  4. Test Adapter EnOcean v0.7.x
    6.4k
eltako fgw14-usbenocean adapter
105 Beiträge 9 Kommentatoren 16.3k Aufrufe 9 Beobachtet
  • I IOSD
    @jey-cee hier der Debug Log, da ich das nirgends einstellen kann. der FGW14 USB sendet ja mit 57600 Baud. Das ist aber vermutlich korrekt. Ich habe es nur nirgends nochmal einstellen können.
    2022-07-09 11:28:15.216 - debug: enocean.0 (592) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-07-09 11:28:15.261 - debug: enocean.0 (592) Objects client ready ... initialize now
    2022-07-09 11:28:15.264 - debug: enocean.0 (592) Objects create System PubSub Client
    2022-07-09 11:28:15.266 - debug: enocean.0 (592) Objects create User PubSub Client
    2022-07-09 11:28:15.289 - debug: enocean.0 (592) Objects client initialize lua scripts
    2022-07-09 11:28:15.298 - debug: enocean.0 (592) Objects connected to redis: 127.0.0.1:9001
    2022-07-09 11:28:15.328 - debug: enocean.0 (592) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-07-09 11:28:15.356 - debug: enocean.0 (592) States create System PubSub Client
    2022-07-09 11:28:15.358 - debug: enocean.0 (592) States create User PubSub Client
    2022-07-09 11:28:15.371 - debug: enocean.0 (592) States connected to redis: 127.0.0.1:9000
    2022-07-09 11:28:15.563 - info: enocean.0 (592) starting. Version 0.7.0 (non-npm: Jey-Cee/ioBroker.enocean#df6980753d3beeadce3db596c2f0809372c55415) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.16.0, js-controller: 4.0.23
    2022-07-09 11:28:33.137 - debug: enocean.0 (592) 55008b020a36055000000000000019302900010000
    2022-07-09 11:28:33.148 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
    2022-07-09 11:28:33.198 - debug: enocean.0 (592) 55008b020a3605500000000000001a302a000100b4
    2022-07-09 11:28:33.202 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
    2022-07-09 11:28:51.419 - debug: enocean.0 (592) 55008b020a3605500000000000001a302a000100b4
    2022-07-09 11:28:51.423 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
    2022-07-09 11:28:52.970 - debug: enocean.0 (592) 55008b020a36055000000000000019302900010000
    2022-07-09 11:28:52.975 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
    2022-07-09 11:28:59.432 - debug: enocean.0 (592) 550003020af6000100ac
    2022-07-09 11:28:59.438 - debug: enocean.0 (592) ERP2 protocol radio telegram received.
    2022-07-09 11:28:59.443 - error: enocean.0 (592) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-07-09 11:28:59.444 - error: enocean.0 (592) unhandled promise rejection: The id is empty! Please provide a valid id.
    2022-07-09 11:28:59.452 - error: enocean.0 (592) Error: The id is empty! Please provide a valid id.
    at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:114:19)
    at Enocean.getObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:2332:23)
    at /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2116:16
    at new Promise ()
    at Enocean.getObjectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2115:16)
    at handleType10.main (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:395:34)
    at new handleType10 (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:390:8)
    at Enocean.parseMessage (/opt/iobroker/node_modules/iobroker.enocean/main.js:613:24)
    2022-07-09 11:28:59.453 - error: enocean.0 (592) The id is empty! Please provide a valid id.
    2022-07-09 11:28:59.463 - info: enocean.0 (592) cleaned everything up...
    2022-07-09 11:28:59.465 - info: enocean.0 (592) terminating
    2022-07-09 11:28:59.467 - warn: enocean.0 (592) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-07-09 11:28:59.475 - info: enocean.0 (592) The serial port was closed.
    2022-07-09 11:29:00.020 - error: host.iobroker instance system.adapter.enocean.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-07-09 11:29:00.022 - info: host.iobroker Restart adapter system.adapter.enocean.0 because enabled
    Jey CeeJ Offline
    Jey CeeJ Offline
    Jey Cee
    @iosd bitte von Github neu installieren. Das Telegram was den Absturz verursacht ist Unvollständig, es wird jetzt einfach ignoriert.
    Bitte beobachte ob Statusänderungen für ein bestimmtes Gerät nicht in ioBroker ankommen.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    • I Offline
      I Offline
      IOSD
      @jey-cee Danke das hat es gelöst. Verbindung ist jetzt da und Geräte werden erkannt. Ob was an Telegrammen fehlt muss ich noch schauen...
        Denis1988
        vielen Dank erstmal für die tolle Arbeit!!!
        Wollte den Enocean Adapter heute auch mal mit meinem TCM310 Stick ans Laufen bringen, aber irgendwie bekomm ich den Adapter nicht auf grün.
        Mein Iobroker läuft über Proxmox in einer VM und parallel betreibe ich noch einen Zigbee USB-Dongle. Stick ist in der VM durchgereicht und ich bekomme folgendes im Logg angezeigt:
        Ansonsten sieht die Einstellung wie folgt aus:
        Kann mir jemand eventuell weiterhelfen?
        Vielen Dank und liebe Grüße
        Denis
        • Jey CeeJ Offline
          Jey CeeJ Offline
          Jey Cee
          @denis1988 du musst den Stick schon Auswählen. Da ist nichts ausgewählt und laut log ist alles in Ordnung.
          D 2 Antworten Letzte Antwort
          • Jey CeeJ Jey Cee
            Denis1988
            @jey-cee oh stimmt sorry :-)
            jetzt bekomme ich allerdings folgenden Fehler
            • D Denis1988
              Jey CeeJ Offline
              Jey CeeJ Offline
              Jey Cee
              @denis1988 Falscher Port ausgewählt, nimm den mit EnOcean im Namen.
              • Jey CeeJ Jey Cee
                Denis1988
                • Jey CeeJ Jey Cee
                  Denis1988
                  @jey-cee da erscheint leider nur das bei mir 2105fd01-84db-41c4-bd02-d712e11b32e8-image.png
                  • Jey CeeJ Jey Cee
                    Denis1988
                    @jey-cee jetzt hab ich es danke nochmal für deine schnelle Hilfe :-)
                    • wendy2702W Online
                      wendy2702W Online
                      habe mir zum Testen den Hoppe eFenstergriff ConnectHome und einen Enocean USB Stick besorgt.
                      Aus Unwissenheit den Griff beim ersten mal mit falscher ID angelernt. Wie kann ich den wieder löschen?
                      Aktuell jetzt zwei Griffe drin wobei halt einer die Falsche ID hat.
                      Der DP Window tilt bleibt immer auf "false", ist das normal ?
                      EDIT: OK, der kann kein tilted anzeigen. Gerade bei Hoppe gefunden.
                      • wendy2702W wendy2702
                        Jey CeeJ Offline
                        Jey CeeJ Offline
                        Jey Cee
                        @wendy2702 sagte in Test Adapter EnOcean v0.7.x:
                        Einfach die Objekte löschen.
                        Gut zu wissen.
                        • Jey CeeJ Jey Cee
                          Gut zu wissen.
                          wendy2702W Online
                          wendy2702W Online
                          @jey-cee Hi,
                          gerade wurde mein Ersatz Drehgriff geliefert welcher laut Hoppe Anleitung und Broschüre alle drei Stellungen (Offen, Gekippt, Geschlossen) übermitteln soll.
                          Hoppe Toulon 0737/FR-409 Secusignal
                          In den Objekten wechselt er aber nur zwischen open und tilted. Closed sehe ich nie.
                          Drehgriff zeigt nach unten --> eigentlich geschlossen:
                          Drehgriff zeigt nach links --> offen:
                          Drehgriff zeigt nach oben --> gekippt:
                          Drehgriff zeigt nach rechts --> offen:
                          Drehgriff wieder unten --> sollte geschlossen sein:
                          Das Debug log dazu sieht so aus, denke aber das hilft dir nicht viel
                          2022-08-01 09:08:09.227  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4900
                          2022-08-01 09:08:09.231  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                          2022-08-01 09:10:29.027  - debug: enocean.0 (2186136) 55000707017af6c0fedfa4fe2000ffffffff4a00
                          2022-08-01 09:10:29.030  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                          2022-08-01 09:11:21.845  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4a00
                          2022-08-01 09:11:21.848  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                          2022-08-01 09:12:22.769  - debug: enocean.0 (2186136) 55000707017af6c0fedfa4fe2000ffffffff4f00
                          2022-08-01 09:12:22.775  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                          2022-08-01 09:13:22.621  - debug: enocean.0 (2186136) 55000707017af6d0fedfa4fe2000ffffffff4a00
                          2022-08-01 09:13:22.624  - debug: enocean.0 (2186136) Message for ID fedfa4fe has been received. It was repeated 0 times.
                          Hier noch das log vom Adpaterstart mit der Info zum USB Adapter:
                          info: enocean.0 (2193870) {"BaseID":"ff92c880","Frequency":"868.3 Mhz","Protocol":"ERP1","AppVersion":"2.15.0.0","ApiVersion":"2.6.9.0","ChipID":"051f2591","ChipVersion":"454f0103","AppDescription":"GATEWAYCTRL"}
                          Habe den als Gerät Hoppe Secusignal zugefügt.
                          Ist das jetzt ein Fehler vom Griff, habe ich was falsch gemacht oder liegt es am Adapter?
                          Kann ich noch weitere Infos liefern?
                            @jey-cee Hi,
                            Jey CeeJ Offline
                            Jey CeeJ Offline
                            Jey Cee
                            Sieht aus als wäre das vom Griff, laut den Telegrammen wird Geschlossen nie übermittelt.
                            Das kann aber auch daran liegen wie du den Griff bedienst. Das drehen des Griffs sollte flüssig sein.
                            Wenn sich das Fenster schwer schließen lässt könnte es sein das der Schwung nicht ausreicht um die nötige Energie auf zu bringen damit das Telegram gesendet wird.
                            In dem Fall wäre es ratsam die Mechanik zu Schmieren und bei bedarf das Fenster neu einstellen (lassen).
                            • Jey CeeJ Jey Cee
                              wendy2702W Online
                              wendy2702W Online
                              @jey-cee Der Griff liegt noch vor mir. Am Fenster kann es nicht liegen.
                              Habe den auch schon so oft gedreht und zumindest jedesmal einen Eintrag im Log bekommen, die Objekte werden dann auch immer mit Zeitstempel aktualisiert.
                              Lediglich den "Closed" Status bekomme ich nie zu sehen.
                                Jey CeeJ Offline
                                Jey CeeJ Offline
                                Jey Cee
                                #66
                                Dann montiere ihn mal und Teste es dann.
                                • Jey CeeJ Jey Cee
                                  wendy2702W Online
                                  wendy2702W Online
                                  #67
                                  @jey-cee Das hat leider nichts geändert.
                                  Hast du noch eine Idee?
                                    Jey CeeJ Offline
                                    Jey CeeJ Offline
                                    Jey Cee
                                    #68
                                    Nein sonst fällt mir gerade nichts mehr ein.
                                    • Jey CeeJ Jey Cee
                                      wendy2702W Online
                                      wendy2702W Online
                                      #69
                                      @jey-cee OK.
                                      Jetzt zeigt er es an. Habe ihn nach einem Hinweis im Netz mal 3-4 mal im Kreis gedreht und quasi alle möglichkeiten hintereinander durch geacktert. Dann das gleiche in die andere Richtung und plötzlich:
                                      Mal gucken wie lange das teure Teil funktioniert.
                                      JackDanielJ 1 Antwort Letzte Antwort
                                        @jey-cee OK.
                                        JackDanielJ Online
                                        JackDanielJ Online
                                        JackDaniel
                                        #70
                                        bei mir 6 stk schon seit jahren sehr zuverlässig
                                        Carpe diem
                                        • JackDanielJ JackDaniel
                                          wendy2702W Online
                                          wendy2702W Online
                                          #71
                                          @jackdaniel sagte in Test Adapter EnOcean v0.7.x:
                                          Dann hoffe ich mal das mein erster und der zweite (noch unterwegs) ebenfalls lange halten.
                                          G 1 Antwort Letzte Antwort
