  3. Einsteigerfragen
  4. Installation
  5. (Erledigt) tr-064 lässt sich nicht installieren
    6.3k
35 Beiträge 6 Kommentatoren 2.0k Aufrufe 5 Beobachtet
  • G Gonzokalle
    Wieder etwas gelernt
    pi@raspberrypi:~ $ iobroker repo list
    Active repo(s): stable
    pi@raspberrypi:~ $ iobroker update -i
    Used repository: stable
    sudAdapter    "admin"        : 5.3.8    , installed 6.0.0
    Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
    Adapter    "backitup"     : 2.4.6    , installed 2.4.9
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "devices"      : 1.0.10   , installed 1.0.10
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "eusec"        : 0.9.1    , installed 0.9.1
    Adapter    "flot"         : 1.10.7   , installed 1.11.0
    Adapter    "history"      : 1.11.1   , installed 2.1.2
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.4   , installed 1.11.5
    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Adapter    "jeelink"      : 0.1.4    , installed 0.1.4
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
    Adapter    "smartgarden"  : 1.0.6    , installed 1.0.6
    Adapter    "socketio"     : 4.2.0    , installed 6.1.4
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.12.6   , installed 1.13.0
    Adapter    "web"          : 4.3.0    , installed 5.2.0
    Adapter    "ws"           : 1.3.0    , installed 2.1.0
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    o pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin nodejs
    ln: Ziel 'nodejs': Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v &&        npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap        t policy nodejs
    armv7l
    /usr/bin/node
    /usr/bin/npm
    pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker repo list
    GlasfaserG Offline
    GlasfaserG Offline
    @gonzokalle sagte in tr-064 lässt sich nicht installieren:
    Veränderst du da was !?
    kenne kein sudAdapter
    und
    dann Benutzer o pi
    • G Gonzokalle
      @Glasfaser
      So richtig?
      GlasfaserG Offline
      GlasfaserG Offline
      So richtig?
      in deinem Screenshot ist es auch
      G 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        So richtig?
        G Online
        G Online
        Gonzokalle
        @glasfaser
        login as: pi
        pi@192.168.10.12's password:
        Linux raspberrypi 5.15.30-v7l+ #1536 SMP Mon Mar 28 13:51:42 BST 2022 armv7l
        permitted by applicable law.
        Last login: Sun Jun  5 19:55:10 2022 from 192.168.10.11
        Wi-Fi is currently blocked by rfkill.
        Use raspi-config to set the country before use.
        pi@raspberrypi:~ $ sudo apt update
        OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:3 https://phoscon.de/apt/deconz bullseye InRelease
        OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
        Alle Pakete sind aktuell.
        pi@raspberrypi:~ $ sudo apt full-upgrade
        Paketaktualisierung (Upgrade) wird berechnet… Fertig
        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
          libegl-dev libgl-dev libgles-dev libglx-dev libqt5opengl5 libqt5opengl5-dev libqt5qml5 libqt5qmlmodels5
          libqt5qmlworkerscript5 libqt5quick5 libqt5quickparticles5 libqt5quickshapes5 libqt5quicktest5 libqt5quickwidgets5
          libqt5serialport5 libqt5serialport5-dev libqt5test5 libqt5websockets5 libqt5websockets5-dev libsqlite3-dev libssl-dev
          libvulkan-dev qt5-qmake qt5-qmake-bin qt5-qmltooling-plugins qtbase5-dev qtbase5-dev-tools qtchooser qtdeclarative5-dev
          qtdeclarative5-dev-tools sqlite3
        Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        pi@raspberrypi:~ $
        • G Gonzokalle
          @glasfaser
          login as: pi
          pi@raspberrypi:~ $
          G Online
          G Online
          Gonzokalle
          login as: pi
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
          uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.19.3
          v14.19.3
          6.14.17
          pi
          /home/pi
          nodejs:
            Installiert:           14.19.3-deb-1nodesource1
            Installationskandidat: 14.19.3-deb-1nodesource1
            Versionstabelle:
           *** 14.19.3-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
               12.22.5~dfsg-2~11u1 500
          pi@raspberrypi:~ $
          • G Gonzokalle
            login as: pi
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.19.3
            v14.19.3
            6.14.17
            pi
            /home/pi
            nodejs:
              Versionstabelle:
            pi@raspberrypi:~ $
            G Online
            G Online
            Gonzokalle
            @gonzokalle
            Ich habe da nichts bewusst verändert.
            pi@raspberrypi:~ $
            • G Gonzokalle
              @gonzokalle
              pi@raspberrypi:~ $
              G Online
              G Online
              Gonzokalle
              @gonzokalle
              Die admin 5.3.8 konnte ich jetzt installieren.
              Der tr-064 ging danach auch.
              • mickymM Offline
                mickymM Offline
                mickym
                Das sind solche Threadüberschriften die ich liebe. Als ob der tr-064 Adapter ein Problem hat. Hat er aber nicht. Sondern die Beta-Version des Admin adapters.
                Warum schreibt man nicht, habe Problem in der Beta Umgebung den ... Adapter zu installieren.
                • G Gonzokalle
                  @glasfaser
                  Da hat einer scheinbar das gleiche Problem.
                  Ist meine Version zu modern?
                  Hast du eine Lösung dafür?
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @mickym
                  @glasfaser
                  @glasfaser sagte in tr-064 lässt sich nicht installieren:
                  Wie schon oben gesagt .. du bist BETA Tester
                  Er hat sich dazu nicht geäußert bzw. Ihm war wohl nicht bewusst in Beta zu sein !?
                  • mickymM mickym
                    G Online
                    G Online
                    Gonzokalle
                    @mickym
                    Naja mit der Beta hat er ja auch ein Problem. Oder?
                    Woher soll ich wissen, dass der Admin Adapter das Problem ist.
                    Davon steht in der Meldung nichts.
                    mickymM GlasfaserG 2 Antworten Letzte Antwort
                      @mickym
                      @glasfaser
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @glasfaser Dann sollte man vielleicht generell das Repository auf stable umstellen, wenn man sich dessen nicht bewußt ist?
                      • mickymM mickym
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @mickym sagte in tr-064 lässt sich nicht installieren:
                        Das kann nur @Gonzokalle beantworten , warum er es umgestellt hat .
                        • G Gonzokalle
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @gonzokalle Wie gesagt - dann solltest Du Dein Repsoitory auf stable umstellen und nur stable nutzen, ausser Du brauchst von einem Adapter die neueste Version.Dann via npm installieren.
                          GlasfaserG G 2 Antworten Letzte Antwort
                          • mickymM mickym
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Bildlich dargestellt :
                            • G Gonzokalle
                              armv7l
                              /usr/bin/node
                              /usr/bin/npm
                              Hier stand Quark.
                              • G Gonzokalle
                                @mickym
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Aber wir wissen es .... da es Thema im Thread zu ( Beta ) Admin 6 ist .
                                • mickymM mickym
                                  G Online
                                  G Online
                                  Gonzokalle
                                  @mickym
                                  Bin halt noch Anfänger. Sorry
                                  Und ja, ich brauchte einen Adapter, den ich auf stable nicht angeboten bekam.
                                  Lasse ich jetzt auf stable stehen.
                                  mickymM HomoranH 2 Antworten Letzte Antwort
                                  • G Gonzokalle
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @mickym
                                    Kein Problem. :) Deswegen reden wir ja. - Vielleicht änderst einfach jetzt noch den Threadtitel. ;)
                                    • G Gonzokalle
                                      @mickym
                                      Ändere dann bitte jetzt den Titel
                                      du hast aber fast alle Adapter in der Beta Version, wo vorhanden.
                                      Wenn du da keine Probleme hast, lass es bis diese Versionen irgendwann stable sind.
                                      • G Online
                                        G Online
                                        Gonzokalle
                                        Alle anderen Adapter laufen perfekt.
                                        Überschrift habe ich geändert.
                                        Danke an alle
                                        • G Gonzokalle
                                          Danke an alle
                                          @gonzokalle sagte in tr-064 lässt sich nicht installieren --- erledigt:
