  4. gelöst: Javascript Adapter 5.8.8
31 Beiträge 6 Kommentatoren 3.4k Aufrufe 6 Beobachtet
  • B Beowolf
    Ich habe das Problem auch
    bei mir kommt die Meldung
    host.raspberrypi
    	2022-09-05 12:51:15.176	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.raspberrypi
    	2022-09-05 12:51:15.176	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    	2022-09-05 12:51:15.176	error	Caught by controller[0]: }
    host.raspberrypi
    	2022-09-05 12:51:15.176	error	Caught by controller[0]: requestPath: 'coffeescript'
    host.raspberrypi
    	2022-09-05 12:51:15.176	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
    host.raspberrypi
    	2022-09-05 12:51:15.175	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi
    	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32) {
    host.raspberrypi
    	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
    host.raspberrypi
    	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
    host.raspberrypi
    	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
    host.raspberrypi
    	2022-09-05 12:51:15.175	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.raspberrypi
    	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
    host.raspberrypi
    	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    host.raspberrypi
    	2022-09-05 12:51:15.174	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
    host.raspberrypi
    	2022-09-05 12:51:15.174	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
    host.raspberrypi
    	2022-09-05 12:51:15.174	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:364:19)
    host.raspberrypi
    	2022-09-05 12:51:15.174	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
    host.raspberrypi
    	2022-09-05 12:51:15.174	error	Caught by controller[0]: ^
    host.raspberrypi
    	2022-09-05 12:51:15.174	error	Caught by controller[0]: throw err;
    host.raspberrypi
    	2022-09-05 12:51:15.173	error	Caught by controller[0]: node:internal/modules/cjs/loader:372
    Ich bin mir nicht sicher was ich machen soll.
    @beowolf sagte in gelöst: Javascript Adapter 5.8.8:
    Welcher Befehl führte zu den Ausgaben?
    Welche nodejs-Version?
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    Welche Versionen der Adapter?
    iobroker update -i
    B 2 Antworten Letzte Antwort
      iobroker update -i
      Beowolf
      Bei
      kommt
      pi@raspberrypi:/ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      pi
      OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
      OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           16.17.0-deb-1nodesource1
        Installationskandidat: 16.17.0-deb-1nodesource1
        Versionstabelle:
       *** 16.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
           14.20.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
           12.22.12~dfsg-1~deb11u1 500
      pi@raspberrypi:/ $
      Bei
      iobroker update -i
      kommt
      pi@raspberrypi:/ $ iobroker update -i
      Used repository: stable
      Adapter    "admin"        : 6.2.20   , installed 6.2.20
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.4.10   , installed 2.4.10
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "email"        : 1.1.3    , installed 1.1.3
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "ical"         : 1.13.1   , installed 1.13.1
      Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.8   , installed 1.11.8
      Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
      Adapter    "javascript"   : 6.0.0    , installed 6.0.0
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "pushover"     : 3.0.2    , installed 3.0.2
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      pi@raspberrypi:/ $
        iobroker update -i
        Beowolf
        @thomas-braun sagte in gelöst: Javascript Adapter 5.8.8:
        Bei diesem
        • B Beowolf
          Bei
          kommt
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.17.0
          v16.17.0
          8.15.0
          pi
          nodejs:
            Versionstabelle:
          pi@raspberrypi:/ $
          Bei
          iobroker update -i
          kommt
          pi@raspberrypi:/ $
          @beowolf
          Stell dich in dein /home-Verzeichnis. Warum steht du da in / herum?
          cd ~
          • B Beowolf
            Bei diesem
            Hast du das auch in / ausgeführt?
            Bitte IMMER vollständige Ein- und Ausgaben inkl. login prompt zeigen, dann sieht man sowas direkt.
              Beowolf
              Habe es dort gemacht.
              pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript/node_modules $ npm install --production
              npm WARN config production Use `--omit=dev` instead.
              > iobroker.javascript@6.0.0 postinstall
              > node ./install/installTypings.js
              Installing NodeJS typings...
              latest @types: 18, installed node: 16
              up to date, audited 107 packages in 12s
              9 packages are looking for funding
                run `npm fund` for details
              found 0 vulnerabilities
              • B Beowolf
                wäre richtig gewesen.
                cd /opt/iobroker/node_modules/iobroker.javascript
                npm install --omit=dev
                  Beowolf
                  schrieb am zuletzt editiert von Beowolf
                  pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ npm install --production
                  up to date, audited 107 packages in 11s
                  Habe ich jetzt ein Problem, weil es im falschen Ordner war?
                  • B Beowolf
                    Gegebenenfalls später, ja.
                      Beowolf
                      pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ npm install --omit=dev
                      • B Beowolf
                        cd /opt/iobroker
                        npm ls iobroker.javascript
                          cd /opt/iobroker
                          Beowolf
                          pi@raspberrypi:/opt/iobroker $ npm ls iobroker.javascript
                          iobroker.inst@3.0.0 /opt/iobroker
                          └── iobroker.javascript@6.0.0
                          • B Beowolf
                            @beowolf
                            Passt.
                            npm ls
                            sagt?
                              @beowolf
                              Passt.
                              npm ls
                              sagt?
                              Beowolf
                              ├── @types/caseless@0.12.2 extraneous
                              ├── @types/request@2.48.8 extraneous
                              ├── @types/tough-cookie@4.0.2 extraneous
                              ├── coffeescript@1.12.7 extraneous
                              ├── iobroker.admin@6.2.20
                              ├── iobroker.alexa2@3.11.2
                              ├── iobroker.alias-manager@1.2.4
                              ├── iobroker.backitup@2.4.10
                              ├── iobroker.discovery@3.0.5
                              ├── iobroker.email@1.1.3
                              ├── iobroker.hm-rega@3.0.40
                              ├── iobroker.hm-rpc@1.15.12
                              ├── iobroker.ical@1.13.1
                              ├── iobroker.influxdb@3.1.7
                              ├── iobroker.info@1.9.19
                              ├── iobroker.iot@1.11.8
                              ├── iobroker.iqontrol@2.0.1
                              ├── iobroker.javascript@6.0.0
                              ├── iobroker.js-controller@4.0.23
                              ├── iobroker.luftdaten@2.2.4
                              ├── iobroker.mqtt@4.0.7
                              ├── iobroker.ping@1.5.3
                              ├── iobroker.pushover@3.0.2
                              ├── iobroker.scenes@2.3.9
                              ├── iobroker.simple-api@2.7.0
                              ├── iobroker.sonoff@2.5.1
                              ├── iobroker.vis-bars@0.1.4
                              ├── iobroker.vis-canvas-gauges@0.1.5
                              ├── iobroker.vis-fancyswitch@1.1.0
                              ├── iobroker.vis-history@1.0.0
                              ├── iobroker.vis-hqwidgets@1.2.0
                              ├── iobroker.vis@1.4.15
                              ├── iobroker.web@4.3.0
                              ├── iobroker.wiffi-wz@2.2.1
                              ├── iobroker.wled@0.6.7
                              ├── jsonata@1.8.6 extraneous
                              ├── node-inspect@2.0.0 extraneous
                              ├── picocolors@1.0.0 extraneous
                              ├── suncalc2@1.8.1 extraneous
                              ├── typescript@4.7.4 extraneous
                              ├── virtual-tsc@0.6.2 extraneous
                              └── wake_on_lan@1.0.0 extraneous
                              • B Beowolf
                                @beowolf
                                Kannst du noch 'prunen', wenn du magst.
                                npm prune
                                Sieht aber sauber aus.
                                  @beowolf
                                  npm prune
                                  Beowolf
                                  npm prune
                                  pi@raspberrypi:/opt/iobroker $ npm prune
                                  removed 105 packages, and changed 1 package in 7s
                                  59 packages are looking for funding
                                    Beowolf
                                    Läuft wieder.
                                    Danke für die Hilfe.
