  4. gelöst: Javascript Adapter 5.8.8
31 Beiträge 6 Kommentatoren 3.4k Aufrufe 6 Beobachtet
  • R robbsen
    Hallo Zusammen,
    musste ggf. beim Update auf Version 5.8.8 irgendwas umgestellt werden. Mein Adapter bleibt bei rot hängen. Ich könnte natürlich ein Backup zurückspielen, aber ggf. musste ich ja nur ne Kleinigkeit ändern?
    host.ioBroker
    2022-07-14 07:03:02.672	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.ioBroker
    2022-07-14 07:03:02.672	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker
    2022-07-14 07:03:02.671	error	Caught by controller[0]: }
    host.ioBroker
    2022-07-14 07:03:02.671	error	Caught by controller[0]: ]
    host.ioBroker
    2022-07-14 07:03:02.671	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.ioBroker
    2022-07-14 07:03:02.671	error	Caught by controller[0]: '/opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js',
    host.ioBroker
    2022-07-14 07:03:02.671	error	Caught by controller[0]: requireStack: [
    host.ioBroker
    2022-07-14 07:03:02.671	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.ioBroker
    2022-07-14 07:03:02.670	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
    host.ioBroker
    2022-07-14 07:03:02.670	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.ioBroker
    2022-07-14 07:03:02.670	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.ioBroker
    2022-07-14 07:03:02.670	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.ioBroker
    2022-07-14 07:03:02.670	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.ioBroker
    2022-07-14 07:03:02.670	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js:7:10)
    host.ioBroker
    2022-07-14 07:03:02.669	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.ioBroker
    2022-07-14 07:03:02.669	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.ioBroker
    2022-07-14 07:03:02.669	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    host.ioBroker
    2022-07-14 07:03:02.669	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    host.ioBroker
    2022-07-14 07:03:02.669	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.ioBroker
    2022-07-14 07:03:02.669	error	Caught by controller[0]: - /opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js
    host.ioBroker
    2022-07-14 07:03:02.668	error	Caught by controller[0]: Require stack:
    host.ioBroker
    2022-07-14 07:03:02.668	error	Caught by controller[0]: Error: Cannot find module 'coffee-script'
    host.ioBroker
    2022-07-14 07:03:02.668	error	Caught by controller[0]: ^
    host.ioBroker
    2022-07-14 07:03:02.668	error	Caught by controller[0]: throw err;
    host.ioBroker
    2022-07-14 07:03:02.667	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
    host.ioBroker
    2022-07-14 07:03:02.462	info	instance system.adapter.javascript.0 started with pid 1200147
    N Offline
    N Offline
    Nordischerjung
    @robbsen
    Guck hier
    Gruß Nordischerjung
    sonnige Grüße von der Ostsee
    • R robbsen
      Hallo Zusammen,
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      @robbsen sagte in Javascript Adapter 5.8.8:
      Bei npm@8:
      cd /opt/iobroker/node_modules/iobroker.javascript
      sudo -H -u iobroker npm install --omit=dev
      R frankthegreatF 2 Antworten Letzte Antwort
        Bei npm@8:
        robbsen
        @thomas-braun das hat geholfen.
        @Nordischerjung tatsächlich hatte ich das nicht gemacht.
        Danke euch beiden! Auch wenn ich keine Ahnung habe, was ich da eigentlich warum grade gemacht habe ;)
        • R robbsen
          @robbsen
          Du hast die beiden Adapter mit den richtigen Dependencies neugebaut.
          R 1 Antwort Letzte Antwort
            @robbsen
            robbsen
            heißt aber, die Abhängigkeiten hatten sich durch das JavaScript Update so stark verändert? Wie kommt man auf sowas 🤗
            • R robbsen
              @robbsen
              Ich weiß zufällig, das die Dependency zu coffee-script auf die richtige Bezeichnung coffeescript geändert wurde. Und das die beiden Module rebuilded werden wollten steht im Log drin. Muss man dann 'nur noch machen'
                Bei npm@8:
                frankthegreatF Offline
                frankthegreat
                @thomas-braun sagte in gelöst: Javascript Adapter 5.8.8:
                Bei npm@8:
                Hab die gleiche Fehlermeldung wie @robbsen
                beim aktualisieren vom Javascript Adapter.
                Wären denn bei npm@6 auch diese Befehle richtig?
                • frankthegreatF frankthegreat
                  Bei npm@8:
                  @frankthegreat sagte in gelöst: Javascript Adapter 5.8.8:
                  Gegenfrage: Warum nicht nodejs16 inkl. npm8 verwenden? Ist eh die vorgesehene Version.
                  frankthegreatF 1 Antwort Letzte Antwort
                    frankthegreat
                    @thomas-braun Bin noch nicht soweit (Produktivsystem) 😢
                    Aber wenn du sagst, das es stabil läuft werd' ich es mal angreifen?
                      @frankthegreat
                      https://forum.iobroker.net/topic/55678/node-js-16-x-neue-empfehlung-für-iobroker
                      In 'meinem' HowTo (s. Signatur) gibt es auch noch ein paar Tips gerade in Bezug auf node16/npm8 und dessen neuem Format für die package*-Files.
                        @frankthegreat
                        frankthegreat
                        @thomas-braun OK, danke.
                        Mal schauen, ob ich es am WE schaffe 😎
                          Beowolf
                          Ich habe das Problem auch
                          bei mir kommt die Meldung
                          host.raspberrypi
                          	2022-09-05 12:51:15.176	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          host.raspberrypi
                          	2022-09-05 12:51:15.176	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.raspberrypi
                          	2022-09-05 12:51:15.176	error	Caught by controller[0]: }
                          host.raspberrypi
                          	2022-09-05 12:51:15.176	error	Caught by controller[0]: requestPath: 'coffeescript'
                          host.raspberrypi
                          	2022-09-05 12:51:15.176	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
                          host.raspberrypi
                          	2022-09-05 12:51:15.175	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                          host.raspberrypi
                          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32) {
                          host.raspberrypi
                          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                          host.raspberrypi
                          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
                          host.raspberrypi
                          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
                          host.raspberrypi
                          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                          host.raspberrypi
                          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
                          host.raspberrypi
                          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                          host.raspberrypi
                          	2022-09-05 12:51:15.174	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
                          host.raspberrypi
                          	2022-09-05 12:51:15.174	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
                          host.raspberrypi
                          	2022-09-05 12:51:15.174	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:364:19)
                          host.raspberrypi
                          	2022-09-05 12:51:15.174	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
                          host.raspberrypi
                          	2022-09-05 12:51:15.174	error	Caught by controller[0]: ^
                          host.raspberrypi
                          	2022-09-05 12:51:15.174	error	Caught by controller[0]: throw err;
                          host.raspberrypi
                          	2022-09-05 12:51:15.173	error	Caught by controller[0]: node:internal/modules/cjs/loader:372
                          Ich bin mir nicht sicher was ich machen soll.
                          • B Beowolf
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            @beowolf sagte in gelöst: Javascript Adapter 5.8.8:
                            Welcher Befehl führte zu den Ausgaben?
                            Welche nodejs-Version?
                            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            Welche Versionen der Adapter?
                            iobroker update -i
                            B 2 Antworten Letzte Antwort
                              iobroker update -i
                              Beowolf
                              Bei
                              kommt
                              pi@raspberrypi:/ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.17.0
                              v16.17.0
                              8.15.0
                              pi
                              OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
                              OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                              Alle Pakete sind aktuell.
                              nodejs:
                                Installiert:           16.17.0-deb-1nodesource1
                                Installationskandidat: 16.17.0-deb-1nodesource1
                                Versionstabelle:
                               *** 16.17.0-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                   14.20.0-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                   12.22.12~dfsg-1~deb11u1 500
                              pi@raspberrypi:/ $
                              Bei
                              iobroker update -i
                              kommt
                              pi@raspberrypi:/ $ iobroker update -i
                              Used repository: stable
                              Adapter    "admin"        : 6.2.20   , installed 6.2.20
                              Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                              Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                              Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                              Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                              Adapter    "email"        : 1.1.3    , installed 1.1.3
                              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                              Adapter    "ical"         : 1.13.1   , installed 1.13.1
                              Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
                              Adapter    "info"         : 1.9.19   , installed 1.9.19
                              Adapter    "iot"          : 1.11.8   , installed 1.11.8
                              Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
                              Adapter    "javascript"   : 6.0.0    , installed 6.0.0
                              Controller "js-controller": 4.0.23   , installed 4.0.23
                              Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                              Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                              Adapter    "pushover"     : 3.0.2    , installed 3.0.2
                              Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                              Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                              Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                              Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
                              Adapter    "wled"         : 0.6.7    , installed 0.6.7
                              pi@raspberrypi:/ $
                                iobroker update -i
                                Beowolf
                                Bei diesem
                                • B Beowolf
                                  Bei
                                  kommt
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.17.0
                                  v16.17.0
                                  8.15.0
                                  pi
                                  nodejs:
                                    Versionstabelle:
                                  pi@raspberrypi:/ $
                                  Bei
                                  iobroker update -i
                                  kommt
                                  pi@raspberrypi:/ $
                                  @beowolf
                                  Stell dich in dein /home-Verzeichnis. Warum steht du da in / herum?
                                  cd ~
                                  • B Beowolf
                                    Bei diesem
                                    Hast du das auch in / ausgeführt?
                                    Bitte IMMER vollständige Ein- und Ausgaben inkl. login prompt zeigen, dann sieht man sowas direkt.
                                      Beowolf
                                      Habe es dort gemacht.
                                      pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript/node_modules $ npm install --production
                                      npm WARN config production Use `--omit=dev` instead.
                                      > iobroker.javascript@6.0.0 postinstall
                                      > node ./install/installTypings.js
                                      Installing NodeJS typings...
                                      latest @types: 18, installed node: 16
                                      up to date, audited 107 packages in 12s
                                      9 packages are looking for funding
                                        run `npm fund` for details
                                      found 0 vulnerabilities
                                      • B Beowolf
                                        wäre richtig gewesen.
                                          Beowolf
                                          schrieb am zuletzt editiert von Beowolf
                                          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ npm install --production
                                          up to date, audited 107 packages in 11s
                                          Habe ich jetzt ein Problem, weil es im falschen Ordner war?
