  4. mihome vaccum ist offt gelb
    5.8k
126 Beiträge 5 Kommentatoren 16.1k Aufrufe 5 Beobachtet
    @krisiun
    Ja, ist okay. Der Rest?
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    code_text/usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.19.3
    v14.19.3
    6.14.17
    pi
    /home/pi
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://deb.nodesource.com/node_14.x buster InRelease
    Aktualisierung für 40 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    nodejs:
      Installiert:           14.19.3-deb-1nodesource1
      Installationskandidat: 14.20.0-deb-1nodesource1
      Versionstabelle:
         14.20.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
     *** 14.19.3-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u1 500
    KrisiunK Thomas BraunT 2 Antworten Letzte Antwort
    • KrisiunK Krisiun
      /usr/bin/node
      /usr/bin/npm
      v14.19.3
      v14.19.3
      6.14.17
      pi
      /home/pi
      nodejs:
        Versionstabelle:
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      @krisiun
      code_textiobroker update -i
      Adapter    "admin"        : 6.2.20   , installed 5.3.8  [Updatable]
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "backitup"     : 2.4.10   , installed 2.4.10
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.2.2    , installed 4.2.2
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "geofency"     : 1.1.1    , installed 1.1.1
      Adapter    "history"      : 2.2.0    , installed 2.2.0
      Adapter    "hmip"         : 1.18.0   , installed 1.18.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.8   , installed 1.11.8
      Adapter    "javascript"   : 6.0.0    , installed 6.0.0
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
      Adapter    "pushover"     : 3.0.2    , installed 3.0.2
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
      Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
      Adapter    "text2command" : 2.2.2    , installed 2.2.2
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
      Adapter    "tuya"         : 3.6.15   , installed 3.6.15
      G 1 Antwort Letzte Antwort
      • KrisiunK Krisiun
        @krisiun
        guergen
        @krisiun Du bist doch auf der richtigen Version...:
        3.4.2 und nicht auf 1.4.0 vom home
        • KrisiunK Krisiun
          /usr/bin/node
          /usr/bin/npm
          v14.19.3
          v14.19.3
          6.14.17
          pi
          /home/pi
          nodejs:
            Versionstabelle:
          @krisiun sagte in mihome vaccum ist offt gelb:
          iobroker stop
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Und ich würde an deiner Stelle auch überlegen nodejs 16 zu installieren.
          KrisiunK 2 Antworten Letzte Antwort
            iobroker stop
            sudo apt update
            sudo reboot
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            Danke. Ja das habe ich auch schon probiert aber irgendwie hat das nicht geklappt
            • KrisiunK Krisiun
              @krisiun
              Dann schau irgendwie in meine Signatur, da wird erklärt wie man es macht.
                iobroker stop
                sudo apt update
                sudo reboot
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                Aber ist das dass Problem der den mihome-vaccum betrifft?
                • KrisiunK Krisiun
                  @krisiun
                  Vielleicht? Jedenfalls ist 16 die zur Zeit empfohlene Version für den ioBroker.
                  KrisiunK 1 Antwort Letzte Antwort
                    @krisiun
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    Wie kann ich in Deine Signatur schauen ?
                    • KrisiunK Krisiun
                      @krisiun
                      Die steht unter jedem meiner Beiträge.
                        @krisiun
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        Ahso Danke.
                        Kannst Du mir sagen was ändert sich nach der installation von nodjes 16 ?
                        Weil manchmal gibts da Probleme
                        • KrisiunK Krisiun
                          Ahso Danke.
                          Dafür gibt es change logs.
                          Hier das für node16:
                          https://github.com/nodejs/node/blob/main/doc/changelogs/CHANGELOG_V16.md#16.17.0
                            KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            Vielen Dank aber da kann ich leider nichts entnähmen was ich wissen will. Aber egal.
                            • KrisiunK Krisiun
                              @krisiun
                              Was willst du denn wissen?
                                @krisiun
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                @thomas-braun sagte in mihome vaccum ist offt gelb:
                                @krisiun
                                Nur auf was wirkt sich dieser updates aus? Kann es sein dass danach manche Adapter Schwierigkeiten bekommen ?
                                • KrisiunK Krisiun
                                  @krisiun
                                  Es ist die aktuell für nodejs vorgesehene Version.
                                  Die Adapter müssten alle damit zurecht kommen.
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    Nein, es ist die aktuell für nodejs vorgesehene Version.
                                    Deine Anleitung ist sehr umfangreich. Ich muss erst mal alles genau lesen was ich da im telnet eingeben muss.
                                    Vielen Dank
                                    • KrisiunK Krisiun
                                      Vielen Dank
                                      telnet
                                      Telnet? Das verwendet noch wer?
                                      SSH ist (seit Jahren) der Standard.
                                      • KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                        telnet
                                        Ja ich hab mich falsch ausgedruckt. Putty habe ich gemeint SSH
                                        • KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          @krisiun
                                          Jedenfalls hat bei mir das Updates Node auf die v. 16.17.0 nicht geklappt. Leider. Aber nicht so schlimm ich werde morgen weiter probieren.
                                          Vielen Dank
