  4. Alternative zu HS100-Adapter?
    5.6k
30 Beiträge 10 Kommentatoren 3.7k Aufrufe 8 Beobachtet
  • B BF0911
    @mrbungle64
    Zeile 529: 2022-09-14 08:16:22.054 - info: host.raspberrypi instance system.adapter.hs100.0 started with pid 4393
    	Zeile 530: 2022-09-14 08:16:23.657 - debug: hs100.0 (4393) Redis Objects: Use Redis connection: 127.0.0.1:9001
    	Zeile 531: 2022-09-14 08:16:23.728 - debug: hs100.0 (4393) Objects client ready ... initialize now
    	Zeile 532: 2022-09-14 08:16:23.732 - debug: hs100.0 (4393) Objects create System PubSub Client
    	Zeile 533: 2022-09-14 08:16:23.733 - debug: hs100.0 (4393) Objects create User PubSub Client
    	Zeile 534: 2022-09-14 08:16:23.822 - debug: hs100.0 (4393) Objects client initialize lua scripts
    	Zeile 535: 2022-09-14 08:16:23.834 - debug: hs100.0 (4393) Objects connected to redis: 127.0.0.1:9001
    	Zeile 536: 2022-09-14 08:16:23.880 - debug: hs100.0 (4393) Redis States: Use Redis connection: 127.0.0.1:9000
    	Zeile 537: 2022-09-14 08:16:23.906 - debug: hs100.0 (4393) States create System PubSub Client
    	Zeile 538: 2022-09-14 08:16:23.908 - debug: hs100.0 (4393) States create User PubSub Client
    	Zeile 539: 2022-09-14 08:16:23.951 - debug: hs100.0 (4393) States connected to redis: 127.0.0.1:9000
    	Zeile 542: 2022-09-14 08:16:24.338 - info: hs100.0 (4393) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.hs100, node: v16.17.0, js-controller: 4.0.23
    	Zeile 543: 2022-09-14 08:16:24.388 - debug: hs100.0 (4393) create state
    	Zeile 544: 2022-09-14 08:16:24.391 - info: hs100.0 (4393) Start with IP : 192.168.178.31
    	Zeile 545: 2022-09-14 08:16:24.872 - info: host.raspberrypi stopInstance system.adapter.hs100.0 (force=false, process=true)
    	Zeile 546: 2022-09-14 08:16:24.879 - info: host.raspberrypi stopInstance system.adapter.hs100.0 send kill signal
    	Zeile 547: 2022-09-14 08:16:24.879 - info: hs100.0 (4393) Got terminate signal TERMINATE_YOURSELF
    	Zeile 548: 2022-09-14 08:16:24.881 - info: hs100.0 (4393) cleaned everything up...
    	Zeile 549: 2022-09-14 08:16:24.883 - info: hs100.0 (4393) terminating
    	Zeile 550: 2022-09-14 08:16:24.884 - info: hs100.0 (4393) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    	Zeile 551: 2022-09-14 08:16:25.539 - info: host.raspberrypi instance system.adapter.hs100.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    	Zeile 553: 2022-09-14 08:16:28.028 - info: host.raspberrypi instance system.adapter.hs100.0 started with pid 4410
    	Zeile 554: 2022-09-14 08:16:29.472 - debug: hs100.0 (4410) Redis Objects: Use Redis connection: 127.0.0.1:9001
    	Zeile 555: 2022-09-14 08:16:29.527 - debug: hs100.0 (4410) Objects client ready ... initialize now
    	Zeile 556: 2022-09-14 08:16:29.530 - debug: hs100.0 (4410) Objects create System PubSub Client
    	Zeile 557: 2022-09-14 08:16:29.531 - debug: hs100.0 (4410) Objects create User PubSub Client
    	Zeile 558: 2022-09-14 08:16:29.603 - debug: hs100.0 (4410) Objects client initialize lua scripts
    	Zeile 559: 2022-09-14 08:16:29.611 - debug: hs100.0 (4410) Objects connected to redis: 127.0.0.1:9001
    	Zeile 560: 2022-09-14 08:16:29.652 - debug: hs100.0 (4410) Redis States: Use Redis connection: 127.0.0.1:9000
    	Zeile 561: 2022-09-14 08:16:29.675 - debug: hs100.0 (4410) States create System PubSub Client
    	Zeile 562: 2022-09-14 08:16:29.677 - debug: hs100.0 (4410) States create User PubSub Client
    	Zeile 563: 2022-09-14 08:16:29.719 - debug: hs100.0 (4410) States connected to redis: 127.0.0.1:9000
    	Zeile 564: 2022-09-14 08:16:29.995 - info: hs100.0 (4410) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.hs100, node: v16.17.0, js-controller: 4.0.23
    	Zeile 565: 2022-09-14 08:16:30.033 - debug: hs100.0 (4410) create state
    	Zeile 566: 2022-09-14 08:16:30.034 - info: hs100.0 (4410) Start with IP : 192.168.178.31
    	Zeile 567: 2022-09-14 08:16:36.287 - debug: hs100.0 (4410) State already present 192.168.178.31
    	Zeile 568: 2022-09-14 08:16:36.289 - info: hs100.0 (4410) Start with IP : 192.168.178.32
    	Zeile 570: 2022-09-14 08:16:46.294 - debug: hs100.0 (4410) State already present 192.168.178.32
    	Zeile 571: 2022-09-14 08:16:46.296 - info: hs100.0 (4410) Start with IP : 192.168.178.33
    	Zeile 572: 2022-09-14 08:16:46.330 - debug: hs100.0 (4410) create_state for IP : 192.168.178.33
    	Zeile 573: 2022-09-14 08:16:46.334 - warn: hs100.0 (4410) Object 192_168_178_33.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 574: 2022-09-14 08:16:46.335 - warn: hs100.0 (4410) This object will not be created in future versions. Please report this to the developer.
    	Zeile 575: 2022-09-14 08:16:46.341 - debug: hs100.0 (4410) HS100(EU) generated 192.168.178.33
    	Zeile 576: 2022-09-14 08:16:46.342 - info: hs100.0 (4410) Start with IP : 192.168.178.34
    	Zeile 577: 2022-09-14 08:16:46.383 - debug: hs100.0 (4410) create_state for IP : 192.168.178.34
    	Zeile 578: 2022-09-14 08:16:46.385 - warn: hs100.0 (4410) Object 192_168_178_34.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 579: 2022-09-14 08:16:46.386 - warn: hs100.0 (4410) This object will not be created in future versions. Please report this to the developer.
    	Zeile 580: 2022-09-14 08:16:46.387 - debug: hs100.0 (4410) HS100(EU) generated 192.168.178.34
    	Zeile 581: 2022-09-14 08:16:46.388 - info: hs100.0 (4410) Start with IP : 192.168.178.35
    	Zeile 582: 2022-09-14 08:16:46.427 - debug: hs100.0 (4410) create_state for IP : 192.168.178.35
    	Zeile 583: 2022-09-14 08:16:46.428 - warn: hs100.0 (4410) Object 192_168_178_35.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 584: 2022-09-14 08:16:46.429 - warn: hs100.0 (4410) This object will not be created in future versions. Please report this to the developer.
    	Zeile 585: 2022-09-14 08:16:46.430 - debug: hs100.0 (4410) KP105(EU) generated 192.168.178.35
    	Zeile 586: 2022-09-14 08:16:46.430 - info: hs100.0 (4410) Start with IP : 192.168.178.36
    	Zeile 587: 2022-09-14 08:16:46.553 - debug: hs100.0 (4410) create_state for IP : 192.168.178.36
    	Zeile 588: 2022-09-14 08:16:46.554 - warn: hs100.0 (4410) Object 192_168_178_36.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 589: 2022-09-14 08:16:46.555 - warn: hs100.0 (4410) This object will not be created in future versions. Please report this to the developer.
    	Zeile 590: 2022-09-14 08:16:46.556 - warn: hs100.0 (4410) Object 192_168_178_36.ledState is invalid: Default value has to be type "string" but received type "boolean"
    	Zeile 591: 2022-09-14 08:16:46.557 - warn: hs100.0 (4410) This object will not be created in future versions. Please report this to the developer.
    	Zeile 592: 2022-09-14 08:16:46.558 - debug: hs100.0 (4410) KP115(EU) generated 192.168.178.36
    	Zeile 593: 2022-09-14 08:16:46.560 - debug: hs100.0 (4410) get Information
    	Zeile 595: 2022-09-14 08:16:46.736 - debug: hs100.0 (4410) Refresh 192.168.178.34 Model = HS100(EU) state = false update = 2022.9.14 08:16:46
    	Zeile 596: 2022-09-14 08:16:46.739 - debug: hs100.0 (4410) Refresh 192.168.178.35 Model = KP105(EU) state = false update = 2022.9.14 08:16:46
    	Zeile 597: 2022-09-14 08:16:46.740 - debug: hs100.0 (4410) Refresh 192.168.178.33 Model = HS100(EU) state = false update = 2022.9.14 08:16:46
    	Zeile 598: 2022-09-14 08:16:46.773 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_34.state changed: false (ack = true)
    	Zeile 599: 2022-09-14 08:16:46.824 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_35.state changed: false (ack = true)
    	Zeile 600: 2022-09-14 08:16:46.825 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_33.state changed: false (ack = true)
    	Zeile 601: 2022-09-14 08:16:46.833 - debug: hs100.0 (4410) Refresh 192.168.178.36 Model = KP115(EU) state = true update = 2022.9.14 08:16:46
    	Zeile 602: 2022-09-14 08:16:46.855 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_36.state changed: true (ack = true)
    	Zeile 603: 2022-09-14 08:16:46.910 - debug: hs100.0 (4410) Refresh 192.168.178.31 Model = HS100(EU) state = true update = 2022.9.14 08:16:46
    	Zeile 604: 2022-09-14 08:16:47.027 - debug: hs100.0 (4410) Refresh Data HS110 192.168.178.36
    	Zeile 605: 2022-09-14 08:16:47.150 - debug: hs100.0 (4410) Month value Model : KP115(EU) IP : 192.168.178.36
    	Zeile 606: 2022-09-14 08:16:47.279 - debug: hs100.0 (4410) Day value for Model : KP115(EU) Energy : 0 IP : 192.168.178.36
    	Zeile 607: 2022-09-14 08:16:49.707 - warn: hs100.0 (4410) getDevice Socket connection Timeout ip: 192.168.178.32 please reconnect the Device
    	Zeile 611: 2022-09-14 08:18:16.565 - debug: hs100.0 (4410) get Information
    	Zeile 612: 2022-09-14 08:18:16.634 - debug: hs100.0 (4410) Refresh 192.168.178.34 Model = HS100(EU) state = false update = 2022.9.14 08:18:16
    	Zeile 613: 2022-09-14 08:18:16.643 - debug: hs100.0 (4410) Refresh 192.168.178.35 Model = KP105(EU) state = false update = 2022.9.14 08:18:16
    	Zeile 614: 2022-09-14 08:18:16.648 - debug: hs100.0 (4410) Refresh 192.168.178.33 Model = HS100(EU) state = false update = 2022.9.14 08:18:16
    	Zeile 615: 2022-09-14 08:18:16.673 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_34.state changed: false (ack = true)
    	Zeile 616: 2022-09-14 08:18:16.682 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_35.state changed: false (ack = true)
    	Zeile 617: 2022-09-14 08:18:16.695 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_33.state changed: false (ack = true)
    	Zeile 618: 2022-09-14 08:18:16.734 - debug: hs100.0 (4410) Refresh 192.168.178.31 Model = HS100(EU) state = true update = 2022.9.14 08:18:16
    	Zeile 619: 2022-09-14 08:18:16.752 - debug: hs100.0 (4410) Refresh 192.168.178.36 Model = KP115(EU) state = true update = 2022.9.14 08:18:16
    	Zeile 620: 2022-09-14 08:18:16.774 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_36.state changed: true (ack = true)
    	Zeile 621: 2022-09-14 08:18:16.868 - debug: hs100.0 (4410) Refresh Data HS110 192.168.178.36
    	Zeile 622: 2022-09-14 08:18:17.094 - debug: hs100.0 (4410) Month value Model : KP115(EU) IP : 192.168.178.36
    	Zeile 623: 2022-09-14 08:18:17.208 - debug: hs100.0 (4410) Day value for Model : KP115(EU) Energy : 0 IP : 192.168.178.36
    	Zeile 624: 2022-09-14 08:18:17.857 - debug: hs100.0 (4410) Refresh 192.168.178.32 Model = HS110(EU) state = true update = 2022.9.14 08:18:17
    	Zeile 625: 2022-09-14 08:18:18.147 - debug: hs100.0 (4410) Refresh Data HS110 192.168.178.32
    	Zeile 626: 2022-09-14 08:18:18.437 - debug: hs100.0 (4410) Month value Model : HS110(EU) IP : 192.168.178.32
    	Zeile 627: 2022-09-14 08:18:18.733 - debug: hs100.0 (4410) Day value for Model : HS110(EU) Energy : 0.004 IP : 192.168.178.32
    	Zeile 630: 2022-09-14 08:19:46.570 - debug: hs100.0 (4410) get Information
    	Zeile 631: 2022-09-14 08:19:46.597 - debug: hs100.0 (4410) Refresh 192.168.178.33 Model = HS100(EU) state = false update = 2022.9.14 08:19:46
    	Zeile 632: 2022-09-14 08:19:46.603 - debug: hs100.0 (4410) Refresh 192.168.178.34 Model = HS100(EU) state = false update = 2022.9.14 08:19:46
    	Zeile 633: 2022-09-14 08:19:46.616 - debug: hs100.0 (4410) Refresh 192.168.178.35 Model = KP105(EU) state = false update = 2022.9.14 08:19:46
    	Zeile 634: 2022-09-14 08:19:46.645 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_33.state changed: false (ack = true)
    	Zeile 635: 2022-09-14 08:19:46.662 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_34.state changed: false (ack = true)
    	Zeile 636: 2022-09-14 08:19:46.673 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_35.state changed: false (ack = true)
    	Zeile 637: 2022-09-14 08:19:46.736 - debug: hs100.0 (4410) Refresh 192.168.178.36 Model = KP115(EU) state = true update = 2022.9.14 08:19:46
    	Zeile 638: 2022-09-14 08:19:46.741 - debug: hs100.0 (4410) Refresh 192.168.178.31 Model = HS100(EU) state = true update = 2022.9.14 08:19:46
    	Zeile 639: 2022-09-14 08:19:46.759 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_36.state changed: true (ack = true)
    	Zeile 640: 2022-09-14 08:19:46.866 - debug: hs100.0 (4410) Refresh 192.168.178.32 Model = HS110(EU) state = true update = 2022.9.14 08:19:46
    	Zeile 641: 2022-09-14 08:19:46.908 - debug: hs100.0 (4410) Refresh Data HS110 192.168.178.36
    	Zeile 642: 2022-09-14 08:19:47.048 - debug: hs100.0 (4410) Month value Model : KP115(EU) IP : 192.168.178.36
    	Zeile 643: 2022-09-14 08:19:47.155 - debug: hs100.0 (4410) Refresh Data HS110 192.168.178.32
    	Zeile 644: 2022-09-14 08:19:47.173 - debug: hs100.0 (4410) Day value for Model : KP115(EU) Energy : 0 IP : 192.168.178.36
    	Zeile 645: 2022-09-14 08:19:47.442 - debug: hs100.0 (4410) Month value Model : HS110(EU) IP : 192.168.178.32
    	Zeile 646: 2022-09-14 08:19:47.732 - debug: hs100.0 (4410) Day value for Model : HS110(EU) Energy : 0.004 IP : 192.168.178.32
    	Zeile 647: 2022-09-14 08:21:16.574 - debug: hs100.0 (4410) get Information
    	Zeile 648: 2022-09-14 08:21:16.601 - debug: hs100.0 (4410) Refresh 192.168.178.33 Model = HS100(EU) state = false update = 2022.9.14 08:21:16
    	Zeile 649: 2022-09-14 08:21:16.607 - debug: hs100.0 (4410) Refresh 192.168.178.34 Model = HS100(EU) state = false update = 2022.9.14 08:21:16
    	Zeile 650: 2022-09-14 08:21:16.620 - debug: hs100.0 (4410) Refresh 192.168.178.35 Model = KP105(EU) state = false update = 2022.9.14 08:21:16
    	Zeile 651: 2022-09-14 08:21:16.643 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_33.state changed: false (ack = true)
    	Zeile 652: 2022-09-14 08:21:16.659 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_34.state changed: false (ack = true)
    	Zeile 653: 2022-09-14 08:21:16.695 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_35.state changed: false (ack = true)
    	Zeile 654: 2022-09-14 08:21:16.712 - debug: hs100.0 (4410) Refresh 192.168.178.36 Model = KP115(EU) state = true update = 2022.9.14 08:21:16
    	Zeile 655: 2022-09-14 08:21:16.728 - debug: hs100.0 (4410) stateID hs100.0.192_168_178_36.state changed: true (ack = true)
    	Zeile 656: 2022-09-14 08:21:16.743 - debug: hs100.0 (4410) Refresh 192.168.178.31 Model = HS100(EU) state = true update = 2022.9.14 08:21:16
    	Zeile 657: 2022-09-14 08:21:16.837 - debug: hs100.0 (4410) Refresh Data HS110 192.168.178.36
    	Zeile 658: 2022-09-14 08:21:16.873 - debug: hs100.0 (4410) Refresh 192.168.178.32 Model = HS110(EU) state = true update = 2022.9.14 08:21:16
    	Zeile 659: 2022-09-14 08:21:17.106 - debug: hs100.0 (4410) Month value Model : KP115(EU) IP : 192.168.178.36
    	Zeile 660: 2022-09-14 08:21:17.171 - debug: hs100.0 (4410) Refresh Data HS110 192.168.178.32
    	Zeile 661: 2022-09-14 08:21:17.222 - debug: hs100.0 (4410) Day value for Model : KP115(EU) Energy : 0 IP : 192.168.178.36
    	Zeile 662: 2022-09-14 08:21:17.453 - debug: hs100.0 (4410) Month value Model : HS110(EU) IP : 192.168.178.32
    	Zeile 663: 2022-09-14 08:21:17.743 - debug: hs100.0 (4410) Day value for Model : HS110(EU) Energy : 0.004 IP : 192.168.178.32
    	Zeile 668: 2022-09-14 08:22:24.359 - info: host.raspberrypi stopInstance system.adapter.hs100.0 (force=false, process=true)
    	Zeile 669: 2022-09-14 08:22:24.366 - info: hs100.0 (4410) Got terminate signal TERMINATE_YOURSELF
    	Zeile 670: 2022-09-14 08:22:24.367 - info: host.raspberrypi stopInstance system.adapter.hs100.0 send kill signal
    	Zeile 671: 2022-09-14 08:22:24.367 - info: hs100.0 (4410) cleaned everything up...
    	Zeile 672: 2022-09-14 08:22:24.368 - info: hs100.0 (4410) terminating
    	Zeile 673: 2022-09-14 08:22:24.369 - info: hs100.0 (4410) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    	Zeile 674: 2022-09-14 08:22:24.998 - info: host.raspberrypi instance system.adapter.hs100.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    	Zeile 675: 2022-09-14 08:22:27.560 - info: host.raspberrypi instance system.adapter.hs100.0 started with pid 4912
    	Zeile 676: 2022-09-14 08:22:29.569 - info: hs100.0 (4912) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.hs100, node: v16.17.0, js-controller: 4.0.23
    	Zeile 677: 2022-09-14 08:22:29.609 - info: hs100.0 (4912) Start with IP : 192.168.178.31
    	Zeile 678: 2022-09-14 08:22:29.923 - warn: hs100.0 (4912) Object 192_168_178_31.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 679: 2022-09-14 08:22:29.925 - warn: hs100.0 (4912) This object will not be created in future versions. Please report this to the developer.
    	Zeile 680: 2022-09-14 08:22:29.933 - info: hs100.0 (4912) Start with IP : 192.168.178.32
    	Zeile 681: 2022-09-14 08:22:30.171 - warn: hs100.0 (4912) Object 192_168_178_32.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 682: 2022-09-14 08:22:30.172 - warn: hs100.0 (4912) This object will not be created in future versions. Please report this to the developer.
    	Zeile 683: 2022-09-14 08:22:30.173 - warn: hs100.0 (4912) Object 192_168_178_32.ledState is invalid: Default value has to be type "string" but received type "boolean"
    	Zeile 684: 2022-09-14 08:22:30.174 - warn: hs100.0 (4912) This object will not be created in future versions. Please report this to the developer.
    	Zeile 685: 2022-09-14 08:22:30.176 - info: hs100.0 (4912) Start with IP : 192.168.178.33
    	Zeile 686: 2022-09-14 08:22:30.219 - warn: hs100.0 (4912) Object 192_168_178_33.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 687: 2022-09-14 08:22:30.220 - warn: hs100.0 (4912) This object will not be created in future versions. Please report this to the developer.
    	Zeile 688: 2022-09-14 08:22:30.222 - info: hs100.0 (4912) Start with IP : 192.168.178.34
    	Zeile 689: 2022-09-14 08:22:30.258 - warn: hs100.0 (4912) Object 192_168_178_34.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 690: 2022-09-14 08:22:30.259 - warn: hs100.0 (4912) This object will not be created in future versions. Please report this to the developer.
    	Zeile 691: 2022-09-14 08:22:30.263 - info: hs100.0 (4912) Start with IP : 192.168.178.35
    	Zeile 692: 2022-09-14 08:22:30.293 - warn: hs100.0 (4912) Object 192_168_178_35.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 693: 2022-09-14 08:22:30.294 - warn: hs100.0 (4912) This object will not be created in future versions. Please report this to the developer.
    	Zeile 694: 2022-09-14 08:22:30.295 - info: hs100.0 (4912) Start with IP : 192.168.178.36
    	Zeile 695: 2022-09-14 08:22:30.433 - warn: hs100.0 (4912) Object 192_168_178_36.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 696: 2022-09-14 08:22:30.434 - warn: hs100.0 (4912) This object will not be created in future versions. Please report this to the developer.
    	Zeile 697: 2022-09-14 08:22:30.435 - warn: hs100.0 (4912) Object 192_168_178_36.ledState is invalid: Default value has to be type "string" but received type "boolean"
    	Zeile 698: 2022-09-14 08:22:30.435 - warn: hs100.0 (4912) This object will not be created in future versions. Please report this to the developer.
    	Zeile 763: 2022-09-14 09:28:40.562 - warn: hs100.0 (4912) getDevice Socket connection Timeout ip: 192.168.178.36 please reconnect the Device
    	Zeile 765: 2022-09-14 09:30:10.559 - warn: hs100.0 (4912) getDevice Socket connection Timeout ip: 192.168.178.36 please reconnect the Device
    	Zeile 983: 2022-09-14 13:48:10.855 - warn: hs100.0 (4912) getDevice Socket connection Timeout ip: 192.168.178.32 please reconnect the Device
    	Zeile 1036: 2022-09-14 14:52:40.902 - warn: hs100.0 (4912) getDevice Socket connection Timeout ip: 192.168.178.32 please reconnect the Device
    	Zeile 1045: 2022-09-14 15:06:10.910 - warn: hs100.0 (4912) getDevice Socket connection Timeout ip: 192.168.178.32 please reconnect the Device
    	Zeile 1094: 2022-09-14 16:04:40.960 - warn: hs100.0 (4912) getDevice Socket connection Timeout ip: 192.168.178.32 please reconnect the Device
    	Zeile 1297: 2022-09-14 20:04:41.120 - warn: hs100.0 (4912) getDevice Socket connection Timeout ip: 192.168.178.32 please reconnect the Device
    	Zeile 1403: 2022-09-14 22:07:41.608 - warn: hs100.0 (4912) Info Message setDevice: Error: TCP Timeout after 10000ms
    	Zeile 1416: 2022-09-14 22:18:21.037 - warn: hs100.0 (4912) Info Message setDevice: Error: TCP Timeout after 10000ms
    	Zeile 1425: 2022-09-14 22:21:20.958 - error: hs100.0 (4912) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    	Zeile 1426: 2022-09-14 22:21:20.959 - error: hs100.0 (4912) unhandled promise rejection: TCP Timeout after 10000ms
    	Zeile 1428: 2022-09-14 22:21:20.959 - error: hs100.0 (4912) Error: TCP Timeout after 10000ms
    	Zeile 1433: 2022-09-14 22:21:20.960 - error: hs100.0 (4912) TCP Timeout after 10000ms
    	Zeile 1435: 2022-09-14 22:21:20.968 - info: hs100.0 (4912) cleaned everything up...
    	Zeile 1436: 2022-09-14 22:21:20.969 - info: hs100.0 (4912) terminating
    	Zeile 1437: 2022-09-14 22:21:20.971 - warn: hs100.0 (4912) Terminated (UNCAUGHT_EXCEPTION): Without reason
    	Zeile 1438: 2022-09-14 22:21:20.975 - warn: hs100.0 (4912) Info Message setDevice: Error: TCP Timeout after 10000ms
    	Zeile 1458: 2022-09-14 22:21:21.658 - error: host.raspberrypi instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    	Zeile 1459: 2022-09-14 22:21:21.659 - info: host.raspberrypi Restart adapter system.adapter.hs100.0 because enabled
    	Zeile 1460: 2022-09-14 22:21:51.827 - info: host.raspberrypi instance system.adapter.hs100.0 started with pid 12131
    	Zeile 1461: 2022-09-14 22:21:53.891 - info: hs100.0 (12131) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.hs100, node: v16.17.0, js-controller: 4.0.23
    	Zeile 1462: 2022-09-14 22:21:53.931 - info: hs100.0 (12131) Start with IP : 192.168.178.31
    	Zeile 1463: 2022-09-14 22:21:54.125 - warn: hs100.0 (12131) Object 192_168_178_31.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1464: 2022-09-14 22:21:54.126 - warn: hs100.0 (12131) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1465: 2022-09-14 22:21:54.130 - info: hs100.0 (12131) Start with IP : 192.168.178.32
    	Zeile 1466: 2022-09-14 22:21:54.758 - warn: hs100.0 (12131) Object 192_168_178_32.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1467: 2022-09-14 22:21:54.760 - warn: hs100.0 (12131) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1468: 2022-09-14 22:21:54.762 - warn: hs100.0 (12131) Object 192_168_178_32.ledState is invalid: Default value has to be type "string" but received type "boolean"
    	Zeile 1469: 2022-09-14 22:21:54.764 - warn: hs100.0 (12131) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1470: 2022-09-14 22:21:54.768 - info: hs100.0 (12131) Start with IP : 192.168.178.33
    	Zeile 1471: 2022-09-14 22:21:54.811 - warn: hs100.0 (12131) Object 192_168_178_33.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1472: 2022-09-14 22:21:54.813 - warn: hs100.0 (12131) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1473: 2022-09-14 22:21:54.817 - info: hs100.0 (12131) Start with IP : 192.168.178.34
    	Zeile 1474: 2022-09-14 22:21:54.870 - warn: hs100.0 (12131) Object 192_168_178_34.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1475: 2022-09-14 22:21:54.871 - warn: hs100.0 (12131) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1476: 2022-09-14 22:21:54.875 - info: hs100.0 (12131) Start with IP : 192.168.178.35
    	Zeile 1477: 2022-09-14 22:21:55.149 - warn: hs100.0 (12131) Object 192_168_178_35.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1478: 2022-09-14 22:21:55.150 - warn: hs100.0 (12131) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1479: 2022-09-14 22:21:55.151 - info: hs100.0 (12131) Start with IP : 192.168.178.36
    	Zeile 1480: 2022-09-14 22:21:55.212 - warn: hs100.0 (12131) Object 192_168_178_36.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1481: 2022-09-14 22:21:55.213 - warn: hs100.0 (12131) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1482: 2022-09-14 22:21:55.214 - warn: hs100.0 (12131) Object 192_168_178_36.ledState is invalid: Default value has to be type "string" but received type "boolean"
    	Zeile 1483: 2022-09-14 22:21:55.214 - warn: hs100.0 (12131) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1500: 2022-09-14 22:41:43.024 - error: hs100.0 (12131) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    	Zeile 1501: 2022-09-14 22:41:43.025 - error: hs100.0 (12131) unhandled promise rejection: TCP Timeout after 10000ms
    	Zeile 1503: 2022-09-14 22:41:43.026 - error: hs100.0 (12131) Error: TCP Timeout after 10000ms
    	Zeile 1508: 2022-09-14 22:41:43.026 - error: hs100.0 (12131) TCP Timeout after 10000ms
    	Zeile 1510: 2022-09-14 22:41:43.029 - info: hs100.0 (12131) cleaned everything up...
    	Zeile 1511: 2022-09-14 22:41:43.030 - info: hs100.0 (12131) terminating
    	Zeile 1512: 2022-09-14 22:41:43.031 - warn: hs100.0 (12131) Terminated (UNCAUGHT_EXCEPTION): Without reason
    	Zeile 1523: 2022-09-14 22:41:43.684 - error: host.raspberrypi instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    	Zeile 1524: 2022-09-14 22:41:43.684 - info: host.raspberrypi Restart adapter system.adapter.hs100.0 because enabled
    	Zeile 1525: 2022-09-14 22:42:13.930 - info: host.raspberrypi instance system.adapter.hs100.0 started with pid 13110
    	Zeile 1526: 2022-09-14 22:42:15.842 - info: hs100.0 (13110) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.hs100, node: v16.17.0, js-controller: 4.0.23
    	Zeile 1527: 2022-09-14 22:42:15.882 - info: hs100.0 (13110) Start with IP : 192.168.178.31
    	Zeile 1528: 2022-09-14 22:42:16.152 - warn: hs100.0 (13110) Object 192_168_178_31.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1529: 2022-09-14 22:42:16.153 - warn: hs100.0 (13110) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1530: 2022-09-14 22:42:16.157 - info: hs100.0 (13110) Start with IP : 192.168.178.32
    	Zeile 1531: 2022-09-14 22:42:16.343 - warn: hs100.0 (13110) Object 192_168_178_32.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1532: 2022-09-14 22:42:16.344 - warn: hs100.0 (13110) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1533: 2022-09-14 22:42:16.345 - warn: hs100.0 (13110) Object 192_168_178_32.ledState is invalid: Default value has to be type "string" but received type "boolean"
    	Zeile 1534: 2022-09-14 22:42:16.346 - warn: hs100.0 (13110) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1535: 2022-09-14 22:42:16.347 - info: hs100.0 (13110) Start with IP : 192.168.178.33
    	Zeile 1536: 2022-09-14 22:42:16.370 - warn: hs100.0 (13110) Object 192_168_178_33.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1537: 2022-09-14 22:42:16.371 - warn: hs100.0 (13110) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1538: 2022-09-14 22:42:16.373 - info: hs100.0 (13110) Start with IP : 192.168.178.34
    	Zeile 1539: 2022-09-14 22:42:16.425 - warn: hs100.0 (13110) Object 192_168_178_34.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1540: 2022-09-14 22:42:16.426 - warn: hs100.0 (13110) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1541: 2022-09-14 22:42:16.428 - info: hs100.0 (13110) Start with IP : 192.168.178.35
    	Zeile 1542: 2022-09-14 22:42:16.471 - warn: hs100.0 (13110) Object 192_168_178_35.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1543: 2022-09-14 22:42:16.471 - warn: hs100.0 (13110) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1544: 2022-09-14 22:42:16.473 - info: hs100.0 (13110) Start with IP : 192.168.178.36
    	Zeile 1545: 2022-09-14 22:42:16.599 - warn: hs100.0 (13110) Object 192_168_178_36.last_update is invalid: Default value has to be type "string" but received type "number"
    	Zeile 1546: 2022-09-14 22:42:16.599 - warn: hs100.0 (13110) This object will not be created in future versions. Please report this to the developer.
    	Zeile 1547: 2022-09-14 22:42:16.600 - warn: hs100.0 (13110) Object 192_168_178_36.ledState is invalid: Default value has to be type "string" but received type "boolean"
    	Zeile 1548: 2022-09-14 22:42:16.600 - warn: hs100.0 (13110) This object will not be created in future versions. Please report this to the developer.
    Node.js: v16.17.0
    mrbungle64M Offline
    mrbungle64M Offline
    mrbungle64
    schrieb am zuletzt editiert von mrbungle64
    @bf0911
    Ich meine, dass ich mit der Version 2.0.6 mal die gleichen Probleme hatte.
    Mit der Version 2.1.2 lief es dann aber wieder stabil.
    Wie schaut es in Version 2.1.2 aus (installiert aus dem ioBroker Repo - nicht von GitHub)?
    Sind das die gleichen Warnungen und Fehler?
    Btw.: Wieso fragst du mich eigentlich wegen dem Log Level wenn du es dann doch anders machst? ;)
    • mrbungle64M mrbungle64
      @bf0911
      BF0911
      @mrbungle64
      Die 2.1.2 ist ja offensichtlich die aktuellste. Da traten die Fehler auch auf.
      Habe die Version aber trotzdem mal geupdatet.
      Das Log-Level hatte ich vor meiner Frage mal umgestellt und dann wieder zurück.
      • B BF0911
        @mrbungle64
        BF0911
        Egal, welche Version ich nutze, das Problem besteht weiterhin.
        Wird vielleicht jemand aus meinem LOG-File was erkennen?
        • B BF0911
          arteckA Offline
          arteckA Offline
          arteck
          @bf0911 sagte in Alternative zu HS100-Adapter?:
          ja weil dein WLAN nicht stabiel genug ist und die Dose braucht laaaaaaaaange zu antworten oder antwortet garnicht.
          die Version 2.1.2 wurde zwar optimiert.. aber wenn die Dose nicht antwortet.. zaubern kan ich auch nicht
          surfer09S B NegaleinN 3 Antworten Letzte Antwort
          • arteckA arteck
            surfer09S Offline
            surfer09S Offline
            surfer09
            schrieb am zuletzt editiert von surfer09
            bei mir stürzt der Adapter auch häufig ab. Ich habe die 2.1.2 im Einsatz und lasse den Adapter schon alle 30 Minuten zeitgesteuert neu starten.
            Mir ist nicht ganz klar, warum sich der komplette Adapter verabschiedet, wenn mal eine Dose nicht erreichbar ist.
            Heute hatte ich auch wieder Meldungen im LOG, wo sich der Adapter beendet hatte. Sorry, ich kann gerade leider nur Screenshots hier anhängen.
            E6E537C9-FD33-4FA4-87C0-E8CE342381E2.png D3702DF1-B69E-4810-AEE6-ED994E5147C5.png
            • surfer09S surfer09
              arteckA Offline
              arteckA Offline
              arteck
              @surfer09 sagte in Alternative zu HS100-Adapter?:
              weil ich eine Ahängigkeit verwende die den timout nicht behandelt und geht immer von aus das die Dose IMMER antwortet
              surfer09S padrinoP 2 Antworten Letzte Antwort
              • arteckA arteck
                surfer09S Offline
                surfer09S Offline
                surfer09
                @arteck Okay. Bestünde eine Möglichkeit das in einer zukünftigen Version zu ändern? Ich habe wenig Ahnung von der Programmierung eines solchen Adapters, aber vielleicht gibt es ja eine Möglichkeit das anzupassen?!
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @surfer09 nein leider nein.. obliegt nicht meiner obhut
                  • arteckA arteck
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @arteck Naja, forken, selbst fixen und unter eigenem Namen veröffentlichen wäre eine Option ;)
                    • arteckA arteck
                      BF0911
                      @arteck
                      Das ist schon verwunderlich. Es sind ja quasi mal alle Steckdosen von TP-Link betroffen.
                      Diese sind stellenweise nur 5m vom Access Point entfernt.
                        mike2712
                        Ich habe auch massiv Probleme mit dem Adapter:
                        Warum kommt überhaupt nach 10 Sekunden ein Timeout? Der Abfrage Interval steht auf 60s. Sporadisch 5-8 mal die Woche hängt sich der Adapter auf und muss neu gestartet werden.
                        hs100.0
                        2022-10-29 13:33:01.880	error	TCP Timeout after 10000ms 172.16.22.38:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                        hs100.0
                        2022-10-29 13:33:01.879	error	Error: TCP Timeout after 10000ms 172.16.22.38:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
                        hs100.0
                        2022-10-29 13:33:01.878	error	unhandled promise rejection: TCP Timeout after 10000ms 172.16.22.38:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                        hs100.0
                        2022-10-29 13:33:01.876	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        hs100.0
                        2022-10-29 13:31:17.908	error	TCP Timeout after 10000ms 172.16.22.38:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                        hs100.0
                        2022-10-29 13:31:17.908	error	Error: TCP Timeout after 10000ms 172.16.22.38:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
                        hs100.0
                        2022-10-29 13:31:17.907	error	unhandled promise rejection: TCP Timeout after 10000ms 172.16.22.38:9999 {"emeter":{"get_daystat":{"year":2022,"month":10}}}
                        hs100.0
                        2022-10-29 13:31:17.906	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
                        • M mike2712
                          hs100.0
                          hs100.0
                          hs100.0
                          hs100.0
                          hs100.0
                          hs100.0
                          hs100.0
                          hs100.0
                          @mike2712 sagte in Alternative zu HS100-Adapter?:
                          Schaut nach Netzwerktrouble bei dir aus.
                          Die IP kommt wohl aus dem ClassB-Netz von dem Docker-Krempel.
                            mike2712
                            okay, so richtig kann ich mit der Information jetzt leider nichts anfangen, ich merke in letzter Zeit das oft zwischendurch Internet am Rechner etc. fehlt, also kurzfristige Aussetzer für 1-3 Minuten, Verbindung meist noch vorhanden, aber kein Internet, aber damit hat das vermutlich nichts zu tun, oder hängt das zusammen?
                            • M mike2712
                              Vermutlich.
                              • arteckA arteck
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                @arteck sagte in Alternative zu HS100-Adapter?:
                                Hallo
                                Ich hänge mich mal hier ran! :)
                                Bei mir besteht auch das Problem bei 1 von 8 Steckern. Der Adapter steigt mehrmals am Tag aus.
                                Mein WLAN ist sehr stabil und der besagte Stecker (10.0.1.80) hat vollen Empfang.
                                Adapter ist am aktuellen Stand.
                                hs100.0 2022-11-10 10:14:43.369	info	Start with IP : 10.0.1.187
                                hs100.0 2022-11-10 10:14:43.175	info	Start with IP : 10.0.1.186
                                hs100.0 2022-11-10 10:14:43.153	info	Start with IP : 10.0.1.185
                                hs100.0 2022-11-10 10:14:42.894	info	Start with IP : 10.0.1.80
                                hs100.0 2022-11-10 10:14:42.614	info	Start with IP : 10.0.1.79
                                hs100.0 2022-11-10 10:14:42.329	info	Start with IP : 10.0.1.78
                                hs100.0 2022-11-10 10:14:42.319	info	Start with IP : 10.0.1.77
                                hs100.0 2022-11-10 10:14:42.299	info	Start with IP : 10.0.1.76
                                hs100.0 2022-11-10 10:14:42.282	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v16.18.1, js-controller: 4.0.23
                                hs100.0 2022-11-10 10:14:10.299	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                hs100.0 2022-11-10 10:14:10.299	info	terminating
                                hs100.0 2022-11-10 10:14:10.299	info	cleaned everything up...
                                hs100.0 2022-11-10 10:14:10.297	error	TCP Timeout after 10000ms10.0.1.80:9999 {"emeter":{"get_daystat":{"year":2022,"month":11}}}
                                hs100.0 2022-11-10 10:14:10.297	error	Error: TCP Timeout after 10000ms10.0.1.80:9999 {"emeter":{"get_daystat":{"year":2022,"month":11}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
                                hs100.0 2022-11-10 10:14:10.297	error	unhandled promise rejection: TCP Timeout after 10000ms10.0.1.80:9999 {"emeter":{"get_daystat":{"year":2022,"month":11}}}
                                hs100.0 2022-11-10 10:14:10.296	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                ° Fixer ---> iob fix
                                • NegaleinN Negalein
                                  Hallo
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  @negalein sagte in Alternative zu HS100-Adapter?:
                                  was soll ich da machen.. wenn die Dose nicht antwortet..
                                  • arteckA arteck
                                    padrinoP Offline
                                    padrinoP Offline
                                    padrino
                                    Könntest Du das etwas näher erläutern?
                                    Ein Fehler sollte doch eigentlich immer abzufangen sein und zumindest nicht zu einem Crash führen. 🤔
                                    • padrinoP padrino
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @padrino sag nicht mir das..wenn man davon ausgeht dass, das immer klappt..
                                      das ist eine Besonderheit auch von iobroker.. dass es da auffällt
