  2. English
  3. ioBroker general
  4. Zigbee adapter stopped running
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
zigbee
43 Beiträge 5 Kommentatoren 9.5k Aufrufe 5 Beobachtet
  • T tritor
    @thomas-braun sagte in Zigbee adapter stopped running:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2483232-if00
    👍 perfect - works, hope I get rid of the issue when restarting
    at the CUL Adapter I guess there is no chance to set the by-id entry as there is only a selection field in the settings which can't be overwritten.
    any idea how to solve that one?
    sorry for hijacking to CUL
    @tritor
    I don't know the cul-Adapter.
    • T tritor
      arteckA Offline
      arteckA Offline
      arteck
      @tritor
      /dev/serial/by-id/usb-busware.de_CUL868-if00
      maybe
        @ap2017 sagte in Zigbee adapter stopped running:
        This 'problem' is exactly the reason why you should never set /dev/ttyDEVICE but always the link that you find in /dev/serial/by-id
        /dev/ttyDEVICE is generated during system start and may change at anytime, the link in /dev/serial/by-id will always point to the correct hardware.
        ap2017
        schrieb am zuletzt editiert von ap2017
        Thanks, but ACM1 is not shown on /dev/serial/by-id despite that it was set in ZigBee adapter and was operational that way for long time. Do I need to reconfigure other serial ports by-id first?
        • arteckA arteck
          lrwxrwxrwx 1 root root 13 Jul 13 14:06 usb-0658_0200-if00 -> ../../ttyACM0
          lrwxrwxrwx 1 root root 13 Jul 13 14:05 usb-1a86_USB2.0-Serial-if00-port0 -> ../../ttyUSB0
          where is here your selected port ttyACM1 ???
          ap2017
          @arteck That is my question too. I am calling for it in adapter configuration. It was working like this for long time.
          7f2db5f6-a629-4fe1-a01f-57f0de0147d8-image.png usb-0658_0200-if00
          • A ap2017
            @ap2017
            It the other way round...
            Setting ACM1 in the adapter means nothing in the 'real world' of the Operating System.
            The linux kernel and/or systemd decides where your devices end up in /dev/tty* and sets the correct link in /dev/serial/by-id pointing to the device.
            So you need to find out which of your two devices in /dev/serial/by-id is the ZigBee Adapter. Try and Error. I think it is the second entry.
            BTW: Set da different Extended PAN-Id. The one you use is too simple and only a place holder for an individual Id .
            A 2 Antworten Letzte Antwort
              @ap2017
              ap2017
              The serial ports currently shown in serial/by-id are for MySensors Adapter and Zwave adapter, both are working fine. The whole point is that Zigbee is missing there. but shown in npm list serialport
              BTW: what is Extended PAN-Id?
              • A ap2017
                The DDDDDDDDDDDDD setting. Extended PAN-Id written next to it...
                If the two entries in /dev/serial/by-id are not your zigbee-stick, then it is completely unrecognized by your system. Maybe a hardware defect?
                Check
                dmesg -T
                for any USB related messages.
                  Check
                  dmesg -T
                  ap2017
                  Sorry, still not following regarding PAN-id
                  Here is dmesg -T log:
                  ap@AP-Tiny:~$ dmesg -T
                  [Wed Jul 13 22:32:23 2022] microcode: microcode updated early to revision 0x21, date = 2019-02-13
                  [Wed Jul 13 22:32:23 2022] Linux version 4.15.0-65-generic (buildd@lgw01-amd64-006) (gcc version 7.4.0 (Ubuntu 7.4.0-1ubuntu1~18.04.1)) #74-Ubuntu SMP Tue Sep 17 17:06:04 UTC 2019 (Ubuntu 4.15.0-65.74-generic 4.15.18)
                  [Wed Jul 13 22:32:23 2022] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-65-generic root=UUID=39ad14a9-18b9-9e8d-0a54-4e90d6154d7f ro quiet splash vt.handoff=1
                  [Wed Jul 13 22:32:23 2022] KERNEL supported cpus:
                  [Wed Jul 13 22:32:23 2022]   Intel GenuineIntel
                  [Wed Jul 13 22:32:23 2022]   AMD AuthenticAMD
                  [Wed Jul 13 22:32:23 2022]   Centaur CentaurHauls
                  [Wed Jul 13 22:32:23 2022] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
                  [Wed Jul 13 22:32:23 2022] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
                  [Wed Jul 13 22:32:23 2022] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
                  [Wed Jul 13 22:32:23 2022] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
                  [Wed Jul 13 22:32:23 2022] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
                  [Wed Jul 13 22:32:23 2022] e820: BIOS-provided physical RAM map:
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x0000000040005000-0x00000000d54e4fff] usable
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d54e5000-0x00000000d5807fff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d5808000-0x00000000d5819fff] ACPI data
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d581a000-0x00000000d61eefff] ACPI NVS
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d61ef000-0x00000000d681cfff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d681d000-0x00000000d681dfff] usable
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d681e000-0x00000000d6860fff] ACPI NVS
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d6861000-0x00000000d6c6bfff] usable
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d6c6c000-0x00000000d6ff2fff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d6ff3000-0x00000000d6ffffff] usable
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000d7000000-0x00000000df9fffff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
                  [Wed Jul 13 22:32:23 2022] BIOS-e820: [mem 0x0000000100000000-0x000000011f5fffff] usable
                  [Wed Jul 13 22:32:23 2022] NX (Execute Disable) protection: active
                  [Wed Jul 13 22:32:23 2022] SMBIOS 2.7 present.
                  [Wed Jul 13 22:32:23 2022] DMI: LENOVO 4004H1U/MAHOBAY, BIOS F4KT61AUS 07/16/2018
                  [Wed Jul 13 22:32:23 2022] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
                  [Wed Jul 13 22:32:23 2022] e820: remove [mem 0x000a0000-0x000fffff] usable
                  [Wed Jul 13 22:32:23 2022] e820: last_pfn = 0x11f600 max_arch_pfn = 0x400000000
                  [Wed Jul 13 22:32:23 2022] MTRR default type: uncachable
                  [Wed Jul 13 22:32:23 2022] MTRR fixed ranges enabled:
                  [Wed Jul 13 22:32:23 2022]   00000-9FFFF write-back
                  [Wed Jul 13 22:32:23 2022]   A0000-BFFFF uncachable
                  [Wed Jul 13 22:32:23 2022]   C0000-CFFFF write-protect
                  [Wed Jul 13 22:32:23 2022]   D0000-E7FFF uncachable
                  [Wed Jul 13 22:32:23 2022]   E8000-FFFFF write-protect
                  [Wed Jul 13 22:32:23 2022] MTRR variable ranges enabled:
                  [Wed Jul 13 22:32:23 2022]   0 base 000000000 mask F00000000 write-back
                  [Wed Jul 13 22:32:23 2022]   1 base 100000000 mask FE0000000 write-back
                  [Wed Jul 13 22:32:23 2022]   2 base 0E0000000 mask FE0000000 uncachable
                  [Wed Jul 13 22:32:23 2022]   3 base 0D8000000 mask FF8000000 uncachable
                  [Wed Jul 13 22:32:23 2022]   4 base 0D7800000 mask FFF800000 uncachable
                  [Wed Jul 13 22:32:23 2022]   5 base 11F800000 mask FFF800000 uncachable
                  [Wed Jul 13 22:32:23 2022]   6 base 11F600000 mask FFFE00000 uncachable
                  [Wed Jul 13 22:32:23 2022]   7 disabled
                  [Wed Jul 13 22:32:23 2022]   8 disabled
                  [Wed Jul 13 22:32:23 2022]   9 disabled
                  [Wed Jul 13 22:32:23 2022] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
                  [Wed Jul 13 22:32:23 2022] total RAM covered: 3950M
                  [Wed Jul 13 22:32:23 2022] Found optimal setting for mtrr clean up
                  [Wed Jul 13 22:32:23 2022]  gran_size: 64K      chunk_size: 16M         num_reg: 8      lose cover RAM: 0G
                  [Wed Jul 13 22:32:23 2022] e820: update [mem 0xd7800000-0xffffffff] usable ==> reserved
                  [Wed Jul 13 22:32:23 2022] e820: last_pfn = 0xd7000 max_arch_pfn = 0x400000000
                  [Wed Jul 13 22:32:23 2022] found SMP MP-table at [mem 0x000fcf30-0x000fcf3f]
                  [Wed Jul 13 22:32:23 2022] Scanning 1 areas for low memory corruption
                  [Wed Jul 13 22:32:23 2022] BRK [0x111541000, 0x111541fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x111542000, 0x111542fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x111543000, 0x111543fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x111544000, 0x111544fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x111545000, 0x111545fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x111546000, 0x111546fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x111547000, 0x111547fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x111548000, 0x111548fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x111549000, 0x111549fff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x11154a000, 0x11154afff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x11154b000, 0x11154bfff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] BRK [0x11154c000, 0x11154cfff] PGTABLE
                  [Wed Jul 13 22:32:23 2022] RAMDISK: [mem 0x30819000-0x34403fff]
                  [Wed Jul 13 22:32:23 2022] ACPI: Early table checksum verification disabled
                  [Wed Jul 13 22:32:23 2022] ACPI: RSDP 0x00000000000F0450 000024 (v02 LENOVO)
                  [Wed Jul 13 22:32:23 2022] ACPI: XSDT 0x00000000D580B080 000084 (v01 LENOVO TC-F4    0000013D AMI  00010013)
                  [Wed Jul 13 22:32:23 2022] ACPI: FACP 0x00000000D58177F0 0000F4 (v04 LENOVO TC-F4    0000013D AMI  00010013)
                  [Wed Jul 13 22:32:23 2022] ACPI: DSDT 0x00000000D580B198 00C656 (v02 LENOVO TC-F4    0000013D INTL 20051117)
                  [Wed Jul 13 22:32:23 2022] ACPI: FACS 0x00000000D61EDF80 000040
                  [Wed Jul 13 22:32:23 2022] ACPI: APIC 0x00000000D58178E8 000072 (v03 LENOVO TC-F4    0000013D AMI  00010013)
                  [Wed Jul 13 22:32:23 2022] ACPI: FPDT 0x00000000D5817960 000044 (v01 LENOVO TC-F4    0000013D AMI  00010013)
                  [Wed Jul 13 22:32:23 2022] ACPI: ASF! 0x00000000D58179A8 0000A5 (v32 LENOVO TC-F4    0000013D TFSM 000F4240)
                  [Wed Jul 13 22:32:23 2022] ACPI: MCFG 0x00000000D5817A50 00003C (v01 LENOVO TC-F4    0000013D MSFT 00000097)
                  [Wed Jul 13 22:32:23 2022] ACPI: SLIC 0x00000000D5817A90 000176 (v01 LENOVO TC-F4    0000013D AMI  00010013)
                  [Wed Jul 13 22:32:23 2022] ACPI: MSDM 0x00000000D5817C08 000055 (v03 LENOVO TC-F4    0000013D AMI  00010013)
                  [Wed Jul 13 22:32:23 2022] ACPI: HPET 0x00000000D5817C60 000038 (v01 LENOVO TC-F4    0000013D AMI. 00000005)
                  [Wed Jul 13 22:32:23 2022] ACPI: SSDT 0x00000000D5817C98 00036D (v01 LENOVO TC-F4    0000013D INTL 20091112)
                  [Wed Jul 13 22:32:23 2022] ACPI: SSDT 0x00000000D5818008 0008E4 (v01 LENOVO TC-F4    0000013D INTL 20051117)
                  [Wed Jul 13 22:32:23 2022] ACPI: SSDT 0x00000000D58188F0 000B22 (v01 LENOVO TC-F4    0000013D INTL 20051117)
                  [Wed Jul 13 22:32:23 2022] ACPI: BGRT 0x00000000D5819418 000038 (v00 LENOVO TC-F4    0000013D AMI  00010013)
                  [Wed Jul 13 22:32:23 2022] ACPI: Local APIC address 0xfee00000
                  [Wed Jul 13 22:32:23 2022] No NUMA configuration found
                  [Wed Jul 13 22:32:23 2022] Faking a node at [mem 0x0000000000000000-0x000000011f5fffff]
                  [Wed Jul 13 22:32:23 2022] NODE_DATA(0) allocated [mem 0x11f5d4000-0x11f5fefff]
                  [Wed Jul 13 22:32:23 2022] tsc: Fast TSC calibration using PIT
                  [Wed Jul 13 22:32:23 2022] Zone ranges:
                  [Wed Jul 13 22:32:23 2022]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
                  [Wed Jul 13 22:32:23 2022]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
                  [Wed Jul 13 22:32:23 2022]   Normal   [mem 0x0000000100000000-0x000000011f5fffff]
                  [Wed Jul 13 22:32:23 2022]   Device   empty
                  [Wed Jul 13 22:32:23 2022] Movable zone start for each node
                  [Wed Jul 13 22:32:23 2022] Early memory node ranges
                  [Wed Jul 13 22:32:23 2022]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
                  [Wed Jul 13 22:32:23 2022]   node   0: [mem 0x0000000000100000-0x000000001fffffff]
                  [Wed Jul 13 22:32:23 2022]   node   0: [mem 0x0000000020200000-0x0000000040003fff]
                  [Wed Jul 13 22:32:23 2022]   node   0: [mem 0x0000000040005000-0x00000000d54e4fff]
                  [Wed Jul 13 22:32:23 2022]   node   0: [mem 0x00000000d681d000-0x00000000d681dfff]
                  [Wed Jul 13 22:32:23 2022]   node   0: [mem 0x00000000d6861000-0x00000000d6c6bfff]
                  [Wed Jul 13 22:32:23 2022]   node   0: [mem 0x00000000d6ff3000-0x00000000d6ffffff]
                  [Wed Jul 13 22:32:23 2022]   node   0: [mem 0x0000000100000000-0x000000011f5fffff]
                  [Wed Jul 13 22:32:23 2022] Reserved but unavailable: 100 pages
                  [Wed Jul 13 22:32:23 2022] Initmem setup node 0 [mem 0x0000000000001000-0x000000011f5fffff]
                  [Wed Jul 13 22:32:23 2022] On node 0 totalpages: 1002649
                  [Wed Jul 13 22:32:23 2022]   DMA zone: 64 pages used for memmap
                  [Wed Jul 13 22:32:23 2022]   DMA zone: 21 pages reserved
                  [Wed Jul 13 22:32:23 2022]   DMA zone: 3996 pages, LIFO batch:0
                  [Wed Jul 13 22:32:23 2022]   DMA32 zone: 13596 pages used for memmap
                  [Wed Jul 13 22:32:23 2022]   DMA32 zone: 870141 pages, LIFO batch:31
                  [Wed Jul 13 22:32:23 2022]   Normal zone: 2008 pages used for memmap
                  [Wed Jul 13 22:32:23 2022]   Normal zone: 128512 pages, LIFO batch:31
                  [Wed Jul 13 22:32:23 2022] Reserving Intel graphics memory at 0x00000000d7a00000-0x00000000df9fffff
                  [Wed Jul 13 22:32:23 2022] ACPI: PM-Timer IO Port: 0x408
                  [Wed Jul 13 22:32:23 2022] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
                  [Wed Jul 13 22:32:23 2022] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
                  [Wed Jul 13 22:32:23 2022] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
                  [Wed Jul 13 22:32:23 2022] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
                  [Wed Jul 13 22:32:23 2022] ACPI: IRQ0 used by override.
                  [Wed Jul 13 22:32:23 2022] ACPI: IRQ9 used by override.
                  [Wed Jul 13 22:32:23 2022] Using ACPI (MADT) for SMP configuration information
                  [Wed Jul 13 22:32:23 2022] ACPI: HPET id: 0x8086a701 base: 0xfed00000
                  [Wed Jul 13 22:32:23 2022] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0x40004000-0x40004fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xd54e5000-0xd5807fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xd5808000-0xd5819fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xd581a000-0xd61eefff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xd61ef000-0xd681cfff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xd681e000-0xd6860fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xd6c6c000-0xd6ff2fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xd7000000-0xdf9fffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
                  [Wed Jul 13 22:32:23 2022] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
                  [Wed Jul 13 22:32:23 2022] e820: [mem 0xdfa00000-0xf7ffffff] available for PCI devices
                  [Wed Jul 13 22:32:23 2022] Booting paravirtualized kernel on bare hardware
                  [Wed Jul 13 22:32:23 2022] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
                  [Wed Jul 13 22:32:23 2022] random: get_random_bytes called from start_kernel+0x99/0x4fd with crng_init=0
                  [Wed Jul 13 22:32:23 2022] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
                  [Wed Jul 13 22:32:23 2022] percpu: Embedded 46 pages/cpu s151552 r8192 d28672 u524288
                  [Wed Jul 13 22:32:23 2022] pcpu-alloc: s151552 r8192 d28672 u524288 alloc=1*2097152
                  [Wed Jul 13 22:32:23 2022] pcpu-alloc: [0] 0 1 2 3
                  [Wed Jul 13 22:32:23 2022] Built 1 zonelists, mobility grouping on.  Total pages: 986960
                  [Wed Jul 13 22:32:23 2022] Policy zone: Normal
                  [Wed Jul 13 22:32:23 2022] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-65-generic root=UUID=39ad14a9-18b9-9e8d-0a54-4e90d6154d7f ro quiet splash vt.handoff=1
                  [Wed Jul 13 22:32:23 2022] Calgary: detecting Calgary via BIOS EBDA area
                  [Wed Jul 13 22:32:23 2022] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
                  [Wed Jul 13 22:32:23 2022] Memory: 3790792K/4010596K available (12300K kernel code, 2481K rwdata, 4256K rodata, 2436K init, 2388K bss, 219804K reserved, 0K cma-reserved)
                  [Wed Jul 13 22:32:23 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                  [Wed Jul 13 22:32:23 2022] Kernel/User page tables isolation: enabled
                  [Wed Jul 13 22:32:23 2022] ftrace: allocating 39301 entries in 154 pages
                  [Wed Jul 13 22:32:23 2022] Hierarchical RCU implementation.
                  [Wed Jul 13 22:32:23 2022]      RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
                  [Wed Jul 13 22:32:23 2022]      Tasks RCU enabled.
                  [Wed Jul 13 22:32:23 2022] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                  [Wed Jul 13 22:32:23 2022] NR_IRQS: 524544, nr_irqs: 456, preallocated irqs: 16
                  [Wed Jul 13 22:32:23 2022] spurious 8259A interrupt: IRQ7.
                  [Wed Jul 13 22:32:23 2022] vt handoff: transparent VT on vt#1
                  [Wed Jul 13 22:32:23 2022] Console: colour dummy device 80x25
                  [Wed Jul 13 22:32:23 2022] console [tty0] enabled
                  [Wed Jul 13 22:32:23 2022] ACPI: Core revision 20170831
                  [Wed Jul 13 22:32:23 2022] ACPI: 4 ACPI AML tables successfully acquired and loaded
                  [Wed Jul 13 22:32:23 2022] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
                  [Wed Jul 13 22:32:23 2022] hpet clockevent registered
                  [Wed Jul 13 22:32:23 2022] APIC: Switch to symmetric I/O mode setup
                  [Wed Jul 13 22:32:23 2022] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
                  [Wed Jul 13 22:32:23 2022] tsc: Detected 2793.672 MHz processor
                  [Wed Jul 13 22:32:23 2022] Calibrating delay loop (skipped), value calculated using timer frequency.. 5587.34 BogoMIPS (lpj=11174688)
                  [Wed Jul 13 22:32:23 2022] pid_max: default: 32768 minimum: 301
                  [Wed Jul 13 22:32:23 2022] Security Framework initialized
                  [Wed Jul 13 22:32:23 2022] Yama: becoming mindful.
                  [Wed Jul 13 22:32:23 2022] AppArmor: AppArmor initialized
                  [Wed Jul 13 22:32:23 2022] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
                  [Wed Jul 13 22:32:23 2022] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
                  [Wed Jul 13 22:32:23 2022] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
                  [Wed Jul 13 22:32:23 2022] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
                  [Wed Jul 13 22:32:23 2022] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
                  [Wed Jul 13 22:32:23 2022] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
                  [Wed Jul 13 22:32:23 2022] CPU0: Thermal monitoring enabled (TM1)
                  [Wed Jul 13 22:32:23 2022] process: using mwait in idle threads
                  [Wed Jul 13 22:32:23 2022] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
                  [Wed Jul 13 22:32:23 2022] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
                  [Wed Jul 13 22:32:23 2022] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
                  [Wed Jul 13 22:32:23 2022] Spectre V2 : Mitigation: Full generic retpoline
                  [Wed Jul 13 22:32:23 2022] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
                  [Wed Jul 13 22:32:23 2022] Spectre V2 : Enabling Restricted Speculation for firmware calls
                  [Wed Jul 13 22:32:23 2022] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
                  [Wed Jul 13 22:32:23 2022] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
                  [Wed Jul 13 22:32:23 2022] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
                  [Wed Jul 13 22:32:23 2022] MDS: Mitigation: Clear CPU buffers
                  [Wed Jul 13 22:32:23 2022] Freeing SMP alternatives memory: 36K
                  [Wed Jul 13 22:32:23 2022] TSC deadline timer enabled
                  [Wed Jul 13 22:32:23 2022] smpboot: CPU0: Intel(R) Core(TM) i3-3220T CPU @ 2.80GHz (family: 0x6, model: 0x3a, stepping: 0x9)
                  [Wed Jul 13 22:32:23 2022] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
                  [Wed Jul 13 22:32:23 2022] ... version:                3
                  [Wed Jul 13 22:32:23 2022] ... bit width:              48
                  [Wed Jul 13 22:32:23 2022] ... generic registers:      4
                  [Wed Jul 13 22:32:23 2022] ... value mask:             0000ffffffffffff
                  [Wed Jul 13 22:32:23 2022] ... max period:             00007fffffffffff
                  [Wed Jul 13 22:32:23 2022] ... fixed-purpose events:   3
                  [Wed Jul 13 22:32:23 2022] ... event mask:             000000070000000f
                  [Wed Jul 13 22:32:23 2022] Hierarchical SRCU implementation.
                  [Wed Jul 13 22:32:23 2022] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
                  [Wed Jul 13 22:32:23 2022] smp: Bringing up secondary CPUs ...
                  [Wed Jul 13 22:32:23 2022] x86: Booting SMP configuration:
                  [Wed Jul 13 22:32:23 2022] .... node  #0, CPUs:      #1 #2
                  [Wed Jul 13 22:32:23 2022] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
                  [Wed Jul 13 22:32:23 2022]  #3
                  [Wed Jul 13 22:32:23 2022] smp: Brought up 1 node, 4 CPUs
                  [Wed Jul 13 22:32:23 2022] smpboot: Max logical packages: 1
                  [Wed Jul 13 22:32:23 2022] smpboot: Total of 4 processors activated (22349.37 BogoMIPS)
                  [Wed Jul 13 22:32:23 2022] devtmpfs: initialized
                  [Wed Jul 13 22:32:23 2022] x86/mm: Memory block size: 128MB
                  [Wed Jul 13 22:32:23 2022] evm: security.selinux
                  [Wed Jul 13 22:32:23 2022] evm: security.SMACK64
                  [Wed Jul 13 22:32:23 2022] evm: security.SMACK64EXEC
                  [Wed Jul 13 22:32:23 2022] evm: security.SMACK64TRANSMUTE
                  [Wed Jul 13 22:32:23 2022] evm: security.SMACK64MMAP
                  [Wed Jul 13 22:32:23 2022] evm: security.apparmor
                  [Wed Jul 13 22:32:23 2022] evm: security.ima
                  [Wed Jul 13 22:32:23 2022] evm: security.capability
                  [Wed Jul 13 22:32:23 2022] PM: Registering ACPI NVS region [mem 0xd581a000-0xd61eefff] (10309632 bytes)
                  [Wed Jul 13 22:32:23 2022] PM: Registering ACPI NVS region [mem 0xd681e000-0xd6860fff] (274432 bytes)
                  [Wed Jul 13 22:32:23 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                  [Wed Jul 13 22:32:23 2022] futex hash table entries: 1024 (order: 4, 65536 bytes)
                  [Wed Jul 13 22:32:23 2022] pinctrl core: initialized pinctrl subsystem
                  [Wed Jul 13 22:32:23 2022] RTC time:  2:32:23, date: 07/14/22
                  [Wed Jul 13 22:32:23 2022] NET: Registered protocol family 16
                  [Wed Jul 13 22:32:23 2022] audit: initializing netlink subsys (disabled)
                  [Wed Jul 13 22:32:23 2022] audit: type=2000 audit(1657765943.040:1): state=initialized audit_enabled=0 res=1
                  [Wed Jul 13 22:32:23 2022] cpuidle: using governor ladder
                  [Wed Jul 13 22:32:23 2022] cpuidle: using governor menu
                  [Wed Jul 13 22:32:23 2022] ACPI: bus type PCI registered
                  [Wed Jul 13 22:32:23 2022] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
                  [Wed Jul 13 22:32:23 2022] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
                  [Wed Jul 13 22:32:23 2022] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
                  [Wed Jul 13 22:32:23 2022] PCI: Using configuration type 1 for base access
                  [Wed Jul 13 22:32:23 2022] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
                  [Wed Jul 13 22:32:23 2022] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
                  [Wed Jul 13 22:32:23 2022] ACPI: Added _OSI(Module Device)
                  [Wed Jul 13 22:32:23 2022] ACPI: Added _OSI(Processor Device)
                  [Wed Jul 13 22:32:23 2022] ACPI: Added _OSI(3.0 _SCP Extensions)
                  [Wed Jul 13 22:32:23 2022] ACPI: Added _OSI(Processor Aggregator Device)
                  [Wed Jul 13 22:32:23 2022] ACPI: Added _OSI(Linux-Dell-Video)
                  [Wed Jul 13 22:32:23 2022] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
                  [Wed Jul 13 22:32:23 2022] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
                  [Wed Jul 13 22:32:23 2022] ACPI: Executed 1 blocks of module-level executable AML code
                  [Wed Jul 13 22:32:23 2022] ACPI: Dynamic OEM Table Load:
                  [Wed Jul 13 22:32:23 2022] ACPI: SSDT 0xFFFFA0DE59DA7000 00083B (v01 PmRef  Cpu0Cst  00003001 INTL 20051117)
                  [Wed Jul 13 22:32:23 2022] ACPI: SSDT 0xFFFFA0DE59E19800 000303 (v01 PmRef  ApIst    00003000 INTL 20051117)
                  [Wed Jul 13 22:32:23 2022] ACPI: SSDT 0xFFFFA0DE59EE4E00 000119 (v01 PmRef  ApCst    00003000 INTL 20051117)
                  [Wed Jul 13 22:32:23 2022] ACPI: Interpreter enabled
                  [Wed Jul 13 22:32:23 2022] ACPI: (supports S0 S3 S4 S5)
                  [Wed Jul 13 22:32:23 2022] ACPI: Using IOAPIC for interrupt routing
                  [Wed Jul 13 22:32:23 2022] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
                  [Wed Jul 13 22:32:23 2022] ACPI: Enabled 16 GPEs in block 00 to 3F
                  [Wed Jul 13 22:32:23 2022] ACPI: Power Resource [FN00] (off)
                  [Wed Jul 13 22:32:23 2022] ACPI: Power Resource [FN01] (off)
                  [Wed Jul 13 22:32:23 2022] ACPI: Power Resource [FN02] (off)
                  [Wed Jul 13 22:32:23 2022] ACPI: Power Resource [FN03] (off)
                  [Wed Jul 13 22:32:23 2022] ACPI: Power Resource [FN04] (off)
                  [Wed Jul 13 22:32:23 2022] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
                  [Wed Jul 13 22:32:23 2022] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
                  [Wed Jul 13 22:32:23 2022] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
                  [Wed Jul 13 22:32:23 2022] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
                  [Wed Jul 13 22:32:23 2022] PCI host bridge to bus 0000:00
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: root bus resource [bus 00-3e]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:02.0: [8086:0152] type 00 class 0x030000
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:16.0: reg 0x10: [mem 0xf7e0a000-0xf7e0a00f 64bit]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1a.0: reg 0x10: [mem 0xf7e08000-0xf7e083ff]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1b.0: reg 0x10: [mem 0xf7e00000-0xf7e03fff 64bit]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.5: [8086:1c1a] type 01 class 0x060400
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1d.0: reg 0x10: [mem 0xf7e07000-0xf7e073ff]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.0: [8086:1c5c] type 00 class 0x060100
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.2: reg 0x10: [io  0xf0b0-0xf0b7]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.2: reg 0x14: [io  0xf0a0-0xf0a3]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.2: reg 0x18: [io  0xf090-0xf097]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.2: reg 0x1c: [io  0xf080-0xf083]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.2: reg 0x20: [io  0xf060-0xf07f]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.2: reg 0x24: [mem 0xf7e06000-0xf7e067ff]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.2: PME# supported from D3hot
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.3: reg 0x10: [mem 0xf7e05000-0xf7e050ff 64bit]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.0: PCI bridge to [bus 01]
                  [Wed Jul 13 22:32:23 2022] pci 0000:02:00.0: [8086:0895] type 00 class 0x028000
                  [Wed Jul 13 22:32:23 2022] pci 0000:02:00.0: reg 0x10: [mem 0xf7d00000-0xf7d01fff 64bit]
                  [Wed Jul 13 22:32:23 2022] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.4: PCI bridge to [bus 02]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.4:   bridge window [mem 0xf7d00000-0xf7dfffff]
                  [Wed Jul 13 22:32:23 2022] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
                  [Wed Jul 13 22:32:23 2022] pci 0000:03:00.0: reg 0x10: [io  0xe000-0xe0ff]
                  [Wed Jul 13 22:32:23 2022] pci 0000:03:00.0: reg 0x18: [mem 0xf7c00000-0xf7c00fff 64bit]
                  [Wed Jul 13 22:32:23 2022] pci 0000:03:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
                  [Wed Jul 13 22:32:23 2022] pci 0000:03:00.0: supports D1 D2
                  [Wed Jul 13 22:32:23 2022] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.5: PCI bridge to [bus 03]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.5:   bridge window [io  0xe000-0xefff]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.5:   bridge window [mem 0xf7c00000-0xf7cfffff]
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:1c.5:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 10 11 12 14 15)
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
                  [Wed Jul 13 22:32:23 2022] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 *4 5 6 10 11 12 14 15)
                  [Wed Jul 13 22:32:23 2022] SCSI subsystem initialized
                  [Wed Jul 13 22:32:23 2022] libata version 3.00 loaded.
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:02.0: vgaarb: setting as boot VGA device
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:02.0: vgaarb: bridge control possible
                  [Wed Jul 13 22:32:23 2022] vgaarb: loaded
                  [Wed Jul 13 22:32:23 2022] ACPI: bus type USB registered
                  [Wed Jul 13 22:32:23 2022] usbcore: registered new interface driver usbfs
                  [Wed Jul 13 22:32:23 2022] usbcore: registered new interface driver hub
                  [Wed Jul 13 22:32:23 2022] usbcore: registered new device driver usb
                  [Wed Jul 13 22:32:23 2022] EDAC MC: Ver: 3.0.0
                  [Wed Jul 13 22:32:23 2022] PCI: Using ACPI for IRQ routing
                  [Wed Jul 13 22:32:23 2022] PCI: pci_cache_line_size set to 64 bytes
                  [Wed Jul 13 22:32:23 2022] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
                  [Wed Jul 13 22:32:23 2022] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
                  [Wed Jul 13 22:32:23 2022] e820: reserve RAM buffer [mem 0xd54e5000-0xd7ffffff]
                  [Wed Jul 13 22:32:23 2022] e820: reserve RAM buffer [mem 0xd681e000-0xd7ffffff]
                  [Wed Jul 13 22:32:23 2022] e820: reserve RAM buffer [mem 0xd6c6c000-0xd7ffffff]
                  [Wed Jul 13 22:32:23 2022] e820: reserve RAM buffer [mem 0xd7000000-0xd7ffffff]
                  [Wed Jul 13 22:32:23 2022] e820: reserve RAM buffer [mem 0x11f600000-0x11fffffff]
                  [Wed Jul 13 22:32:23 2022] NetLabel: Initializing
                  [Wed Jul 13 22:32:23 2022] NetLabel:  domain hash size = 128
                  [Wed Jul 13 22:32:23 2022] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
                  [Wed Jul 13 22:32:23 2022] NetLabel:  unlabeled traffic allowed by default
                  [Wed Jul 13 22:32:23 2022] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
                  [Wed Jul 13 22:32:23 2022] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
                  [Wed Jul 13 22:32:23 2022] clocksource: Switched to clocksource hpet
                  [Wed Jul 13 22:32:23 2022] VFS: Disk quotas dquot_6.6.0
                  [Wed Jul 13 22:32:23 2022] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                  [Wed Jul 13 22:32:23 2022] AppArmor: AppArmor Filesystem Enabled
                  [Wed Jul 13 22:32:23 2022] pnp: PnP ACPI init
                  [Wed Jul 13 22:32:23 2022] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
                  [Wed Jul 13 22:32:23 2022] system 00:01: [io  0x0680-0x069f] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:01: [io  0x1100-0x110f] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:01: [io  0xffff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:01: [io  0x0400-0x0453] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:01: [io  0x0458-0x047f] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:01: [io  0x0500-0x057f] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:01: [io  0x164e-0x164f] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
                  [Wed Jul 13 22:32:23 2022] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
                  [Wed Jul 13 22:32:23 2022] system 00:03: [io  0x0454-0x0457] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
                  [Wed Jul 13 22:32:23 2022] system 00:04: [io  0x0a00-0x0a1f] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:04: [io  0x0a30-0x0a3f] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:04: [io  0x0a20-0x0a2f] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
                  [Wed Jul 13 22:32:23 2022] system 00:05: [io  0x04d0-0x04d1] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xf8000000-0xfbffffff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xfed90000-0xfed93fff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: [mem 0xdfa00000-0xdfa00fff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
                  [Wed Jul 13 22:32:23 2022] system 00:07: [mem 0x20000000-0x201fffff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:07: [mem 0x40004000-0x40004fff] has been reserved
                  [Wed Jul 13 22:32:23 2022] system 00:07: Plug and Play ACPI device, IDs PNP0c01 (active)
                  [Wed Jul 13 22:32:23 2022] pnp: PnP ACPI: found 8 devices
                  [Wed Jul 13 22:32:23 2022] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff window]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
                  [Wed Jul 13 22:32:23 2022] pci_bus 0000:03: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
                  [Wed Jul 13 22:32:23 2022] NET: Registered protocol family 2
                  [Wed Jul 13 22:32:23 2022] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
                  [Wed Jul 13 22:32:23 2022] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
                  [Wed Jul 13 22:32:23 2022] TCP: Hash tables configured (established 32768 bind 32768)
                  [Wed Jul 13 22:32:23 2022] UDP hash table entries: 2048 (order: 4, 65536 bytes)
                  [Wed Jul 13 22:32:23 2022] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
                  [Wed Jul 13 22:32:23 2022] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
                  [Wed Jul 13 22:32:23 2022] PCI: CLS mismatch (64 != 32), using 64 bytes
                  [Wed Jul 13 22:32:23 2022] Unpacking initramfs...
                  [Wed Jul 13 22:32:23 2022] Freeing initrd memory: 61356K
                  [Wed Jul 13 22:32:23 2022] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
                  [Wed Jul 13 22:32:23 2022] software IO TLB: mapped [mem 0xd14e5000-0xd54e5000] (64MB)
                  [Wed Jul 13 22:32:23 2022] Scanning for low memory corruption every 60 seconds
                  [Wed Jul 13 22:32:23 2022] Initialise system trusted keyrings
                  [Wed Jul 13 22:32:23 2022] Key type blacklist registered
                  [Wed Jul 13 22:32:23 2022] workingset: timestamp_bits=36 max_order=20 bucket_order=0
                  [Wed Jul 13 22:32:23 2022] zbud: loaded
                  [Wed Jul 13 22:32:23 2022] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                  [Wed Jul 13 22:32:23 2022] fuse init (API version 7.26)
                  [Wed Jul 13 22:32:23 2022] Key type asymmetric registered
                  [Wed Jul 13 22:32:23 2022] Asymmetric key parser 'x509' registered
                  [Wed Jul 13 22:32:23 2022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
                  [Wed Jul 13 22:32:23 2022] io scheduler noop registered
                  [Wed Jul 13 22:32:23 2022] io scheduler deadline registered
                  [Wed Jul 13 22:32:23 2022] io scheduler cfq registered (default)
                  [Wed Jul 13 22:32:23 2022] vesafb: mode is 640x480x32, linelength=2560, pages=0
                  [Wed Jul 13 22:32:23 2022] vesafb: scrolling: redraw
                  [Wed Jul 13 22:32:23 2022] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
                  [Wed Jul 13 22:32:23 2022] vesafb: framebuffer at 0xe0000000, mapped to 0x        (ptrval), using 1216k, total 1216k
                  [Wed Jul 13 22:32:23 2022] Console: switching to colour frame buffer device 80x30
                  [Wed Jul 13 22:32:23 2022] fb0: VESA VGA frame buffer device
                  [Wed Jul 13 22:32:23 2022] intel_idle: MWAIT substates: 0x1120
                  [Wed Jul 13 22:32:23 2022] intel_idle: v0.4.1 model 0x3A
                  [Wed Jul 13 22:32:23 2022] intel_idle: lapic_timer_reliable_states 0xffffffff
                  [Wed Jul 13 22:32:23 2022] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
                  [Wed Jul 13 22:32:23 2022] ACPI: Power Button [PWRB]
                  [Wed Jul 13 22:32:23 2022] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
                  [Wed Jul 13 22:32:23 2022] ACPI: Power Button [PWRF]
                  [Wed Jul 13 22:32:23 2022] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
                  [Wed Jul 13 22:32:23 2022] thermal LNXTHERM:00: registered as thermal_zone0
                  [Wed Jul 13 22:32:23 2022] ACPI: Thermal Zone [TZ00] (28 C)
                  [Wed Jul 13 22:32:23 2022] thermal LNXTHERM:01: registered as thermal_zone1
                  [Wed Jul 13 22:32:23 2022] ACPI: Thermal Zone [TZ01] (30 C)
                  [Wed Jul 13 22:32:23 2022] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
                  [Wed Jul 13 22:32:23 2022] Linux agpgart interface v0.103
                  [Wed Jul 13 22:32:23 2022] loop: module loaded
                  [Wed Jul 13 22:32:23 2022] libphy: Fixed MDIO Bus: probed
                  [Wed Jul 13 22:32:23 2022] tun: Universal TUN/TAP device driver, 1.6
                  [Wed Jul 13 22:32:23 2022] PPP generic driver version 2.4.2
                  [Wed Jul 13 22:32:23 2022] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                  [Wed Jul 13 22:32:23 2022] ehci-pci: EHCI PCI platform driver
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1a.0: EHCI Host Controller
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1a.0: debug port 2
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7e08000
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
                  [Wed Jul 13 22:32:23 2022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
                  [Wed Jul 13 22:32:23 2022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                  [Wed Jul 13 22:32:23 2022] usb usb1: Product: EHCI Host Controller
                  [Wed Jul 13 22:32:23 2022] usb usb1: Manufacturer: Linux 4.15.0-65-generic ehci_hcd
                  [Wed Jul 13 22:32:23 2022] usb usb1: SerialNumber: 0000:00:1a.0
                  [Wed Jul 13 22:32:23 2022] hub 1-0:1.0: USB hub found
                  [Wed Jul 13 22:32:23 2022] hub 1-0:1.0: 2 ports detected
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1d.0: EHCI Host Controller
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1d.0: debug port 2
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7e07000
                  [Wed Jul 13 22:32:23 2022] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
                  [Wed Jul 13 22:32:23 2022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
                  [Wed Jul 13 22:32:23 2022] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                  [Wed Jul 13 22:32:23 2022] usb usb2: Product: EHCI Host Controller
                  [Wed Jul 13 22:32:23 2022] usb usb2: Manufacturer: Linux 4.15.0-65-generic ehci_hcd
                  [Wed Jul 13 22:32:23 2022] usb usb2: SerialNumber: 0000:00:1d.0
                  [Wed Jul 13 22:32:23 2022] hub 2-0:1.0: USB hub found
                  [Wed Jul 13 22:32:23 2022] hub 2-0:1.0: 2 ports detected
                  [Wed Jul 13 22:32:23 2022] ehci-platform: EHCI generic platform driver
                  [Wed Jul 13 22:32:23 2022] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                  [Wed Jul 13 22:32:23 2022] ohci-pci: OHCI PCI platform driver
                  [Wed Jul 13 22:32:23 2022] ohci-platform: OHCI generic platform driver
                  [Wed Jul 13 22:32:23 2022] uhci_hcd: USB Universal Host Controller Interface driver
                  [Wed Jul 13 22:32:23 2022] i8042: PNP: No PS/2 controller found.
                  [Wed Jul 13 22:32:23 2022] mousedev: PS/2 mouse device common for all mice
                  [Wed Jul 13 22:32:23 2022] rtc_cmos 00:02: RTC can wake from S4
                  [Wed Jul 13 22:32:23 2022] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
                  [Wed Jul 13 22:32:23 2022] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
                  [Wed Jul 13 22:32:23 2022] i2c /dev entries driver
                  [Wed Jul 13 22:32:23 2022] device-mapper: uevent: version 1.0.3
                  [Wed Jul 13 22:32:23 2022] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
                  [Wed Jul 13 22:32:23 2022] intel_pstate: Intel P-state driver initializing
                  [Wed Jul 13 22:32:23 2022] ledtrig-cpu: registered to indicate activity on CPUs
                  [Wed Jul 13 22:32:23 2022] NET: Registered protocol family 10
                  [Wed Jul 13 22:32:23 2022] Segment Routing with IPv6
                  [Wed Jul 13 22:32:23 2022] NET: Registered protocol family 17
                  [Wed Jul 13 22:32:23 2022] Key type dns_resolver registered
                  [Wed Jul 13 22:32:23 2022] mce: Using 7 MCE banks
                  [Wed Jul 13 22:32:23 2022] RAS: Correctable Errors collector initialized.
                  [Wed Jul 13 22:32:23 2022] microcode: sig=0x306a9, pf=0x2, revision=0x21
                  [Wed Jul 13 22:32:23 2022] microcode: Microcode Update Driver: v2.2.
                  [Wed Jul 13 22:32:23 2022] sched_clock: Marking stable (941768096, 0)->(922187180, 19580916)
                  [Wed Jul 13 22:32:23 2022] registered taskstats version 1
                  [Wed Jul 13 22:32:23 2022] Loading compiled-in X.509 certificates
                  [Wed Jul 13 22:32:23 2022] Loaded X.509 cert 'Build time autogenerated kernel key: 3a65b6a3c8b5d6b297d77c25be9161529933bc49'
                  [Wed Jul 13 22:32:23 2022] zswap: loaded using pool lzo/zbud
                  [Wed Jul 13 22:32:23 2022] Key type big_key registered
                  [Wed Jul 13 22:32:23 2022] Key type trusted registered
                  [Wed Jul 13 22:32:23 2022] Key type encrypted registered
                  [Wed Jul 13 22:32:23 2022] AppArmor: AppArmor sha1 policy hashing enabled
                  [Wed Jul 13 22:32:23 2022] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
                  [Wed Jul 13 22:32:23 2022] ima: Allocated hash algorithm: sha1
                  [Wed Jul 13 22:32:23 2022] evm: HMAC attrs: 0x1
                  [Wed Jul 13 22:32:23 2022]   Magic number: 14:743:510
                  [Wed Jul 13 22:32:23 2022] rtc_cmos 00:02: setting system clock to 2022-07-14 02:32:24 UTC (1657765944)
                  [Wed Jul 13 22:32:23 2022] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
                  [Wed Jul 13 22:32:23 2022] EDD information not available.
                  [Wed Jul 13 22:32:23 2022] Freeing unused kernel image memory: 2436K
                  [Wed Jul 13 22:32:23 2022] Write protecting the kernel read-only data: 20480k
                  [Wed Jul 13 22:32:23 2022] Freeing unused kernel image memory: 2008K
                  [Wed Jul 13 22:32:23 2022] Freeing unused kernel image memory: 1888K
                  [Wed Jul 13 22:32:23 2022] x86/mm: Checked W+X mappings: passed, no W+X pages found.
                  [Wed Jul 13 22:32:23 2022] x86/mm: Checking user space page tables
                  [Wed Jul 13 22:32:24 2022] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
                  [Wed Jul 13 22:32:24 2022] r8169 0000:03:00.0 eth0: RTL8168e/8111e at 0x        (ptrval), 00:23:24:44:8b:04, XID 0c200000 IRQ 24
                  [Wed Jul 13 22:32:24 2022] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
                  [Wed Jul 13 22:32:24 2022] ahci 0000:00:1f.2: version 3.0
                  [Wed Jul 13 22:32:24 2022] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x1 impl SATA mode
                  [Wed Jul 13 22:32:24 2022] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
                  [Wed Jul 13 22:32:24 2022] scsi host0: ahci
                  [Wed Jul 13 22:32:24 2022] scsi host1: ahci
                  [Wed Jul 13 22:32:24 2022] r8169 0000:03:00.0 enp3s0: renamed from eth0
                  [Wed Jul 13 22:32:24 2022] scsi host2: ahci
                  [Wed Jul 13 22:32:24 2022] scsi host3: ahci
                  [Wed Jul 13 22:32:24 2022] ata1: SATA max UDMA/133 abar m2048@0xf7e06000 port 0xf7e06100 irq 25
                  [Wed Jul 13 22:32:24 2022] ata2: DUMMY
                  [Wed Jul 13 22:32:24 2022] ata3: DUMMY
                  [Wed Jul 13 22:32:24 2022] ata4: DUMMY
                  [Wed Jul 13 22:32:24 2022] [drm] Memory usable by graphics device = 2048M
                  [Wed Jul 13 22:32:24 2022] checking generic (e0000000 130000) vs hw (e0000000 10000000)
                  [Wed Jul 13 22:32:24 2022] fb: switching to inteldrmfb from VESA VGA
                  [Wed Jul 13 22:32:24 2022] Console: switching to colour dummy device 80x25
                  [Wed Jul 13 22:32:24 2022] [drm] Replacing VGA console driver
                  [Wed Jul 13 22:32:24 2022] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                  [Wed Jul 13 22:32:24 2022] [drm] Driver supports precise vblank timestamp query.
                  [Wed Jul 13 22:32:24 2022] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
                  [Wed Jul 13 22:32:24 2022] [drm] Initialized i915 1.6.0 20171023 for 0000:00:02.0 on minor 0
                  [Wed Jul 13 22:32:24 2022] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
                  [Wed Jul 13 22:32:24 2022] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input2
                  [Wed Jul 13 22:32:24 2022] usb 1-1: new high-speed USB device number 2 using ehci-pci
                  [Wed Jul 13 22:32:24 2022] usb 2-1: new high-speed USB device number 2 using ehci-pci
                  [Wed Jul 13 22:32:24 2022] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
                  [Wed Jul 13 22:32:24 2022] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                  [Wed Jul 13 22:32:24 2022] hub 2-1:1.0: USB hub found
                  [Wed Jul 13 22:32:24 2022] hub 2-1:1.0: 6 ports detected
                  [Wed Jul 13 22:32:24 2022] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
                  [Wed Jul 13 22:32:24 2022] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                  [Wed Jul 13 22:32:24 2022] hub 1-1:1.0: USB hub found
                  [Wed Jul 13 22:32:24 2022] hub 1-1:1.0: 4 ports detected
                  [Wed Jul 13 22:32:24 2022] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
                  [Wed Jul 13 22:32:24 2022] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
                  [Wed Jul 13 22:32:24 2022] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
                  [Wed Jul 13 22:32:24 2022] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
                  [Wed Jul 13 22:32:24 2022] ata1.00: ATA-9: CT240BX500SSD1,  M6CR013, max UDMA/133
                  [Wed Jul 13 22:32:24 2022] ata1.00: 468862128 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
                  [Wed Jul 13 22:32:24 2022] ata1.00: configured for UDMA/133
                  [Wed Jul 13 22:32:24 2022] scsi 0:0:0:0: Direct-Access     ATA      CT240BX500SSD1   R013 PQ: 0 ANSI: 5
                  [Wed Jul 13 22:32:24 2022] sd 0:0:0:0: Attached scsi generic sg0 type 0
                  [Wed Jul 13 22:32:24 2022] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
                  [Wed Jul 13 22:32:24 2022] sd 0:0:0:0: [sda] Write Protect is off
                  [Wed Jul 13 22:32:24 2022] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
                  [Wed Jul 13 22:32:24 2022] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
                  [Wed Jul 13 22:32:24 2022]  sda: sda1
                  [Wed Jul 13 22:32:24 2022] sd 0:0:0:0: [sda] Attached SCSI disk
                  [Wed Jul 13 22:32:24 2022] [drm] Cannot find any crtc or sizes
                  [Wed Jul 13 22:32:24 2022] usb 2-1.1: new full-speed USB device number 3 using ehci-pci
                  [Wed Jul 13 22:32:24 2022] usb 2-1.1: New USB device found, idVendor=0658, idProduct=0200
                  [Wed Jul 13 22:32:24 2022] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                  [Wed Jul 13 22:32:24 2022] usb 2-1.2: new full-speed USB device number 4 using ehci-pci
                  [Wed Jul 13 22:32:24 2022] tsc: Refined TSC clocksource calibration: 2793.655 MHz
                  [Wed Jul 13 22:32:24 2022] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2844d6ea4b8, max_idle_ns: 440795338834 ns
                  [Wed Jul 13 22:32:25 2022] usb 2-1.2: New USB device found, idVendor=1a86, idProduct=7523
                  [Wed Jul 13 22:32:25 2022] usb 2-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
                  [Wed Jul 13 22:32:25 2022] usb 2-1.2: Product: USB2.0-Serial
                  [Wed Jul 13 22:32:25 2022] clocksource: Switched to clocksource tsc
                  [Wed Jul 13 22:32:26 2022] raid6: sse2x1   gen()  8242 MB/s
                  [Wed Jul 13 22:32:26 2022] raid6: sse2x1   xor()  5886 MB/s
                  [Wed Jul 13 22:32:26 2022] raid6: sse2x2   gen()  9807 MB/s
                  [Wed Jul 13 22:32:26 2022] raid6: sse2x2   xor()  6541 MB/s
                  [Wed Jul 13 22:32:26 2022] raid6: sse2x4   gen() 11699 MB/s
                  [Wed Jul 13 22:32:26 2022] raid6: sse2x4   xor()  7771 MB/s
                  [Wed Jul 13 22:32:26 2022] raid6: using algorithm sse2x4 gen() 11699 MB/s
                  [Wed Jul 13 22:32:26 2022] raid6: .... xor() 7771 MB/s, rmw enabled
                  [Wed Jul 13 22:32:26 2022] raid6: using ssse3x2 recovery algorithm
                  [Wed Jul 13 22:32:26 2022] xor: automatically using best checksumming function   avx
                  [Wed Jul 13 22:32:26 2022] Btrfs loaded, crc32c=crc32c-intel
                  [Wed Jul 13 22:32:26 2022] random: fast init done
                  [Wed Jul 13 22:32:26 2022] random: systemd-udevd: uninitialized urandom read (16 bytes read)
                  [Wed Jul 13 22:32:26 2022] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                  [Wed Jul 13 22:32:26 2022] ip_tables: (C) 2000-2006 Netfilter Core Team
                  [Wed Jul 13 22:32:26 2022] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Detected architecture x86-64.
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Set hostname to <AP-Tiny>.
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Reached target User and Group Name Lookups.
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Created slice User and Session Slice.
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Reached target Remote File Systems.
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Created slice System Slice.
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Listening on udev Control Socket.
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Listening on Syslog Socket.
                  [Wed Jul 13 22:32:26 2022] systemd[1]: Listening on Journal Socket (/dev/log).
                  [Wed Jul 13 22:32:26 2022] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                  [Wed Jul 13 22:32:26 2022] lp: driver loaded but no devices found
                  [Wed Jul 13 22:32:26 2022] ppdev: user-space parallel port driver
                  [Wed Jul 13 22:32:26 2022] systemd-journald[379]: Received request to flush runtime journal from PID 1
                  [Wed Jul 13 22:32:26 2022] Adding 2097148k swap on /swapfile.  Priority:-2 extents:11 across:2244544k SSFS
                  [Wed Jul 13 22:32:27 2022] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
                  [Wed Jul 13 22:32:27 2022] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20170831/utaddress-247)
                  [Wed Jul 13 22:32:27 2022] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
                  [Wed Jul 13 22:32:27 2022] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20170831/utaddress-247)
                  [Wed Jul 13 22:32:27 2022] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20170831/utaddress-247)
                  [Wed Jul 13 22:32:27 2022] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20170831/utaddress-247)
                  [Wed Jul 13 22:32:27 2022] lpc_ich: Resource conflict(s) found affecting gpio_ich
                  [Wed Jul 13 22:32:27 2022] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                  [Wed Jul 13 22:32:27 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                  [Wed Jul 13 22:32:27 2022] Intel(R) Wireless WiFi driver for Linux
                  [Wed Jul 13 22:32:27 2022] Copyright(c) 2003- 2015 Intel Corporation
                  [Wed Jul 13 22:32:27 2022] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
                  [Wed Jul 13 22:32:27 2022] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
                  [Wed Jul 13 22:32:27 2022] RAPL PMU: hw unit of domain package 2^-16 Joules
                  [Wed Jul 13 22:32:27 2022] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
                  [Wed Jul 13 22:32:27 2022] iwlwifi 0000:02:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
                  [Wed Jul 13 22:32:27 2022] cdc_acm 2-1.1:1.0: ttyACM0: USB ACM device
                  [Wed Jul 13 22:32:27 2022] usbcore: registered new interface driver cdc_acm
                  [Wed Jul 13 22:32:27 2022] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                  [Wed Jul 13 22:32:27 2022] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG disabled
                  [Wed Jul 13 22:32:27 2022] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
                  [Wed Jul 13 22:32:27 2022] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
                  [Wed Jul 13 22:32:27 2022] iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Wireless-N 105 BGN, REV=0x110
                  [Wed Jul 13 22:32:27 2022] kvm: disabled by bios
                  [Wed Jul 13 22:32:27 2022] usbcore: registered new interface driver usbserial_generic
                  [Wed Jul 13 22:32:27 2022] usbserial: USB Serial support registered for generic
                  [Wed Jul 13 22:32:27 2022] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
                  [Wed Jul 13 22:32:27 2022] usbcore: registered new interface driver ch341
                  [Wed Jul 13 22:32:27 2022] usbserial: USB Serial support registered for ch341-uart
                  [Wed Jul 13 22:32:27 2022] ch341 2-1.2:1.0: ch341-uart converter detected
                  [Wed Jul 13 22:32:27 2022] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
                  [Wed Jul 13 22:32:27 2022] intel_rapl: Found RAPL domain package
                  [Wed Jul 13 22:32:27 2022] intel_rapl: Found RAPL domain core
                  [Wed Jul 13 22:32:27 2022] intel_rapl: Found RAPL domain uncore
                  [Wed Jul 13 22:32:27 2022] intel_rapl: RAPL package 0 domain package locked by BIOS
                  [Wed Jul 13 22:32:27 2022] usb 2-1.2: ch341-uart converter now attached to ttyUSB0
                  [Wed Jul 13 22:32:27 2022] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
                  [Wed Jul 13 22:32:27 2022] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC662 rev3: line_outs=1 (0x15/0x0/0x0/0x0/0x0) type:speaker
                  [Wed Jul 13 22:32:27 2022] snd_hda_codec_realtek hdaudioC0D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
                  [Wed Jul 13 22:32:27 2022] snd_hda_codec_realtek hdaudioC0D2:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
                  [Wed Jul 13 22:32:27 2022] snd_hda_codec_realtek hdaudioC0D2:    mono: mono_out=0x0
                  [Wed Jul 13 22:32:27 2022] snd_hda_codec_realtek hdaudioC0D2:    inputs:
                  [Wed Jul 13 22:32:27 2022] snd_hda_codec_realtek hdaudioC0D2:      Mic=0x19
                  [Wed Jul 13 22:32:27 2022] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input3
                  [Wed Jul 13 22:32:27 2022] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
                  [Wed Jul 13 22:32:27 2022] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=611 comm="apparmor_parser"
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=608 comm="apparmor_parser"
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=608 comm="apparmor_parser"
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=608 comm="apparmor_parser"
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=608 comm="apparmor_parser"
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=607 comm="apparmor_parser"
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=607 comm="apparmor_parser"
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=610 comm="apparmor_parser"
                  [Wed Jul 13 22:32:27 2022] audit: type=1400 audit(1657765948.434:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=610 comm="apparmor_parser"
                  [Wed Jul 13 22:32:28 2022] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
                  [Wed Jul 13 22:32:28 2022] r8169 0000:03:00.0 enp3s0: link down
                  [Wed Jul 13 22:32:28 2022] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
                  [Wed Jul 13 22:32:30 2022] r8169 0000:03:00.0 enp3s0: link up
                  [Wed Jul 13 22:32:30 2022] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
                  [Wed Jul 13 22:33:00 2022] Bluetooth: Core ver 2.22
                  [Wed Jul 13 22:33:00 2022] NET: Registered protocol family 31
                  [Wed Jul 13 22:33:00 2022] Bluetooth: HCI device and connection manager initialized
                  [Wed Jul 13 22:33:00 2022] Bluetooth: HCI socket layer initialized
                  [Wed Jul 13 22:33:00 2022] Bluetooth: L2CAP socket layer initialized
                  [Wed Jul 13 22:33:00 2022] Bluetooth: SCO socket layer initialized
                  [Wed Jul 13 22:33:26 2022] usb 2-1.1: USB disconnect, device number 3
                  [Wed Jul 13 22:33:26 2022] usb 2-1.1: new full-speed USB device number 5 using ehci-pci
                  [Wed Jul 13 22:33:26 2022] usb 2-1.1: New USB device found, idVendor=0658, idProduct=0200
                  [Wed Jul 13 22:33:26 2022] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                  [Wed Jul 13 22:33:26 2022] cdc_acm 2-1.1:1.0: ttyACM0: USB ACM device
                  [Wed Jul 13 22:33:33 2022] random: crng init done
                  [Wed Jul 13 22:33:33 2022] random: 7 urandom warning(s) missed due to ratelimiting
                  [Thu Jul 14 08:10:54 2022] perf: interrupt took too long (2522 > 2500), lowering kernel.perf_event_max_sample_rate to 79250
                  [Thu Jul 14 11:24:53 2022] perf: interrupt took too long (3164 > 3152), lowering kernel.perf_event_max_sample_rate to 63000
                  ap@AP-Tiny:~$
                    @ap2017 sagte in Zigbee adapter stopped running:
                    what is Extended PAN-Id?
                    The DDDDDDDDDDDDD setting. Extended PAN-Id written next to it...
                    If the two entries in /dev/serial/by-id are not your zigbee-stick, then it is completely unrecognized by your system. Maybe a hardware defect?
                    Check
                    dmesg -T
                    for any USB related messages.
                    ap2017
                    schrieb am zuletzt editiert von ap2017
                    Plugged Zigbee adapter to a different USB port on controller, now can see all three USB ports:
                    ap@AP-Tiny:~$ ls -l /dev/serial/by-id
                    total 0
                    lrwxrwxrwx 1 root root 13 Jul 14 13:34 usb-0658_0200-if00 -> ../../ttyACM0
                    lrwxrwxrwx 1 root root 13 Jul 14 13:33 usb-1a86_USB2.0-Serial-if00-port0 -> ../../ttyUSB0
                    lrwxrwxrwx 1 root root 13 Jul 14 13:37 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2EC73-if00 -> ../../ttyACM1
                    Zigbee adapter still does not work after reboot:
                    2022-07-14 13:46:08.303 - info: zigbee.0 (2610) Starting Zigbee npm ...
                    2022-07-14 13:46:08.524 - info: zigbee.0 (2610) Installed Version: iobroker.zigbee@1.7.5
                    2022-07-14 13:46:14.661 - info: mysensors.0 (2275) disconnected
                    2022-07-14 13:46:21.257 - info: mysensors.0 (2275) Connected
                    2022-07-14 13:46:21.258 - info: mysensors.0 (2275) STARTED
                    2022-07-14 13:46:28.818 - error: zigbee.0 (2610) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                    2022-07-14 13:46:28.820 - error: zigbee.0 (2610) Failed to start Zigbee
                    2022-07-14 13:46:28.820 - error: zigbee.0 (2610) Error herdsman start
                    2022-07-14 13:46:38.821 - info: zigbee.0 (2610) Try to reconnect. 1 attempts left
                    2022-07-14 13:46:38.822 - info: zigbee.0 (2610) Starting Zigbee npm ...
                    2022-07-14 13:46:38.833 - info: zigbee.0 (2610) Installed Version: iobroker.zigbee@1.7.5
                    2022-07-14 13:46:38.920 - error: zigbee.0 (2610) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    2022-07-14 13:46:38.921 - error: zigbee.0 (2610) Failed to start Zigbee
                    2022-07-14 13:46:38.921 - error: zigbee.0 (2610) Error herdsman start
                    • A ap2017
                      total 0
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      total 0
                      You have an issue with the stick. The port is opened but the firmware does not respond (as per this message)
                      The message about not being able to open the port is from a later start attempt which fails as the previous attempt did not manage to close the port after the firmware did not respond.
                      You need to check:
                      • which USB port the stick is plugged into (USB2 or USB3)
                      • do you have any disks or SSD's plugged into a USB3 port ?
                      • does the Stick have the correct firmware flashed
                      A.
                      • AsgothianA Asgothian
                        total 0
                        You need to check:
                        A.
                        ap2017
                        @asgothian
                        Not sure how to check which USB port is which, don't know Linux enough.
                        Nothing is connected to USB ports except MySensors gateway, Zwave adapter and Zigbee adapter.
                        There is certainly a chance that Zigbee adapter failed, but it was working fine for many months, this is not new setup. I think that it uses firmware version 20190608.
                          @ap2017
                          It the other way round...
                          Setting ACM1 in the adapter means nothing in the 'real world' of the Operating System.
                          The linux kernel and/or systemd decides where your devices end up in /dev/tty* and sets the correct link in /dev/serial/by-id pointing to the device.
                          So you need to find out which of your two devices in /dev/serial/by-id is the ZigBee Adapter. Try and Error. I think it is the second entry.
                          BTW: Set da different Extended PAN-Id. The one you use is too simple and only a place holder for an individual Id .
                          ap2017
                          Thank you found where is PAN-id, changing it caused many new error messages even after reboot, so I restored the default one.
                            This 'problem' is exactly the reason why you should never set /dev/ttyDEVICE but always the link that you find in /dev/serial/by-id
                            /dev/ttyDEVICE is generated during system start and may change at anytime, the link in /dev/serial/by-id will always point to the correct hardware.
                            ap2017
                            I changed all serial ports definitions with /dev/serial/by-id settings. MySensors and Zwave (USB) adapters work, but Zwave still does not
                            2022-07-14 20:45:46.201 - error: zigbee.0 (3605) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                            2022-07-14 20:45:46.202 - error: zigbee.0 (3605) Failed to start Zigbee
                            2022-07-14 20:45:46.202 - error: zigbee.0 (3605) Error herdsman start
                            total 0
                            lrwxrwxrwx 1 root root 13 Jul 14 18:07 usb-0658_0200-if00 -> ../../ttyACM0
                            lrwxrwxrwx 1 root root 13 Jul 14 20:38 usb-1a86_USB2.0-Serial-if00-port0 -> ../../ttyUSB0
                            lrwxrwxrwx 1 root root 13 Jul 14 20:43 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2EC73-if00 -> ../..                 /ttyACM1
                              ap2017
                              Nobody responded if it is important that serialport version of Zigbee is older than serialport of other adapters (assuming that 9.2.8 is a version number)
                              ap@AP-Tiny:/opt/iobroker$ npm list serialport
                              [sudo] password for ap:
                              iobroker.inst@2.0.3 /opt/iobroker
                              ├─┬ iobroker.discovery@3.0.5
                              │ └── serialport@10.4.0
                              ├─┬ iobroker.mysensors@3.0.0
                              │ └── serialport@10.4.0 deduped
                              ├─┬ iobroker.zigbee@1.7.5
                              │ └─┬ zigbee-herdsman@0.14.34
                              │   └── serialport@9.2.8
                              └─┬ iobroker.zwave2@2.6.0
                                └─┬ zwave-js@9.6.0
                                  ├─┬ @zwave-js/serial@9.6.0
                              • A ap2017
                                @asgothian
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @asgothian
                                Please test:
                                remove the MySensors gateway and the Zwave adapter and see if the zigbee adapter starts. Please be on the lookout for the first log message containing Starting zigbee-herdsman problem :, ignoring all messages after info: zigbee.0 (2610) Try to reconnect. as they will point you to a wrong direction.
                                If the zigbee adapter starts in this configuration there might be some interference between either the mysensors gateway and the zigbee stick or the zwave stick and the zigbee stick. If it does not start in this configuration, the firmware on the stick has become corrupted and should be refreshed.
                                The Zigbee-Herdsman Library which is used by the zigbee adapter requires a specific serialport library version, which is why it is completely normal to have a separate installation of the serial port library.
                                A.
                                  @asgothian
                                  Please test:
                                  A.
                                  ap2017
                                  @asgothian
                                  I disabled MySensors and Zwave then restarted controller. Here is what I am getting:
                                  2022-07-15 15:49:58.005 - error: zigbee.0 (20495) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                  2022-07-15 15:49:58.006 - error: zigbee.0 (20495) Failed to start Zigbee
                                  2022-07-15 15:49:58.006 - error: zigbee.0 (20495) Error herdsman start
                                  • A ap2017
                                    @asgothian
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @ap2017 Please reread my previous post and check for the correct message. I am 99% certain that this message is the one i explicitly told you was a false flag.
                                    A.
                                      A.
                                      ap2017
                                      @asgothian
                                      2022-07-15 18:26:04.695 - info: zigbee.0 (25872) Starting Zigbee npm ...
                                      2022-07-15 18:26:04.921 - info: zigbee.0 (25872) Installed Version: iobroker.zigbee@1.7.5
                                      2022-07-15 18:26:09.726 - info: mysensors.0 (21245) STARTED
                                      2022-07-15 18:26:24.873 - error: zigbee.0 (25872) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                      2022-07-15 18:26:24.875 - error: zigbee.0 (25872) Failed to start Zigbee
                                      2022-07-15 18:26:24.875 - error: zigbee.0 (25872) Error herdsman start
                                      2022-07-15 18:26:34.876 - info: zigbee.0 (25872) Try to reconnect. 1 attempts left
                                      2022-07-15 18:26:34.877 - info: zigbee.0 (25872) Starting Zigbee npm ...
                                      2022-07-15 18:26:34.889 - info: zigbee.0 (25872) Installed Version: iobroker.zigbee@1.7.5
                                      2022-07-15 18:26:34.989 - error: zigbee.0 (25872) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                      2022-07-15 18:26:34.990 - error: zigbee.0 (25872) Failed to start Zigbee
                                      2022-07-15 18:26:34.990 - error: zigbee.0 (25872) Error herdsman start
                                      • A ap2017
                                        @asgothian
                                        @ap2017
                                        I quote:
                                        So try to reflash the Firmware.
                                          @ap2017
                                          I quote:
                                          ap2017
                                          @thomas-braun After reflashing the firmware Zigbeee adapter started to behave differently. It works for some seconds then shuts down with error code. After restarting the adapter is does it again - works for a short time then shuts down with error code. I received another stick, reflashed it as well, but system behaves same way.
                                          2022-07-17 21:10:10.373 - info: zigbee.0 (2538) Zigbee started
                                          2022-07-17 21:10:12.539 - info: admin.0 (1256) ==> Connected system.user.admin from ::ffff:192.168.1.244
                                          2022-07-17 21:10:21.356 - warn: zigbee.0 (2538) DeviceAvailability:Failed to ping 0x90fd9ffffe2bad6b TRADFRI bulb E26 W opal 1000lm
                                          2022-07-17 21:10:40.020 - warn: zigbee.0 (2538) Device '0x90fd9ffffe2baf88' announced itself
                                          2022-07-17 21:10:40.023 - error: zigbee.0 (2538) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-07-17 21:10:40.024 - error: zigbee.0 (2538) unhandled promise rejection: Cannot read properties of undefined (reading 'color_options')
                                          2022-07-17 21:10:40.024 - error: zigbee.0 (2538) TypeError: Cannot read properties of undefined (reading 'color_options')
                                          at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
                                          at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
                                          at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
                                          at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
                                          at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
                                          2022-07-17 21:10:40.025 - error: zigbee.0 (2538) Cannot read properties of undefined (reading 'color_options')
                                          2022-07-17 21:10:40.028 - info: zigbee.0 (2538) cleaned everything up...
                                          2022-07-17 21:10:40.056 - info: zigbee.0 (2538) Zigbee: disabling joining new devices.
                                          2022-07-17 21:10:40.528 - info: zigbee.0 (2538) terminating
                                          2022-07-17 21:10:40.529 - warn: zigbee.0 (2538) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2022-07-17 21:10:41.035 - warn: zigbee.0 (2538) get state error: Connection is closed.
                                          2022-07-17 21:10:41.101 - error: host.AP-Tiny instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2022-07-17 21:10:41.102 - info: host.AP-Tiny Restart adapter system.adapter.zigbee.0 because enabled
                                          2022-07-17 21:10:41.102 - warn: host.AP-Tiny Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                                          2022-07-17 21:10:43.459 - info: mysensors.0 (2199) STARTED
                                          2022-07-17 21:10:43.460 - info: mysensors.0 (2199) STARTED
                                          2022-07-17 21:10:48.629 - info: admin.0 (1256) <== Disconnect system.user.admin from ::ffff:192.168.1.244
