  4. Ganze Iobroker Version läuft langsam
    5.8k
286 Beiträge 8 Kommentatoren 31.9k Aufrufe 6 Beobachtet
  • DJMarc75D DJMarc75
    @stefu87_ch sagte in Ganze Iobroker Version läuft langsam:
    obwohl ich alles so eingestellt habe wie es vor kurzem in den Foren angegeben wurde.
    Anscheinend aber nicht.
    iobroker update -i
    stefu87_CHS Offline
    stefu87_CHS Offline
    stefu87_CH
    #163
    @djmarc75 sagte in Ganze Iobroker Version läuft langsam:
    iobroker update -i
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "birthdays"    : 2.0.0    , installed 2.0.0
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "countdown"    : 1.2.5    , installed 1.2.5
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.1.7    , installed 2.1.7
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.8
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "parser"       : 1.1.7    , installed 1.1.7
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "snmp"         : 1.0.0    , installed 1.0.0
    Adapter    "sql"          : 2.1.7    , installed 2.1.7
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "trashschedule": 2.0.2    , installed 2.0.2
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Cores: 1 × 8 = 8 cores
    Threads: 16
    mit Proxmox
    LXC Container mit Iobroker
    • stefu87_CHS stefu87_CH
      iobroker update -i
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #164
      @stefu87_ch
      Sicher nicht aus einem Backup zurückgespielt ?
      Mal ehrlich, erstmal das Grundsystem ans Laufen bringen und dann diese Flut an Adaptern installieren ist besser.
      Weiss jetzt nicht genau ob der WS da nicht wieder reinfunkt.
      Lehrling seit 1975 !!!
        @stefu87_ch
        stefu87_CHS Offline
        stefu87_CHS Offline
        stefu87_CH
        #165
        @stefu87_ch
        Ja da bin ich mir sicher.
        Hab ein komplett neues Iobroker aufgesetzt und dann die Adapter einzeln installiert, und immer wieder kontrolliert, ob er langsamer wird. Bis jetzt läuft er einwandfrei ohne Time-Out Problemen. Ist sehr flüssig.
        Threads: 16
        mit Proxmox
          @stefu87_ch
          GlasfaserG Offline
          GlasfaserG Offline
          #166
          @stefu87_ch
          Hast du NodeJS 14 gelassen !?
          • GlasfaserG Glasfaser
            @stefu87_ch
            stefu87_CHS Offline
            stefu87_CHS Offline
            stefu87_CH
            #167
            @glasfaser sagte in Ganze Iobroker Version läuft langsam:
            @stefu87_ch
            Ja
            pt policy nodejs
            x86_64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.20.0
            v14.20.0
            6.14.17
            root
            /opt/iobroker
            Hit:1 https://deb.nodesource.com/node_14.x bionic InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu bionic InRelease
            Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
            Hit:4 http://archive.ubuntu.com/ubuntu bionic-security InRelease
            Reading package lists... Done
            Building dependency tree
            All packages are up to date.
            nodejs:
              Installed: 14.20.0-1nodesource1
              Candidate: 14.20.0-1nodesource1
              Version table:
             *** 14.20.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x bionic/main amd64 Packages
                 8.10.0~dfsg-2ubuntu0.4 500
                    500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                 8.10.0~dfsg-2ubuntu0.2 500
                    500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                 8.10.0~dfsg-2 500
                    500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
            Threads: 16
            mit Proxmox
            GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
              @stefu87_ch
              Ja
              pt policy nodejs
              x86_64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.20.0
              v14.20.0
              6.14.17
              root
              /opt/iobroker
              nodejs:
                Version table:
                   8.10.0~dfsg-2 500
              GlasfaserG Offline
              GlasfaserG Offline
              #168
              @stefu87_ch
              Weil ... das kommt mit langsam so vor als liege es daran , denn
              ich habe noch nie Probleme gehabt und bin noch bei Nodejs14
              DJMarc75D stefu87_CHS 2 Antworten Letzte Antwort
                @stefu87_ch
                Ja
                pt policy nodejs
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.20.0
                v14.20.0
                6.14.17
                root
                /opt/iobroker
                nodejs:
                  Version table:
                     8.10.0~dfsg-2 500
                #169
                @stefu87_ch
                Und waum hast du es jetzt immer noch nicht geschafft einen user anzulegen und den Scheiß-root-Acount in Ruhe zu lassen?
                  @stefu87_ch
                  stefu87_CHS Offline
                  stefu87_CHS Offline
                  stefu87_CH
                  #170
                  @thomas-braun sagte in Ganze Iobroker Version läuft langsam:
                  @stefu87_ch
                  Wenn er wirklich komplett sauber läuft und einwandfrei ist, dann werd ich das sofort tun. Hab das ja jetzt gelernt
                  Threads: 16
                  mit Proxmox
                    @stefu87_ch
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #171
                    Ja, das scheint mal so und mal so zu sein.
                    Ich habe weder auf der 14 noch auf der 16 Probleme und bei beiden Systemen eingebautes simple-api aktiviert.
                    spooky 👻
                      @stefu87_ch
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #172
                      @stefu87_ch
                      Nimm mal meine Einstellungen vom Web Adapter
                        @stefu87_ch
                        stefu87_CHS Offline
                        stefu87_CHS Offline
                        stefu87_CH
                        #173
                        @stefu87_ch
                        Wieso hast du V 5.2.4 ? Hab nur V4.3.0
                        Threads: 16
                        mit Proxmox
                          @stefu87_ch
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #174
                          Bin im BETA ;) ... das darf ich
                            @stefu87_ch
                            #175
                            Ja offenbar nicht. Du hast das Ding doch jetzt komplett neuaufgesetzt? Also warum nicht direkt von vorneherein richtig?
                              spooky 👻
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #176
                              spooky
                              Ja das sehe ich auch ..
                              aber das sind aber meist diejenigen die sich was auf das System kloppen ohne zu wissen was sie da machen !
                              UND
                              mit Root alles durcheinander bringen ... das sieht man jetzt ganz deutlich seit NodeJS 16 .
                                stefu87_CHS Offline
                                stefu87_CHS Offline
                                stefu87_CH
                                #177
                                Damit du dich jetzt wohler fühlst, hab ich jetzt einen neuen Benutzer angelegt.
                                Threads: 16
                                mit Proxmox
                                  stefu87_CHS Offline
                                  stefu87_CHS Offline
                                  stefu87_CH
                                  #178
                                  Hab jetzt alles wie du eingestellt, aber bei mir passiert nichts mit dem Import. Auch die Meldung erscheint nicht.
                                  Ist ja richtig über diesen Import
                                  Threads: 16
                                  mit Proxmox
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #179
                                    Nee ... nicht falsch verstehen !!!
                                    Es geht darum ...
                                    WIR helfen dir ... dann sollte von Anfang bis Ende alles richtig sein ... sonst bringt das nichts ... und der Thread wird ENDLOS lang .
                                      spooky
                                      UND
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #180
                                      ich muss gestehen, ich weiß bis heute nicht wie ich mich als ROOT einlogge... dank sauberer Anleitungen und Raspberrys.
                                      Hoffe ich werde jetzt nicht geächtet, weil das mit dem ROOT ja anscheinend Mode ist 😀
                                      Fairnesshalber muss man aber auch sagen dass wohl auf manchen Maschinen ROOT schon fast Pflicht ist - Synology war das glaub ich ??!! Kann mich aber auch täuschen - ist sehr, sehr warm heute 😰
                                      Aber zurück zum "Verbindungsfehler"
                                      @stefu87_CH haste die Einstellungen von @Glasfaser mal getestet ?
                                      stefu87_CHS GlasfaserG 2 Antworten Letzte Antwort
                                        #181
                                        Wegen mir musst du da nicht machen. DU hast da ein Problem.
                                        Und nicht nur anlegen, auch verwenden.
                                          stefu87_CHS Offline
                                          stefu87_CHS Offline
                                          stefu87_CH
                                          #182
                                          Ja hab ich genau auch so:
                                          Threads: 16
                                          mit Proxmox
