  4. Zwave2 Adapter startet nicht mehr
27 Beiträge 5 Kommentatoren 1.5k Aufrufe 5 Beobachtet
  • R Offline
    ross0865
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: raspbian buster
    Node-Version: 14.2.0
    Nodejs-Version: 14.2.0
    NPM-Version: 6.14.17
    Hallo aus dem Norden,
    seit einigen Tagen kann ich den Zwave2 Adapter nicht mehr starten. Im Protokoll von iobroker werden folgende Fehlermeldungen angezeigt:
    host.raspberrypi
    2022-09-02 16:28:45.367 info Restart adapter system.adapter.zwave2.0 because enabled
    host.raspberrypi
    2022-09-02 16:28:45.367 error instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2022-09-02 16:28:45.367 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.raspberrypi
    2022-09-02 16:28:45.367 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.raspberrypi
    2022-09-02 16:28:45.366 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
    host.raspberrypi
    2022-09-02 16:28:45.366 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.raspberrypi
    2022-09-02 16:28:45.366 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.raspberrypi
    2022-09-02 16:28:45.366 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.raspberrypi
    2022-09-02 16:28:45.366 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.raspberrypi
    2022-09-02 16:28:45.365 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.raspberrypi
    2022-09-02 16:28:45.365 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.raspberrypi
    2022-09-02 16:28:45.365 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
    host.raspberrypi
    2022-09-02 16:28:45.364 error Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
    host.raspberrypi
    2022-09-02 16:28:43.854 info instance system.adapter.zwave2.0 started with pid 2860
    host.raspberrypi
    2022-09-02 16:28:13.662 info Restart adapter system.adapter.zwave2.0 because enabled
    Ich habe in der Zeit keine Veränderungen an dem System durchgeführt. Ein Update auf auf die Version 2.6 hat nicht geholfen. Der Adapter zeigt folgendes:
    Verbunden mit Host - nein
    Lebenszeichen - nein
    Verbunden mit Gerät oder Dienst - ja
    Hat jemand eine Idee?
    • R ross0865
      Hardwaresystem: Pi4
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      @ross0865
      Bring das System zunächst auf nodejs 16, dann schauen wir weiter.
      R 1 Antwort Letzte Antwort
        @ross0865
        ross0865
        @thoma Mache ich morgen, vielen Dank!
        • R Offline
          ross0865
          @ross0865
          nodejs 16 ist installiert.
          pi@raspberrypi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.17.0
          v16.17.0
          8.15.0
          pi
          /opt/iobroker
          Leider startet der Zwave2-Adapter immer noch nicht. Es erscheinen weiterhin folgende Fehlermeldungen:
          host.raspberrypi
          2022-09-03 10:24:45.509	info	Restart adapter system.adapter.zwave2.0 because enabled
          host.raspberrypi
          2022-09-03 10:24:45.509	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.raspberrypi
          2022-09-03 10:24:45.509	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
          host.raspberrypi
          2022-09-03 10:24:45.509	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
          host.raspberrypi
          2022-09-03 10:24:45.509	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
          host.raspberrypi
          2022-09-03 10:24:45.508	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
          host.raspberrypi
          2022-09-03 10:24:45.508	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
          host.raspberrypi
          2022-09-03 10:24:45.508	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
          host.raspberrypi
          2022-09-03 10:24:45.508	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
          host.raspberrypi
          2022-09-03 10:24:45.508	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
          host.raspberrypi
          2022-09-03 10:24:45.508	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
          host.raspberrypi
          2022-09-03 10:24:45.507	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
          host.raspberrypi
          2022-09-03 10:24:45.507	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
          host.raspberrypi
          2022-09-03 10:24:43.889	info	instance system.adapter.zwave2.0 started with pid 23124
          host.raspberrypi
          2022-09-03 10:24:13.679	info	Restart adapter system.adapter.zwave2.0 because enabled
          Kann es sein, dass er keinen Zugriff mehr auf die serielle Schnittstelle zum Razberry hat? Kann ich das irgendwie prüfen?
          • R ross0865
            @ross0865
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.17.0
            v16.17.0
            8.15.0
            pi
            /opt/iobroker
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            arteckA Offline
            arteckA Offline
            arteck
            @ross0865 sagte in Zwave2 Adapter startet nicht mehr:
            SerialPortMock
            stop den adapter ma..zieh den stick mal ab und wieder rein und adapter neu starten
            • arteckA arteck
              SerialPortMock
              ross0865
              @arteck Ich habe das Aufsteckmodul für den Raspberry. Das Modul nutzt die GPIO Pins 1-10. Kann ich das Modul auch einfach wie ein USB-Stick im laufenden Betrieb abziehen?
              arteckA R 2 Antworten Letzte Antwort
              • R ross0865
                arteckA Offline
                arteckA Offline
                arteck
                @ross0865 ne..dann nimm kurz den pi vom strom.. also runnterfahren.. stromstecker raus..dann wieder hochfahren
                da stimmt was mit dem serialport nicht
                • R ross0865
                  ross0865
                  @ross0865 Hab ich gemacht. Unverändert, Adapter startet nicht....
                  • R Offline
                    ross0865
                    @ross0865 Hier könnte mir evtl. jemand mit gleicher Hardware (raspberry pi 4 mit razberry2-Aufsteckmodul) weiterhelfen, der mir schreibt, was bei dem folgenden Befehl ausgegeben wird?
                    pi@raspberrypi:/opt/iobroker $ ls -la /dev/serial/by-id/
                    Ich bekomme keinen Hinweis auf eine serielle Schnittstelle.
                    • R ross0865
                      @ross0865
                      Ist die Serielle Schnittstelle auch in
                      sudu raspi-config
                      aktiviert worden?
                      Punkt 3 - I6 - NEIN - JA
                      • R Offline
                        ross0865
                        @thomas-braun Ja, ich habe es nochmal geprüft. Ist korrekt.
                        Ich bin ratlos:
                        1. Bei einem alten funktionierenden Image hat es auch nicht geklappt. Gleiche Fehlermeldungen --> Hardware?
                        2. Neues Zwave-Modul getestet. Gleicher Fehler. ---> Fehler Hardware Raspberry Pi 4?
                        • R ross0865
                          Ich bin ratlos:
                          ross0865
                          @ross0865 Ich habe das System neu aufgesetzt, jetzt startet der Adapter wieder. Also kein Hardware-Problem. Aber warum funktionierte das alte Image, was vorher fehlerfrei lief, auch nicht?
                          Jetzt beginnt die Arbeit mit InfluxDB. Grafana, MySQL usw. 😠 Vielen Dank für eure Bemühungen!
                          • R ross0865
                            arteckA Offline
                            arteckA Offline
                            arteck
                            irgend ein alter schXXXX wirds da dazwischen gefunkt haben
                            Fred FreundF 1 Antwort Letzte Antwort
                            • arteckA arteck
                              Fred FreundF Offline
                              Fred Freund
                              Hallo , muss mich hier anhaengen:
                              nach dem update started der Adapter bei mir nicht mehr.
                              lsusb
                              Bus 002 Device 002: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
                              Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                              Bus 001 Device 004: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
                              Bus 001 Device 003: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                              Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                              usbreset gemacht
                              host.iobroker1
                              	2022-09-06 10:20:28.627	info	Restart adapter system.adapter.zwave2.0 because enabled
                              host.iobroker1
                              	2022-09-06 10:20:28.627	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.iobroker1
                              	2022-09-06 10:20:28.627	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                              host.iobroker1
                              	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                              host.iobroker1
                              	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
                              host.iobroker1
                              	2022-09-06 10:20:28.626	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                              host.iobroker1
                              	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                              host.iobroker1
                              	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                              host.iobroker1
                              	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                              host.iobroker1
                              	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                              host.iobroker1
                              	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                              host.iobroker1
                              	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
                              host.iobroker1
                              	2022-09-06 10:20:28.624	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
                              host.iobroker1
                              	2022-09-06 10:20:27.233	info	instance system.adapter.zwave2.0 started with pid 5584
                              host.iobroker1
                              	2022-09-06 10:19:57.038	info	Restart adapter system.adapter.zwave2.0 because enabled
                              und das wiederholt sich immer...
                              keine updates:
                              apt list --upgradable
                              Listing... Done
                              many Thx for your support,
                              Vielen Dank!
                              arteckA AlCalzoneA 2 Antworten Letzte Antwort
                              • Fred FreundF Fred Freund
                                lsusb
                                usbreset gemacht
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                host.iobroker1
                                keine updates:
                                Listing... Done
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @fred-freund was hast du im USB sonst noch stecken ?
                                • arteckA arteck
                                  Fred Freund
                                  @arteck bootable usb sata, zigbee stick
                                  Vielen Dank!
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @fred-freund da hast du deine Probleme.. zeigmal die einstellung des adapter ?
                                    nochmal der kann den Port nicht öffnen ergo den zwave stick nicht finden
                                      lsusb
                                      usbreset gemacht
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      host.iobroker1
                                      keine updates:
                                      Listing... Done
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      @fred-freund sagte in Zwave2 Adapter startet nicht mehr:
                                      Welche Version hast du denn installiert? Sieht mir nicht nach der stable-Version aus.
                                      • AlCalzoneA AlCalzone
                                        Fred Freund
                                        schrieb am zuletzt editiert von Fred Freund
                                        @alcalzone
                                        Vielen Dank!
                                          @alcalzone
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          @fred-freund Seltsam. Du könntest mal auf 3.0.3 aus dem Latest/Beta-Repo upgraden. Da sollte das auf jeden Fall gehen.
                                          Es kann aber derzeit noch Probleme mit manchen Geräten geben. Fall das der Fall ist, bitte jeweils neu interviewen (nur interviewen, nicht neu anlernen).
