  4. Mal wieder Error 25 beim Restore
    5.8k
24 Beiträge 5 Kommentatoren 2.0k Aufrufe 4 Beobachtet
  • W Offline
    W Offline
    wusa
    Ich versuche gerade ein Backup wieder einzuspielen.
    Leider erhalte ich Reihenweise Fehler:
    host.iobroker
    2022-08-03 16:13:29.932	info	iobroker npm-install: Installing iobroker.trashschedule@2.0.2... (System call)
    host.iobroker
    2022-08-03 16:13:29.923	info	iobroker npm-install: NPM version: 8.11.0
    host.iobroker
    2022-08-03 16:13:18.485	info	iobroker install trashschedule@2.0.2 using installedFrom
    host.iobroker
    2022-08-03 16:13:18.483	warn	startInstance cannot find adapter "trashschedule@2.0.2". Try to install it... 2 attempt
    host.iobroker
    2022-08-03 16:13:17.481	info	iobroker npm-install: exit 25
    host.iobroker
    2022-08-03 16:13:16.378	error	iobroker npm-install: host.iobroker Cannot install iobroker.tankerkoenig@2.1.1: 217
    host.iobroker
    2022-08-03 16:12:57.257	info	iobroker npm-install: Installing iobroker.tankerkoenig@2.1.1... (System call)
    host.iobroker
    2022-08-03 16:12:57.251	info	iobroker npm-install: NPM version: 8.11.0
    host.iobroker
    2022-08-03 16:12:45.583	info	iobroker install tankerkoenig@2.1.1 using installedFrom
    host.iobroker
    2022-08-03 16:12:45.581	warn	startInstance cannot find adapter "tankerkoenig@2.1.1". Try to install it... 2 attempt
    host.iobroker
    2022-08-03 16:12:44.568	info	iobroker npm-install: exit 25
    host.iobroker
    2022-08-03 16:12:43.478	error	iobroker npm-install: host.iobroker Cannot install iobroker.simple-api@2.7.0: 217
    host.iobroker
    2022-08-03 16:12:24.796	info	iobroker npm-install: Installing iobroker.simple-api@2.7.0... (System call)
    host.iobroker
    2022-08-03 16:12:24.790	info	iobroker npm-install: NPM version: 8.11.0
    host.iobroker
    2022-08-03 16:12:14.294	info	iobroker install simple-api@2.7.0 using installedFrom
    host.iobroker
    2022-08-03 16:12:14.292	warn	startInstance cannot find adapter "simple-api@2.7.0". Try to install it... 2 attempt
    Was mache ich falsch?
    • W wusa
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      @wusa sagte in [HowTo] ioBroker Restore unter Linux durchführen:
      was machst du überhaupt?
      da ist nichts zu sehen, kein Prompt, kein Input
      was erwartest du?
      was stört dich?
      • W Offline
        W Offline
        wusa
        Ich habe einen neuen Pi aufgesetzt und versuche jetzt über den Backitup Adapter das Backup einzuspielen.
        Das Backup an sich lief meiner Meinung nach sauber durch.
        Aber jetzt wenn ich unter den Logs schaue, kommen Reihenweise diese Fehler.
        Ich erwarte eigentlich, dass sich die Adapter wieder wie es in der Anleitung steht, wieder von allein Installieren.
        Mich stört, dass sich die Adapter anscheinend nicht selber wieder installieren und immer mit einem Fehler abbrechen.
        Fehler
        host.iobroker
        2022-08-03 16:21:51.594	warn	startInstance cannot find adapter "iot@1.11.4". Try to install it... 3 attempt
        host.iobroker
        2022-08-03 16:21:50.593	info	iobroker npm-install: exit 25
        host.iobroker
        2022-08-03 16:21:49.520	error	iobroker npm-install: host.iobroker Cannot install iobroker.chromecast@2.3.1: 217
        host.iobroker
        2022-08-03 16:21:06.654	info	iobroker npm-install: Installing iobroker.chromecast@2.3.1... (System call)
        • W wusa
          Fehler
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          das versucht er doch auch
          Mich stört, dass sich die Adapter ... immer mit einem Fehler abbrechen.
          dann such mal im Forum nach dem Fehler 25, mit mehr Infos zu
          könnte man dir vielleicht helfen
          W 1 Antwort Letzte Antwort
            W Offline
            W Offline
            wusa
            @homoran sagte in [HowTo] ioBroker Restore unter Linux durchführen:
            Aber er schafft es anscheinend nicht?
            Sonst würde er es nicht immer und immer wieder versuchen?
            Ok werde ich machen.
            Ich denke nicht. In einem anderen Thread hatte ich sehr viele Probleme. @Thomas-Braun hat mir sehr viel versucht zu helfen. Aber ich habe meinen ioBroker nicht wieder zu laufen gebracht. Habe dann abgebrochen und einen neuen Pi aufgesetzt. Backups habe ich jeden Tag gemacht. Habe dann das Backup genommen bevor der Fehler aufgetreten ist, in der Hoffnung, dass alles wieder läuft.
            • W wusa
              Tontechniker
              @wusa Hast Du lange genug gewartet? Das kann schon dauern, bis alle Adapter installiert und gestartet sind.
              W HomoranH 2 Antworten Letzte Antwort
              • T Tontechniker
                W Offline
                W Offline
                wusa
                @tontechniker
                Ich warte noch. Bzw ich lasse es jetzt einfach laufen.
                Wollte mich nur melde, da die Meldung sagt, kann nicht installiert werden. Und er es schon zum 3. Mal versucht wurde.
                Wenn das normal ist, warte ich ab?
                • T Tontechniker
                  @tontechniker sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                  das ist hier nicht der Punkt, er bekommt den Error 25
                  • W wusa
                    @tontechniker
                    @wusa
                    Installier mal 'irgendeinen' Adapter mit --debug-Option.
                    HomoranH W 2 Antworten Letzte Antwort
                      @wusa
                      @wusa
                      ich hab das mal als x-ten Thread zum error 25 abgespalten.
                        @wusa
                        @homoran sagte in Mal wieder Error 25 beim Restore:
                        error 25
                        Wobei der eigentlich total generisch ist und nur besagt: "Geht nicht, da liegt was im Weg!"
                          @thomas-braun sagte in Mal wieder Error 25 beim Restore:
                          error 25
                          richtig, ist aber kein allgemeingültiges Restore Thema, sondern ein spezielles Problem
                            @wusa
                            W Offline
                            W Offline
                            wusa
                            @wusa
                            Ok muss ich später machen. Melde mich dann nochmal
                            • W Offline
                              W Offline
                              wusa
                              schrieb am zuletzt editiert von wusa
                              Kannst du mir helfen wie das geht. Vermutlich über die Konsole?
                              pi@iobroker:~ $ npm install iobroker.bring --debug
                              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                              npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                              added 73 packages, and audited 74 packages in 25s
                              4 packages are looking for funding
                                run `npm fund` for details
                              found 0 vulnerabilities
                              Wenn es irgendwie anders gehen sollte, dann bräuchte ich bitte kurz Hilfe.
                              • W wusa
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                @wusa
                                das sind nur warnungen.
                                request funktioniert noch wunderbar weiter.
                                Meine Adapter und Widgets
                                Links im Profil
                                • OliverIOO OliverIO
                                  @wusa
                                  Nicht im Homeverzeichnis des 'pi' per npm installieren...
                                  Mach es so:
                                  iobroker add bring --debug
                                    Mach es so:
                                    W Offline
                                    W Offline
                                    wusa
                                    Mach es so:
                                    pi@iobroker:~ $ iobroker add bring --debug
                                    NPM version: 8.11.0
                                    Installing iobroker.bring@1.8.1... (System call)
                                    npm ERR! code ENOTEMPTY
                                    npm ERR! syscall rename
                                    npm ERR! path /opt/iobroker/node_modules/acorn
                                    npm ERR! dest /opt/iobroker/node_modules/.acorn-zHERliMH
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acorn' -> '/opt/iobroker/node_modules/.acorn-zHERliMH'
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-03T19_25_04_208Z-debug-0.log
                                    host.iobroker Cannot install iobroker.bring@1.8.1: 217```
                                    • W wusa
                                      Mach es so:
                                      NPM version: 8.11.0
                                      npm ERR! errno -39
                                      @wusa
                                      Schau in mein Node HowTo (s. Signatur), im zweiten Teil steht die Lösung drin.
                                        @wusa
                                        W Offline
                                        W Offline
                                        wusa
                                        Irgendwie komme ich weiter oder ich mache was falsch:
                                        cd /opt/iobroker/node_modules
                                        pi@iobroker:/opt/iobroker/node_modules $ for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                                        pi@iobroker:/opt/iobroker/node_modules $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                                        pi@iobroker:/opt/iobroker/node_modules $ nodejs -v
                                        v16.16.0
                                        pi@iobroker:/opt/iobroker/node_modules $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        aarch64
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.16.0
                                        v16.16.0
                                        8.11.0
                                        pi
                                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        Reading package lists... Done
                                        All packages are up to date.
                                        nodejs:
                                          Installed: 16.16.0-deb-1nodesource1
                                          Candidate: 16.16.0-deb-1nodesource1
                                          Version table:
                                         *** 16.16.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                             12.22.12~dfsg-1~deb11u1 500
                                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                             12.22.5~dfsg-2~11u1 500
                                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                        pi@iobroker:/opt/iobroker/node_modules $ iobroker add bring --debug
                                        NPM version: 8.11.0
                                        npm ERR! path /opt/iobroker/node_modules/@types/request
                                        npm ERR! dest /opt/iobroker/node_modules/@types/.request-wwDUthdZ
                                        npm ERR! errno -39
                                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@types/request' -> '/opt/iobroker/node_modules/@types/.request-wwDUthdZ'
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-03T19_51_25_251Z-debug-0.log
                                        • W wusa
                                          v16.16.0
                                          aarch64
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.16.0
                                          v16.16.0
                                          8.11.0
                                          pi
                                          nodejs:
                                            Version table:
                                          NPM version: 8.11.0
                                          npm ERR! errno -39
                                          @wusa
                                          Jetzt in das nächste Verzeichnis springen und dort die for-Schleife ausführen
