  4. Test Adapter Meteoalarm v2.0.x
    6.6k
412 Beiträge 19 Kommentatoren 112.8k Aufrufe 19 Beobachtet
  • JackDanielJ Offline
    JackDanielJ Offline
    JackDaniel
    #187
    danke tut wieder ohne fehler 👍
    host.iobroker
    2022-06-14 09:30:06.214	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
    meteoalarm.0
    2022-06-14 09:30:05.186	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
    host.iobroker
    2022-06-14 09:30:04.048	info	instance system.adapter.meteoalarm.0 started with pid 1086108
    host.iobroker
    2022-06-14 09:20:06.074	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
    meteoalarm.0
    2022-06-14 09:20:05.171	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
    host.iobroker
    2022-06-14 09:20:04.058	info	instance system.adapter.meteoalarm.0 started with pid 1085719
    host.iobroker
    2022-06-14 09:10:06.125	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
    meteoalarm.0
    2022-06-14 09:10:05.150	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
    host.iobroker
    2022-06-14 09:10:04.058	info	instance system.adapter.meteoalarm.0 started with pid 1085344
    host.iobroker
    2022-06-14 09:00:06.211	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
    meteoalarm.0
    2022-06-14 09:00:05.188	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
    host.iobroker
    2022-06-14 09:00:04.071	info	instance system.adapter.meteoalarm.0 started with pid 1084912
    host.iobroker
    2022-06-14 08:50:02.150	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
    meteoalarm.0
    2022-06-14 08:50:01.255	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
    host.iobroker
    2022-06-14 08:50:00.039	info	instance system.adapter.meteoalarm.0 started with pid 1084526
    host.iobroker
    2022-06-14 08:49:23.586	info	instance scheduled system.adapter.meteoalarm.0 */10 * * * *
    Carpe diem
    • da_WoodyD Online
      da_WoodyD Online
      #188
      @jackblackson sag mal, siehst du eine möglichkeit nicht nur html, sonder das auch als JSON auszugeben in den objekten?
      jackblacksonJ 1 Antwort Letzte Antwort
      • da_WoodyD da_Woody
        jackblacksonJ Offline
        jackblackson
        #189
        @da_woody Möglich ist alles. Die Frage ist, wie sollte dass aussehen - sprich welche Spalten, mit Überschrift,…?
        • jackblacksonJ jackblackson
          da_WoodyD Online
          da_WoodyD Online
          #190
          @jackblackson mein problem ist, daß iQontrol mit dem html die höhe der kachel nicht anpassen kann. dadurch muss ich html als state verwenden, da wird aber dann die datum/zeit nicht angezeigt. ist das die überschrift? ist blöd, weil gestern schon die warnung für heute drinnen war.
          wenn ich die json aber in ein widget einbinde, wird die höhe angepasst. sieht man da jetzt nicht, da nur eine meldung ist, bei mehreren wird dann unten abgeschnitten.
          aufgefallen ist mir das beim neuen device watcher adapter. der passt als widget mit einer jsontable die höhe automatisch an...
          hoffe dich jetzt genug verwirrt zu haben... :D mitm erklären ist das so eine sache bei mir. ;)
          als nichtprogger kann ich nicht abschätzen wie kompliziert das ist. wenns zuviel arbeit macht, muss ich mir was anderes einfallen lassen.
            jackblackson
            #191
            @da_woody :) Ist doch schon mal eine super Erklärung. Die Idee des HTML Widgets war natürlich, dass man es nutzen kann ohne selbst etwas an der Formatierung groß anzupassen. Du würdest in dem Fall aber eher gerne eine reine Tabelle haben, vermute ich? Damit es dann wie beim Device Watcher dargestellt werden kann.
            Ich könnte es mir so vorstellen, da hier jeder vielleicht einen anderen Bedraft hat, dass die Spalten frei wählbar sind - damit jeder selbst entscheiden kann, ob er den Alarmtyp haben will, das Icon, oder was auch immer. Ich glaub, da müssen dann auch etwas abstriche gemacht werden, wenn es nebeneinander angezeigt wird. Oder weißt du, ob er hier auch Zeilenumbrüche macht? Ich selbst hab iQontrol noch nie ausprobiert.
              da_WoodyD Online
              da_WoodyD Online
              #192
              @jackblackson im prinzip würde es ja so passen. den level kann ich ja mit der umrandung anzeigen. den hintergrund muss ich dann natürlich ändern wegen der schriftfarbe.
              an den muss sich ja in den instanzeneinstellungen nichts ändern.
              69f00d92-a7da-457f-ab94-c2ae6f95dab6-grafik.png 7b040d08-d1f0-4d3f-a9f7-b212bc9aa77e-grafik.png
              ist ja im prinzip nichts anderes, wie es in vis dargestellt wird.
              nur, daß deinem halt durch die fenstergröße halt zeilenumbrüche drinnen sind.
              ich hau dir da mal vom watcher das listAll objekt rein. da kann man sich über die 3 punkte auch die spaltenansicht einstellen.
              [{"Device":"Andy","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":70},{"Device":"Büro","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":76},{"Device":"D1mini_Bad","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":64},{"Device":"D1mini_Pool","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":70},{"Device":"Ender","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":96},{"Device":"Gästezimmer","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:02 Uhr","Link_quality":68},{"Device":"Küche","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":64},{"Device":"Terra","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":94},{"Device":"Duo1","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-60},{"Device":"Duo2","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-60},{"Device":"Wohnungstür","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-71},{"Device":"Duo4","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-57},{"Device":"Duo6","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-56},{"Device":"Duo5","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-60},{"Device":"Duo3","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-61},{"Device":"WC-Licht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:12 Uhr","Link_quality":-81},{"Device":"Duo7","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-61},{"Device":"Terra3","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-73},{"Device":"Terra2","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-61},{"Device":"Terra1","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-83},{"Device":"Klingel","Adapter":"Shelly","Battery":" - ","Last_contact":"07:16 Uhr","Link_quality":-76},{"Device":"Luster_Taster","Adapter":"Shelly","Battery":" - ","Last_contact":"07:16 Uhr","Link_quality":-74},{"Device":"Schreibtisch","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-84},{"Device":"Tür","Adapter":"Shelly","Battery":"100%","Last_contact":"8 Tagen","Link_quality":-60},{"Device":"Tor","Adapter":"Shelly","Battery":"100%","Last_contact":"3 Stunden","Link_quality":-61},{"Device":"Werkstatt Strom","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-36},{"Device":"HT Zentrale","Adapter":"Shelly","Battery":" - ","Last_contact":"06:55 Uhr","Link_quality":-54},{"Device":"HT Studio","Adapter":"Shelly","Battery":" - ","Last_contact":"2 Stunden","Link_quality":-81},{"Device":"HT Büro","Adapter":"Shelly","Battery":" - ","Last_contact":"07:05 Uhr","Link_quality":-42},{"Device":"HT Waschküche","Adapter":"Shelly","Battery":" - ","Last_contact":"06:51 Uhr","Link_quality":-57},{"Device":"HT Gästezimmer","Adapter":"Shelly","Battery":" - ","Last_contact":"07:13 Uhr","Link_quality":-74},{"Device":"HT Wohnzimmer","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-31},{"Device":"HT Schlafzimmer","Adapter":"Shelly","Battery":" - ","Last_contact":"23 Stunden","Link_quality":-61},{"Device":"HT Küche","Adapter":"Shelly","Battery":" - ","Last_contact":"07:16 Uhr","Link_quality":-66},{"Device":"HT Holz","Adapter":"Shelly","Battery":" - ","Last_contact":"06:57 Uhr","Link_quality":-51},{"Device":"HT Lager","Adapter":"Shelly","Battery":" - ","Last_contact":"06:55 Uhr","Link_quality":-59},{"Device":"Alarm","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-60},{"Device":"Lötplatz","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-76},{"Device":"Waschmaschine","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-61},{"Device":"Dose1","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-59},{"Device":"Dose2","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-57},{"Device":"Woody","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-82},{"Device":"Tiefkühlkasten","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-71},{"Device":"Salz","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-58},{"Device":"Trockner","Adapter":"Shelly","Battery":" - ","Last_contact":"07:06 Uhr","Link_quality":-53},{"Device":"Bad-RGB","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-61},{"Device":"RGBW Pool","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-47},{"Device":"RGBW Wohnzimmer","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-71},{"Device":"BüroLicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-68},{"Device":"Garage_Taster","Adapter":"Shelly","Battery":" - ","Last_contact":"07:13 Uhr","Link_quality":-56},{"Device":"Aussenplatz","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-44},{"Device":"LackLicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-40},{"Device":"Lüftung","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-49},{"Device":"WC Ventilator","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-70},{"Device":"Massagelicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-81},{"Device":"Allibert","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-78},{"Device":"HolzLicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-72},{"Device":"StudioLicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-75},{"Device":"Lagerlicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-47},{"Device":"Interactive","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-26},{"Device":"Arbeitsfläche","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-68},{"Device":"Küchenlicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-68},{"Device":"Test","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-79},{"Device":"Rollo2","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-67},{"Device":"Rollo1","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-67},{"Device":"RolloBüro","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-71},{"Device":"RolloLager","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-60},{"Device":"Deckenlicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-65},{"Device":"Pool","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-47},{"Device":"Infra Lager","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-60},{"Device":"Infra Studio","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-69},{"Device":"Infra WZ","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-61},{"Device":"Infra GZ","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-92},{"Device":"Infra SZ","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-78},{"Device":"Infra Z","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-67},{"Device":"Infra Büro","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-54},{"Device":"Infra Küche","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-77},{"Device":"Infra Holz","Adapter":"Shelly","Battery":" - ","Last_contact":"07:16 Uhr","Link_quality":-62},{"Device":"Heizung WK","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-81},{"Device":"Eiskasten","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-89}]
                jackblackson
                #193
                @da_woody Danke - werd ich mir die nächsten Wochen ansehen und mich bei dir melden
                • NashraN Offline
                  NashraN Offline
                  Nashra
                  Most Active Forum Testing
                  #194
                  Moin, mir werden die Warningimages nicht mehr angezeigt. Installierte Version 2.1.3
                  Im Pfad steht "/meteoalarm.admin/icons/black/t.png" was es aber nicht gibt, hier
                  müßte für heute t5.png enthalten sein.
                  Gruß Ralf
                  • NashraN Nashra
                    da_WoodyD Online
                    da_WoodyD Online
                    #195
                    @nashra hmm, beta ist schon 2.1.5 frage, welchen pfad meinst du? upload schon versucht?
                      NashraN Offline
                      NashraN Offline
                      Nashra
                      #196
                      @da_woody sagte in Test Adapter Meteoalarm v2.0.x:
                      Die Icons liegen in "/meteoalarm.admin/icons/black/" und die wurden mir gestern nicht angezeigt d.h.
                      da stand nur t.png im html-Code. Heute morgen zeigt er es richtig an
                      werde es mal weiter beobachten
                      Gruß Ralf
                      da_WoodyD jackblacksonJ 2 Antworten Letzte Antwort
                      • NashraN Nashra
                        da_WoodyD Online
                        da_WoodyD Online
                        #197
                        @nashra ich denk mal, da ist einiges nicht ganz passend. hab auch schon teilweise keine icons bekommen.
                        siehe hier:
                        aber @jackblackson ist ja dran... :)
                          siehe hier:
                          NashraN Offline
                          NashraN Offline
                          Nashra
                          #198
                          siehe hier:
                          Genau, viel mir eben nur auf und davon geht die Welt nicht unter wenn mal ein Icon fehlt 😀
                          Wird er schon finden und beheben ☺
                          Gruß Ralf
                          • NashraN Nashra
                            siehe hier:
                            da_WoodyD Online
                            da_WoodyD Online
                            #199
                            @nashra heute ist sowieso wieder halligalli...
                            • NashraN Nashra
                              jackblackson
                              #200
                              @nashra Hallo! Könntest du mir, wenn dir dies das nächste Mal auffällt, bitte das komplette Objekt für den Alarm screenshotten? Sprich Level, Typ, usw - dann könnte ich es mir ansehen.
                                NashraN Offline
                                NashraN Offline
                                Nashra
                                #201
                                @jackblackson sagte in Test Adapter Meteoalarm v2.0.x:
                                Moin, ja mache ich sobald es nochmal auftreten sollte
                                Gruß Ralf
                                • jackblacksonJ Offline
                                  jackblackson
                                  #202
                                  @da_Woody Ich hab eine neue Verstion erstellt (2.2.0), wo es jetzt ein neues Objekt gibt - JSON - welches dir helfen sollte bei IQontrol. Könntest du es bitte mal testen? Installation über https://github.com/jack-blackson/ioBroker.meteoalarm/tarball/v2.2.0
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    #203
                                    @jackblackson 👍 sieht fürs erste mal ganz gut aus!
                                    allerdings gibts bei den widgets in iQontrol soviel einzustellen, da muss ich mich erstmal durchackern... :D
                                    mal guxxen wann ich da noch zeit finde. so gesehn ist's ganz praktisch zum testen mit den 4fach warnings. 🙄
                                      jackblackson
                                      #204
                                      @da_woody Super, danke für das erste Feedback. Wenn dir was auffällt, oder dir Spalten fehlen, einfach melden.
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        #205
                                        @jackblackson zu, ein bißchen rumgespielt mit den möglichkeiten in iQontrol widget. 2 verschiedene versionen.
                                        eigener header, nicht gebrauchtes rausgeschmissen. so kann ich mal leben.
                                        das mit icons hab ich noch nicht geschafft, da wird mir nur der linktext angezeigt.
                                          jackblackson
                                          #206
                                          @da_woody Schaut gut aus. Wenn du was rausfindest wegen dem Icon einfach melden, dann kann ich es ändern.
                                          Hatte die letzten Tage einiges an Mails mit einem netten Herrn vom ZAMG, der mir noch erklärt hat wie es zu diesen doppelten Alarmen kommt, und baue grad die Lösung ein, hoffe diese in den nächsten Tagen zum Testen freizugeben.
