  3. Einsteigerfragen
  4. [Gelöst] Unifi Adapter Probleme
    4.2k
  • Weihnachtsangebot 2025! 🎄
    2.6k
7 Beiträge 3 Kommentatoren 762 Aufrufe 4 Watching
  • blue231181B Offline
    blue231181B Offline
    blue231181
    schrieb am zuletzt editiert von blue231181
    ich habe folgende Fehlermeldungen im Log:
    unifi.0
    2022-08-22 08:33:46.387	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:33:44.450	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:33:44.268	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:32:47.337	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:32:46.730	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:32:44.477	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:32:44.301	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:31:47.275	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:31:46.704	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:31:45.670	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:31:45.394	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:30:46.066	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:30:45.610	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:30:44.159	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:30:44.032	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:29:46.269	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:29:45.795	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:29:45.082	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:29:44.963	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:28:46.062	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:28:45.623	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:28:44.956	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:28:44.828	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:27:45.920	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:27:45.512	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:27:44.678	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:27:44.554	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:26:45.645	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:26:45.041	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:26:44.423	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:26:44.322	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:25:45.478	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:25:44.837	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:25:44.231	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:25:44.124	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:24:45.356	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:24:44.854	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:24:44.182	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:24:44.086	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:23:46.123	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:23:45.488	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:23:44.454	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:23:44.287	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:22:45.538	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:22:44.917	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:22:44.273	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:22:44.161	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:21:45.598	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:21:44.964	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:21:44.204	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:21:44.109	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:20:45.748	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:20:45.135	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:20:44.477	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:20:44.325	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:19:45.292	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:19:44.675	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:19:44.157	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:19:44.031	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:18:45.337	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:18:44.734	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:18:44.163	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:18:44.061	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:17:45.370	info	State value to set for "unifi.0.default.clients.a8:48:fa:c0:82:03.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:17:44.673	info	State value to set for "unifi.0.default.clients.d4:a6:51:b0:71:44.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:17:44.153	info	State value to set for "unifi.0.default.clients.30:83:98:b6:0f:9d.noted" has to be type "boolean" but received type "string"
    unifi.0
    2022-08-22 08:17:44.023	info	State value to set for "unifi.0.default.clients.10:d5:61:14:91:98.noted" has to be type "boolean" but received type "string"
    Könnt Ihr mir hier weiter helfen?
    Beste Grüße
    • blue231181B blue231181
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      Beste Grüße
      crunchipC Abwesend
      crunchipC Abwesend
      @blue231181 welche adapter version?
      ggf Datenpunkte löschen, Instanz neu starten, danach sollten sie automatisch richtig angelegt werden, wenn nicht issue auf Github erstellen
      blue231181B M 2 Antworten Letzte Antwort
        blue231181B Offline
        blue231181B Offline
        blue231181
        @crunchip Danke für die Antwort.
        Version ist die 0.5.10
        Ich hab jetzt mal den Adapter deinstalliert, alle Datenpunkte gelöscht und neu Installiert. Mal sehen ob es sich verbessert
        Beste Grüße
          McChip
          @crunchip Ich habe auch endlos Fehlermeldungen:
          Object of state "unifi.0.default.num_new_alarms" is missing the required property "common.type"
          State value to set for "unifi.0.default.clients.ae:15:a2:59:32:31.noted" has to be type "boolean" but received type "string"
          State value to set for "unifi.0.default.vouchers.voucher_.used" has to be type "number" but received type "string"
          u.s.w.
          Generell habe ich noch nie in ioBroker einen Adapter aus github installiert.
          Meine Version des unifi Adapters ist 0.5.10 - in Github gibt es bereits die 0.6.3 (2022-10-08).
          Gibt es eine Anleitung wie man eine Github Version installiert? Und Zusatzfrage - warum wird mir die 0.6.3 nicht als Update angeboten.
          Danke schonmal für nen Tipp!
          • M McChip
            u.s.w.
            crunchipC Abwesend
            crunchipC Abwesend
            @mcchip sagte in [Gelöst] Unifi Adapter Probleme:
            weil du entsprechend dein Repo auf stable stehen hast
            github:	0.6.3
            latest:	0.6.3 for 3 months
            stable:	0.5.10 for 20 months
            du kannst auch einzelne Adapter aus dem latest installieren, per NPM
            https://www.iobroker.net/#de/documentation/basics/repositories.md
            Github ist nur nach Aufforderung bzw wenn man weiß was man tut, da dies noch "unfertige" Versionsstände sind.
              github:	0.6.3
              McChip
              @crunchip
              Es hat fast funktioniert!
              Ich wollte nur den Vorschlag anwenden wo ich nicht alles auf Beta umstelle - das hat leider nicht funktioniert.
              Als ich dann den gesamten ioBroker umgestellt hatte konnte ich die aktuelle (nicht stable) Version installieren.
              Die Fehlermeldungen sind weg!
              Danke!
              • M McChip
                @crunchip
                Danke!
                crunchipC Abwesend
                crunchipC Abwesend
                was heisst, hat nicht funktioniert im Detail?
                32.7k
                82.4k
