  3. Einsteigerfragen
  4. Zigbee Netzwerk Aufbau
    5.6k
77 Beiträge 8 Kommentatoren 11.2k Aufrufe 7 Beobachtet
    @hot-air-balloon
    Das ist Quark. Schau in meiner Signatur wie es richtig gemacht wird und wie man den Mist wieder los wird
    Hot-Air-BalloonH Offline
    Hot-Air-Balloon
    Danke !
    Jetzt sieht es so aus:
    • Hot-Air-BalloonH Hot-Air-Balloon
      Danke !
      @hot-air-balloon
      Bitte keine Screenshots aus der Konsole.
      Als Text (in CodeTags eingebettet) hier rein kopieren.
      5c424217-50fa-4d46-b362-b4381e24bdda-image.png ```
      code_text
      Hot-Air-BalloonH 1 Antwort Letzte Antwort
        @hot-air-balloon
        code_text
        Hot-Air-Balloon
        Verstanden
        host.ioBroker
        	2022-07-13 12:02:12.568	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.ioBroker
        	2022-07-13 12:02:12.568	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.ioBroker
        	2022-07-13 12:02:12.568	error	Caught by controller[1]: at processImmediate (node:internal/timers:466:21)
        host.ioBroker
        	2022-07-13 12:02:12.568	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37)
        host.ioBroker
        	2022-07-13 12:02:12.568	error	Caught by controller[1]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34)
        host.ioBroker
        	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Zigbee.emit (node:domain:475:12)
        host.ioBroker
        	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Zigbee.emit (node:events:539:35)
        host.ioBroker
        	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:76:30)
        host.ioBroker
        	2022-07-13 12:02:12.567	error	Caught by controller[1]: at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:455:52)
        host.ioBroker
        	2022-07-13 12:02:12.567	error	Caught by controller[1]: at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:935:54)
        host.ioBroker
        	2022-07-13 12:02:12.567	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'waitFor')
        host.ioBroker
        	2022-07-13 12:02:12.566	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        zigbee.0
        	2022-07-13 12:02:11.947	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        zigbee.0
        	2022-07-13 12:02:11.945	info	terminating
        zigbee.0
        	2022-07-13 12:02:11.465	info	Zigbee: disabling joining new devices.
        zigbee.0
        	2022-07-13 12:02:11.444	info	cleaned everything up...
        zigbee.0
        	2022-07-13 12:02:11.411	error	Cannot read properties of undefined (reading 'waitFor')
        zigbee.0
        	2022-07-13 12:02:11.410	error	TypeError: Cannot read properties of undefined (reading 'waitFor') at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:935:54) at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:455:52) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:76:30) at Zigbee.emit (node:events:539:35) at Zigbee.emit (node:domain:475:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:466:21)
        zigbee.0
        	2022-07-13 12:02:11.255	error	unhandled promise rejection: Cannot read properties of undefined (reading 'waitFor')
        zigbee.0
        	2022-07-13 12:02:11.255	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        Die Meldung bekomme ich jetzt, wenn ich nach einem Netzwerk scanne.
          Verstanden
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          @hot-air-balloon
          Du hast gesehen, dass node und npm noch im falschen Pfad ist und das korrigiert?
            @hot-air-balloon
            Hot-Air-Balloon
            @thomas-braun Ehrlich gesagt nicht. Wie gesagt, ich bin auf dem Gebiet hier ein blutiger Anfänger.
            Schade, dass das install bash das nicht direkt sauber konfiguriert.
              @hot-air-balloon
              Macht es. Aber es kann natürlich die über einen anderen Installationsweg ins System gebügelte Installation nicht rauskratzen. Das mußte du schon selber wieder reparieren.
                @hot-air-balloon
                Hot-Air-Balloon
                schrieb am zuletzt editiert von Hot-Air-Balloon
                Also meine ioBroker Installation sah wie folgt aus:
                Raspberry OS auf die SD Karte schreiben und den PI damit starten. Pi Updaten und dann die ioBroker Install bash ausführen. Mehr habe ich nicht gemacht, alles was auf dem Pi läuft ist entweder teil der standard Installation oder kommt von der ioBroker Installation.
                Was ist deine Empfehlung, wie ziehe ich das grade ? Wie gesagt ich habe mich noch nie mit node beschäftigt und was ich bislang im Internet gefunden habe, schien ja alles falsch zu sein. Dein Anleitung zeigt leider keine saubere Deinstallation, dann wäre ich danach noch mal von vorne angefangen.
                sudo apt-get purge -y nodejs
                Ich habs mal so entfernt und deine Anleitung gefolgt, trotzdem landet die installation im local Ordner und nicht im bin
                  Also auch falsch ? :(
                  node -v
                  hatte mir 14.x ausgegeben, dann habe ich
                  sudo npm install -g n
                  ausgeführt und dann:
                  sudo n stable
                  hatte das so im Netz gefunden. Hab mit node noch keine Berührungspunkte gehabt.
                  @hot-air-balloon sagte in Zigbee Netzwerk Aufbau:
                  sudo n stable
                  Das ist NICHT Teil der Standardinstallation, das hast du weiß der Geier woher. Das steht in keinem unserer HowTos zu nodeJS drin.
                  Da kommen aber die Installationen in /use/local/bin her. Also bitte nicht behaupten, man habe eine Standardinstallation.
                  Wie man die los wird steht auch in meinem How to drin. Im zweiten Teil, falls du bis dort nicht gelesen hast.
                    @hot-air-balloon
                    Sehr lange dauert das, weil du vermutlich nicht die aktuell empfohlene nodejs/npm Versionen installiert hast. Mit nodejs16 sollte das schneller gehen.
                    Hot-Air-Balloon
                    @thomas-braun said in Zigbee Netzwerk Aufbau:
                    sudo n stable
                    Also .... ich habe mein ioBroker wie in dem posting gerade beschrieben installiert. Darauf bezog sich die Aussage mit der Standard Installation. Nach deiner Aussage:
                    @hot-air-balloon
                    habe ich die von dir gerade geqoteten Befehle ausgeführt. Davor war aber schon ein Node 14 installiert... lange rede... was kann ich also machen und kann mir dabei einer helfen?
                      sudo n stable
                      @hot-air-balloon
                      @hot-air-balloon
                      Wie schon gesagt: Es steht alles in meinem How to drin.
                        @hot-air-balloon
                        Hot-Air-Balloon
                        Danke, ich denke ich habe es hinbekommen:
                        pi@ioBroker:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        aarch64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.16.0
                        v16.16.0
                        8.11.0
                        pi
                        /home/pi
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
                        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Reading package lists... Done
                        All packages are up to date.
                        nodejs:
                          Installed: 16.16.0-deb-1nodesource1
                          Candidate: 16.16.0-deb-1nodesource1
                          Version table:
                         *** 16.16.0-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                             12.22.12~dfsg-1~deb11u1 500
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                             12.22.5~dfsg-2~11u1 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        Also Jetzt zuerst den normalen Zigbee Adapter installieren, dann den von GIT ?
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          gu kannst den direkt von git nehmen
                          • arteckA arteck
                            Hot-Air-Balloon
                            @arteck Danke, das habe ich jetzt gemacht, der bringt aber keine Instanz und auch kein Eintrag im Menü mit.
                            $ iobroker url ioBroker/ioBroker.zigbee --host ioBroker
                            install ioBroker/ioBroker.zigbee
                            NPM version: 8.11.0
                            Installing ioBroker/ioBroker.zigbee... (System call)
                            added 44 packages in 31s60 packages are looking for funding run `npm fund` for details
                            upload [311] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                            upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                            upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                            upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                            upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
                            upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
                            upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
                            upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                            upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
                            upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
                            upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                            upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                            upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                            upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                            upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                            upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                            upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                            upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                            upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                            upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                            upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                            upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                            upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                            upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                            upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                            upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                            upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                            upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                            upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                            upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                            upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                            upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                            upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                            upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                            Process exited with code 0
                            arteckA Thomas BraunT 2 Antworten Letzte Antwort
                              NPM version: 8.11.0
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @hot-air-balloon die insanz musst du selber hinzufügen
                                NPM version: 8.11.0
                                Machen git-Installationen nie, die Instanz muss händisch hinzugefügt werden.
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  @thomas-braun sagte in Zigbee Netzwerk Aufbau:
                                  jaja... kam ja von mir. also alles gut..ist ja ne Ausnahme
                                  Thomas BraunT Hot-Air-BalloonH 2 Antworten Letzte Antwort
                                  • arteckA arteck
                                    @arteck sagte in Zigbee Netzwerk Aufbau:
                                    Hab ich gesehen, ich meinter aber das Hinzufügen einer Instanz. Das muss der geneigte git-user halt selber machen.
                                    • Hot-Air-BalloonH Offline
                                      Hot-Air-Balloon
                                      @arteck Bevor ich jetzt wieder was ausführe, von dem ich keine Ahnung habe aber meine es hört sich gut an..
                                      cd /opt/iobroker
                                      sudo iobroker stop
                                      sudo iobroker add Zigbee
                                      sudo iobroker start
                                      Ist das so richtig ?
                                        cd /opt/iobroker
                                        sudo iobroker stop
                                        sudo iobroker start
                                        @hot-air-balloon
                                        Nein, NIE NIE NIE NIEMALS iobroker mit sudo anpacken. NIE.
                                        Instanz z. B. über die GUI:
                                          @hot-air-balloon
                                          Hot-Air-Balloon
                                          @thomas-braun Wo finde ich denn das ? Ich habe trotz suchen in allen Bereichen die Option zum hinzufügen von Instanzen nicht gefunden.
                                          Nur halt auf dem Adapter, wenn eine instanz schon installiert ist.
