  5. PV Überschuss zum betreiben von 1 Heizstab
    6.7k
144 Beiträge 10 Kommentatoren 28.5k Aufrufe 12 Beobachtet
    @spidermike sagte: ist das jetzt was schlimmes oder egal?
    Auf die Funktion dieses Skriptes hat es keinen Einfluss.
    Spidermike
    #116
    @paul53 sagte in PV Überschuss zum betreiben von 1 Heizstab:
    perfekt, nochmals vielen Dank an Euch
    werde mich jetzt mal an mein Garagentorprojekt mit dem Wled heranmachen damit das mal endlich zum laufen kommt
    • S Spidermike
      Spidermike
      #117
      @spidermike
      bekomme jetzt viele Log
      was ist das denn jetzt
      hs100.0
      	2022-07-24 17:01:03.310	warn	This object will not be created in future versions. Please report this to the developer.
      hs100.0
      	2022-07-24 17:01:03.309	warn	Object 192_168_178_94.ledState is invalid: Default value has to be type "string" but received type "boolean"
      hs100.0
      	2022-07-24 17:01:03.306	warn	This object will not be created in future versions. Please report this to the developer.
      hs100.0
      	2022-07-24 17:01:03.304	warn	Object 192_168_178_94.last_update is invalid: Default value has to be type "string" but received type "number"
      hs100.0
      	2022-07-24 17:01:03.198	info	Start with IP : 192.168.178.94
      hs100.0
      	2022-07-24 17:01:03.196	warn	This object will not be created in future versions. Please report this to the developer.
      hs100.0
      	2022-07-24 17:01:03.196	warn	Object 192_168_178_38.last_update is invalid: Default value has to be type "string" but received type "number"
      hs100.0
      	2022-07-24 17:01:02.934	info	Start with IP : 192.168.178.38
      hs100.0
      	2022-07-24 17:01:02.931	warn	This object will not be created in future versions. Please report this to the developer.
      hs100.0
      	2022-07-24 17:01:02.931	warn	Object 192_168_178_95.ledState is invalid: Default value has to be type "string" but received type "boolean"
      hs100.0
      	2022-07-24 17:01:02.929	warn	This object will not be created in future versions. Please report this to the developer.
      hs100.0
      	2022-07-24 17:01:02.928	warn	Object 192_168_178_95.last_update is invalid: Default value has to be type "string" but received type "number"
      hs100.0
      	2022-07-24 17:01:02.870	info	Start with IP : 192.168.178.95
      hs100.0
      	2022-07-24 17:01:02.820	info	starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
      host.raspberrypi4-iobroker
      	2022-07-24 17:01:00.691	info	instance system.adapter.hs100.0 started with pid 14007
      	2022-07-24 17:00:30.614	info	Restart adapter system.adapter.hs100.0 because enabled
      	2022-07-24 17:00:30.614	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      	2022-07-24 17:00:30.613	error	Caught by controller[7]: }
      	2022-07-24 17:00:30.613	error	Caught by controller[7]: port: 9999
      	2022-07-24 17:00:30.613	error	Caught by controller[7]: address: '192.168.178.94',
      	2022-07-24 17:00:30.613	error	Caught by controller[7]: syscall: 'connect',
      	2022-07-24 17:00:30.613	error	Caught by controller[7]: code: 'ECONNREFUSED',
      	2022-07-24 17:00:30.613	error	Caught by controller[7]: errno: -111,
      	2022-07-24 17:00:30.612	error	Caught by controller[7]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
      	2022-07-24 17:00:30.612	error	Caught by controller[7]: [3kw Heizstab] device.send() Error: connect ECONNREFUSED 192.168.178.94:9999
      	2022-07-24 17:00:30.612	error	Caught by controller[6]: }
      	2022-07-24 17:00:30.612	error	Caught by controller[6]: port: 9999
      	2022-07-24 17:00:30.612	error	Caught by controller[6]: address: '192.168.178.94',
      	2022-07-24 17:00:30.612	error	Caught by controller[6]: syscall: 'connect',
      	2022-07-24 17:00:30.611	error	Caught by controller[6]: code: 'ECONNREFUSED',
      	2022-07-24 17:00:30.611	error	Caught by controller[6]: errno: -111,
      	2022-07-24 17:00:30.611	error	Caught by controller[6]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
      	2022-07-24 17:00:30.611	error	Caught by controller[6]: TCP 192.168.178.94:9999 Error: connect ECONNREFUSED 192.168.178.94:9999
      	2022-07-24 17:00:30.611	error	Caught by controller[5]: }
      	2022-07-24 17:00:30.611	error	Caught by controller[5]: port: 9999
      	2022-07-24 17:00:30.610	error	Caught by controller[5]: address: '192.168.178.94',
      	2022-07-24 17:00:30.610	error	Caught by controller[5]: syscall: 'connect',
      	2022-07-24 17:00:30.610	error	Caught by controller[5]: code: 'ECONNREFUSED',
      	2022-07-24 17:00:30.610	error	Caught by controller[5]: errno: -111,
      	2022-07-24 17:00:30.610	error	Caught by controller[5]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
      	2022-07-24 17:00:30.610	error	Caught by controller[5]: [3kw Heizstab] device.send() Error: connect ECONNREFUSED 192.168.178.94:9999
      	2022-07-24 17:00:30.609	error	Caught by controller[4]: }
      	2022-07-24 17:00:30.609	error	Caught by controller[4]: port: 9999
      	2022-07-24 17:00:30.609	error	Caught by controller[4]: address: '192.168.178.94',
      	2022-07-24 17:00:30.609	error	Caught by controller[4]: syscall: 'connect',
      	2022-07-24 17:00:30.609	error	Caught by controller[4]: code: 'ECONNREFUSED',
      	2022-07-24 17:00:30.609	error	Caught by controller[4]: errno: -111,
      	2022-07-24 17:00:30.608	error	Caught by controller[4]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
      	2022-07-24 17:00:30.608	error	Caught by controller[4]: TCP 192.168.178.94:9999 Error: connect ECONNREFUSED 192.168.178.94:9999
      	2022-07-24 17:00:30.608	error	Caught by controller[3]: at processTimers (internal/timers.js:500:7)
      	2022-07-24 17:00:30.608	error	Caught by controller[3]: at listOnTimeout (internal/timers.js:557:17)
      	2022-07-24 17:00:30.608	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
      	2022-07-24 17:00:30.607	error	Caught by controller[3]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
      	2022-07-24 17:00:30.607	error	Caught by controller[3]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
      	2022-07-24 17:00:30.607	error	Caught by controller[2]: at processTimers (internal/timers.js:500:7)
      	2022-07-24 17:00:30.607	error	Caught by controller[2]: at listOnTimeout (internal/timers.js:557:17)
      	2022-07-24 17:00:30.607	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
      	2022-07-24 17:00:30.607	error	Caught by controller[2]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
      	2022-07-24 17:00:30.606	error	Caught by controller[2]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
      	2022-07-24 17:00:30.606	error	Caught by controller[1]: at processTimers (internal/timers.js:500:7)
      	2022-07-24 17:00:30.606	error	Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
      	2022-07-24 17:00:30.606	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
      	2022-07-24 17:00:30.606	error	Caught by controller[1]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
      	2022-07-24 17:00:30.606	error	Caught by controller[1]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
      	2022-07-24 17:00:30.605	error	Caught by controller[0]: at processTimers (internal/timers.js:500:7)
      	2022-07-24 17:00:30.605	error	Caught by controller[0]: at listOnTimeout (internal/timers.js:557:17)
      	2022-07-24 17:00:30.605	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
      	2022-07-24 17:00:30.605	error	Caught by controller[0]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
      	2022-07-24 17:00:30.604	error	Caught by controller[0]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
      hs100.0
      	2022-07-24 17:00:30.132	error	Exception-Code: ECONNREFUSED: connect ECONNREFUSED 192.168.178.94:9999
      hs100.0
      	2022-07-24 17:00:30.131	error	Error: connect ECONNREFUSED 192.168.178.94:9999 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)
      hs100.0
      	2022-07-24 17:00:30.131	error	unhandled promise rejection: connect ECONNREFUSED 192.168.178.94:9999
      hs100.0
      	2022-07-24 17:00:30.130	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      hs100.0
      	2022-07-24 17:00:30.049	error	Exception-Code: ECONNREFUSED: connect ECONNREFUSED 192.168.178.94:9999
      hs100.0
      	2022-07-24 17:00:30.048	error	Error: connect ECONNREFUSED 192.168.178.94:9999 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)
      hs100.0
      	2022-07-24 17:00:30.047	error	unhandled promise rejection: connect ECONNREFUSED 192.168.178.94:9999
      hs100.0
      	2022-07-24 17:00:30.046	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      hs100.0
      	2022-07-24 17:00:30.033	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      hs100.0
      	2022-07-24 17:00:30.031	info	terminating
      hs100.0
      	2022-07-24 17:00:30.030	info	cleaned everything up...
      hs100.0
      	2022-07-24 17:00:30.027	warn	Info Message setDevice: Error: TCP Timeout after 10000ms192.168.178.94:9999 {"system":{"get_sysinfo":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
      hs100.0
      	2022-07-24 17:00:30.020	error	TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
      hs100.0
      	2022-07-24 17:00:30.020	error	Error: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
      hs100.0
      	2022-07-24 17:00:30.019	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
      hs100.0
      	2022-07-24 17:00:30.018	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      • S Spidermike
        @spidermike
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        hs100.0
        #118
        @spidermike was soll das mit dem bisherigen Thema zu tun haben?
        S D 2 Antworten Letzte Antwort
          Diamand2k22
          schrieb am zuletzt editiert von Diamand2k22
          #119
          finde das Blockly Klasse und habe es erfolgreich bei mir im Einsatz.
          Konstellation ist 2x E-Heizkörper die je nach Heizstufe zuschalten.
          Beide Geräte haben eine Leistung von 800W. Somit funktioniert das ganze recht gut.
          Frage von meiner Seite wäre, wie kann ich das Skript um eine 3. Heizstufe aufbohren, aber wenn der Verbraucher dann nicht 800 W hat sondern 2400W hat ?
          Diamand
          • D Diamand2k22
            Diamand
            #120
            @diamand2k22 sagte: wie kann ich das Skript um eine 3. Heizstufe aufbohren, aber wenn der Verbraucher dann nicht 800 W hat sondern 2400W hat ?
            Wieso nur 3 Stufen?
            1. Stufe: Stab 1
            2. Stufe: Stab 1+2
            3. Stufe: Stab 3
            4. Stufe: Stab 3 + 1
            5. Stufe: Stab 3 + 1 + 2
            Jede Stufe unterscheidet sich um 800 W, also ist es wohl nicht so schwierig, das anzupassen?
              Wieso nur 3 Stufen?
              1. Stufe: Stab 1
              2. Stufe: Stab 1+2
              3. Stufe: Stab 3
              Diamand2k22
              #121
              @paul53 said in PV Überschuss zum betreiben von 1 Heizstab:
              Wieso nur 3 Stufen?
              1. Stufe: Stab 1
              2. Stufe: Stab 1+2
              3. Stufe: Stab 3
              ok, dann ist Stufe 5 die 2400W
              • D Diamand2k22
                Wieso nur 3 Stufen?
                1. Stufe: Stab 1
                2. Stufe: Stab 1+2
                3. Stufe: Stab 3
                #122
                @diamand2k22 sagte: dann ist Stufe 5 die 2400W
                Nein, Stufe 5 ist 4000 W.
                  Diamand2k22
                  #123
                  stimmt, zu blöd zum Rechnen :-D ....
                  • D Diamand2k22
                    Diamand2k22
                    #124
                    aber ich glaube wir haben aneinander vorbei geredet :-D der Ablauf soll folgender sein:
                    Überschuss >800W -> Heistab 1 ein (Heistufe 1)
                    Danach Überschuss wieder > 800W Heizstab 2 ein (Heizstufe 2)
                    danach Überschuss >2400 W Poolheizung ein (Heizstufe 3)
                    aber Heizstab 1 und Heizstab 2 sollen weiterlaufen und der Pool schaltet sich bei Überschuss >2400W noch dazu.
                    Wenn der Überschuss wieder weniger wird, schaltet sich alles in umgekehrter Reihenfolge wieder ab.
                    • D Diamand2k22
                      #125
                      @diamand2k22 sagte: aber Heizstab 1 und Heizstab 2 sollen weiterlaufen
                      Dann gibt es einen Leistungssprung von 2400 W (1600 auf 4000 W), der nicht mehr per einfacher Stufenschaltung zu behandeln ist.
                      Übrigens: Wie hast Du mit zwei 800 W Heizungen 3 Stufen gebildet?
                      • D Diamand2k22
                        #126
                        @diamand2k22 sagte:
                          @diamand2k22 sagte:
                          Diamand2k22
                          #127
                          hier mal das aktuelle Blockly
                          • D Diamand2k22
                            #128
                            @diamand2k22 sagte: das aktuelle Blockly
                            Das funktioniert so nicht. Ändere bei Skriptstart die Ermittlung der Leistungsstufe so wie hier gezeigt.
                            Außerdem wird, wenn die Leistungsstufe 2 erreicht ist, ein höherer Grenzwert (-2400) für weiteres Hochschalten benötigt.
                            Wozu dienen cntEin und cntAus, die nirgends ausgewertet werden?
                              Diamand2k22
                              #129
                              ich habe es wie von dir beschrieben angepasst.
                              cnt werden ausgewertet, siehe Markierung!
                              jetzt habe ich noch das Thema mit der Leistungsstufe 2400W.
                              Muss ich mal sehen wie ich das hin bekomm...
                              • D Diamand2k22
                                #130
                                @diamand2k22 sagte: Thema mit der Leistungsstufe 2400W.
                                Wie gezeigt.
                                @diamand2k22 sagte in PV Überschuss zum betreiben von 1 Heizstab:
                                Ach ja, das dient zur Verzögerung (Anpassung an das Verhalten des Smartmeters).
                                  Wie gezeigt.
                                  Diamand2k22
                                  #131
                                  danke das funktioniert!
                                  Wie müsste ich das Blockly noch anpassen, wenn die Leistungsstufe 3 nochmal eine E-Heizung mit 600W sind und dann die Leistungsstufe 4 der Pool mit den 2400W.
                                  Wie sieht dann das setzten des Startwertes oben aus?
                                  Danke und
                                  paul53P A 2 Antworten Letzte Antwort
                                  • D Diamand2k22
                                    Danke und
                                    #132
                                    @diamand2k22 sagte: Leistungsstufe 3 nochmal eine E-Heizung mit 600W sind und dann die Leistungsstufe 4 der Pool mit den 2400W.
                                      Diamand2k22
                                      #133
                                      Danke dir, jetzt kann ich beliebig viele Verbraucher der Reihe nach dazu oder abschalten am Überschuss orientiert, das ist perfekt.
                                        @spidermike sagte: Werte für Bezug, Eigenverbrauch und Einspeisung
                                        Bezug und Einspeisung sind jeweils positiv? Wenn ja, Vorschlag:
                                        Hodde
                                        #134
                                        @spidermike Hi Mike, mein Heizstab ist gerade im Anflug. Du hast da genau das schon aufgebaut was ich in den nächsten Wochen schaffen will. Wärst du bitte so nett und wüdest deinen finalen code posten?👏 Das würde mich und bestimmt einige andere um Tage beschleunigen. 🚀
                                        Meine 18.5 kWp Anlage mit 2 SMA WR und einem HM 2 liefert mir schon alles was man an Daten braucht (über Modbus) in den IoB. Das nutze ich in meiner Hausbussteurung (Beckhoff Cx9010) bereits als Anzeigeoption.
                                        Danke für die coole Vorarbeit.
                                        Hodde
                                        • H Hodde
                                          Hodde
                                          #135
                                          @hodde sagte: mein Heizstab
                                          Leistung? Eine Stufe oder 3 Stufen?
                                          Messwerte: Bezug - Überschuss (negativ bei Überschuss) oder Bezug und Überschuss getrennt (beide positiv)?
                                          @hodde sagte in PV Überschuss zum betreiben von 1 Heizstab:
                                          code posten?
                                          Hier eine Version für Überschuss (positiv) und 3 mal 1 kW:
                                           <variables>
                                             <variable id="0yCRj*O9QX1#dhgtI-o5">grenzwertEin</variable>
                                             <variable id="k5G]U.qWO4-lc^#fGv0R">grenzwertAus</variable>
                                             <variable type="timeout" id="delayOn">delayOn</variable>
                                             <variable type="timeout" id="delayOff">delayOff</variable>
                                           </variables>
                                           <block type="variables_set" id="zo);,rK_T+=a,mP%]Wg." x="12" y="-62">
                                             <field name="VAR" id="0yCRj*O9QX1#dhgtI-o5">grenzwertEin</field>
                                             <value name="VALUE">
                                               <block type="math_number" id="7%K@1T{#I/I|Lk};-m.l">
                                                 <field name="NUM">1400</field>
                                               </block>
                                             </value>
                                             <next>
                                               <block type="variables_set" id="I7I-F_#:#J)(O0wL4Aih">
                                                 <field name="VAR" id="k5G]U.qWO4-lc^#fGv0R">grenzwertAus</field>
                                                   <block type="math_arithmetic" id="d=rJR%ogfy#lFSNUW#06">
                                                     <value name="A">
                                                       <shadow type="math_number" id="b+alG`6e;V6Rycn#})9|">
                                                         <field name="NUM">1</field>
                                                       </shadow>
                                                       <block type="variables_get" id="YHi/ucvd~zJOaY27ffQX">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       <shadow type="math_number" id="BrB|~i^$qYCE5dc,z}(J">
                                                         <field name="NUM">1200</field>
                                                       </shadow>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                   <block type="on_ext" id="^=k13pGi`kMjtE||vY.J">
                                                     <value name="OID0">
                                                       <shadow type="field_oid" id="n:wY~I3GQO$7,0:+.oY=">
                                                         <field name="oid">0_userdata.0.Blockly.PV_Ueberschuss</field>
                                                       </shadow>
                                                     </value>
                                                     <statement name="STATEMENT">
                                                       <block type="controls_if" id="?{[99~rn+X@-!776Gil$">
                                                         <value name="IF0">
                                                           <block type="logic_compare" id="d%IZlzT50i(a7nefKk6]">
                                                             <field name="OP">LTE</field>
                                                             <value name="A">
                                                               <block type="on_source" id="f=2?mi+jttya*Yya7dG.">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               <block type="variables_get" id="q{]f~,LPED4*s[Rqru9L">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <statement name="DO0">
                                                           <block type="timeouts_cleartimeout" id="|#WysqWLOkMz:?pQ*-CZ">
                                                             <field name="NAME">delayOn</field>
                                                           </block>
                                                         </statement>
                                                         <value name="IF1">
                                                           <block type="logic_negate" id="dch2(fx(/ykyn#X-R`9x">
                                                             <value name="BOOL">
                                                               <block type="timeouts_gettimeout" id="xJVx:Mi5[U_(t*bw(Yq$">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <statement name="DO1">
                                                           <block type="timeouts_settimeout" id="=EI:`22NaF],y?uV^b1B">
                                                             <field name="DELAY">10</field>
                                                             <field name="UNIT">min</field>
                                                               <block type="controls_if" id="i.:l;5vs?$}^L}N-R(^T">
        <mutation elseif="2"></mutation>
        <value name="IF0">
        <block type="logic_negate" id="R(_3jAG`Md_w[,(|^wr/">
        <value name="BOOL">
        <block type="get_value" id="NG3*!?gfl8{k3cP;uW1`">
        <field name="OID">0_userdata.0.Blockly.Switch1</field>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="qYesRpdij9z`93JQ2~w%">
        <block type="logic_boolean" id="ndh[{X~M{gFV,0p.u?49">
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <block type="logic_negate" id="r:ak[AbR=(fM06(!MiNq">
        <value name="BOOL">
        <block type="get_value" id="Wk#V-l{Fi[!?`_6`Qj_b">
        <field name="OID">0_userdata.0.Blockly.Switch2</field>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="S(zYFzv^}$AcCYB-`Q`e">
        <block type="logic_boolean" id="r_?O8H8QBzI#o|3X!Q%#">
        </block>
        </value>
        </block>
        </statement>
        <value name="IF2">
        <block type="logic_negate" id="jM5~.3jyY`N/(9mGWI:O">
        <value name="BOOL">
        <block type="get_value" id="*guxu@lyFFjMcgr}bL4V">
        <field name="OID">0_userdata.0.Blockly.Switch3</field>
        </block>
        </value>
        </block>
        </value>
        <statement name="DO2">
        <block type="control" id="XXUi|!^XGmi4z|s+a-/j">
        <block type="logic_boolean" id="J{N8i(G2CBr~GS95U1P5">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="timeouts_wait" id="6xiZ%Mi^9lNm4OO$#|4N">
        <next>
        <block type="timeouts_cleartimeout" id="WJ?t^mxt0H|jM5A2zX=v">
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                         <next>
                                                           <block type="controls_if" id="U^YFuAk{|bn.*b{Ep;B=">
                                                             <value name="IF0">
                                                               <block type="logic_compare" id="GddE`U/xj*}WZ:OC-j_5">
        <field name="OP">GTE</field>
        <value name="A">
        <block type="on_source" id="7p.M-{Jv;0@=Z(ul53Sv">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="-t@cJFEI+*?5ME9yFOuZ">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                               <block type="timeouts_cleartimeout" id="_N.QOqsujv5EzF,e1:^`">
        <field name="NAME">delayOff</field>
                                                               </block>
                                                             </statement>
                                                             <value name="IF1">
                                                               <block type="logic_negate" id="0(6[M7amQ.RY*S4wPkX3">
        <value name="BOOL">
        <block type="timeouts_gettimeout" id="pTQJfLPne.dmqq!4K#Q.">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                               <block type="timeouts_settimeout" id="b(4T]c7c@_xcR0^(IJQ#">
        <block type="controls_if" id="?qIetfb=Y~enZP|MFl{L">
        <value name="IF0">
        <block type="get_value" id="Gfj4~P(NGH1)wmLG*_5i">
        </block>
        </value>
        <block type="control" id="+}7@V!ZV,:MdpdXzwfQM">
        <block type="logic_boolean" id="7]gwCTD%n]L)8L{d}UV;">
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <block type="get_value" id="c5)cE;gpnkQiW1,[Z~lq">
        </block>
        </value>
        <block type="control" id="mz4KPZXji[VtQd%D^Q)G">
        <block type="logic_boolean" id="aHm,f%vDaSf!ndb?Gy^;">
        </block>
        </value>
        </block>
        </statement>
        <value name="IF2">
        <block type="get_value" id="qiL4rv;pF_`rhwPjnuos">
        </block>
        </value>
        <block type="control" id="1)T#:T-4fP9.161U$Ox!">
        <block type="logic_boolean" id="EpsV1@;P~LvEiJ]XiL]D">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="timeouts_wait" id="L_G?=s-{iS/.+04Ro9ln">
        <next>
        <block type="timeouts_cleartimeout" id="NWZqJ:pmXfkR7B(bD,.L">
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                          </xml>
