  4. HS100-Adapter stürzt immer wieder ab
    5.4k
hs100 adapter
17 Beiträge 6 Kommentatoren 816 Aufrufe 6 Beobachtet
  • GregorSG Offline
    GregorSG Offline
    GregorS
    schrieb am zuletzt editiert von GregorS
    ich habe seit einigen Tagen ein Problem mit dem HS100-Adapter V2.06
    Er stürzt immer wieder mal ab.
    Habe ein Script geschieben, was ihn nach einem Disconnect neu startet.
    Aber er verbindet sich nicht mehr sauber.
    hs100.0	2022-01-16 16:58:36.297	warn	(5569) Could not perform strict object check of state hs100.0.192_168_10_147.ledState: Connection is closed.
    hs100.0	2022-01-16 16:58:36.296	warn	(5569) Could not perform strict object check of state hs100.0.192_168_10_147.voltage: Connection is closed.
    hs100.0	2022-01-16 16:58:36.295	warn	(5569) Could not perform strict object check of state hs100.0.192_168_10_147.power: Connection is closed.
    hs100.0	2022-01-16 16:58:36.293	warn	(5569) Could not perform strict object check of state hs100.0.192_168_10_147.current: Connection is closed.
    hs100.0	2022-01-16 16:58:36.262	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.262	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.262	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.262	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.262	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.262	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.262	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.261	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.260	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.258	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.256	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.256	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.256	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.256	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.256	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.256	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.256	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.255	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.253	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.252	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.252	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.252	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.252	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.252	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.252	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.252	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.251	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.249	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.248	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.248	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.248	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.248	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.248	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.248	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.248	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.247	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.245	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.244	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.244	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.244	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.244	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.244	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.244	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.243	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.238	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.231	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.230	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.230	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.230	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.230	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.230	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.230	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.229	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.228	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.227	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.220	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.220	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.220	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.220	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.220	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.220	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.218	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.217	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.216	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.215	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.215	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.215	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.215	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.215	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.215	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.214	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.213	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.212	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.211	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.211	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.211	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.211	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.211	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.211	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.210	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.209	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.208	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.207	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.207	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.207	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.207	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.207	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.207	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.206	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.205	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.203	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.203	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.203	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.203	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.203	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.203	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.203	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.202	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.201	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.200	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.199	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.199	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.199	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.199	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.199	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.199	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.198	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.197	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.195	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.195	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.195	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.195	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.195	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.195	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.195	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.194	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.193	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.190	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.189	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.189	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.189	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.189	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.189	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.189	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.188	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.187	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.186	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.185	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.185	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.185	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.185	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.185	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.185	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.184	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.183	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.180	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.179	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.179	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.179	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.179	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.179	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.179	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.174	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.173	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.171	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.170	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.170	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.170	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.170	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.170	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.170	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.169	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.168	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.167	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.166	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.166	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.166	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.166	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.166	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.166	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.165	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.158	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.157	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.156	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.156	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.156	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.156	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.156	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.156	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.155	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.154	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.153	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.152	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.152	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.152	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.152	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.152	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.152	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.151	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.150	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.148	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.135	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.135	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.135	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.135	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.135	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.135	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.117	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.116	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.114	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.113	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.113	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.113	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.113	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.113	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.113	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.113	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.112	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.110	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.109	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.109	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.109	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.109	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.109	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.109	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.108	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.107	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.106	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.105	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.105	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.105	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.105	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.105	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.105	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.104	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.103	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.099	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.098	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.098	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.098	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.098	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.098	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.098	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.097	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.096	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.095	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.094	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.094	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.094	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.094	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.094	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.094	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.093	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.092	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.090	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.089	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.089	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.089	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.089	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.089	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.089	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.088	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.087	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.085	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.085	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.085	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.085	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.085	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.085	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.085	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.084	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.079	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.077	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.076	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.076	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.076	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.076	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.076	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.076	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.076	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.073	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.071	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.070	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.070	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.070	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.070	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.070	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.070	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.069	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.068	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.066	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.066	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.066	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.066	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.066	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.066	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.066	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.065	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.064	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.062	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.061	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.061	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.061	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.061	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.061	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.061	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.060	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.059	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.055	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.054	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.054	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.054	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.054	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.054	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.054	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.053	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.052	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.050	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.049	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.049	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.049	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.049	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.049	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.049	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.048	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.047	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.045	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.044	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.044	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.044	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.044	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.044	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.044	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.043	error	(5569) unhandled promise rejection: DB closed
    hs100.0	2022-01-16 16:58:36.042	error	(5569) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0	2022-01-16 16:58:36.040	error	(5569) DB closed
    hs100.0	2022-01-16 16:58:36.039	error	at TCP.<anonymous> (net.js:675:12)
    hs100.0	2022-01-16 16:58:36.039	error	at Socket.emit (events.js:314:20)
    hs100.0	2022-01-16 16:58:36.039	error	at Object.onceWrapper (events.js:421:26)
    hs100.0	2022-01-16 16:58:36.039	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
    hs100.0	2022-01-16 16:58:36.039	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
    hs100.0	2022-01-16 16:58:36.039	error	(5569) Error: DB closed
    hs100.0	2022-01-16 16:58:36.038	error	(5569) unhandled promise rejection: DB closed
    Kann leider den Fehler nicht finden.
    Danke für eure Hilfe.
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      GlasfaserG Offline
      GlasfaserG Offline
      @gregors sagte in [gelöst] HS100-Adapter stürzt immer wieder ab:
      ?? brauchst du noch Hilfe .
      Du hast im Threadtitel :
      GregorSG 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        GregorSG Offline
        GregorSG Offline
        GregorS
        @glasfaser
        Sah erst gut aus, aber jetzt kackt er wieder ab.
        host.TinkerboardS	2022-01-16 18:25:43.966	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.TinkerboardS	2022-01-16 18:25:43.965	error	Caught by controller[3]: }
        host.TinkerboardS	2022-01-16 18:25:43.964	error	Caught by controller[3]: syscall: 'read'
        host.TinkerboardS	2022-01-16 18:25:43.964	error	Caught by controller[3]: code: 'ECONNRESET',
        host.TinkerboardS	2022-01-16 18:25:43.963	error	Caught by controller[3]: errno: 'ECONNRESET',
        host.TinkerboardS	2022-01-16 18:25:43.962	error	Caught by controller[3]: at TCP.onStreamRead (internal/stream_base_commons.js:209:20) {
        host.TinkerboardS	2022-01-16 18:25:43.961	error	Caught by controller[3]: [Waschmaschine] device.send() Error: read ECONNRESET
        host.TinkerboardS	2022-01-16 18:25:43.960	error	Caught by controller[2]: }
        host.TinkerboardS	2022-01-16 18:25:43.958	error	Caught by controller[2]: syscall: 'read'
        host.TinkerboardS	2022-01-16 18:25:43.953	error	Caught by controller[2]: code: 'ECONNRESET',
        host.TinkerboardS	2022-01-16 18:25:43.948	error	Caught by controller[2]: errno: 'ECONNRESET',
        host.TinkerboardS	2022-01-16 18:25:43.947	error	Caught by controller[2]: at TCP.onStreamRead (internal/stream_base_commons.js:209:20) {
        host.TinkerboardS	2022-01-16 18:25:43.946	error	Caught by controller[2]: TCP 192.168.10.147:9999 Error: read ECONNRESET
        host.TinkerboardS	2022-01-16 18:25:43.946	error	Caught by controller[1]: at processTimers (internal/timers.js:497:7)
        host.TinkerboardS	2022-01-16 18:25:43.945	error	Caught by controller[1]: at listOnTimeout (internal/timers.js:554:17)
        host.TinkerboardS	2022-01-16 18:25:43.944	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
        host.TinkerboardS	2022-01-16 18:25:43.943	error	Caught by controller[1]: 192.168.10.148:9999 {"system":{"get_sysinfo":{}}}
        host.TinkerboardS	2022-01-16 18:25:43.926	error	Caught by controller[1]: TCP 192.168.10.148:9999 Error: TCP Timeout after 10000ms
        hs100.0	2022-01-16 18:25:42.885	warn	(9042) Terminated (UNCAUGHT_EXCEPTION): Without reason
        hs100.0	2022-01-16 18:25:42.862	error	(9042) Exception-Code: ECONNRESET: read ECONNRESET
        hs100.0	2022-01-16 18:25:42.860	error	at TCP.onStreamRead (internal/stream_base_commons.js:209:20)
        hs100.0	2022-01-16 18:25:42.860	error	(9042) Error: read ECONNRESET
        hs100.0	2022-01-16 18:25:42.859	error	(9042) unhandled promise rejection: read ECONNRESET
        hs100.0	2022-01-16 18:25:42.857	error	(9042) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        hs100.0	2022-01-16 18:25:30.509	warn	(9042) getDevice Socket connection Timeout ip: 192.168.10.148 please reconnect the Device
        hs100.0	2022-01-16 18:25:00.508	warn	(9042) getDevice Socket connection Timeout ip: 192.168.10.147 please reconnect the Device
        hs100.0	2022-01-16 18:24:53.572	warn	(9042) getDevice Socket connection Timeout ip: 192.168.10.148 please reconnect the Device
        hs100.0	2022-01-16 18:24:30.514	warn	(9042) getDevice Socket connection Timeout ip: 192.168.10.148 please reconnect the Device
        hs100.0	2022-01-16 18:24:30.506	warn	(9042) getDevice Socket connection Timeout ip: 192.168.10.147 please reconnect the Device
        Ich glaube ich habe ein Problem mit der Erreichbarkeit von .147 und .148
        Ping ist aber einwandfrei <20ms.
        Die beiden hängen an einem Repeater der über DLAN eingespeist wird.
        Allerdings läuft darüber Sonntags auch eine Sicherung auf einem Server.
        Behalte ich mal im Auge
        • arteckA Offline
          arteckA Offline
          arteck
          @gregors sagte in HS100-Adapter stürzt immer wieder ab:
          0000ms
          welche Adapter Version ?? nimm die aus GIT
          zeigmal die Aktualisierungswerte
          • arteckA arteck
            0000ms
            GregorSG Offline
            GregorSG Offline
            GregorS
            @arteck
            Hatte den 2.06 installiert, bin jetzt testweise zurück auf den 2.05.
            hs100.0	2022-01-17 17:57:54.240	error	(9862) Connection is closed.
            hs100.0	2022-01-17 17:57:54.239	error	at processImmediate (internal/timers.js:463:21)
            hs100.0	2022-01-17 17:57:54.239	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2332:33)
            hs100.0	2022-01-17 17:57:54.239	error	at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2286:37)
            hs100.0	2022-01-17 17:57:54.239	error	at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
            hs100.0	2022-01-17 17:57:54.239	error	at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
            hs100.0	2022-01-17 17:57:54.239	error	(9862) Error: Connection is closed.
            hs100.0	2022-01-17 17:57:54.235	error	(9862) unhandled promise rejection: Connection is closed.
            hs100.0	2022-01-17 17:57:54.234	error	(9862) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            hs100.0	2022-01-17 17:57:54.232	error	(9862) Connection is closed.
            		debug	at processImmediate (internal/timers.js:463:21)
            		debug	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2332:33)
            		debug	at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2286:37)
            		debug	at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
            		debug	at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
            • GregorSG GregorS
              @arteck
              arteckA Offline
              arteckA Offline
              arteck
              @gregors das kmmt zwar auf dem hs100 Adapter aber hat damit nix zu tun..
              ist die platte/SD-Karte voll ??
              da kann was nicht geschrieben werden
              • arteckA arteck
                GregorSG Offline
                GregorSG Offline
                GregorS
                @arteck
                Seit dem Downgrade gibt es bis heute keine Abstürze mehr.
                Plattenplatz verfügbar 55,7%, RAM frei 24%.
                Alles im grünen Bereich
                  skokarl
                  Hallo @arteck
                  machst Du noch was an dem HS Adapter ?
                  Hab aktuell 2.07 installiert, und unten stehende Meldung kommt immer mal wieder.
                  Kommt wahrscheinlich auch öfter, weil manche Steckdosen die WLAN Verbindung verlieren, wobei ich nicht
                  glaube dass das an Dir liegt ( Waschmaschinenraum )
                  Aber der type ist eben falsch definiert.
                  2022-03-02 08:22:03.736	warn	This object will not be created in future versions. Please report this to the developer.
                  hs100.0
                  	2022-03-02 08:22:03.736	warn	Object 192_168_178_40.last_update is invalid: Default value has to be type "string" but received type "number"
                  hs100.0
                  	2022-03-02 08:22:03.645	info	Start with IP : 192.168.178.40
                  • S skokarl
                    Hallo @arteck
                    hs100.0
                    hs100.0
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @skokarl sagte in HS100-Adapter stürzt immer wieder ab:
                    was soll ich da machen deinermeinung nach ?? gibts offene issues ??
                    die problematik mit dem invalid value ist schon 100000 besprochen worden(lösche das object und starte den adapter neu)
                    • arteckA arteck
                      skokarl
                      @arteck
                      ok,
                      dann muss ich mal nen issue machen .... vermutlich kannst Du gar nix dafür, glaube die HS100 Dosen sind wohl nicht so
                      gut, blöd nur wenn man davon viele hat. Nix für ungut.
                      Objekte gelöscht, Adapter neu gestartet.
                      • S skokarl
                        @arteck
                        ok,
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @skokarl hast du den adapter von GIT ?
                        die HS Dosen verlangen eine bestehende WLAN Verbindung.. ja die meckern wenn das nicht der fall ist
                        wie ist das timeout eingestellt ? in Einstellungen
                        • arteckA arteck
                          skokarl
                          @arteck
                          eben nochmal alles gelöscht, und von github neu installiert.
                          Abfrage steht auf 30 sek.
                          Wenns nicht besser wird, müssen eben andere Steckdosen her, mal gucken.
                          Danke Dir.
                          • GregorSG GregorS
                            @arteck
                            Spidermike
                            schrieb am zuletzt editiert von Spidermike
                            @gregors
                            habt ihr jetzt eine gute Lösung für das Problem gefunden?
                            ich bekomme auch immer viele Fehlermeldungen
                            host.raspberrypi4-iobroker
                            	2022-10-01 18:10:11.133	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            	2022-10-01 18:10:11.133	error	Caught by controller[15]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.132	error	Caught by controller[15]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.132	error	Caught by controller[15]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.132	error	Caught by controller[15]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                            	2022-10-01 18:10:11.132	error	Caught by controller[15]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.132	error	Caught by controller[14]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.132	error	Caught by controller[14]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.132	error	Caught by controller[14]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.132	error	Caught by controller[14]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                            	2022-10-01 18:10:11.131	error	Caught by controller[14]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.131	error	Caught by controller[13]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.131	error	Caught by controller[13]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.131	error	Caught by controller[13]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.131	error	Caught by controller[13]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.131	error	Caught by controller[13]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.131	error	Caught by controller[12]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.130	error	Caught by controller[12]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.130	error	Caught by controller[12]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.130	error	Caught by controller[12]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.130	error	Caught by controller[12]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.130	error	Caught by controller[11]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.130	error	Caught by controller[11]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.130	error	Caught by controller[11]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.129	error	Caught by controller[11]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.129	error	Caught by controller[11]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.129	error	Caught by controller[10]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.129	error	Caught by controller[10]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.129	error	Caught by controller[10]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.129	error	Caught by controller[10]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.129	error	Caught by controller[10]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.129	error	Caught by controller[9]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.128	error	Caught by controller[9]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.128	error	Caught by controller[9]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.128	error	Caught by controller[9]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.128	error	Caught by controller[9]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.128	error	Caught by controller[8]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.128	error	Caught by controller[8]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.128	error	Caught by controller[8]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.127	error	Caught by controller[8]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.127	error	Caught by controller[8]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.127	error	Caught by controller[7]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.127	error	Caught by controller[7]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.127	error	Caught by controller[7]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.127	error	Caught by controller[7]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.127	error	Caught by controller[7]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.126	error	Caught by controller[6]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.126	error	Caught by controller[6]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.126	error	Caught by controller[6]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.126	error	Caught by controller[6]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.126	error	Caught by controller[6]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.126	error	Caught by controller[5]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.126	error	Caught by controller[5]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.125	error	Caught by controller[5]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.125	error	Caught by controller[5]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.125	error	Caught by controller[5]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.125	error	Caught by controller[4]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.125	error	Caught by controller[4]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.125	error	Caught by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.125	error	Caught by controller[4]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.124	error	Caught by controller[4]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.124	error	Caught by controller[3]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.124	error	Caught by controller[3]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.124	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.124	error	Caught by controller[3]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.123	error	Caught by controller[3]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.123	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.123	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.123	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.123	error	Caught by controller[2]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.123	error	Caught by controller[2]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:10:11.123	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:10:11.122	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:10:11.122	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:10:11.122	error	Caught by controller[1]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:10:11.122	error	Caught by controller[1]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                            hs100.0
                            	2022-10-01 18:10:10.485	error	TCP Timeout after 10000ms 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                            hs100.0
                            	2022-10-01 18:10:10.484	error	Error: TCP Timeout after 10000ms 192.168.178.94:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                            hs100.0
                            	2022-10-01 18:10:10.483	error	unhandled promise rejection: TCP Timeout after 10000ms 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                            hs100.0
                            	2022-10-01 18:10:10.482	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            	2022-10-01 18:08:38.854	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            	2022-10-01 18:08:38.854	error	Caught by controller[7]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.854	error	Caught by controller[7]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:08:38.853	error	Caught by controller[7]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.853	error	Caught by controller[7]: 192.168.178.95:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:08:38.853	error	Caught by controller[7]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:08:38.853	error	Caught by controller[6]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.853	error	Caught by controller[6]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:08:38.852	error	Caught by controller[6]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.852	error	Caught by controller[6]: 192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                            	2022-10-01 18:08:38.852	error	Caught by controller[6]: [Geschirrspüler Steckdose] device.send() Error: TCP Timeout after 10000ms
                            	2022-10-01 18:08:38.852	error	Caught by controller[5]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.852	error	Caught by controller[5]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:08:38.852	error	Caught by controller[5]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.851	error	Caught by controller[5]: 192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                            	2022-10-01 18:08:38.851	error	Caught by controller[5]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:08:38.851	error	Caught by controller[4]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.851	error	Caught by controller[4]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:08:38.851	error	Caught by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.851	error	Caught by controller[4]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:08:38.851	error	Caught by controller[4]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:08:38.850	error	Caught by controller[4]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.850	error	Caught by controller[4]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:08:38.850	error	Caught by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.850	error	Caught by controller[4]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:08:38.850	error	Caught by controller[4]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:08:38.850	error	Caught by controller[3]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.849	error	Caught by controller[3]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:08:38.849	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.849	error	Caught by controller[3]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:08:38.849	error	Caught by controller[3]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:08:38.849	error	Caught by controller[3]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.848	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.848	error	Caught by controller[3]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:08:38.848	error	Caught by controller[3]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:08:38.848	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.848	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:08:38.848	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.847	error	Caught by controller[2]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:08:38.847	error	Caught by controller[2]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 18:08:38.847	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 18:08:38.847	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 18:08:38.847	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 18:08:38.847	error	Caught by controller[1]: 192.168.178.38:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 18:08:38.845	error	Caught by controller[1]: TCP 192.168.178.38:9999 Error: TCP Timeout after 10000ms
                            hs100.0
                            	2022-10-01 18:08:38.247	error	TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                            hs100.0
                            	2022-10-01 18:08:38.247	error	Error: TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                            hs100.0
                            	2022-10-01 18:08:38.247	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                            hs100.0
                            	2022-10-01 18:08:38.246	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            	2022-10-01 13:09:14.462	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            	2022-10-01 13:09:14.461	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 13:09:14.461	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 13:09:14.461	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 13:09:14.461	error	Caught by controller[2]: 192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                            	2022-10-01 13:09:14.461	error	Caught by controller[2]: [Geschirrspüler Steckdose] device.send() Error: TCP Timeout after 10000ms
                            	2022-10-01 13:09:14.460	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 13:09:14.460	error	Caught by controller[2]: 192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                            	2022-10-01 13:09:14.460	error	Caught by controller[2]: TCP 192.168.178.95:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 13:09:14.460	error	Caught by controller[1]: }
                            	2022-10-01 13:09:14.460	error	Caught by controller[1]: port: 9999
                            	2022-10-01 13:09:14.460	error	Caught by controller[1]: address: '192.168.178.95',
                            	2022-10-01 13:09:14.460	error	Caught by controller[1]: syscall: 'connect',
                            	2022-10-01 13:09:14.459	error	Caught by controller[1]: code: 'ECONNREFUSED',
                            	2022-10-01 13:09:14.459	error	Caught by controller[1]: errno: -111,
                            	2022-10-01 13:09:14.459	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1247:16) {
                            	2022-10-01 13:09:14.457	error	Caught by controller[1]: TCP 192.168.178.95:9999 Error: connect ECONNREFUSED 192.168.178.95:9999
                            hs100.0
                            	2022-10-01 13:09:13.859	error	TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                            hs100.0
                            	2022-10-01 13:09:13.857	error	Error: TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                            hs100.0
                            	2022-10-01 13:09:13.856	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.95:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                            hs100.0
                            	2022-10-01 13:09:13.855	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            	2022-10-01 08:58:05.593	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            	2022-10-01 08:58:05.593	error	Caught by controller[3]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 08:58:05.593	error	Caught by controller[3]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 08:58:05.592	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 08:58:05.592	error	Caught by controller[3]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
                            	2022-10-01 08:58:05.592	error	Caught by controller[3]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            	2022-10-01 08:58:05.592	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 08:58:05.592	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 08:58:05.592	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 08:58:05.592	error	Caught by controller[2]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                            	2022-10-01 08:58:05.591	error	Caught by controller[2]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
                            	2022-10-01 08:58:05.591	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
                            	2022-10-01 08:58:05.591	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
                            	2022-10-01 08:58:05.591	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                            	2022-10-01 08:58:05.591	error	Caught by controller[1]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                            	2022-10-01 08:58:05.589	error	Caught by controller[1]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                            hs100.0
                            	2022-10-01 08:58:04.962	error	TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                            hs100.0
                            	2022-10-01 08:58:04.961	error	Error: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            	2022-10-01 08:58:04.961	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
                            hs100.0
                            	2022-10-01 08:58:04.960	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            hs100.0
                            	2022-10-01 18:08:38.247	error	TCP Timeout after 10000ms 192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                            hs100.0
                            	2022-10-01 18:08:38.247	error	Error: TCP Timeout after 10000ms 192.168.178.95:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                            hs100.0
                            	2022-10-01 18:08:38.247	error	unhandled promise rejection: TCP Timeout after 10000ms 192.168.178.95:9999 {"emeter":{"get_realtime":{}}}
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            hs100.0
                            iot.0
                            	2022-10-01 03:40:30.676	error	Error by device connection: "read ECONNRESET"
                            ich hoffe mir kann jemand helfen?
                            • S Spidermike
                              @gregors
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              hs100.0
                              iot.0
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @spidermike sagte in HS100-Adapter stürzt immer wieder ab:
                              immer noch das selbe.. die Dose läuft auf Timeout
                              installier mal von GIT .. und check nochmal
                              • arteckA arteck
                                Spidermike
                                ich habe immernoch manchmal fehlermeldungen
                                Habe alles gemacht was mir vorgeschlagen wurde,
                                Heute bei guten Bedingungen und ich am Rechner war und habe es überwacht, da hat alles funktioniert aber später wo eigentlich keine Sonne mehr da war kamen die Fehlermeldungen.
                                		2022-10-22 18:48:21.073	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                		2022-10-22 18:48:21.073	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
                                		2022-10-22 18:48:21.072	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
                                		2022-10-22 18:48:21.072	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                                		2022-10-22 18:48:21.072	error	Caught by controller[2]: 192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
                                		2022-10-22 18:48:21.072	error	Caught by controller[2]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
                                		2022-10-22 18:48:21.072	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
                                		2022-10-22 18:48:21.072	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
                                		2022-10-22 18:48:21.071	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
                                		2022-10-22 18:48:21.071	error	Caught by controller[1]: 192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
                                		2022-10-22 18:48:21.071	error	Caught by controller[1]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
                                hs100.0
                                	1007	2022-10-22 18:48:20.467	error	TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
                                hs100.0
                                	1007	2022-10-22 18:48:20.467	error	Error: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                                hs100.0
                                	1007	2022-10-22 18:48:20.466	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
                                hs100.0
                                	1007	2022-10-22 18:48:20.465	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a pro
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  für alle die Probleme haben
                                  einmal bitte die GIT version installieren...
                                  dann schauen wir nochmal
                                  • arteckA arteck
                                    mike2712
                                    @arteck
                                    seit einigen Tagen funktioniert aus unerklärlichen Gründen der HS Adapter bei mir nicht mehr, in der Smart Home App funktioniert alles, die benutze ich aber eigentlich nicht, anbei der LOG, leider kann ich da nicht viel mit anfangen.
                                    Jemand eine Idee warum das nicht mehr funktioniert?
                                    hs100.0
                                    2023-04-26 23:37:54.448	warn	Socket connection Timeout 172_16_22_38 TP-Link-Steckdose-38 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:54.446	warn	Socket connection Timeout 172_16_22_11 TP-Link-Steckdose-11 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:54.444	warn	Socket connection Timeout 172_16_22_31 TP-Link-Steckdose-31 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:54.442	warn	Socket connection Timeout 172_16_22_32 TP-Link-Steckdose-32 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:54.440	warn	Socket connection Timeout 172_16_22_33 TP-Link-Steckdose-33 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:54.438	warn	Socket connection Timeout 172_16_22_34 TP-Link-Steckdose-34 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:54.435	warn	Socket connection Timeout 172_16_22_35 TP-Link-Steckdose-35 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:54.432	warn	Socket connection Timeout 172_16_22_36 TP-Link-Steckdose-36 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:54.429	warn	Socket connection Timeout 172_16_22_37 TP-Link-Steckdose-37 please reconnect the Device
                                    hs100.0
                                    2023-04-26 23:37:51.360	debug	get Information
                                    hs100.0
                                    2023-04-26 23:37:51.357	debug	State already present 172.16.22.38
                                    hs100.0
                                    2023-04-26 23:37:48.288	debug	create_state for IP : 172.16.22.38
                                    hs100.0
                                    2023-04-26 23:37:48.288	info	Start with 172.16.22.38 TP-Link-Steckdose-38
                                    hs100.0
                                    2023-04-26 23:37:48.285	debug	State already present 172.16.22.37
                                    hs100.0
                                    2023-04-26 23:37:45.213	debug	create_state for IP : 172.16.22.37
                                    hs100.0
                                    2023-04-26 23:37:45.213	info	Start with 172.16.22.37 TP-Link-Steckdose-37
                                    hs100.0
                                    2023-04-26 23:37:45.212	debug	State already present 172.16.22.36
                                    hs100.0
                                    2023-04-26 23:37:42.142	debug	create_state for IP : 172.16.22.36
                                    hs100.0
                                    2023-04-26 23:37:42.141	info	Start with 172.16.22.36 TP-Link-Steckdose-36
                                    hs100.0
                                    2023-04-26 23:37:42.140	debug	State already present 172.16.22.35
                                    hs100.0
                                    2023-04-26 23:37:39.015	debug	create_state for IP : 172.16.22.35
                                    hs100.0
                                    2023-04-26 23:37:39.014	info	Start with 172.16.22.35 TP-Link-Steckdose-35
                                    hs100.0
                                    2023-04-26 23:37:39.013	debug	State already present 172.16.22.34
                                    hs100.0
                                    2023-04-26 23:37:35.939	debug	create_state for IP : 172.16.22.34
                                    hs100.0
                                    2023-04-26 23:37:35.938	info	Start with 172.16.22.34 TP-Link-Steckdose-34
                                    hs100.0
                                    2023-04-26 23:37:35.937	debug	State already present 172.16.22.33
                                    hs100.0
                                    2023-04-26 23:37:32.865	debug	create_state for IP : 172.16.22.33
                                    hs100.0
                                    2023-04-26 23:37:32.864	info	Start with 172.16.22.33 TP-Link-Steckdose-33
                                    hs100.0
                                    2023-04-26 23:37:32.862	debug	State already present 172.16.22.32
                                    hs100.0
                                    2023-04-26 23:37:29.790	debug	create_state for IP : 172.16.22.32
                                    hs100.0
                                    2023-04-26 23:37:29.789	info	Start with 172.16.22.32 TP-Link-Steckdose-32
                                    hs100.0
                                    2023-04-26 23:37:29.788	debug	State already present 172.16.22.31
                                    hs100.0
                                    2023-04-26 23:37:26.729	debug	create_state for IP : 172.16.22.31
                                    hs100.0
                                    2023-04-26 23:37:26.728	info	Start with 172.16.22.31 TP-Link-Steckdose-31
                                    hs100.0
                                    2023-04-26 23:37:26.726	debug	State already present 172.16.22.11
                                    hs100.0
                                    2023-04-26 23:37:23.595	debug	create_state for IP : 172.16.22.11
                                    hs100.0
                                    2023-04-26 23:37:23.591	info	Start with 172.16.22.11 TP-Link-Steckdose-11
                                    hs100.0
                                    2023-04-26 23:37:23.588	debug	create state
                                    hs100.0
                                    2023-04-26 23:37:23.438	debug	Schedule restart: 59 11,23 * * *
                                    hs100.0
                                    2023-04-26 23:37:23.264	info	starting. Version 2.1.6 (non-npm: arteck/ioBroker.hs100) in /opt/iobroker/node_modules/iobroker.hs100, node: v16.19.0, js-controller: 4.0.24
                                    ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
