  4. Error 25
    6.3k
Error 25
error process exited with coderror 25
66 Beiträge 5 Kommentatoren 4.6k Aufrufe 4 Beobachtet
    @thomas-brodmann
    sudo -u iobroker whoami
    sudo -u iobroker ls -la /home/iobroker
    Thomas BrodmannT Offline
    Thomas Brodmann
    @thomas-braun sagte in Error 25:
    thommy@DietPi:/opt/iobroker$ sudo -u iobroker whoami
    iobroker
    thommy@DietPi:/opt/iobroker$ sudo -u iobroker ls -la /home/iobroker
    ls: Zugriff auf '/home/iobroker' nicht möglich: Datei oder Verzeichnis nicht gefunden
    • Thomas BrodmannT Thomas Brodmann
      @thomas-brodmann
      thommy@DietPi:/opt/iobroker$ sudo systemctl stop iobroker
      thommy@DietPi:/opt/iobroker$ iobroker fix
      library: loaded
      Library version=2022-06-15
          Welcome to the ioBroker installation fixer!
          Script version: 2022-06-03
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      [sudo] Passwort für thommy:
      OK:1 https://deb.debian.org/debian bullseye InRelease
      OK:2 https://deb.nodesource.com/node_14.x bullseye InRelease
      OK:3 https://deb.debian.org/debian bullseye-updates InRelease
      OK:4 https://deb.debian.org/debian-security bullseye-security InRelease
      OK:5 https://deb.debian.org/debian bullseye-backports InRelease
      OK:6 http://mirrors.xtom.de/armbian bullseye InRelease
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      thommy@DietPi:/opt/iobroker$ sudo systemctl start iobroker
      Warning: The unit file, source configuration file or drop-ins of iobroker.service changed on disk. Run 'systemctl daemon-reload' to reload units.
      thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi
      NPM version: 6.14.17
      Installing iobroker.sonoff@2.5.1... (System call)
      host.DietPi Cannot install iobroker.sonoff@2.5.1: 243
      @thomas-brodmann sagte in Error 25:
      Versuch mal
      sudo -H -u iobroker iobroker add sonoff --host DietPi
      Thomas BrodmannT 1 Antwort Letzte Antwort
        @thomas-brodmann
        library: loaded
        Installed gcc-c++
        @thomas-brodmann so sieht ein gelaufener fix aus
          iobroker
          @thomas-brodmann
          sudo ls -la /home/
            @thomas-brodmann
            library: loaded
            Installed gcc-c++
            was ist denn da bei dir los?
              Versuch mal
              Thomas Brodmann
              thommy@DietPi:/opt/iobroker$ sudo -H -u iobroker iobroker add sonoff --host DietPi
                @thomas-brodmann
                sudo ls -la /home/
                Thomas Brodmann
                thommy@DietPi:/opt/iobroker$ sudo ls -la /home/
                insgesamt 16
                drwxr-xr-x  4 root   root   4096 15. Jun 13:36 .
                drwxr-xr-x 18 root   root   4096 29. Mai 14:11 ..
                drwxr-xr-x  2 dietpi dietpi 4096 19. Okt 2021  dietpi
                drwxr-xr-x  9 thommy thommy 4096 15. Jun 19:58 thommy
                  insgesamt 16
                  @thomas-brodmann
                  Siehste...
                  Kein /home für iobroker
                  sudo mkdir /home/iobroker
                  sudo chown iobroker:iobroker /home/iobroker
                  sudo chmod 755 /home/iobroker
                  HomoranH Thomas BrodmannT 2 Antworten Letzte Antwort
                    @thomas-brodmann
                    Siehste...
                    @thomas-braun bist du sicher dass da nicht noch mehr krumm ist?
                    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                      @homoran sagte in Error 25:
                      Nein.
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @Thomas-Braun
                        ich würde mal in dem Verzeichniss mal schauen was da drin ist ..!?
                        sudo ls -la /home/thommy/
                          Nein.
                          @thomas-braun wenn die iobroker Befehle nich klappen sondern nur systemctl, wird das jetzt besser?
                            sudoers scheint auch 'nen Knick zu haben. Aber ich weiß nicht ob das auf dem DiätPi nicht irgendwie auch auf Diät sitzt und nur Knäckebrot bekommt.
                              @thomas-brodmann
                              Siehste...
                              Thomas Brodmann
                              Das Anlegen des Ordners hat geholfen.
                              thommy@DietPi:/opt/iobroker$ sudo mkdir /home/iobroker
                              thommy@DietPi:/opt/iobroker$ sudo chown iobroker:iobroker /home/iobroker
                              thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi --debug
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                              + iobroker.sonoff@2.5.1
                              added 15 packages from 19 contributors in 37.07s
                              38 packages are looking for funding
                                run `npm fund` for details
                              host.DietPi install adapter sonoff
                              upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                              upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                              upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                              upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                              host.DietPi object system.adapter.sonoff created/updated
                              host.DietPi create instance sonoff
                              host.DietPi object system.adapter.sonoff.0.alive created
                              host.DietPi object system.adapter.sonoff.0.connected created
                              host.DietPi object system.adapter.sonoff.0.compactMode created
                              host.DietPi object system.adapter.sonoff.0.cpu created
                              host.DietPi object system.adapter.sonoff.0.cputime created
                              host.DietPi object system.adapter.sonoff.0.memHeapUsed created
                              host.DietPi object system.adapter.sonoff.0.memHeapTotal created
                              host.DietPi object system.adapter.sonoff.0.memRss created
                              host.DietPi object system.adapter.sonoff.0.uptime created
                              host.DietPi object system.adapter.sonoff.0.inputCount created
                              host.DietPi object system.adapter.sonoff.0.outputCount created
                              host.DietPi object system.adapter.sonoff.0.eventLoopLag created
                              host.DietPi object system.adapter.sonoff.0.sigKill created
                              host.DietPi object system.adapter.sonoff.0.logLevel created
                              host.DietPi object sonoff.0.info created
                              host.DietPi object sonoff.0.info.connection created
                              host.DietPi object system.adapter.sonoff.0 created
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Dietpi ist abgespeckt , habe es als VM ( Grafana / Influx )
                                  @thomas-brodmann
                                  ls -la /home/
                                  • GlasfaserG Glasfaser
                                    @glasfaser sagte in Error 25:
                                    ich hab damals iobroker darauf nicht ans laufen gebracht. Hätte zu viele Klimmzüge gebraucht, wo ich mich nicht mit auskenne
                                      @thomas-brodmann
                                      ls -la /home/
                                      Thomas Brodmann
                                      thommy@DietPi:/opt/iobroker$ ls -la /home/
                                      insgesamt 20
                                      drwxr-xr-x  5 root     root     4096 15. Jun 20:09 .
                                      drwxr-xr-x  3 iobroker iobroker 4096 15. Jun 20:11 iobroker
                                      Vielen lieben Dank für eure Großartige hilfe!!!
                                        insgesamt 20
                                        @thomas-brodmann
                                        und das hier?
                                        @Thomas-Braun
                                          @thomas-brodmann
                                          und das hier?
                                          @Thomas-Braun
                                          Thomas Brodmann
                                          thommy@DietPi:/opt/iobroker$ sudo ls -la /home/thommy/
                                          insgesamt 64
                                          drwxr-xr-x 9 thommy thommy 4096 15. Jun 19:58 .
                                          drwxr-xr-x 5 root   root   4096 15. Jun 20:09 ..
                                          -rw------- 1 thommy thommy 5313 15. Jun 16:44 .bash_history
                                          -rw-r--r-- 1 thommy thommy  220  4. Nov 2021  .bash_logout
                                          -rw-r--r-- 1 thommy thommy 3716 15. Jun 19:58 .bashrc
                                          drwxr-xr-x 5 thommy thommy 4096 15. Jun 14:14 .cache
                                          drwx------ 4 thommy thommy 4096  4. Nov 2021  .config
                                          drwxr-xr-x 3 thommy thommy 4096 15. Jun 12:49 i0broker
                                          drwxr-xr-x 2 thommy thommy 4096  4. Nov 2021  .iobroker
                                          drwx------ 3 thommy thommy 4096  4. Nov 2021  .local
                                          lrwxrwxrwx 1 root   root     13 15. Jun 18:31 node -> /usr/bin/node
                                          lrwxrwxrwx 1 root   root     15 15. Jun 18:31 nodejs -> /usr/bin/nodejs
                                          -rw------- 1 thommy thommy    0 15. Jun 18:37 .node_repl_history
                                          drwxr-xr-x 5 thommy thommy 4096 15. Jun 14:14 .npm
                                          -rw------- 1 thommy thommy   36 15. Jun 14:09 .npmrc
                                          -rw-r--r-- 1 thommy thommy  807  4. Nov 2021  .profile
                                          drwxr-xr-x 3 thommy thommy 4096  4. Nov 2021  .terminfo
                                          -rw-r--r-- 1 thommy thommy 2945  1. Mai 07:27 terminfo.txt
                                          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
