  4. Alpha Testing: OCPP Wallbox Adapter
    6.3k
ocppwallboxadapter
448 Beiträge 49 Kommentatoren 152.5k Aufrufe 47 Beobachtet
  • foxriver76F foxriver76
    @foxriver76 Ich habe mal go-e parallel installiert, funktioniert bei mir trotzdem. Bin da aktuell etwas ratlos. Auf dem Host auf dem das läuft ist bei mir noch node 12.
    Meister MopperM Online
    Meister Mopper
    #188
    @foxriver76
    Ich habe den Adapter mal auf einem Slave installiert. Dort läuft Node.js 16.17.0 und npm 8.15.0.
    Ich bekomme ihn jedoch nicht grün und das log zeigt das Folgende:
    $ iobroker url https://github.com/foxriver76/ioBroker.ocpp.git --host rpizigbee --debug
    install foxriver76/ioBroker.ocpp#48303d5b08f18682ed681038d614133990a50c1e
    Installing foxriver76/ioBroker.ocpp#48303d5b08f18682ed681038d614133990a50c1e... (System call)
    npm WARN skipping integrity check for git dependency ssh://git@github.com/foxriver76/ioBroker.ocpp.git
    npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated joi-date-extensions@1.2.0: This module has moved and is now available at @hapi/joi-date. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated hoek@5.0.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
    npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated joi@13.7.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
    npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    added 47 packages, removed 40 packages, and changed 8 packages in 2m86 packages are looking for funding run `npm fund` for details
    upload [1] ocpp.admin /opt/iobroker/node_modules/iobroker.ocpp/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] ocpp.admin /opt/iobroker/node_modules/iobroker.ocpp/admin/ocpp.png ocpp.png image/png
    Process exited with code 0
    Proxmox und HA ...
      @foxriver76
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #189
      @meister-mopper Bitte nicht mehr von Git installieren, Adapter ist mittlerweile im Repo. Abseits davon sieht das Installations-Log unauffällig aus. Log vom Start ist eher interessant.
      Videotutorials & mehr
        Meister Mopper
        #190
        @foxriver76
        Na ja, das ist wahrscheinlich auch eher unspektakulär. Ich schrieb ja, dass der Adapter nicht grün wird und somit auch mit meiner Wallbox nicht kommuniziert.
        ocpp.0	2022-08-26 16:01:03.819	debug	Redis Objects: Use Redis connection: 192.168.178.10:9001
        ocpp.0	2022-08-26 16:01:03.894	debug	Objects client ready ... initialize now
        ocpp.0	2022-08-26 16:01:03.914	debug	Objects create System PubSub Client
        ocpp.0	2022-08-26 16:01:03.916	debug	Objects create User PubSub Client
        ocpp.0	2022-08-26 16:01:04.028	debug	Objects client initialize lua scripts
        ocpp.0	2022-08-26 16:01:04.043	debug	Objects connected to redis: 192.168.178.10:9001
        ocpp.0	2022-08-26 16:01:04.093	debug	Redis States: Use Redis connection: 192.168.178.10:6379
        ocpp.0	2022-08-26 16:01:04.103	debug	States create System PubSub Client
        ocpp.0	2022-08-26 16:01:04.104	debug	States create User PubSub Client
        ocpp.0	2022-08-26 16:01:04.118	debug	States connected to redis: 192.168.178.10:6379
        ocpp.0	2022-08-26 16:01:04.368	info	starting. Version 0.6.0 (non-npm: foxriver76/ioBroker.ocpp#48303d5b08f18682ed681038d614133990a50c1e) in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.17.0, js-controller: 4.0.23
        ocpp.0	2022-08-26 16:01:04.413	info	Starting OCPP Server
        ocpp.0	2022-08-26 16:01:04.454	info	Server listening on port 9220
        ocpp.0	2022-08-26 16:12:17.153	info	Got terminate signal TERMINATE_YOURSELF
        ocpp.0	2022-08-26 16:12:17.166	info	terminating
        ocpp.0	2022-08-26 16:12:17.169	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        Proxmox und HA ...
          @foxriver76
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          #191
          @meister-mopper Ah.. ich hattes es so interpretiert, dass er crashed ;-)
          Und in der Box hast du die OCPP Server Adresse auf deine IP vom "Slave" abgeändert?
          Meister MopperM 2 Antworten Letzte Antwort
            Meister Mopper
            #192
            @foxriver76 sagte in Alpha Testing: OCPP Wallbox Adapter:
            Natürlich habe ich Depp das nicht getan. Das teste ich morgen nochmal.
            Proxmox und HA ...
              Meister Mopper
              #193
              @foxriver76
              Leider bekomme ich auch mit in der Wallbox geänderter IP des Slave dasselbe Ergebnis.
              Irgendwie scheint es mit Nodejs.16 noch nicht zu funktionieren. Vielleicht kann ja jemand anders dies nochmal testen.
              Proxmox und HA ...
                @foxriver76
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                #194
                @meister-mopper dasselbe Ergebnis heißt wieder joi Schema issue?
                  Meister Mopper
                  #195
                  Nein, nein, der Server lauscht, aber er ses kommt keine Verbindung mit der Wallbox unter Node.js 16 zustande.
                  ocpp.0	2022-08-27 08:51:24.315	info	Got terminate signal TERMINATE_YOURSELF
                  ocpp.0	2022-08-27 08:51:24.333	info	terminating
                  ocpp.0	2022-08-27 08:51:24.335	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  ocpp.0	2022-08-27 08:51:29.572	debug	Redis Objects: Use Redis connection: 192.168.178.10:9001
                  ocpp.0	2022-08-27 08:51:29.628	debug	Objects client ready ... initialize now
                  ocpp.0	2022-08-27 08:51:29.631	debug	Objects create System PubSub Client
                  ocpp.0	2022-08-27 08:51:29.632	debug	Objects create User PubSub Client
                  ocpp.0	2022-08-27 08:51:29.708	debug	Objects client initialize lua scripts
                  ocpp.0	2022-08-27 08:51:29.716	debug	Objects connected to redis: 192.168.178.10:9001
                  ocpp.0	2022-08-27 08:51:29.763	debug	Redis States: Use Redis connection: 192.168.178.10:6379
                  ocpp.0	2022-08-27 08:51:29.774	debug	States create System PubSub Client
                  ocpp.0	2022-08-27 08:51:29.776	debug	States create User PubSub Client
                  ocpp.0	2022-08-27 08:51:29.789	debug	States connected to redis: 192.168.178.10:6379
                  ocpp.0	2022-08-27 08:51:29.976	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.17.0, js-controller: 4.0.23
                  ocpp.0	2022-08-27 08:51:30.015	info	Starting OCPP Server
                  ocpp.0	2022-08-27 08:51:30.056	info	Server listening on port 9220
                  Proxmox und HA ...
                    Meister Mopper
                    schrieb am zuletzt editiert von Meister Mopper
                    #196
                    @foxriver76
                    Edit: Ich sehe schon, die neue IP wurde noch nicht übernommen. Ich habe es jetzt erfolgreich geändert und siehe da, die Wallbox ist mit dem Slave verbunden.
                    Weiterhin habe ich transactionActive auf false gesetzt, und der Adapter ist nicht ausgestiegen. Der status wechselte auf Finishing.
                    Es scheint zu funktionieren.
                    ocpp.0	2022-08-27 09:06:02.027	debug	Connection from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with credentials "undefined", protocol: "http", OCPP: ocpp1.6
                    ocpp.0	2022-08-27 09:06:02.028	info	New valid connection from "http://192.168.178.80:9220/EVB-XXXXXXXXX" (http/ocpp1.6)
                    ocpp.0	2022-08-27 09:06:06.779	info	New device connected: "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:06:06.781	info	Requesting StatusNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:06:06.897	debug	{"chargePointVendor":"EV-BOX","chargePointModel":"G4E-WIFI","chargePointSerialNumber":"21312507","firmwareVersion":"P0422B0422v0.211223_U6.0.0-050","commandOcpp":"BootNotification"}
                    ocpp.0	2022-08-27 09:06:06.898	info	Received boot notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:06:07.136	debug	{"connectorId":0,"status":"Available","errorCode":"NoError","timestamp":"2022-08-27T07:06:06Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:06:07.137	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Available
                    ocpp.0	2022-08-27 09:06:07.174	debug	{"status":"Installed","commandOcpp":"FirmwareStatusNotification"}
                    ocpp.0	2022-08-27 09:06:07.175	warn	Command not implemented from "http://192.168.178.80:9220/EVB-XXXXXXXXX": {"status":"Installed","commandOcpp":"FirmwareStatusNotification"}
                    ocpp.0	2022-08-27 09:06:07.308	debug	{"connectorId":1,"status":"Available","errorCode":"NoError","timestamp":"2022-08-27T07:06:06Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:06:07.308	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Available
                    ocpp.0	2022-08-27 09:06:11.786	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Available,NoError,No error.,0,Green,0,{0,7984,100},{0,0},{A,11893,12017,61568},0,0,440,2022-08-27T07:06:06Z,0,3,{0,0,0,0,0,0,0,0,0},360,0,0,114,0,370,900,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:06:11.787	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Available,NoError,No error.,0,Green,0,{0,7984,100},{0,0},{A,11893,12017,61568},0,0,440,2022-08-27T07:06:06Z,0,3,{0,0,0,0,0,0,0,0,0},360,0,0,114,0,370,900,0
                    ocpp.0	2022-08-27 09:06:16.785	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Available,NoError,No error.,0,Green,0,{0,7984,100},{0,0},{A,11936,12029,61568},0,0,340,2022-08-27T07:06:06Z,0,3,{0,0,0,0,0,0,0,0,0},260,1,0,113,0,270,900,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:06:16.787	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Available,NoError,No error.,0,Green,0,{0,7984,100},{0,0},{A,11936,12029,61568},0,0,340,2022-08-27T07:06:06Z,0,3,{0,0,0,0,0,0,0,0,0},260,1,0,113,0,270,900,0
                    ocpp.0	2022-08-27 09:06:36.802	warn	Could not request states of "http://192.168.178.80:9220/EVB-XXXXXXXXX": Timeout for message d80dc13d-9799-4699-823a-0ea010c20356
                    ocpp.0	2022-08-27 09:07:01.794	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:07:01.795	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:07:56.754	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:07:56.755	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:08:51.761	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:08:51.762	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:09:46.955	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:09:46.956	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:10:41.921	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:10:41.922	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:11:36.759	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:11:36.759	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:12:31.800	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:12:31.801	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:13:26.757	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:13:26.758	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:13:44.003	debug	{"connectorId":1,"status":"Preparing","errorCode":"NoError","timestamp":"2022-08-27T07:13:43Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:13:44.004	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                    ocpp.0	2022-08-27 09:13:44.054	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11930,9530,61568},0,0,340,2022-08-27T07:13:43Z,0,3,{0,0,0,0,0,0,0,0,0},260,0,1,113,0,270,900,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:13:44.055	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11930,9530,61568},0,0,340,2022-08-27T07:13:43Z,0,3,{0,0,0,0,0,0,0,0,0},260,0,1,113,0,270,900,0
                    ocpp.0	2022-08-27 09:13:50.071	debug	{"idTag":"048EAB728E6781","commandOcpp":"Authorize"}
                    ocpp.0	2022-08-27 09:13:50.071	info	Received Authorization Request from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:13:51.487	debug	{"connectorId":1,"status":"Preparing","errorCode":"NoError","timestamp":"2022-08-27T07:13:50Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:13:51.488	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                    ocpp.0	2022-08-27 09:13:51.535	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Preparing,NoError,No error.,0,Off,0,{20,7984,100},{0,0},{B,11929,9148,61568},0,0,340,2022-08-27T07:13:50Z,0,3,{0,0,0,0,0,0,0,0,0},260,0,0,125,0,270,900,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:13:51.536	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Off,0,{20,7984,100},{0,0},{B,11929,9148,61568},0,0,340,2022-08-27T07:13:50Z,0,3,{0,0,0,0,0,0,0,0,0},260,0,0,125,0,270,900,0
                    ocpp.0	2022-08-27 09:13:54.120	debug	{"connectorId":1,"status":"SuspendedEVSE","errorCode":"NoError","info":"B;340","timestamp":"2022-08-27T07:13:53Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:13:54.121	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": SuspendedEVSE
                    ocpp.0	2022-08-27 09:13:54.334	debug	{"connectorId":1,"status":"SuspendedEV","errorCode":"NoError","info":"B;340","timestamp":"2022-08-27T07:13:53Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:13:54.334	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": SuspendedEV
                    ocpp.0	2022-08-27 09:13:55.768	debug	{"connectorId":1,"idTag":"048EAB728E6781","timestamp":"2022-08-27T07:13:52Z","meterStart":0,"commandOcpp":"StartTransaction"}
                    ocpp.0	2022-08-27 09:13:55.768	info	Received Start transaction from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:13:56.627	debug	{"connectorId":1,"status":"Charging","errorCode":"NoError","info":"C;340","timestamp":"2022-08-27T07:13:55Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:13:56.628	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
                    ocpp.0	2022-08-27 09:14:00.779	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7984,10},{0,0},{B,11936,8706,10437},0,0,340,2022-08-27T07:13:53Z,1,3,{0,0,0,0,0,0,0,0,0},250,0,0,125,0,270,60,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:14:00.780	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7984,10},{0,0},{B,11936,8706,10437},0,0,340,2022-08-27T07:13:53Z,1,3,{0,0,0,0,0,0,0,0,0},250,0,0,125,0,270,60,0
                    ocpp.0	2022-08-27 09:14:05.770	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7983,10},{0,0},{B,11936,8652,12160},0,0,340,2022-08-27T07:13:53Z,1,3,{0,0,0,0,0,0,0,0,0},250,0,0,125,0,270,60,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:14:05.771	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7983,10},{0,0},{B,11936,8652,12160},0,0,340,2022-08-27T07:13:53Z,1,3,{0,0,0,0,0,0,0,0,0},250,0,0,125,0,270,60,0
                    ocpp.0	2022-08-27 09:14:10.780	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Charging,NoError,No error.,1,Blue,1,{20,7983,10},{0,0},{C,11936,5883,12160},0,0,340,2022-08-27T07:13:55Z,1,3,{0,0,0,0,0,0,0,0,0},250,0,0,113,0,270,60,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:14:10.782	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7983,10},{0,0},{C,11936,5883,12160},0,0,340,2022-08-27T07:13:55Z,1,3,{0,0,0,0,0,0,0,0,0},250,0,0,113,0,270,60,0
                    ocpp.0	2022-08-27 09:14:21.756	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:14:21.757	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:15:16.755	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:15:16.756	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:15:16.810	debug	Sending ChangeAvailability for http://192_168_178_80:9220/EVB-XXXXXXXXX: Operative
                    ocpp.0	2022-08-27 09:15:17.042	debug	{"connectorId":1,"status":"Charging","errorCode":"NoError","info":"C;340","timestamp":"2022-08-27T07:15:16Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:15:17.043	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
                    ocpp.0	2022-08-27 09:15:17.287	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6070,12128},0,0,340,2022-08-27T07:15:16Z,1,3,{0,0,0,0,0,0,0,0,0},260,13,1,113,0,270,160,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:15:17.288	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6070,12128},0,0,340,2022-08-27T07:15:16Z,1,3,{0,0,0,0,0,0,0,0,0},260,13,1,113,0,270,160,0
                    ocpp.0	2022-08-27 09:15:43.178	debug	Sending RemoteStopTransaction for http://192_168_178_80:9220/EVB-XXXXXXXXX
                    ocpp.0	2022-08-27 09:15:48.408	debug	{"transactionId":1,"idTag":"048EAB728E6781","timestamp":"2022-08-27T07:15:47Z","meterStop":0,"reason":"Remote","commandOcpp":"StopTransaction"}
                    ocpp.0	2022-08-27 09:15:48.409	info	Received stop transaction from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:15:49.026	debug	{"connectorId":1,"status":"Finishing","errorCode":"NoError","timestamp":"2022-08-27T07:15:48Z","commandOcpp":"StatusNotification"}
                    ocpp.0	2022-08-27 09:15:49.027	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Finishing
                    ocpp.0	2022-08-27 09:15:52.779	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{C,11927,6188,61591},0,0,340,2022-08-27T07:15:48Z,0,3,{0,0,0,0,0,0,0,0,0},260,8,1,112,0,270,900,0","commandOcpp":"DataTransfer"}
                    ocpp.0	2022-08-27 09:15:52.780	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{C,11927,6188,61591},0,0,340,2022-08-27T07:15:48Z,0,3,{0,0,0,0,0,0,0,0,0},260,8,1,112,0,270,900,0
                    ocpp.0	2022-08-27 09:16:11.755	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:16:11.756	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                    ocpp.0	2022-08-27 09:17:06.775	debug	{"commandOcpp":"Heartbeat"}
                    ocpp.0	2022-08-27 09:17:06.776	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"```
                    [/s]
                    Proxmox und HA ...
                      @foxriver76
                      [/s]
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #197
                      @meister-mopper Sehr gut, interessant sind jetzt die Unterschiede zw. "Master"-System u. "Slave"-System
                        Meister Mopper
                        #198
                        @foxriver76
                        Der Master läuft mit Node.js 14.20.0 und NPM 6.14.17.
                        Der Slave mit 16.17.0 und 8.15.0.
                        Außerdem bekomme ich eine Fehlermeldung, wenn ich chargeLimit auf 16 setze.
                        ocpp.0	2022-08-27 09:25:26.930	error	Cannot execute command "chargeLimit" for "http://192_168_178_80:9220/EVB-XXXXXXXXXX": Sender's message does not comply with protocol specification.
                        Proxmox und HA ...
                          @foxriver76
                          Meister Mopper
                          #199
                          @meister-mopper
                          Ich habe eine EVBox Elvi erfolgreich mit dem Adapter verbunden und kann einen Ladevorgang problemlos abbrechen.
                          Nach Abbrechen über transAction = false erhalte ich den status Finishing
                          Leider kann ich den Ladevorgang durch transAction = true und deaktivieren/reaktivieren der availability nicht wieder starten und bekomme:
                          ocpp.0	2022-08-28 18:41:40.749	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-XXXXXXXXXX": Sender's message does not comply with protocol specification.
                          Jetzt könnte es noch an einem fehlerhaften idTag liegen:
                          Ich habe das idTag erfolglos in verschiedenen Versionen eingegeben
                          <NL-EVB-CXXXXXXXX-F>
                          oder
                          <CXXXXXXXX>
                          oder
                          <CXXXXXXXX-F>
                          oder
                          <NL-EVB-CXXXXXXXX>
                          Weiteres:
                          Nachdem ich einen Ladevorgang abgebrochen habe (Finished), ist die Wallbox für den Adapter tot und reagiert nicht mehr auf irgendwas.
                          Ich muss dann das Ladekabel ziehen, wieder einstecken und mit dem RFID Chip aktivieren. Dann wird wieder geladen, und ich kann problemlos das Laden auch wieder unterbrechen.
                          Manchmal steht man millimeternah vorm Scheunentor, vielleicht ist jemand weiter entfernt.
                          So sieht es nach dem Beenden des Ladevorgangs aus:
                          @foxriver76
                          Hier mal die Zeilen im debug log, nachdem ich transactionActive = true gesetzt habe:
                          ocpp.0	2022-09-02 15:30:29.860	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-xxxxxxxxxx": Sender's message does not comply with protocol specification.
                          ocpp.0	2022-09-02 15:30:29.573	debug	Sending RemoteStartTransaction for http://192_168_178_80:9220/EVB-xxxxxxxxxx: {"connectorId":1,"idTag":"xxxxxxxxxxxxxx","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":16}]}}}
                          Vielleicht hast Du ja eine Idee, welche Informationen der Wallbox noch fehlen.
                          Proxmox und HA ...
                            Tiedi
                            #200
                            Ich versuche meinen ganz neuen NRGkick per ocpp mit diesem Adapter zu verbinden. Leider bisher ohne Erfolg. Stimmt was an den Einstellungen in der NRG App nicht? Hat da jemand Erfahrung?
                            NatorN 1 Antwort Letzte Antwort
                            • T Tiedi
                              NatorN Offline
                              NatorN Offline
                              Nator
                              #201
                              @tiedi
                              Versuche mal ws://... statt http://...
                                Tiedi
                                #202
                                Leider nein.
                                Keine Verbindung möglich. Habe au h schon mit der Authentifizierung alles probiert.
                                Keine Verbindung. Er lädt aber wesentlich länger, wenn ich es mit WS mache.
                                  Tiedi
                                  #203
                                  Kann ich denn irgendwo ein Fehlerprotokoll sehen, um zu checken, was bei der Verbindung schief läuft?
                                  In iobroker unter Protokoll erscheint nichts dazu.
                                  • T Tiedi
                                    Meister Mopper
                                    #204
                                    @foxriver76
                                    Der aktuelle Stand ist, dass ich jetzt vermittels des Adapters Ladevorgänge nicht mehr beenden kann.
                                    Am System habe ich nichts verändert. Das log wirft nach transactiveFalse folgendes:
                                    ocpp.0	2022-09-07 18:15:26.683	info	New valid connection from "http://192.168.178.80:9220/XXXXXXXXX" (http/ocpp1.6)
                                    ocpp.0	2022-09-07 18:15:26.738	info	New device connected: "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-09-07 18:15:26.740	info	Requesting BootNotification from "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-09-07 18:15:27.778	info	Requesting StatusNotification from "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-09-07 18:15:31.785	info	Received boot notification from "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-09-07 18:15:32.108	info	Received Status Notification from "http://192.168.178.80:9220/XXXXXXXXX": Available
                                    ocpp.0	2022-09-07 18:15:36.708	info	Received DataTransfer from "http://192.168.178.80:9220/XXXXXXXXX" with id "evbStatusNotification": 1,Available,NoError,No error.,0,Green,0,{0,7984,100},{0,0},{A,11904,12024,61568},0,0,430,2022-09-07T16:15:31Z,0,3,{0,0,0,0,0,0,0,0,0},350,0,2,112,0,370,900,0
                                    ocpp.0	2022-09-07 18:15:57.789	warn	Could not request states of "http://192.168.178.80:9220/XXXXXXXXX": Timeout for message bf60175d-e1cb-433d-b6ee-69f079b9950d
                                    Möglicherweise ist meine Wallbox jetzt im Reaktionsverhalten langsamer geworden? I have no eaning (😊 )
                                    Proxmox und HA ...
                                      @foxriver76
                                      foxriver76F Offline
                                      foxriver76F Offline
                                      foxriver76
                                      #205
                                      @meister-mopper hm im log sieht man nur die neue Connection
                                        Meister Mopper
                                        #206
                                        @foxriver76
                                        Sorry. Möchtest Du das debug log sehen?
                                        Ja klar, liefere ich morgen nach.
                                        Proxmox und HA ...
                                          @foxriver76
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          schrieb am zuletzt editiert von foxriver76
                                          #207
                                          @meister-mopper Ja genau, der Befehl der raus geht sollte im Debug zu sehen sein. Das ist dann hilfreich. Sorry, bin in letzter Zeit etwas kurz angebunden.
                                          Also wenn er den Ladevorgang nicht beendet, dann sollte ja im Log zumindest die transactionActive=false generierte Message sein und der Payload dazu, auf debug vermute ich nur.
