  4. (Gelöst) Fehlermeldung bei Backitup
    5.4k
67 Beiträge 5 Kommentatoren 5.3k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @thomas-braun Hallo Thomas, bei Eingabe dieser Befehle wird bei mir nichts installiert:
    pi@homebridge:~ $ sudo apt install lsb-release wget
    Reading package lists... Done
    lsb-release is already the newest version (11.1.0).
    lsb-release set to manually installed.
    wget is already the newest version (1.21-1+deb11u1).
    wget set to manually installed.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    pi@homebridge:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
    pi@homebridge:~ $ export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
    pi@homebridge:~ $ echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
    pi@homebridge:~ $
    Was die {1} unter dem letzten Eingabeprompt bedeutet weiß ich nicht. Ich habe sie nicht eingegeben.
    @damrak2022
    sudo apt update
    apt policy influxdb influxdb2
    Jetzt müsste aber influx zur Installation verfügbar sein.
      @damrak2022
      sudo apt update
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      pi@homebridge:~ $ sudo apt update
      Get:1 http://security.debian.org/debian-security bullseye-security InRelease [44.1 kB]
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [39.4 kB]
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:5 https://repos.influxdata.com/debian bullseye InRelease [4,739 B]
      Hit:6 https://deb.nodesource.com/node_14.x bullseye InRelease
      Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [154 kB]
      Get:8 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [152 kB]
      Get:9 http://security.debian.org/debian-security bullseye-security/main Translation-en [95.3 kB]
      Get:10 https://repos.influxdata.com/debian bullseye/stable armhf Packages [778 B]
      Get:11 https://repos.influxdata.com/debian bullseye/stable arm64 Packages [1,268 B]
      Fetched 491 kB in 2s (314 kB/s)
      All packages are up to date.
      pi@homebridge:~ $ apt policy influxdb influxdb2
      influxdb:
        Installed: (none)
        Candidate: 1.8.10-1
        Version table:
           1.8.10-1 500
              500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages
           1.6.7~rc0-1+b5 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      influxdb2:
        Installed: (none)
        Candidate: 2.2.0
        Version table:
           2.2.0 500
      pi@homebridge:~ $
      Mit besten Grüßen
      Andy
        influxdb:
          Installed: (none)
          Candidate: 1.8.10-1
          Version table:
             1.8.10-1 500
             1.6.7~rc0-1+b5 500
        influxdb2:
          Installed: (none)
          Candidate: 2.2.0
          Version table:
             2.2.0 500
        pi@homebridge:~ $
        @damrak2022
        Dann ist das Repository jetzt richtig angelegt und du kannst aus dem Vollen schöpfen, was influx in allen möglichen Verkanten angeht. Ich weiß ja nicht was du jetzt installieren willst.
          @damrak2022
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          @thomas-braun Einfach nur die Influx 2, die soll sauber drauf sein
          Mit besten Grüßen
          Andy
            @damrak2022
            Dann halt die influxdb2 wie üblich installieren.
              @damrak2022
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              @thomas-braun Wie üblich heißt dann ?
              sudo apt update
              sudo apt install influxdb2-cli
              Richtig so?
              Mit besten Grüßen
              Andy
                sudo apt update
                Richtig so?
                @damrak2022
                Das Paket influxdb2 ist die Datenbank selber, influxdb2-cli sind die zusätzlichen Kommandozeilentools (werden u.a. für Backups benötigt)
                  @damrak2022
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  @thomas-braun Okay, aber die Befehle sind korrekt, oder?
                  Mit besten Grüßen
                  Andy
                    @damrak2022
                    Ja, prinzipiell schon.
                      @damrak2022
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      @thomas-braun Okay, aber was heißt prinzipiell? Würdest Du es anders machen
                      Mit besten Grüßen
                      Andy
                        #66
                        @damrak2022
                        Nein.
                        Der Standardbefehl ist
                        apt install PAKETNAME
                          @damrak2022
                          Nein.
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #67
                          @thomas-braun Vielen Dank
                          Mit besten Grüßen
                          Andy
