  4. BLE läuft nach Node Update auf 16 nicht mehr (gelöst)
    5.8k
33 Beiträge 5 Kommentatoren 2.8k Aufrufe 5 Beobachtet
  • J Jan1
    Dieser Fehler steht im Log:
    2022-06-17 20:57:10.717 - info: host.Beelink instance system.adapter.ble.0 started with pid 13607
    2022-06-17 20:57:12.464 - info: ble.0 (13607) starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.15.1, js-controller: 4.0.23
    2022-06-17 20:57:12.542 - info: ble.0 (13607) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    2022-06-17 20:57:12.544 - info: ble.0 (13607) enabled plugins: Xiaomi, mi-flora, _default
    2022-06-17 20:57:12.545 - info: ble.0 (13607) monitored services: fe95
    2022-06-17 20:57:12.631 - info: ble.0 (13607) starting scanner process...
    2022-06-17 20:57:13.041 - error: ble.0 (13607) Terminating because A dependency requires a rebuild.
    2022-06-17 20:57:13.130 - info: host.Beelink instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
    2022-06-17 20:57:13.131 - info: host.Beelink Rebuild for adapter system.adapter.ble.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    Das habe ich dann gemacht:
    jan@Beelink:/opt/iobroker/iobroker-data/files/ble.admin$ npm install --production
    npm WARN config production Use `--omit=dev` instead.
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm WARN old lockfile Error: An unknown git error occurred
    npm WARN old lockfile     at makeError (/usr/lib/node_modules/npm/node_modules/@npmcli/git/lib/make-error.js:28:13)
    npm WARN old lockfile     at /usr/lib/node_modules/npm/node_modules/@npmcli/git/lib/spawn.js:37:26
    npm WARN old lockfile     at runMicrotasks (<anonymous>)
    npm WARN old lockfile     at processTicksAndRejections (node:internal/process/task_queues:96:5)
    npm WARN old lockfile  Could not fetch metadata for iobroker.boschebike@git+ssh://git@github.com/gaudes/ioBroker.boschebike.git#caab76421a131da61a7a8bbb8cd07bad28711e3e GitUnknownError: An unknown git error occurred
    npm WARN old lockfile     at processTicksAndRejections (node:internal/process/task_queues:96:5) {
    npm WARN old lockfile   cmd: 'git',
    npm WARN old lockfile   args: [
    npm WARN old lockfile     '--no-replace-objects',
    npm WARN old lockfile     'ls-remote',
    npm WARN old lockfile     'ssh://git@github.com/gaudes/ioBroker.boschebike.git'
    npm WARN old lockfile   ],
    npm WARN old lockfile   code: 128,
    npm WARN old lockfile   signal: null,
    npm WARN old lockfile   stdout: '',
    npm WARN old lockfile   stderr: 'git@github.com: Permission denied (publickey).\r\n' +
    npm WARN old lockfile     'fatal: Konnte nicht vom Remote-Repository lesen.\n' +
    npm WARN old lockfile     '\n' +
    npm WARN old lockfile     'Bitte stellen Sie sicher, dass die korrekten Zugriffsberechtigungen bestehen\n' +
    npm WARN old lockfile     'und das Repository existiert.\n'
    npm WARN old lockfile }
    npm ERR! code 128
    npm ERR! An unknown git error occurred
    npm ERR! command git --no-replace-objects ls-remote ssh://git@github.com/gaudes/ioBroker.boschebike.git
    npm ERR! git@github.com: Permission denied (publickey).
    npm ERR! fatal: Konnte nicht vom Remote-Repository lesen.
    npm ERR!
    npm ERR! Bitte stellen Sie sicher, dass die korrekten Zugriffsberechtigungen bestehen
    npm ERR! und das Repository existiert.
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-17T18_58_21_474Z-debug-0.log
    Ändert aber nichts am Fehler. Neuinstallation vom BLE bringt auch keine Änderung.
    GlasfaserG Offline
    GlasfaserG Offline
    @jan1
    https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition/356
    • GlasfaserG Glasfaser
      @jan1
      Jan1
      @glasfaser
      Das ist richtig, aber extra für Dich:
      jan@Beelink:~$ nodejs -v && node -v && npm -v && which nodejs && which node && which npm
      v16.15.1
      v16.15.1
      8.11.0
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
      • J Jan1
        @glasfaser
        v16.15.1
        v16.15.1
        8.11.0
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        GlasfaserG Offline
        GlasfaserG Offline
        @jan1
        im Link
        • J Jan1
          @glasfaser
          v16.15.1
          v16.15.1
          8.11.0
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          @jan1
          Du stehst im falschen Verzeichnis für sowas.
          Und schau dir das an:
          https://forum.iobroker.net/topic/53863/ble-0-ist-rot/2
            @jan1
            im Link
            Jan1
            @glasfaser
            kannst den bitte posten, oder soll ich den abtippen?
              @jan1
              Jan1
              Na im Log stand Adapter Verzeichnis und da bin ich mal hin ;)
              OK, schau mir mal den Link an.
              Thomas BraunT J 2 Antworten Letzte Antwort
              • J Jan1
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                @jan1 sagte in BLE lauft nach Node Update auf 16 nicht mehr.:
                @glasfaser
                Der steht doch im Link von
                @jan1
                Habe daraus auch ein Screenshot gemacht
                @glasfaser
                • J Jan1
                  Dann bist du aber dabei falsch abgebogen.
                  /opt/iobroker/node_modules/iobroker.ADAPTERNAME/
                  wäre richtig, würde dir aber in dem Fall auch nichts bringen.
                  • J Jan1
                    Jan1
                    @Thomas-Braun
                    Ok, da fällt mir doch gleich ein, dass da was mit dem BLE war, voll vergessen.
                    Muss mal schauen, da die genannte Änderung im Link nicht so gepasst hatte, hat aber das letzte Mal auch geklappt ;)
                    Thomas wie immer, schnelle und einfache Hilfe.
                    @Glasfaser
                    mit direktem Link ohne Bilder gehts einfach einfacher :)
                    • J Jan1
                      @Thomas-Braun
                      @Glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Glasfaser
                      Sorry , wollte nur ein Link zu diesem Thread setzten , da dieses Thema gerade vor x Minuten / Stunden schon gelöst wurde .
                        @Glasfaser
                        Jan1
                        @glasfaser
                        Ich kannte die Lösung sogar, da ich das letzte Mal beim Basteln auch am BLE ein Problem hatte. Im Moment läuft er noch nicht, schau ich mir morgen noch mal an. Oder wenn einer spotan ne Idee zu dem Fehler hat der nach Änderung der "package.json" kommt:
                        ble.0
                        2022-06-17 21:27:20.269	error	ENODEV, No such device
                        ble.0
                        2022-06-17 21:27:19.797	info	starting scanner process...
                        ble.0
                        2022-06-17 21:27:19.774	info	monitored services: fe95
                        ble.0
                        2022-06-17 21:27:19.772	info	enabled plugins: Xiaomi, mi-flora, _default
                        ble.0
                        2022-06-17 21:27:19.771	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                        ble.0
                        2022-06-17 21:27:19.708	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.15.1, js-controller: 4.0.23
                        Da klemmt wohl das BT Modul
                        • J Jan1
                          @glasfaser
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          @jan1
                          Was ist denn eingestellt?
                          rfkill
                          sagt?
                            @jan1
                            rfkill
                            sagt?
                            Jan1
                            Der Befehl geht bei mir überhaupt nicht:
                            jan@Beelink:~$ rfkill
                            -bash: rfkill: Kommando nicht gefunden.
                            In dem Link zum BLE Problem hat der Kamerad übrigens Node 14 laufen und damit habe ich auch mit dem BLE keine Probleme.
                            Ich bin jetzt erst mal wieder zurück auf Node 14, da der Node-Red auch ein Problemchen hat. Da ist plötzlich unter Node 16 der Port 80 für meine Amazon Node nicht mehr frei. Was um alles in der Welt ändert denn Node 16 auch noch an der vergabe der Ports?
                            Die Änderung an der "package.json" hatte ich ja gemacht, wobei das auch unter Node 14 ohne diese Änderung läuft. Kann mich auch wieder dran erinnern, wie ich den Post dazu schon mal wegen nem BLE Problem gefunden hatte und damals war das auch nicht die Lösung, da sich da auch lediglich mein BT Modul weggehangen hatte und hier ein Shutdown mit anschließendem Stecker ziehen die Lösung war.
                            Somit habe ich die Befürchtung, dass ich eh ein anderes Problem habe. Mal sehen, ob ich das heute bei dem schönen Wetter überhaupt nochmal angehe.
                            Wenn, dann werde ich wohl mit der großen Keule ran gehen und den IOBroker löschen, Node auf 16 ziehen, ein Backup restoren und schauen was passiert.
                            ? Thomas BraunT 2 Antworten Letzte Antwort
                            • J Jan1
                              @jan1 hatte das selbe Problem gestern Abend. Die anderen Lösungen klappten bei mir auch nicht. Habe dann den Ble adapter deinstalliert und nochmal neu installiert danach lief er wieder.
                              • J Jan1
                                Weil der Adapter bzw die binären Teile aus der Library gegen die ABI von node14 gebaut ist. Die ABI ändert sich aber mit jedem node-Release und die binären Komponenten müssen dann neu dagegen gebaut werden. Deswegen betrifft das auch nicht alle Adapter, sondern nur diese mit binären Komponenten.
                                • J Offline
                                  Jan1
                                  So, die Hammermethode hilft einfach immer :)
                                  Also iobroker löschen inklusive Node und Restor eines Backup. Siehe da, Node 16 drauf und BLE sowie Port 80 beim Node-Red OK.
                                  Den BLE nach Node Update neu installieren, hat bei mir nicht geholfen, warum auch immer.
                                  @Thomas-Braun
                                  in der BLE readme steht ja der Hinweis was zu tun ist, wenn man Node update, was auch so bei den letzten Node Updates funktioniert hatte, nur vom Sprung 14 nach 16 wollte das nicht. 12 nach 14 war das howdo dafür erfolgreich. Entweder bei mir hatte sich ein Fehler angestaut, oder das läuft nun anders und sollte in der readme angepasst werden.
                                  • J Jan1
                                    @Thomas-Braun
                                    @jan1
                                    Die Ergänzung kannst du ja trotzdem machen, dann passt es auch weiterhin für rebuilds von ble.
                                      @jan1
                                      Jan1
                                      welche, die aus der readme, oder an der jason?
                                      • J Jan1
                                        @jan1
                                        Keine Ahnung was in der Readme steht.
                                        Ich meine die Ergänzung im json.
                                          @jan1
                                          Jan1
                                          hatte ich mir gedacht und wird erledigt ;)
                                          Edit:
                                          wird wohl mit gesichert, da nach dem Restor die Änderung schon drin war
