  4. Widget wie auf der Startseite
    5.6k
20 Beiträge 4 Kommentatoren 3.6k Aufrufe
    DeepCore
    Ich vermute, dass buscet die Visu von http://forum.iobroker.net/viewtopic.php?f=35&t=5369#p54686 meint …
    http://forum.iobroker.net/viewtopic.php?f=30&t=4452 gab's eine Diskussion dazu
    Und https://iobroker.net:8080/vis/edit.html?spaceduck#main hat spaceduck seine Visu hochgeladen
    Wurde anscheinend mit dem HistorySparkLine Widget erstellt, kenne ich noch nicht
    ! [{ "tpl": "tplHistorySparkLIne", "data": { "g_fixed": true, "g_visibility": true, "g_css_font_text": false, "g_css_background": false, "g_css_shadow_padding": false, "g_css_border": true, "g_gestures": false, "g_signals": true, "visibility-cond": "==", "visibility-val": 1, "visibility-groups-action": "hide", "aggregate": "average", "chartType": "bar", "points": "10", "time_interval": "24 hours", "signals-cond-0": "==", "signals-val-0": true, "signals-icon-0": "", "signals-icon-size-0": 0, "signals-blink-0": false, "signals-horz-0": 0, "signals-vert-0": 0, "signals-hide-edit-0": false, "signals-cond-1": "==", "signals-val-1": true, "signals-icon-1": "/vis/signals/lowbattery.png", "signals-icon-size-1": 0, "signals-blink-1": false, "signals-horz-1": 0, "signals-vert-1": 0, "signals-hide-edit-1": false, "signals-cond-2": "==", "signals-val-2": true, "signals-icon-2": "/vis/signals/lowbattery.png", "signals-icon-size-2": 0, "signals-blink-2": false, "signals-horz-2": 0, "signals-vert-2": 0, "signals-hide-edit-2": false, "oid": "hm-rega.0.15324", "instance": "history.0", "min": "960", "max": "1040", "g_line": false, "barSpacing": "1", "zeroColor": "#f8b03a", "negBarColor": "#f8b03a", "barColor": "#f8b03a", "views": ["dg", "dwd", "eg", "energie", "it", "kg", "log", "log-aussen", "log-solar", "og"] }, "style": { "left": "18px", "top": "706px", "width": "104px", "height": "30px" }, "widgetSet": "history" }] !
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      @DeepCore:
      Und https://iobroker.net:8080/vis/edit.html?spaceduck#mainhat spaceduck seine Visu hochgeladen
      ! [{ "tpl": "tplHistorySparkLIne", "data": { "g_fixed": true, "g_visibility": true, "g_css_font_text": false, "g_css_background": false, "g_css_shadow_padding": false, "g_css_border": true, "g_gestures": false, "g_signals": true, "visibility-cond": "==", "visibility-val": 1, "visibility-groups-action": "hide", "aggregate": "average", "chartType": "bar", "points": "10", "time_interval": "24 hours", "signals-cond-0": "==", "signals-val-0": true, "signals-icon-0": "", "signals-icon-size-0": 0, "signals-blink-0": false, "signals-horz-0": 0, "signals-vert-0": 0, "signals-hide-edit-0": false, "signals-cond-1": "==", "signals-val-1": true, "signals-icon-1": "/vis/signals/lowbattery.png", "signals-icon-size-1": 0, "signals-blink-1": false, "signals-horz-1": 0, "signals-vert-1": 0, "signals-hide-edit-1": false, "signals-cond-2": "==", "signals-val-2": true, "signals-icon-2": "/vis/signals/lowbattery.png", "signals-icon-size-2": 0, "signals-blink-2": false, "signals-horz-2": 0, "signals-vert-2": 0, "signals-hide-edit-2": false, "oid": "hm-rega.0.15324", "instance": "history.0", "min": "960", "max": "1040", "g_line": false, "barSpacing": "1", "zeroColor": "#f8b03a", "negBarColor": "#f8b03a", "barColor": "#f8b03a", "views": ["dg", "dwd", "eg", "energie", "it", "kg", "log", "log-aussen", "log-solar", "og"] }, "style": { "left": "18px", "top": "706px", "width": "104px", "height": "30px" }, "widgetSet": "history" }] ! `
      Danke, also das Bar widget doch ;)
      Send from mobile device
        @Dutchman:
        Danke, also das Bar widget doch `
        Nee,
        @DeepCore:
        HistorySparkLine Widget `
          buscet
          Vielen dank für euerer Beiträge.
          DeepCore hat recht, es handelt sich wohl um die Widget Library von Spaceduck.
          Schade, dass ich die nicht so ohne weiteres benutzen kann, ich bin leider kein Node.js bzw. JavaScript Freak. Ich bin aber beindruckt was spaceduck da vorgestellt hat.
          Ich hab auch mal versucht, wie Hormoran vorgeschlagen hat, die "history" Widgets einzubinden.
          Leider läuft da etwas schief.
          Nach der Installation meldet das System abschließend dass index.html nicht gefunden wurde (im LOG gibt es auch keine errors) , was durchaus kein großes Problem darstellen sollte, wenn ich dann aber das sparkline widget verwenden möchte passiert im großen und ganzen gar nichts. (Ich hab mal einen Screenshot aus der 'Edit' Umgebung angefügt.)
          Man sieht weder einen Preview im Auswahl Tab noch nach dem platzieren in der GUI. Nur den gestrichelten Rahmen. Life geschaltet wird dann gar nichts angezeigt.
            @buscet:
            Leider läuft da etwas schief. `
            Sicher?
            @buscet:
            dass index.html nicht gefunden wurde `
            Das ist korrekt, die gibt es auch nicht, da dort nichts zu konfigurieren gibt ;)
            @buscet:
            passiert im großen und ganzen gar nichts. `
            Doch, du siehst es nur nicht.
            Geh mal bitte in die Konsole und mache
            cd /opt/iobroker
            sudo iobroker stop
            sudo iobroker upload all
            sudo iobroker start
            Dann versuchst du es nochmal, aber bitte vorher den Browsercache löschen.
              buscet
              ich habe gerade herausgefunden warum das 'history' bei mir nicht funktioniert.
              Nach der Installation von 'history' in ioBroker.admin (Adapter-Tab) wird keine Instanz von history im verzeichnis /opt/iobroker/iobroker-data/files/vis/widgets angelegt.
              Kopiere ich nun von hand von ]b]/opt/iobroker/node_modules/iobroker.vis-history/widgets nach /opt/iobroker/iobroker-data/files/vis/widgets funktioniert auf einmal alles.
              Hab jetzt aber keine Ahnung an wen ich meine Erkenntnis adressieren soll.
              in meinem Environment ist es ein reproduzierbarer Bug.
              Viele Grüße an alle
              Buscet
                Hast du vor deinen Kopieraktionen meinen Hinweis abgearbeitet?
                  buscet
                  Hallo homoran,
                  ich hatte erst nach meiner Aktion deinen Kommentar gelesen.
                  Aber um dir ein Feedback zu deinem Vorschlag geben zu können, habe ich meine Kopien in …../vis/widgets wieder gelöscht. Danach die 'history' instanz in iobroker.admin offiziell gelöscht.
                  Dann habe ich deine Schritte (incl. BrowserCache leeren) abgearbeitet.
                  Zuletzt habe ich wieder 'history' via iobroker.admin installiert.
                  Leider zeigte sich das gleiche Symptom wie oben beschreiben.(VIS Editor :? )
                  Erst wenn ich history.html und history manuell in ..../vis/widgets kopiere läuft es.
                  Vielleicht noch etwas zu meinem Environment:
                  iobroker läuft auf einem RaspberryPI 3
                  node Version 4.8.3
                  admin Version 1.7.3
                  vis version 0.14.6
                  vis history widgets Version 0.2.4
                  Viele Grüße
                  Buscet
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    Falsche Reihenfolgen, erst den history Adapter installieren Dan die upload Commandos (also als letzten Schritt)
                    Sonst ist ja nichts da was er uploaden kan ;)
                      Der upload müsste genau diese Dateien kopieren.
                        buscet
                        Habs verstanden,
                        werds nochmal, wie von euch beschrieben, machen.
                        Melde mich dann wieder
                        Buscet
                          buscet
                          hab die von homoran vorschlagene Prozedur durchgeführt.
                          (vorher hatte ich meine von Hand kopierten Folder/Dateien history und history.html in ….vis/widget gelöscht)
                          Mit dem Befehl 'iobroker upload all' wurden history und history.html in das widget verzeichnis kopiert. :D
                          Weis jemand, an was es liegen kann, warum das nicht bei der Instanzierung geschieht :?:
                          Nochmal vielen Dank an alle die mir in dem Thread zur Seite standen.
                          Tolles Forum :!:
                          Gruss Buscet
                            @buscet:
                            Weis jemand, an was es liegen kann, warum das nicht bei der Instanzierung geschieht `
                            Nein, sonstige wäre dieser Bug längst behoben ;)
