  4. iobroker startet alle 30 Sekunden neu
    5.8k
83 Beiträge 8 Kommentatoren 3.6k Aufrufe 6 Beobachtet
  • D daza04
    @thomas-braun said in iobroker startet alle 30 Sekunden neu:
    @daza04
    1,8 GB ist auch heftig viel.
    Ich hab aber keine Ahnung wo das herkommt.
    iobroker update -i
    sagt?
    Ich leider auch nicht...
    Könnte mal die History stoppen und schauen wie es sich in einer Woche verhält.
     iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.9    , installed 2.4.6  [Updatable]
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
    Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
    Adapter    "ham"          : 4.0.2    , installed 4.0.2
    Adapter    "history"      : 1.11.1   , installed 1.11.1
    Adapter    "hmip"         : 1.17.0   , installed 1.15.4 [Updatable]
    Adapter    "ical"         : 1.12.1   , installed 1.12.1
    Adapter    "info"         : 1.9.19   , installed 1.9.18 [Updatable]
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
    Adapter    "linkeddevices": 1.4.3    , installed 1.4.3
    Adapter    "modbus"       : 5.0.4    , installed 4.0.4  [Updatable]
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "ring"         : 3.0.4    , installed 1.2.8  [Updatable]
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.6.4  [Updatable]
    Adapter    "synology"     : 2.1.7    , installed 2.1.6  [Updatable]
    Adapter    "telegram"     : 1.13.0   , installed 1.12.2 [Updatable]
    Adapter    "terminal"     : 0.2.6    , installed 0.2.2  [Updatable]
    Adapter    "trashschedule": 2.0.2    , installed 1.2.0  [Updatable]
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
    Adapter    "web"          : 4.3.0    , installed 4.2.3  [Updatable]
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Adapter    "zigbee"       : 1.7.5    , installed 1.6.16 [Updatable]
    @daza04 sagte in iobroker startet alle 30 Sekunden neu:
    warum?
    das hat nichts mit den historisierten Daten zu tun.
    Das sind deine ganz normalen Zustände
    • D daza04
      @daza04
      iobroker update -i
      sagt?
       iobroker update -i
      @daza04
      Und du könntest den Update-Stau auflösen.
        warum?
        daza04
        schrieb am zuletzt editiert von daza04
        hmm, okay. Aber was heißt das jetzt genau?
        Ich meine nicht übermäßig viele zu haben...
          @daza04
          daza04
          Na klar, das mache ich ab und an mal...
          • D daza04
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            #66
            nuja, eher nicht 😛😉
            Lehrling seit 1975 !!!
              daza04
              #67
              So siehts jetzt im laufenden (älterer Stand) System aus:
              Vielleicht hilft das ja bei der Fehlersuche....
                daza04
                #68
                Was könnte der Grund für ein immer grösser werdendes states.json file sein?
                G 1 Antwort Letzte Antwort
                • D daza04
                  guergen
                  #69
                  @daza04 Ich habe im Moment auch immer mal das Problem, dass Iob neu startet. (Beta repo, alles aktuell)
                  Wenn ich mal dirket dabei bin, frage ich auch den iob status ab und bekomme ebenfalls:
                  iobroker status
                  Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                  Meine states sieht folgendermassen aus:
                  iob@iob:/opt/iobroker/iobroker-data$ ls -lh *states*
                  -rw-rwxr--+ 1 iobroker iobroker 7,8M  8. Feb 18:42 states.json.bak.migrated
                  -rw-rwxr--+ 1 iobroker iobroker    0  6. Feb 09:59 states.json.broken
                  -rw-rw-r--+ 1 iobroker iobroker  54M 28. Jun 13:52 states.jsonl
                  -rw-rwxr--+ 1 iobroker iobroker 7,8M  8. Feb 18:43 states.json.migrated
                  -rw-rwxr--+ 1 iobroker iobroker 2,5M 10. Nov 2021  states.json.old
                  • G guergen
                    iobroker status
                    #70
                    @guergen
                    Läuft da vielleicht schon was anderes auf dem Port 9000?
                      @guergen
                      guergen
                      #71
                      @thomas-braun Nein, macht es nicht. 5 sek. später ist auch wieder alles ok.
                      Dann startet das System wieder und läuft erst mal.
                        daza04
                        #72
                        Ist jetzt schon wieder bei:
                        daniel@iobroker:~$ ls -lh /opt/iobroker/iobroker-data/states.jsonl
                        -rw-rwxr--+ 1 iobroker iobroker 3.4G Jul  3 06:07 /opt/iobroker/iobroker-data/states.jsonl
                        Was kann denn der Grund für den immer größer werden states.jsonl sein?
                        • D daza04
                          BananaJoeB Online
                          BananaJoeB Online
                          BananaJoe
                          #73
                          Ich war der Meinung das man im Objekte-Browser in einer Ansicht sehen kann wie viele Objekte hinter Adaptern etc. liegen ... finde ich im Admin 6 gerade nicht wieder ...
                          • BananaJoeB BananaJoe
                            daza04
                            #74
                            @bananajoe
                            Hmm okay, mich wundert nur dass die Datei größer und größer wird und andere hier von einer Größe < 1mb reden...
                            D BananaJoeB 2 Antworten Letzte Antwort
                            • D daza04
                              @bananajoe
                              daza04
                              #75
                              Vielleicht könnte das helfen?!
                              https://crycode.de/homepi-gundlagen-und-installation-von-iobroker#redis
                              Probiere ich später mal
                              • D daza04
                                @bananajoe
                                BananaJoeB Online
                                BananaJoeB Online
                                BananaJoe
                                #76
                                @daza04 naja, die Idee war festzustellen wo die ganzen Datenpunkte denn liegen, sprich welcher Adapter die erzeugt.
                                Wenn du im Objekte-Explorer einen Adapter markierst und oben auf Export klickst steht im Dialog dann wie viele Objekte (Sprich Datenpunkte + Ordner) er exportieren würde.
                                Ein Grund für eine große States-Datei wären nämlich aus meiner Sicht viele Datenpunkte.
                                Die andere Möglichkeit wären Datenpunkten in denen viele Daten stehen - ich weis aus dem Kopf aber gerade nicht wieviel Bytes man da in so einen Datenpunkt reinbekommt, aber man kann da auch ein ganzen Bild drin speichern. Beim Regenradar wird da zum Beispiel eine Gif-Animation drin gespeichert. Und dann hättest du ganz schnell eine ganz große Datei. Wenn auch nicht im GigaByte Bereich
                                  daza04
                                  #77
                                  @bananajoe
                                  Würde aber das Problem nicht lösen.
                                  Alle Datenpunkte benötige ich ja irgendwie. Möchte nicht ausschießen, dass man da etwas charmanter machen kann...
                                  Nehmen wir aber nur mal den, sind es erstmal nicht so viele...
                                  Habe den Wert jetzt mal hochgestellt.
                                  Wird dann aber nur länger dauern bis der states.jsonl mal wieder groß ist...
                                  Die Frage, WARUM?! :-P
                                  BananaJoeB D 2 Antworten Letzte Antwort
                                  • D daza04
                                    @bananajoe
                                    BananaJoeB Online
                                    BananaJoeB Online
                                    BananaJoe
                                    #78
                                    @daza04 ich meinte eigentlich eher die Datenpunkte der ganzen Adapter.
                                      #79
                                      @bananajoe sagte: eher die Datenpunkte der ganzen Adapter.
                                      Im Tab "Objekte" ganz oben rechts?
                                      • BananaJoeB Online
                                        BananaJoeB Online
                                        BananaJoe
                                        #80
                                        @paul53 mhh das ist wirklich nicht sehr viel, ich hab da 34050 / 31126 und meine redis-Datenbank ist 16 Megabyte groß
                                        • BananaJoeB Online
                                          BananaJoeB Online
                                          BananaJoe
                                          #81
                                          Eigentlich ist das ja eine stinknormale Textdatei und man könnte reinschauen was da so groß ist ... mit etwas was 3,4 Gigabyte frisst.
                                          Pro Zeile ist ein Datenpunkt beschrieben ... man bräuchte etwas was die Datei statistisch auswerten kann
