  4. Mihome Vacuum Karte
    5.8k
Mihome Vacuum Karte
66 Beiträge 8 Kommentatoren 7.8k Aufrufe 6 Beobachtet
    @tobitobsta
    11GB Klopper sind halt schwer zu handeln. Das passt in den Speicher ja nicht rein.
    Was kommt denn im tail immer dazu? Das muss ja rappeln, dass da GBweise Text zusammen kommt.
    tobitobsta
    also nun passiert hier was
    iobroker log zeigt immer wieder das hier:
    host.haustuerpi
    2022-07-07 13:21:19.517	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    host.haustuerpi
    2022-07-07 13:21:19.516	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
    mihome-vacuum.0
    2022-07-07 13:21:16.197	info	Room array empty... generate from mapdata.. [[17,"room17"],[21,"room21"],[20,"room20"],[19,"room19"],[16,"room16"],[22,"room22"],[18,"room18"],[23,"room23"],[1,"room1"]]
    host.haustuerpi
    2022-07-07 14:59:42.236	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    host.haustuerpi
    2022-07-07 14:59:42.235	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    host.haustuerpi
    2022-07-07 14:59:42.234	error	Caught by controller[0]: free(): invalid pointer
    mihome-vacuum.0
    2022-07-07 14:59:40.988	info	Room array empty... generate from mapdata.. [[17,"room17"],[21,"room21"],[20,"room20"],[19,"room19"],[16,"room16"],[22,"room22"],[18,"room18"],[23,"room23"],[1,"room1"]]
    host.haustuerpi
    2022-07-07 19:08:39.472	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    host.haustuerpi
    2022-07-07 19:08:39.471	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    host.haustuerpi
    2022-07-07 19:08:39.470	error	Caught by controller[0]: munmap_chunk(): invalid pointer
    mihome-vacuum.0
    2022-07-07 19:08:38.275	info	Room array empty... generate from mapdata.. [[17,"room17"],[21,"room21"],[20,"room20"],[19,"room19"],[16,"room16"],[22,"room22"],[18,"room18"],[23,"room23"],[1,"room1"]]
    ... aber evtl ist es ja ein Folgefehler aufgrund des übergelaufenen Filesystems....
    ich konnte aber mit less an die Stelle im syslog scrollen wo es meiner Meinung nach interessant wird:
    Jul  7 19:08:39 haustuerpi bash[475]: munmap_chunk(): invalid pointer
    Jul  7 19:08:50 haustuerpi kernel: [29526.174369] device eth0 entered promiscuous mode
    Jul  7 19:08:56 haustuerpi kernel: [29532.033920] device eth0 left promiscuous mode
    Jul  7 19:09:01 haustuerpi CRON[13730]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
    Jul  7 19:09:18 haustuerpi bash[475]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    Jul  7 19:09:18 haustuerpi bash[475]: cat: /sys/class/net/wlan0/statistics/rx_bytes: Datei oder Verzeichnis nicht gefunden
    Jul  7 19:09:18 haustuerpi bash[475]: cat: /sys/class/net/wlan0/statistics/tx_bytes: Datei oder Verzeichnis nicht gefunden
    Jul  7 19:09:20 haustuerpi systemd[1]: Starting Clean php session files...
    Jul  7 19:09:21 haustuerpi systemd[1]: phpsessionclean.service: Succeeded.
    Jul  7 19:09:21 haustuerpi systemd[1]: Started Clean php session files.
    Jul  7 19:09:24 haustuerpi bash[475]: #
    Jul  7 19:09:24 haustuerpi bash[475]: # Fatal error in , line 0
    Jul  7 19:09:24 haustuerpi bash[475]: # Check failed: !backing_store->is_wasm_memory().
    Jul  7 19:09:24 haustuerpi bash[475]: #FailureMessage Object: 0xbe8323a0
    Jul  7 19:09:24 haustuerpi kernel: [29560.437554] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
    Jul  7 19:09:24 haustuerpi kernel: [29560.437656] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
    Jul  7 19:09:24 haustuerpi kernel: [29560.437695] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
    Jul  7 19:09:24 haustuerpi kernel: [29560.437732] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
    Jul  7 19:09:24 haustuerpi kernel: [29560.437768] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
    Jul  7 19:09:24 haustuerpi kernel: [29560.437805] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
    Jul  7 19:09:24 haustuerpi kernel: [29560.437841] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
    ... und das zieht er dann durch bis um ca 22:05 scheinbar die Platte voll war.... das ist Zeitlich auch passend zum iobroker log.
    • Thomas BraunT Online
      @tobitobsta sagte in Mihome Vacuum Karte:
      https://forum.iobroker.net/topic/54012/iobroker-kernel-unhandled-prefetch-abort-breakpoint-debug
      Hier auch der mihome-vacuum.
      Mach mal ein issue auf. Auch wenn das vermutlich schwer sein wird da zu debuggen.
        tobitobsta
        @thomas-braun said in Mihome Vacuum Karte:
        unschuldige meine Unwissenheit: wo soll ich ein issue aufmachen?
          @tobitobsta
          Hier:
          https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
            @tobitobsta
            Hier:
            D Nicht stören
            D Nicht stören
            dirkhe
            @thomas-braun Macht meiner Meinung nach keinen Sinn. Das wird dann die canvas lib sein, die muß wahrscheinlich neu gebildet werden. Die macht öfter Probleme. Da hilf ggf. die Karte auszuschalten.
            • D dirkhe
              @dirkhe sagte in Mihome Vacuum Karte:
              Möglich. Aber die sollte eigentlich den Kernel kalt lassen.
              @tobitobsta
              Wie schaut denn canvas aus?
              cd /opt/iobroker
              npm ls canvas
              D T 2 Antworten Letzte Antwort
                @tobitobsta
                cd /opt/iobroker
                npm ls canvas
                D Nicht stören
                D Nicht stören
                dirkhe
                @thomas-braun ich gehe davon aus, dass der Speicher falsch angesprochen wird, man sieht da ja, dass er auf falsche Speicherbereiche zugreifen will. Sieht füt mich nach 32 und 64 bit mix aus
                  @tobitobsta
                  cd /opt/iobroker
                  npm ls canvas
                  tobitobsta
                  @tobitobsta
                  cd /opt/iobroker
                  npm ls canvas
                  iobroker.inst@2.0.3 /opt/iobroker
                  └─┬ iobroker.mihome-vacuum@3.5.0
                    └── canvas@2.9.3
                  • D dirkhe
                    Ja, das könnte sein.
                    Aber wie bekommt man so einen Mix rein? Der Paketmanager zieht eigentlich die richtige Archtiektur rein...
                    • T tobitobsta
                      @tobitobsta
                      cd /opt/iobroker
                      npm ls canvas
                        └── canvas@2.9.3
                      @tobitobsta
                      uname -a
                      apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                      sagt?
                        D Nicht stören
                        D Nicht stören
                        dirkhe
                        @thomas-braun ich hatte das letztens auch auf meinem raspi, nicht mit dem canvas, sondern mit dem ble adapter. Da waren irgendwelche structs in headern bereits auf 64bit gestzt, obwohl es ein 32bit System ist. An andere Stelle habe ich auch irgendwo gelesen, dass nodejs 32bit auch nicht mehr unterstützt.
                          tobitobsta
                          Kann schon sein dass ich da viel Quatsch gemacht habe - hatte schonmal Probleme mit der Karte gehabt und hatte da Tipps gefunden wie man canvas nach installiert.
                          Dachte aber mit deinstallieren und installieren des Adapters baut er mit allen Abhängigkeiten neu. Evtl hätte ich aber vor der Adapter Neuinstallation auch erstmal gezielt auch die canvas lib nochmal runternehmen? Wenn ja, wie würde ich das machen können?
                            @tobitobsta
                            uname -a
                            sagt?
                            tobitobsta
                            @tobitobsta
                            uname -a
                            sagt?
                            Linux haustuerpi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
                            build-essential:
                              Installiert:           12.6
                              Installationskandidat: 12.6
                              Versionstabelle:
                             *** 12.6 500
                            libcairo2-dev:
                              Installiert:           1.16.0-4+rpt1
                              Installationskandidat: 1.16.0-4+rpt1
                              Versionstabelle:
                             *** 1.16.0-4+rpt1 500
                                    500 http://archive.raspberrypi.org/debian buster/main armhf Packages
                                 1.16.0-4+deb10u1 500
                            libpango1.0-dev:
                              Installiert:           1.42.4-8~deb10u1
                              Installationskandidat: 1.42.4-8~deb10u1
                              Versionstabelle:
                             *** 1.42.4-8~deb10u1 500
                            libjpeg-dev:
                              Installiert:           1:1.5.2-2+deb10u1
                              Installationskandidat: 1:1.5.2-2+deb10u1
                              Versionstabelle:
                             *** 1:1.5.2-2+deb10u1 500
                            libgif-dev:
                              Installiert:           5.1.4-3
                              Installationskandidat: 5.1.4-3
                              Versionstabelle:
                             *** 5.1.4-3 500
                            librsvg2-dev:
                              Installiert:           2.44.10-2.1+rpi1
                              Installationskandidat: 2.44.10-2.1+rpi1
                              Versionstabelle:
                             *** 2.44.10-2.1+rpi1 500
                            • T tobitobsta
                              @tobitobsta
                              uname -a
                              sagt?
                              build-essential:
                                Installiert:           12.6
                                Versionstabelle:
                               *** 12.6 500
                              libcairo2-dev:
                                Versionstabelle:
                              libpango1.0-dev:
                                Versionstabelle:
                              libjpeg-dev:
                                Versionstabelle:
                              libgif-dev:
                                Versionstabelle:
                               *** 5.1.4-3 500
                              librsvg2-dev:
                                Versionstabelle:
                              @tobitobsta
                              Passt soweit.
                              Aber vielleicht wäre es auch eine gute Gelegenheit ein 64bit-Bullseye frisch zu installieren und dort ein Backup des iobrokers einzuspielen.
                              Buster erreicht ohnehin in wenigen Wochen das EndOfLife.
                                @tobitobsta
                                Passt soweit.
                                tobitobsta
                                #66
                                @tobitobsta
                                Danke für den Hinweis! Werd ich dann wohl bei Client und Host bald mal machen müssen.
