  4. Seit Update Node V12->V14 ständige Fehlermeldung
    6.3k
27 Beiträge 3 Kommentatoren 3.0k Aufrufe 2 Beobachtet
    @trafficlight
    Wie sieht denn die Auslastung von dem Kistchen aus?
    Trafficlight
    freier Festplattenspeicher: 72%, Gesamte RAM-Auslastung: 1428 Mb / Frei: 81% = 3100 Mb [Server: raspberrypi - 21 Prozesse]
    top - 13:45:24 up 4 min,  2 users,  load average: 3.52, 2.04, 0.86
    Tasks: 180 total,   5 running, 175 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 52.2 us,  9.5 sy,  0.0 ni, 35.0 id,  0.0 wa,  0.0 hi,  3.3 si,  0.0 st
    MiB Mem :   3837.9 total,   2344.6 free,   1032.8 used,    460.5 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2914.1 avail Mem
      PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
      522 iobroker  20   0  257272 146532  33972 R  93.7   3.7   3:20.18 iobroker.js-con
      779 iobroker  20   0  277000 164560  29056 R  68.2   4.2   2:23.39 io.javascript.0
     2211 iobroker  20   0  244028 132316  29032 R  61.6   3.4   1:39.45 io.g-homa.0
      390 avahi     20   0    6916   2728   2468 S   7.6   0.1   0:16.87 avahi-daemon
      616 iobroker  20   0  190788  83192  34596 S   6.3   2.1   0:16.12 io.admin.0
      921 iobroker  20   0  184356  76232  34612 S   4.3   1.9   0:09.86 io.telegram.0
     1524 iobroker  20   0  173240  55208  28852 S   4.3   1.4   0:08.41 io.simple-api.0
     1180 iobroker  20   0  184240  68536  29208 S   3.0   1.7   0:04.95 io.tr-064.0
      401 pi        20   0  153612  51804  36800 S   1.0   1.3   0:04.70 deCONZ
       91 root      20   0       0      0      0 D   0.7   0.0   0:01.07 kworker/0:2+events_freezable
     1005 iobroker  20   0  185116  69304  29080 S   0.7   1.8   0:06.53 io.shelly.0
     1342 iobroker  20   0  172560  52280  28888 S   0.7   1.3   0:01.94 io.discovery.0
     1640 iobroker  20   0  182968  71232  29908 S   0.7   1.8   0:06.72 io.mercedesme.0
     1889 iobroker  20   0  175772  59220  29068 S   0.7   1.5   0:04.06 io.wled.0
     1932 iobroker  20   0  182896  72416  29140 S   0.7   1.8   0:05.24 io.yahka.0
       90 root     -51   0       0      0      0 S   0.3   0.0   0:00.58 irq/64-mmc0
       95 root      20   0       0      0      0 S   0.3   0.0   0:00.03 jbd2/sda2-8
      397 root      20   0    8428   3620   2900 S   0.3   0.1   0:00.89 deCONZ-WIFI2.sh
     1751 iobroker  20   0  172664  53072  29168 S   0.3   1.4   0:02.54 io.nanoleaf-lig
     2024 iobroker  20   0  175532  56308  28876 S   0.3   1.4   0:02.87 io.web.0
     2144 iobroker  20   0  177944  58160  30256 S   0.3   1.5   0:03.87 io.fb-checkpres
     3805 pi        20   0   11240   3172   2612 R   0.3   0.1   0:00.06 top
        1 root      20   0   33948   9088   7224 S   0.0   0.2   0:03.07 systemd
    • haselchenH haselchen
      @trafficlight
      gib mal
      iobroker compact disable
      im terminal ein unter /opt/iobroker
      dann Neustart
      Trafficlight
      @haselchen
      habe ich durchgeführt. sobald JS gestartet wird ist das gleiche Problem wieder da.
      • T Trafficlight
        @haselchen
        haselchenH Offline
        haselchenH Offline
        haselchen
        @trafficlight
        was sagt denn:
        iobroker compact status
          @trafficlight
          was sagt denn:
          Trafficlight
          @haselchen
          pi@raspberrypi:/opt/iobroker $ iobroker compact status
          Compact mode for this host is currently disabled
          • T Trafficlight
            @haselchen
            haselchenH Offline
            haselchenH Offline
            haselchen
            @trafficlight
            Okay, das passt jetzt.
            Die obige Meldung dürfte jetzt nicht mehr kommen.
            Cannot read compact mode by host "system.host.raspberrypi": timeout
              @trafficlight
              Trafficlight
              @haselchen
              hatte diese Meldung tatsächlich nicht mehr aber es kam ein Fenster das eine Langsame Verbindung erkannt wurde. Letzten Endes musste ich einen reboot durchführen.
              Habe jetzt von V5.7.0 auf V5.6.0 downgegraded mal schauen ob es stabil läuft.
              • T Trafficlight
                @haselchen
                @trafficlight
                Da kippt dir wohl ein Skript weg.
                  @trafficlight
                  Trafficlight
                  zum Verständnis ich habe aktuell 22 Skripte am laufen. Sollen die besser zusammen gefasst werden oder lieber viele einzelne?
                  Könnte es eventuell dieser hier sein.
                  Ich möchte einen Dummy Schalter (dient nur als Anzeige in VIS) mit den Werten 0;1;2;3 schalten sobald bestimmte Temperaturen erreicht wurden.
                  Diesen Skript habe ich für all meine Räume und Außenbereich erstellt.
                  • T Trafficlight
                    @trafficlight
                    Das knallt dir bei jeder Änderung der Temperatur los.
                    Zumindest ungeschickt, ohne Hysterese.
                      @trafficlight
                      Trafficlight
                      schrieb am zuletzt editiert von Trafficlight
                      habe diesen Skript für alle Räume dementsprechend angepasst. Habe eben diese Deaktiviert leider auch ohne Erfolg.
                      Wie gesagt ich schalte damit nichts es dient nur zur Anzeige ;-)
                      hier mal etwas neues
                      Cannot read countsOfInstances: timeout
                      • T Trafficlight
                        @trafficlight
                        Das schaut für mich unlogisch aus. Wenn die Temperatur 25 Grad ist werden drei Bedingungen wahr.
                        Muss sich vielleicht @paul53 mal anschauen.
                        Wenn die anderen Skripte auch so aussehen...
                          @trafficlight
                          Trafficlight
                          bin jetzt von V5.6.0. auf V5.5.4 gegangen scheint zu funktionieren.
                          Wenn ja hat mich das ganze 2 Tage Urlaub und viel viel nerven gekostet. 😲
                          • T Trafficlight
                            @trafficlight
                            Spricht für unsaubere Skripte. Da wirst du wohl ran müssen.
                              @trafficlight
                              Trafficlight
                              wieso hatte es dann 3 Jahre lang so funktioniert?
                              edit: funzt immer noch nicht 😰
                              • T Trafficlight
                                @trafficlight
                                Weil sich Dinge die früher möglich waren ändern z.B.?
                                  @trafficlight
                                  Trafficlight
                                  sehr schön ... manchmal
                                  eventuell habe ich den fehler aber jetzt gefunden.
                                  Mein Protokoll wird zugeknallt mit dieser Fehlermeldung.
                                  script.js.Heizung.Bad-Heizung-Sommer: setForeignState: Error: DB closed
                                  • T Trafficlight
                                    @trafficlight
                                    Ich sag doch, da sind die Skripte krumm.
                                      @trafficlight
                                      Trafficlight
                                      Für alle die auch Probleme haben. Es ist tatsächlich so was "Thomas Braun" schreibt.
                                      Zwei Skripte waren "krumm". Habe diese angepasst. Nun läufts wieder ;-)
