  4. Ganze Iobroker Version läuft langsam
    5.8k
286 Beiträge 8 Kommentatoren 31.9k Aufrufe 6 Beobachtet
  • stefu87_CHS stefu87_CH
    @djmarc75 sagte in Ganze Iobroker Version läuft langsam:
    @stefu87_ch sagte in Ganze Iobroker Version läuft langsam:
    obwohl ich alles so eingestellt habe wie es vor kurzem in den Foren angegeben wurde.
    Anscheinend aber nicht.
    iobroker update -i
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "birthdays"    : 2.0.0    , installed 2.0.0
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "countdown"    : 1.2.5    , installed 1.2.5
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.1.7    , installed 2.1.7
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.8
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "parser"       : 1.1.7    , installed 1.1.7
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "snmp"         : 1.0.0    , installed 1.0.0
    Adapter    "sql"          : 2.1.7    , installed 2.1.7
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "trashschedule": 2.0.2    , installed 2.0.2
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #164
    @stefu87_ch
    Sicher nicht aus einem Backup zurückgespielt ?
    Mal ehrlich, erstmal das Grundsystem ans Laufen bringen und dann diese Flut an Adaptern installieren ist besser.
    Weiss jetzt nicht genau ob der WS da nicht wieder reinfunkt.
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
      @stefu87_ch
      stefu87_CHS Offline
      stefu87_CHS Offline
      stefu87_CH
      #165
      @stefu87_ch
      Ja da bin ich mir sicher.
      Hab ein komplett neues Iobroker aufgesetzt und dann die Adapter einzeln installiert, und immer wieder kontrolliert, ob er langsamer wird. Bis jetzt läuft er einwandfrei ohne Time-Out Problemen. Ist sehr flüssig.
      Cores: 1 × 8 = 8 cores
      Threads: 16
      mit Proxmox
      LXC Container mit Iobroker
        @stefu87_ch
        GlasfaserG Offline
        GlasfaserG Offline
        #166
        @stefu87_ch
        Hast du NodeJS 14 gelassen !?
        • GlasfaserG Glasfaser
          @stefu87_ch
          stefu87_CHS Offline
          stefu87_CHS Offline
          stefu87_CH
          #167
          @glasfaser sagte in Ganze Iobroker Version läuft langsam:
          @stefu87_ch
          Ja
          pt policy nodejs
          x86_64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.20.0
          v14.20.0
          6.14.17
          root
          /opt/iobroker
          Hit:1 https://deb.nodesource.com/node_14.x bionic InRelease
          Hit:2 http://archive.ubuntu.com/ubuntu bionic InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu bionic-security InRelease
          Reading package lists... Done
          Building dependency tree
          All packages are up to date.
          nodejs:
            Installed: 14.20.0-1nodesource1
            Candidate: 14.20.0-1nodesource1
            Version table:
           *** 14.20.0-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bionic/main amd64 Packages
               8.10.0~dfsg-2ubuntu0.4 500
                  500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
               8.10.0~dfsg-2ubuntu0.2 500
                  500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
               8.10.0~dfsg-2 500
                  500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
          Threads: 16
          mit Proxmox
          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
            @stefu87_ch
            Ja
            pt policy nodejs
            x86_64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.20.0
            v14.20.0
            6.14.17
            root
            /opt/iobroker
            nodejs:
              Version table:
                 8.10.0~dfsg-2 500
            GlasfaserG Offline
            GlasfaserG Offline
            #168
            @stefu87_ch
            Weil ... das kommt mit langsam so vor als liege es daran , denn
            ich habe noch nie Probleme gehabt und bin noch bei Nodejs14
            DJMarc75D stefu87_CHS 2 Antworten Letzte Antwort
              @stefu87_ch
              Ja
              pt policy nodejs
              x86_64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.20.0
              v14.20.0
              6.14.17
              root
              /opt/iobroker
              nodejs:
                Version table:
                   8.10.0~dfsg-2 500
              #169
              @stefu87_ch
              Und waum hast du es jetzt immer noch nicht geschafft einen user anzulegen und den Scheiß-root-Acount in Ruhe zu lassen?
                @stefu87_ch
                stefu87_CHS Offline
                stefu87_CHS Offline
                stefu87_CH
                #170
                @thomas-braun sagte in Ganze Iobroker Version läuft langsam:
                @stefu87_ch
                Wenn er wirklich komplett sauber läuft und einwandfrei ist, dann werd ich das sofort tun. Hab das ja jetzt gelernt
                Threads: 16
                mit Proxmox
                  @stefu87_ch
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  #171
                  Ja, das scheint mal so und mal so zu sein.
                  Ich habe weder auf der 14 noch auf der 16 Probleme und bei beiden Systemen eingebautes simple-api aktiviert.
                  spooky 👻
                    @stefu87_ch
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #172
                    @stefu87_ch
                    Nimm mal meine Einstellungen vom Web Adapter
                      @stefu87_ch
                      stefu87_CHS Offline
                      stefu87_CHS Offline
                      stefu87_CH
                      #173
                      @stefu87_ch
                      Wieso hast du V 5.2.4 ? Hab nur V4.3.0
                      Threads: 16
                      mit Proxmox
                        @stefu87_ch
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #174
                        Bin im BETA ;) ... das darf ich
                          @stefu87_ch
                          #175
                          Ja offenbar nicht. Du hast das Ding doch jetzt komplett neuaufgesetzt? Also warum nicht direkt von vorneherein richtig?
                            spooky 👻
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #176
                            spooky
                            Ja das sehe ich auch ..
                            aber das sind aber meist diejenigen die sich was auf das System kloppen ohne zu wissen was sie da machen !
                            UND
                            mit Root alles durcheinander bringen ... das sieht man jetzt ganz deutlich seit NodeJS 16 .
                              stefu87_CHS Offline
                              stefu87_CHS Offline
                              stefu87_CH
                              #177
                              Damit du dich jetzt wohler fühlst, hab ich jetzt einen neuen Benutzer angelegt.
                              Threads: 16
                              mit Proxmox
                                stefu87_CHS Offline
                                stefu87_CHS Offline
                                stefu87_CH
                                #178
                                Hab jetzt alles wie du eingestellt, aber bei mir passiert nichts mit dem Import. Auch die Meldung erscheint nicht.
                                Ist ja richtig über diesen Import
                                Threads: 16
                                mit Proxmox
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #179
                                  Nee ... nicht falsch verstehen !!!
                                  Es geht darum ...
                                  WIR helfen dir ... dann sollte von Anfang bis Ende alles richtig sein ... sonst bringt das nichts ... und der Thread wird ENDLOS lang .
                                    spooky
                                    UND
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #180
                                    ich muss gestehen, ich weiß bis heute nicht wie ich mich als ROOT einlogge... dank sauberer Anleitungen und Raspberrys.
                                    Hoffe ich werde jetzt nicht geächtet, weil das mit dem ROOT ja anscheinend Mode ist 😀
                                    Fairnesshalber muss man aber auch sagen dass wohl auf manchen Maschinen ROOT schon fast Pflicht ist - Synology war das glaub ich ??!! Kann mich aber auch täuschen - ist sehr, sehr warm heute 😰
                                    Aber zurück zum "Verbindungsfehler"
                                    @stefu87_CH haste die Einstellungen von @Glasfaser mal getestet ?
                                    stefu87_CHS GlasfaserG 2 Antworten Letzte Antwort
                                      #181
                                      Wegen mir musst du da nicht machen. DU hast da ein Problem.
                                      Und nicht nur anlegen, auch verwenden.
                                        stefu87_CHS Offline
                                        stefu87_CHS Offline
                                        stefu87_CH
                                        #182
                                        Ja hab ich genau auch so:
                                        Threads: 16
                                        mit Proxmox
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #183
                                          Das habe ich schon im Chat gesten mit Thomas besprochen ... der Root innerhalb des Containers wird zu ioBroker per Start-Script geändert
                                          DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
