  4. Lidl Silvercrest Smart Button *gelöst*
    6.3k
65 Beiträge 10 Kommentatoren 11.0k Aufrufe 8 Beobachtet
  • G gluecksmann
    So, updates gemacht... weiterhin beta
    Used repository: beta
    Adapter    "admin"        : 6.0.8    , installed 6.0.7  [Updatable]
    Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "ble"          : 0.13.0   , installed 0.13.0
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "history"      : 2.1.4    , installed 2.1.4
    Adapter    "hue"          : 3.7.0    , installed 3.7.0
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.0   , installed 1.13.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.7   , installed 1.11.7
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
    Adapter    "mielecloudservice": 6.3.2, installed 6.3.2
    Adapter    "musiccast"    : 0.2.2    , installed 0.2.2
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
    Adapter    "socketio"     : 6.1.7    , installed 6.1.7
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sonos"        : 2.2.2    , installed 2.2.2
    Adapter    "trashschedule": 2.0.3    , installed 1.4.5  [Updatable]
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.43
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 5.2.3    , installed 5.2.3
    Adapter    "ws"           : 2.1.2    , installed 2.1.2
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    @gluecksmann sagte in Lidl Silvercrest Smart Button:
    So, updates gemacht
    warum??
    vorher hättest du auf stable umstellen müssen
    jetzt hast du die frischesten Beta-Versionen
    G 1 Antwort Letzte Antwort
      So, updates gemacht
      warum??
      gluecksmann
      OK, das habe ich falsch verstanden... immerhin habe ich jetzt umgestellt...hab aber an der Sitoation nix geändert....
      • G gluecksmann
        und die wäre aktuell?
        nach reboot? und Browser refresh?
        • G gluecksmann
          Hallo, hat es schon jemand hinbekommen den SmartButton anzumelden UND auch zu nutzen? Abgemeldet habe ich ihn scheinbar bekommen. Aber die Objecte ändern Ihren Status nicht. Sehe auch etwas komisch aus...
          O Offline
          O Offline
          oFbEQnpoLKKl6mbY5e13
          @gluecksmann
          Wenn du den HG08164 meinst, dann sehen die Datenpunkte korrekt aus. Der läuft bei mir seit heute einwandfrei. Die Datenpunkte ändern sehr kurz ihren Wert auf True und dann wieder zurück auf False. Das kann der Admin nicht anzeigen. Wenn du wirklich wissen willst, ob der richtig funktioniert, dann mach dir ein Skript, was auf die Datenpunkte triggert und gib einen Text im Log aus.
          • O oFbEQnpoLKKl6mbY5e13
            @gluecksmann
            gluecksmann
            @ofbeqnpolkkl6mby5e13 Hallo...na das wäre ja nen Ding.... teste ich gleich mal....
            • G gluecksmann
              gluecksmann
              @gluecksmann
              Hmmm...wie bekomme ich den richtig gekoppelt?
              O 1 Antwort Letzte Antwort
              • G gluecksmann
                @gluecksmann
                O Offline
                O Offline
                @gluecksmann
                Was ist denn falsch?
                  @gluecksmann
                  gluecksmann
                  @ofbeqnpolkkl6mby5e13 Das Zeichen ganz rechts oben in der Ecke? Müßte das nicht ein anderes sein? Außerdem sieht es bei den Objekten so aus...
                  • G gluecksmann
                    O Offline
                    O Offline
                    @gluecksmann
                    Ist ja ein Batteriegerät, das geht schlafen, um Energie zu sparen. Hast du dir ein Skript gebaut, um die Funktion zu prüfen?
                      @gluecksmann
                      gluecksmann
                      schrieb am zuletzt editiert von gluecksmann
                      Ist tatsächlich so das die Änderung scheinbar nur sehr kurz dauert..... werde gleich mal den Ikea Schalter testen...da hatte ich ähnliche Probleme...danke für die Hilfe.... muß dann nur noch sehen wie der doppelklick genutzt werden kann...
                      • G gluecksmann
                        O Offline
                        O Offline
                        @gluecksmann
                        Einmal drücken = "on" geht kurz auf True und fällt wieder auf False zurück
                        Zweimal schnell hintereinander drücken = "off" geht kurz auf True und fällt wieder auf False zurück
                        Halten = "brightness_step_up" wechselt so lange zwischen True und False bis "brightness_step_down" zwischen True und False wechselt und wieder von vorn...
                        Loslassen = "brightness_stop" geht kurz auf True und fällt wieder auf False zurück
                        G O 2 Antworten Letzte Antwort
                          @gluecksmann
                          gluecksmann
                          Hmmm...verstehe jetzt den Unterschied zwischen einmal und zweimal schnell nicht.... Wie schalte ich jetzt was an, und dann wieder aus?
                          • G gluecksmann
                            O Offline
                            O Offline
                            @gluecksmann
                            Bei zweimal Drücken geht der Datenpunkt "off" auf True statt der Datenpunkt "on".
                            G K 2 Antworten Letzte Antwort
                              @gluecksmann
                              gluecksmann
                              Ups.... danke... macht ja auch Sinn...
                              • G gluecksmann
                                bigfun_de
                                Hallo ich habe mir den Button auch gekauft und bekomme ihn nicht gekoppelt.
                                Mein System ist ein pi3 mit den deConz-Stick.
                                pi@iobroker-pi:~ $ iobroker update -i
                                Used repository: stable
                                Adapter    "admin"        : 5.3.8    , installed 5.3.8
                                Adapter    "denon"        : 1.13.4   , installed 1.13.4
                                Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                                Adapter    "echarts"      : 1.0.7    , installed 1.0.7
                                Controller "js-controller": 4.0.23   , installed 4.0.23
                                Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                                Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
                                Wenn ich in Zigbee-Adapter auf pairing gehe, passiert nichts.
                                Im log steht:
                                Error: Failed to touchlinkReset Error: Touchlink operation already in progress
                                    at Touchlink.lock (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/touchlink.ts:20:19)
                                    at Touchlink.factoryResetFirst (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/touchlink.ts:110:14)
                                    at Controller.touchlinkFactoryResetFirst (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:202:31)
                                    at ZigbeeController.touchlinkReset (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:913:33)
                                    at Commands.touchlinkReset (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:156:31)
                                    at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:56:30)
                                    at Zigbee.emit (events.js:412:35)
                                    at Zigbee.emit (domain.js:475:12)
                                    at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5824:34)
                                    at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37). undefined
                                Touchlink reset started
                                Ich kann den Fehler leider nicht sogrichtig deuten :-(
                                Alle anderen Geräte gehen ja.
                                • B bigfun_de
                                  Im log steht:
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @bigfun_de der Fehler deutet darauf hin das du mehrfach versucht hast einen touchlink-reset durchzuführen ohne zu warten was passiert.
                                  Er hat mit dem Gerät selber nichts zu tun.
                                  A.
                                  • AsgothianA Asgothian
                                    A.
                                    bigfun_de
                                    @asgothian
                                    Danke für die Rückmeldung!
                                    Wenn die Meldung mit dem Pairing nichts zu tun hat, woran kann es liegen, dass der Button nicht erkannt wird.
                                    Zur Ergänzung, ich habe den deConz II Stick.
                                      @gluecksmann
                                      kamolus
                                      @ofbeqnpolkkl6mby5e13 said in Lidl Silvercrest Smart Button *gelöst*:
                                      @gluecksmann
                                      Hallo, ich bekomme den script nicht zum laufen
                                      • K kamolus
                                        @gluecksmann
                                        kamolus
                                        @kamolus said in Lidl Silvercrest Smart Button *gelöst*:
                                        @gluecksmann
                                        "on/off state of the switch" ist das selbst erzeugte Datapunkt in 0_datauser ?
                                        Ändert sich gar nicht.
                                        Das funktioniert aber tadellos
                                        • K kamolus
                                          @gluecksmann
                                          kamolus
                                          @gluecksmann
