  4. Node-Red
  5. Smartmeter -> NR
    6.5k
Smartmeter -> NR
19 Beiträge 2 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • H hpgo
    @mickym
    Kapier ich nicht, sorry
    Ich schaffe es nur die flow Variable mit >9000 und <9001 abzufragen.
            "id": "c7b1863ec3de5b58",
            "type": "tab",
            "label": "Smartmeter",
            "disabled": false,
            "info": "",
            "env": []
            "id": "4f4c02518d0af791",
            "type": "mqtt in",
            "z": "c7b1863ec3de5b58",
            "name": "",
            "topic": "smartmeter/SmartyReader",
            "qos": "2",
            "datatype": "auto",
            "broker": "501dcbe75f7121d1",
            "nl": false,
            "rap": true,
            "rh": 0,
            "inputs": 0,
            "x": 430,
            "y": 180,
            "wires": [
                    "83af5ee7562b2766",
                    "fdb8ec4dd58e4f02"
            "id": "83af5ee7562b2766",
            "type": "json",
            "name": "",
            "property": "payload",
            "action": "",
            "pretty": false,
            "x": 630,
            "y": 180,
            "wires": [
                    "483a142959cc36be"
            "id": "fdb8ec4dd58e4f02",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 650,
            "y": 120,
            "wires": []
            "id": "483a142959cc36be",
            "type": "change",
            "name": "payload.energy_consumption_calc_kWh",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.energy_consumption_calc_kWh",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 880,
            "y": 180,
            "wires": [
                    "7562d54de63c4554"
            "id": "7562d54de63c4554",
            "type": "calculator",
            "name": "",
            "inputMsgField": "payload",
            "outputMsgField": "payload",
            "operation": "div",
            "constant": "1000",
            "round": true,
            "decimals": "2",
            "x": 1130,
            "y": 180,
            "wires": [
                    "7c3d8abd88fc55aa",
                    "ada862e65c4e3bf9"
            "id": "7c3d8abd88fc55aa",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": true,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "payload",
            "x": 1290,
            "y": 140,
            "wires": []
            "id": "ada862e65c4e3bf9",
            "type": "change",
            "name": "flow.smartmeter.kwh",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "smartmeter.kwh",
                    "tot": "flow"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1320,
            "y": 240,
            "wires": [
            "id": "4bb2def3f08ebd30",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "",
            "payloadType": "date",
            "x": 360,
            "y": 340,
            "wires": [
                    "229327472da1804a"
            "id": "229327472da1804a",
            "type": "switch",
            "name": "",
            "propertyType": "msg",
            "rules": [
                    "t": "eq",
                    "v": "smartmeter.kwh",
                    "vt": "flow"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 510,
            "y": 340,
            "wires": [
                    "87acd33c808325b1"
            "id": "87acd33c808325b1",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 710,
            "y": 340,
            "wires": []
            "id": "501dcbe75f7121d1",
            "type": "mqtt-broker",
            "name": "",
            "broker": "192.168.178.103",
            "port": "1883",
            "clientid": "",
            "autoConnect": true,
            "usetls": false,
            "protocolVersion": "5",
            "keepalive": "60",
            "cleansession": true,
            "birthTopic": "",
            "birthQos": "0",
            "birthPayload": "",
            "birthMsg": {},
            "closeTopic": "",
            "closeQos": "0",
            "closePayload": "",
            "closeMsg": {},
            "willTopic": "",
            "willQos": "0",
            "willPayload": "",
            "willMsg": {},
            "sessionExpiry": ""
    mickymM Offline
    mickymM Offline
    mickym
    @hpgo Ich helf Dir gleich - nach 23 Uhr^^. Was Du in der Flow smartmeter.kwh gespeichert hast, ist doch die Summe die Du zum Tageswechseln brauchst?
    H 1 Antwort Letzte Antwort
    • mickymM mickym
      hpgo
      schrieb am zuletzt editiert von hpgo
      @mickym
      Ja bitte, ich freue mich über deine Hilfe sehr!
      Das ist der Gesamtverbrauch des Hausanschlusses, also ja damit ich dann mit der neuen Summe vergleichen kann (neu minus alt).
      Oder denk ich zu kompliziert??
      • H hpgo
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        @hpgo Also ich machs mal mit 2 Flowvariablen - aber eigentlich müsstest Du es mit Datenpunkten machen - entweder über mqtt oder iobroker Datenpunkte - da ja sonst nach jedem Neustart der Vortageswert weg ist.
        Und die letzte Change Node musst natürlich umgekehrt machen, um die Flowvariable zu setzen.
        • mickymM mickym
          hpgo
          @mickym
          Ja, das stimmt natürlich - muss ich schauen wie ich das am besten machen kann. Bevorzugen würde ich eine Lösung im Mqtt Broker.
          Grundsätzlich wüsste ich nicht wie ich das sonst umsetzen soll, als beide Werte zu vergleichen (Differenz)
          • H hpgo
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @hpgo Na dann speicher das einfach unter einem Topic - hier mal wie man es mit Flowvariablen macht. Wenn Du mqtt topics nimmst, dann musst Du die sowieso wieder in Flowvariablen abspeichern - also parallel und dann setzen.
            So einfach habe ich mir das vorgestellt:
                    "type": "inject",
                    "name": "trigger um Mitternacht",
                    "props": [
                            "p": "payload"
                    "repeat": "",
                    "crontab": "00 00 * * *",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "true",
                    "payloadType": "bool",
                    "x": 570,
                    "y": 440,
                    "wires": [
                            "16258346f6ff4528"
                    "type": "debug",
                    "name": "",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1050,
                    "y": 440,
                    "wires": []
                    "id": "16258346f6ff4528",
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "aktuell",
                            "pt": "msg",
                            "tot": "flow"
                            "t": "set",
                            "p": "vortag",
                            "pt": "msg",
                            "to": "$flowContext(\"smartmeter.vortag\") ? $flowContext(\"smartmeter.vortag\") : 0\t\t\t",
                            "tot": "jsonata"
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "aktuell - vortag",
                            "tot": "jsonata"
                            "t": "set",
                            "p": "smartmeter.vortag",
                            "pt": "flow",
                            "to": "aktuell",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 810,
                    "y": 440,
                    "wires": [
                            "87acd33c808325b1"
            In der payload ist also der Verbrauch und zum Schluss wird der aktuelle Stand schon in den Wert vortag kopiert, um den dann beim nächsten Tageswechsel zur Verfügung zu haben.
            • mickymM mickym
                      "type": "inject",
                      "props": [
                              "p": "payload"
                      "repeat": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "true",
                      "x": 570,
                      "y": 440,
                      "wires": [
                              "16258346f6ff4528"
                      "type": "debug",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1050,
                      "y": 440,
                      "wires": []
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "aktuell",
                              "pt": "msg",
                              "tot": "flow"
                              "t": "set",
                              "p": "vortag",
                              "pt": "msg",
                              "tot": "jsonata"
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "jsonata"
                              "t": "set",
                              "pt": "flow",
                              "to": "aktuell",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 810,
                      "y": 440,
                      "wires": [
                              "87acd33c808325b1"
              hpgo
              @mickym
              Ok ich glaube, ich beginne zu verstehen wie du das meist.
              Leider ist das heute schon zu viel für mich, brauch ne mütze voll schlaf - werde mir das morgen nochmal genau anschauen und wenn ich darf auch nachfragen bei dir.
              Für heute vielen lieben Dank
              • H hpgo
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @hpgo sagte in Smartmeter -> NR:
                @mickym
                Na klar doch! - Freue mich immer, wenn es noch Leute gibt, die dieses fantastische Tool nutzen. Schlaf gut!!!
                • H hpgo
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @hpgo Hier mal ein ganzer Flow - mit mqtt als Zwischenspeicher. Und statt der Divide Node habe ich eine normale genommen, da ich diese 1. nicht habe und ich Nodes vermeide, wenn ich das mit Boardmitteln erreichen kann:
                         "type": "mqtt in",
                         "name": "",
                         "qos": "2",
                         "datatype": "auto",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 430,
                         "y": 180,
                         "wires": [
                                 "83af5ee7562b2766",
                                 "fdb8ec4dd58e4f02"
                         "type": "json",
                         "name": "",
                         "action": "",
                         "pretty": false,
                         "x": 630,
                         "y": 180,
                         "wires": [
                                 "483a142959cc36be"
                         "type": "debug",
                         "name": "",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 650,
                         "y": 120,
                         "wires": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 880,
                         "y": 180,
                         "wires": [
                                 "48a6e7bff5963893"
                         "type": "inject",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "true",
                         "x": 450,
                         "y": 440,
                         "wires": [
                                 "16258346f6ff4528"
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "aktuell",
                                 "pt": "msg",
                                 "to": "smartmeter.aktuell",
                                 "tot": "flow"
                                 "t": "set",
                                 "p": "vortag",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 690,
                         "y": 440,
                         "wires": [
                                 "d5fb6df94bac6441",
                                 "10e449ba6576c606"
                         "id": "48a6e7bff5963893",
                         "type": "change",
                         "name": "Divide",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "payload /1000",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1130,
                         "y": 180,
                         "wires": [
                                 "c6f33ac925334c18"
                         "id": "c6f33ac925334c18",
                         "type": "mqtt out",
                         "name": "",
                         "topic": "smartmeter/aktuell",
                         "qos": "0",
                         "retain": "true",
                         "respTopic": "",
                         "contentType": "",
                         "userProps": "",
                         "correl": "",
                         "expiry": "",
                         "x": 1310,
                         "y": 180,
                         "wires": []
                         "id": "f6822e891382cc53",
                         "type": "mqtt in",
                         "name": "",
                         "qos": "2",
                         "datatype": "json",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 410,
                         "y": 280,
                         "wires": [
                                 "3c9f037fa95cd9a0"
                         "id": "2702b4f8d50278a9",
                         "type": "mqtt in",
                         "name": "",
                         "topic": "smartmeter/vortag",
                         "qos": "2",
                         "datatype": "json",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 410,
                         "y": 340,
                         "wires": [
                                 "1a76e50621c6f78f"
                         "id": "3c9f037fa95cd9a0",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "smartmeter.aktuell",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 700,
                         "y": 280,
                         "wires": [
                         "id": "1a76e50621c6f78f",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "pt": "flow",
                                 "to": "payload",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 700,
                         "y": 340,
                         "wires": [
                         "id": "10e449ba6576c606",
                         "type": "change",
                         "name": "Tagesverbrauch",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 920,
                         "y": 420,
                         "wires": [
                                 "b6d1f4335392c4c1"
                         "id": "d5fb6df94bac6441",
                         "type": "change",
                         "name": "aktuell => vortag",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "aktuell",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 910,
                         "y": 460,
                         "wires": [
                                 "b9f17858738e632f"
                         "id": "b9f17858738e632f",
                         "type": "mqtt out",
                         "name": "",
                         "qos": "0",
                         "retain": "true",
                         "respTopic": "",
                         "contentType": "",
                         "userProps": "",
                         "correl": "",
                         "expiry": "",
                         "x": 1130,
                         "y": 460,
                         "wires": []
                         "id": "b6d1f4335392c4c1",
                         "type": "mqtt out",
                         "name": "",
                         "topic": "smartmeter/tagesverbrauch",
                         "qos": "0",
                         "retain": "",
                         "respTopic": "",
                         "contentType": "",
                         "userProps": "",
                         "correl": "",
                         "expiry": "",
                         "x": 1160,
                         "y": 420,
                         "wires": []
                         "name": "",
                         "port": "1883",
                         "clientid": "",
                         "usetls": false,
                         "keepalive": "60",
                         "birthTopic": "",
                         "birthQos": "0",
                         "birthPayload": "",
                         "birthMsg": {},
                         "closeTopic": "",
                         "closeQos": "0",
                         "closePayload": "",
                         "closeMsg": {},
                         "willTopic": "",
                         "willQos": "0",
                         "willPayload": "",
                         "willMsg": {},
                         "sessionExpiry": ""
                  Der erste Teil ist quasi dein bisheriger Flow ohne diese Divide Node (ich gehe mal davon aus, dass Du hier nur die payload durch 1000 teilst).
                  Im mittleren Teil werden die Inhalte der mqtt topics permanent für den Flow verfügbar gemacht.
                  Und der letzte teil triggert zum Tageswechsel, rechnet den Tagesverbrauch als Differenz zum Vortag aus und setzt den Vortageswert neu und speichert alles wieder im mqtt ab. Dadurch dass ich die Werte in den mqtt topics als retain abspeichere, werden die Flowvariablen automatisch nach Neustart des Flows wieder belegt.
                  Übrigens wenn Du in den mqtt-In Nodes die Opition ein analysiertes JSON Objekt nutzt, dann kannst DU Dir die JSON Node wahrscheinlich auch sparen.
                  Das nutze ich auch unten um Zahlenwerte rauszubekommen. Funktioniert leider bei normalen Stings nicht, habe ich aber mal an die NOde-Red Entwickler weiter gegeben und dürfte vielleicht in Node-Red Version 3.0.x enthalten sein.
                  https://discourse.nodered.org/t/improvement-of-mqtt-in-nodes/55445
                  https://github.com/node-red/node-red/blob/98b4b0dce057047c414e7a41b7220384c0c1d11a/CHANGELOG.md
                  Hoffe ich mal. ;)
                  • mickymM mickym
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "datatype": "auto",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 430,
                           "y": 180,
                           "wires": [
                                   "83af5ee7562b2766",
                                   "fdb8ec4dd58e4f02"
                           "type": "json",
                           "name": "",
                           "action": "",
                           "pretty": false,
                           "x": 630,
                           "y": 180,
                           "wires": [
                                   "483a142959cc36be"
                           "type": "debug",
                           "name": "",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 650,
                           "y": 120,
                           "wires": []
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "tot": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 880,
                           "y": 180,
                           "wires": [
                                   "48a6e7bff5963893"
                           "type": "inject",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "true",
                           "x": 450,
                           "y": 440,
                           "wires": [
                                   "16258346f6ff4528"
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "p": "aktuell",
                                   "pt": "msg",
                                   "tot": "flow"
                                   "t": "set",
                                   "p": "vortag",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 690,
                           "y": 440,
                           "wires": [
                                   "d5fb6df94bac6441",
                                   "10e449ba6576c606"
                           "type": "change",
                           "name": "Divide",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 1130,
                           "y": 180,
                           "wires": [
                                   "c6f33ac925334c18"
                           "type": "mqtt out",
                           "name": "",
                           "qos": "0",
                           "retain": "true",
                           "respTopic": "",
                           "contentType": "",
                           "userProps": "",
                           "correl": "",
                           "expiry": "",
                           "x": 1310,
                           "y": 180,
                           "wires": []
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "datatype": "json",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 410,
                           "y": 280,
                           "wires": [
                                   "3c9f037fa95cd9a0"
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "datatype": "json",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 410,
                           "y": 340,
                           "wires": [
                                   "1a76e50621c6f78f"
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "pt": "flow",
                                   "to": "payload",
                                   "tot": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 700,
                           "y": 280,
                           "wires": [
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "pt": "flow",
                                   "to": "payload",
                                   "tot": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 700,
                           "y": 340,
                           "wires": [
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 920,
                           "y": 420,
                           "wires": [
                                   "b6d1f4335392c4c1"
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "aktuell",
                                   "tot": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 910,
                           "y": 460,
                           "wires": [
                                   "b9f17858738e632f"
                           "type": "mqtt out",
                           "name": "",
                           "qos": "0",
                           "retain": "true",
                           "respTopic": "",
                           "contentType": "",
                           "userProps": "",
                           "correl": "",
                           "expiry": "",
                           "x": 1130,
                           "y": 460,
                           "wires": []
                           "type": "mqtt out",
                           "name": "",
                           "qos": "0",
                           "retain": "",
                           "respTopic": "",
                           "contentType": "",
                           "userProps": "",
                           "correl": "",
                           "expiry": "",
                           "x": 1160,
                           "y": 420,
                           "wires": []
                           "name": "",
                           "port": "1883",
                           "clientid": "",
                           "usetls": false,
                           "keepalive": "60",
                           "birthTopic": "",
                           "birthQos": "0",
                           "birthPayload": "",
                           "birthMsg": {},
                           "closeTopic": "",
                           "closeQos": "0",
                           "closePayload": "",
                           "closeMsg": {},
                           "willTopic": "",
                           "willQos": "0",
                           "willPayload": "",
                           "willMsg": {},
                           "sessionExpiry": ""
                    Hoffe ich mal. ;)
                    hpgo
                    @mickym
                    Wow, ein großes Dankeschön von mir für die Mühe. Jetzt muss ich mir das mal genauer anschauen.
                    Edit: Echt bombe, was du da in kurzer Zeit zusammengeklickt hast, dafür hätte ich Tage gebraucht.
                    Nochmal vielen Dank, bin dir wirklich dankbar, auch wenn ich vor allem im letzten Teil nicht alles verstehe.
                    Lg
                    • H hpgo
                      @mickym
                      Lg
                      mickymM Offline
                      mickymM Offline
                      mickym
                      Lg
                      Na dann raus mit der Sprache - welche Node ist Dir unklar. Nur vom Fragen lernt man. ;) ... oder welcher Teil des Flows (unten nach der Inject Node?)
                      • mickymM mickym
                        Lg
                        hpgo
                        @mickym
                        Tut mir leid das ich mich erst jetzt wieder melde, war unverhofft weg über Pfingsten.
                        Genau, vor allem die 2 Regel in der Change Node "$flowContext("smartmeter.vortag") ? $flowContext("smartmeter.vortag") : 0" verstehe ich gar nicht.
                        ? und $ Zeichen?
                        Werde jetzt mal schauen, ob das mit dem Tagesverbrauch so funktioniert.
                        Nochmals vielen lieben Dank an dich!
                        • H hpgo
                          @mickym
                          ? und $ Zeichen?
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @hpgo Nun alle Funktionen in JSONATA beginnen mit einem $
                          Ansonsten ist das einfach eine normale Bedigung, die es sowohl unter Javascript also auch unter JSONATA gibt:
                          Es wird hier nur der conditional Operator ? genommen: https://docs.jsonata.org/other-operators
                          In diesem Fall:
                          Wenn ein Inhalt der Flow Variable smartmeter.vortag gelesen werden kann ( da sie bereits gesetzt/initialisiert wurde ), soll der Inhalt der Flow Variable smartmeter.vortag zurückgegeben werden, falls nicht, dann soll 0 zurückgeggeben werden.
                          In der Change Node wird mit der 2. Regel als die Eigenschaft vortag des msg Objektes entweder auf 0 oder auf den Wert der Flowvariable smartmeter.vortag gesetzt.
                          Man kann das Ganze aber auch ohne JSONATA Funkionen umsetzen:
                                 "type": "inject",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "true",
                                 "x": 210,
                                 "y": 440,
                                 "wires": [
                                         "551b8a4cf9ca56fa"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "aktuell",
                                         "pt": "msg",
                                         "tot": "flow"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 950,
                                 "y": 440,
                                 "wires": [
                                         "d5fb6df94bac6441",
                                         "10e449ba6576c606"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1200,
                                 "y": 420,
                                 "wires": [
                                         "b6d1f4335392c4c1"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "aktuell",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1190,
                                 "y": 460,
                                 "wires": [
                                         "b9f17858738e632f"
                                 "id": "551b8a4cf9ca56fa",
                                 "type": "switch",
                                 "name": "smartmeter.vortag definiert?",
                                 "property": "smartmeter.vortag",
                                 "propertyType": "flow",
                                 "rules": [
                                         "t": "null"
                                         "t": "nnull"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 480,
                                 "y": 440,
                                 "wires": [
                                         "59f4a5f665f000f5"
                                         "7c6837d0718c7163"
                                 "id": "7c6837d0718c7163",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "vortag",
                                         "pt": "msg",
                                         "to": "smartmeter.vortag",
                                         "tot": "flow"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 730,
                                 "y": 460,
                                 "wires": [
                                         "16258346f6ff4528"
                                 "id": "59f4a5f665f000f5",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "vortag",
                                         "pt": "msg",
                                         "to": "0",
                                         "tot": "num"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 730,
                                 "y": 420,
                                 "wires": [
                                         "16258346f6ff4528"
                          • mickymM mickym
                            In diesem Fall:
                                   "type": "inject",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "true",
                                   "x": 210,
                                   "y": 440,
                                   "wires": [
                                           "551b8a4cf9ca56fa"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "aktuell",
                                           "pt": "msg",
                                           "tot": "flow"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 950,
                                   "y": 440,
                                   "wires": [
                                           "d5fb6df94bac6441",
                                           "10e449ba6576c606"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1200,
                                   "y": 420,
                                   "wires": [
                                           "b6d1f4335392c4c1"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "aktuell",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1190,
                                   "y": 460,
                                   "wires": [
                                           "b9f17858738e632f"
                                   "type": "switch",
                                   "rules": [
                                           "t": "null"
                                           "t": "nnull"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 480,
                                   "y": 440,
                                   "wires": [
                                           "59f4a5f665f000f5"
                                           "7c6837d0718c7163"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "vortag",
                                           "pt": "msg",
                                           "tot": "flow"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 730,
                                   "y": 460,
                                   "wires": [
                                           "16258346f6ff4528"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "vortag",
                                           "pt": "msg",
                                           "to": "0",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 730,
                                   "y": 420,
                                   "wires": [
                                           "16258346f6ff4528"
                            hpgo
                            @mickym
                            ... ich bin dir echt dankbar, leider melde ich mich erst jetzt wieder, unsere Familie ist größer geworden und deshalb bleibt für mein Hobby kaum noch Zeit.
                            Ich werd mir deinen Flow hoffentlich am Abend genauer anschauen können. Außerdem hab ich dann auch noch eine Frage zu Daten persistent (über einen NR Neustart) halten/speichern in NR (Änderung in der settings.js). Dazu mache ich dann ein eigenes Thema auf.
                            Danke und Lg
                            • H hpgo
                              @mickym
                              Danke und Lg
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @mickym
                              Danke und Lg
                              Da werde ich Dir nicht viel dazu sagen könne, da keine Daten im Dateisystem speichere. Bei mir sind die ja in der Regel im iobroker oder im mqtt.
