  4. mihome vaccum ist offt gelb
    5.8k
126 Beiträge 5 Kommentatoren 16.1k Aufrufe 5 Beobachtet
  • KrisiunK Krisiun
    @krisiun
    code_textiobroker update -i
    Adapter    "admin"        : 6.2.20   , installed 5.3.8  [Updatable]
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.10   , installed 2.4.10
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.2.2    , installed 4.2.2
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "geofency"     : 1.1.1    , installed 1.1.1
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hmip"         : 1.18.0   , installed 1.18.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.8
    Adapter    "javascript"   : 6.0.0    , installed 6.0.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
    Adapter    "pushover"     : 3.0.2    , installed 3.0.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "tuya"         : 3.6.15   , installed 3.6.15
    guergen
    @krisiun Du bist doch auf der richtigen Version...:
    3.4.2 und nicht auf 1.4.0 vom home
    • KrisiunK Krisiun
      code_text/usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.3
      v14.19.3
      6.14.17
      pi
      /home/pi
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      OK:3 https://deb.nodesource.com/node_14.x buster InRelease
      Aktualisierung für 40 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      nodejs:
        Installiert:           14.19.3-deb-1nodesource1
        Installationskandidat: 14.20.0-deb-1nodesource1
        Versionstabelle:
           14.20.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
       *** 14.19.3-deb-1nodesource1 100
           10.24.0~dfsg-1~deb10u1 500
      @krisiun sagte in mihome vaccum ist offt gelb:
      iobroker stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      Und ich würde an deiner Stelle auch überlegen nodejs 16 zu installieren.
      KrisiunK 2 Antworten Letzte Antwort
        iobroker stop
        sudo apt update
        sudo reboot
        KrisiunK Offline
        KrisiunK Offline
        Krisiun
        Danke. Ja das habe ich auch schon probiert aber irgendwie hat das nicht geklappt
        • KrisiunK Krisiun
          @krisiun
          Dann schau irgendwie in meine Signatur, da wird erklärt wie man es macht.
            iobroker stop
            sudo apt update
            sudo reboot
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            Aber ist das dass Problem der den mihome-vaccum betrifft?
            • KrisiunK Krisiun
              @krisiun
              Vielleicht? Jedenfalls ist 16 die zur Zeit empfohlene Version für den ioBroker.
              KrisiunK 1 Antwort Letzte Antwort
                @krisiun
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                Wie kann ich in Deine Signatur schauen ?
                • KrisiunK Krisiun
                  @krisiun
                  Die steht unter jedem meiner Beiträge.
                    @krisiun
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    Ahso Danke.
                    Kannst Du mir sagen was ändert sich nach der installation von nodjes 16 ?
                    Weil manchmal gibts da Probleme
                    • KrisiunK Krisiun
                      Ahso Danke.
                      Dafür gibt es change logs.
                      Hier das für node16:
                      https://github.com/nodejs/node/blob/main/doc/changelogs/CHANGELOG_V16.md#16.17.0
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        Vielen Dank aber da kann ich leider nichts entnähmen was ich wissen will. Aber egal.
                        • KrisiunK Krisiun
                          @krisiun
                          Was willst du denn wissen?
                            @krisiun
                            KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            @thomas-braun sagte in mihome vaccum ist offt gelb:
                            @krisiun
                            Nur auf was wirkt sich dieser updates aus? Kann es sein dass danach manche Adapter Schwierigkeiten bekommen ?
                            • KrisiunK Krisiun
                              @krisiun
                              Es ist die aktuell für nodejs vorgesehene Version.
                              Die Adapter müssten alle damit zurecht kommen.
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                Nein, es ist die aktuell für nodejs vorgesehene Version.
                                Deine Anleitung ist sehr umfangreich. Ich muss erst mal alles genau lesen was ich da im telnet eingeben muss.
                                Vielen Dank
                                • KrisiunK Krisiun
                                  Vielen Dank
                                  telnet
                                  Telnet? Das verwendet noch wer?
                                  SSH ist (seit Jahren) der Standard.
                                  • KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    telnet
                                    Ja ich hab mich falsch ausgedruckt. Putty habe ich gemeint SSH
                                    • KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      @krisiun
                                      Jedenfalls hat bei mir das Updates Node auf die v. 16.17.0 nicht geklappt. Leider. Aber nicht so schlimm ich werde morgen weiter probieren.
                                      Vielen Dank
                                      • KrisiunK Krisiun
                                        @krisiun
                                        Vielen Dank
                                        nicht geklappt.
                                        Heißt konkret?
                                          nicht geklappt.
                                          Heißt konkret?
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          Heißt keine Veränderung. Die alte Version ist geblieben
