  3. Einsteigerfragen
  4. Installation
  5. (Erledigt) tr-064 lässt sich nicht installieren
    6.3k
35 Beiträge 6 Kommentatoren 2.0k Aufrufe 5 Beobachtet
    @gonzokalle
    Da klemmt irgendwas bei dir.
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Und bitte das Eingeben, was gepostet wird. Am besten kopieren und in das Terminal pasten (Rechte Maustaste meist).
    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    G Online
    G Online
    Gonzokalle
    Wieder etwas gelernt
    pi@raspberrypi:~ $ iobroker repo list
    Active repo(s): stable
    pi@raspberrypi:~ $ iobroker update -i
    Used repository: stable
    sudAdapter    "admin"        : 5.3.8    , installed 6.0.0
    Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
    Adapter    "backitup"     : 2.4.6    , installed 2.4.9
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "devices"      : 1.0.10   , installed 1.0.10
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "eusec"        : 0.9.1    , installed 0.9.1
    Adapter    "flot"         : 1.10.7   , installed 1.11.0
    Adapter    "history"      : 1.11.1   , installed 2.1.2
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.4   , installed 1.11.5
    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Adapter    "jeelink"      : 0.1.4    , installed 0.1.4
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
    Adapter    "smartgarden"  : 1.0.6    , installed 1.0.6
    Adapter    "socketio"     : 4.2.0    , installed 6.1.4
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.12.6   , installed 1.13.0
    Adapter    "web"          : 4.3.0    , installed 5.2.0
    Adapter    "ws"           : 1.3.0    , installed 2.1.0
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    o pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin nodejs
    ln: Ziel 'nodejs': Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v &&        npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap        t policy nodejs
    armv7l
    /usr/bin/node
    /usr/bin/npm
    pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker repo list
    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
    • G Gonzokalle
      armv7l
      /usr/bin/node
      /usr/bin/npm
      GlasfaserG Offline
      GlasfaserG Offline
      @gonzokalle sagte in tr-064 lässt sich nicht installieren:
      Veränderst du da was !?
      kenne kein sudAdapter
      und
      dann Benutzer o pi
      • G Gonzokalle
        @Glasfaser
        So richtig?
        GlasfaserG Offline
        GlasfaserG Offline
        So richtig?
        in deinem Screenshot ist es auch
        G 1 Antwort Letzte Antwort
        • GlasfaserG Glasfaser
          So richtig?
          G Online
          G Online
          Gonzokalle
          @glasfaser
          login as: pi
          pi@192.168.10.12's password:
          Linux raspberrypi 5.15.30-v7l+ #1536 SMP Mon Mar 28 13:51:42 BST 2022 armv7l
          permitted by applicable law.
          Last login: Sun Jun  5 19:55:10 2022 from 192.168.10.11
          Wi-Fi is currently blocked by rfkill.
          Use raspi-config to set the country before use.
          pi@raspberrypi:~ $ sudo apt update
          OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:3 https://phoscon.de/apt/deconz bullseye InRelease
          OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
          Alle Pakete sind aktuell.
          pi@raspberrypi:~ $ sudo apt full-upgrade
          Paketaktualisierung (Upgrade) wird berechnet… Fertig
          Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
            libegl-dev libgl-dev libgles-dev libglx-dev libqt5opengl5 libqt5opengl5-dev libqt5qml5 libqt5qmlmodels5
            libqt5qmlworkerscript5 libqt5quick5 libqt5quickparticles5 libqt5quickshapes5 libqt5quicktest5 libqt5quickwidgets5
            libqt5serialport5 libqt5serialport5-dev libqt5test5 libqt5websockets5 libqt5websockets5-dev libsqlite3-dev libssl-dev
            libvulkan-dev qt5-qmake qt5-qmake-bin qt5-qmltooling-plugins qtbase5-dev qtbase5-dev-tools qtchooser qtdeclarative5-dev
            qtdeclarative5-dev-tools sqlite3
          Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          pi@raspberrypi:~ $
          • G Gonzokalle
            @glasfaser
            login as: pi
            pi@raspberrypi:~ $
            G Online
            G Online
            Gonzokalle
            login as: pi
            pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.19.3
            v14.19.3
            6.14.17
            pi
            /home/pi
            nodejs:
              Installiert:           14.19.3-deb-1nodesource1
              Installationskandidat: 14.19.3-deb-1nodesource1
              Versionstabelle:
             *** 14.19.3-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                 12.22.5~dfsg-2~11u1 500
            pi@raspberrypi:~ $
            • G Gonzokalle
              login as: pi
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.19.3
              v14.19.3
              6.14.17
              pi
              /home/pi
              nodejs:
                Versionstabelle:
              pi@raspberrypi:~ $
              G Online
              G Online
              Gonzokalle
              @gonzokalle
              Ich habe da nichts bewusst verändert.
              pi@raspberrypi:~ $
              • G Gonzokalle
                @gonzokalle
                pi@raspberrypi:~ $
                G Online
                G Online
                Gonzokalle
                @gonzokalle
                Die admin 5.3.8 konnte ich jetzt installieren.
                Der tr-064 ging danach auch.
                • mickymM Offline
                  mickymM Offline
                  mickym
                  Das sind solche Threadüberschriften die ich liebe. Als ob der tr-064 Adapter ein Problem hat. Hat er aber nicht. Sondern die Beta-Version des Admin adapters.
                  Warum schreibt man nicht, habe Problem in der Beta Umgebung den ... Adapter zu installieren.
                  • G Gonzokalle
                    @glasfaser
                    Da hat einer scheinbar das gleiche Problem.
                    Ist meine Version zu modern?
                    Hast du eine Lösung dafür?
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @mickym
                    @glasfaser
                    @glasfaser sagte in tr-064 lässt sich nicht installieren:
                    Wie schon oben gesagt .. du bist BETA Tester
                    Er hat sich dazu nicht geäußert bzw. Ihm war wohl nicht bewusst in Beta zu sein !?
                    • mickymM mickym
                      G Online
                      G Online
                      Gonzokalle
                      @mickym
                      Naja mit der Beta hat er ja auch ein Problem. Oder?
                      Woher soll ich wissen, dass der Admin Adapter das Problem ist.
                      Davon steht in der Meldung nichts.
                      mickymM GlasfaserG 2 Antworten Letzte Antwort
                        @mickym
                        @glasfaser
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @glasfaser Dann sollte man vielleicht generell das Repository auf stable umstellen, wenn man sich dessen nicht bewußt ist?
                        • mickymM mickym
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @mickym sagte in tr-064 lässt sich nicht installieren:
                          Das kann nur @Gonzokalle beantworten , warum er es umgestellt hat .
                          • G Gonzokalle
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @gonzokalle Wie gesagt - dann solltest Du Dein Repsoitory auf stable umstellen und nur stable nutzen, ausser Du brauchst von einem Adapter die neueste Version.Dann via npm installieren.
                            GlasfaserG G 2 Antworten Letzte Antwort
                            • mickymM mickym
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Bildlich dargestellt :
                              • G Gonzokalle
                                armv7l
                                /usr/bin/node
                                /usr/bin/npm
                                Hier stand Quark.
                                • G Gonzokalle
                                  @mickym
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Aber wir wissen es .... da es Thema im Thread zu ( Beta ) Admin 6 ist .
                                  • mickymM mickym
                                    G Online
                                    G Online
                                    Gonzokalle
                                    @mickym
                                    Bin halt noch Anfänger. Sorry
                                    Und ja, ich brauchte einen Adapter, den ich auf stable nicht angeboten bekam.
                                    Lasse ich jetzt auf stable stehen.
                                    mickymM HomoranH 2 Antworten Letzte Antwort
                                    • G Gonzokalle
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @mickym
                                      Kein Problem. :) Deswegen reden wir ja. - Vielleicht änderst einfach jetzt noch den Threadtitel. ;)
                                      • G Gonzokalle
                                        @mickym
                                        HomoranH Offline
                                        HomoranH Offline
                                        Ändere dann bitte jetzt den Titel
                                        du hast aber fast alle Adapter in der Beta Version, wo vorhanden.
                                        Wenn du da keine Probleme hast, lass es bis diese Versionen irgendwann stable sind.
                                        • G Online
                                          G Online
                                          Gonzokalle
                                          Alle anderen Adapter laufen perfekt.
                                          Überschrift habe ich geändert.
                                          Danke an alle
