  4. Test Adapter swiss-weather-api v0.1.x
adaptertestweather
91 Beiträge 17 Kommentatoren 17.3k Aufrufe 18 Beobachtet
    Matt77CHE
    Guten Morgen
    Bin gerade wieder einmal im IoBroker am werkeln und mir ist aufgefallen, dass ich vom Adapter eine Fehlermeldung erhalten habe:
    swiss-weather-api.0
    2022-08-24 07:53:23.508	error	Get Gelocation id - An error has occured. {"code":"429.01.001","message":"Too Many Requests","info":"Quota limit exceeded, please wait to make a new request or contact https://developer.srgssr.ch to increase your quota"}
    swiss-weather-api.0
    2022-08-24 07:53:23.507	error	Get Gelocation id - Invalid or expired access token
    swiss-weather-api.0
    2022-08-24 07:53:13.337	info	longitude/longitude will be set by self-Config - longitude: 7.338249796212077 latitude: 47.1045571
    swiss-weather-api.0
    2022-08-24 07:53:13.316	info	starting. Version 1.0.3 (non-npm: baerengraben/ioBroker.swiss-weather-api) in /opt/iobroker/node_modules/iobroker.swiss-weather-api, node: v16.16.0, js-controller: 4.0.23
    swiss-weather-api.0
    2022-08-24 07:53:09.367	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    swiss-weather-api.0
    2022-08-24 07:53:09.366	info	terminating
    swiss-weather-api.0
    2022-08-24 07:53:09.366	info	cleaned everything up...
    swiss-weather-api.0
    2022-08-24 07:53:09.365	info	Got terminate signal TERMINATE_YOURSELF
    swiss-weather-api.0
    2022-08-24 07:50:52.880	error	Get Gelocation id - An error has occured. {"code":"429.01.001","message":"Too Many Requests","info":"Quota limit exceeded, please wait to make a new request or contact https://developer.srgssr.ch to increase your quota"}
    swiss-weather-api.0
    2022-08-24 07:50:52.880	error	Get Gelocation id - Invalid or expired access token
    swiss-weather-api.0
    2022-08-24 07:50:42.749	info	system longitude: 7.338249796212077 latitude: 47.1045571
    swiss-weather-api.0
    2022-08-24 07:50:42.692	info	longitude/longitude not set, get data from system
    swiss-weather-api.0
    2022-08-24 07:50:42.673	info	starting. Version 1.0.3 (non-npm: baerengraben/ioBroker.swiss-weather-api) in /opt/iobroker/node_modules/iobroker.swiss-weather-api, node: v16.16.0, js-controller: 4.0.23
    swiss-weather-api.0
    2022-08-24 07:50:38.632	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    swiss-weather-api.0
    2022-08-24 07:50:38.632	info	terminating
    swiss-weather-api.0
    2022-08-24 07:50:38.632	info	cleaned everything up...
    swiss-weather-api.0
    2022-08-24 07:50:38.631	info	Got terminate signal TERMINATE_YOURSELF
    Ich habe eine neue API gelöst und diese im Adapter eingetragen und trotzdem kommt die Fehlermeldung über zu viele Anfragen... ich habe auch die Position mal manuell eingetragen.
    Ist da bei der SRG wieder einmal der Wurm drin? - oder lieg das an mir?
    Gruss
    Matt
    • M Matt77CHE
      Guten Morgen
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      swiss-weather-api.0
      Gruss
      Matt
      baerengraben
      @matt77che Guten Morgen
      Die API war jetzt einige Monate sehr stabil.
      Gestern (so ab 13:00 Uhr) lieferte mir das API auch die Meldung, dass die maximale Anzahl verfügbarer Requests überschritten wurde (so wie bei dir). Seit gestern Abend (ca. 22:30 Uhr) funktioniert es aber wieder.
      Sie haben wohl in dieser Zeit was am API angepasst. Gestern um 13:00 Uhr hatte ich sicher noch verfügbare Requests => Das war aus meiner Sicht ein API-Fehler und kein Problem bei dir.
      • B baerengraben
        Matt77CHE
        @baerengraben
        Jep; so wie es aussieht läuft es wieder...
        • M Matt77CHE
          @baerengraben
          baerengraben
          @matt77che Hm.. Heute habe ich wieder die gleiche Meldung. Ich frage mal bei SRF nach....
          • B baerengraben
            Matt77CHE
            @baerengraben
            Bei mir sah ich heute Morgen früh in meiner VIS, dass der Adapter nicht verbunden war mittlerweile ist er wieder verbunden.
              Matt77CHE
              Aktuell habe ich wieder einen ERROR {"code":"429.01.001","message".....
              • M Matt77CHE
                baerengraben
                Ok. Ich warte aktuell noch auf das Feedback von SRF. Ich vermute die haben da was an der API geändert...
                  baerengraben
                  schrieb am zuletzt editiert von baerengraben
                  @Matt77CHE
                  Ich habe heute die Antwort von SRF erhalten. Für das Freemium Abo haben sie die maximale Anzahl Request auf 25 pro Tag reduziert. Wir haben also neu die Updates nicht mehr im Halbstunden-Takt sondern nur noch im Stunden-Takt :(
                  Sie werden dies noch unter https://developer.srgssr.ch/apis/srf-weather dokumentieren.
                  Das bedeutet, dass im Adapter das Attribut "Poll Intervall in Minutes" von 30 auf 60 erhöht werden muss.
                  • B baerengraben
                    @Matt77CHE
                    Matt77CHE
                    @baerengraben
                    Na super wieder einmal Leistungsabbau ..... kennen wir ja von denen leider....
                    Merci für die Info, habe es bei mir angepasst.
                    L 1 Antwort Letzte Antwort
                    • M Matt77CHE
                      @baerengraben
                      Liladi
                      @baerengraben danke für's abklären. Problem gelöst mit dem Intervall auf 60.
                        baerengraben
                        Die aktulle Stable-Version 1.0.3 funktioniert leider seit rund 4 Tagen nicht mehr korrekt. Ich habe heute eine neue Version 1.0.4 released, welche das Problem löst. Die neue Version steht aktuell im Beta-Repo (npm).
                          baerengraben
                          Die Version 1.0.5, welche kleinere Bugs korrigiert, steht im Beta-Repo bereit.
                          • B baerengraben
                            Aktuelle Test Version 2.2.2
                            Veröffentlichungsdatum 9.1.2020
                            Github Link https://github.com/baerengraben/ioBroker.swiss-weather-api
                            Bereit zum Test
                            Hallo zusammen
                            Ich einen Adapter geschrieben, der die Wetter-Daten vom schweizer Staatsfernsehen https://developer.srgssr.ch/apis/srgssr-weather liest und im ioBroker zur Verfügung stellt. Ich bitte um Tests.
                            Vielen Dank :)
                            Peguschwein
                            @baerengraben Hallo bin noch neu in der Materie Iobroker usw. aber habe es geschaft dein Swiss Weather api zu installieren. Zusätzlich habe ich die Wettervorhersagen.json und die Day0_Detailview.json 0-4 importiert. Hat mal alles geklappt. Nur wenn ich den Vis starte habe ich keine vergösserung wenn ich auf den entsprechenden Tag gehe. Wie muss ich diese verlinken ? Konnte leider nichts finden Gruss Rene
                              baerengraben
                              @Peguschwein Da scheint mir die Version mit Overlay abhanden gekommen zu sein. Ich habe die Version mit Overlay wieder auf Github commitet:
                              https://github.com/baerengraben/ioBroker.swiss-weather-api/blob/master/views/Wettervorhersagen_with_Overlay
                              Versuche mal diese zu Importieren. Dann sollte auch der Link auf die Wetterdetails wieder funktionieren.
                              P 2 Antworten Letzte Antwort
                              • B baerengraben
                                Peguschwein
                                @baerengraben werde ich gleich versuchen. Bei den Views ist mir noch aufgefallen das beim Tag2 auch die Daten von Tag1 angezeigt werden. Ist aber nur ein Detail.
                                • B baerengraben
                                  Peguschwein
                                  @baerengraben Perfekt jetzt funktioniert es. Danke dir
                                  • P Peguschwein
                                    baerengraben
                                    #66
                                    @peguschwein für das die falsche Tag2-Anzeige in der View habe ich noch ein Issue erstellt https://github.com/baerengraben/ioBroker.swiss-weather-api/issues/93
                                    ...unglaublich. Obschon ich diese View fast täglich brauche, ist mir das noch nie aufgefallen. Ich muss wohl mal zum Optiker gehen. 🤓
                                      baerengraben
                                      #67
                                      Wichtig - Neue API Version 2
                                      SRF hat eine neue Version des APIs veröffentlicht (Version 2)
                                      Die Version 1 (auf welcher der Adapter aktuell noch basiert) soll noch ein Jahr so weiterlaufen. Nur lassen sich per sofort keine Keys mehr für die API-Version 1 generieren. Neue User des Adapters können damit keine Keys mehr für die die aktuelle Version des Adapters lösen.
                                      Lange Rede kurzer Sinn:
                                      Nur bestehende User können die API Version 1 noch ein Jahr verwenden. Neue User müssen warten, bis der Adapter auf die API Version 2 aktualisiert wurde. => Ich mache mich so rasch wie möglich an die Arbeit https://github.com/baerengraben/ioBroker.swiss-weather-api/issues/94. Aufgrund Familienzeit (Ferien) wird das aber noch etwas dauern.
                                        baerengraben
                                        #68
                                        Ich habe eine neue Version des Adapters (Version 2.0.2) publiziert, welche die SRF Weather API Version 2 implementiert. Wer Zeit und Lust hat, bitte testen!
                                        • B baerengraben
                                          bommel_030
                                          #69
                                          @baerengraben
                                          2.0.2 hat sich geweigert, mit 2.0.3 läuft es jetzt wieder. Danke!
