  4. Node.Js wird nicht gefunden
    6.3k
26 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • Z Zlorsh
    @thomas-braun ok werde ich raus löschen, leider hat der versuch auch nicht geklappt :(
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.17
    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    In file included from ../../nan/nan.h:60,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/14.19.3/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.3/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
    > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Successfully migrated 2083 objects to Redis Sets
    object _design/system updated
    host.raspberrypi install adapter backitup
    These apt-get packages were already installed: cifs-utils, nfs-common
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    host.raspberrypi Invalid version of "admin". Installed "4.2.1", required ">=5.2.0"
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 32
    npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
    npm ERR! Exit status 32
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-01T20_20_36_990Z-debug.log
    pi@raspberrypi:/opt/iobroker $ iobroker status
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    @zlorsh
    Da ist Chaos drin...
    iobroker update -i
    funktioniert noch?
    Z 1 Antwort Letzte Antwort
      @zlorsh
      iobroker update -i
      funktioniert noch?
      Z Offline
      Z Offline
      Zlorsh
      @thomas-braun leider nein
      pi@raspberrypi:/opt/iobroker $ iobroker update -i
        throw err;
        requireStack: []
      • Z Zlorsh
        @homoran sehr gute frage, das hab ich vor Ewigkeiten installiert das Teil. Wenn ich so drüber nach denke ist es wohl eher ein Raspberian oder so?!
        Kurz geprüft....
        pi@raspberrypi:/opt/iobroker $ cat /etc/*release
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        @zlorsh sagte in Node.Js wird nicht gefunden:
        langsam gefällt mir deine Idee
        Ich glaube ich mach einfach ein ganz cleanen reinstall von allem
          Z Offline
          Z Offline
          Zlorsh
          @homoran Ja ist vermutlich das einfachste...
          Genau aus dem Grund hab ich nie Updates gemacht, never change a running system :)
          • Z Zlorsh
            Das war jetzt der falscheste Satz an der ungünstigsten Stelle!
            Deine Probleme hast du weil du so gehandelt hast.
              Z Offline
              Z Offline
              Zlorsh
              schrieb am zuletzt editiert von Zlorsh
              @homoran Ja, da könnte was dran sein, shame on me 😨🙊
              • Z Zlorsh
                Ich weiß nicht ob @Thomas-Braun noch Lust hat das tote Pferd wiederzubeleben. Könnte eine Herausforderung für ihn sein.
                Sonst mach am besten alles neu, angefangen vom aktuellen Raspberry Pi OS lite.
                und erzähl uns wenn du wieder in local installiert hast, wie du das gemacht hast. Interessiert uns brennend!
                • Z Zlorsh
                  So lange, bis dir das tolle running system komplett versumpft.
                  Ist dir hier passiert.
                    @homoran sagte in Node.Js wird nicht gefunden:
                    Ehrlich gesagt nicht. Wobei das Grundsystem ja jetzt wohl auf Stand ist.
                    Ist 'nur' noch der ioBroker in der Update-Falle versunken.
                      Z Offline
                      Z Offline
                      Zlorsh
                      Ich habe nun ganz neu installiert, trotzdem vielen Dank für eure Versuche mein Problem zu lösen.
                      Von mir aus kann der Thread gerne geschlossen werden.
