  4. Admin Error
    5.4k
Admin Error
73 Beiträge 11 Kommentatoren 9.5k Aufrufe 6 Beobachtet
  • peterk34P peterk34
    Auszug :
    2022-08-14 12:25:41.831 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-PM#765C89#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1660463611295,"_id":"shelly.1.SHSW-PM#765C89#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2022-08-14 12:25:41.873 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-PM#F4CFA2E3B5D0#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1660463634390,"_id":"shelly.1.SHSW-PM#F4CFA2E3B5D0#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2022-08-14 12:25:41.875 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-1#8CAAB54B510D#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1660463623004,"_id":"shelly.1.SHSW-1#8CAAB54B510D#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2022-08-14 12:25:41.876 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-PM#F4CFA2E3ACBE#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1652771805223,"_id":"shelly.1.SHSW-PM#F4CFA2E3ACBE#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2022-08-14 12:25:41.876 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-1#76DCCF#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false,"smartName":{"de":"HeizungWerkstatt","smartType":"SWITCH"}},"native":{},"_id":"shelly.1.SHSW-1#76DCCF#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1660463620247}
    2022-08-14 12:25:41.877 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#BCDDC2774AC5#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1660463595456,"_id":"shelly.1.SHSW-25#BCDDC2774AC5#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2022-08-14 12:25:41.878 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-PM#E09806A9CB4F#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1639229888832,"_id":"shelly.1.SHSW-PM#E09806A9CB4F#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2022-08-14 12:25:51.732 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-PM#765C89#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1660463611295,"_id":"shelly.1.SHSW-PM#765C89#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2022-08-14 12:25:51.776 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-PM#F4CFA2E3B5D0#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1660463634390,"_id":"shelly.1.SHSW-PM#F4CFA2E3B5D0#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2022-08-14 12:25:51.779 - error: admin.0 (549218) Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-1#8CAAB54B510D#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1660463623004,"_id":"shelly.1.SHSW-1#8CAAB54B510D#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    @peterk34
    Man sieht leider nur die Quellobjekte, die alle auf "Relay0.Switch" enden, aber keine Ursache. Wie sieht der Alias zu einem angemeckerten Quellobjekt aus?
    peterk34P 1 Antwort Letzte Antwort
      @peterk34
      peterk34P Offline
      peterk34P Offline
      peterk34
        "common": {
          "name": "E Patrone Boiler",
          "desc": "Manuell erzeugt",
          "role": "state",
          "type": "boolean",
          "read": true,
          "write": true,
          "def": false,
          "alias": {
            "id": "shelly.1.SHSW-PM#765C89#1.Relay0.Switch"
        "type": "state",
        "_id": "alias.0.Heizung.E_Patrone_Boiler",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
        "user": "system.user.admin",
        "ts": 1660076562181
        "common": {
          "name": "Heizung Bad",
          "role": "state",
          "type": "boolean",
          "read": true,
          "write": true,
          "def": false,
          "alias": {
            "id": "shelly.1.SHSW-PM#F4CFA2E3B5D0#1.Relay0.Switch"
        "type": "state",
        "_id": "alias.0.Heizung.Heizung_Bad",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1660076708330
          "common": {
            "role": "state",
            "type": "boolean",
            "read": true,
            "write": true,
            "def": false,
            "alias": {
          "type": "state",
          "acl": {
            "object": 1636,
            "state": 1636,
          "ts": 1660076562181
          "common": {
            "role": "state",
            "type": "boolean",
            "read": true,
            "write": true,
            "def": false,
            "alias": {
          "type": "state",
          "acl": {
            "object": 1636,
            "state": 1636,
          "ts": 1660076708330
        @peterk34
        Die sehen soweit in Ordnung aus, außer dass fehlt (unter Zeile 13):
          "native": {},
        und die Rolle in "switch" geändert werden sollte.
        peterk34P 2 Antworten Letzte Antwort
          @peterk34
            "native": {},
          peterk34P Offline
          peterk34P Offline
          peterk34
          Das native habe ich bei einigen reingeschrieben… aufgrund der Menge der Errors hab ich aber noch nicht prüfen können ob die auch noch einen error haben … mach ich noch.
          Soll die Rolle im alias gleich dem referenzierten Datenpunkt sein?
            @peterk34 sagte: Soll die Rolle im alias gleich dem referenzierten Datenpunkt sein?
            Ja, wenn keine Typwandlung stattfindet und die Rolle im Original richtig vergeben wurde.
              @peterk34
                "native": {},
              peterk34P Offline
              peterk34P Offline
              peterk34
              @paul53 sagte in Admin Error:
              "native": {},
              welchen Zweck hat das native?
              paul53P HomoranH 2 Antworten Letzte Antwort
                "native": {},
                @peterk34 sagte: welchen Zweck hat das native?
                Laut Doku ist "native" obligatorisch, und enthält Adapter spezifische Eigenschaften, wenn verwendet, andernfalls ein leeres Objekt.
                  "native": {},
                  @peterk34 meines Wissens befinden sich darin üblicherweise die Daten der Geräte wie sie nativ, ohne Bearbeitung durch den Adapter, vom Gerät kommen.
                    @homoran sagte: üblicherweise die Daten der Geräte wie sie nativ, ohne Bearbeitung durch den Adapter, vom Gerät kommen.
                    Das trifft auf HomeMatic-Datenpunkte zu, sonst eher selten.
                      peterk34P Offline
                      peterk34P Offline
                      peterk34
                      hab das jetzt bei rund 100 Alias ergänzt 😅
                        @peterk34 sagte: hab das jetzt bei rund 100 Alias ergänzt
                        Alias per Admin im Tab "Objekte" erstellt? Dann erstelle ein Issue zum Admin-Adapter, damit dies künftig nicht mehr erforderlich ist.
                        EDIT:
                        Fixed in 6.0.3
                          EDIT:
                          Fixed in 6.0.3
                          peterk34P Offline
                          peterk34P Offline
                          peterk34
                          @apollon77 machen?
                            @apollon77 machen?
                            @peterk34
                            Ich habe gerade einen Alias per Admin 6.2.13 im Tab "Objekte" erstellt und "native" ist automatisch vorhanden:
                             "common": {
                               "name": "LOWBAT",
                               "role": "state",
                               "type": "boolean",
                               "read": true,
                               "write": true,
                               "def": false,
                               "alias": {
                                 "id": "hm-rpc.0.XEQ1234568.0.LOWBAT"
                             "type": "state",
                             "native": {},
                             "_id": "alias.0.Batterie.LOWBAT",
                             "acl": {
                               "object": 1636,
                               "state": 1636,
                             "ts": 1660493639620
                            Verwendest Du eine ältere Version von Amin?
                              @peterk34
                               "common": {
                                 "name": "LOWBAT",
                                 "role": "state",
                                 "type": "boolean",
                                 "read": true,
                                 "write": true,
                                 "def": false,
                                 "alias": {
                               "type": "state",
                               "native": {},
                               "acl": {
                                 "object": 1636,
                                 "state": 1636,
                               "ts": 1660493639620
                              peterk34P Offline
                              peterk34P Offline
                              peterk34
                              ja 5.3.8
                                ja 5.3.8
                                @peterk34 sagte: ja 5.3.8
                                Offenbar ist dies inzwischen korrigiert worden.
                                EDIT:
                                Fixed in 6.0.3
                                  EDIT:
                                  Fixed in 6.0.3
                                  peterk34P Offline
                                  peterk34P Offline
                                  peterk34
                                  5.3.8 ist stable ... machts sinn upzugraden?
                                    @peterk34 sagte: machts sinn upzugraden?
                                    Nur dann, wenn noch einige Alias-Datenpunkte erstellt werden sollen. Andernfalls kann man warten, bis die Korrektur in "stable" angekommen ist.
                                      peterk34P Offline
                                      peterk34P Offline
                                      peterk34
                                      Ich habe jetzt folgendes gemacht. Zum einen habe ich meinen Raspi auf eine SSD Platte umgestellt. Zweitens habe ich redis installiert ... und jetzt sind die Errors weg - warum auch immer.
                                      Ich bedanke mich nochmal für die tolle Unterstützung.
                                      • G Offline
                                        Gabe
                                        Hi zusammen,
                                        ich bekomme auch hin und wieder solche Fehler, mir ist der Zusammenhang nicht ganz klar.
                                        Hier ein Beispiel
                                        Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_024.Binary_Sensor.any, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Any)","type":"boolean"},"native":{"nodeId":24,"valueId"{"commandClass":48,"endpoint":0,"property":"Any"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1661489840603,"_id":"zwave2.0.Node_024.Binary_Sensor.any","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        Hier die Daten aus dem Alias
                                          "common": {
                                            "name": {
                                              "de": "Vorraum"
                                            "role": "door",
                                            "icon": null
                                          "native": {},
                                          "type": "channel",
                                          "ts": 1661514919648,
                                          "_id": "alias.0.Alarm.Vorraum",
                                          "acl": {
                                            "object": 1636,
                                        Was muss ich denn da machen?
                                        • G Gabe
                                          Hi zusammen,
                                          Hier ein Beispiel
                                            "common": {
                                              "name": {
                                                "de": "Vorraum"
                                              "role": "door",
                                              "icon": null
                                            "native": {},
                                            "type": "channel",
                                            "acl": {
                                              "object": 1636,
                                          @gabe sagte: Hier die Daten aus dem Alias
                                          Das ist kein Alias-Datenpunkt, sondern ein Kanal im Alias-Baum.
                                          G 1 Antwort Letzte Antwort
