-22 18:48:21.073	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        		2022-10-22 18:48:21.073	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                        		2022-10-22 18:48:21.072	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                        		2022-10-22 18:48:21.072	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                        		2022-10-22 18:48:21.072	error	Caught by controller[2]: 192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
                        		2022-10-22 18:48:21.072	error	Caught by controller[2]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
                        		2022-10-22 18:48:21.072	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
                        		2022-10-22 18:48:21.072	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
                        		2022-10-22 18:48:21.071	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                        		2022-10-22 18:48:21.071	error	Caught by controller[1]: 192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
                        		2022-10-22 18:48:21.071	error	Caught by controller[1]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                        hs100.0
                        	1007	2022-10-22 18:48:20.467	error	TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
                        hs100.0
                        	1007	2022-10-22 18:48:20.467	error	Error: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                        hs100.0
                        	1007	2022-10-22 18:48:20.466	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
                        hs100.0
                        	1007	2022-10-22 18:48:20.465	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a pro
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          für alle die Probleme haben
                          einmal bitte die GIT version installieren...
                          dann schauen wir nochmal
                          • arteckA arteck
                            mike2712
                            @arteck
                            seit einigen Tagen funktioniert aus unerklärlichen Gründen der HS Adapter bei mir nicht mehr, in der Smart Home App funktioniert alles, die benutze ich aber eigentlich nicht, anbei der LOG, leider kann ich da nicht viel mit anfangen.
                            Jemand eine Idee warum das nicht mehr funktioniert?
                            hs100.0
                            2023-04-26 23:37:54.448	warn	Socket connection Timeout 172_16_22_38 TP-Link-Steckdose-38 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:54.446	warn	Socket connection Timeout 172_16_22_11 TP-Link-Steckdose-11 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:54.444	warn	Socket connection Timeout 172_16_22_31 TP-Link-Steckdose-31 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:54.442	warn	Socket connection Timeout 172_16_22_32 TP-Link-Steckdose-32 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:54.440	warn	Socket connection Timeout 172_16_22_33 TP-Link-Steckdose-33 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:54.438	warn	Socket connection Timeout 172_16_22_34 TP-Link-Steckdose-34 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:54.435	warn	Socket connection Timeout 172_16_22_35 TP-Link-Steckdose-35 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:54.432	warn	Socket connection Timeout 172_16_22_36 TP-Link-Steckdose-36 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:54.429	warn	Socket connection Timeout 172_16_22_37 TP-Link-Steckdose-37 please reconnect the Device
                            hs100.0
                            2023-04-26 23:37:51.360	debug	get Information
                            hs100.0
                            2023-04-26 23:37:51.357	debug	State already present 172.16.22.38
                            hs100.0
                            2023-04-26 23:37:48.288	debug	create_state for IP : 172.16.22.38
                            hs100.0
                            2023-04-26 23:37:48.288	info	Start with 172.16.22.38 TP-Link-Steckdose-38
                            hs100.0
                            2023-04-26 23:37:48.285	debug	State already present 172.16.22.37
                            hs100.0
                            2023-04-26 23:37:45.213	debug	create_state for IP : 172.16.22.37
                            hs100.0
                            2023-04-26 23:37:45.213	info	Start with 172.16.22.37 TP-Link-Steckdose-37
                            hs100.0
                            2023-04-26 23:37:45.212	debug	State already present 172.16.22.36
                            hs100.0
                            2023-04-26 23:37:42.142	debug	create_state for IP : 172.16.22.36
                            hs100.0
                            2023-04-26 23:37:42.141	info	Start with 172.16.22.36 TP-Link-Steckdose-36
                            hs100.0
                            2023-04-26 23:37:42.140	debug	State already present 172.16.22.35
                            hs100.0
                            2023-04-26 23:37:39.015	debug	create_state for IP : 172.16.22.35
                            hs100.0
                            2023-04-26 23:37:39.014	info	Start with 172.16.22.35 TP-Link-Steckdose-35
                            hs100.0
                            2023-04-26 23:37:39.013	debug	State already present 172.16.22.34
                            hs100.0
                            2023-04-26 23:37:35.939	debug	create_state for IP : 172.16.22.34
                            hs100.0
                            2023-04-26 23:37:35.938	info	Start with 172.16.22.34 TP-Link-Steckdose-34
                            hs100.0
                            2023-04-26 23:37:35.937	debug	State already present 172.16.22.33
                            hs100.0
                            2023-04-26 23:37:32.865	debug	create_state for IP : 172.16.22.33
                            hs100.0
                            2023-04-26 23:37:32.864	info	Start with 172.16.22.33 TP-Link-Steckdose-33
                            hs100.0
                            2023-04-26 23:37:32.862	debug	State already present 172.16.22.32
                            hs100.0
                            2023-04-26 23:37:29.790	debug	create_state for IP : 172.16.22.32
                            hs100.0
                            2023-04-26 23:37:29.789	info	Start with 172.16.22.32 TP-Link-Steckdose-32
                            hs100.0
                            2023-04-26 23:37:29.788	debug	State already present 172.16.22.31
                            hs100.0
                            2023-04-26 23:37:26.729	debug	create_state for IP : 172.16.22.31
                            hs100.0
                            2023-04-26 23:37:26.728	info	Start with 172.16.22.31 TP-Link-Steckdose-31
                            hs100.0
                            2023-04-26 23:37:26.726	debug	State already present 172.16.22.11
                            hs100.0
                            2023-04-26 23:37:23.595	debug	create_state for IP : 172.16.22.11
                            hs100.0
                            2023-04-26 23:37:23.591	info	Start with 172.16.22.11 TP-Link-Steckdose-11
                            hs100.0
                            2023-04-26 23:37:23.588	debug	create state
                            hs100.0
                            2023-04-26 23:37:23.438	debug	Schedule restart: 59 11,23 * * *
                            hs100.0
                            2023-04-26 23:37:23.264	info	starting. Version 2.1.6 (non-npm: arteck/ioBroker.hs100) in /opt/iobroker/node_modules/iobroker.hs100, node: v16.19.0, js-controller: 4.0.24
                            ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
