  3. Einsteigerfragen
  4. Zigbee Netzwerk Aufbau
    5.6k
77 Beiträge 8 Kommentatoren 11.2k Aufrufe 7 Beobachtet
    @hot-air-balloon
    Bitte keine Screenshots aus der Konsole.
    Als Text (in CodeTags eingebettet) hier rein kopieren.
    5c424217-50fa-4d46-b362-b4381e24bdda-image.png ```
    code_text
    Hot-Air-BalloonH Offline
    Hot-Air-Balloon
    Verstanden
    host.ioBroker
    	2022-07-13 12:02:12.568	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.ioBroker
    	2022-07-13 12:02:12.568	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ioBroker
    	2022-07-13 12:02:12.568	error	Caught by controller[1]: at processImmediate (node:internal/timers:466:21)
    host.ioBroker
    	2022-07-13 12:02:12.568	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37)
    host.ioBroker
    	2022-07-13 12:02:12.568	error	Caught by controller[1]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34)
    host.ioBroker
    	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Zigbee.emit (node:domain:475:12)
    host.ioBroker
    	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Zigbee.emit (node:events:539:35)
    host.ioBroker
    	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:76:30)
    host.ioBroker
    	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:455:52)
    host.ioBroker
    	2022-07-13 12:02:12.567	error	Caught by controller[1]: at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:935:54)
    host.ioBroker
    	2022-07-13 12:02:12.567	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'waitFor')
    host.ioBroker
    	2022-07-13 12:02:12.566	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    	2022-07-13 12:02:11.947	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2022-07-13 12:02:11.945	info	terminating
    zigbee.0
    	2022-07-13 12:02:11.465	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2022-07-13 12:02:11.444	info	cleaned everything up...
    zigbee.0
    	2022-07-13 12:02:11.411	error	Cannot read properties of undefined (reading 'waitFor')
    zigbee.0
    	2022-07-13 12:02:11.410	error	TypeError: Cannot read properties of undefined (reading 'waitFor') at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:935:54) at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:455:52) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:76:30) at Zigbee.emit (node:events:539:35) at Zigbee.emit (node:domain:475:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:466:21)
    zigbee.0
    	2022-07-13 12:02:11.255	error	unhandled promise rejection: Cannot read properties of undefined (reading 'waitFor')
    zigbee.0
    	2022-07-13 12:02:11.255	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Die Meldung bekomme ich jetzt, wenn ich nach einem Netzwerk scanne.
    • Hot-Air-BalloonH Hot-Air-Balloon
      Verstanden
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @hot-air-balloon
      Du hast gesehen, dass node und npm noch im falschen Pfad ist und das korrigiert?
      Hot-Air-BalloonH 1 Antwort Letzte Antwort
        @hot-air-balloon
        Hot-Air-Balloon
        @thomas-braun Ehrlich gesagt nicht. Wie gesagt, ich bin auf dem Gebiet hier ein blutiger Anfänger.
        Schade, dass das install bash das nicht direkt sauber konfiguriert.
          @hot-air-balloon
          Macht es. Aber es kann natürlich die über einen anderen Installationsweg ins System gebügelte Installation nicht rauskratzen. Das mußte du schon selber wieder reparieren.
            @hot-air-balloon
            Hot-Air-Balloon
            schrieb am zuletzt editiert von Hot-Air-Balloon
            Also meine ioBroker Installation sah wie folgt aus:
            Raspberry OS auf die SD Karte schreiben und den PI damit starten. Pi Updaten und dann die ioBroker Install bash ausführen. Mehr habe ich nicht gemacht, alles was auf dem Pi läuft ist entweder teil der standard Installation oder kommt von der ioBroker Installation.
            Was ist deine Empfehlung, wie ziehe ich das grade ? Wie gesagt ich habe mich noch nie mit node beschäftigt und was ich bislang im Internet gefunden habe, schien ja alles falsch zu sein. Dein Anleitung zeigt leider keine saubere Deinstallation, dann wäre ich danach noch mal von vorne angefangen.
            sudo apt-get purge -y nodejs
            Ich habs mal so entfernt und deine Anleitung gefolgt, trotzdem landet die installation im local Ordner und nicht im bin
              Also auch falsch ? :(
              node -v
              hatte mir 14.x ausgegeben, dann habe ich
              sudo npm install -g n
              ausgeführt und dann:
              sudo n stable
              hatte das so im Netz gefunden. Hab mit node noch keine Berührungspunkte gehabt.
              @hot-air-balloon sagte in Zigbee Netzwerk Aufbau:
              sudo n stable
              Das ist NICHT Teil der Standardinstallation, das hast du weiß der Geier woher. Das steht in keinem unserer HowTos zu nodeJS drin.
              Da kommen aber die Installationen in /use/local/bin her. Also bitte nicht behaupten, man habe eine Standardinstallation.
              Wie man die los wird steht auch in meinem How to drin. Im zweiten Teil, falls du bis dort nicht gelesen hast.
                @hot-air-balloon
                Sehr lange dauert das, weil du vermutlich nicht die aktuell empfohlene nodejs/npm Versionen installiert hast. Mit nodejs16 sollte das schneller gehen.
                Hot-Air-Balloon
                @thomas-braun said in Zigbee Netzwerk Aufbau:
                sudo n stable
                Also .... ich habe mein ioBroker wie in dem posting gerade beschrieben installiert. Darauf bezog sich die Aussage mit der Standard Installation. Nach deiner Aussage:
                @hot-air-balloon
                habe ich die von dir gerade geqoteten Befehle ausgeführt. Davor war aber schon ein Node 14 installiert... lange rede... was kann ich also machen und kann mir dabei einer helfen?
                  sudo n stable
                  @hot-air-balloon
                  @hot-air-balloon
                  Wie schon gesagt: Es steht alles in meinem How to drin.
                    @hot-air-balloon
                    Hot-Air-Balloon
                    Danke, ich denke ich habe es hinbekommen:
                    pi@ioBroker:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    aarch64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.16.0
                    v16.16.0
                    8.11.0
                    pi
                    /home/pi
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
                    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                    Reading package lists... Done
                    All packages are up to date.
                    nodejs:
                      Installed: 16.16.0-deb-1nodesource1
                      Candidate: 16.16.0-deb-1nodesource1
                      Version table:
                     *** 16.16.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                         12.22.12~dfsg-1~deb11u1 500
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                         12.22.5~dfsg-2~11u1 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    Also Jetzt zuerst den normalen Zigbee Adapter installieren, dann den von GIT ?
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      gu kannst den direkt von git nehmen
                      • arteckA arteck
                        Hot-Air-Balloon
                        @arteck Danke, das habe ich jetzt gemacht, der bringt aber keine Instanz und auch kein Eintrag im Menü mit.
                        $ iobroker url ioBroker/ioBroker.zigbee --host ioBroker
                        install ioBroker/ioBroker.zigbee
                        NPM version: 8.11.0
                        Installing ioBroker/ioBroker.zigbee... (System call)
                        added 44 packages in 31s60 packages are looking for funding run `npm fund` for details
                        upload [311] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                        upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                        upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                        upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                        upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
                        upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
                        upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
                        upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                        upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
                        upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
                        upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                        upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                        upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                        upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                        upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                        upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                        upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                        upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                        upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                        upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                        upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                        upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                        upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                        upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                        upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                        upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                        upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                        upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                        upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                        upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                        upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                        upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                        upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                        upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                        Process exited with code 0
                        arteckA Thomas BraunT 2 Antworten Letzte Antwort
                          NPM version: 8.11.0
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @hot-air-balloon die insanz musst du selber hinzufügen
                            NPM version: 8.11.0
                            Machen git-Installationen nie, die Instanz muss händisch hinzugefügt werden.
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @thomas-braun sagte in Zigbee Netzwerk Aufbau:
                              jaja... kam ja von mir. also alles gut..ist ja ne Ausnahme
                              Thomas BraunT Hot-Air-BalloonH 2 Antworten Letzte Antwort
                              • arteckA arteck
                                @arteck sagte in Zigbee Netzwerk Aufbau:
                                Hab ich gesehen, ich meinter aber das Hinzufügen einer Instanz. Das muss der geneigte git-user halt selber machen.
                                • Hot-Air-BalloonH Offline
                                  Hot-Air-Balloon
                                  @arteck Bevor ich jetzt wieder was ausführe, von dem ich keine Ahnung habe aber meine es hört sich gut an..
                                  cd /opt/iobroker
                                  sudo iobroker stop
                                  sudo iobroker add Zigbee
                                  sudo iobroker start
                                  Ist das so richtig ?
                                    cd /opt/iobroker
                                    sudo iobroker stop
                                    sudo iobroker start
                                    @hot-air-balloon
                                    Nein, NIE NIE NIE NIEMALS iobroker mit sudo anpacken. NIE.
                                    Instanz z. B. über die GUI:
                                      @hot-air-balloon
                                      Hot-Air-Balloon
                                      @thomas-braun Wo finde ich denn das ? Ich habe trotz suchen in allen Bereichen die Option zum hinzufügen von Instanzen nicht gefunden.
                                      Nur halt auf dem Adapter, wenn eine instanz schon installiert ist.
                                        @hot-air-balloon
                                        Dazu muss der 'Experten-Modus' aktiviert sein.
                                          @hot-air-balloon
                                          Hot-Air-Balloon
                                          @thomas-braun Der ist aktiv, aber es gibt ja kein Adapter und keine Instanz nach der installation von GIT:
